commit 944cfe9be1fbbec73bab2f7e77fe2e8f9c72970f upstream.
If a build rule fails, the .DELETE_ON_ERROR special target removes the
target, but does nothing for the .*.cmd file, which might be corrupted.
So, .*.cmd files should be included only when the corresponding targets
exist.
Commit 392885ee82d3 ("kbuild: let fixdep directly write to .*.cmd
files") missed to fix up this file.
Fixes: 392885ee82d3 ("kbuild: let fixdep directly write to .*.cmd")
Cc: <stable@vger.kernel.org> # v5.0+
commit 0c5b6c28ed68becb692b43eae5e44d5aa7e160ce upstream.
Prior to this commit, starting nconfig, xconfig or gconfig, and saving
the .config file more than once caused data loss, where a .config file
that contained only comments would be written to disk starting from the
second save operation.
This bug manifests itself because the SYMBOL_WRITTEN flag is never
cleared after the first call to conf_write, and subsequent calls to
conf_write then skip all of the configuration symbols due to the
SYMBOL_WRITTEN flag being set.
This commit resolves this issue by clearing the SYMBOL_WRITTEN flag
from all symbols before conf_write returns.
Fixes: 8e2442a5f86e ("kconfig: fix missing choice values in auto.conf")
Cc: linux-stable <stable@vger.kernel.org> # 4.19+
Signed-off-by: M. Vefa Bicakci <m.v.b@runbox.com>
[ Upstream commit 33177f01ca3fe550146bb9001bec2fd806b2f40c ]
gcc asan instrumentation emits the following sequence to store frame pc
when the kernel is built with CONFIG_RELOCATABLE:
debug/vsprintf.s:
.section .data.rel.ro.local,"aw"
.align 8
.LC3:
.quad .LASANPC4826@GOTOFF
.text
.align 8
.type number, @function
number:
.LASANPC4826:
and in case reloc is issued for LASANPC label it also gets into .symtab
with the same address as actual function symbol:
$ nm -n vmlinux | grep 0000000001397150
0000000001397150 t .LASANPC4826
0000000001397150 t number
In the end kernel backtraces are almost unreadable:
[ 143.748476] Call Trace:
[ 143.748484] ([<000000002da3e62c>] .LASANPC2671+0x114/0x190)
[ 143.748492] [<000000002eca1a58>] .LASANPC2612+0x110/0x160
[ 143.748502] [<000000002de9d830>] print_address_description+0x80/0x3b0
[ 143.748511] [<000000002de9dd64>] __kasan_report+0x15c/0x1c8
[ 143.748521] [<000000002ecb56d4>] strrchr+0x34/0x60
[ 143.748534] [<000003ff800a9a40>] kasan_strings+0xb0/0x148 [test_kasan]
[ 143.748547] [<000003ff800a9bba>] kmalloc_tests_init+0xe2/0x528 [test_kasan]
[ 143.748555] [<000000002da2117c>] .LASANPC4069+0x354/0x748
[ 143.748563] [<000000002dbfbb16>] do_init_module+0x136/0x3b0
[ 143.748571] [<000000002dbff3f4>] .LASANPC3191+0x2164/0x25d0
[ 143.748580] [<000000002dbffc4c>] .LASANPC3196+0x184/0x1b8
[ 143.748587] [<000000002ecdf2ec>] system_call+0xd8/0x2d8
Since LASANPC labels are not even unique and get into .symtab only due
to relocs filter them out in kallsyms.
Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
[ Upstream commit 80e5302e4bc85a6b685b7668c36c6487b5f90e9a ]
An impending change to enable HAVE_C_RECORDMCOUNT on powerpc leads to
warnings such as the following:
# modprobe kprobe_example
ftrace-powerpc: Not expected bl: opcode is 3c4c0001
WARNING: CPU: 0 PID: 227 at kernel/trace/ftrace.c:2001 ftrace_bug+0x90/0x318
Modules linked in:
CPU: 0 PID: 227 Comm: modprobe Not tainted 5.2.0-rc6-00678-g1c329100b942 #2
NIP: c000000000264318 LR: c00000000025d694 CTR: c000000000f5cd30
REGS: c000000001f2b7b0 TRAP: 0700 Not tainted (5.2.0-rc6-00678-g1c329100b942)
MSR: 900000010282b033 <SF,HV,VEC,VSX,EE,FP,ME,IR,DR,RI,LE,TM[E]> CR: 28228222 XER: 00000000
CFAR: c0000000002642fc IRQMASK: 0
<snip>
NIP [c000000000264318] ftrace_bug+0x90/0x318
LR [c00000000025d694] ftrace_process_locs+0x4f4/0x5e0
Call Trace:
[c000000001f2ba40] [0000000000000004] 0x4 (unreliable)
[c000000001f2bad0] [c00000000025d694] ftrace_process_locs+0x4f4/0x5e0
[c000000001f2bb90] [c00000000020ff10] load_module+0x25b0/0x30c0
[c000000001f2bd00] [c000000000210cb0] sys_finit_module+0xc0/0x130
[c000000001f2be20] [c00000000000bda4] system_call+0x5c/0x70
Instruction dump:
419e0018 2f83ffff 419e00bc 2f83ffea 409e00cc 4800001c 0fe00000 3c62ff96
39000001 39400000 386386d0 480000c4 <0fe00000> 3ce20003 39000001 3c62ff96
---[ end trace 4c438d5cebf78381 ]---
ftrace failed to modify
[<c0080000012a0008>] 0xc0080000012a0008
actual: 01:00:4c:3c
Initializing ftrace call sites
ftrace record flags: 2000000
(0)
expected tramp: c00000000006af4c
Looking at the relocation records in __mcount_loc shows a few spurious
entries:
RELOCATION RECORDS FOR [__mcount_loc]:
OFFSET TYPE VALUE
0000000000000000 R_PPC64_ADDR64 .text.unlikely+0x0000000000000008
0000000000000008 R_PPC64_ADDR64 .text.unlikely+0x0000000000000014
0000000000000010 R_PPC64_ADDR64 .text.unlikely+0x0000000000000060
0000000000000018 R_PPC64_ADDR64 .text.unlikely+0x00000000000000b4
0000000000000020 R_PPC64_ADDR64 .init.text+0x0000000000000008
0000000000000028 R_PPC64_ADDR64 .init.text+0x0000000000000014
The first entry in each section is incorrect. Looking at the
relocation records, the spurious entries correspond to the
R_PPC64_ENTRY records:
RELOCATION RECORDS FOR [.text.unlikely]:
OFFSET TYPE VALUE
0000000000000000 R_PPC64_REL64 .TOC.-0x0000000000000008
0000000000000008 R_PPC64_ENTRY *ABS*
0000000000000014 R_PPC64_REL24 _mcount
<snip>
The problem is that we are not validating the return value from
get_mcountsym() in sift_rel_mcount(). With this entry, mcountsym is 0,
but Elf_r_sym(relp) also ends up being 0. Fix this by ensuring
mcountsym is valid before processing the entry.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Tested-by: Satheesh Rajendran <sathnaga@linux.vnet.ibm.com>
[ Upstream commit 6f9ac9f4427ec0470ccffbf852cfaf326677cc21 ]
When there is not enough space on your storage device, the build will
fail with 'No space left on device' error message.
The reason is obvious from the message, so you will free up some disk
space, then you will resume the build.
However, sometimes you may still see a mysterious error message:
unterminated call to function 'wildcard': missing ')'.
If you run out of the disk space, fixdep may end up with generating
incomplete .*.cmd files.
For example, if the disk-full error occurs while fixdep is running
print_dep(), the .*.cmd might be truncated like this:
$(wildcard include/config/
When you run 'make' next time, this broken .*.cmd will be included,
then Make will terminate parsing since it is a wrong syntax.
Once this happens, you need to run 'make clean' or delete the broken
.*.cmd file manually.
Even if you do not see any error message, the .*.cmd files after any
error could be potentially incomplete, and unreliable. You may miss
the re-compilation due to missing header dependency.
If printf() cannot output the string for disk shortage or whatever
reason, it returns a negative value, but currently fixdep does not
check it at all. Consequently, fixdep *successfully* generates a
broken .*.cmd file. Make never notices that since fixdep exits with 0,
which means success.
Given the intended usage of fixdep, it must respect the return value
of not only malloc(), but also printf() and putchar().
This seems a long-standing issue since the introduction of fixdep.
In old days, Kbuild tried to provide an extra safety by letting fixdep
output to a temporary file and renaming it after everything is done:
scripts/basic/fixdep $(depfile) $@ '$(make-cmd)' > $(dot-target).tmp;\
rm -f $(depfile); \
mv -f $(dot-target).tmp $(dot-target).cmd)
It was no help to avoid the current issue; fixdep successfully created
a truncated tmp file, which would be renamed to a .*.cmd file.
This problem should be fixed by propagating the error status to the
build system because:
[1] Since commit 9c2af1c7377a ("kbuild: add .DELETE_ON_ERROR special
target"), Make will delete the target automatically on any failure
in the recipe.
[2] Since commit 392885ee82d3 ("kbuild: let fixdep directly write to
.*.cmd files"), .*.cmd file is included only when the corresponding
target already exists.
