path: root/scripts
2007-02-08kbuild: fix space for good (take 103)Linus Torvalds
Michal Ostrowski points out what the real problem was: the spaces at the start of the definition of the 'checker-shell' make function. Cc: Michal Ostrowski <mostrows@watson.ibm.com> Acked-by: David Miller <davem@davemloft.net> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07kbuild: make $(checker-shell ) strip spaces around the resultLinus Torvalds
It looks like GNU make version 3.80 (but apparently not 3.81) adds leading whitespace to the result of the checker-shell execution. This strips them off explicitly. Also, don't bother symlinking the output file to /dev/null. It's likely as expensive as just writing the temp-file, and we need to remove it anyway afterwards. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[PATCH] kbuild, Kbuild.include: avoid using spaces in call argumentsOleg Verych
Do not use whitespace in arguments of functions in makefiles, as they propagate further without notice. Thus we get + echo ' y' instead of + echo y Fix misleading comments. Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[PATCH] kbuild: improve option checking, Kbuild.include cleanupOleg Verych
GNU binutils, root users, tmpfiles, external modules ro builds must be fixed to do the right thing now. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Horst Schirmeier <horst@schirmeier.com> Cc: Jan Beulich <jbeulich@novell.com> Cc: Daniel Drake <dsd@gentoo.org> Cc: Andi Kleen <ak@suse.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[PATCH] kbuild scripts: replace gawk, head, bc with shell, updateOleg Verych
Replacing overhead of using some (external) programs instead of good old `sh'. Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: William Stearns <wstearns@pobox.com> Cc: Martin Schlemmer <azarah@nosferatu.za.org> Signed-off-by: Oleg Verych <olecom@flower.upol.cz> Acked-by: Mark Lord <lkml@rtr.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] translate dashes in filenames for headers installMike Frysinger
The current filename->define translation does not scrub dashes so when creating stub defines for like asm-x86_64/ptrace-abi.h, we get: #define __ASM_STUB_PTRACE-ABI_H gcc just hates that sort of thing :) trivial attached patch adds - to the tr list to scrub it to _ Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] qconf: (re)fix SIGSEGV on empty menu itemsRoman Zippel
Back out the recent fix for this bug, fix it by correctly initialising ConfigInfoView.sym. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: "Cyrill V. Gorcunov" <gorcunov@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2007-01-11[PATCH] x86-64: Modpost whitelist reference to more symbols (pattern 3)Vivek Goyal
o MODPOST generates warning on i386 if kernel is compiled with CONFIG_RELOCATABLE=y. WARNING: vmlinux - Section mismatch: reference to .init.text:__init_begin from .text between 'free_initmem' (at offset 0xc0114fd3) and 'do_test_wp_bit' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'core_kernel_text' (at offset 0xc012aeae) and 'kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'core_kernel_text' (at offset 0xc012aeb7) and 'kernel_text_address' WARNING: vmlinux - Section mismatch: reference to .init.text:_sinittext from .text between 'get_symbol_pos' (at offset 0xc0135776) and 'reset_iter' WARNING: vmlinux - Section mismatch: reference to .init.text:_einittext from .text between 'get_symbol_pos' (at offset 0xc013577d) and 'reset_iter' o These symbols (__init_begin, _sinittext, _einittext) belong to init section and generally represent a section boundary. These are special symbols in the sense that their size is zero and no memory is allocated for them in init section. Their addr and value are same. So even if we free the init section, it is ok to reference them. o Whitelist access to such select symbols in MODPOST. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-01-11[PATCH] x86-64: modpost add more symbols to whitelist pattern2Vivek Goyal
o MODPOST generates warning for i386 if compiled with CONFIG_RELOCATABLE=y and serial console support is enabled. o Serial console setup function, serial8250_console_setup(), is a non __init function and it calls functions which are of type __init(). (uart_parse_options() and uart_set_options()). Assuming, setup will be called during init time, changing serial8250_console_setup() to __init. o Adding one more pattern to modpost whitelist. Console drivers might have *_console structures containing references to setup functions which can be of __init type. Don't generate warnings for those. WARNING: vmlinux - Section mismatch: reference to .init.text: from .data between 'serial8250_console' (at offset 0xc05a33d8) and 'serial8250_reg' Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-01-05[PATCH] qconf: fix SIGSEGV on empty menu itemsCyrill V. Gorcunov
qconf may cause SIGSEGV by trying to show debug information on empty menu items Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] kernel-doc: allow unnamed structs/unionsRandy Dunlap
Make kernel-doc support unnamed (anonymous) structs and unions. There is one (union) in include/linux/skbuff.h (inside struct sk_buff) that is currently generating a kernel-doc warning, so this fixes that warning. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: set gconf's save-widget's sensitivity according to ↵Karsten Wiese
.config's changed state Clean up a little. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: add "void conf_set_changed_callback(void (*fn)(void))", use ↵Karsten Wiese
