path: root/scripts/package
2014-01-03deb-pkg: Fix building for MIPS big-endian or ARM OABIBen Hutchings
These commands will mysteriously fail: $ make ARCH=arm versatile_defconfig [...] $ make ARCH=arm deb-pkg [...] make[1]: *** [deb-pkg] Error 1 make: *** [deb-pkg] Error 2 The Debian architecture selection for these kernel architectures does 'grep FOO=y $KCONFIG_CONFIG && echo bar', and after 'set -e' this aborts the script if grep does not find the given config symbol. Fixes: 10f26fa64200 ('build, deb-pkg: select userland architecture based on UTS_MACHINE') Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-01-03deb-pkg: Fix cross-building linux-headers packageBen Hutchings
builddeb generates a control file that says the linux-headers package can only be built for the build system primary architecture. This breaks cross-building configurations. We should use $debarch for this instead. Since $debarch is not yet set when generating the control file, set Architecture: any and use control file variables to fill in the description. Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg') Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-01-02Merge commit v3.13-rc1 into kbuild/miscMichal Marek
2013-11-18deb-pkg: Inhibit initramfs builders if CONFIG_BLK_DEV_INITRD is not setBen Hutchings
The kernel postinst hook for initramfs-tools will build an initramfs on installation unless $INITRD is set to 'No'. make-kpkg generates a postinst script that sets this variable appropriately, but we don't. Set it based on CONFIG_BLK_DEV_INITRD. This should also work with dracut when <http://bugs.debian.org/729622> is fixed. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-11-07perf tools: Fix version when building out of treeDavid Ahern
When building perf out of tree: $ make perf-tar-src-pkg $ tar -xf perf-<ver>.tar -C /tmp $ cd /tmp/perf<ver> $ make -C tools/perf you get this warning message: make[1]: *** No rule to make target `kernelversion'. Stop. Fix it by saving the perf version in the tar file and using that for the out of tree builds. v2: removed short form request and fixed up version string from usual output. Signed-off-by: David Ahern <dsahern@gmail.com> Suggested-by: Ingo Molnar <mingo@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1383753335-25782-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This has been sitting in -next for a while with no objections and all MIPS defconfigs except one are building fine; that one platform got broken by another patch in your tree and I'm going to submit a patch separately. - a handful of fixes that didn't make 3.11 - a few bits of Octeon 3 support with more to come for a later release - platform enhancements for Octeon, ath79, Lantiq, Netlogic and Ralink SOCs - a GPIO driver for the Octeon - some dusting off of the DECstation code - the usual dose of cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (65 commits) MIPS: DMA: Fix BUG due to smp_processor_id() in preemptible code MIPS: kexec: Fix random crashes while loading crashkernel MIPS: kdump: Skip walking indirection page for crashkernels MIPS: DECstation HRT calibration bug fixes MIPS: Export copy_from_user_page() (needed by lustre) MIPS: Add driver for the built-in PCI controller of the RT3883 SoC MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000 MIPS: ralink: Add support for reset-controller API MIPS: ralink: mt7620: Add cpu-feature-override header MIPS: ralink: mt7620: Add spi clock definition MIPS: ralink: mt7620: Add wdt clock definition MIPS: ralink: mt7620: Improve clock frequency detection MIPS: ralink: mt7620: This SoC has EHCI and OHCI hosts MIPS: ralink: mt7620: Add verbose ram info MIPS: ralink: Probe clocksources from OF MIPS: ralink: Add support for systick timer found on newer ralink SoC MIPS: ralink: Add support for periodic timer irq MIPS: Netlogic: Built-in DTB for XLP2xx SoC boards MIPS: Netlogic: Add support for USB on XLP2xx MIPS: Netlogic: XLP2xx update for I2C controller ...
