path: root/scripts/link-vmlinux.sh
2012-09-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin Pull blackfin updates from Bob Liu: "One kbuild and a smp build fix." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin: kbuild: add symbol prefix arg to kallsyms blackfin: smp: adapt to generic smp helpers
2012-09-11kbuild: add symbol prefix arg to kallsymsJames Hogan
Commit 1f2bfbd00e466ff3489b2ca5cc75b1cccd14c123 ("kbuild: link of vmlinux moved to a script") introduced in v3.5-rc1 broke kallsyms on architectures which have symbol prefixes. The --symbol-prefix argument used to be added to the KALLSYMS command line from the architecture Makefile, however this isn't picked up by the new scripts/link-vmlinux.sh. This resulted in symbols like kallsyms_addresses being added which weren't correctly overriding the weak symbols such as _kallsyms_addresses. These could then trigger BUG_ONs in kallsyms code. This is fixed by removing the KALLSYMS addition from the architecture Makefile, and using CONFIG_SYMBOL_PREFIX in the link-vmlinux.sh script to determine whether to add the --symbol-prefix argument. Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-08-10link-vmlinux.sh: Fix stray "echo" in error messageMichal Marek
Reported-by: Jan Engelhardt <jengelh@inai.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-07kbuild: Print errors to stderrMichal Marek
... at least in the top-level Makefile and scripts/link-vmlinux.sh. There are some more instances of the 'echo <error>; exit 1' pattern in some arch Makefiles and kconfig. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-05-28Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek. Fixed up nontrivial merge conflict in Makefile as per Stephen Rothwell and linux-next (and trivial arch/sparc/Makefile changes due to removed sparc32 logic). * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: mips: Fix KBUILD_CPPFLAGS definition kbuild: fix ia64 link kbuild: document KBUILD_LDS, KBUILD_VMLINUX_{INIT,MAIN} and LDFLAGS_vmlinux kbuild: link of vmlinux moved to a script kbuild: refactor final link of sparc32 kbuild: drop unused KBUILD_VMLINUX_OBJS from top-level Makefile kbuild: Makefile: remove unnecessary check for m68knommu ARCH
2012-05-10kbuild: fix ia64 linkSam Ravnborg
ia64 build failed like this: CC init/version.o LD init/built-in.o KSYM .tmp_kallsyms1.o ld: .tmp_kallsyms1.o: linking constant-gp files with non-constant-gp files ld: failed to merge target specific data of file .tmp_kallsyms1.o make: *** [vmlinux] Error 1 This was introduced when link of vmlinux was migrated to a script. Add missing option to as to fix this. Reported-by: Tony Luck <tony.luck@gmail.com> Tested-by: Tony Luck <tony.luck@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-05-05kbuild: link of vmlinux moved to a scriptSam Ravnborg
Move the final link of vmlinux to a script to improve readability and maintainability of the code. The Makefile fragments used to link vmlinux has over the years seen far too many changes and the logic had become hard to follow. As the process by nature is serialized there was nothing gained including this in the Makefile. "um" has special link requirments - and the only way to handle this was to hard-code the linking of "um" in the script. This was better than trying to modularize it only for the benefit of "um" anyway. The shell script has been improved after input from: Arnaud Lacombe <lacombar@gmail.com> Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Arnaud Lacombe <lacombar@gmail.com> Cc: Nick Bowler <nbowler@elliptictech.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
