path: root/scripts/mod
2008-10-06Marker depmod fix core kernel listMathieu Desnoyers
* Theodore Ts'o (tytso@mit.edu) wrote: > > I've been playing with adding some markers into ext4 to see if they > could be useful in solving some problems along with Systemtap. It > appears, though, that as of 2.6.27-rc8, markers defined in code which is > compiled directly into the kernel (i.e., not as modules) don't show up > in Module.markers: > > kvm_trace_entryexit arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-intel %u %p %u %u %u %u %u %u > kvm_trace_entryexit arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > kvm_trace_handler arch/x86/kvm/kvm-amd %u %p %u %u %u %u %u %u > > (Note the lack of any of the kernel_sched_* markers, and the markers I > added for ext4_* and jbd2_* are missing as wel.) > > Systemtap apparently depends on in-kernel trace_mark being recorded in > Module.markers, and apparently it's been claimed that it used to be > there. Is this a bug in systemtap, or in how Module.markers is getting > built? And is there a file that contains the equivalent information > for markers located in non-modules code? I think the problem comes from "markers: fix duplicate modpost entry" (commit d35cb360c29956510b2fe1a953bd4968536f7216) Especially : - add_marker(mod, marker, fmt); + if (!mod->skip) + add_marker(mod, marker, fmt); } return; fail: Here is a fix that should take care if this problem. Thanks for the bug report! Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Tested-by: "Theodore Ts'o" <tytso@mit.edu> CC: Greg KH <greg@kroah.com> CC: David Smith <dsmith@redhat.com> CC: Roland McGrath <roland@redhat.com> CC: Sam Ravnborg <sam@ravnborg.org> CC: Wenji Huang <wenji.huang@oracle.com> CC: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-21pnp: fix "add acpi:* modalias entries"Kay Sievers
With 22454cb99fc39f2629ad06a7eccb3df312f8830e we added only the first entry of the device table. We need to loop over the whole device list. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-30scripts/mod/modpost.c: fix spelling of module and happensBen Dooks
Spelling fixes in scripts/mod/modpost.c Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24remove the v850 portAdrian Bunk
Trying to compile the v850 port brings many compile errors, one of them exists since at least kernel 2.6.19. There also seems to be noone willing to bring this port back into a usable state. This patch therefore removes the v850 port. If anyone ever decides to revive the v850 port the code will still be available from older kernels, and it wouldn't be impossible for the port to reenter the kernel if it would become actively maintained again. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (79 commits) arm: bus_id -> dev_name() and dev_set_name() conversions sparc64: fix up bus_id changes in sparc core code 3c59x: handle pci_name() being const MTD: handle pci_name() being const HP iLO driver sysdev: Convert the x86 mce tolerant sysdev attribute to generic attribute sysdev: Add utility functions for simple int/ulong variable sysdev attributes sysdev: Pass the attribute to the low level sysdev show/store function driver core: Suppress sysfs warnings for device_rename(). kobject: Transmit return value of call_usermodehelper() to caller sysfs-rules.txt: reword API stability statement debugfs: Implement debugfs_remove_recursive() HOWTO: change email addresses of James in HOWTO always enable FW_LOADER unless EMBEDDED=y uio-howto.tmpl: use unique output names uio-howto.tmpl: use standard copyright/legal markings sysfs: don't call notify_change sysdev: fix debugging statements in registration code. kobject: should use kobject_put() in kset-example kobject: reorder kobject to save space on 64 bit builds ...
