path: root/scripts
2017-01-09kconfig/nconf: Fix hang when editing symbol with a long promptBen Hutchings
commit 79e51b5c2deea542b3bb8c66e0d502230b017dde upstream. Currently it is impossible to edit the value of a config symbol with a prompt longer than (terminal width - 2) characters. dialog_inputbox() calculates a negative x-offset for the input window and newwin() fails as this is invalid. It also doesn't check for this failure, so it busy-loops calling wgetch(NULL) which immediately returns -1. The additions in the offset calculations also don't match the intended size of the window. Limit the window size and calculate the offset similarly to show_scroll_win(). Fixes: 692d97c380c6 ("kconfig: new configuration interface (nconfig)") Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-26scripts/has-stack-protector: add -fno-PIESebastian Andrzej Siewior
commit 82031ea29e454b574bc6f49a33683a693ca5d907 upstream. Adding -no-PIE to the fstack protector check. -no-PIE was introduced before -fstack-protector so there is no need for a runtime check. Without it the build stops: |Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong available but compiler is broken due to -mcmodel=kernel + -fPIE if -fPIE is enabled by default. Tagging it stable so it is possible to compile recent stable kernels as well. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31Revert "x86/mm: Expand the exception table logic to allow new handling options"Greg Kroah-Hartman
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31x86/mm: Expand the exception table logic to allow new handling optionsTony Luck
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream. Huge amounts of help from Andy Lutomirski and Borislav Petkov to produce this. Andy provided the inspiration to add classes to the exception table with a clever bit-squeezing trick, Boris pointed out how much cleaner it would all be if we just had a new field. Linus Torvalds blessed the expansion with: ' I'd rather not be clever in order to save just a tiny amount of space in the exception table, which isn't really criticial for anybody. ' The third field is another relative function pointer, this one to a handler that executes the actions. We start out with three handlers: 1: Legacy - just jumps the to fixup IP 2: Fault - provide the trap number in %ax to the fixup code 3: Cleaned up legacy for the uaccess error hack Signed-off-by: Tony Luck <tony.luck@intel.com> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20ftrace/recordmcount: Work around for addition of metag magic but not relocationsLaura Abbott
commit b2e1c26f0b62531636509fbcb6dab65617ed8331 upstream. glibc recently did a sync up (94e73c95d9b5 "elf.h: Sync with the gabi webpage") that added a #define for EM_METAG but did not add relocations This triggers build errors: scripts/recordmcount.c: In function 'do_file': scripts/recordmcount.c:466:28: error: 'R_METAG_ADDR32' undeclared (first use in this function) case EM_METAG: reltype = R_METAG_ADDR32; ^~~~~~~~~~~~~~ scripts/recordmcount.c:466:28: note: each undeclared identifier is reported only once for each function it appears in scripts/recordmcount.c:468:20: error: 'R_METAG_NONE' undeclared (first use in this function) rel_type_nop = R_METAG_NONE; ^~~~~~~~~~~~ Work around this change with some more #ifdefery for the relocations. Fedora Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1354034 Link: http://lkml.kernel.org/r/1468005530-14757-1-git-send-email-labbott@redhat.com Cc: James Hogan <james.hogan@imgtec.com> Fixes: 00512bdd4573 ("metag: ftrace support") Reported-by: Ross Burton <ross.burton@intel.com> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-27of: fix autoloading due to broken modalias with no 'compatible'Wolfram Sang
commit b3c0a4dab7e35a9b6d69c0415641d2280fdefb2b upstream. Because of an improper dereference, a stray 'C' character was output to the modalias when no 'compatible' was specified. This is the case for some old PowerMac drivers which only set the 'name' property. Fix it to let them match again. Reported-by: Mathieu Malaterre <malat@debian.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Tested-by: Mathieu Malaterre <malat@debian.org> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Andreas Schwab <schwab@linux-m68k.org> Fixes: 6543becf26fff6 ("mod/file2alias: make modalias generation safe for cross compiling") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-07scripts/package/Makefile: rpmbuild add support of RPMOPTSSrinivas Pandruvada
commit 65a9f31c5042e5bb50d30ed8ae374044be561054 upstream. After commit 21a59991ce0c ("scripts/package/Makefile: rpmbuild is needed for rpm targets"), it is no longer possible to specify RPMOPTS. For example, we can no longer able to control _topdir using the following make command. make RPMOPTS="--define '_topdir /home/xyz/workspace/'" binrpm-pkg Fixes: 21a59991ce0c ("scripts/package/Makefile: rpmbuild is needed for rpm targets") Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01kbuild: move -Wunused-const-variable to W=1 warning levelArnd Bergmann
commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 upstream. gcc-6 started warning by default about variables that are not used anywhere and that are marked 'const', generating many false positives in an allmodconfig build, e.g.: arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=] arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=] drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=] drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=] drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=] drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=] This is similar to the existing -Wunused-but-set-variable warning that was added in an earlier release and that we disable by default now and only enable when W=1 is set, so it makes sense to do the same here. Once we have eliminated the majority of the warnings for both, we can put them back into the default list. We probably want this in backport kernels as well, to allow building them with gcc-6 without introducing extra warnings. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04unbreak allmodconfig KCONFIG_ALLCONFIG=...Al Viro
