path: root/scripts
2008-05-25scripts/ver_linux use 'gcc -dumpversion'Gabriel C
These magic greps and hacks in ver_linux to get the gcc version always break after some gcc releases. Since now gcc >4.3 allows compiling with '--with-pkgversion' ( which can be everything 'My Cool Gcc' or something ) ver_linux will report random junk for these. Simply use 'gcc -dumpversion' to get the gcc version which should always work. Signed-off-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-19kconfig: incorrect 'len' field initialisation ?Christophe Jaillet
1) The field 'len' of the 'gstr' structure seems to track the size of the memory already allocated for the "growable string". So the value of this field should be the same as the 'malloc()' just above, shouldn't it ? Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-19kernel-doc: allow unnamed bit-fieldsRandy Dunlap
Allow for unnamed bit-fields and skip them instead of printing an erroneous warning message for them, such as: Warning(include/asm-s390/cio.h:103): No description found for parameter 'u32' which contains: struct tm_scsw { u32 :1; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-19kbuild: filter away debug symbols from kernel symbolsSam Ravnborg
Andi Kleen <andi@firstfloor.org> reported that he saw a lot of symbols like this: 0000000000000b24 N DW.aio.h.903a6d92.2 0000000000000bce N DW.task_io_accounting.h.8d8de327.0 0000000000000bec N DW.hrtimer.h.c23659c6.0 in his System.map / kallsyms output. Simple solution is to skip all debugging symbols (they are marked 'N'). Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Paulo Marques <pmarques@grupopie.com>
2008-05-11kbuild: disable modpost warnings for linkonce sectionsAndi Kleen
Disable modpost warnings for linkonce sections My build gives lots of warnings like WARNING: sound/core/snd.o (.gnu.linkonce.wi.mpspec_def.h.30779716): unexpected section name. The (.[number]+) following section name are ld generated and not expected. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. But for .linkonce. duplicated sections are actually ok and expected. So just disable the warning for this case. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-04kconfig: fix MAC OS X warnings in menuconfigSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Timur Tabi <timur@freescale.com>
2008-05-04modpost: i2c aliases need no trailing wildcardJean Delvare
Not all device types need a wildcard at the end of their module aliases. In particular, for i2c module aliases, the trailing wildcard is not only unneeded, it could also cause the wrong driver to be loaded. As I2C devices have no IDs, i2c module aliases are simple, arbitrary device names. For example: $ /sbin/modinfo lm90 filename: /lib/modules/2.6.25-git18/kernel/drivers/hwmon/lm90.ko author: Jean Delvare <khali@linux-fr.org> description: LM90/ADM1032 driver license: GPL vermagic: 2.6.25-git18 mod_unload depends: hwmon alias: i2c:lm90* alias: i2c:adm1032* alias: i2c:lm99* alias: i2c:lm86* alias: i2c:max6657* alias: i2c:adt7461* alias: i2c:max6680* $ This would cause trouble if one I2C chip name matches the beginning of another I2C chip name and both chips are supported by different drivers. For example, an i2c device named lm9042 would cause the lm90 driver to be loaded, while it doesn't support that device. This case has yet to be seen in practice, but still, I'd like to fix it now. The cleanest fix is to remove the trailing wildcard from i2c module aliases. Here's a patch doing this. Not all device type aliases need a trailing wildcard, in particular the i2c aliases don't. Don't add a wildcard by default in do_table(), instead let each device type handler add it if needed. I have tested types acpi, dmi, eisa, i2c, ide, ieee1394, input, pci, pcmcia, platform, pnp, scsi, serio, ssb and usb. Other types (ccw, of, vio, parisc, sdio and virtio) are untested. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-01kconfig: made check-lxdialog more portableSam Ravnborg
OS-X shell did not like 'echo -e' so implement suggestion from Al Viro to use a more portable construct. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Acked-By: Timur Tabi <timur@freescale.com>
2008-04-30kallsyms: nuke all ChangeLog, this should be logged by gitBryan Wu
Pointed out by Paulo: "When I wrote this initially, it was a mistake to add a Changelog in the first place, but I didn't know better at the time. If you're going to make changes to this file, please remove all the Changelog, instead of adding more entries to it. The 'Changelog' should be kept by the version control system, and not the source code itself." Cc: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-29update checkpatch.pl to version 0.18Andy Whitcroft
This version brings a few fixes for the extern checks, and a couple of new checks. Of note: - false is now recognised as a 0 assignment in static/external assignments, - printf format strings including %L are reported, - a number of fixes for the extern in .c file detector which had temporarily lost its ability to detect variables; undetected due to the loss of its test. Andy Whitcroft (8): Version: 0.18 false should trip 0 assignment checks tests: reinstate missing tests tests: allow specification of the file extension for a test fix extern checks for variables check for and report %Lu, %Ld, and %Li ensure we only start a statement on lines with some content extern spacing Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29update checkpatch.pl to version 0.17Andy Whitcroft