2008-07-22markers: fix duplicate modpost entryMathieu Desnoyers
When a kernel was rebuilt, the previous Module.markers was not cleared. It caused markers with different format strings to appear as duplicates when a markers was changed. This problem is present since scripts/mod/modpost.c started to generate Module.markers, commit b2e3e658b344c6bcfb8fb694100ab2f2b5b2edb0 It therefore applies to 2.6.25, 2.6.26 and linux-next. I merely merged the patches from Roland, Wenji and Takashi here. Credits to Roland McGrath <roland@redhat.com> Wenji Huang <wenji.huang@oracle.com> and Takashi Nishiie <t-nishiie@np.css.fujitsu.com> for providing the individual fixes. - Changelog : - Integrated Takashi's Makefile modification to clear Module.markers upon make clean. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Roland McGrath <roland@redhat.com> Cc: Wenji Huang <wenji.huang@oracle.com> Cc: Takashi Nishiie <t-nishiie@np.css.fujitsu.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21pnp: add acpi:* modalias entriesKay Sievers
Along with the non-modalias conformant "pnp:*" aliases, we add "acpi:*" entries to PNP drivers, to allow module autoloading by ACPI PNP device entries, which export proper modalias information, without any specific userspace modprobe mangling. Cc: Adam Belay <ambx1@neo.rr.com> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-14[S390] cio: Introduce modalias for css bus.Cornelia Huck
Add modalias and subchannel type attributes for all subchannels. I/O subchannel specific attributes are now created in io_subchannel_probe(). modalias and subchannel type are also added to the uevent for the css bus. Also make the css modalias known. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-06-12kbuild: ignore powerpc specific symbols in modpostSam Ravnborg
Kumar Gala <galak@kernel.crashing.org> wrote: We have a case in powerpc in which we want to link some library routines with all module objects. The routines are intended for handling out-of-line function call register save/restore so having them as EXPORT_SYMBOL() is counter productive (we do also need to link the same "library" code into the kernel). Without this patch a powerpc build would error out and fail to build modules with the added register save/restore module. There were two obvious solutions: 1) To link the .o file before the modpost stage 2) To ignore the symbols in modpost Option 1) was ruled out because we do not have any separate linking stage for single file modules. This patch implements option 2 - and do so only for powerpc. The symbols we ignore are all undefined symbols named: _restgpr_*, _savegpr_*, _rest32gpr_*, _save32gpr_* Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org>
2008-05-11kbuild: disable modpost warnings for linkonce sectionsAndi Kleen
Disable modpost warnings for linkonce sections My build gives lots of warnings like WARNING: sound/core/snd.o (.gnu.linkonce.wi.mpspec_def.h.30779716): unexpected section name. The (.[number]+) following section name are ld generated and not expected. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. But for .linkonce. duplicated sections are actually ok and expected. So just disable the warning for this case. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-04modpost: i2c aliases need no trailing wildcardJean Delvare
Not all device types need a wildcard at the end of their module aliases. In particular, for i2c module aliases, the trailing wildcard is not only unneeded, it could also cause the wrong driver to be loaded. As I2C devices have no IDs, i2c module aliases are simple, arbitrary device names. For example: $ /sbin/modinfo lm90 filename: /lib/modules/2.6.25-git18/kernel/drivers/hwmon/lm90.ko author: Jean Delvare <khali@linux-fr.org> description: LM90/ADM1032 driver license: GPL vermagic: 2.6.25-git18 mod_unload depends: hwmon alias: i2c:lm90* alias: i2c:adm1032* alias: i2c:lm99* alias: i2c:lm86* alias: i2c:max6657* alias: i2c:adt7461* alias: i2c:max6680* $ This would cause trouble if one I2C chip name matches the beginning of another I2C chip name and both chips are supported by different drivers. For example, an i2c device named lm9042 would cause the lm90 driver to be loaded, while it doesn't support that device. This case has yet to be seen in practice, but still, I'd like to fix it now. The cleanest fix is to remove the trailing wildcard from i2c module aliases. Here's a patch doing this. Not all device type aliases need a trailing wildcard, in particular the i2c aliases don't. Don't add a wildcard by default in do_table(), instead let each device type handler add it if needed. I have tested types acpi, dmi, eisa, i2c, ide, ieee1394, input, pci, pcmcia, platform, pnp, scsi, serio, ssb and usb. Other types (ccw, of, vio, parisc, sdio and virtio) are untested. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-26kbuild: soften MODULE_LICENSE checkSam Ravnborg
Only modules that has other MODULE_* content shall have the MODULE_LICENSE() tag. This fixes allmodconfig build on my box. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: support loading extra symbols in modpostRichard Hacker