it in qconf.cc Added function sets "void (*conf_changed_callback)(void)". Call it, if .config's changed state changes. Use above in qconf.cc to set gui's save-widget's sensitvity. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: make sym_change_count static, let it be altered by 2 ↵Karsten Wiese
functions only Those two functions are void sym_set_change_count(int count) and void sym_add_change_count(int count) All write accesses to sym_change_count are replaced by calls to above functions. Variable and changer-functions are moved to confdata.c. IMO thats ok, as sym_change_count is an attribute of the .config's change state. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] kconfig: new function "bool conf_get_changed(void)"Karsten Wiese
Run "make xconfig" on a freshly untarred kernel-tree. Look at the floppy disk icon of the qt application, that has just started: Its in a normal, active state. Mouse click on it: .config is being saved. This patch series changes things so taht after the mouse click on the floppy disk icon, the icon is greyed out. If you mouse click on it now, nothing happens. If you change some CONFIG_*, the floppy disk icon returns to "active state", that is, if you mouse click it now, .config is written. This patch: Returns sym_change_count to reflect the .config's change state. All read only accesses of sym_change_count are replaced by calls to conf_get_changed() . mconfig.c is manipulated to ask for saving only when conf_get_changed() returned true. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Fix section mismatch in parainstructionsRandy Dunlap
Section .parainstructions should not warn about section mismatches. WARNING: drivers/net/hamradio/scc.o - Section mismatch: reference to .exit.text: from .parainstructions after '' (at offset 0x0) WARNING: drivers/net/hamradio/scc.o - Section mismatch: reference to .exit.text: from .parainstructions after '' (at offset 0x8) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] kbuild: don't put temp files in sourceRoman Zippel
The as-instr/ld-option need to create temporary files, but create them in the output directory, when compiling external modules. Reformat them a bit and use $(CC) instead of $(AS) as the former is used by kbuild to assemble files. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Cc: Jan Beulich <jbeulich@novell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: <jpdenheijer@gmail.com> Cc: Horst Schirmeier <horst@schirmeier.com> Cc: Daniel Drake <dsd@gentoo.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] move kallsyms data to .rodataJan Beulich
Kallsyms data is never written to, so it can as well benefit from CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kernel-doc: stricter function pointer recognitionRandy Dunlap
Be more careful about function pointer args: look for "(...*" instead of just "(". This line in include/linux/input.h fools the current kernel-doc script into deciding that this is a function pointer: unsigned long ffbit[NBITS(FF_MAX)]; Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ver_linux additionsValdis Kletnieks
scripts/ver_linux needed some minor clean-ups, as follows: 1) Add reporting of actual oprofile release 2) Add reporting of actual wireless-tools release 3) Add reporting of actual pcmciautils release Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] qconf: support old QTakpm@osdl.org
Might make qconf compilable with qt-3.1 as well as qt-3.3 Cc: greg chesson <xtp@google.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] relocatable kernel: Fix kallsyms on avr32 after relocatable kernel ↵Vivek Goyal
changes o On some platforms like avr32, section init comes before .text and not necessarily a symbol's relative position w.r.t _text is positive. In such cases assembler detects the overflow and emits warning. This patch fixes it. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] paravirt: Patch inline replacements for paravirt interceptsRusty Russell
It turns out that the most called ops, by several orders of magnitude, are the interrupt manipulation ops. These are obvious candidates for patching, so mark them up and create infrastructure for it. The method used is that the ops structure has a patch function, which is called for each place which needs to be patched: this returns a number of instructions (the rest are NOP-padded). Usually we can spare a register (%eax) for the binary patched code to use, but in a couple of critical places in entry.S we can't: we make the clobbers explicit at the call site, and manually clobber the allowed registers in debug mode as an extra check. And: Don't abuse CONFIG_DEBUG_KERNEL, add CONFIG_DEBUG_PARAVIRT. And: AK: Fix warnings in x86-64 alternative.c build And: AK: Fix compilation with defconfig And: ^From: Andrew Morton <akpm@osdl.org> Some binutlises still like to emit references to __stop_parainstructions and __start_parainstructions. And: AK: Fix warnings about unused variables when PARAVIRT is disabled. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Zachary Amsden <zach@vmware.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-12-07[PATCH] relocatable kernel: Kallsyms generate relocatable symbolsEric W. Biederman
Print the addresses of non-absolute symbols relative to _text so that ld will generate relocations. Allowing a relocatable kernel to relocate them. We can't actually use the symbol names because kallsyms includes static symbols that are not exported from their object files. Add the _text symbol definitions to the architectures which don't define it otherwise linker will fail. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-11-25[PATCH] fix menuconfig colours with TERM=vt100Roman Zippel
