path: root/scripts
2010-03-06checkpatch: warn on unnecessary spaces before quoted newlinesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch.pl: warn if an adding line introduce spaces before tabs.Alberto Panizzo
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch.pl: extend list of expected-to-be-const structuresEmese Revfy
Based on Arjan's suggestion, extend the list of ops structures that should be const. Signed-off-by: Emese Revfy <re.emese@gmail.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch.pl: add union and struct to the exceptions listStefani Seibold
Here is a small code snippet, which will be complained about by checkpatch.pl: #define __STRUCT_KFIFO_COMMON(recsize, ptrtype) \ union { \ struct { \ unsigned int in; \ unsigned int out; \ }; \ char rectype[recsize]; \ ptrtype *ptr; \ const ptrtype *ptr_const; \ }; This construct is legal and safe, so checkpatch.pl should accept this. It should be also true for struct defined in a macro. Add the `struct' and `union' keywords to the exceptions list of the checkpatch.pl script, to prevent error message "Macros with multiple statements should be enclosed in a do - while loop". Otherwise it is not possible to build a struct or union with a macro. Signed-off-by: Stefani Seibold <stefani@seibold.net> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch: fix false positive on __initconstWolfram Sang
checkpatch falsely complained about '__initconst' because it thought the 'const' needed a space before. Fix this by changing the list of attributes: - add '__initconst' - force plain 'init' to contain a word-boundary at the end Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch.pl: allow > 80 char lines for logging functions not just printkJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06checkpatch: trivial fix for trailing statements checkHidetoshi Seto
In case if the statement and the conditional are in one line, the line appears in the report doubly. And items of this check have no blank line before the next item. This patch fixes these trivial problems, to improve readability of the report. [sample.c] > if (cond1 > && cond2 > && cond3) func_foo(); > > if (cond4) func_bar(); Before: > ERROR: trailing statements should be on next line > #1: FILE: sample.c:1: > +if (cond1 > [...] > + && cond3) func_foo(); > ERROR: trailing statements should be on next line > #5: FILE: sample.c:5: > +if (cond4) func_bar(); > +if (cond4) func_bar(); > total: 2 errors, 0 warnings, 5 lines checked After: > ERROR: trailing statements should be on next line > #1: FILE: sample.c:1: > +if (cond1 > [...] > + && cond3) func_foo(); > > ERROR: trailing statements should be on next line > #5: FILE: sample.c:5: > +if (cond4) func_bar(); > > total: 2 errors, 0 warnings, 5 lines checked Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/checkpatch.pl: add WARN on sizeof(&foo)Joe Perches
sizeof(&foo) is frequently an error. Warn on its use. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: fix possible infinite loopJoe Perches
If MAINTAINERS section entries are misformatted, it was possible to have an infinite loop. Correct the defect by always moving the index to the end of section + 1 Also, exit check for exclude as soon as possible. Signed-off-by: Joe Perches <joe@perches.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06get_maintainer: quote email address with periodStephen Hemminger
Picky mail systems won't accept email addresses where recipient has period in name; ie. David S. Miller <davemloft.net> will not work. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06get_maintainer: fix perlcritic warningsStephen Hemminger
perlcritic is a standard checker for Perl Best Practices. This patch fixes most of the warnings in the get_maintainer script. If kernel programmers are going to have checkpatch they should write clean scripts as well... Bareword file handle opened at line 176, column 1. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 176, column 1. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 207, column 5. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 207, column 5. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 246, column 6. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 246, column 6. See page 207 of PBP. (Severity: 5) Bareword file handle opened at line 258, column 2. See pages 202,204 of PBP. (Severity: 5) Two-argument "open" used at line 258, column 2. See page 207 of PBP. (Severity: 5) Expression form of "eval" at line 983, column 17. See page 161 of PBP. (Severity: 5) Expression form of "eval" at line 985, column 17. See page 161 of PBP. (Severity: 5) Subroutine prototypes used at line 1186, column 1. See page 194 of PBP. (Severity: 5) Subroutine prototypes used at line 1206, column 1. See page 194 of PBP. (Severity: 5) Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add ability to read from STDINJoe Perches
