path: root/scripts
2010-08-26fixes for using make 3.82Jan Beulich
commit 3c955b407a084810f57260d61548cc92c14bc627 upstream. It doesn't like pattern and explicit rules to be on the same line, and it seems to be more picky when matching file (or really directory) names with different numbers of trailing slashes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Andrew Benton <b3nton@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-02kbuild: Fix modpost segfaultKrzysztof Halasa
commit 1c938663d58b5b2965976a6f54cc51b5d6f691aa upstream. Alan <alan@clueserver.org> writes: > program: /home/alan/GitTrees/linux-2.6-mid-ref/scripts/mod/modpost -o > Module.symvers -S vmlinux.o > > Program received signal SIGSEGV, Segmentation fault. It just hit me. It's the offset calculation in reloc_location() which overflows: return (void *)elf->hdr + sechdrs[section].sh_offset + (r->r_offset - sechdrs[section].sh_addr); E.g. for the first rodata r entry: r->r_offset < sechdrs[section].sh_addr and the expression in the parenthesis produces 0xFFFFFFE0 or something equally wise. Reported-by: Alan <alan@clueserver.org> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Tested-by: Alan <alan@clueserver.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-20kconfig: Fix make O=<dir> local{mod,yes}configSteven Rostedt
When the output directory is something other than the kernel source, the streamline_config script gets confused. This patch passes in the source directory to the script so that it can find the proper files. Reported-by: Peter Zijlstra <peterz@infradead.org> Tested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-15dtc: Mark various internal functions staticJosh Triplett
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15dtc: Set "noinput" in the lexer to avoid an unused functionJosh Triplett
Regenerate the corresponding generated lexer. Regenerating the lexer with current flex also provides prototypes for various yy* functions, making some -Wmissing-prototypes warnings go away as well. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15genksyms: Mark is_reserved_word staticJosh Triplett
The genksyms keyword gperf hash provides a function is_reserved_word. genksyms #includes the resulting generated file keywords.c, so the function gets used only in the same source file that defines it. Mark is_reserved_word static, and regenerate the corresponding generated file. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-15kconfig: Mark various internal functions staticJosh Triplett
kconfig's keyword hash, lexer, and parser define various functions used only locally. Declare these functions as static, and regenerate the corresponding generated files. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-12get_maintainer: fix usage commentRoel Kluin
With the `s' it just won't work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: version 0.30Andy Whitcroft
Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: fix false EXPORT_SYMBOL warningAndy Whitcroft
Ingo reported that the following lines triggered a false warning, static struct lock_class_key rcu_lock_key; struct lockdep_map rcu_lock_map = STATIC_LOCKDEP_MAP_INIT("rcu_read_lock", &rcu_lock_key); EXPORT_SYMBOL_GPL(rcu_lock_map); from kernel/rcutree.c , and the false warning looked like this, WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL_GPL(rcu_lock_map); We actually should be checking the statement before the EXPORT_* for a mention of the exported object, and complain where it is not there. [akpm@linux-foundation.org: coding-style fixes] Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reported-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: fix __attribute__ matchingAndy Whitcroft
In the following code, union thread_union init_thread_union __attribute__((__section__(".data.init_task"))) = { INIT_THREAD_INFO(init_task) }; There is a non-conforming declaration. It should really be like the following, union thread_union init_thread_union __attribute__((__section__(".data.init_task"))) = { INIT_THREAD_INFO(init_task) }; However, checkpatch doesn't catch this right now because it doesn't correctly evaluate the "__attribute__". It is not at all clear that we care what preceeds an assignment style attribute when we find the open brace. Relax the test so we do not need to check the __attribute__. Reported-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: fix false errors due to macro concatenationAndy Whitcroft
The macro concatenation (##) sequence can cause false errors when checking macro's. Checkpatch doesn't currently know about the operator. For example this line, + entry = (struct ftrace_raw_##call *)raw_data; \ is correct but it produces the following error, ERROR: need consistent spacing around '*' (ctx:WxB) + entry = (struct ftrace_raw_##call *)raw_data;\ ^ The line above doesn't have any spacing problems, and if you remove the macro concatenation sequence checkpatch doesn't give any errors. Extend identifier handling to include ## concatenation within the definition of an identifier. Reported-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: update copyright datesAndy Whitcroft