This version brings improvements to external declaration detection, fixes to quote tracking, fixes to unary tracking, some clarification of wording, and the usual slew of fixes for false positives. Of note: - much better unary tracking across preprocessor directives - UTF8 checks highlight the character at fault - widening of mutex detection Andy Whitcroft (17): Version: 0.17 values: __attribute__ carries through the previous type quotes: should only follow "positive" lines clarify the indent tabs over spaces wording loosen NR_CPUS check for array range initialisers detect external function declarations without an extern prefix function declaration arguments should be with the identifier DEFINE_MUTEX should report in line with struct mutex NR_CPUS is valid in preprocessor statements comment detection should not start on the @@ line types: add support for #undef tighten mutex/completion reports to usage allow export of function pointers values: preprocessor #define is out of line maintain values values: #define does not always have parentheses unary '*' may be const utf8 checks should report location of the invalid character Wolfram Sang (1): make checkpatch.pl really skip <asm/irq.h> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29scripts/Lindent: support gnu indent v2.2.10Joe Perches
The new version of indent supports positioning labels in column 1 using "-il0" http://www.nabble.com/Release-2.2.10-of-GNU-Indent-td15990700.html Add "-il0" if indent version >= 2.2.10 Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kconfig: add named choice groupRoman Zippel
As choice dependency are now fully checked, it's quite easy to add support for named choices. This lifts the restriction that a choice value can only appear once, although it still has to be within the same group, but multiple choices can be joined by giving them a name. While at it I cleaned up a little the choice type logic to simplify it a bit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kconfig: fix choice dependency checkRoman Zippel
Properly check the dependency of choices as a group. Also fix that sym_check_deps() correctly terminates the dependency loop error check (otherwise it would continue printing the dependency chain). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kbuild: fix unportability in gen_initramfs_list.shFelix Fietkau
On a Mac OS X machine the output of ls -l is different from a standard Linux machine. Use readlink instead of parsing a hardcoded field number from the ls output. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kconfig: reversed borderlines in inputboxRoel Kluin
Fix reversal of dlg.border.atr and dlg.dialog.atr for draw_box() Makes the inputbox look like expected Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-28kernel-doc: detect trailing kernel-doc line trashRandy Dunlap
Print a warning when a kernel-doc comment block ends with text on the same line as the ending comment characters, e.g.: * this text is lost. */ Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28kernel-doc: detect/prevent duplicate doc section namesRandy Dunlap
I saw this problem recently. With this kernel-doc: * Note: some important info * * Note: other important info kernel-doc uses the "section name" (preceding the ':', like "Note") as a hash key for storing the descriptive text ("blah important info"). It is (was) possible to have duplicate (colliding) section names, without any kind of warning or error. kernel-doc happily used the latter descriptive text for all instances of printing the <section-name> descriptive text and the former important info was lost. One way to "fix" this is to modify the kernel-doc comments, e.g.: * Note1: foo bar * * Note.2: blah zay For now, kernel-doc will signal an error when it sees colliding section names like this. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26kbuild: scripts/Makefile.modpost typo fixAdrian Bunk
-EVIUSER ;-) Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-26kbuild: soften MODULE_LICENSE checkSam Ravnborg
Only modules that has other MODULE_* content shall have the MODULE_LICENSE() tag. This fixes allmodconfig build on my box. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (120 commits) usb: don't update devnum for wusb devices wusb: make ep0_reinit available for modules wusb: devices dont use a set address wusb: teach choose_address() about wireless devices wusb: add link wusb-usb device wusb: add authenticathed bit to usb_dev USB: remove unnecessary type casting of urb->context usb serial: more fixes and groundwork for tty changes USB: replace remaining __FUNCTION__ occurrences USB: usbfs: export the URB_NO_INTERRUPT flag to userspace USB: fix compile problems in ehci-hcd USB: ehci: qh_completions cleanup and bugfix USB: cdc-acm: signedness fix USB: add documentation about callbacks USB: don't explicitly reenable root-hub status interrupts USB: OHCI: turn off RD when remote wakeup is disabled USB: HCDs use the do_remote_wakeup flag USB: g_file_storage: ignore bulk-out data after invalid CBW USB: serial: remove endpoints setting checks from core and header USB: serial: remove unneeded number endpoints settings ...
