git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio balloon driver fixes from Rusty Russell:
"Refactoring broke the balloon driver, and fixing kallsyms on ARM broke
some (non-ARM) MMUless setups, so we're making that fix ARM-only for
now.
Unfortunately, the ARM refactoring which broke kallsyms/perf was
CC:stable, so the fix (which broken non-ARM) was also CC:stable, so
now the partial reversion is also CC:stable..."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
scripts/link-vmlinux.sh: only filter kernel symbols for arm
virtio_balloon: update_balloon_size(): update correct field
Currently localmodconfig will miss dependencies from the default option.
For example:
config FOO
default y if BAR || ZOO
If FOO is needed for a module and is set to '=m', and so are BAR or ZOO,
localmodconfig will not see that BOO or ZOO are also needed for the foo
module, and will incorrectly disable them.
Link: http://lkml.kernel.org/r/20131218175137.162937350@goodmis.org
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC fixes from Vineet Gupta:
"These are couple of weeks old already, but I just couldn't get them to
you earlier.
- couple of fixes for recently added perf code
- build time extable sort"
* tag 'arc-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: [perf] Fix a few thinkos
ARC: Add guard macro to uapi/asm/unistd.h
ARC: extable: Enable sorting at build time
Prefer use of the direct definition of struct pci_device_id instead of
indirection via macro DEFINE_PCI_DEVICE_TABLE.
Update the PCI documentation to deprecate DEFINE_PCI_DEVICE_TABLE. Update
checkpatch adding --fix option.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Actually CONFIG_PAGE_OFFSET isn't same with PAGE_OFFSET, so
it isn't easy to figue out PAGE_OFFSET defined in header
file from scripts.
Because CONFIG_PAGE_OFFSET may not be defined in some ARCHs(
64bit ARCH), or defined as bogus value in !MMU case, so
this patch only applys the filter on ARM when CONFIG_PAGE_OFFSET
is defined as the original problem is only on ARM.
Cc: <stable@vger.kernel.org>
Fixes: f6537f2f0eba4eba3354e48dbe3047db6d8b6254
Singed-off-by: Ming Lei <tom.leiming@gmail.com>
This matches the existing behavior in arch/tile/Makefile for defconfig.
Reported-by: fengguang.wu@intel.com
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Tony Lu <zlu@tilera.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Avoids wasting cycles at boot specially on slower simulators
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Francois Bedard <fbedard@synopsys.com>
Acked-by: David Daney <david.daney@cavium.com>
Merge patches from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: place page->pmd_huge_pte to right union
MAINTAINERS: add keyboard driver to Hyper-V file list
x86, mm: do not leak page->ptl for pmd page tables
ipc,shm: correct error return value in shmctl (SHM_UNLOCK)
mm, mempolicy: silence gcc warning
block/partitions/efi.c: fix bound check
ARM: drivers/rtc/rtc-at91rm9200.c: disable interrupts at shutdown
mm: hugetlbfs: fix hugetlbfs optimization
kernel: remove CONFIG_USE_GENERIC_SMP_HELPERS cleanly
ipc,shm: fix shm_file deletion races
mm: thp: give transparent hugepage code a separate copy_page
checkpatch: fix "Use of uninitialized value" warnings
configfs: fix race between dentry put and lookup
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"In this patchset, we finally get an SELinux update, with Paul Moore
taking over as maintainer of that code.
Also a significant update for the Keys subsystem, as well as
maintenance updates to Smack, IMA, TPM, and Apparmor"
and since I wanted to know more about the updates to key handling,
here's the explanation from David Howells on that:
"Okay. There are a number of separate bits. I'll go over the big bits
and the odd important other bit, most of the smaller bits are just
fixes and cleanups. If you want the small bits accounting for, I can
do that too.
(1) Keyring capacity expansion.
KEYS: Consolidate the concept of an 'index key' for key access
KEYS: Introduce a search context structure
KEYS: Search for auth-key by name rather than target key ID
Add a generic associative array implementation.
KEYS: Expand the capacity of a keyring
Several of the patches are providing an expansion of the capacity of a
keyring. Currently, the maximum size of a keyring payload is one page.