[ Upstream commit a222061b85234d8a44486a46bd4df7e2cda52385 ]
__uint128_t crops up in a few files that export symbols to modules, so
teach genksyms about it and the other GCC built-in 128-bit integer types
so that we don't end up skipping the CRC generation for some symbols due
to the parser failing to spot them:
| WARNING: EXPORT symbol "kernel_neon_begin" [vmlinux] version
| generation failed, symbol will not be versioned.
| ld: arch/arm64/kernel/fpsimd.o: relocation R_AARCH64_ABS32 against
| `__crc_kernel_neon_begin' can not be used when making a shared
| object
| ld: arch/arm64/kernel/fpsimd.o:(.data+0x0): dangerous relocation:
| unsupported relocation
commit 8e2442a5f86e1f77b86401fce274a7f622740bc4 upstream.
Since commit 00c864f8903d ("kconfig: allow all config targets to write
auto.conf if missing"), Kconfig creates include/config/auto.conf in the
defconfig stage when it is missing.
Joonas Kylmälä reported incorrect auto.conf generation under some
circumstances.
To reproduce it, apply the following diff:
| --- a/arch/arm/configs/imx_v6_v7_defconfig
| +++ b/arch/arm/configs/imx_v6_v7_defconfig
| @@ -345,14 +345,7 @@ CONFIG_USB_CONFIGFS_F_MIDI=y
| CONFIG_USB_CONFIGFS_F_HID=y
| CONFIG_USB_CONFIGFS_F_UVC=y
| CONFIG_USB_CONFIGFS_F_PRINTER=y
| -CONFIG_USB_ZERO=m
| -CONFIG_USB_AUDIO=m
| -CONFIG_USB_ETH=m
| -CONFIG_USB_G_NCM=m
| -CONFIG_USB_GADGETFS=m
| -CONFIG_USB_FUNCTIONFS=m
| -CONFIG_USB_MASS_STORAGE=m
| -CONFIG_USB_G_SERIAL=m
| +CONFIG_USB_FUNCTIONFS=y
| CONFIG_MMC=y
| CONFIG_MMC_SDHCI=y
| CONFIG_MMC_SDHCI_PLTFM=y
And then, run:
$ make ARCH=arm mrproper imx_v6_v7_defconfig
You will see CONFIG_USB_FUNCTIONFS=y is correctly contained in the
.config, but not in the auto.conf.
Please note drivers/usb/gadget/legacy/Kconfig is included from a choice
block in drivers/usb/gadget/Kconfig. So USB_FUNCTIONFS is a choice value.
This is probably a similar situation described in commit beaaddb62540
("kconfig: tests: test defconfig when two choices interact").
When sym_calc_choice() is called, the choice symbol forgets the
SYMBOL_DEF_USER unless all of its choice values are explicitly set by
the user.
The choice symbol is given just one chance to recall it because
set_all_choice_values() is called if SYMBOL_NEED_SET_CHOICE_VALUES
is set.
When sym_calc_choice() is called again, the choice symbol forgets it
forever, since SYMBOL_NEED_SET_CHOICE_VALUES is a one-time aid.
Hence, we cannot call sym_clear_all_valid() again and again.
It is crazy to repeat set and unset of internal flags. However, we
cannot simply get rid of "sym->flags &= flags | ~SYMBOL_DEF_USER;"
Doing so would re-introduce the problem solved by commit 5d09598d488f
("kconfig: fix new choices being skipped upon config update").
To work around the issue, conf_write_autoconf() stopped calling
sym_clear_all_valid().
conf_write() must be changed accordingly. Currently, it clears
SYMBOL_WRITE after the symbol is written into the .config file. This
is needed to prevent it from writing the same symbol multiple times in
case the symbol is declared in two or more locations. I added the new
flag SYMBOL_WRITTEN, to track the symbols that have been written.
Anyway, this is a cheesy workaround in order to suppress the issue
as far as defconfig is concerned.
Handling of choices is totally broken. sym_clear_all_valid() is called
every time a user touches a symbol from the GUI interface. To reproduce
it, just add a new symbol drivers/usb/gadget/legacy/Kconfig, then touch
around unrelated symbols from menuconfig. USB_FUNCTIONFS will disappear
from the .config file.
I added the Fixes tag since it is more fatal than before. But, this
has been broken since long long time before, and still it is.
We should take a closer look to fix this correctly somehow.
Fixes: 00c864f8903d ("kconfig: allow all config targets to write auto.conf if missing")
Reported-by: Joonas Kylmälä <joonas.kylmala@iki.fi>
Tested-by: Joonas Kylmälä <joonas.kylmala@iki.fi>
Based on 1 normalized pattern(s):
gplv2
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 58 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081207.556988620@linutronix.de
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
this file is subject to the terms and conditions of the gnu general
public license v2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 1 file(s).