This patch adds a new command line option -E to modpost, expecting a symbol file as an argument which is read prior to symbol processing. -E can be supplied multiple times for as many files as is needed. When building kernel modules that depend on other modules not in the main kernel tree, modpost complains about undefined symbols: # make -C /path/to/linux/kernel M=/path/to/my/module ... Building modules, stage 2. .... WARNING: "rt_copy_buf" [/home/rich/osc_etl_rtw/osc_kmod.ko] undefined! ...etc This situation occurs when modpost processes the new module's symbols. When it finds symbols not exported by the mainline kernel, it issues this warning. The patch adds a new command line option -e to modpost which expects a symbol file as an argument. The symbols listed in this file are added to modpost's symbol tables during startup. -e can be supplied as often as required. This patch works together with the second patch. It introduces a new make variable, KBUILD_EXTRA_SYMBOLS, which is used when calling modpost. Signed-off-by: Richard Hacker <lerichi@gmx.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: error out on missing MODULE_LICENSESam Ravnborg
Adrian Bunk suggested a build time check for missing MODULE_LICENSE annotation in modules. The build time check is fatal as we really want this fixed for all modules. In-tree modules should all have been fixed up by now. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@kernel.org>
2008-04-19PNP: add all PNP card device id's as individual aliasesKay Sievers
The current PNP combined card + devices module aliase can never ever match anything, because these values are not available all at the same time to request a module. Instead of adding the combined alias, we add the device id's all as individual aliases. Device id's are exported by the PNP bus and can now properly used to request the loading of a matching module. The module snd-sbawe currently exports aliases, which can never match anything: alias: pnp:cCTLXXXXdCTL0045dCTL0022* alias: pnp:cCTLXXXXdCTL0044dCTL0023* alias: pnp:cCTLXXXXdCTL0042dCTL0022* alias: pnp:cCTLXXXXdCTL0041dCTL0021* alias: pnp:cCTLXXXXdCTL0031dCTL0021* alias: pnp:cCTL00eddCTL0041dCTL0070* alias: pnp:cCTL00e9dCTL0045dCTL0022* alias: pnp:cCTL00e4dCTL0045dCTL0022* alias: pnp:cCTL00c7dCTL0045dCTL0022* alias: pnp:cCTL00c5dCTL0045dCTL0022* alias: pnp:cCTL00c3dCTL0045dCTL0022* alias: pnp:cCTL00c1dCTL0042dCTL0022* alias: pnp:cCTL00b2dCTL0044dCTL0023* alias: pnp:cCTL009edCTL0044dCTL0023* alias: pnp:cCTL009ddCTL0042dCTL0022* alias: pnp:cCTL009fdCTL0041dCTL0021* alias: pnp:cCTL009cdCTL0041dCTL0021* alias: pnp:cCTL009adCTL0041dCTL0021* alias: pnp:cCTL0054dCTL0031dCTL0021* alias: pnp:cCTL0048dCTL0031dCTL0021* alias: pnp:cCTL0047dCTL0031dCTL0021* alias: pnp:cCTL0046dCTL0031dCTL0021* alias: pnp:cCTL0045dCTL0031dCTL0021* alias: pnp:cCTL0044dCTL0031dCTL0021* alias: pnp:cCTL0043dCTL0031dCTL0021* alias: pnp:cCTL0042dCTL0031dCTL0021* alias: pnp:cCTL0039dCTL0031dCTL0021* alias: pnp:cCTL0035dCTL0031dCTL0021* With this patch it exports only the device id's, as properly matchable aliases: alias: pnp:dCTL0070* alias: pnp:dCTL0045* alias: pnp:dCTL0023* alias: pnp:dCTL0044* alias: pnp:dCTL0022* alias: pnp:dCTL0042* alias: pnp:dCTL0041* alias: pnp:dCTL0021* alias: pnp:dCTL0031* Now, the exported value of the PNP bus can be used to autoload a matching module: $ modprobe --first-time -n -v pnp:dCTL0045 insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-rawmidi.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/mpu401/snd-mpu401-uart.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-hwdep.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb-common.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-csp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-dsp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/opl3/snd-opl3-lib.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sbawe.ko $ grep CTL0045 /sys/bus/pnp/devices/*/id /sys/bus/pnp/devices/01:01.00/id:CTL0045 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-23kbuild: soften modpost checks when doing cross buildsSam Ravnborg
The module alias support in the kernel have a consistency check where it is checked that the size of a structure in the kernel and on the build host are the same. For cross builds this check does not make sense so detect when we do cross builds and silently skip the check in these situations. This fixes a build bug for a wireless driver when cross building for arm. Acked-by: Michael Buesch <mb@bu3sch.de> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: stable@kernel.org
2008-02-19kbuild: fix reversed symbol name order in modpostGeert Uytterhoeven
XXXINIT_TO_INIT and XXXEXIT_TO_EXIT warnings use the reversed symbol name order in the suggestion, e.g.: WARNING: vmlinux.o(.meminit.text+0x36c): Section mismatch in reference from the function free_area_init_core() to the function .init.text:setup_usemap() The function __meminit free_area_init_core() references a function __init setup_usemap(). If free_area_init_core is only used by setup_usemap then annotate free_area_init_core with a matching annotation. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-13Linux Kernel Markers: create modpost fileMathieu Desnoyers