Subtract a small header and then divide up into pointers, that only gives
you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses
a keyring to store ID mapping data, that has proven to be insufficient to
the cause.
Whatever data structure I use to handle the keyring payload, it can only
store pointers to keys, not the keys themselves because several keyrings
may point to a single key. This precludes inserting, say, and rb_node
struct into the key struct for this purpose.
I could make an rbtree of records such that each record has an rb_node
and a key pointer, but that would use four words of space per key stored
in the keyring. It would, however, be able to use much existing code.
I selected instead a non-rebalancing radix-tree type approach as that
could have a better space-used/key-pointer ratio. I could have used the
radix tree implementation that we already have and insert keys into it by
their serial numbers, but that means any sort of search must iterate over
the whole radix tree. Further, its nodes are a bit on the capacious side
for what I want - especially given that key serial numbers are randomly
allocated, thus leaving a lot of empty space in the tree.
So what I have is an associative array that internally is a radix-tree
with 16 pointers per node where the index key is constructed from the key
type pointer and the key description. This means that an exact lookup by
type+description is very fast as this tells us how to navigate directly to
the target key.
I made the data structure general in lib/assoc_array.c as far as it is
concerned, its index key is just a sequence of bits that leads to a
pointer. It's possible that someone else will be able to make use of it
also. FS-Cache might, for example.
(2) Mark keys as 'trusted' and keyrings as 'trusted only'.
KEYS: verify a certificate is signed by a 'trusted' key
KEYS: Make the system 'trusted' keyring viewable by userspace
KEYS: Add a 'trusted' flag and a 'trusted only' flag
KEYS: Separate the kernel signature checking keyring from module signing
These patches allow keys carrying asymmetric public keys to be marked as
being 'trusted' and allow keyrings to be marked as only permitting the
addition or linkage of trusted keys.
Keys loaded from hardware during kernel boot or compiled into the kernel
during build are marked as being trusted automatically. New keys can be
loaded at runtime with add_key(). They are checked against the system
keyring contents and if their signatures can be validated with keys that
are already marked trusted, then they are marked trusted also and can
thus be added into the master keyring.
Patches from Mimi Zohar make this usable with the IMA keyrings also.
(3) Remove the date checks on the key used to validate a module signature.
X.509: Remove certificate date checks
It's not reasonable to reject a signature just because the key that it was
generated with is no longer valid datewise - especially if the kernel
hasn't yet managed to set the system clock when the first module is
loaded - so just remove those checks.
(4) Make it simpler to deal with additional X.509 being loaded into the kernel.
KEYS: Load *.x509 files into kernel keyring
KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate
The builder of the kernel now just places files with the extension ".x509"
into the kernel source or build trees and they're concatenated by the
kernel build and stuffed into the appropriate section.
(5) Add support for userspace kerberos to use keyrings.
KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches
KEYS: Implement a big key type that can save to tmpfs
Fedora went to, by default, storing kerberos tickets and tokens in tmpfs.
We looked at storing it in keyrings instead as that confers certain
advantages such as tickets being automatically deleted after a certain
amount of time and the ability for the kernel to get at these tokens more
easily.
To make this work, two things were needed:
(a) A way for the tickets to persist beyond the lifetime of all a user's
sessions so that cron-driven processes can still use them.
The problem is that a user's session keyrings are deleted when the
session that spawned them logs out and the user's user keyring is
deleted when the UID is deleted (typically when the last log out
happens), so neither of these places is suitable.
I've added a system keyring into which a 'persistent' keyring is
created for each UID on request. Each time a user requests their
persistent keyring, the expiry time on it is set anew. If the user
doesn't ask for it for, say, three days, the keyring is automatically
expired and garbage collected using the existing gc. All the kerberos
tokens it held are then also gc'd.
(b) A key type that can hold really big tickets (up to 1MB in size).