2008-04-25kconfig: fix broken target update-po-configSam Ravnborg
Massimo Maiurana reported: In the latest kernel "make update-po-config" fails because it tries to open arch/Kconfig/Kconfig, since the ls command doesn't distinguish between files and directories. Cc: Massimo Maiurana <maiurana@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: Add new Kbuild variable KBUILD_EXTRA_SYMBOLSRichard Hacker
This patch adds a new (Kbuild) Makefile variable KBUILD_EXTRA_SYMBOLS. The space separated list of file names assigned to KBUILD_EXTRA_SYMBOLS is used when calling scripts/mod/modpost during stage 2 of the Kbuild process for non-kernel-tree modules. Signed-off-by: Richard Hacker <lerichi@gmx.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: support loading extra symbols in modpostRichard Hacker
This patch adds a new command line option -E to modpost, expecting a symbol file as an argument which is read prior to symbol processing. -E can be supplied multiple times for as many files as is needed. When building kernel modules that depend on other modules not in the main kernel tree, modpost complains about undefined symbols: # make -C /path/to/linux/kernel M=/path/to/my/module ... Building modules, stage 2. .... WARNING: "rt_copy_buf" [/home/rich/osc_etl_rtw/osc_kmod.ko] undefined! ...etc This situation occurs when modpost processes the new module's symbols. When it finds symbols not exported by the mainline kernel, it issues this warning. The patch adds a new command line option -e to modpost which expects a symbol file as an argument. The symbols listed in this file are added to modpost's symbol tables during startup. -e can be supplied as often as required. This patch works together with the second patch. It introduces a new make variable, KBUILD_EXTRA_SYMBOLS, which is used when calling modpost. Signed-off-by: Richard Hacker <lerichi@gmx.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: fix some minor typoesRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-25kbuild: error out on missing MODULE_LICENSESam Ravnborg
Adrian Bunk suggested a build time check for missing MODULE_LICENSE annotation in modules. The build time check is fatal as we really want this fixed for all modules. In-tree modules should all have been fixed up by now. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@kernel.org>
2008-04-24checkpatch: usb_free_urb() can take NULLGreg Kroah-Hartman
usb_free_urb() can take a NULL, so let's check and warn about that. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19PNP: add all PNP card device id's as individual aliasesKay Sievers
The current PNP combined card + devices module aliase can never ever match anything, because these values are not available all at the same time to request a module. Instead of adding the combined alias, we add the device id's all as individual aliases. Device id's are exported by the PNP bus and can now properly used to request the loading of a matching module. The module snd-sbawe currently exports aliases, which can never match anything: alias: pnp:cCTLXXXXdCTL0045dCTL0022* alias: pnp:cCTLXXXXdCTL0044dCTL0023* alias: pnp:cCTLXXXXdCTL0042dCTL0022* alias: pnp:cCTLXXXXdCTL0041dCTL0021* alias: pnp:cCTLXXXXdCTL0031dCTL0021* alias: pnp:cCTL00eddCTL0041dCTL0070* alias: pnp:cCTL00e9dCTL0045dCTL0022* alias: pnp:cCTL00e4dCTL0045dCTL0022* alias: pnp:cCTL00c7dCTL0045dCTL0022* alias: pnp:cCTL00c5dCTL0045dCTL0022* alias: pnp:cCTL00c3dCTL0045dCTL0022* alias: pnp:cCTL00c1dCTL0042dCTL0022* alias: pnp:cCTL00b2dCTL0044dCTL0023* alias: pnp:cCTL009edCTL0044dCTL0023* alias: pnp:cCTL009ddCTL0042dCTL0022* alias: pnp:cCTL009fdCTL0041dCTL0021* alias: pnp:cCTL009cdCTL0041dCTL0021* alias: pnp:cCTL009adCTL0041dCTL0021* alias: pnp:cCTL0054dCTL0031dCTL0021* alias: pnp:cCTL0048dCTL0031dCTL0021* alias: pnp:cCTL0047dCTL0031dCTL0021* alias: pnp:cCTL0046dCTL0031dCTL0021* alias: pnp:cCTL0045dCTL0031dCTL0021* alias: pnp:cCTL0044dCTL0031dCTL0021* alias: pnp:cCTL0043dCTL0031dCTL0021* alias: pnp:cCTL0042dCTL0031dCTL0021* alias: pnp:cCTL0039dCTL0031dCTL0021* alias: pnp:cCTL0035dCTL0031dCTL0021* With this patch it exports only the device id's, as properly matchable aliases: alias: pnp:dCTL0070* alias: pnp:dCTL0045* alias: pnp:dCTL0023* alias: pnp:dCTL0044* alias: pnp:dCTL0022* alias: pnp:dCTL0042* alias: pnp:dCTL0041* alias: pnp:dCTL0021* alias: pnp:dCTL0031* Now, the exported value of the PNP bus can be used to autoload a matching module: $ modprobe --first-time -n -v pnp:dCTL0045 insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-rawmidi.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/mpu401/snd-mpu401-uart.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-hwdep.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb-common.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-csp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-dsp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/opl3/snd-opl3-lib.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sbawe.ko $ grep CTL0045 /sys/bus/pnp/devices/*/id /sys/bus/pnp/devices/01:01.00/id:CTL0045 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-28update checkpatch.pl to version 0.16Andy Whitcroft