2013-08-26kbuild: Add MIPS specific files to generated package.Stuart Longland
A lot of 64-bit systems supported by Linux/MIPS have boot firmware or bootloaders that only understand 32-bit ELF files, and as such, the vmlinux.32 target exists to support these systems. Therefore, it'd be nice if the tar-pkg target recognised this, and included the right version when packaging up a binary of the kernel. This updates buildtar to support MIPS targets. MIPS may use 'vmlinux' or 'vmlinux.32' depending on the target system. This uses 'vmlinux.32' in preference to 'vmlinux' where present (although I should check which is newer), including either file as /boot/vmlinux-${version}. Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1673/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-08-15Provide version number for Debian firmware packageHeinrich Schuchardt
scripts/package/builddeb is used to create Debian packages. Currently the firmware package always gets the same version number irrespective of the Kernel version. The paths inside the firmware package depend on the Kernel version. With the patch supplied the Kernel version becomes part of the Debian firmware package number. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-24deb-pkg: add a hook argument to match debian hooks parametersAnisse Astier
We now provide the installed image path to the kernel hooks. This should allow the package to better integrate with debian hooks, and should not be too disruptive of hooks supporting only one parameter. Signed-off-by: Anisse Astier <anisse@astier.eu> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-24deb-pkg: fix installed image path on parisc, mips and powerpcAnisse Astier
Signed-off-by: Anisse Astier <anisse@astier.eu> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-24deb-pkg: split debug symbols in their own packageAnisse Astier
This can reduce almost 3 times the size of the linux-image package, while keeping the debug symbols available for this particular build, in their own package. This mimics the way kernels are built in debian, ubuntu, or with make-kpkg, and comes at the price of a small slowdown in the building of packages. Signed-off-by: Anisse Astier <anisse@astier.eu> Cc: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-24deb-pkg: use KCONFIG_CONFIG instead of .config file directlyAnisse Astier
2013-07-23rpm-pkg: add generation of kernel-develMike Marciniszyn
Change the spec file to generate a kernel-devel module allowing for compilation of external kernel modules. This patch requires a new minimum RPM level of 4.0.3. Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-23rpm-pkg: install firmware files in kernel relative directoryMike Marciniszyn
Prior to this patch, firmware files were being installed in /lib/firmware with a potential conflict with already installed kernels. firmware files are now installed in /lib/firmware/<release> and packaged with the rest of the modules. Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-23rpm-pkg: add %post section to create initramfs and grub hooksMike Marciniszyn
/sbin/installkernel is used to insure grub hooks are inserted and the initramfs is created on the target system. The invokation installkernel will work with any kernel as long as: - /sbin/installkernel exists - the kernel and sysem map files are readable Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-07-10Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: - fix for make headers_install argv explosion with too long path - scripts/setlocalversion does not call git update-index needlessly - fix for the src.rpm produced by make rpm-pkg. The new make image_name can be useful also for other packaging tools. - scripts/mod/devicetable-offsets.o is not rebuilt during each make run - make modules_install dependency fix - scripts/sortextable portability fix - fix for kbuild to generate the output directory for all object files in subdirs. - a couple of minor fixes * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: create directory for dir/file.o tools/include: use stdint types for user-space byteshift headers Makefile: Fix install error with make -j option Fix a build warning in scripts/mod/file2alias.c improve modalias building scripts/mod: Spelling s/DEVICEVTABLE/DEVICETABLE/ kbuild: fix error when building from src rpm scripts/setlocalversion on write-protected source tree Makefile.lib: align DTB quiet_cmd kbuild: fix make headers_install when path is too long
2013-06-24kbuild: fix error when building from src rpmMike Marciniszyn
The following issue can be reproduced with Linus' tree on an x86_64 server. >+ cp /home/user/rpmbuild-test/BUILDROOT/kernel-3.9.2.x86_64/boot/vmlinuz-3.9.2 >cp: missing destination file operand after >/home/user/rpmbuild-test/BUILDROOT/kernel-3.9.2-1.x86_64/boot/vmlinuz-3.9.2' >Try `cp --help' for more information. >error: Bad exit status from /var/tmp/rpm-tmp.R4o0iI (%install) Here are the commands to reproduce: make defconfig make rpm-pkg Use the resulting src rpm to build as follows: mkdir ~/rpmbuild-test cd ~/rpmbuild-test rpmbuild --rebuild --define "_topdir `pwd`" -vv ~/rpmbuild/SRPMS/kernel-3.10.0_rc1+-1.src.rpm The issue is because the %install script uses $KBUILD_IMAGE and it hasn't been set since it is only available in the kbuild system and not in the %install script. This patch adds a Makefile target to emit the image_name that can be used and modifies the mkspec to use the dynamic name in %install. Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-05-16package: Makefile: unbreak binrpm-pkg targetLuiz Capitulino