Doesn't need or accept '-' as a trailing option to read stdin. Doesn't print usage() after bad options. Adds --usage as command line equivalent of --help Suggested-by: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: change --sections to print in the same style as ↵Joe Perches
MAINTAINERS Signed-off-by: Joe Perches <joe@perches.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add --sections, print entire matched subsystemJoe Perches
Print the complete contents of the matched subsystems in pattern match depth order. Sample output: $ ./scripts/get_maintainer.pl --sections -f drivers/net/usb/smsc95xx.c USB SMSC95XX ETHERNET DRIVER M:Steve Glendinning <steve.glendinning@smsc.com> L:netdev@vger.kernel.org S:Supported F:drivers/net/usb/smsc95xx.* USB SUBSYSTEM M:Greg Kroah-Hartman <gregkh@suse.de> L:linux-usb@vger.kernel.org W:http://www.linux-usb.org T:quilt kernel.org/pub/linux/kernel/people/gregkh/gregkh-2.6/ S:Supported F:Documentation/usb/ F:drivers/net/usb/ F:drivers/usb/ F:include/linux/usb.h F:include/linux/usb/ NETWORKING DRIVERS L:netdev@vger.kernel.org W:http://www.linuxfoundation.org/en/Net T:git git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.git S:Odd Fixes F:drivers/net/ F:include/linux/if_* F:include/linux/*device.h THE REST M:Linus Torvalds <torvalds@linux-foundation.org> L:linux-kernel@vger.kernel.org Q:http://patchwork.kernel.org/project/LKML/list/ T:git git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git S:Buried alive in reporters F:* F:*/ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06scripts/get_maintainer.pl: add --file-emails, find embedded email addressesJoe Perches
Add an imperfect option to search a source file for email addresses. New option: --file-emails or --fe email addresses in files are freeform text and are nearly impossible to parse. Still, might as well try to do a somewhat acceptable job of finding them. This code should find all addresses that are in the form addr@domain.tld The code assumes that up to 3 alphabetic words along with dashes, commas, and periods that preceed the email address are a name. If 3 words are found for the name, and one of the first two words are a single letter and period, or just a single letter then the 3 words are use as name otherwise the last 2 words are used. Some variants that are shown correctly: John Smith <jksmith@domain.org> Random J. Developer <rjd@tld.com> Random J. Developer (rjd@tld.com) J. Random Developer rjd@tld.com Variants that are shown nominally correctly: Written by First Last (funny-addr@somecompany.com) is shown as: First Last <funny-addr@somecompany.com> Variants that are shown incorrectly: Some Really Long Name <srln@foo.bar> MontaVista Software, Inc. <source@mvista.com> are returned as: Long Name <srln@foo.bar> "Software, Inc" <source@mvista.com> --roles and --rolestats show "(in file)" for matches. For instance: Without -file-emails: $ ./scripts/get_maintainer.pl -f -nogit -roles net/core/netpoll.c David S. Miller <davem@davemloft.net> (maintainer:NETWORKING [GENERAL]) linux-kernel@vger.kernel.org (open list) With -fe: $ ./scripts/get_maintainer.pl -f -fe -nogit -roles net/core/netpoll.c David S. Miller <davem@davemloft.net> (maintainer:NETWORKING [GENERAL]) Matt Mackall <mpm@selenic.com> (in file) Ingo Molnar <mingo@redhat.com> (in file) linux-kernel@vger.kernel.org (open list) netdev@vger.kernel.org (open list:NETWORKING [GENERAL]) The number of email addresses in the file in not limited. Neither is the number of returned email addresses. Signed-off-by: Joe Perches <joe@perches.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits) ftrace: Add function names to dangling } in function graph tracer tracing: Simplify memory recycle of trace_define_field tracing: Remove unnecessary variable in print_graph_return tracing: Fix typo of info text in trace_kprobe.c tracing: Fix typo in prof_sysexit_enable() tracing: Remove CONFIG_TRACE_POWER from kernel config tracing: Fix ftrace_event_call alignment for use with gcc 4.5 ftrace: Remove memory barriers from NMI code when not needed tracing/kprobes: Add short documentation for HAVE_REGS_AND_STACK_ACCESS_API s390: Add pt_regs register and stack access API tracing/kprobes: Make Kconfig dependencies generic tracing: Unify arch_syscall_addr() implementations tracing: Add notrace to TRACE_EVENT implementation functions ftrace: Allow to remove a single function from function graph filter tracing: Add correct/incorrect to sort keys for branch annotation output tracing: Simplify test for function_graph tracing start point tracing: Drop the tr check from the graph tracing path tracing: Add stack dump to trace_printk if stacktrace option is set tracing: Use appropriate perl constructs in recordmcount.pl tracing: optimize recordmcount.pl for offsets-handling ...
