path: root/scripts/ver_linux
2019-01-22ver_linux: Assign constant RE to variable name for clarityAlexander Kapshuk
The regular expression that matches the version number of a utility being queried is used as a constant expression in the current implementation. Assigning the RE in question to a variable gives it a meaningful name that clearly expresses the intended use of the expression without having to think about the details of implementation. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-07ver_linux: Do not check for ver_linux pattern in version functionAlexander Kapshuk
Checking whether output of commands matches the ver_linux pattern in the version function is original shell implementation legacy code. When the original implementation failed to locate a particular utility, it generated error output along the lines of: ver_linux:line number: command not found. The awk implementation, does not contain the name of the script within the body of the error message returned by the subshell when a given utility fails to be located. The error message returned is along the lines of: sh: name of utility: command not found Safeguarding against the ver_linux pattern being found in the output being parsed may thus be safely omitted. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-07ver_linux: Process input coming from procmaps that matches libc onlyAlexander Kapshuk
Currently, input coming from /proc/self/maps is split into fields without checking whether or not it matches libc.so. This is not efficient. All text processing should only be performed on lines of input that match libc.so. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-14ver_linux: Drop redundant calls to system() to test if file is readableAlexander Kapshuk
Running 'test -r' on an awk variable name whose value is an empty string results in test being run with no arguments, and causes system() to return 0, which indicates success when used to test values returned by function calls. This results in code within the if blocks being run when it should not be. Instead of testing if a file is accessible and readable via calls to system("test -r " file), rely on the value returned by getline to perform this kind of testing. Getline returns -1 on error, with the code within the while loops not being run. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-14ver_linux: Move stderr redirection from function parameter to function bodyAlexander Kapshuk
Remove stderr redirection to stdout from all the parameters to the version() function, and put it with the body of the version() function instead. This improves code readability. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-08ver_linux: Use /usr/bin/awk instead of /bin/awkSaul Wold
Most Linux distributions contain awk in /usr/bin by default, not in /bin. This script's suggested use is for creating version information for bug reporting. This has been tested on a number of different distributions, including Fedora, Ubuntu, OpenSUSE, Debian, Centos, Arch Linuxi, and Poky! Signed-off-by: Saul Wold <sgw@linux.intel.com> Reviewed-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Reviewed-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31ver_linux: rename ver_linux.awk to ver_linuxAlexander Kapshuk
ver_linux.awk renamed to ver_linux. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-31ver_linux: shell implementation removedAlexander Kapshuk
The shell implementation removed. To be replaced with an all-awk implementation via consecutive patch. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-07scripts: fix typo in ver_linuxMatthias Lange
Signed-off-by: Matthias Lange <matthias.lange@kernkonzept.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: proc/modules, limit text processing to 'sed'Alexander Kapshuk
This patch is more of a personal preference, rather than a fix for a problem. The current implementation used a combination of both 'cat' and 'sed' to generate an unsorted list of kernel modules separated by while space. The proposed implementation uses 'sort' and 'sed' to generate a sort list of kernel modules separated by while space. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Arch Linux openSuSE 13.2 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: wireless-tools, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Tested on: Gentoo Linux Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: use 'udevadm', instead of 'udevinfo'Alexander Kapshuk
'udevinfo' no longer seems to be available across various distros. 'udevadm' seems to be the currently valid way to look up the 'udev' version. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'awk'. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: sh-utils, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: loadkeys, look for numerical input, not field numberAlexander Kapshuk
'loadkeys -h' no longer prints the version number across all distros, despite the claim to do so in the manpage, which I found to be the case on a Debian Linux system. The proposed implementation utilises the output of 'loadkeys -V' to acquire the version of both 'Kbd' and 'Console-tools'. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: net-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: procps, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: libcpp, fix missing outputAlexander Kapshuk
Neither 'libg++.so', nor 'libstdc++.so' were found where the current implementation expects them to be found in the distros below. Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Which results in zero ouput generated. The proposed implementation relies on 'ldconfig' to locate the libraries in question. 'Sed' is used to do the text processing. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: ldd, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'head' + 'awk'. The '-v' flag either seems to have been deprecated in some distros, e.g. Gentoo, or is an alias for '--version' in others. The proposed implementation uses the latter flag only. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: libc, input redirection to sed fails in some distrosAlexander Kapshuk