commit 6b87b70c5339f30e3c5b32085e69625906513dc2 upstream. Prior to 3.13 make allmodconfig KCONFIG_ALLCONFIG=/dev/null used to be equivalent to make allmodconfig; these days it hardwires MODULES to n. In fact, any KCONFIG_ALLCONFIG that doesn't set MODULES explicitly is treated as if it set it to n. Regression had been introduced by commit cfa98f ("kconfig: do not override symbols already set"); what happens is that conf_read_simple() does sym_calc_value(modules_sym) on exit, which leaves SYMBOL_VALID set and has conf_set_all_new_symbols() skip modules_sym. It's pretty easy to fix - simply move that call of sym_calc_value() into the callers, except for the ones in KCONFIG_ALLCONFIG handling. Objections? Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Fixes: cfa98f2e0ae9 ("kconfig: do not override symbols already set") Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12kbuild/mkspec: fix grub2 installkernel issueJiri Kosina
commit c8b08ca558c0067bc9e15ce3f1e70af260410bb2 upstream. mkspec is copying built kernel to temporrary location /boot/vmlinuz-$KERNELRELEASE-rpm and runs installkernel on it. This however directly leads to grub2 menuentry for this suffixed binary being generated as well during the run of installkernel script. Later in the process the temporary -rpm suffixed files are removed, and therefore we end up with spurious (and non-functional) grub2 menu entries for each installed kernel RPM. Fix that by using a different temporary name (prefixed by '.'), so that the binary is not recognized as an actual kernel binary and no menuentry is created for it. Signed-off-by: Jiri Kosina <jkosina@suse.cz> Fixes: 3c9c7a14b627 ("rpm-pkg: add %post section to create initramfs and grub hooks") Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12scripts/kconfig: allow building with make 3.80 againJan Beulich
commit 42f9d3c6888bceef6dc7ba72c77acf47347dcf05 upstream. Documentation/Changes still lists this as the minimal required version, so it ought to remain usable for the time being. Fixes: d2036f30cf ("scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target") Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12scripts/coccinelle: modernize &Julia Lawall
commit 1b669e713f277a4d4b3cec84e13d16544ac8286d upstream. & is no longer allowed in column 0, since Coccinelle 1.0.4. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Michal Marek <mmarek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-16ld-version: Fix awk regex compile failureJames Hogan
commit 4b7b1ef2c2f83d702272555e8adb839a50ba0f8e upstream. The ld-version.sh script fails on some versions of awk with the following error, resulting in build failures for MIPS: awk: scripts/ld-version.sh: line 4: regular expression compile failed (missing '(') This is due to the regular expression ".*)", meant to strip off the beginning of the ld version string up to the close bracket, however brackets have a meaning in regular expressions, so lets escape it so that awk doesn't expect a corresponding open bracket. Fixes: ccbef1674a15 ("Kbuild, lto: add ld-version and ld-ifversion ...") Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Hogan <james.hogan@imgtec.com> Tested-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Tested-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Cc: Michal Marek <mmarek@suse.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-mips@linux-mips.org Cc: linux-kbuild@vger.kernel.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/12838/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03um: link with -lpthreadVegard Nossum
commit a7df4716d19594b7b3f106f0bc0ca1c548e508e6 upstream. Similarly to commit fb1770aa78a43530940d0c2dd161e77bc705bdac, with gcc 5 on Ubuntu and CONFIG_STATIC_LINK=y I was seeing these linker errors: /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/librt.a(timer_create.o): In function `__timer_create_new': (.text+0xcd): undefined reference to `pthread_once' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/librt.a(timer_create.o): In function `__timer_create_new': (.text+0x126): undefined reference to `pthread_attr_init' /usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/librt.a(timer_create.o): In function `__timer_create_new': (.text+0x168): undefined reference to `pthread_attr_setdetachstate' [...] Obviously we also need -lpthread for librt.a. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25scripts/bloat-o-meter: fix python3 syntax errorSergey Senozhatsky
commit 72214a24a7677d4c7501eecc9517ed681b5f2db2 upstream. In Python3+ print is a function so the old syntax is not correct anymore: $ ./scripts/bloat-o-meter vmlinux.o vmlinux.o.old File "./scripts/bloat-o-meter", line 61 print "add/remove: %s/%s grow/shrink: %s/%s up/down: %s/%s (%s)" % \ ^ SyntaxError: invalid syntax Fix by calling print as a function. Tested on python 2.7.11, 3.5.1 Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-31scripts/recordmcount.pl: support data in text section on powerpcUlrich Weigand