2010-02-26kernel-doc: drop the -filelist option, it doesn't workIlya Dryomov
I also found the -filelist option, but apparently the implementation is broken, and it was broken from the very first git commit. For the -filelist option I suggest the removal (I wasn't able to find any users of it, moreover it's not even listed in the usage() output, so presumably nobody knows about it). Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26kernel-doc: track line numbers for each file separatelyIlya Dryomov
The problem is that $. keeps track of the current record number (which is line number by default). But if you pass it multiple files, it does not wrap at the end of file, and therefore contains the *total* number of processed lines. I suppose we can fix line numbering by introducing a simple assignment $. = 1 before processing every new file. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26Merge commit 'v2.6.33' into tracing/coreIngo Molnar
Conflicts: scripts/recordmcount.pl Merge reason: Merge up to v2.6.33. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig: kconfig: Simplify LSMOD= handling kconfig: Add LSMOD=file to override the lsmod for localmodconfig kconfig: Look in both /bin and /sbin for lsmod in streamline_config.pl kconfig: Check for if conditions in Kconfig for localmodconfig kconfig: Create include/generated for localmodconfig
2010-02-25Merge branch 'for-linus-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig * 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-kconfig: kconfig: simplification of scripts/extract-ikconfig
2010-02-03kconfig: Simplify LSMOD= handlingMichal Marek
Signed-off-by: Michal Marek <mmarek@suse.cz> LKML-Reference: <20100203162014.GA10956@sepie.suse.cz> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-02-02kconfig: Add LSMOD=file to override the lsmod for localmodconfigSteven Rostedt
Doing the following: make LSMOD=file localmodconfig Will make the streamline-config code use the given file instead of lsmod. If the file is an executable, it will execute it, otherwise it will read it as text. make LSMOD=/my/local/path/lsmod localmodconfig The above will execute the lsmod in /my/local/path instead of the lsmods that may be located elsewhere. make LSMOD=embedded_board_lsmod localmodconfig The above will read the "embedded_board_lsmod" as a text file. This is useful if you are doing a cross compile and need to run the config against modules that exist on an embedded device. Note, if the LSMOD= file does is not a path, it will add the path to the object directory. That is, the above example will look for "embedded_board_lsmod" in the directory that the binary will be built in (the O=dir directory). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> On branch config/linus
2010-02-02markup_oops.pl: fix $func_offset error with x86_64Hui Zhu
When I use markup_oops.pl parse a x8664 oops, I got: objdump: --start-address: bad number: NaN No matching code found This is because: main::(./m.pl:228): open(FILE, "objdump -dS --adjust-vma=$vmaoffset --start-address=$decodestart --stop-address=$decodestop $filename |") || die "Cannot start objdump"; DB<3> p $decodestart NaN This NaN is from: main::(./m.pl:176): my $decodestart = Math::BigInt->from_hex("0x$target") - Math::BigInt->from_hex("0x$func_offset"); DB<2> p $func_offset 0x175 There is already a "0x" in $func_offset, another 0x makes it a NaN. The $func_offset is from line: if ($line =~ /RIP: 0010:\[\<[0-9a-f]+\>\] \[\<[0-9a-f]+\>\] ([a-zA-Z0-9\_]+)\+(0x[0-9a-f]+)\/0x[a-f0-9]/) { $function = $1; $func_offset = $2; } I make a patch to change "(0x[0-9a-f]+)\/0x[a-f0-9]/)" to "0x([0-9a-f]+)\/0x[a-f0-9]/)". Signed-off-by: Hui Zhu <teawater@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02get_maintainer.pl: teach git log to use --no-colorRichard Kennedy
When git has been set to always use color in .gitconfig then I get the warning message Bad divisor in main::vcs_assign: 0 This is caused by vcs_file_signoffs not matching any commits due to the pattern not understand the colour codes. Fix this by telling git log to never use colour. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-02kconfig: Look in both /bin and /sbin for lsmod in streamline_config.plSteven Rostedt
