path: root/scripts
2008-04-19PNP: add all PNP card device id's as individual aliasesKay Sievers
The current PNP combined card + devices module aliase can never ever match anything, because these values are not available all at the same time to request a module. Instead of adding the combined alias, we add the device id's all as individual aliases. Device id's are exported by the PNP bus and can now properly used to request the loading of a matching module. The module snd-sbawe currently exports aliases, which can never match anything: alias: pnp:cCTLXXXXdCTL0045dCTL0022* alias: pnp:cCTLXXXXdCTL0044dCTL0023* alias: pnp:cCTLXXXXdCTL0042dCTL0022* alias: pnp:cCTLXXXXdCTL0041dCTL0021* alias: pnp:cCTLXXXXdCTL0031dCTL0021* alias: pnp:cCTL00eddCTL0041dCTL0070* alias: pnp:cCTL00e9dCTL0045dCTL0022* alias: pnp:cCTL00e4dCTL0045dCTL0022* alias: pnp:cCTL00c7dCTL0045dCTL0022* alias: pnp:cCTL00c5dCTL0045dCTL0022* alias: pnp:cCTL00c3dCTL0045dCTL0022* alias: pnp:cCTL00c1dCTL0042dCTL0022* alias: pnp:cCTL00b2dCTL0044dCTL0023* alias: pnp:cCTL009edCTL0044dCTL0023* alias: pnp:cCTL009ddCTL0042dCTL0022* alias: pnp:cCTL009fdCTL0041dCTL0021* alias: pnp:cCTL009cdCTL0041dCTL0021* alias: pnp:cCTL009adCTL0041dCTL0021* alias: pnp:cCTL0054dCTL0031dCTL0021* alias: pnp:cCTL0048dCTL0031dCTL0021* alias: pnp:cCTL0047dCTL0031dCTL0021* alias: pnp:cCTL0046dCTL0031dCTL0021* alias: pnp:cCTL0045dCTL0031dCTL0021* alias: pnp:cCTL0044dCTL0031dCTL0021* alias: pnp:cCTL0043dCTL0031dCTL0021* alias: pnp:cCTL0042dCTL0031dCTL0021* alias: pnp:cCTL0039dCTL0031dCTL0021* alias: pnp:cCTL0035dCTL0031dCTL0021* With this patch it exports only the device id's, as properly matchable aliases: alias: pnp:dCTL0070* alias: pnp:dCTL0045* alias: pnp:dCTL0023* alias: pnp:dCTL0044* alias: pnp:dCTL0022* alias: pnp:dCTL0042* alias: pnp:dCTL0041* alias: pnp:dCTL0021* alias: pnp:dCTL0031* Now, the exported value of the PNP bus can be used to autoload a matching module: $ modprobe --first-time -n -v pnp:dCTL0045 insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-rawmidi.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/mpu401/snd-mpu401-uart.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/core/snd-hwdep.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb-common.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-csp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sb16-dsp.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/drivers/opl3/snd-opl3-lib.ko insmod /lib/modules/2.6.24-rc6-g5b825ed2-dirty/kernel/sound/isa/sb/snd-sbawe.ko $ grep CTL0045 /sys/bus/pnp/devices/*/id /sys/bus/pnp/devices/01:01.00/id:CTL0045 Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-28update checkpatch.pl to version 0.16Andy Whitcroft
This version brings proper quote tracking across lines, and brings the handling of comments into the same mechanism ensuring nesting is correctly handled. It brings the usual flurry of fixes for false positives. It also brings a number of new checks. The most contentious change will likely be the checks for NR_CPUS as this throws some new warnings in kernel/sched.c. Of note: - all new quote tracking across lines - all new comment tracking - new more direct, less ambigious wording for some warnings - recommends mutexes and completions over semaphores - recommends strict_strto* over simple_strto* - report on direct use of NR_CPUS Andy Whitcroft (22): Version: 0.16 string quote tracking should cross line boundaries check spacing round -> correctly across newlines checks for linux/ against asm/ include files should be warnings standardise on 'required' and 'prohibited' take the first end of condition when parsing statements values: cope with unbalanced brackets preprocessor #elif is not a function preprocessor #if should not trigger trailing statement checks test: allow us to limit output to a single error recommend real mutexes over semaphores asm checks should mirror those for __asm__ warn on semaphores being used in place of completions trailing ; on control structure should ignore do {} while (); recommend strict_strtoX over simple_strtoX redo comment handling as a quote type use of NR_CPUS is normally wrong consistant spacing should only be about spaces if brace check suppression should only apply to the top-levels use tr/// to align spacing for operators move to using four parameter form of substr check and report modifications to include/asm Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-23kbuild: soften modpost checks when doing cross buildsSam Ravnborg
The module alias support in the kernel have a consistency check where it is checked that the size of a structure in the kernel and on the build host are the same. For cross builds this check does not make sense so detect when we do cross builds and silently skip the check in these situations. This fixes a build bug for a wireless driver when cross building for arm. Acked-by: Michael Buesch <mb@bu3sch.de> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: stable@kernel.org
2008-03-13kernel-doc: set verbose mode via environmentRandy Dunlap
