path: root/scripts/kconfig
2011-06-09kconfig: regen parserArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kconfig: migrate parser to implicit rulesArnaud Lacombe
2011-06-09kconfig/zconf.l: do not ask to generate backupArnaud Lacombe
This avoids the creation of a top-level `lex.backup' when the lexer gets re-generated. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-06-09kconfig: kill no longer needed reference to YYDEBUGArnaud Lacombe
2011-06-09kconfig: constify `kconf_id_lookup'Arnaud Lacombe
2011-05-25xconfig: merge code path to conf_write()Arnaud Lacombe
Avoid to have multiple path saving the config. This fixes an error check miss when the window is being closed and the user requested the config to be written. Reported-by: Hiromu Yakura <hiromu1996@gmail.com> Pointed-out-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24kconfig: do not record timestamp in .configArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: Hide unused left treeview when start up the interfaceEduardo Silva
When the gconfig program starts in full mode view, it shows the left treeview which belongs to the 'split mode view'. The patch fix this visual issue. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24gconfig: enable rules hint for main treeviewsEduardo Silva
Due to the large amount of rows in the treeviews, is difficult to match columns with rows, setting the rules hint to 'true' allows the treeview to alternate background colors in the rows making the data more readable. Signed-off-by: Eduardo Silva <edsiper@gmail.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-29kconfig: quiet commands when V=0Peter Foley
Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-29kconfig: change update-po-config to reflect new layout of arch/umPeter Foley
2011-04-29kconfig: make update-po-config work in KBUILD_OUTPUTPeter Foley
2011-04-29kconfig: rearrange clean-filesPeter Foley
2011-04-29kconfig: change gconf to modify hostprogs-y like nconf and mconfPeter Foley
2011-04-29kconfig: change qconf to modify hostprogs-y like nconf and mconfPeter Foley
2011-04-29kconfig: only build kxgettext when neededPeter Foley
2011-04-19nconfig: Silence unused return values from wattrsetStephen Boyd
Ignore the return value from wattrset since we ignore the return value in nconf.gui.c as well. scripts/kconfig/nconf.c: In function 'print_function_line': scripts/kconfig/nconf.c:376: warning: value computed is not used scripts/kconfig/nconf.c:380: warning: value computed is not used scripts/kconfig/nconf.c:387: warning: value computed is not used scripts/kconfig/nconf.c: In function 'show_menu': scripts/kconfig/nconf.c:956: warning: value computed is not used scripts/kconfig/nconf.c:961: warning: value computed is not used scripts/kconfig/nconf.c:963: warning: value computed is not used scripts/kconfig/nconf.c:965: warning: value computed is not used Cc: Nir Tzachar <nir.tzachar@gmail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-18kconfig: Do not record timestamp in auto.conf and autoconf.hMichal Marek
Timestamps in file data are useless and there is already one in .config Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-15kconfig: get rid of unused flagsYann E. MORIN
Now that we detect recusrion of sourced files, get rid of now unused flags. Regenerate lex.zconf.c_shipped file. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@anciens.enib.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-15kconfig: allow multiple inclusion of the same fileYann E. MORIN
Allow 'source'ing the same file from multiple places (eg. from different files, and/or under different conditions). To avoid circular inclusion, scan the source-ancestry of the current file, and abort if already sourced in this branch. Regenerate the pre-parsed lex.zconf.c_shipped file. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@anciens.enib.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-04-08kconfig: Avoid buffer underrun in choice inputBen Hutchings
commit 40aee729b350672c2550640622416a855e27938f ('kconfig: fix default value for choice input') fixed some cases where kconfig would select the wrong option from a choice with a single valid option and thus enter an infinite loop. However, this broke the test for user input of the form 'N?', because when kconfig selects the single valid option the input is zero-length and the test will read the byte before the input buffer. If this happens to contain '?' (as it will in a mips build on Debian unstable today) then kconfig again enters an infinite loop. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@kernel.org [2.6.17+] Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-08trivial: Fix Steven's Copyright typosUwe Kleine-König