Distributions now have lsmod in /bin instead of /sbin. But to handle both cases, we look for it in /sbin /bin /usr/bin and /usr/sbin. If lsmod is not found in any of those paths, it defaults to use just lsmod and hopes that it lies in the path of the user. Tested-by: Xavier Chantry <shiningxc@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-17modpost: fix segfault in sym_is() with prefixed archesMike Frysinger
The sym_is() compares a symbol in an attempt to automatically skip symbol prefixes. It does this first by searching the real symbol with the normal unprefixed symbol. But then it uses the length of the original symbol to check the end of the substring instead of the length of the symbol it is looking for. On non-prefixed arches, this is effectively the same thing, so there is no problem. On prefixed-arches, since this is exceeds by just one byte, a crash is rare and it is usually a NUL byte anyways. But every once in a blue moon, you get the right page alignment and it segfaults. For example, on the Blackfin arch, sym_is() will be called with the real symbol "___mod_usb_device_table" as "symbol" when looking for the normal symbol "__mod_usb_device_table" as "name". The substring will thus return one byte into "symbol" and store it into "match". But then "match" will be indexed with the length of "symbol" instead of "name" and so we will exceed the storage. i.e. the code ends up doing: char foo[] = "abc"; return foo[strlen(foo)+1] == '\0'; Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-16Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing/filters: Add comment for match callbacks tracing/filters: Fix MATCH_FULL filter matching for PTR_STRING tracing/filters: Fix MATCH_MIDDLE_ONLY filter matching lib: Introduce strnstr() tracing/filters: Fix MATCH_END_ONLY filter matching tracing/filters: Fix MATCH_FRONT_ONLY filter matching ftrace: Fix MATCH_END_ONLY function filter tracing/x86: Derive arch from bits argument in recordmcount.pl ring-buffer: Add rb_list_head() wrapper around new reader page next field ring-buffer: Wrap a list.next reference with rb_list_head()
2010-01-16markup_oops.pl: fix error with x86Hui Zhu
When I try to use markup_oops.pl in x86, I always get: cat 1 | perl markup_oops.pl ./vmlinux objdump: --start-address: bad number: NaN No matching code found This is because in line: if ($line =~ /EIP is at ([a-zA-Z0-9\_]+)\+0x([0-9a-f]+)\/[a-f0-9]/) { $function = $1; $func_offset = $2; } $func_offset will get a number like "0x2" But in follow code: my $decodestart = Math::BigInt->from_hex("0x$target") - Math::BigInt->from_hex("0x$func_offset"); It add other ox to ox2. Then this value will be set to NaN. So I made a small patch to fix it. Signed-off-by: Hui Zhu <teawater@gmail.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-13kbuild: really fix bzImage build with non-bash shJonathan Nieder
In an x86 build with CONFIG_KERNEL_LZMA enabled and dash as sh, arch/x86/boot/compressed/vmlinux.bin.lzma ends with '\xf0\x7d\x39\x00' (16 bytes) instead of the 4 bytes intended and the resulting vmlinuz fails to boot. This improves on the previous behavior, in which the file contained the characters '-ne ' as well, but not by much. Previous commits replaced "echo -ne" first with "/bin/echo -ne", then "printf" in the hope of improving portability, but none of these commands is guaranteed to support hexadecimal escapes on POSIX systems. So use the shell to convert from hexadecimal to octal. With this change, an LZMA-compressed kernel built with dash as sh boots correctly again. Reported-by: Sebastian Dalfuß <sd@sedf.de> Reported-by: Oliver Hartkopp <oliver@hartkopp.net> Reported-by: Michael Guntsche <mike@it-loops.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Cc: Michael Tokarev <mjt@tls.msk.ru> Cc: Alek Du <alek.du@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-01-12remove my email address from checkpatch.Dave Jones
Maybe this will stop people emailing me about it. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11tracing/x86: Derive arch from bits argument in recordmcount.plJan Kiszka
