path: root/scripts/kconfig
2008-09-29kconfig: readd lost change countzippel@linux-m68k.org
Commit f072181e6403b0fe2e2aa800a005497b748fd284 ("kconfig: drop the ""trying to assign nonexistent symbol" warning") simply dropped the warnings, but it does a little more than that, it also marks the current .config as needed saving, so add this back. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-29kconfig: fix silentoldconfigzippel@linux-m68k.org
Recent changes to oldconfig have mixed up the silentoldconfig handling, so this fixes that by clearly separating that special mode, e.g. KCONFIG_NOSILENTUPDATE is only relevant here, the .config is written as needed. This will also properly close Bug 11230. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04kconfig: drop the ""trying to assign nonexistent symbol" warningSam Ravnborg
They really stand out now that make *config is less chatty - and they are generally ignored - so drop them. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@kernel.org>
2008-08-04kconfig: always write out .configSam Ravnborg
Always write out .config also in the case where config did not change. This fixes: http://bugzilla.kernel.org/show_bug.cgi?id=11230 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-07-30kconfig: scripts/kconfig/zconf.l: add %option noinputAdrian Bunk
gcc 4.3 correctly determines that input() is unused and gives the following warning: <-- snip --> ... HOSTCC scripts/kconfig/zconf.tab.o scripts/kconfig/lex.zconf.c:1628: warning: ‘input’ defined but not used ... <-- snip --> Fix it by adding %option noinput to scripts/kconfig/zconf.l and regeneration of scripts/kconfig/lex.zconf.c_shipped. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kconfig: make defconfig is no longer chattySam Ravnborg
make defconfig generated a lot of output then noone actually read. Use conf_set_all_new_symbols() to generate the default configuration and avoid the chatty output. A typical run now looks like this: $ make defconfig *** Default configuration is based on 'i386_defconfig' arch/x86/configs/i386_defconfig:13:warning: trying to assign nonexistent symbol SEMAPHORE_SLEEPERS arch/x86/configs/i386_defconfig:176:warning: trying to assign nonexistent symbol PREEMPT_BKL ... arch/x86/configs/i386_defconfig:1386:warning: trying to assign nonexistent symbol INSTRUMENTATION $ As an added benefit we now clearly see the warnings generated in the start of the process. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: make oldconfig is now less chattySam Ravnborg
Previously when running "make oldconfig" we saw all the propmt lines from kconfig and noone actully read this. With this patch the user will only see output if there is new symbols. This will be seen as "make oldconfig" runs which does not generate any output. A typical run now looks like this: $ make oldconfig scripts/kconfig/conf -o arch/x86/Kconfig $ If a new symbol is found then we restart the config process like this: $ make oldconfig scripts/kconfig/conf -o arch/x86/Kconfig * * Restart config... * * * General setup * Prompt for development and/or incomplete code/drivers (EXPERIMENTAL) [Y/n/?] y Local version - append to kernel release (LOCALVERSION) [] ... The bahaviour is similar to what we know when running the implicit oldconfig target "make silentoldconfig". "make silentoldconfig" are run as part of the kernel build process if the configuration has changed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: speed up all*config + randconfigSam Ravnborg
Drop the chatty mode when we generate the all*config, randconfig configurations. Ths speeds up the process considerably and noone looked at the output anyway. This patch uses the conf_set_all_new_symbols() function just added to kconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-07-25kconfig: set all new symbols automaticallyRoman Zippel
Add conf_set_all_new_symbols() which set all symbols (which don't have a value yet) to a specifed value. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-19kconfig: incorrect 'len' field initialisation ?Christophe Jaillet
1) The field 'len' of the 'gstr' structure seems to track the size of the memory already allocated for the "growable string". So the value of this field should be the same as the 'malloc()' just above, shouldn't it ? Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-04kconfig: fix MAC OS X warnings in menuconfigSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Timur Tabi <timur@freescale.com>
2008-05-01kconfig: made check-lxdialog more portableSam Ravnborg
OS-X shell did not like 'echo -e' so implement suggestion from Al Viro to use a more portable construct. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Acked-By: Timur Tabi <timur@freescale.com>