This version brings proper quote tracking across lines, and brings the handling of comments into the same mechanism ensuring nesting is correctly handled. It brings the usual flurry of fixes for false positives. It also brings a number of new checks. The most contentious change will likely be the checks for NR_CPUS as this throws some new warnings in kernel/sched.c. Of note: - all new quote tracking across lines - all new comment tracking - new more direct, less ambigious wording for some warnings - recommends mutexes and completions over semaphores - recommends strict_strto* over simple_strto* - report on direct use of NR_CPUS Andy Whitcroft (22): Version: 0.16 string quote tracking should cross line boundaries check spacing round -> correctly across newlines checks for linux/ against asm/ include files should be warnings standardise on 'required' and 'prohibited' take the first end of condition when parsing statements values: cope with unbalanced brackets preprocessor #elif is not a function preprocessor #if should not trigger trailing statement checks test: allow us to limit output to a single error recommend real mutexes over semaphores asm checks should mirror those for __asm__ warn on semaphores being used in place of completions trailing ; on control structure should ignore do {} while (); recommend strict_strtoX over simple_strtoX redo comment handling as a quote type use of NR_CPUS is normally wrong consistant spacing should only be about spaces if brace check suppression should only apply to the top-levels use tr/// to align spacing for operators move to using four parameter form of substr check and report modifications to include/asm Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-23kbuild: soften modpost checks when doing cross buildsSam Ravnborg
The module alias support in the kernel have a consistency check where it is checked that the size of a structure in the kernel and on the build host are the same. For cross builds this check does not make sense so detect when we do cross builds and silently skip the check in these situations. This fixes a build bug for a wireless driver when cross building for arm. Acked-by: Michael Buesch <mb@bu3sch.de> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: stable@kernel.org
2008-03-13kernel-doc: set verbose mode via environmentRandy Dunlap
Honor the environment variable "KBUILD_VERBOSE=1" (as set by make V=1) to enable verbose mode in scripts/kernel-doc. Useful for getting more info and warnings from kernel-doc. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04update checkpatch.pl to version 0.15Andy Whitcroft
This version brings a number of minor fixes updating the type detector and the unary tracker. It also brings a few small fixes for false positives. It also reverts the --file warning. Of note: - limit CVS checks to added lines - improved type detections - fixes to the unary tracker Andy Whitcroft (13): Version: 0.15 EXPORT_SYMBOL checks need to accept array variables export checks must match DECLARE_foo and LIST_HEAD possible types: cleanup debugging missing line values: track values through preprocessor conditional paths typeof is actually a type possible types: detect definitions which cross lines values: include line numbers on value debug information values: ensure we find correctly record pending brackets values: simplify the brace history stack CVS keyword checks should only apply to added lines loosen spacing for comments allow braces for single statement blocks with multiline conditionals Harvey Harrison (1): checkpatch: remove fastcall Ingo Molnar (1): checkpatch.pl: revert wrong --file message Uwe Kleine-Koenig (1): fix typo "goot" -> "good" Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23kernel-doc: fix function-pointer-parameter parsingRichard Kennedy
When running "make htmldocs" I'm seeing some non-fatal perl errors caused by trying to parse the callback function definitions in blk-core.c. The errors are "Use of uninitialized value in concatenation (.)..." in combination with: Warning(linux-2.6.25-rc2/block/blk-core.c:1877): No description found for parameter '' The function pointers are defined without a * i.e. int (drv_callback)(struct request *) The compiler is happy with them, but kernel-doc isn't. This patch teaches create_parameterlist in kernel-doc to parse this type of function pointer definition, but is it the right way to fix the problem ? The problem only seems to occur in blk-core.c. However with the patch applied, kernel-doc finds the correct parameter description for the callback in blk_end_request_callback, which is doesn't normally. I thought it would be a bit odd to change to code to use the more normal form of function pointers just to get the documentation to work, so I fixed kernel-doc instead - even though this is teaching it to understand code that might go away (The comment for blk_end_request_callback says that it should not be used and will removed at some point). Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-19kbuild: fix reversed symbol name order in modpostGeert Uytterhoeven