2009-10-29checkpatch: correctly stop scanning at the bottom of a hunkAndy Whitcroft
We are allowing context scanning checks to apply against the first line of context outside at the end of the hunk. This can lead to false matches to patch names leading to various perl warnings. Correctly stop at the bottom of the hunk. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29checkpatch: possible types -- prevent illegal modifiers being addedAndy Whitcroft
Prevent known non types being detected as modifiers. Ensure we do not look at any type which starts with a keyword. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-29scripts/get_maintainer.pl: add patch/file search for keywordsJoe Perches
Based on an idea from Wolfram Sang. Add search for MAINTAINERS line "K:" regex pattern match in a patch or file Matches are added after file pattern matches Add --keywords command line switch (default 1, on) Change version to 0.21 Signed-off-by: Joe Perches <joe@perches.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-15kconfig: Make zconf.y work with current bisonJosh Triplett
zconf.y includes zconf.hash.c from the initial code section. zconf.hash.c references the token constants from zconf.y. However, current bison defines the token constants after the initial code section, making zconf.hash.c fail to compile. Move the include of zconf.hash.c later in zconf.y, so bison puts it after the token constants. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-10-11warn about use of uninstalled kernel headersArnd Bergmann
User applications frequently hit problems when they try to use the kernel headers directly, rather than the exported headers. This adds an explicit warning for this case, and points to a URL holding an explanation of why this is wrong and what to do about it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-10-11kbuild: mkcompile_h: trivial cleanupsFelipe Contreras
UTS_TRUNCATTE is simpler this way, and now editors idetify this as a shell script. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-10-11kbuild: fix warning when domainname is not availableFelipe Contreras
Otherwise we get: "dnsdomainname: Unknown host" Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-10-11kbuild: Fix size_append issue for bzip2/lzma kernelAlek Du
The Makefile.lib will call "echo -ne" to append uncompressed kernel size to bzip2/lzma kernel image. The "echo" here depends on the shell that /bin/sh pointing to. On Ubuntu system, the /bin/sh is pointing to dash, which does not support "echo -e" at all. Use /bin/echo instead of shell echo should always be safe. Signed-off-by: Alek Du <alek.du@intel.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-10-11kbuild,scripts: use non-builtin echo for '-e'Amerigo Wang
Alek reported that on Ubuntu, where dash is used, 'echo -e' can't work, so let's use non-builtin echo in this case. Reported-by: Alek Du <alek.du@intel.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-10-11kbuild: fix the binrpm-pkg target to work with KBUILD_OUTPUT setFrans Pop
The binrpm-pkg target (binary RPM only) fails when called with KBUILD_OUTPUT set. This patch makes it work. For the rpm-pkg target (source + binary RPM), building with KBUILD_OUTPUT set is not possible and also not needed as the actual build is done in a temporary directory anyway, so check that KBUILD_OUTPUT is not set in that case to avoid later errors. Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23spi: add support for device table matchingAnton Vorontsov
With this patch spi drivers can use standard spi_driver.id_table and MODULE_DEVICE_TABLE() mechanisms to bind against the devices. Just like we do with I2C drivers. This is useful when a single driver supports several variants of devices but it is not possible to detect them in run-time (like non-JEDEC chips probing in drivers/mtd/devices/m25p80.c), and when platform_data usage is overkill. This patch also makes life a lot easier on OpenFirmware platforms, since with OF we extensively use proper device IDs in modaliases. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kallsyms: fix segfault in prefix_underscores_count()Paul Mundt
Commit b478b782e110fdb4135caa3062b6d687e989d994 "kallsyms, tracing: output more proper symbol name" introduces a "bugfix" that introduces a segfault in kallsyms in my configurations. The cause is the introduction of prefix_underscores_count() which attempts to count underscores, even in symbols that do not have them. As a result, it just uselessly runs past the end of the buffer until it crashes: CC init/version.o LD init/built-in.o LD .tmp_vmlinux1 KSYM .tmp_kallsyms1.S /bin/sh: line 1: 16934 Done sh-linux-gnu-nm -n .tmp_vmlinux1 16935 Segmentation fault | scripts/kallsyms > .tmp_kallsyms1.S make: *** [.tmp_kallsyms1.S] Error 139 This simplifies the logic and just does a straightforward count. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> [2.6.30.x, 2.6.31.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Fix all -Wmissing-prototypes warnings in x86 defconfigTrevor Keith