2008-04-28kconfig: add named choice groupRoman Zippel
As choice dependency are now fully checked, it's quite easy to add support for named choices. This lifts the restriction that a choice value can only appear once, although it still has to be within the same group, but multiple choices can be joined by giving them a name. While at it I cleaned up a little the choice type logic to simplify it a bit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kconfig: fix choice dependency checkRoman Zippel
Properly check the dependency of choices as a group. Also fix that sym_check_deps() correctly terminates the dependency loop error check (otherwise it would continue printing the dependency chain). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kconfig: reversed borderlines in inputboxRoel Kluin
Fix reversal of dlg.border.atr and dlg.dialog.atr for draw_box() Makes the inputbox look like expected Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kconfig: fix broken target update-po-configSam Ravnborg
Massimo Maiurana reported: In the latest kernel "make update-po-config" fails because it tries to open arch/Kconfig/Kconfig, since the ls command doesn't distinguish between files and directories. Cc: Massimo Maiurana <maiurana@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-13kconfig: fix select in combination with defaultRoman Zippel
> The attached .config (with current -git) results in a compile > error since it contains: > > CONFIG_X86=y > # CONFIG_EMBEDDED is not set > CONFIG_SERIO=m > CONFIG_SERIO_I8042=y > > Looking at drivers/input/serio/Kconfig I simply don't get how this > can happen. You've hit the rather subtle rules of select vs default. What happened is that SERIO is selected to m, but SERIO_I8042 isn't selected so the default of y is used instead. We already had the problem in the past that select and default don't work well together, so this patch cleans this up and makes the rule hopefully more straightforward. Basically now the value is calculated like this: (value && dependency) || select where the value is the user choice (if available and the symbol is visible) or default. In this case it means SERIO and SERIO_I8042 are both set to y due to their default and if SERIO didn't had the default, then the SERIO_I8042 value would be limited to m due to the dependency. I tested this patch with more 10000 random configs and above case is the only the difference that showed up, so I hope there is nothing that depended on the old more complex and subtle rules. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Tested-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03kconfig: ignore select of unknown symbolSam Ravnborg
We have had warnings for a long time about select of unknow symbol but the warnings does not really makes sense since we may select a symbol that is relevant and defined in one arch but not in another arch. And as long as we do not use a common set of Kconfig files for all archs lets just ignore this case. Previously we have used this to find bad uses of select but we need a more relaible method to do so. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-02-03kconfig: mark config as changed when loading an alternate configSam Ravnborg
Michal Zachar <mgzachar@mail.t-com.sk> reported that menuconfig did not save the new config when loading an alternate config unless he altered it manually. Mark config as changed upon load of alternate config fixed this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: tristate choices with mixed tristate and boolean valuesJan Beulich
Change kconfig behavior so that mixing bool and tristate config settings in a choice is possible and has the desired effect of offering just the tristate options individually if the choice gets set to M, and a normal boolean selection if the choice gets set to Y. Also fix scripts/kconfig/conf's handling of children of choice values - there may be more than one immediate child, and all of them need to be processed. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Roman Zippel" <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: remove "enable"Adrian Bunk
Kconfig had a synonym "enable" for "select" that was neither documented nor used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: use environment optionRoman Zippel
Use the environment option to provide the ARCH symbol and the KERNELVERSION symbol. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: environment symbol supportRoman Zippel
Add the possibility to import a value from the environment into kconfig via the option syntax. Beside flexibility this has the advantage providing proper dependencies. Documented the options syntax. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: explicitly introduce expression listRoman Zippel