Honor the environment variable "KBUILD_VERBOSE=1" (as set by make V=1) to enable verbose mode in scripts/kernel-doc. Useful for getting more info and warnings from kernel-doc. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04update checkpatch.pl to version 0.15Andy Whitcroft
This version brings a number of minor fixes updating the type detector and the unary tracker. It also brings a few small fixes for false positives. It also reverts the --file warning. Of note: - limit CVS checks to added lines - improved type detections - fixes to the unary tracker Andy Whitcroft (13): Version: 0.15 EXPORT_SYMBOL checks need to accept array variables export checks must match DECLARE_foo and LIST_HEAD possible types: cleanup debugging missing line values: track values through preprocessor conditional paths typeof is actually a type possible types: detect definitions which cross lines values: include line numbers on value debug information values: ensure we find correctly record pending brackets values: simplify the brace history stack CVS keyword checks should only apply to added lines loosen spacing for comments allow braces for single statement blocks with multiline conditionals Harvey Harrison (1): checkpatch: remove fastcall Ingo Molnar (1): checkpatch.pl: revert wrong --file message Uwe Kleine-Koenig (1): fix typo "goot" -> "good" Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Joel Schopp <jschopp@austin.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23kernel-doc: fix function-pointer-parameter parsingRichard Kennedy
When running "make htmldocs" I'm seeing some non-fatal perl errors caused by trying to parse the callback function definitions in blk-core.c. The errors are "Use of uninitialized value in concatenation (.)..." in combination with: Warning(linux-2.6.25-rc2/block/blk-core.c:1877): No description found for parameter '' The function pointers are defined without a * i.e. int (drv_callback)(struct request *) The compiler is happy with them, but kernel-doc isn't. This patch teaches create_parameterlist in kernel-doc to parse this type of function pointer definition, but is it the right way to fix the problem ? The problem only seems to occur in blk-core.c. However with the patch applied, kernel-doc finds the correct parameter description for the callback in blk_end_request_callback, which is doesn't normally. I thought it would be a bit odd to change to code to use the more normal form of function pointers just to get the documentation to work, so I fixed kernel-doc instead - even though this is teaching it to understand code that might go away (The comment for blk_end_request_callback says that it should not be used and will removed at some point). Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-19kbuild: fix reversed symbol name order in modpostGeert Uytterhoeven
XXXINIT_TO_INIT and XXXEXIT_TO_EXIT warnings use the reversed symbol name order in the suggestion, e.g.: WARNING: vmlinux.o(.meminit.text+0x36c): Section mismatch in reference from the function free_area_init_core() to the function .init.text:setup_usemap() The function __meminit free_area_init_core() references a function __init setup_usemap(). If free_area_init_core is only used by setup_usemap then annotate free_area_init_core with a matching annotation. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: explain why DEBUG_SECTION_MISMATCH is UNDEFINED kbuild: fix building vmlinux.o kbuild: allow -fstack-protector to take effect kconfig: fix select in combination with default
2008-02-14kernel-doc: remove fastcallHarvey Harrison
fastcall is gone from the tree, no need to adjust the function prototypes anymore for this. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Linux Kernel Markers: create modpost fileMathieu Desnoyers
This adds some new magic in the MODPOST phase for CONFIG_MARKERS. Analogous to the Module.symvers file, the build will now write a Module.markers file when CONFIG_MARKERS=y is set. This file lists the name, defining module, and format string of each marker, separated by \t characters. This simple text file can be used by offline build procedures for instrumentation code, analogous to how System.map and Module.symvers can be useful to have for kernels other than the one you are running right now. The strings are made easy to extract by having the __trace_mark macro define the name and format together in a single array called __mstrtab_* in the __markers_strings section. This is straightforward and reliable as long as the marker structs are always defined by this macro. It is an unreasonable amount of hairy work to extract the string pointers from the __markers section structs, which entails handling a relocation type for every machine under the sun. Mathieu : - Ran through checkpatch.pl Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: David Smith <dsmith@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13kconfig: fix select in combination with defaultRoman Zippel