Let the arch argument be overruled by bits. Otherwise, building of external modules against a i386 target on a x86-64 host (and likely vice versa as well) fails unless ARCH=i386 is explicitly passed to make. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> LKML-Reference: <4B4AFE10.8050109@siemens.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-11scripts/get_maintainer.pl: fix file exclusion X: logicJoe Perches
The following command doesn't generate any output. `./scripts/get_maintainer.pl --no-git -f drivers/net/wireless/wl12xx/wl1271_acx.c` An excluded "X:" pattern match in any section would cause a file not to match any other section. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11lib: add support for LZO-compressed kernelsAlbin Tonnerre
This patch series adds generic support for creating and extracting LZO-compressed kernel images, as well as support for using such images on the x86 and ARM architectures, and support for creating and using LZO-compressed initrd and initramfs images. Russell King said: : Testing on a Cortex A9 model: : - lzo decompressor is 65% of the time gzip takes to decompress a kernel : - lzo kernel is 9% larger than a gzip kernel : : which I'm happy to say confirms your figures when comparing the two. : : However, when comparing your new gzip code to the old gzip code: : - new is 99% of the size of the old code : - new takes 42% of the time to decompress than the old code : : What this means is that for a proper comparison, the results get even better: : - lzo is 7.5% larger than the old gzip'd kernel image : - lzo takes 28% of the time that the old gzip code took : : So the expense seems definitely worth the effort. The only reason I : can think of ever using gzip would be if you needed the additional : compression (eg, because you have limited flash to store the image.) : : I would argue that the default for ARM should therefore be LZO. This patch: The lzo compressor is worse than gzip at compression, but faster at extraction. Here are some figures for an ARM board I'm working on: Uncompressed size: 3.24Mo gzip 1.61Mo 0.72s lzo 1.75Mo 0.48s So for a compression ratio that is still relatively close to gzip, it's much faster to extract, at least in that case. This part contains: - Makefile routine to support lzo compression - Fixes to the existing lzo compressor so that it can be used in compressed kernels - wrapper around the existing lzo1x_decompress, as it only extracts one block at a time, while we need to extract a whole file here - config dialog for kernel compression [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: cleanup] Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Tested-by: Russell King <rmk@arm.linux.org.uk> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-06tracing: Use appropriate perl constructs in recordmcount.plWolfram Sang
Modified recordmcount.pl to use perl constructs that are still understandable by C hackers that are not perl programmers. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> LKML-Reference: <1262724082-9517-1-git-send-email-w.sang@pengutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06kconfig: Check for if conditions in Kconfig for localmodconfigSteven Rostedt
The streamline_config.pl misses the if conditions for checking dependencies. For Kconfigs with the following construct: if MEDIA_SUPPORT config VIDEO_DEV [...] If VIDEO_DEV was enabled, the script will miss the fact that MEDIA_SUPPORT is also needed. This patch changes streamline_config.pl to include if conditions into the dependencies of configs. Reported-by: Anton Blanchard <anton@sambo.org> Tested-by: Anton Blanchard <anton@sambo.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06kconfig: Create include/generated for localmodconfigSteven Rostedt
If someone downloads a brand new kernel and runs localmodconfig or localyesconfig, the ending result will report: *** Error during update of the kernel configuration. This is because localmodconfig and localyesconfig must create the include/generated directory to place the autoconf.h file. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: optimize recordmcount.pl for offsets-handlingWolfram Sang