Link: https://lkml.kernel.org/r/20190604081203.508532280@linutronix.de
At least for ARM64 kernels compiled with the crosstoolchain from
Debian/stretch or with the toolchain from kernel.org the line number is
not decoded correctly by 'decode_stacktrace.sh':
$ echo "[ 136.513051] f1+0x0/0xc [kcrash]" | \
CROSS_COMPILE=/opt/gcc-8.1.0-nolibc/aarch64-linux/bin/aarch64-linux- \
./scripts/decode_stacktrace.sh /scratch/linux-arm64/vmlinux \
/scratch/linux-arm64 \
/nfs/debian/lib/modules/4.20.0-devel
[ 136.513051] f1 (/linux/drivers/staging/kcrash/kcrash.c:68) kcrash
If addr2line from the toolchain is used the decoded line number is correct:
[ 136.513051] f1 (/linux/drivers/staging/kcrash/kcrash.c:57) kcrash
Link: http://lkml.kernel.org/r/20190527083425.3763-1-manut@linutronix.de
Signed-off-by: Manuel Traut <manut@linutronix.de>
Acked-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull yet more SPDX updates from Greg KH:
"Another round of SPDX header file fixes for 5.2-rc4
These are all more "GPL-2.0-or-later" or "GPL-2.0-only" tags being
added, based on the text in the files. We are slowly chipping away at
the 700+ different ways people tried to write the license text. All of
these were reviewed on the spdx mailing list by a number of different
people.
We now have over 60% of the kernel files covered with SPDX tags:
$ ./scripts/spdxcheck.py -v 2>&1 | grep Files
Files checked: 64533
Files with SPDX: 40392
Files with errors: 0
I think the majority of the "easy" fixups are now done, it's now the
start of the longer-tail of crazy variants to wade through"
* tag 'spdx-5.2-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (159 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 450
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 449
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 448
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 446
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 445
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 444
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 443
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 442
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 441
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 440
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 438
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 437
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 436
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 435
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 434
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 433
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 432
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 431
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 430
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 429
To print the pathname that will be used by shell in the current
environment, 'command -v' is a standardized way. [1]
'which' is also often used in scripts, but it is less portable.
When I worked on commit bd55f96fa9fc ("kbuild: refactor cc-cross-prefix
implementation"), I was eager to use 'command -v' but it did not work.
(The reason is explained below.)
I kept 'which' as before but got rid of '> /dev/null 2>&1' as I
thought it was no longer needed. Sorry, I was wrong.
It works well on my Ubuntu machine, but Alexey Brodkin reports noisy
warnings on CentOS7 when 'which' fails to find the given command in
the PATH environment.
$ which foo
which: no foo in (/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin)
Given that behavior of 'which' depends on system (and it may not be
installed by default), I want to try 'command -v' once again.
The specification [1] clearly describes the behavior of 'command -v'
when the given command is not found:
Otherwise, no output shall be written and the exit status shall reflect
that the name was not found.
However, we need a little magic to use 'command -v' from Make.
$(shell ...) passes the argument to a subshell for execution, and
returns the standard output of the command.
Here is a trick. GNU Make may optimize this by executing the command
directly instead of forking a subshell, if no shell special characters
are found in the command and omitting the subshell will not change the
behavior.
In this case, no shell special character is used. So, Make will try
to run it directly. However, 'command' is a shell-builtin command,
then Make would fail to find it in the PATH environment:
$ make ARCH=m68k defconfig
make: command: Command not found
In fact, Make has a table of shell-builtin commands because it must
ask the shell to execute them.
Until recently, 'command' was missing in the table.
This issue was fixed by the following commit:
| commit 1af314465e5dfe3e8baa839a32a72e83c04f26ef
| Author: Paul Smith <psmith@gnu.org>
| Date: Sun Nov 12 18:10:28 2017 -0500
| * job.c: Add "command" as a known shell built-in.
| This is not a POSIX shell built-in but it's common in UNIX shells.
| Reported by Nick Bowler <nbowler@draconx.ca>.
Because the latest release is GNU Make 4.2.1 in 2016, this commit is
not included in any released versions. (But some distributions may
have back-ported it.)
We need to trick Make to spawn a subshell. There are various ways to
do so:
1) Use a shell special character '~' as dummy
$(shell : ~; command -v $(c)gcc)
2) Use a variable reference that always expands to the empty string
(suggested by David Laight)
$(shell command$${x:+} -v $(c)gcc)
3) Use redirect
$(shell command -v $(c)gcc 2>/dev/null)
I chose 3) to not confuse people. The stderr would not be polluted
anyway, but it will provide extra safety, and is easy to understand.