Rename E_CHOICE to E_LIST to explicitly add support for expression lists. Add a helper macro expr_list_for_each_sym to more easily iterate over the list. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: gconfig: symbol fixEGRY Gabor
Gettext support for symbol names are unnecessary. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: gettext support for configEGRY Gabor
Gettext support for conf.c [Include locale.h by Kyle]. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Kyle McMartin <kyle@mcmartin.ca>
2008-01-28kconfig: gettext support for lxdialogEGRY Gabor
Gettext support for lxdialog. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: gettext support for menuconfigEGRY Gabor
Full gettext support for menuconfig. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: gettext support for xconfigEGRY Gabor
Full gettext support for xconfig. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: macro fix in menu.cEGRY Gabor
This patch removes the indirect I18N support for config file. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: gettext support for gconfigEGRY Gabor
Gettext support for menu and toolbar. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: missing macros in gconfigEGRY Gabor
This patch adds missing gettext macros. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: whitespace removingEGRY Gabor
This patch removes the unnecessary whitespaces from end of help lines of Kconfig files. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: update-po-config infoEGRY Gabor
This patch adds tracking messages. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: use C89 random functions in conf.cLadislav Michl
rand and srand functions conform also to C89 in addition to POSIX.1-2001, which makes them a bit more portable (work also on MinGW host). Linux man page also says: "The versions of rand() and srand() in the Linux C Library use the same random number generator as random() and srandom()". * Use C89 conformant functions rand() and srand() Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: fix whitespace and sort includes in conf.cLadislav Michl
Sort includes and remove leading whitespace. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org
2008-01-28kconfig: delete unused FILE_ and SYMBOL_ flagsSam Ravnborg
The *_PRINTED flags were never used - so delete them. Do we need them later then we can re-add them. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: rename E_OR & friends to avoid name clashSam Ravnborg
We had macros named the same as a set of enumeration values. It is legal code but very confusing to read - so rename the macros from E_* to EXPR_* Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: allow overriding symbolsJan Engelhardt
Allow config variables in .config to override earlier ones in the same file. In other words, # CONFIG_SECURITY is not defined CONFIG_SECURITY=y will activate it. This makes it a bit easier to do cat original-config myconfig myconfig2 ... >.config; and run *config as expected. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Randy Dunlap <randy.dunlap@oracle.com>
2008-01-28kconfig: make kconfig MinGW friendlyLadislav Michl
Kconfig is powerfull tool. So powerfull that more and more software projects are using it for configuration. So instead of fixing some of them one by one, lets fix it in kernel and wait for sync. This work was originaly done for PTXdist - GPL licensed build system for userlands and cross-compilers, but it will not hurt kernel kconfig either. PTXdist menuconfig now works on Windows linked with PDCurses and compiled using MinGW - there is no termios and signals. * Do not include <sys/wait.h> and <signal.h> (comes from times when lxdialog was separate process) * Do not mess with termios directly and let curses tell screen size. Comment to commit c8dc68ad0fbd934e78e913b8a8d7b45945db4930 says check for screen size could be removed later, but because it didn't happen for more than year I left it here as well. * Save cursor position added by Sam Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: use getopt() in conf.c for handling command line argumentsAndres Salomon
Switch from doing our own parsing of command line arguments to using getopt(3) to do it. Aside from simplifying things, this allows us to specify multiple arguments; the old code could only accept two arguments (input_mode and kconfig name). Note some subtle changes: - The argument '-?' is no longer supported. - '-h' is not treated as an error, so output goes to stdout, and we exit with '0'. - There is no compatibility checking amongst arguments; the last option will simply override earlier options. For example, 'conf -n -y foo' is perfectly valid now (input_mode will be set_yes). Previously, that would have been an error ("can't find file -y"). Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-01-28kconfig: if ncurses-devel is missing then say soSam Ravnborg