- move check for open file in front of the writing loop - use perl-constructs to access the array Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> LKML-Reference: <1262716072-14414-2-git-send-email-w.sang@pengutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-17Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (71 commits) MIPS: Lasat: Fix botched changes to sysctl code. RTC: rtc-cmos.c: Fix warning on MIPS MIPS: Cleanup random differences beween lmo and Linus' kernel. MIPS: No longer hardwire CONFIG_EMBEDDED to y MIPS: Fix and enhance built-in kernel command line MIPS: eXcite: Remove platform. MIPS: Loongson: Cleanups of serial port support MIPS: Lemote 2F: Suspend CS5536 MFGPT Timer MIPS: Excite: move iodev_remove to .devexit.text MIPS: Lasat: Convert to proc_fops / seq_file MIPS: Cleanup signal code initialization MIPS: Modularize COP2 handling MIPS: Move EARLY_PRINTK to Kconfig.debug MIPS: Yeeloong 2F: Cleanup reset logic using the new ec_write function MIPS: Yeeloong 2F: Add LID open event as the wakeup event MIPS: Yeeloong 2F: Add basic EC operations MIPS: Move several variables from .bss to .init.data MIPS: Tracing: Make function graph tracer work with -mmcount-ra-address MIPS: Tracing: Reserve $12(t0) for mcount-ra-address of gcc 4.5 MIPS: Tracing: Make ftrace for MIPS work without -fno-omit-frame-pointer ...
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-17MIPS: Tracing: Add dynamic function tracer supportWu Zhangjin
With dynamic function tracer, by default, _mcount is defined as an "empty" function, it returns directly without any more action . When enabling it in user-space, it will jump to a real tracing function(ftrace_caller), and do the real job for us. Differ from the static function tracer, dynamic function tracer provides two functions ftrace_make_call()/ftrace_make_nop() to enable/disable the tracing of some indicated kernel functions(set_ftrace_filter). In the -v4 version, the implementation of this support is basically the same as X86 version does: _mcount is implemented as an empty function and ftrace_caller is implemented as a real tracing function respectively. But in this version, to support module tracing with the help of -mlong-calls in arch/mips/Makefile: MODFLAGS += -mlong-calls. The stuff becomes a little more complex. We need to cope with two different type of calling to _mcount. For the kernel part, the calling to _mcount(result of "objdump -hdr vmlinux"). is like this: 108: 03e0082d move at,ra 10c: 0c000000 jal 0 <fpcsr_pending> 10c: R_MIPS_26 _mcount 10c: R_MIPS_NONE *ABS* 10c: R_MIPS_NONE *ABS* 110: 00020021 nop For the module with -mlong-calls, it looks like this: c: 3c030000 lui v1,0x0 c: R_MIPS_HI16 _mcount c: R_MIPS_NONE *ABS* c: R_MIPS_NONE *ABS* 10: 64630000 daddiu v1,v1,0 10: R_MIPS_LO16 _mcount 10: R_MIPS_NONE *ABS* 10: R_MIPS_NONE *ABS* 14: 03e0082d move at,ra 18: 0060f809 jalr v1 In the kernel version, there is only one "_mcount" string for every kernel function, so, we just need to match this one in mcount_regex of scripts/recordmcount.pl, but in the module version, we need to choose one of the two to match. Herein, I choose the first one with "R_MIPS_HI16 _mcount". and In the kernel verion, without module tracing support, we just need to replace "jal _mcount" by "jal ftrace_caller" to do real tracing, and filter the tracing of some kernel functions via replacing it by a nop instruction. but as we have described before, the instruction "jal ftrace_caller" only left 32bit length for the address of ftrace_caller, it will fail when calling from the module space. so, herein, we must replace something else. the basic idea is loading the address of ftrace_caller to v1 via changing these two instructions: lui v1,0x0 addiu v1,v1,0 If we want to enable the tracing, we need to replace the above instructions to: lui v1, HI_16BIT_ftrace_caller addiu v1, v1, LOW_16BIT_ftrace_caller If we want to stop the tracing of the indicated kernel functions, we just need to replace the "jalr v1" to a nop instruction. but we need to replace two instructions and encode the above two instructions oursevles. Is there a simpler solution? Yes! Here it is, in this version, we put _mcount and ftrace_caller together, which means the address of _mcount and ftrace_caller is the same: _mcount: ftrace_caller: j ftrace_stub nop ...