path: root/scripts/pnmtologo.c
2014-06-10kbuild: trivial - remove trailing empty linesMasahiro Yamada
2012-11-20scripts/pnmtologo: fix for plain PBMAndreas Bießmann
PBM generated with current tools do not have a whitespace between the digits. Therefore the pnmtologo tool fails to gernerate the required C-Array for these images. This patch fixes that behaviour and can handle both 'old style' and 'new style' PBM files. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-06-30fbdev: work around old compiler bugStephen Rothwell
When building with a 4.1.x compiler on powerpc64 (at least) we get this error: drivers/video/logo/logo_linux_mono.c:81: error: logo_linux_mono causes a section type conflict This was introduced by commit ae52bb2384f721562f15f719de1acb8e934733cb ("fbdev: move logo externs to header file"). This is a partial revert of that commit sufficient to not hit the compiler bug. Also convert _clut arrays from __initconst to __initdata. Sam said: Al analysed this some time ago. When we say something is const then _sometimes_ gcc annotate the section as const(?) - sometimes not. So if we have two variables/functions annotated __*const and gcc decides to annotate the section const only in one case we get a section type conflict. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