This adds some new magic in the MODPOST phase for CONFIG_MARKERS. Analogous to the Module.symvers file, the build will now write a Module.markers file when CONFIG_MARKERS=y is set. This file lists the name, defining module, and format string of each marker, separated by \t characters. This simple text file can be used by offline build procedures for instrumentation code, analogous to how System.map and Module.symvers can be useful to have for kernels other than the one you are running right now. The strings are made easy to extract by having the __trace_mark macro define the name and format together in a single array called __mstrtab_* in the __markers_strings section. This is straightforward and reliable as long as the marker structs are always defined by this macro. It is an unreasonable amount of hairy work to extract the string pointers from the __markers section structs, which entails handling a relocation type for every machine under the sun. Mathieu : - Ran through checkpatch.pl Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: David Smith <dsmith@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09kbuild/modpost: Use warn() for announcing section mismatchesGeert Uytterhoeven
modpost: Use warn() for announcing section mismatches, for easy grepping for warnings in build logs. Also change an existing call from fprintf() to warn() while we're at it. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild/modpost: improve warnings if symbol is unknownSam Ravnborg
If we cannot determine the symbol then print (unknown) to hint the reader that we failed to find the symbol. This happens with REL relocation records in arm object files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03kbuild: do not warn about __*init/__*exit symbols being exportedSam Ravnborg
We have several legitimate uses where we export symbols annotated with one of: __devinit, __cpuinit, __meminit and their exit counterpart. So let's stop warning about those being exported in favour of adding all sorts of workaround to silence the warning. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03kbuild: print only total number of section mismatces foundSam Ravnborg
We have too many section mismatches detected at the moment. So silence modpost and prevent the option from being set in a typical allyesconfig build. Tell the user how to see all the deteils in the summary message from modpost. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01USB: handle idVendor of 0x0000Greg Kroah-Hartman
Some crazy devices in the wild have a vendor id of 0x0000. If we try to add a module alias with this id, we just can't do it due to a check in the file2alias.c file. Change the test to verify that both the vendor and product ids are 0x0000 to show a real "blank" module alias. Note, the module-init-tools package also needs to be changed to properly generate the depmod tables. Cc: Janusz <janumix@poczta.fm> Cc: stable <stable@kernel.org> Cc: Jon Masters <jcm@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28kbuild: warn about ld added unique sectionsSam Ravnborg
If there is a mixture of specifying sections for code in gcc and assembler then if the assembler code do not add the "ax" flags the linker will see this as two different sections and generate unique sections for each. ld does so by adding a dot and a number. Teach modpost to warn if a section shows up that match this pattern - but do this only for non-debug sections. It will result in warnings like this: WARNING: vmlinux.o (.sched.text.1): unexpected section name. The (.[number]+) following section name are ld generated and not expected. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. All warnings seen with a defconfig build for: x86 (32+64bit) and sparc64 has been fixed (via respective maintainers). arm, powerpc (64 bit), s390 (32 bit), ia64, alpha, sh4 checked - no warnings seen with a defconfig build. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: add verbose option to Section mismatch reporting in modpostSam Ravnborg
If the config option CONFIG_SECTION_MISMATCH is not set and we see a Section mismatch present the following to the user: modpost: Found 1 section mismatch(es). To see additional details select "Enable full Section mismatch analysis" in the Kernel Hacking menu (CONFIG_SECTION_MISMATCH). If the option CONFIG_SECTION_MISMATCH is selected then be verbose in the Section mismatch reporting from mdopost. Sample outputs: WARNING: o-x86_64/vmlinux.o(.text+0x7396): Section mismatch in reference from the function discover_ebda() to the variable .init.data:ebda_addr The function discover_ebda() references the variable __initdata ebda_addr. This is often because discover_ebda lacks a __initdata annotation or the annotation of ebda_addr is wrong. WARNING: o-x86_64/vmlinux.o(.data+0x74d58): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() The variable pci_serial_quirks references the function __devexit pci_plx9050_exit() If the reference is valid then annotate the variable with __exit* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: o-x86_64/vmlinux.o(__ksymtab+0x630): Section mismatch in reference from the variable __ksymtab_arch_register_cpu to the function .cpuinit.text:arch_register_cpu() The symbol arch_register_cpu is exported and annotated __cpuinit Fix this by removing the __cpuinit annotation of arch_register_cpu or drop the export. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: simplified warning report in modpostSam Ravnborg