> The attached .config (with current -git) results in a compile > error since it contains: > > CONFIG_X86=y > # CONFIG_EMBEDDED is not set > CONFIG_SERIO=m > CONFIG_SERIO_I8042=y > > Looking at drivers/input/serio/Kconfig I simply don't get how this > can happen. You've hit the rather subtle rules of select vs default. What happened is that SERIO is selected to m, but SERIO_I8042 isn't selected so the default of y is used instead. We already had the problem in the past that select and default don't work well together, so this patch cleans this up and makes the rule hopefully more straightforward. Basically now the value is calculated like this: (value && dependency) || select where the value is the user choice (if available and the symbol is visible) or default. In this case it means SERIO and SERIO_I8042 are both set to y due to their default and if SERIO didn't had the default, then the SERIO_I8042 value would be limited to m due to the dependency. I tested this patch with more 10000 random configs and above case is the only the difference that showed up, so I hope there is nothing that depended on the old more complex and subtle rules. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Tested-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-11kbuild: fix make V=1Sam Ravnborg
When make -s support were added to filechk to combination created with make V=1 were not covered. Fix it by explicitly cover this case too. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Mike Frysinger <vapier@gentoo.org>
2008-02-09Kbuild: Fix deb-pkg target to work with kernel versions ending with ↵Michal Sojka
-<text-without-digit> If CONIFIG_LOCALVERSION is set for example to -loop, the following error message was generated. dpkg-deb - error: Debian revision (`loop') doesn't contain any digits dpkg-deb: 1 errors in control file The patch solves this by adding a numeric revision to package version. Signed-off-by: Michal Sojka <sojkam1@fel.cvut.cz> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild: silence CHK/UPD messages according to $(quiet)Mike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild/modpost: Use warn() for announcing section mismatchesGeert Uytterhoeven
modpost: Use warn() for announcing section mismatches, for easy grepping for warnings in build logs. Also change an existing call from fprintf() to warn() while we're at it. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09Add binoffset to gitignoreUwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-09kbuild/modpost: improve warnings if symbol is unknownSam Ravnborg
If we cannot determine the symbol then print (unknown) to hint the reader that we failed to find the symbol. This happens with REL relocation records in arm object files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-08update checkpatch.pl to version 0.14Andy Whitcroft
This version brings the remainder of the queued fixes. A number of fixes for items missed reported by Andrew Morton and others. Also a handful of new checks and fixes for false positives. Of note: - new warning associated with --file to try and avoid cleanup only patches, - corrected handling of completly empty files, - corrected report handling with multiple files, - handling of possible types in the face of multiple declarations, - detection of unnessary braces on complex if statements (where present), and - all new comment spacing handling. Andi Kleen (1): Introduce a warning when --file mode is used Andy Whitcroft (14): Version: 0.14 clean up some space violations in checkpatch.pl a completly empty file should not provoke a whinge reset report lines buffers between files unary ++/-- may abutt close braces __typeof__ is also unary comments: revamp comment handling add --summary-file option adding filename to summary line trailing backslashes are not trailing statements handle operators passed as parameters such as to ASSERTCMP possible types -- enhance debugging check for boolean operations with constants possible types: handle multiple declarations detect and report if statements where all branches are single statements Arjan van de Ven (1): quiet option should not print the summary on no errors Bartlomiej Zolnierkiewicz (1): warn about using __FUNCTION__ Timur Tabi (1): loosen spacing checks for __asm__ Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08update checkpatch.pl to version 0.13Andy Whitcroft
This version brings a large number of fixes which have built up over the Christmas period. Mostly these are fixes for false positives, both through improvments to unary checks and possible type detection. It also brings new checks for while location and CVS keywords. Of note: - a number of fixes to unary detection - detection of a number of new forms of types to improve type matching - better inline handling - recognision of '%' as an operator Andy Whitcroft (28): Version: 0.13 unary detection: maintain bracket state across lines move to pre-sanitising the entire file the text of a #error statement should be treated like it is in quotes line sanitisation needs to target double backslash correctly tighten comment guestimation for lines starting ' * ' debug: add a debug framework prevent unclosed single quotes from spreading add % as an operator the text of a #warning statement should be treated like it is in quotes possible matching applies in typedefs single statement block checks must not trigger when two or more statements possible types: local variables may also be const treat inline as a type attribute to even when out of place possible types: sparse annotations are valid indicators possible types: beef up the possible type testing check for hanging while statements on the wrong line utf8 checks need to occur against the raw lines function brace checks should use any whitespece matches comments should take up space in the line when sanitised remove debugging from if assignment checks possible types -- ensure we detect all pointer casts fix tests for function spacing in the presence of #define clean up the UTF-8 error message to be clearer test-lib: invert the status report, output success counts detect and report CVS keywords tests: break out tests Add $Id$ to the CVS keyword checks Benny Halevy (1): checkpatch.pl: recognize the #elif preprocessor directive Geert Uytterhoeven (1): print the filenames of patches where available Mauro Carvalho Chehab (1): Fix missing \n in checkpatch.pl Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: warn on badly formatted short descriptionRandy Dunlap
Make kernel-doc warn when a function/struct/union/typedef does not contain a properly formatted short description, such as: * scsi_devinfo: set up the dynamic device list or * scsi_devinfo - This warning is only generated when verbose (-v) mode is used. Also explain the -v command line option in the -h output. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: prevent duplicate description: outputRandy Dunlap
Prevent duplicate output of a Description: section when there is a "blank" ("*") line between the initial function name/description line and the "Description:" header. Test case: drivers/scsi/scsi_devinfo.c::scsi_init_devinfo(). Rob Landley hit this while he was producing SCSI kernel-doc. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07kernel-doc: fix for vunmap function prototypeRandy Dunlap
Fix kernel-doc function prototype parsing which was exposed by vunmap() by allowing more than one '*' before the function name. Error(linux-2.6.24-mm1//mm/vmalloc.c:438): cannot understand prototype: 'struct page **vunmap(const void *addr) ' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Claim maintainership for block2mtd and update email addressesJoern Engel
I have been prime author and maintainer of block2mtd from day one, but neither MAINTAINERS nor the module source makes this fact clear. And while I'm at it, update my email addresses tree-wide, as the old address currently bounces and change my name to "joern" as unicode will likely continue to cause trouble until the end of this century. Signed-off-by: Joern Engel <joern@lazybastard.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06kallsyms should prefer non weak symbolsPaulo Marques
When resolving symbol names from addresses with aliased symbol names, kallsyms_lookup always returns the first symbol, even if it is a weak symbol. This patch changes this by sorting the symbols with the weak symbols last before feeding them to the kernel. This way the kernel runtime isn't changed at all, only the kallsyms build system is changed. Another side effect is that the symbols get sorted by address, too. So, even if future binutils version have some bug in "nm" that makes it fail to correctly sort symbols by address, the kernel won't be affected by this. Mathieu says: I created a module in LTTng that uses kallsyms to get the symbol corresponding to a specific system call address. Unfortunately, all the unimplemented syscalls were all referring to the (same) weak symbol identifying an unrelated system call rather that sys_ni (or whatever non-weak symbol would be expected). Kallsyms was dumbly returning the first symbol that matched. This patch makes sure kallsyms returns the non-weak symbol when there is one, which seems to be the expected result. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Looks-great-to: Rusty Russell <rusty@rustcorp.com.au> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06remove support for un-needed _extratext sectionRobin Getz
When passing a zero address to kallsyms_lookup(), the kernel thought it was a valid kernel address, even if it is not. This is because is_ksym_addr() called is_kernel_extratext() and checked against labels that don't exist on many archs (which default as zero). Since PPC was the only kernel which defines _extra_text, (in 2005), and no longer needs it, this patch removes _extra_text support. For some history (provided by Jon): http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019734.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019736.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019751.html [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jon Loeliger <jdl@freescale.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03kbuild: add svn revision information to setlocalversionBryan Wu