XXXINIT_TO_INIT and XXXEXIT_TO_EXIT warnings use the reversed symbol name order in the suggestion, e.g.: WARNING: vmlinux.o(.meminit.text+0x36c): Section mismatch in reference from the function free_area_init_core() to the function .init.text:setup_usemap() The function __meminit free_area_init_core() references a function __init setup_usemap(). If free_area_init_core is only used by setup_usemap then annotate free_area_init_core with a matching annotation. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: explain why DEBUG_SECTION_MISMATCH is UNDEFINED kbuild: fix building vmlinux.o kbuild: allow -fstack-protector to take effect kconfig: fix select in combination with default
2008-02-14kernel-doc: remove fastcallHarvey Harrison
fastcall is gone from the tree, no need to adjust the function prototypes anymore for this. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Linux Kernel Markers: create modpost fileMathieu Desnoyers
This adds some new magic in the MODPOST phase for CONFIG_MARKERS. Analogous to the Module.symvers file, the build will now write a Module.markers file when CONFIG_MARKERS=y is set. This file lists the name, defining module, and format string of each marker, separated by \t characters. This simple text file can be used by offline build procedures for instrumentation code, analogous to how System.map and Module.symvers can be useful to have for kernels other than the one you are running right now. The strings are made easy to extract by having the __trace_mark macro define the name and format together in a single array called __mstrtab_* in the __markers_strings section. This is straightforward and reliable as long as the marker structs are always defined by this macro. It is an unreasonable amount of hairy work to extract the string pointers from the __markers section structs, which entails handling a relocation type for every machine under the sun. Mathieu : - Ran through checkpatch.pl Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: David Smith <dsmith@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13kconfig: fix select in combination with defaultRoman Zippel
> The attached .config (with current -git) results in a compile > error since it contains: > > CONFIG_X86=y > # CONFIG_EMBEDDED is not set > CONFIG_SERIO=m > CONFIG_SERIO_I8042=y > > Looking at drivers/input/serio/Kconfig I simply don't get how this > can happen. You've hit the rather subtle rules of select vs default. What happened is that SERIO is selected to m, but SERIO_I8042 isn't selected so the default of y is used instead. We already had the problem in the past that select and default don't work well together, so this patch cleans this up and makes the rule hopefully more straightforward. Basically now the value is calculated like this: (value && dependency) || select where the value is the user choice (if available and the symbol is visible) or default. In this case it means SERIO and SERIO_I8042 are both set to y due to their default and if SERIO didn't had the default, then the SERIO_I8042 value would be limited to m due to the dependency. I tested this patch with more 10000 random configs and above case is the only the difference that showed up, so I hope there is nothing that depended on the old more complex and subtle rules. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Tested-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-11kbuild: fix make V=1Sam Ravnborg
When make -s support were added to filechk to combination created with make V=1 were not covered. Fix it by explicitly cover this case too. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Mike Frysinger <vapier@gentoo.org>
2008-02-09Kbuild: Fix deb-pkg target to work with kernel versions ending with ↵Michal Sojka
-<text-without-digit> If CONIFIG_LOCALVERSION is set for example to -loop, the following error message was generated. dpkg-deb - error: Debian revision (`loop') doesn't contain any digits dpkg-deb: 1 errors in control file The patch solves this by adding a numeric revision to package version. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild: silence CHK/UPD messages according to $(quiet)Mike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild/modpost: Use warn() for announcing section mismatchesGeert Uytterhoeven
modpost: Use warn() for announcing section mismatches, for easy grepping for warnings in build logs. Also change an existing call from fprintf() to warn() while we're at it. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09Add binoffset to gitignoreUwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild/modpost: improve warnings if symbol is unknownSam Ravnborg