With this patch when ncurses-devel (or whatever it is named) is missing trying to run menuconfig will result in this: $ make menuconfig HOSTCC scripts/kconfig/conf.o HOSTCC scripts/kconfig/kxgettext.o *** Unable to find the ncurses libraries or the *** required header files. *** 'make menuconfig' requires the ncurses libraries. *** *** Install ncurses (ncurses-devel) and try again. *** make[1]: *** [scripts/kconfig/dochecklxdialog] Error 1 make: *** [menuconfig] Error 2 Much better than before where we just listed some build errors. The other *config targets will work indepenednt on ncurses being present or not. Includes improvements suggested by: Frans Pop <elendil@planet.nl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Frans Pop <elendil@planet.nl>
2007-12-23kconfig: obey KCONFIG_ALLCONFIG choices with randconfig.Paul Mundt
Currently when using KCONFIG_ALLCONFIG with randconfig the choice options are clobbered. As recommended by Roman, this adds an is_new test to see whether to select a new option or obey the existing one. This is a resend of the earlier patch a couple of weeks ago, since there was no reply. Original thread is at http://lkml.org/lkml/2007/11/28/94 Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-17x86: simplify "make ARCH=x86" and fix kconfig all.configSam Ravnborg
Simplify "make ARCH=x86" and fix kconfig so we again can set 64BIT in all.config. For a fix the diffstat is nice: 6 files changed, 3 insertions(+), 36 deletions(-) The patch reverts these commits: - 0f855aa64b3f63d35a891510cf7db932a435c116 ("kconfig: add helper to set config symbol from environment variable") - 2a113281f5cd2febbab21a93c8943f8d3eece4d3 ("kconfig: use $K64BIT to set 64BIT with all*config targets") Roman Zippel pointed out that kconfig supported string compares so the additional complexity introduced by the above two patches were not needed. With this patch we have following behaviour: # make {allno,allyes,allmod,rand}config [ARCH=...] option \ host arch | 32bit | 64bit ===================================================== ./. | 32bit | 64bit ARCH=x86 | 32bit | 32bit ARCH=i386 | 32bit | 32bit ARCH=x86_64 | 64bit | 64bit The general rule are that ARCH= and native architecture takes precedence over the configuration. So make ARCH=i386 [whatever] will always build a 32-bit kernel no matter what the configuration says. The configuration will be updated to 32-bit if it was configured to 64-bit and the other way around. This behaviour is consistent with previous behaviour so no suprises here. make ARCH=x86 will per default result in a 32-bit kernel but as the only ARCH= value x86 allow the user to select between 32-bit and 64-bit using menuconfig. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Herrmann <aherrman@arcor.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-12x86: enable "make ARCH=x86"Sam Ravnborg
After unification of the Kconfig files and introducing K64BIT support in kconfig it required only trivial changes to enable "make ARCH=x86". With this patch you can build for x86_64 in several ways: 1) make ARCH=x86_64 2) make ARCH=x86 K64BIT=y 3) make ARCH=x86 menuconfig => select 64-bit Likewise for i386 with the addition that i386 is default is you say ARCH=x86. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2007-11-12kconfig: use $K64BIT to set 64BIT with all*config targetsSam Ravnborg
The variable K64BIT can now be used to select the value of CONFIG_64BIT. This is for example useful for powerpc to generate allmodconfig for both bit sizes - like this: make ARCH=powerpc K64BIT=y make ARCH=powerpc K64BIT=n To use this the Kconfig file must use "64BIT" as the config value to select between 32 and 64 bit. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-11-12kconfig: add helper to set config symbol from environment variableSam Ravnborg
Add conf_set_env_sym() that can set an already defined symbol based on the value of an environment variable. Unknown symbols are silently ignored. A warning is printed if the value of the environment variable is unexpected. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-11-12kconfig: factor out code in confdata.cSam Ravnborg
This patch introduce no functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2007-10-25x86: move i386 and x86_64 Kconfig files to x86 directorySam Ravnborg
After a small change in kconfig Makefile we could move all x86 Kconfig files to x86 directory. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-25kconfig: small code refactoring in kconfig MakefileSam Ravnborg
Do not hardcode the arch/$(ARCH)/Kconfig name all over Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
