path: root/scripts/mkmakefile
2019-04-02kbuild: mkmakefile: generate a simple wrapper of top MakefileMasahiro Yamada
Now that Kbuild is able to start from any directory, the generated Makefile can simply wrap the top Makefile. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Kieran Bingham <kbingham@kernel.org>
2019-04-02kbuild: mkmakefile: do not check the generated Makefile markerMasahiro Yamada
This hunk was added to avoid accidental overwrite of the top Makefile in case O= points to the top of the source tree. As commit 4f1127e20437 ("kbuild: fix infinite make recursion"), it caused some troubles in the past because Kbuild assumes O= as out-of-tree build, while it actually works in the source tree. Now this works more properly; if O= points to the source directory, it is handled as in-tree build. So, this sanity check is unneeded. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-04kbuild: simplify command line creation in scripts/mkmakefileMasahiro Yamada
Assuming we never invoke the generated Makefile from outside of the $(objtree) directory, $(CURDIR) points to the absolute path of $(objtree). BTW, 'lastword' is natively supported by GNU Make 3.81+, which is the current requirement for building the kernel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-04kbuild: do not pass $(objtree) to scripts/mkmakefileMasahiro Yamada
Since $(objtree) is always '.', it is not useful to pass it to scripts/mkmakefile. I assume nobody wants to run this script directly. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-04kbuild: remove user ID check in scripts/mkmakefileMasahiro Yamada
This line was added by commit fd5f0cd6b0ce ("kbuild: Do not overwrite makefile as anohter user"). Its commit description says the intention was to prevent $(objtree)/Makefile from being owned by root when e.g. running 'make install'. However, as commit 19514fc665ff ("arm, kbuild: make "make install" not depend on vmlinux") stated, installation targets must not modify the source tree in the first place. If they do, we are already screwed up. We must fix the root cause. Installation targets should just copy files verbatim, hence we never expect $(objtree)/Makefile is touched by root. The user ID check in scripts/mkmakefile is unneeded. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-10-04kbuild: remove VERSION and PATCHLEVEL from $(objtree)/MakefileMasahiro Yamada
Neither VERSION nor PATCHLEVEL is used in any useful way. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-20kbuild: Make scripts executableMichal Marek
The Makefiles call the respective interpreter explicitly, but this makes it easier to use the scripts manually. Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-04-30kbuild: support simultaneous "make %config" and "make all"Masahiro Yamada
Kbuild is supposed to support mixed targets. (%config and build targets) But "make all" did nothing if it was run with configuration targets. For example, $ LANG=C make defconfig all HOSTCC scripts/basic/fixdep HOSTCC scripts/kconfig/conf.o SHIPPED scripts/kconfig/zconf.tab.c SHIPPED scripts/kconfig/zconf.lex.c SHIPPED scripts/kconfig/zconf.hash.c HOSTCC scripts/kconfig/zconf.tab.o HOSTLD scripts/kconfig/conf *** Default configuration is based on 'x86_64_defconfig' # # configuration written to .config # make: Nothing to be done for `all'. This commits allows "make %config all" and makes sure mixed targets are built one by one in the given order. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Marek <mmarek@suse.cz> CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-07-20kbuild: silence generated makefile messagePeter Foley
This patch silences the "make -C /usr/src/git O=/usr/src/git/build/." message shown when using the generated makefile in KBUILD_OUTDIR. Signed-off-by: Peter Foley <pefoley2@verizon.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-17fixes for using make 3.82Jan Beulich
It doesn't like pattern and explicit rules to be on the same line, and it seems to be more picky when matching file (or really directory) names with different numbers of trailing slashes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Andrew Benton <b3nton@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2008-12-03kbuild: teach mkmakfile to be silentSam Ravnborg
With this fix a "make -s" is now really silent Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: scripts/mkmakefile: dynamic determination of output directoryJan Beulich
Rather than fixing the output directory in the generated Makefile, determine it from the placement of Makefile. This allows moving the build tree around or accessing it through different mount paths. (The lastword definition is a compatibility one for make prior to 3.81; newer make will simply ignore it and use the [faster] built-in.) Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-12-13kbuild: re-enable Makefile generation in a new O=... directoryGuillaume Chazarain
The commit: 18c32dac75b187d1a4e858f3cfdf03e844129f5e "kbuild: fix building with O=.. options" disabled the creation of a Makefile in a new O=... directory. Restore it. Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-12-09kbuild: fix building with O=.. optionsSam Ravnborg
The check introduced in commit: 4f1127e204377cbd2a56d112d323466f668e8334 "kbuild: fix infinite make recursion" caused certain external modules not to build and also caused 'make targz-pkg' to fail. This is a minimal fix so we revert to previous behaviour - but we do not overwrite the Makefile in the top-level directory. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Jay Cliburn <jacliburn@bellsouth.net> Cc: Jay Cliburn <jacliburn@bellsouth.net>
2007-10-12kbuild: call make once for all targets when O=.. is usedMilton Miller
Change the invocations of make in the output directory Makefile and the main Makefile for separate object trees to pass all goals to one $(MAKE) via a new phony target "sub-make" and the existing target _all. When compiling with separate object directories, a separate make is called in the context of another directory (from the output directory the main Makefile is called, the Makefile is then restarted with current directory set to the object tree). Before this patch, when multiple make command goals are specified, each target results in a separate make invocation. With make -j, these invocations may run in parallel, resulting in multiple commands running in the same directory clobbering each others results. I did not try to address make -j for mixed dot-config and no-dot-config targets. Because the order does matter, a solution was not obvious. Perhaps a simple check for MAKEFLAGS having -j and refusing to run would be appropriate. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-05-08kbuild: Do not overwrite makefile as anohter userJan Beulich
Change the conditional of the outputmakefile rule to be evaluated entirely in make, and add a conditional to not touch the generated makefile when e.g. running 'make install' as root while the build was done as non-root. Also adjust the comment describing this, and move the message printing and redirection to mkmakefile. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-02-19kbuild: fix mkmakefileJan Beulich
With the current way of generating the Makefile in the output directory for builds outside of the source tree, specifying real targets (rather than phony ones) doesn't work in an already (partially) built tree, as the stub Makefile doesn't have any dependency information available. Thus, all targets where files may actually exist must be listed explicitly and, due to what I'd call a make misbehavior, directory targets must then also be special cased. Signed-Off-By: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