(do real tracing here)... ftrace_stub: jr ra move ra, at By default, the kernel functions call _mcount, and then jump to ftrace_stub and return. and when we want to do real tracing, we just need to remove that "j ftrace_stub", and it will run through the two "nop" instructions and then do the real tracing job. what about filtering job? we just need to do this: lui v1, hi_16bit_of_mcount <--> b 1f (0x10000004) addiu v1, v1, low_16bit_of_mcount move at, ra jalr v1 nop 1f: (rec->ip + 12) In linux-mips64, there will be some local symbols, whose name are prefixed by $L, which need to be filtered. thanks goes to Steven for writing the mips64-specific function_regex. In a conclusion, with RISC, things becomes easier with such a "stupid" trick, RISC is something like K.I.S.S, and also, there are lots of "simple" tricks in the whole ftrace support, thanks goes to Steven and the other folks for providing such a wonderful tracing framework! Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/675/ Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Tracing: Add an endian argument to scripts/recordmcount.plWu Zhangjin
MIPS and some other architectures need this argument to handle big/little endian respectively. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/674/ Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-16Merge branch 'module' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: modpost: fix segfault with short symbol names module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y Kbuild: clear marker out of modpost module: make MODULE_SYMBOL_PREFIX into a CONFIG option ARM: unexport symbols used to implement floating point emulation ARM: use unified discard definition in linker script x86: don't export inline function sparc64: don't export static inline pci_ functions
2009-12-15scripts/get_maintainer.pl: support multiple VCSs - add mercurialJoe Perches
Restructure a bit for multiple version control systems support. Use a hash for each supported VCS that contains the commands and patterns used to find commits, logs, and signers. --git command line options are still used for hg except for --git-since. Use --hg-since instead. The number of commits can differ for git and hg, so --rolestats might be different. Style changes: Use common push style push(@foo...), simplify a return Bumped version to 0.23. Signed-off-by: Joe Perches <joe@perches.com> Cc: Marti Raudsepp <marti@juffo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: fix --non with --git-blame and cleanupsJoe Perches
Fix email matching without name --n and --git-blame Using --non and --git-blame caused maintainer signature matching to fail. Fixed that by adding 3rd argument to sub format_email to control show/hide name portion of address Slurp -f file instead of reading line-by-line for K: pattern matching. Suggested by Wolfram Sang as more efficient Refactor git command execution Break into 2 functions, execute/analyze Share code between --git and --git-blame Don't warn multiple times when git isn't installed Improve stats reporting --git-min-percent and -- rolestats now count the total number of commits for either the period of --git-since or if using --git-blame the commits used by the current file and calculate commit % as # of commits signed / total commits * 100 Code style cleaning Use consistent sub foo { my (args...) = @_; Signed-off-by: Joe Perches <joe@perches.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15scripts/get_maintainer.pl: add --roles and --rolestatsJoe Perches