If we cannot determine the symbol then print (unknown) to hint the reader that we failed to find the symbol. This happens with REL relocation records in arm object files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-08update checkpatch.pl to version 0.14Andy Whitcroft
This version brings the remainder of the queued fixes. A number of fixes for items missed reported by Andrew Morton and others. Also a handful of new checks and fixes for false positives. Of note: - new warning associated with --file to try and avoid cleanup only patches, - corrected handling of completly empty files, - corrected report handling with multiple files, - handling of possible types in the face of multiple declarations, - detection of unnessary braces on complex if statements (where present), and - all new comment spacing handling. Andi Kleen (1): Introduce a warning when --file mode is used Andy Whitcroft (14): Version: 0.14 clean up some space violations in checkpatch.pl a completly empty file should not provoke a whinge reset report lines buffers between files unary ++/-- may abutt close braces __typeof__ is also unary comments: revamp comment handling add --summary-file option adding filename to summary line trailing backslashes are not trailing statements handle operators passed as parameters such as to ASSERTCMP possible types -- enhance debugging check for boolean operations with constants possible types: handle multiple declarations detect and report if statements where all branches are single statements Arjan van de Ven (1): quiet option should not print the summary on no errors Bartlomiej Zolnierkiewicz (1): warn about using __FUNCTION__ Timur Tabi (1): loosen spacing checks for __asm__ Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08update checkpatch.pl to version 0.13Andy Whitcroft
This version brings a large number of fixes which have built up over the Christmas period. Mostly these are fixes for false positives, both through improvments to unary checks and possible type detection. It also brings new checks for while location and CVS keywords. Of note: - a number of fixes to unary detection - detection of a number of new forms of types to improve type matching - better inline handling - recognision of '%' as an operator Andy Whitcroft (28): Version: 0.13 unary detection: maintain bracket state across lines move to pre-sanitising the entire file the text of a #error statement should be treated like it is in quotes line sanitisation needs to target double backslash correctly tighten comment guestimation for lines starting ' * ' debug: add a debug framework prevent unclosed single quotes from spreading add % as an operator the text of a #warning statement should be treated like it is in quotes possible matching applies in typedefs single statement block checks must not trigger when two or more statements possible types: local variables may also be const treat inline as a type attribute to even when out of place possible types: sparse annotations are valid indicators possible types: beef up the possible type testing check for hanging while statements on the wrong line utf8 checks need to occur against the raw lines function brace checks should use any whitespece matches comments should take up space in the line when sanitised remove debugging from if assignment checks possible types -- ensure we detect all pointer casts fix tests for function spacing in the presence of #define clean up the UTF-8 error message to be clearer test-lib: invert the status report, output success counts detect and report CVS keywords tests: break out tests Add $Id$ to the CVS keyword checks Benny Halevy (1): checkpatch.pl: recognize the #elif preprocessor directive Geert Uytterhoeven (1): print the filenames of patches where available Mauro Carvalho Chehab (1): Fix missing \n in checkpatch.pl Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: warn on badly formatted short descriptionRandy Dunlap
Make kernel-doc warn when a function/struct/union/typedef does not contain a properly formatted short description, such as: * scsi_devinfo: set up the dynamic device list or * scsi_devinfo - This warning is only generated when verbose (-v) mode is used. Also explain the -v command line option in the -h output. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: prevent duplicate description: outputRandy Dunlap
Prevent duplicate output of a Description: section when there is a "blank" ("*") line between the initial function name/description line and the "Description:" header. Test case: drivers/scsi/scsi_devinfo.c::scsi_init_devinfo(). Rob Landley hit this while he was producing SCSI kernel-doc. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: fix for vunmap function prototypeRandy Dunlap
Fix kernel-doc function prototype parsing which was exposed by vunmap() by allowing more than one '*' before the function name. Error(linux-2.6.24-mm1//mm/vmalloc.c:438): cannot understand prototype: 'struct page **vunmap(const void *addr) ' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