The problem is that Active Directory can return huge tickets with lots
of auxiliary data attached. We don't, however, want to eat up huge
tracts of unswappable kernel space for this, so if the ticket is
greater than a certain size, we create a swappable shmem file and dump
the contents in there and just live with the fact we then have an
inode and a dentry overhead. If the ticket is smaller than that, we
slap it in a kmalloc()'d buffer"
* 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits)
KEYS: Fix keyring content gc scanner
KEYS: Fix error handling in big_key instantiation
KEYS: Fix UID check in keyctl_get_persistent()
KEYS: The RSA public key algorithm needs to select MPILIB
ima: define '_ima' as a builtin 'trusted' keyring
ima: extend the measurement list to include the file signature
kernel/system_certificate.S: use real contents instead of macro GLOBAL()
KEYS: fix error return code in big_key_instantiate()
KEYS: Fix keyring quota misaccounting on key replacement and unlink
KEYS: Fix a race between negating a key and reading the error set
KEYS: Make BIG_KEYS boolean
apparmor: remove the "task" arg from may_change_ptraced_domain()
apparmor: remove parent task info from audit logging
apparmor: remove tsk field from the apparmor_audit_struct
apparmor: fix capability to not use the current task, during reporting
Smack: Ptrace access check mode
ima: provide hash algo info in the xattr
ima: enable support for larger default filedata hash algorithms
ima: define kernel parameter 'ima_template=' to change configured default
ima: add Kconfig default measurement list template
checkpatch is currently confused about some complex macros and references
undefined variables $stat and $cond.
Make sure these are defined before using them.
Reported-by: Gerhard Sittig <gsi@denx.de>
Acked-by: Andy Whitcroft <apw@canonical.com>
The kernel postinst hook for initramfs-tools will build an initramfs
on installation unless $INITRD is set to 'No'. make-kpkg generates a
postinst script that sets this variable appropriately, but we don't.
Set it based on CONFIG_BLK_DEV_INITRD.
This should also work with dracut when <http://bugs.debian.org/729622>
is fixed.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing update from Steven Rostedt:
"This batch of changes is mostly clean ups and small bug fixes. The
only real feature that was added this release is from Namhyung Kim,
who introduced "set_graph_notrace" filter that lets you run the
function graph tracer and not trace particular functions and their
call chain.
Tom Zanussi added some updates to the ftrace multibuffer tracing that
made it more consistent with the top level tracing.
One of the fixes for perf function tracing required an API change in
RCU; the addition of "rcu_is_watching()". As Paul McKenney is pushing
that change in this release too, he gave me a branch that included all
the changes to get that working, and I pulled that into my tree in
order to complete the perf function tracing fix"
* tag 'trace-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Add rcu annotation for syscall trace descriptors
tracing: Do not use signed enums with unsigned long long in fgragh output
tracing: Remove unused function ftrace_off_permanent()
tracing: Do not assign filp->private_data to freed memory
tracing: Add helper function tracing_is_disabled()
tracing: Open tracer when ftrace_dump_on_oops is used
tracing: Add support for SOFT_DISABLE to syscall events
tracing: Make register/unregister_ftrace_command __init
tracing: Update event filters for multibuffer
recordmcount.pl: Add support for __fentry__
ftrace: Have control op function callback only trace when RCU is watching
rcu: Do not trace rcu_is_watching() functions
ftrace/x86: skip over the breakpoint for ftrace caller
trace/trace_stat: use rbtree postorder iteration helper instead of opencoding
ftrace: Add set_graph_notrace filter
ftrace: Narrow down the protected area of graph_lock
ftrace: Introduce struct ftrace_graph_data
ftrace: Get rid of ftrace_graph_filter_enabled
tracing: Fix potential out-of-bounds in trace_get_user()
tracing: Show more exact help information about snapshot
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild changes from Michal Marek:
- make tags fixes again
- scripts/show_delta fix for newer python
- scripts/kernel-doc does not fail on unknown function prototype
- one less coccinelle check this time
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/tags.sh: remove obsolete __devinit[const|data]