Tested on Make 3.81, 3.82, 4.0, 4.1, 4.2, 4.2.1
[1] http://pubs.opengroup.org/onlinepubs/9699919799/utilities/command.html
Fixes: bd55f96fa9fc ("kbuild: refactor cc-cross-prefix implementation")
Cc: linux-stable <stable@vger.kernel.org> # 5.1
Reported-by: Alexey Brodkin <abrodkin@synopsys.com>
Tested-by: Alexey Brodkin <abrodkin@synopsys.com>
it under the terms of the gnu general public license as published by
the free software foundation version 2 of the license
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 315 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Link: https://lkml.kernel.org/r/20190531190115.503150771@linutronix.de
gpl 2 0 applies
GPL-2.0-only
Link: https://lkml.kernel.org/r/20190531190115.220546219@linutronix.de
this program file is free software you can redistribute it and or
modify it under the terms of the gnu general public license as
published by the free software foundation version 2 of the license
this program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
merchantability or fitness for a particular purpose see the gnu
general public license for more details you should have received a
copy of the gnu general public license along with this program in a
file named copying if not write to the free software foundation inc
51 franklin street fifth floor boston ma 02110 1301 usa
GPL-2.0-only
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Link: https://lkml.kernel.org/r/20190531081038.017566012@linutronix.de
licensed under the gnu general public license version 2 gplv2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 5 file(s).
Link: https://lkml.kernel.org/r/20190531081036.993848054@linutronix.de
GPL-2.0-only
Link: https://lkml.kernel.org/r/20190531081036.527324761@linutronix.de
released under gplv2
GPL-2.0-only
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Link: https://lkml.kernel.org/r/20190530000436.946199729@linutronix.de
gpl v2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 19 file(s).
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Link: https://lkml.kernel.org/r/20190529141333.108140152@linutronix.de
The following error occurs for the `make ARCH=arm64 checkstack` case:
aarch64-linux-gnu-objdump -d vmlinux $(find . -name '*.ko') | \
perl ./scripts/checkstack.pl arm64
wrong or unknown architecture "arm64"
As suggested by Masahiro Yamada, fix the above error using regular
expressions in the same way it was fixed for the `ARCH=x86` case via
commit fda9f9903be6 ("scripts/checkstack.pl: automatically handle
32-bit and 64-bit mode for ARCH=x86").
Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: George G. Davis <george_davis@mentor.com>
The buildtar script might want to invoke a make, so tell the parent
make to pass the jobserver token pipe to the subcommand by prefixing
the command with a +.
This addresses the issue seen here:
/bin/sh ../scripts/package/buildtar tar-pkg
make[3]: warning: jobserver unavailable: using -j1. Add '+' to parent make rule.
See https://www.gnu.org/software/make/manual/html_node/Job-Slots.html
for more information.
Signed-off-by: Trevor Bourget <tgb.kernel@gmail.com>
Adding SPDX license identifier is pretty safe; however, here is one
exception.
Since commit ec8f24b7faaf ("treewide: Add SPDX license identifier -
Makefile/Kconfig"), "make testconfig" would not pass.
When Kconfig detects a circular file inclusion, it displays error
messages with a file name and a line number prefixed to each line.
The unit test checks if Kconfig emits the error messages correctly
(this also checks the line number correctness).
Now that the test input has the SPDX license identifier at the very top,
the line numbers in the expected stderr should be incremented by 1.
Fixes: ec8f24b7faaf ("treewide: Add SPDX license identifier - Makefile/Kconfig")
Merge misc fixes from Andrew Morton:
"Various fixes and followups"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm, compaction: make sure we isolate a valid PFN
include/linux/generic-radix-tree.h: fix kerneldoc comment
kernel/signal.c: trace_signal_deliver when signal_group_exit
drivers/iommu/intel-iommu.c: fix variable 'iommu' set but not used
spdxcheck.py: fix directory structures
kasan: initialize tag to 0xff in __kasan_kmalloc
z3fold: fix sheduling while atomic
scripts/gdb: fix invocation when CONFIG_COMMON_CLK is not set
mm/gup: continue VM_FAULT_RETRY processing even for pre-faults
ocfs2: fix error path kobject memory leak
memcg: make it work on sparse non-0-node systems
mm, memcg: consider subtrees in memory.events
prctl_set_mm: downgrade mmap_sem to read lock
prctl_set_mm: refactor checks from validate_prctl_map
kernel/fork.c: make max_threads symbol static
arch/arm/boot/compressed/decompress.c: fix build error due to lz4 changes
arch/parisc/configs/c8000_defconfig: remove obsoleted CONFIG_DEBUG_SLAB_LEAK
mm/vmalloc.c: fix typo in comment
lib/sort.c: fix kernel-doc notation warnings
mm: fix Documentation/vm/hmm.rst Sphinx warnings
The LICENSE directory has recently changed structure and this makes
spdxcheck fails as per below:
FAIL: "Blob or Tree named 'other' not found"
Traceback (most recent call last):
File "scripts/spdxcheck.py", line 240, in <module>
spdx = read_spdxdata(repo)
File "scripts/spdxcheck.py", line 41, in read_spdxdata
for el in lictree[d].traverse():
KeyError: "Blob or Tree named 'other' not found"
Fix the script to restore the correctness on checkpatch License checking.