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22checkpatch: add some common Blackfin checksMike Frysinger
Add checks for Blackfin-specific issues that seem to crop up from time to time. In particular, we have helper macros to break a 32bit address into the hi/lo parts, and we want to make sure people use the csync/ssync variant that includes fun anomaly workarounds. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: version 0.29Andy Whitcroft
2009-09-22checkpatch: limit sN/uN matches to actual bit sizesAndy Whitcroft
Limit our type matcher to the s/u/le/be etc sizes that actually exist to prevent miss categorising s2 as a type. Fix up the spelling of the error also. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: format strings should not have brackets in macrosAndy Whitcroft
We should not recommend braces for the following: #define pr_fmt(fmt) "%s: " fmt, __func__ allow things with double quotes round them to avoid this check. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: make -f alias --file, add --help, more verbose help messageHannes Eder
Impact: - More verbose help/usage message. - Make the option -f an alias for --file. - On -h, --help, and --version display help message and exit(0). - With no FILE(s) given, exit(1) with "no input files". - On invalid options display help/usage and exit(1). Based on a patch by Pavel Machek. Signed-off-by: Hannes Eder <hannes@hanneseder.net> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: indent checks -- stop when we run out of continuation linesAndy Whitcroft
Ensure we terminate when there are no futher continuation lines when trying to determine relative indent of conditionals and their blocks. Reported-by: John Daiker <daikerjohn@gmail.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: handle C99 comments correctly (performance issue)Daniel Walker
This fixes the sanitation process in checkpatch.pl so that it blocks out the text after a C99 style comment the same way it does with block style comments. This prevents the text from getting processed as regular code. Signed-off-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22checkpatch: possible types -- else cannot start a typeAndy Whitcroft
An else cannot start a type, it would have to be within a block after the else. This can trigger false modifier matching. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add maintainers in order listed in matched sectionJoe Perches
Previous behavior was "bottom-up" in each section from the pattern "F:" entry that matched. Now information is entered into the various lists in the "as entered" order for each matched section. This also allows the F: entry to be put anywhere in a section, not just as the last entries in the section. And a couple of improvements: Don't alphabetically sort before outputting the matched scm, status, subsystem and web sections. Ignore content after a single email address so these entries are acceptable M: name <address> whatever other comment And a fix: Make an M: entry without a name again use the name from an immediately preceding P: line if it exists. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add --remove-duplicatesJoe Perches
Allow control over the elimination of duplicate email names and addresses --remove-duplicates will use the first email name or address presented --noremove-duplicates will emit all names and addresses --remove-duplicates is enabled by default For instance: $ ./scripts/get_maintainer.pl -f drivers/char/tty_ioctl.c Greg Kroah-Hartman <gregkh@suse.de> Alan Cox <alan@linux.intel.com> Mike Frysinger <vapier@gentoo.org> Alexey Dobriyan <adobriyan@gmail.com> linux-kernel@vger.kernel.org $ ./scripts/get_maintainer.pl -f --noremove-duplicates drivers/char/tty_ioctl.c Greg Kroah-Hartman <gregkh@suse.de> Alan Cox <alan@redhat.com> Alan Cox <alan@linux.intel.com> Alan Cox <alan@lxorguk.ukuu.org.uk> Mike Frysinger <vapier@gentoo.org> Alexey Dobriyan <adobriyan@gmail.com> linux-kernel@vger.kernel.org Using --remove-duplicates could eliminate multiple maintainers that share the same name but not the same email address. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: using --separator implies --nomultilineJoe Perches
If a person sets a separator, it's only used if --nomultiline is set. Don't make the command line also include --nomultiline in that case. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add .mailmap use, shell and email cleanupsJoe Perches
Add reading and using .mailmap file if it exists Convert address entries in .mailmap to first encountered address Don't terminate shell commands with \n Strip characters found after sign-offs by: name <address> [stripped] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: better email routines, use perl not shell where ↵Joe Perches