On Mon, 13 Nov 2006, Phil Oester wrote: > In commit 350b5b76384e77bcc58217f00455fdbec5cac594, the default menuconfig > color scheme was changed to bluetitle. This breaks the highlighting > of the selected item for me with TERM=vt100. The only way I can see > which item is selected is via: > > make MENUCONFIG_COLOR=mono menuconfig > > Which restores the pre-2.6.19 white on black highlighting. Fix. Cc: Phil Oester <kernel@linuxace.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] qconf: fix uninitialsied memberRoman Zippel
Fixes a segfault reported by Randy. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] initramfs: handle more than one source dir or file listThomas Chou
Fix bug 7401. Handle more than one source dir or file list to the initramfs gen scripts. The Kconfig help for INITRAMFS_SOURCE claims that you can specify multiple space-separated sources in order to allow unprivileged users to build an image. There are two bugs in the current implementation that prevent this from working. First, we pass "file1 dir2" to the gen_initramfs_list.sh script, which it obviously can't open. Second, gen_initramfs_list.sh -l outputs multiple definitions for deps_initramfs -- one for each argument. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] .gitignore: add miscellaneous filesFranck Bui-Huu
Prevent git from reporting this useless status: On branch refs/heads/master Untracked files: (use "git add" to add to commit) TAGS scripts/kconfig/lkc_defs.h scripts/kconfig/qconf.moc nothing to commit Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-03[PATCH] update some docbook commentsRandy Dunlap
Correct a few comments in kernel-doc Doc and source files. (akpm: note: the patch removes a non-ascii character and might have to be applied by hand..) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[POWERPC] Support feature fixups in modulesBenjamin Herrenschmidt
This patch adds support for feature fixups in modules. This involves adding support for R_PPC64_REL64 relocs to the 64 bits module loader. It also modifies modpost.c to ignore the powerpc fixup sections (or it would warn when used in .init.text). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-17[PATCH] kbuild: allow multi-word $M in Makefile.modpostGreg Banks
Some people want to do crazy things like pass multiple directories as the value of $(SUBDIRS) or $M. Mostly this kinda works, except that Makefile.modpost constructs a modpost commandline which fails modpost's argument parsing. This patch fixes that little wrinkle. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] fix `make headers_install'David Woodhouse
Fix this: make[3]: *** No rule to make target `/mnt/md0/devel/linux-git/include/linux/version.h', needed by `/mnt/md0/devel/linux-git-obj/usr/include/linux/version.h'. Stop. make[2]: *** [linux] Error 2 make[1]: *** [headers_install] Error 2 Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] kernel-doc: make parameter description indentation uniformRandy Dunlap
- In parameter descriptions, strip all whitespace between the parameter name (e.g., @len) and its description so that the description is indented uniformly in text and man page modes. Previously, spaces or tabs (which are used for cleaner source code viewing) affected the produced output in a negative way. Before (man mode): to Destination address, in user space. from Source address, in kernel space. n Number of bytes to copy. After (man mode): to Destination address, in user space. from Source address, in kernel space. n Number of bytes to copy. - Fix/clarify a few function description comments. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] kernel-doc: drop various "inline" qualifiersRandy Dunlap
Drop __inline, __always_inline, and noinline in the produced kernel-doc output, similar to other pseudo directives. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Fix menuconfig build failure due to missing stdbool.hLuca Tettamanti
scripts/kconfig/lxdialog/util.c fails to build because it uses true/false without including stdbool.h: kronos:~/src/linux-2.6$ make O=../linux-build-git menuconfig GEN /home/kronos/src/linux-build/Makefile HOSTCC scripts/kconfig/lxdialog/util.o /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_classic_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: (Each undeclared identifier is reported only once /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: for each function it appears in.) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:70: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_blackbg_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:101: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:102: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_bluetitle_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:144: error: 'true' undeclared (first use in this function) make[2]: *** [scripts/kconfig/lxdialog/util.o] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [menuconfig] Error 2 Add <stdbool.h> to dialog.h to fix the breakage. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] hdrcheck permission fixAndrew Morton
Don't require that scripts/hdrcheck.sh be executable - shit happens... Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Fix copy&waste bug in comment in scripts/kernel-docRolf Eike Beer