References: 62be257e986d ("LICENSES: Rename other to deprecated")
References: 8ea8814fcdcb ("LICENSES: Clearly mark dual license only licenses")
Link: http://lkml.kernel.org/r/20190523084755.56739-1-vincenzo.frascino@arm.com
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
Cc: Joe Perches <joe@perches.com>
Cc: Jeremy Cline <jcline@redhat.com>
CLK_GET_RATE_NOCACHE depends on CONFIG_COMMON_CLK. Importing constants.py
when CONFIG_COMMON_CLK is not defined causes:
(gdb) lx-symbols
File "scripts/gdb/linux/proc.py", line 15, in <module>
from linux import constants
File "scripts/gdb/linux/constants.py", line 2, in <module>
LX_CLK_GET_RATE_NOCACHE = gdb.parse_and_eval("CLK_GET_RATE_NOCACHE")
gdb.error: No symbol "CLK_GET_RATE_NOCACHE" in current context.
Link: http://lkml.kernel.org/r/20190523195313.24701-1-farosas@linux.ibm.com
Fixes: e7e6f462c1be ("scripts/gdb: print cached rate in lx-clk-summary")
Signed-off-by: Fabiano Rosas <farosas@linux.ibm.com>
Reviewed-by: Stephen Boyd <swboyd@chromium.org>
Cc: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Kieran Bingham <kbingham@kernel.org>
Cc: Leonard Crestez <leonard.crestez@nxp.com>
Cc: Jackie Liu <liuyun01@kylinos.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc-plugins fix from Kees Cook:
"Handle unusual header environment, fixing a redefined macro error
under a Darwin build host"
* tag 'gcc-plugins-v5.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
gcc-plugins: Fix build failures under Darwin host
"Here is another set of reviewed patches that adds SPDX tags to
different kernel files, based on a set of rules that are being used to
parse the comments to try to determine that the license of the file is
"GPL-2.0-or-later" or "GPL-2.0-only". Only the "obvious" versions of
these matches are included here, a number of "non-obvious" variants of
text have been found but those have been postponed for later review
and analysis.
There is also a patch in here to add the proper SPDX header to a bunch
of Kbuild files that we have missed in the past due to new files being
added and forgetting that Kbuild uses two different file names for
Makefiles. This issue was reported by the Kbuild maintainer.
These patches have been out for review on the linux-spdx@vger mailing
list, and while they were created by automatic tools, they were
hand-verified by a bunch of different people, all whom names are on
the patches are reviewers"
* tag 'spdx-5.2-rc3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (82 commits)
treewide: Add SPDX license identifier - Kbuild
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 225
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 224
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 223
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 222
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 221
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 220
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 218
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 217
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 216
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 215
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 214
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 213
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 211
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 210
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 209
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 207
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 206
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 203
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 201
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0
Reported-by: Masahiro Yamada <yamada.masahiro@socionext.com>
released under gpl v2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 15 file(s).
Link: https://lkml.kernel.org/r/20190528171438.895196075@linutronix.de
licensed under the terms of the gnu gpl version 2
GPL-2.0-only
Link: https://lkml.kernel.org/r/20190528170027.911569875@linutronix.de
licensed under the terms of the gnu gpl license version 2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 62 file(s).
Link: https://lkml.kernel.org/r/20190527070033.929121379@linutronix.de
Based on 3 normalized pattern(s):
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
that it will be useful but without any warranty without even the
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not write to the free software foundation inc
59 temple place suite 330 boston ma 02111 1307 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1334 file(s).
Link: https://lkml.kernel.org/r/20190527070033.113240726@linutronix.de
Pull documentation fixes from Jonathan Corbet:
"The Sphinx 2.0 release contained a few incompatible API changes that
broke our extensions and, thus, the documentation build in general.