Commit 6501320311664e11ad5489fedb17ea1f817c2617 dropped the rpm spec as a prerequisite for the binrpm-pkg target but forgot to update $< usage, which causes the rule to break. This commit fixes that by replacing $< with the spec name. Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-18rpm-pkg: Remove pointless set -e statementsMichal Marek
2013-04-18rpm-pkg: Always regenerate the specfileMichal Marek
The *pkg targets are always run, so it makes no sense to cache the generated specfile. This also fixes build errors when the specfile becomes out of date, without the Makefile noticing it: $ make rpm works $ echo yadadada >localversion-test $ make rpm fails, because kernel.spec assumes the old kernel release string Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-18rpm-pkg: Do not write to the parent directoryMichal Marek
Now that we only package explicitly listed files to the tarball, there is no need to abuse the parent directory. Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-18rpm-pkg: Do not package the whole source directoryMichal Marek
The source tree can contain lots of uninteresting data like tag or cscope files, packaging which slows down make rpm needlessly. It can also break the build, if the tree contains an unrelated file named *.spec. The downside of this change is that new subdirectories have to be added to the KBUILD_ALLDIRS variable in the top-level Makefile. The upside is that the behavior is more predictable. Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08buildtar: Add ARCH to the archive nameBorislav Petkov
When dealing with multiple sub-arches (like 32- and 64-bit on x86, for example) generating a bunch of kernel tar archives with the same name but for different sub-arches could get confusing and error-prone. Also, the build process could overwrite otherwise unrelated builds and you probably don't want that. So, add the architecture to the archive name for more clarity and less shoot-yourself-in-the-foot practices. Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08scripts/package/Makefile: compare objtree with srctree instead of test ↵Bin Wang
KBUILD_OUTPUT KBUILD_OUTPUT is always empty here, so it is useless to test it. But while use O=.., objtree and srctree will be different. I compare them instead. Signed-off-by: Bin Wang <wbin00@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22kbuild: clear KBUILD_SRC when calling 'make' in RPM specDavid R. Bild
'make rpm-pkg' and 'make binrpm-pkg' fail when the kernel source is read-only. Specifically, when the RPM spec generated by scripts/package/mkspec is run, KBUILD_SRC happens to be set to the source location and thus the invocation of 'make headers_install' fails when an internal call to 'filechk' tries to write a file into the source tree. The fix is to clear KBUILD_SRC for the 'make headers_install' invocation in the spec file, as is already done for the 'make modules_install' invocation. Signed-off-by: David R. Bild <drbild@umich.edu> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The main part of kbuild for v3.7 contains: - Fix for scripts/Makefile.modpost to not choke on a '.ko' substring in the build directory path - Two warning fixes (modpost and main Makefile) - __compiletime_error works also with gcc 4.3 - make tar{gz,bz2,xz}-pkg uses default compression settings instead of saving as many bytes as possible (this should actually be in the misc branch, I don't know why I applied it here)." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: compiler-gcc4.h: correct verion check for __compiletime_error modpost: Permit .GCC.command.line sections Kbuild: use normal compression settings for tar*-pkg scripts/Makefile.modpost: error in finding modules from .mod files. kbuild: Remove useless warning while appending KCFLAGS
2012-09-27Kbuild: use normal compression settings for tar*-pkgAndi Kleen
For large kernel configurations (like a distribution kernel) targz-pkg takes a quite long time to just do the compression. I clocked it at 15+mins for a SUSE kernel like config on a fast system. And tarxz and bzip2 are even slower. The main reason is that the script that is doing the taring sets the highest compression level (-9). When I change it to just use the defaults the gzip time for the same kernel goes down to ~3 mins. I haven't tested xz and bzip, but I expect those to be much faster too. I'm not willing to wait that long for a small compression gain. So just change the script to use the defaults. Signed-off-by: Andi Kleen <ak@linux.intel.com> Reviewed-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-09-27kbuild: Do not package /boot and /lib in make tar-pkgMichal Marek
There were reports of users destroying their Fedora installs by a kernel tarball that replaces the /lib -> /usr/lib symlink. Let's remove the toplevel directories from the tarball to prevent this from happening. Reported-by: Andi Kleen <andi@firstfloor.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Cc: <stable@kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28deb-pkg: Add all Makefiles to header packagemaximilian attems
I discovered that make deb-pkg does not add Makefile_32.cpu from arch/x86 directory when doing i386 kernel build and package build. Fix it by greedily adding all Makefiles. Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28deb-pkg: Install linux-firmware-image in versioned dirmaximilian attems
That way they don't file conflict with official firmware package: trying to overwrite '/lib/firmware/qlogic/1040.bin', which is also in package firmware-qlogic 0.35 .. Reported-by: Michael Prokop <mika@debian.org> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-05-26builddeb: include autogenerated header filesLekensteyn