scripts/kernel-doc: make unknown function prototype a Warning instead of an Error
show_delta: Update script to support python versions 2.5 through 3.3
scripts/coccinelle/api: remove devm_request_and_ioremap.cocci
scripts/tags.sh: Increase identifier list
Pull kconfig changes from Michal Marek:
- xconfig stores its setting in a meaningful path
(~/.config/kernel.org/qconf.conf)
- kconfig symbol search fix
- documentation fixes
- cleanup & comment update
- fix warning when a kconfig symbol is defined with two different types
- Yann is now officially listed as maintainer of kconfig, but he
prefers me to send pull requests for now
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
MAINTAINERS: New kconfig maintainer
xconfig: Fix the filename for GUI settings
kconfig: fix bug in search results string: use strlen(gstr->s), not gstr->len
kconfig: remove unused definition from scanner
kconfig: adjust warning message for conflicting types
kconfig: fix trivial typos and update mconf documentation
kconfig: add short explanation to SYMBOL_WRITE
Documentation/kbuild/kconfig.txt: 'make listnewconfig' replaces: yes "" | make oldconfig
Pull kbuild changes from Michal Marek:
- LTO fixes, but the kallsyms part had to be reverted
- Pass -Werror=implicit-int and -Werror=strict-prototypes to the
compiler by default
- snprintf fix in modpost
- remove GREP_OPTIONS from the environment to be immune against exotic
grep option settings
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kallsyms: Revert back to 128 max symbol length
Kbuild: Ignore GREP_OPTIONS env variable
scripts: kallsyms: Use %zu to print 'size_t'
scripts/bloat-o-meter: use .startswith rather than fragile slicing
scripts/bloat-o-meter: ignore changes in the size of linux_banner
kbuild: replace unbounded sprintf call in modpost
kbuild, bloat-o-meter: fix static detection
Kbuild: Handle longer symbols in kallsyms.c
kbuild: Increase kallsyms max symbol length
Makefile: enable -Werror=implicit-int and -Werror=strict-prototypes by default
Pull module updates from Rusty Russell:
"Mainly boring here, too. rmmod --wait finally removed, though"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: fix bogus 'exported twice' warnings.
init: fix in-place parameter modification regression
asmlinkage, module: Make ksymtab and kcrctab symbols and __this_module __visible
kernel: add support for init_array constructors
modpost: Optionally ignore secondary errors seen if a single module build fails
module: remove rmmod --wait option.
This reverts commits
f3462aa (Kbuild: Handle longer symbols in kallsyms.c) and
eea0e9c (kbuild: Increase kallsyms max symbol length)
except for the added overflow check. The reason is a regression caused
by increasing the buffer:
http://marc.info/?l=linux-kernel&m=138387700415675.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Joe Mario <jmario@redhat.com>
When using '!Ffile function' in a docbook template, and the function no
longer exists, you get a "no structured comments found" error from the
kernel-doc processing script. It's useful to know which functions it was
looking for, so print them out in this case. Also do the same for '!Pfile
doc-section'
The same error also happens when using '!Efile' when some exported
functions aren't documented (in the same file.) There's a very large
number of such functions though, so don't print the message in this case
-- right now it would give ~850 messages.
Cc: Rob Landley <rob@landley.net>
Cc: Randy Dunlap <rdunlap@infradead.org>
When expert configuration option(CONFIG_EXPERT) is enabled, menuconfig
offers a choice of compression algorithm to compress initial ramfs image;
This choice is stored into CONFIG_RD_* variables. But usr/Makefile uses
earlier INITRAMFS_COMPRESSION_* macros to build initial ramfs file. Since
none of them is defined, resulting 'initramfs_data.cpio' file remains
un-compressed.
This patch updates the Makefile to use CONFIG_RD_* variables and adds
support for LZ4 compression algorithm. Also updates the
'gen_initramfs_list.sh' script to check whether a selected compression
command is accessible or not. And fall-back to default gzip(1)
compression when it is not.
Signed-off-by: P J P <prasad@redhat.com>
Naked use sscanf can be troublesome because the pointed to variables may
not have been set.
Add a warning when the sscanf return value is not used.
For now, do not add __must_check to the sscanf prototype because that will
cause a couple of hundred new warnings when compiling a kernel.