OK, the copyright allows you to write a copy, still I think the lawyers prefer the correct spelling. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> LKML-Reference: <1295899921-11333-1-git-send-email-u.kleine-koenig@pengutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-10Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: nconf: handle comment entries within choice/endchoice kconfig: fix warning kconfig: Make expr_copy() take a const argument kconfig: simplify select-with-unmet-direct-dependency warning kconfig: add more S_INT and S_HEX consistency checks kconfig: fix `zconfdebug' extern declaration kconfig/conf: merge duplicate switch's case kconfig: fix typos kbuild/gconf: add dummy inline for bind_textdomain_codeset() kbuild/nconf: fix spaces damage kconfig: nuke second argument of conf_write_symbol() kconfig: do not define AUTOCONF_INCLUDED kconfig: the day kconfig warns about "select"-abuse has come
2011-01-07nconf: handle comment entries within choice/endchoicePeter Korsgaard
Equivalent to af6c1598 (kconfig: handle comment entries within choice/endchoice), but for nconfig instead. Implement support for comment entries within choice groups. Comment entries are displayed visually distinct from normal configs, and selecting them is a no-op. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-29kconfig: fix undesirable side effect of adding "visible" menu attributeJan Beulich
This lead to non-selected, non-user-selectable options to be written out to .config. This is not only pointless, but also preventing the user to be prompted should any of those options eventually become visible (e.g. by de-selecting the *_AUTO options the "visible" attribute was added for. Furthermore it is quite logical for the "visible" attribute of a menu to control the visibility of all contained prompts, which is what the patch does. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-27kconfig: fix warningArnaud Lacombe
In file included from scripts/kconfig/zconf.tab.c:2502: scripts/kconfig/expr.c:1033: warning: no previous prototype for 'expr_simplify_unmet_dep' Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-21kconfig: Make expr_copy() take a const argumentMichal Marek
Fixes scripts/kconfig/expr.c: In function ‘expr_get_leftmost_symbol’: scripts/kconfig/expr.c:1026:2: warning: passing argument 1 of ‘expr_copy’ discards qualifiers from pointer target type scripts/kconfig/expr.c:67:14: note: expected ‘struct expr *’ but argument is of type ‘const struct expr *’ Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-21kconfig: simplify select-with-unmet-direct-dependency warningArnaud Lacombe
This is an attempt to simplify the expressing printed by kconfig when a symbol is selected but still has direct unmet dependency. First, the symbol reverse dependency is split in sub-expression. Then, each sub-expression is checked to ensure that it does not contains the unmet dependency. This removes the false-positive symbols and fixed symbol which already have the correct dependency. Finally, only the symbol responsible of the "select" is printed, instead of its full dependency tree. CC: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kconfig: add more S_INT and S_HEX consistency checksArnaud Lacombe
This patch add more number consistency checkg, trying to catch the following situation: config FOO0 hex default 42 config FOO1 string config BAR0 int default FOO1 config BAR1 hex default FOO1 config FOO2 hex default 42h config FOO3 int default "1bar" Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kconfig: fix `zconfdebug' extern declarationArnaud Lacombe
This symbol is only exist if YYDEBUG is defined. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kconfig/conf: merge duplicate switch's caseArnaud Lacombe
2010-12-15kconfig: fix typosArnaud Lacombe
2010-12-15kbuild/gconf: add dummy inline for bind_textdomain_codeset()Arnaud Lacombe
This symbols is used by gconf. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kbuild/nconf: fix spaces damageArnaud Lacombe
2010-12-15kconfig: nuke second argument of conf_write_symbol()Arnaud Lacombe
Replacing S_TRISTATE by S_BOOLEAN is a no-op for conf_write_symbol(). Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> [mmarek: Fix unused variable warning in conf_write()] Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kconfig: do not define AUTOCONF_INCLUDEDArnaud Lacombe
AUTOCONF_INCLUDED is not checked is not used within the tree and its parent header, `autoconf.h', is safe to be re-included. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-11-22kconfig: regen parserArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-22kconfig: add an option to determine a menu's visibilityArnaud Lacombe
This option is aimed to add the possibility to control a menu's visibility without adding dependency to the expression to all the submenu. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Tested-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-01kconfig: sym_expand_string_value: allow for string termination when reallocingAndy Whitcroft
When expanding a parameterised string we may run out of space, this triggers a realloc. When computing the new allocation size we do not allow for the terminating '\0'. Allow for this when calculating the new length. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29kconfig: Have streamline_config process menuconfigs tooSteven Rostedt