Who knew that those deprecation warnings it was outputting actually
meant we should change something? This set of fixes makes the build
work again with Sphinx 2.0 and eliminates the warnings for 1.8. As
part of that, we also need a few fixes to the docs for places where
the new Sphinx is more strict.
It is a bit late in the cycle for this kind of change, but it does fix
problems that people are experiencing now.
There has been some talk of raising the minimum version of Sphinx we
support. I don't want to do that abruptly, though, so these changes
add some glue to continue to support versions back to 1.3. We will be
adding some infrastructure soon to nudge users of old versions
forward, with the idea of maybe increasing our minimum version (and
removing this glue) sometime in the future"
* tag 'docs-5.2-fixes2' of git://git.lwn.net/linux:
drm/i915: Maintain consistent documentation subsection ordering
scripts/sphinx-pre-install: make it handle Sphinx versions
docs: Fix conf.py for Sphinx 2.0
docs: fix multiple doc build warnings in enumeration.rst
lib/list_sort: fix kerneldoc build error
docs: fix numaperf.rst and add it to the doc tree
doc: Cope with the deprecation of AutoReporter
doc: Cope with Sphinx logging deprecations
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull Devicetree fixes from Rob Herring:
- Update checkpatch.pl to use DT vendor-prefixes.yaml
- Fix DT binding references to files converted to DT schema
- Clean-up Arm CPU binding examples to match schema
- Add Sifive block versioning scheme documentation
- Pass binding directory base to validation tools for reference lookups
* tag 'devicetree-fixes-for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
checkpatch.pl: Update DT vendor prefix check
dt: bindings: mtd: replace references to nand.txt with nand-controller.yaml
dt-bindings: interrupt-controller: arm,gic: Fix schema errors in example
dt-bindings: arm: Clean up CPU binding examples
dt: fix refs that were renamed to json with the same file name
dt-bindings: Pass binding directory to validation tools
dt-bindings: sifive: describe sifive-blocks versioning
Pule more SPDX updates from Greg KH:
"GPL-2.0-or-later".
Only the "obvious" versions of these matches are included here, a
number of "non-obvious" variants of text have been found but those
have been postponed for later review and analysis.
* tag 'spdx-5.2-rc2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (85 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 125
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 123
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 122
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 121
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 120
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 119
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 118
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 116
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 114
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 113
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 112
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 111
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 110
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 106
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 105
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 104
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 103
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 102
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 101
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 98
675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 441 file(s).
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Link: https://lkml.kernel.org/r/20190520071858.739733335@linutronix.de
this program is a part of the linux kernel and may be freely copied
under the terms of the gnu general public license gpl version 2 or
at your option any later version
GPL-2.0-or-later
Link: https://lkml.kernel.org/r/20190520071858.118952876@linutronix.de
it under the terms of the gnu general public licence as published by
the free software foundation either version 2 of the licence or at
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 114 file(s).
Link: https://lkml.kernel.org/r/20190520170857.552531963@linutronix.de
As we want to switch to a newer Sphinx version in the future,
add some version detected logic, checking if the current
version meets the requirement and suggesting upgrade it the
version is supported but too old.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
"A handful of fixes for a docs build problem, along with catching the
spdxcheck.py script up with the current state of affairs"
* tag 'docs-5.2-fixes' of git://git.lwn.net/linux:
Documentation: kdump: fix minor typo
scripts/spdxcheck.py: Add dual license subdirectory
scripts/spdxcheck.py: Fix path to deprecated licenses
counter: fix Documentation build error due to incorrect source file name
In commit 8122de54602e ("dt-bindings: Convert vendor prefixes to
json-schema"), vendor-prefixes.txt has been converted to a DT schema.
Update the checkpatch.pl DT check to extract vendor prefixes from the new
vendor-prefixes.yaml file.
Fixes: 8122de54602e ("dt-bindings: Convert vendor prefixes to json-schema")
Signed-off-by: Rob Herring <robh@kernel.org>
In order to have $ref's to schema files within the kernel, we need to
pass the base path of bindings to the schema validation tools.
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: devicetree@vger.kernel.org
Cc: linux-kbuild@vger.kernel.org
Pull SPDX update from Greg KH:
"Here is a series of patches that add SPDX tags to different kernel
files, based on two different things:
- SPDX entries are added to a bunch of files that we missed a year
ago that do not have any license information at all.
These were either missed because the tool saw the MODULE_LICENSE()
tag, or some EXPORT_SYMBOL tags, and got confused and thought the
file had a real license, or the files have been added since the
last big sweep, or they were Makefile/Kconfig files, which we
didn't touch last time.
