path: root/scripts/kconfig/util.c
2012-11-20kconfig: Fix malloc handling in conf toolsAlan Cox
(and get them out of the noise in the audit work) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-06kconfig: add missing <stdlib.h> inclusionArnaud Lacombe
This header is needed when using {m,re}alloc(3) and free(3) function family. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-06kconfig: add missing <stdarg.h> inclusionArnaud Lacombe
This header is needed when using va_{start,end,copy}(3) functions family. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2010-09-19kconfig: expand file namesArnaud Lacombe
This will allow to use the following construct in source files: config FOO string default "foo" source "$FOO/Kconfig" Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-03-15kconfig: util: Fix typo in commentThomas Weber
sting replaced with string Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-02menuconfig: wrap long help linesVadim Bendebury (вб)
Help text for certain config options is very extensive (the text includes the names of all other options the option in question depends on). Long lines are not wrapped, making it impossible to see the list without scrolling horizontally. This patch adds some logic which wraps help screen lines at word boundaries to prevent truncating. Tested by running ARCH=powerpc make menuconfig O=/tmp/build which shows that the long lines are now wrapped, and ARCH=powerpc make xconfig O=/tmp/build to demonstrate that it still compiles and operates as expected. Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-06-09kconfig: do not hardcode "include/config/auto.conf" filenameMarkus Heidelberg
Regardless of KCONFIG_AUTOCONFIG, the filename written as a Make target into "include/config/auto.conf.cmd" was always the default one. Of course this doesn't make it work for the Kernel kbuild system, since there the filename is hardcoded at several places in the Makefiles. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-19kconfig: incorrect 'len' field initialisation ?Christophe Jaillet
1) The field 'len' of the 'gstr' structure seems to track the size of the memory already allocated for the "growable string". So the value of this field should be the same as the 'malloc()' just above, shouldn't it ? Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: environment symbol supportRoman Zippel
Add the possibility to import a value from the environment into kconfig via the option syntax. Beside flexibility this has the advantage providing proper dependencies. Documented the options syntax. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kconfig: fix segv fault in menuconfigSam Ravnborg
With specific configurations requesting help for certain menu lines caused menuconfig to crash. This was tracked down to a null pointer bug. Thanks to "Miles Lane" <miles.lane@gmail.com> for inital reporting and to Gabriel C <nix.or.die@googlemail.com> for the backtrace that helped me locating the bug. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: fix .config dependenciesRoman Zippel
This fixes one of the worst kbuild warts left - the broken dependencies used to check and regenerate the .config file. This was done via an indirect dependency and the .config itself had an empty command, which can cause make not to reread the changed .config file. Instead of this we generate now a new file include/config/auto.conf from .config, which is used for kbuild and has the proper dependencies. It's also the main make target now for all files generated during this step (and thus replaces include/linux/autoconf.h). This also means we can now relax the syntax requirements for the .config file and we don't have to rewrite it all the time, i.e. silentoldconfig only writes .config now when it's necessary to keep it in sync with the Kconfig files and even this can be suppressed by setting the environment variable KCONFIG_NOSILENTUPDATE, so the update can (and must) be done manually. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-26kbuild: always run 'make silentoldconfig' when tree is cleanedSam Ravnborg
If the file .kconfig.d is missing then make sure to run 'make silentoldconfig', since we have no way to detect if a Kconfig file has been updated. -kconfig.d is created by kconfig and is removed as part of 'make clean' so the situation is likely to occur in reality. Jan Beulich <JBeulich@novell.com> reported this bug. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