The current implementation has been found not to work across all distros. The proposed implementation relies on 'sed' to both output the string 'Linux C Library' as well as to open '/proc/self/maps' without having to use output redirection. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Arch Linux openSuSE 13.2 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: ppp, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'awk'. Tested on: Oracle Linux Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: quota-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: pcmciautils, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: xfsprogs, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: reiserfsprogs, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: jfsutils, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'sed' + 'awk'. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: e2fsprogs, look for numerical input, not field numberAlexander Kapshuk
Rely on regex to find the version number, rather than rely on numerical input to be found in a particular input field. Proposed implementation also eliminates the necessity to invoke 'grep' + 'sed' + 'awk'. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: module-init-tools, look for numerical input, not field numberAlexander Kapshuk
2015-10-17ver_linux: util-linux, 'fdformat' not ubiquitous any longerAlexander Kapshuk
The current implementation relies on 'fdformat' to output the version of 'util-linux'. This does not seem to be reliable any longer, as 'fdformat' does not seem to come preinstalled in all ditros these days. The proposed implementation uses 'mount' to output both the version of 'util-linux' and 'mount' proper, as 'mount' is also a part of the 'util-linux' package. Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number, rather than a field number. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: binutils, fix inaccurate outputAlexander Kapshuk
Current implementation output on Gentoo Linux: binutils 2.25.1 1.1 2.25.1 Proposed implementation: Binutils 2.25.1 Tested on: Gentoo Linux Debian 6.0.10 Oracle Linux Server release 7.1 Rely on regex to find the version number. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: make --version, use regex to find version numberAlexander Kapshuk
Rely on regex to find the version number, rather than a field number. Reduce the number of 'awk' invocations from two to one. Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17ver_linux: gcc -dumpversion, use regex to find version numberAlexander Kapshuk
2009-06-09Remove bashisms from scriptsdann frazier
The '-e' option to echo and brace expansion are not guaranteed to be supported by a POSIX-compliant /bin/sh (e.g. dash) Signed-off-by: dann frazier <dannf@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-31kbuild: scripts/ver_linux: don't set PATHAdrian Bunk
It would have saved both a bug submitter and me a few hours if scripts/ver_linux had picked the same gcc as the build. Since I can't see any reason why it fiddles with PATH at all this patch therefore removes the PATH setting. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-25scripts/ver_linux use 'gcc -dumpversion'Gabriel C
These magic greps and hacks in ver_linux to get the gcc version always break after some gcc releases. Since now gcc >4.3 allows compiling with '--with-pkgversion' ( which can be everything 'My Cool Gcc' or something ) ver_linux will report random junk for these. Simply use 'gcc -dumpversion' to get the gcc version which should always work. Signed-off-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: scripts/ver_linux : correct printing of binutils versionJesper Juhl
Currently scripts/ver_linux prints "Binutils" or other random information for the version number in the "binutils" output line on some distributions. This patch corrects that. When I initially submitted a patch to correct that, I was not aware that the output from "ld -v" could differ as much as it turned out it can, so my original fix turned out to not cover all bases. This patch works correctly with all the different "ld -v" output that people posted in replys to my first patch, so it should be a clear win over what we have currently. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-12kbuild: ver_linux fix glibc version printJesper Juhl
Fix ver_linux glibc version printing (for real this time) Alexey Dobriyan reported that commit 4a645d5ea65baaa5736bcb566673bf4a351b2ad8 broke ver_linux when glibc has a 3 digit version number, and proposed a patch. Al Viro then suggested a simpler way to solve the problem which I've then simply put into patch form. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-07-25kbuild: fix up printing of Linux C Library version in scripts/ver_linuxJesper Juhl
I noticed, when running scripts/ver_linux on both a Gentoo system and a Slackware system, that the line printing the C library version looked a little odd. So I fixed it up to be in line with all the rest. Old output: Linux C Library > libc.2.5 New output: Linux C Library 2.5 Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-12-07[PATCH] ver_linux additionsValdis Kletnieks
scripts/ver_linux needed some minor clean-ups, as follows: 1) Add reporting of actual oprofile release 2) Add reporting of actual wireless-tools release 3) Add reporting of actual pcmciautils release Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-05ver_linux: don't print reiser4progs version if none foundAlexey Dobriyan
Sam: did the same for reiserprogs Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] Adapt scripts/ver_linux to new util-linux version stringsAlexey Dobriyan
Tested with 2.12i and 2.13-pre2. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] 2.6.12-rc1-mm3 Fix ver_linux script for no udev utils.Steven Cole
Without the attached patch, the ver_linux script gives the following if udev utils are not present. ./scripts/ver_linux: line 90: udevinfo: command not found The patch causes ver_linux to be silent in the case of no udevinfo command. Signed-off-by: Steven Cole <elenstev@mesatop.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