follow git and mercurial style, include uncommitted changes detect Cc: Frans Pop <elendil@planet.nl> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03kbuild: do not warn about __*init/__*exit symbols being exportedSam Ravnborg
We have several legitimate uses where we export symbols annotated with one of: __devinit, __cpuinit, __meminit and their exit counterpart. So let's stop warning about those being exported in favour of adding all sorts of workaround to silence the warning. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03kconfig: ignore select of unknown symbolSam Ravnborg
We have had warnings for a long time about select of unknow symbol but the warnings does not really makes sense since we may select a symbol that is relevant and defined in one arch but not in another arch. And as long as we do not use a common set of Kconfig files for all archs lets just ignore this case. Previously we have used this to find bad uses of select but we need a more relaible method to do so. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2008-02-03kconfig: mark config as changed when loading an alternate configSam Ravnborg
Michal Zachar <mgzachar@mail.t-com.sk> reported that menuconfig did not save the new config when loading an alternate config unless he altered it manually. Mark config as changed upon load of alternate config fixed this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Roman Zippel <zippel@linux-m68k.org>
2008-02-03kbuild: print only total number of section mismatces foundSam Ravnborg
We have too many section mismatches detected at the moment. So silence modpost and prevent the option from being set in a typical allyesconfig build. Tell the user how to see all the deteils in the summary message from modpost. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01USB: handle idVendor of 0x0000Greg Kroah-Hartman
Some crazy devices in the wild have a vendor id of 0x0000. If we try to add a module alias with this id, we just can't do it due to a check in the file2alias.c file. Change the test to verify that both the vendor and product ids are 0x0000 to show a real "blank" module alias. Note, the module-init-tools package also needs to be changed to properly generate the depmod tables. Cc: Janusz <janumix@poczta.fm> Cc: stable <stable@kernel.org> Cc: Jon Masters <jcm@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-28kbuild: warn about ld added unique sectionsSam Ravnborg
If there is a mixture of specifying sections for code in gcc and assembler then if the assembler code do not add the "ax" flags the linker will see this as two different sections and generate unique sections for each. ld does so by adding a dot and a number. Teach modpost to warn if a section shows up that match this pattern - but do this only for non-debug sections. It will result in warnings like this: WARNING: vmlinux.o (.sched.text.1): unexpected section name. The (.[number]+) following section name are ld generated and not expected. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. All warnings seen with a defconfig build for: x86 (32+64bit) and sparc64 has been fixed (via respective maintainers). arm, powerpc (64 bit), s390 (32 bit), ia64, alpha, sh4 checked - no warnings seen with a defconfig build. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: add verbose option to Section mismatch reporting in modpostSam Ravnborg
If the config option CONFIG_SECTION_MISMATCH is not set and we see a Section mismatch present the following to the user: modpost: Found 1 section mismatch(es). To see additional details select "Enable full Section mismatch analysis" in the Kernel Hacking menu (CONFIG_SECTION_MISMATCH). If the option CONFIG_SECTION_MISMATCH is selected then be verbose in the Section mismatch reporting from mdopost. Sample outputs: WARNING: o-x86_64/vmlinux.o(.text+0x7396): Section mismatch in reference from the function discover_ebda() to the variable .init.data:ebda_addr The function discover_ebda() references the variable __initdata ebda_addr. This is often because discover_ebda lacks a __initdata annotation or the annotation of ebda_addr is wrong. WARNING: o-x86_64/vmlinux.o(.data+0x74d58): Section mismatch in reference from the variable pci_serial_quirks to the function .devexit.text:pci_plx9050_exit() The variable pci_serial_quirks references the function __devexit pci_plx9050_exit() If the reference is valid then annotate the variable with __exit* (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, WARNING: o-x86_64/vmlinux.o(__ksymtab+0x630): Section mismatch in reference from the variable __ksymtab_arch_register_cpu to the function .cpuinit.text:arch_register_cpu() The symbol arch_register_cpu is exported and annotated __cpuinit Fix this by removing the __cpuinit annotation of arch_register_cpu or drop the export. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: tristate choices with mixed tristate and boolean valuesJan Beulich