Some menuconfigs in the Kconfig files have prompts and dependencies. Currently, streamline_config misses these, and this can cause streamline_config to keep modules enabled that should not be, and even worse, not enable those that should. This patch makes streamline_config process menuconfigs just like it would process a config. Reported-by: member graysky <graysky@archlinux.us> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29kconfig: Fix streamline_config to read multi line deps in Kconfig filesSteven Rostedt
I noticed that some Kconfig files have multi line dependencies that continue with a backslash. Those dependencies on the next line will be missed by streamline_config. For example: config CS89x0 tristate "CS89x0 support" depends on NET_ETHERNET && (ISA || EISA || MACH_IXDP2351 \ || ARCH_IXDP2X01 || MACH_MX31ADS) The "|| ARCH_IXDP2X01 || MACH_MX31ADS)" will not be processed. This patch adds code to handle this case. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29kconfig: Fix missing declaration of variable $dir in streamline_config.plhiromu
On Fri, Aug 17, 2010 at 01:43PM +0800, Américo Wang wrote: > Acked-by: WANG Cong <xiyou.wangcong@gmail.com> > > BTW, I think we should add "use strict;" too. Then I added "use strict;" to streamline_config.pl, I saw another warning. > Global symbol "$dir" requires explicit package name at scripts/kconfig/streamline_config.pl line 286. > Global symbol "$dir" requires explicit package name at scripts/kconfig/streamline_config.pl line 287. > Global symbol "$dir" requires explicit package name at scripts/kconfig/streamline_config.pl line 288. Then I added "my $dir;" to line 285. Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: Toralf Foerster <toralf.foerster@gmx.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hiromu Yakura <hiromu1996@gmail.com> LKML-Reference: <1282042158.7160.9.camel@hiromu-Macbook> [ changed to just add my in front of $dir instead of new line ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29kconfig: Fix variable name typo %prompts in streamline_config.plhiromu yagura
When I added "use strict;" to streamline_config.pl, I saw the following warnings: > Global symbol "%prompt" requires explicit package name at scripts/kconfig/streamline_config.pl line 183. > Global symbol "%prompt" requires explicit package name at scripts/kconfig/streamline_config.pl line 368. The declaration of %prompt was incorrect, and should have been %prompts. Cc: Toralf Foerster <toralf.foerster@gmx.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Hiromu Yakura <hiromu1996@gmail.com> LKML-Reference: <1281845597.11566.5.camel@camp10-laptop> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-29kconfig: Make localmodconfig handle environment variablesSteven Rostedt
The commit 838a2e55e6a4e9e8a10451ed2ef0f7a08dabdb04 kbuild: migrate all arch to the kconfig mainmenu upgrade Broke make localmodconfig. The reason was that it added a environment variable to the kconfig source, which the streamline_config.pl could not handle. This patch changes streamline_config.pl to handle kconfig sources using environment variables in their names. Cc: Arnaud Lacombe <lacombar@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-28Merge branch 'message-callback' into kbuild/kconfigMichal Marek
Conflicts: scripts/kconfig/nconf.c
2010-10-12Revert "kconfig: Temporarily disable dependency warnings"Michal Marek
This reverts commit 71ebc01, which was a 2.6.36-only stopgap solution. Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-12Merge branch 'kbuild/rc-fixes' into kbuild/kconfigMichal Marek
We need to revert the temporary hack in 71ebc01, hence the merge.
2010-10-09kbuild: fix oldnoconfig to do the right thingKyle McMartin
Commit 861b4ea4 broke oldnoconfig when removed the oldnoconfig checks on if (input_mode == nonint_oldconfig || input_mode == oldnoconfig) { if (input_mode == nonint_oldconfig && sym->name && !sym_is_choice_value(sym)) { to avoid oldnoconfig chugging through the else stanza. Fix that to restore expected behaviour (which I've confirmed in the Fedora kernel build that the configs end up looking the same.) Signed-off-by: Kyle McMartin <kyle@redhat.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-09kconfig: Temporarily disable dependency warningsMichal Marek
After fixing a use-after-free bug in kconfig, a 'make defconfig' or 'make allmodconfig' fills the screen with warnings that were not detected before. Given that we are close to the release now, disable the warnings temporarily and deal with them after 2.6.36. Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-04kconfig: Use PATH_MAX instead of 128 for path buffer sizes.Will Newton
This prevents the buffers being overflowed when using a config file with a long name. PATH_MAX is used elsewhere in the same file, so use it here as well. Signed-off-by: Will Newton <will.newton@imgtec.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