Refactor code so the warning report function does nothing else than reporting warnings. As a side effect some other code paths were cleaned up by this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce a few helpers in modpostSam Ravnborg
Introducing helpers to retreive symbol and section names cleaned up the code a bit. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: use simpler section mismatch warnings in modpostSam Ravnborg
The typical layout is now: WARNING: vmlinux.o(.text+0x372ec): Section mismatch: reference to .devinit.text:pci_scan_one_pbm in 'psycho_scan_bus' This is first step towards more readable warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28Use separate sections for __dev/__cpu/__mem code/dataSam Ravnborg
Introducing separate sections for __dev* (HOTPLUG), __cpu* (HOTPLUG_CPU) and __mem* (MEMORY_HOTPLUG) allows us to do a much more reliable Section mismatch check in modpost. We are no longer dependent on the actual configuration of for example HOTPLUG. This has the effect that all users see much more Section mismatch warnings than before because they were almost all hidden when HOTPLUG was enabled. The advantage of this is that when building a piece of code then it is much more likely that the Section mismatch errors are spotted and the warnings will be felt less random of nature. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-01-28kbuild: check section names consistently in modpostSam Ravnborg
Now that match() is introduced use it consistently so we can share the section name definitions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce blacklisting in modpostSam Ravnborg
Change the logic in modpost so we identify all the bad combinations of sections that refer to other sections. Compared to the previous approach we are much less dependent on knowledge of what additional sections the tool chain uses and thus we can keep the false positives low. The implmentation is changed to use a table based lookup and we now check all combinations in first pass so we no longer need separate passes for init and exit sections. Tested that the same warnings are generated for an allyesconfig build without CONFIG_HOTPLUG. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-01-28kbuild: code refactoring in modpostSam Ravnborg
Split a too long function up in smaller bits to make prgram logic easier to follow. A few related changes done due to parameter changes. No functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: try harder to find symbol names in modpostSam Ravnborg
The relocation record sometimes contained an address which was not an exactly match for a symbol. Implment some simple logic such that if there is a symbol within 20 bytes of the address contained in the relocation record then print the name of this symbol. With this change modpost could find symbol names for the remaining .init.text symbols in my allyesconfig build for x86_64. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: fix so modpost can now check any .o fileSam Ravnborg
It is very convinient to say: scripts/mod/modpost mm/built-in.o to check if any section mismatch errors occured in mm/ (as an example). Fix it so this is possible again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: clean up modpost.cSam Ravnborg
akpm complained about overly long lines in modpost.c and when started additional style issues were fixed: o Updated my copyright o Removed unneeded {} o Drop assignments in if () o Spaces around operators o Break long lines o locate * near variable not type o Fix a format specifier for sizeof() o Corrected placement of '{' and '}' o spaces to tabs (but use tabs only for indention) modpost.c is not checkpatch clean. Readability were favoured on top of checkpatch compliance. But checkpatch were used to find additional stuff to clean up. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: fix a buffer overflow in modpostAndi Kleen
When passing an file name > 1k the stack could be overflowed. Not really a security issue, but still better plugged. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: fix format string warnings in modpostAndi Kleen
Fix wrong format strings in modpost exposed by the previous patch. Including one missing argument -- some random data was printed instead. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: declare the modpost error functions as printf likeAndi Kleen
This way gcc can warn for wrong format strings Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-23Module autoprobing support for virtio drivers.Rusty Russell
This adds the logic to convert the virtio ids into module aliases, and includes a modalias entry in sysfs and the env var to make probing work. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-18kbuild: modpost problem when symbols move from one module to anotherTrent Piepho