Avoid prescribing kernel styled shortcuts for gcc extensions of
__attribute__((foo)) in the uapi include paths.
Fix $realfile filename when using -f/--file to not remove first level
directory as if the filename was used in a -P1 patch. Only strip the
first level directory (typically a or b) for P1 patches.
Cc: "Dixit, Ashutosh" <ashutosh.dixit@intel.com>
Cc: Andy Whitcroft <apw@canonical.com>
Find a few more cases where parentheses are used around the value of a
return statement.
This now uses the "$balanced_parens" test and also makes the test depend
on perl v5.10 and higher.
This now finds return with parenthesis uses the old code did not find
like:
ERROR: return is not a function, parentheses are not required
#211: FILE: arch/m68k/include/asm/sun3xflop.h:211:
+ return ((error == 0) ? 0 : -1);
Tested-by: David Cohen <david.a.cohen@linux.intel.com>
Acked-by: David Cohen <david.a.cohen@linux.intel.com>
Kernel maintainers reject new instances of the GPL boilerplate paragraph
directing people to write to the FSF for a copy of the GPL, since the FSF
has moved in the past and may do so again.
Make this an error for new code, but just a --strict CHK in --file mode;
anyone interested in doing tree-wide cleanups of this form can enable this
test explicitly.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Joe Perches <joe@perches.com>
Peter Zijlstra prefers that comments be required near uses of memory
barriers.
Change the message level for memory barrier uses from a --strict test only
to a normal WARN so it's always emitted.
This might produce false positives around insertions of memory barriers
when a comment is outside the patch context block.
And checkpatch is still stupid, it only looks for existence of any
comment, not at the comment content.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Oliver Neukum <oliver@neukum.org>
People get this regularly wrong and it breaks the LTO builds, as it causes
a section attribute conflict.
Add --fix capability too.
Based on a patch from Andi Kleen.
Add a test for these #defines
Additionally, moved string_find_replace sub as it screws up subsequent
formatting when placed inside another sub.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Checkpatch doesn't currently find CamelCase definitions of structs, unions
or enums.
Add that ability.
seq_vprintf, seq_printf and seq_puts are logging functions and should be
allowed to exceed the maximium line length.
Add maximum line length exceptions for these functions.
Also, suggesting seq_printf conversions to seq_puts should be tested for
arguments after the format.
Extend the CamelCase words found to include structure members.
In https://lkml.org/lkml/2013/9/3/318 Sarah Sharp (mostly) wrote:
"In general, if checkpatch.pl complains about a variable a patch
introduces that's CamelCase, you should pay attention to it. Otherwise,
[] ignore it."
So, if checking a patch, scan the original patched file if it's available
and add any preexisting CamelCase types so reuses do not generate
CamelCase messages.
That also means Andrew's not so cruelly spurned anymore.
https://lkml.org/lkml/2013/2/22/426
Suggested-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Spaces around trigraphs are specified by CodingStyle but checkpatch is
currently silent about them because there are many current instances
without them.
Make missing spaces around trigraphs a --strict message.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
For some reason I managed to trick gcc into create CRC symbols that are
not absolute anymore, but weak.
Make modpost handle this case.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Building with a large config and -ffunction-sections results in a large
number of sections and sortextable needs to be able to handle that.
Implement support for > 64K sections as modpost does.
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
This removes the use of __devinitconst and __devinitdata in scripts/tags.sh,
which were removed in 3.8.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Commit f3462aa95 (Kbuild: Handle longer symbols in kallsyms.c) introduced the
following warning on ARM:
scripts/kallsyms.c:121:4: warning: format '%lu' expects argument of type 'long unsigned int', but argument 4 has type 'size_t' [-Wformat]
Use %zu to print 'size_t'.
When building perf out of tree:
$ make perf-tar-src-pkg
$ tar -xf perf-<ver>.tar -C /tmp
$ cd /tmp/perf<ver>
$ make -C tools/perf
you get this warning message:
make[1]: *** No rule to make target `kernelversion'. Stop.