--roles shows the role of each email address, i.e. why it was selected. --rolestats selects --roles and adds git log/blame signers #'s and % Multiple roles are possible (supporter, maintainer, git-signer...) --roles or --rolestats is meant to help identify appropriate maintainers to notify and should not be used with "git send-email --cc-cmd" Example output: Existing: $ ./scripts/get_maintainer.pl -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> Karol Kozimor <sziwan@users.sourceforge.net> Len Brown <len.brown@intel.com> Pavel Machek <pavel@ucw.cz> Rafael J. Wysocki <rjw@sisk.pl> Thomas Gleixner <tglx@linutronix.de> Ingo Molnar <mingo@redhat.com> H. Peter Anvin <hpa@zytor.com> x86@kernel.org Yinghai Lu <yhlu.kernel@gmail.com> Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> acpi4asus-user@lists.sourceforge.net linux-pm@lists.linux-foundation.org linux-kernel@vger.kernel.org With --roles $ ./scripts/get_maintainer.pl --roles -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats $ ./scripts/get_maintainer.pl --rolestats -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) With --rolestats and --git-blame $ ./scripts/get_maintainer.pl --rolestats --git-blame -f arch/x86/kernel/acpi/boot.c Corentin Chary <corentincj@iksaif.net> (maintainer:ASUS ACPI EXTRAS...) Karol Kozimor <sziwan@users.sourceforge.net> (maintainer:ASUS ACPI EXTRAS...) Len Brown <len.brown@intel.com> (supporter:SUSPEND TO RAM,git-signer:16/79=20%,commits:22/154=14%) Pavel Machek <pavel@ucw.cz> (supporter:SUSPEND TO RAM) Rafael J. Wysocki <rjw@sisk.pl> (supporter:SUSPEND TO RAM) Thomas Gleixner <tglx@linutronix.de> (maintainer:X86 ARCHITECTURE...) Ingo Molnar <mingo@redhat.com> (maintainer:X86 ARCHITECTURE...,git-signer:29/79=37%,commits:36/154=23%) H. Peter Anvin <hpa@zytor.com> (maintainer:X86 ARCHITECTURE...) x86@kernel.org (maintainer:X86 ARCHITECTURE...) Yinghai Lu <yhlu.kernel@gmail.com> (git-signer:12/79=15%,commits:9/154=6%) Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> (git-signer:6/79=8%) Andi Kleen <ak@suse.de> (commits:11/154=7%) Andrew Morton <akpm@osdl.org> (commits:10/154=6%) acpi4asus-user@lists.sourceforge.net (open list:ASUS ACPI EXTRAS...) linux-pm@lists.linux-foundation.org (open list:SUSPEND TO RAM) linux-kernel@vger.kernel.org (open list) Other changes: Format git-signers email addresses a bit to reduce bad signatures Command line bad arguments emitted a verbose usage(), just show --help Version number bumped to .22 Ben Hutchings had the idea and created a good deal of this implementation. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15modpost: fix segfault with short symbol namesMichal Marek
memcmp() is wrong here, the symbol name can be shorter than KSYMTAB_PFX or CRC_PFX. Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-15Kbuild: clear marker out of modpostWenji Huang
Remove the unnecessary functions and variables. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-15module: make MODULE_SYMBOL_PREFIX into a CONFIG optionAlan Jenkins
The next commit will require the use of MODULE_SYMBOL_PREFIX in .tmp_exports-asm.S. Currently it is mixed in with C structure definitions in "asm/module.h". Move the definition of this arch option into Kconfig, so it can be easily accessed by any code. This also lets modpost.c use the same definition. Previously modpost relied on a hardcoded list of architectures in mk_elfconfig.c. A build test for blackfin, one of the two MODULE_SYMBOL_PREFIX archs, showed the generated code was unchanged. vmlinux was identical save for build ids, and an apparently randomized suffix on a single "__key" symbol in the kallsyms data). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> (blackfin) CC: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-12-14microblaze: ftrace: Add dynamic trace supportMichal Simek
With dynamic function tracer, by default, _mcount is defined as an "empty" function, it returns directly without any more action. When enabling it in user-space, it will jump to a real tracing function(ftrace_caller), and do the real job for us. Differ from the static function tracer, dynamic function tracer provides two functions ftrace_make_call()/ftrace_make_nop() to enable/disable the tracing of some indicated kernel functions(set_ftrace_filter). In the kernel version, there is only one "_mcount" string for every kernel function, so, we just need to match this one in mcount_regex of scripts/recordmcount.pl. For more information please look at code and Documentation/trace folder. Steven ACK that scripts/recordmcount.pl part. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Michal Simek <monstr@monstr.eu>