When part of build an external module tree, modpost first reads in the kernel's and then the external tree's Module.symvers files. From these files it establishes a symbol => module mapping. When it later reads in each module built and processes the symbols it finds, it discovers the symbol=>module mapping from Module.symvers and leaves it as it is. The problem comes with a module has been re-named or a symbol has moved from one module to another, since the Module.symvers file was generated. modpost does not update the symbol=>module mapping when it finds the new location of the symbol when scanning the newly built modules. This results in the module containing incorrect dependency information and the new Module.symvers file written by modpost will also contain the incorrect mappings, perpetuating the problem to the next build, and so on. When building the out of kernel development tree for kernel subsystem, like v4l-dvb or ALSA, deleting the external Module.symvers file before building (which the kernel build system doesn't do and shouldn't be necessary anyway), won't fix the problem. modpost still reads the kernel's Module.symvers, and since we a building a kernel subsystem, it will define the same symbols as the external modules. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: (40 commits) kbuild: introduce ccflags-y, asflags-y and ldflags-y kbuild: enable 'make CPPFLAGS=...' to add additional options to CPP kbuild: enable use of AFLAGS and CFLAGS on commandline kbuild: enable 'make AFLAGS=...' to add additional options to AS kbuild: fix AFLAGS use in h8300 and m68knommu kbuild: check for wrong use of CFLAGS kbuild: enable 'make CFLAGS=...' to add additional options to CC kbuild: fix up CFLAGS usage kbuild: make modpost detect unterminated device id lists kbuild: call export_report from the Makefile kbuild: move Kai Germaschewski to CREDITS kconfig/menuconfig: distinguish between selected-by-another options and comments kconfig: tristate choices with mixed tristate and boolean values include/linux/Kbuild: remove duplicate entries kbuild: kill backward compatibility checks kbuild: kill EXTRA_ARFLAGS kbuild: fix documentation in makefiles.txt kbuild: call make once for all targets when O=.. is used kbuild: pass -g to assembler under CONFIG_DEBUG_INFO kbuild: update _shipped files for kconfig syntax cleanup ... Fix up conflicts in arch/um/sys-{x86_64,i386}/Makefile manually.
2007-10-13i2c: Kill struct i2c_device_idJean Delvare
I2C devices do not have any form of ID as PCI or USB devices have. No driver uses "MODULE_DEVICE_TABLE(i2c, ...)" because it doesn't make sense. So we can get rid of struct i2c_device_id and the associated support code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg KH <greg@kroah.com>
2007-10-12kbuild: make modpost detect unterminated device id listsKees Cook
Cause modpost to fail if any device id lists are incorrectly terminated, after reporting the offender. Improved reporting by akpm Signed-off-by: Kees Cook <kees@ubuntu.com> Cc: Greg KH <greg@kroah.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Ben Collins <bcollins@ubuntu.com> Cc: Michael Wu <flamingice@sourmilk.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: fix segfault in modpostPetr Stetiar
Fix modpost segfault. Before: ------- ynezz@ntbk:~/linux-2.6.git$ scripts/mod/modpost vmlinux ath_pci.o Segmentation fault After: ------ ynezz@ntbk:~/linux-2.6.git$ scripts/mod/modpost vmlinux ath_pci.o FATAL: section header offset=815726848 in file 'ath_pci.o' is bigger then filesize=153968 Sam: This seems to warn for a binutils issue. Anyway modpost should not segfault. Signed-off-by: Petr Stetiar <ynezz@true.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: Use Elfnn_Half as replacement for Elfnn_SectionSam Ravnborg
The Elfnn_Section is not available on all platforms, noteworthy are cygwin. Use the safe replacement _Half. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NETNS]: Move some code into __init section when CONFIG_NET_NS=nPavel Emelyanov
With the net namespaces many code leaved the __init section, thus making the kernel occupy more memory than it did before. Since we have a config option that prohibits the namespace creation, the functions that initialize/finalize some netns stuff are simply not needed and can be freed after the boot. Currently, this is almost not noticeable, since few calls are no longer in __init, but when the namespaces will be merged it will be possible to free more code. I propose to use the __net_init, __net_exit and __net_initdata "attributes" for functions/variables that are not used if the CONFIG_NET_NS is not set to save more space in memory. The exiting functions cannot just reside in the __exit section, as noticed by David, since the init section will have references on it and the compilation will fail due to modpost checks. These references can exist, since the init namespace never dies and the exit callbacks are never called. So I introduce the __exit_refok attribute just like it is already done with the __init_refok. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[SSB]: add Sonics Silicon Backplane bus supportMichael Buesch
SSB is an SoC bus used in a number of embedded devices. The most well-known of these devices is probably the Linksys WRT54G, but there are others as well. The bus is also used internally on the BCM43xx and BCM44xx devices from Broadcom. This patch also includes support for SSB ID tables in modules, so that SSB drivers can be loaded automatically. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