possible Added format_email and parse_email routines to reduce inline use. Added email_address_inuse to eliminate multiple maintainer entries for the same email address, the first name encountered is used. Used internal perl equivalents of shell cmd use of grep|cut|sort|uniq Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add --pattern-depthJoe Perches
--pattern-depth is used to control how many levels of directory traversal should be performed to find maintainers. default is 0 (all directory levels). For instance: MAINTAINERS currently has multiple M: and F: entries that match net/netfilter/ipvs/ip_vs_app.c IPVS M: Wensong Zhang <wensong@linux-vs.org> M: Simon Horman <horms@verge.net.au> M: Julian Anastasov <ja@ssi.bg> [...] F: net/netfilter/ipvs/ NETFILTER/IPTABLES/IPCHAINS [...] M: Patrick McHardy <kaber@trash.net> [...] F: net/netfilter/ NETWORKING [GENERAL] M: "David S. Miller" <davem@davemloft.net> [...] F: net/ THE REST M: Linus Torvalds <torvalds@linux-foundation.org> [...] F: */ Using this command will return all of those maintainers: (except Linus unless --git-chief-maintainers is specified) $ ./scripts/get_maintainer.pl --nogit -nol \ -f net/netfilter/ipvs/ip_vs_app.c Julian Anastasov <ja@ssi.bg> Simon Horman <horms@verge.net.au> Wensong Zhang <wensong@linux-vs.org> Patrick McHardy <kaber@trash.net> David S. Miller <davem@davemloft.net> Adding --pattern-depth=1 will match at the deepest level $ ./scripts/get_maintainer.pl --nogit -nol --pattern-depth=1 \ -f net/netfilter/ipvs/ip_vs_app.c Julian Anastasov <ja@ssi.bg> Simon Horman <horms@verge.net.au> Wensong Zhang <wensong@linux-vs.org> Adding --pattern-depth=2 will match at the deepest level and 1 higher $ ./scripts/get_maintainer.pl --nogit -nol --pattern-depth=2 \ -f net/netfilter/ipvs/ip_vs_app.c Julian Anastasov <ja@ssi.bg> Simon Horman <horms@verge.net.au> Wensong Zhang <wensong@linux-vs.org> Patrick McHardy <kaber@trash.net> and so on. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add sections in pattern match depth orderJoe Perches
Before this change, matched sections were added in the order of appearance in the normally alphabetic section order of the MAINTAINERS file. For instance, finding the maintainer for drivers/scsi/wd7000.c would first find "SCSI SUBSYSTEM", then "WD7000 SCSI SUBSYSTEM", then "THE REST". before patch: $ ./scripts/get_maintainer.pl --nogit -f drivers/scsi/wd7000.c James E.J. Bottomley <James.Bottomley@HansenPartnership.com> Miroslav Zagorac <zaga@fly.cc.fer.hr> linux-scsi@vger.kernel.org linux-kernel@vger.kernel.org get_maintainer.pl now selects matched sections by longest pattern match. Longest is the number of "/"s and any specific file pattern. This changes the example output order of MAINTAINERS to whatever is selected in "WD7000 SUBSYSTEM", then "SCSI SYSTEM", then "THE REST". after patch: $ ./scripts/get_maintainer.pl --nogit -f drivers/scsi/wd7000.c Miroslav Zagorac <zaga@fly.cc.fer.hr> James E.J. Bottomley <James.Bottomley@HansenPartnership.com> linux-scsi@vger.kernel.org linux-kernel@vger.kernel.org Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22scripts/get_maintainer.pl: add --git-blameJoe Perches
Julia Lawall suggested that get_maintainers.pl should have the ability to include signatories of commits that are modified by a particular patch. Vegard Nossum did something similar once. http://lkml.org/lkml/2008/5/29/449 The modified script looks the commits for all lines in the patch, and includes the "-by:" signatories for those commits. It uses the same git-min-percent, git-max-maintainers, and git-min-signatures options. git-since is ignored. It can be used independently from the --git default, so ./scripts/get_maintainers.pl --nogit --git-blame <patch> or ./scripts/get_maintainers.pl --nogit --git-blame -f <file> is acceptable. If used with -f <file>, all lines/commits for the file are checked. --git-blame can be slow if used with -f <file> --git-blame does not work with -f <directory> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kernel/profile.c: Switch /proc/irq/prof_cpu_mask to seq_file tracing: Export trace_profile_buf symbols tracing/events: use list_for_entry_continue tracing: remove max_tracer_type_len function-graph: use ftrace_graph_funcs directly tracing: Remove markers tracing: Allocate the ftrace event profile buffer dynamically tracing: Factorize the events profile accounting
2009-09-21trivial: kbuild: remove extraneous blank line after declaration of usage()Trevor Keith
Signed-off-by: Trevor Keith <tsrk@tsrk.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: remove references to non-existent include/linux/config.hMarkus Heidelberg
Ignore drivers/staging/ since it is very likely that new drivers introduce it again. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