Fix it by saving the perf version in the tar file and using that for the
out of tree builds.
v2: removed short form request and fixed up version string from usual output.
Signed-off-by: David Ahern <dsahern@gmail.com>
Suggested-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1383753335-25782-1-git-send-email-dsahern@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
str.startswith has existed since at least Python 2.0, in 2000; use it
rather than a fragile comparison against an initial slice of a string,
which requires hard-coding the length of the string to compare against.
linux_banner can change size due to changes in the compiler, build number,
or the user@host the system was compiled on; ignore size changes in
linux_banner entirely.
Andi's change in e0f244c63fc9 ("asmlinkage, module: Make ksymtab and
kcrctab symbols and __this_module __visible") make the crc appear
first in the symbol table.
modpost creates an entry when it sees the CRC, then when it sees the
actual symbol, it complains that it's seen it before. The preloaded
flag already exists for the equivalent case where we loaded from
Module.symvers, so use that.
Tested-by: The Awesome Power Of linux-next
The modpost tool could overflow its stack buffer if someone was running
with an insane shell environment. Regardless, it's technically a bug,
so this fixes it to truncate the string instead of seg-faulting.
Found by Coverity.
Disable static detection: the static currently drops a lot of useful
information including clones generated by gcc. Drop this. The statics
will appear now without static. prefix.
But remove the LTO .NUMBER postfixes that look ugly
Also warn for too long symbols
v2: Add missing newline. Use 255 max (Joe Perches)
Error
When scripts/kernel-doc cannot understand a function prototype,
it had been generating a fatal error and stopping immediately.
Make this a Warning instead of an Error and keep going.
Note that this can happen if the kernel-doc notation that is being
parsed is not actually a function prototype; maybe it's a struct or
something else, so I added "function" to the warning message to try
to make it clearer that scripts/kernel-doc is looking for a function
prototype here.
Cc: Mark Brown <broonie@kernel.org>
With gcc 4.6.0 the -mfentry feature places the function profiling call
at the start of the function. When this is used, the call is to
__fentry__ and not mcount. This is required for Ksplice as the C
version of recordmcount doesn't insert section symbols for the
__mcount_loc section so we fall back to the perl version.
Based on 48bb5dc6cd9d30fe0d594947563da1f8bd9abada (ftrace: Make
recordmcount.c handle __fentry__).
Link: http://lkml.kernel.org/r/1383648129-10724-1-git-send-email-jamie.iles@oracle.com
This patch uses CONFIG_PAGE_OFFSET to filter symbols which
are not in kernel address space because these symbols are
generally for generating code purpose and can't be run at
kernel mode, so we needn't keep them in /proc/kallsyms.
For example, on ARM there are some symbols which may be
linked in relocatable code section, then perf can't parse
symbols any more from /proc/kallsyms, this patch fixes the
problem (introduced b9b32bf70f2fb710b07c94e13afbc729afe221da)
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: stable@vger.kernel.org
git://gitorious.org/linux-kconfig/linux-kconfig into kbuild/kconfig
Make the ksymtab symbols for EXPORT_SYMBOL visible.
This prevents the LTO compiler from adding a .NUMBER prefix,
which avoids various problems in later export processing.
Cc: rusty@rustcorp.com.au
Support past and active versions of python while maintaining backward compatibility. Script has been tested on python versions from 2.5.x up to and including 3.3.x.
Signed-off-by: Mike Pagano <mpagano@gentoo.org>
Use of this function is discouraged in favour of
devm_ioremap_resource(). Don't advertise it.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Add __maybe_unused
__always_unused
__cacheline_aligned
__cacheline_aligned_in_smp
ACPI_EXPORT_SYMBOL
to the list.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
Currently the qconf program invoked by 'make xconfig' stores GUI
settings in the file ~/.config/Unknown\ Organization.conf. This name
is apparently generated by the QSettings class when no organisation
or application name are specified.
This is obviously not a sensible filename (nor does it seem sensible
that these QSettings parameters are optional!). Pass the names
'kernel.org' and 'qconf', resuling in the filename
~/.config/kernel.org/qconf.conf.
Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