After 303395ac3bf3e2cb488435537d416bc840438fcb, some headers are autogenerated. Include these autogenerated headers (mainly unistd_32_ia32.h) in out-of-tree builds to allow DKMS modules to be built succesfully. Signed-off-by: Peter Lekensteyn <lekensteyn@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-25kbuild: Fix out-of-tree build for 'make deb-pkg'Joerg Roedel
The out-of-tree build is broken in 'make deb-pkg'. The header checks and the header install works on the source and not on the object tree. While fixing this also replace the direct 'make' invocations with the $MAKE variable to be consistent within the script. Cc: maximilian attems <max@stro.at> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: debian-kernel@lists.debian.org Cc: linux-kbuild@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-24kbuild: Only build linux-image package for UMLJoerg Roedel
For user-mode Linux the other packages are not required. So only build the package with the linux-image in it. Cc: maximilian attems <max@stro.at> Cc: debian-kernel@lists.debian.org Cc: linux-kbuild@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Tested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-24kbuild: Fix link to headers in 'make deb-pkg'Joerg Roedel
The Link to the kernel header files in the debian packages point to the original build directory. This is a bad choice if the packages were installed on a different machine. Fix this in by manually re-creating the link in the builddeb script. Cc: maximilian attems <max@stro.at> Cc: debian-kernel@lists.debian.org Cc: linux-kbuild@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-18builddeb: Don't create files in /tmp with predictable namesBen Hutchings
The current use of /tmp for file lists is insecure. Put them under $objtree/debian instead. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: stable@vger.kernel.org # 2.6.39+ Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-10-29scripts/package/Makefile: Fix typo: an deb -> a debPaul Menzel
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-24package: Makefile: fix perf target bugmatt mooney
Specify --git-dir when building perf targets to allow out-of-tree builds using O=<build-dir>. The shell command in `git archive' had to be modified to allow proper file name expansion of the files listed in MANIFEST. Signed-off-by: matt mooney <mfm@muteddisk.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-25Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Create a kernel-headers RPM rpm-pkg: Fix when current directory is a symlink Replace '-' in kernel version with '_'
2011-05-24kbuild: Create a kernel-headers RPMArun Sharma
To compile binaries which depend on new kernel interfaces, we need a kernel-headers RPM Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-24rpm-pkg: Fix when current directory is a symlinkMichal Marek
The better fix would be to stop using the parent directory (principle of least surprise), but as long as we use it, use it consistently. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-05-04Replace '-' in kernel version with '_'Arun Sharma
Removing the '-' results in hard to read filenames such as: kernel-2.6.35.2000042g76e4caf-28.x86_64.rpm kernel-2.6.35.2_000042_g76e4caf-28.x86_64.rpm is easier to read. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-09kbuild: Add make tarxz-pkg build optionZdenek Kaspar
Signed-off-by: Zdenek Kaspar <zkaspar82@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-09Merge commit 'v2.6.38-rc1' into kbuild/packagingMichal Marek
2011-02-04deb-pkg: Fix building outside of source tree (O=...).Nicolas de Pesloüan
When building linux-headers package using deb-pkg, builddeb erroneously assume current directory is the source tree. This is not true if building in another directory, using make O=... deb-pkg. This patch fix this problem. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Tested-by: Nikolai Kondrashov <spbnick@gmail.com> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-15deb-pkg: Use $SRCARCH for include pathmaximilian attems
Fix x86 centric path to allow building kernel-header packages for other architecture. Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-10Merge branch 'packaging' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'packaging' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: deb-pkg: s/hdr/kernel_headers_/ && s/header/libc_headers_/ deb-pkg: Make deb-pkg generate a seperate linux-libc-dev deb kbuild: create linux-headers package in deb-pkg kbuild, deb-pkg: support overriding userland architecture kbuild, deb-pkg: select userland architecture based on UTS_MACHINE kbuild, deb-pkg: Fix build with paranoid umask
2011-01-07deb-pkg: s/hdr/kernel_headers_/ && s/header/libc_headers_/maximilian attems
hdrpackage and headerpackage are not intuitive names, use proposed alternatives by Michel Marek. While touching them move the mkdir of the kernel_headers dir up and fix it for paranoid umask. CC: Theodore Ts'o <tytso@mit.edu> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-01-07deb-pkg: Make deb-pkg generate a seperate linux-libc-dev debmaximilian attems
userland dev likes latest incarnation of that userland API. make it easy to also build it on make deb-pkg invocation: dpkg-deb: building package `linux-libc-dev' in `../linux-libc-dev_2.6.32-rc6-4_amd64.deb'. Last year patch rebased on top of latest deb-pkg changes. Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-29kbuild: create linux-headers package in deb-pkgTheodore Ts'o
Create a linux-headers-$KVER.deb package which can be used to build external modules without having the source tree around. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Michal Marek <mmarek@suse.cz>