Change kconfig behavior so that mixing bool and tristate config settings in a choice is possible and has the desired effect of offering just the tristate options individually if the choice gets set to M, and a normal boolean selection if the choice gets set to Y. Also fix scripts/kconfig/conf's handling of children of choice values - there may be more than one immediate child, and all of them need to be processed. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Roman Zippel" <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: support ARCH=x86 in buildtarDaniel De Graaf
Signed-off-by: Daniel De Graaf <danieldegraaf@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: remove "enable"Adrian Bunk
Kconfig had a synonym "enable" for "select" that was neither documented nor used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: simplified warning report in modpostSam Ravnborg
Refactor code so the warning report function does nothing else than reporting warnings. As a side effect some other code paths were cleaned up by this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce a few helpers in modpostSam Ravnborg
Introducing helpers to retreive symbol and section names cleaned up the code a bit. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: use simpler section mismatch warnings in modpostSam Ravnborg
The typical layout is now: WARNING: vmlinux.o(.text+0x372ec): Section mismatch: reference to .devinit.text:pci_scan_one_pbm in 'psycho_scan_bus' This is first step towards more readable warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce new option to enhance section mismatch analysisSam Ravnborg
Setting the option DEBUG_SECTION_MISMATCH will report additional section mismatch'es but this should in the end makes it possible to get rid of all of them. See help text in lib/Kconfig.debug for details. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28Use separate sections for __dev/__cpu/__mem code/dataSam Ravnborg
Introducing separate sections for __dev* (HOTPLUG), __cpu* (HOTPLUG_CPU) and __mem* (MEMORY_HOTPLUG) allows us to do a much more reliable Section mismatch check in modpost. We are no longer dependent on the actual configuration of for example HOTPLUG. This has the effect that all users see much more Section mismatch warnings than before because they were almost all hidden when HOTPLUG was enabled. The advantage of this is that when building a piece of code then it is much more likely that the Section mismatch errors are spotted and the warnings will be felt less random of nature. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-01-28kbuild: check section names consistently in modpostSam Ravnborg
Now that match() is introduced use it consistently so we can share the section name definitions. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: introduce blacklisting in modpostSam Ravnborg
Change the logic in modpost so we identify all the bad combinations of sections that refer to other sections. Compared to the previous approach we are much less dependent on knowledge of what additional sections the tool chain uses and thus we can keep the false positives low. The implmentation is changed to use a table based lookup and we now check all combinations in first pass so we no longer need separate passes for init and exit sections. Tested that the same warnings are generated for an allyesconfig build without CONFIG_HOTPLUG. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Adrian Bunk <bunk@kernel.org>
2008-01-28kbuild: code refactoring in modpostSam Ravnborg
Split a too long function up in smaller bits to make prgram logic easier to follow. A few related changes done due to parameter changes. No functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: try harder to find symbol names in modpostSam Ravnborg
The relocation record sometimes contained an address which was not an exactly match for a symbol. Implment some simple logic such that if there is a symbol within 20 bytes of the address contained in the relocation record then print the name of this symbol. With this change modpost could find symbol names for the remaining .init.text symbols in my allyesconfig build for x86_64. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: fix so modpost can now check any .o fileSam Ravnborg
It is very convinient to say: scripts/mod/modpost mm/built-in.o to check if any section mismatch errors occured in mm/ (as an example). Fix it so this is possible again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kbuild: minor scripts/decodecode updateRandy Dunlap
Remove the tmp file when exiting. Noticed by Arjan van de Ven. Catch mktemp failure and exit with message. Trap kill or other signals and exit cleanly. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: use environment optionRoman Zippel
Use the environment option to provide the ARCH symbol and the KERNELVERSION symbol. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: environment symbol supportRoman Zippel
Add the possibility to import a value from the environment into kconfig via the option syntax. Beside flexibility this has the advantage providing proper dependencies. Documented the options syntax. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