This is obviously copied from some lines before without proper fixing. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuildLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild: kbuild: trivial documentation fixes kconfig: fix saving alternate kconfig file in parent dir kbuild: make modpost processing configurable kconfig/menuconfig: do not let ncurses clutter screen on exit kconfig/lxdialog: clear long menu lines kbuild: do not build mconf & lxdialog unless needed kconfig/lxdialog: fix make mrproper kconfig/lxdialog: support resize kconfig/lxdialog: let <ESC><ESC> behave as expected kconfig/menuconfig: lxdialog is now built-in kconfig/lxdialog: add a new theme bluetitle which is now default kconfig/lxdialog: add support for color themes and add blackbg theme kconfig/lxdialog: refactor color support
2006-10-02[PATCH] Add unifdef to gitignorePaul Mundt
This seems to have been missed when unifdef went in via Sam's tree.. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01kconfig: fix saving alternate kconfig file in parent dirSam Ravnborg
This fixes bugzilla entry: 7182 http://bugzilla.kernel.org/show_bug.cgi?id=7182 With this patch we no longer append the directory part twice before saving the config file. This patch has been sent to Roman Zippel for review with no feedback. It is so obviously simple that this should be OK to apply it anyway. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-01kbuild: make modpost processing configurableSam Ravnborg
On request from Al Viro make modpost processing configurable. KBUILD_MODPOST_WARN can be set to make modpost warn instead of error out in case on unresolved symbols in final module link. KBUILD_MODPOST_NOFINAL can be set to avoid the final and timeconsuming .c file generation and link of .ko files. This is solely useful for speeding up when doing compile checks with for example allmodconfig Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-10-01[PATCH] allow /proc/config.gz to be built as a moduleRoss Biro
The driver for /proc/config.gz consumes rather a lot of memory and it is in fact possible to build it as a module. In some ways this is a bit risky, because the .config which is used for compiling kernel/configs.c isn't necessarily the same as the .config which was used to build vmlinux. But OTOH the potential memory savings are decent, and it'd be fairly dumb to build your configs.o with a different .config. Signed-off-by: Andrew Morton <akpm@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30kconfig/menuconfig: do not let ncurses clutter screen on exitSam Ravnborg
Do not initialize ncurses twice - it causes unpredicable results. My display was sometimes weird after running make menuconfig and I had to execute 'reset' to properly restore my display. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: clear long menu linesSam Ravnborg
Menulines that were wider than the available line width is now properly null terminated. While at it renamed the variable choice => line_y so it better reflect the usage in do_print_item(). Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kbuild: do not build mconf & lxdialog unless neededSam Ravnborg
Due to a limitation in kbuild all objects referred by xxx-y or xxx-objs will be build when one of the targets needs to e build. This caused lxdialog to be build pulling in ncurses that is not always available. So avoid building mconf & lxdialog unless really needed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: fix make mrproperSam Ravnborg
No Makefile in scripts/kconfig/lxdialog anymore, so do not go there during make mrproper. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: support resizeSam Ravnborg
In all dialogs now properly catch KEY_RESIZE and take proper action. In mconf try to behave sensibly when a dialog routine returns -ERRDISPLAYTOOSMALL. The original check for a screnn size of 80x19 is kept for now. It may make sense to remove it later, but thats anyway what much text is adjusted for. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: let <ESC><ESC> behave as expectedSam Ravnborg
<ESC><ESC> is used to step one back in the dialogs. When lxdialog became built-in pressing <ESC> once would cause one step back and pressing <ESC><ESC> would cause two steps back. This patch - based on concept from Roman Zippel <zippel@linux-m68k.org> - makes one <ESC> a noop and pressing <ESC><ESC> will cause one step backward. In addition the final yes/no dialog now has the option to go back to the the kernel configuration. So if you get too far out you can now go back to configuring the kernel without saving and starting all over again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/menuconfig: lxdialog is now built-inSam Ravnborg
lxdialog was previously called as an external program causing screen to flicker when used. With this patch lxdialog is now built-in. It is loosly based om previous work by: Petr Baudis <pasky@ucw.cz> Following is a list of changes: o Moved build of dialog routings to kconfig Makefile o menubox + checklist uses a new item list to hold all menu items o in util.c implmented helper function to deal with item list o menubox now uses parameters to save scroll state (avoids temp file) o textbox now get text to be displayed as parameter and not a file o make sure to properly delete subwin's before main windows o killed unused files: lxdialog.c msgbox.c o modified return value for ESC to match direct calling o in a few places the code has been adjusted to 80 char wide o in textbox a small refactoring was made to make code remotely readable o in mconf removed all unused stuff (functions/variables) Following is a list of know short comings: a) pressing ESC twice will be interpreted as two ESC presses b) resize does not work. menuconfig needs to be restarted to be adjusted Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