- Add GPL-2.0-only or GPL-2.0-or-later tags to files where our scan
tools can determine the license text in the file itself. Where this
happens, the license text is removed, in order to cut down on the
700+ different ways we have in the kernel today, in a quest to get
rid of all of these.
the patches are reviewers.
The reason for these "large" patches is if we were to continue to
progress at the current rate of change in the kernel, adding license
tags to individual files in different subsystems, we would be finished
in about 10 years at the earliest.
There will be more series of these types of patches coming over the
next few weeks as the tools and reviewers crunch through the more
"odd" variants of how to say "GPLv2" that developers have come up with
over the years, combined with other fun oddities (GPL + a BSD
disclaimer?) that are being unearthed, with the goal for the whole
kernel to be cleaned up.
These diffstats are not small, 3840 files are touched, over 10k lines
removed in just 24 patches"
* tag 'spdx-5.2-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (24 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 25
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 24
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 23
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 19
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 18
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 17
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 15
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 14
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 13
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 7
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 5
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 3
The licenses from the other directory were partially moved to the dual
directory in commit 8ea8814fcdcb ("LICENSES: Clearly mark dual license only
licenses"). checkpatch therefore rejected files like
drivers/staging/android/ashmem.h with
WARNING: 'SPDX-License-Identifier: GPL-2.0 OR Apache-2.0 */' is not supported in LICENSES/...
#1: FILE: drivers/staging/android/ashmem.h:1:
+/* SPDX-License-Identifier: GPL-2.0 OR Apache-2.0 */
Fixes: 8ea8814fcdcb ("LICENSES: Clearly mark dual license only licenses")
Signed-off-by: Sven Eckelmann <sven@narfation.org>
GPL-2.0-only
Add SPDX license identifiers to all files which:
- Have EXPORT_.*_SYMBOL_GPL inside which was used in the
initial scan/conversion to ignore the file
GPL-2.0-only
I just thought it was a good idea to scan builtin.modules in the name
uniqueness checking, but a couple of false positives were found.
Stephen reported a false positive for ppc64_defconfig:
warning: same basename if the following are built as modules:
arch/powerpc/platforms/powermac/nvram.ko
drivers/char/nvram.ko
The former is never built as a module as you see in
arch/powerpc/platforms/powermac/Makefile:
# CONFIG_NVRAM is an arch. independent tristate symbol, for pmac32 we really
# need this to be a bool. Cheat here and pretend CONFIG_NVRAM=m is really
# CONFIG_NVRAM=y
obj-$(CONFIG_NVRAM:m=y) += nvram.o
Another example of false positive is arm64 defconfig:
arch/arm64/lib/crc32.ko
lib/crc32.ko
It is true CONFIG_CRC32 is a tristate option but it is always 'y' since
it is select'ed by ARM64. Hence, neither of them is built as a module
for the arm64 build.
From the above, modules.builtin essentially contains false positives.
I do not think it is a big deal as far as kmod is concerned, but false
positive warnings in the kernel build make people upset. It is better
to not check it.
Even without builtin.modules checked, we have enough (and more solid)
test coverage with allmodconfig.
While I touched this part, I replaced the sed code with neater one
provided by Stephen.
Link: https://lkml.org/lkml/2019/5/19/120
Link: https://lkml.org/lkml/2019/5/19/123
Fixes: 3a48a91901c5 ("kbuild: check uniqueness of module names")
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
The gcc-common.h file did not take into account certain macros that
might have already been defined in the build environment. This updates
the header to avoid redefining the macros, as seen on a Darwin host
using gcc 4.9.2:
HOSTCXX -fPIC scripts/gcc-plugins/arm_ssp_per_task_plugin.o - due to: scripts/gcc-plugins/gcc-common.h
In file included from scripts/gcc-plugins/arm_ssp_per_task_plugin.c:3:0:
scripts/gcc-plugins/gcc-common.h:153:0: warning: "__unused" redefined
In file included from /usr/include/stdio.h:64:0,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/system.h:40,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/gcc-plugin.h:28,
from /Users/hns/Documents/Projects/QuantumSTEP/System/Library/Frameworks/System.framework/Versions-jessie/x86_64-apple-darwin15.0.0/gcc/arm-linux-gnueabi/bin/../lib/gcc/arm-linux-gnueabi/4.9.2/plugin/include/plugin.h:23,
from scripts/gcc-plugins/gcc-common.h:9,
/usr/include/sys/cdefs.h:161:0: note: this is the location of the previous definition
Reported-and-tested-by: "H. Nikolaus Schaller" <hns@goldelico.com>
Fixes: 189af4657186 ("ARM: smp: add support for per-task stack canaries")
Cc: stable@vger.kernel.org