commit 2e50c4bef77511b42cc226865d6bc568fa7f8769 upstream. If a text section starts out with a data blob before the first function start label, disassembly parsing doing in recordmcount.pl gets confused on powerpc, leading to creation of corrupted module objects. This was not a problem so far since the compiler would never create such text sections. However, this has changed with a recent change in GCC 6 to support distances of > 2GB between a function and its assoicated TOC in the ELFv2 ABI, exposing this problem. There is already code in recordmcount.pl to handle such data blobs on the sparc64 platform. This patch uses the same method to handle those on powerpc as well. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ulrich Weigand <ulrich.weigand@de.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-04ftrace/scripts: Fix incorrect use of sprintf in recordmcountColin Ian King
Fix build warning: scripts/recordmcount.c:589:4: warning: format not a string literal and no format arguments [-Wformat-security] sprintf("%s: failed\n", file); Fixes: a50bd43935586 ("ftrace/scripts: Have recordmcount copy the object file") Link: http://lkml.kernel.org/r/1451516801-16951-1-git-send-email-colin.king@canonical.com Cc: Li Bin <huawei.libin@huawei.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-12-16ftrace/scripts: Have recordmcount copy the object fileSteven Rostedt (Red Hat)
Russell King found that he had weird side effects when compiling the kernel with hard linked ccache. The reason was that recordmcount modified the kernel in place via mmap, and when a file gets modified twice by recordmcount, it will complain about it. To fix this issue, Russell wrote a patch that checked if the file was hard linked more than once and would unlink it if it was. Linus Torvalds was not happy with the fact that recordmcount does this in place modification. Instead of doing the unlink only if the file has two or more hard links, it does the unlink all the time. In otherwords, it always does a copy if it changed something. That is, it does the write out if a change was made. Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-12-16scripts: recordmcount: break hardlinksRussell King
recordmcount edits the file in-place, which can cause problems when using ccache in hardlink mode. Arrange for recordmcount to break a hardlinked object. Link: http://lkml.kernel.org/r/E1a7MVT-0000et-62@rmk-PC.arm.linux.org.uk Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-12-08arch: um: fix error when linking vmlinux.Lorenzo Colitti
On gcc Ubuntu 4.8.4-2ubuntu1~14.04, linking vmlinux fails with: arch/um/os-Linux/built-in.o: In function `os_timer_create': /android/kernel/android/arch/um/os-Linux/time.c:51: undefined reference to `timer_create' arch/um/os-Linux/built-in.o: In function `os_timer_set_interval': /android/kernel/android/arch/um/os-Linux/time.c:84: undefined reference to `timer_settime' arch/um/os-Linux/built-in.o: In function `os_timer_remain': /android/kernel/android/arch/um/os-Linux/time.c:109: undefined reference to `timer_gettime' arch/um/os-Linux/built-in.o: In function `os_timer_one_shot': /android/kernel/android/arch/um/os-Linux/time.c:132: undefined reference to `timer_settime' arch/um/os-Linux/built-in.o: In function `os_timer_disable': /android/kernel/android/arch/um/os-Linux/time.c:145: undefined reference to `timer_settime' This is because -lrt appears in the generated link commandline after arch/um/os-Linux/built-in.o. Fix this by removing -lrt from arch/um/Makefile and adding it to the UM-specific section of scripts/link-vmlinux.sh. Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: Richard Weinberger <richard@nod.at>
2015-11-17kernel-doc: Make it compatible with Perl versions below 5.12 againMauro Carvalho Chehab
Changeset 4d73270192ec('scripts/kernel-doc: Replacing highlights hash by an array') broke compatibility of the kernel-doc script with older versions of perl by using "keys ARRAY" syntax with is available only on Perl 5.12 or newer, according with: http://perldoc.perl.org/functions/keys.html Restore backward compatibility by replacing "foreach my $k (keys ARRAY)" by a C-like variant: "for (my $k = 0; $k < !ARRAY; $k++)" Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2015-11-10Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "This is the non-critical part of kbuild: - several coccinelle updates - make deb-pkg creates an armhf package if CONFIG_VFP=y - make tags understands some more powerpc macros" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: coccinelle: Improve checking for missing NULL terminators coccinelle: ifnullfree: handle various destroy functions coccinelle: ifnullfree: various cleanups cocinelle: iterators: semantic patch to delete unneeded of_node_put deb-pkg: Add automatic support for armhf architecture scripts/coccinelle: fix typos coccinelle: misc: remove "complex return code" warnings Coccinelle: fix incorrect -include option transformation coccinelle: tests: improve odd_ptr_err.cocci coccinelle: misc: move constants to the right scripts/tags.sh: Teach tags about some powerpc macros
2015-11-10Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: - 'make xconfig' ported to Qt5, dropping support for Qt3 - merge_config.sh supports a single-input-file mode and also respects $KCONFIG_CONFIG - Fix for incorrect display of >= and > in dependency expressions * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (44 commits) Add current selection check. Use pkg-config to find Qt 4 and 5 instead of direct qmake kconfig: Fix copy&paste error kconfig/merge_config.sh: Accept a single file kconfig/merge_config.sh: Support KCONFIG_CONFIG Update the buildsystem for KConfig finding Qt Port xconfig to Qt5 - Update copyright. Port xconfig to Qt5 - Fix goParent issue. Port xconfig to Qt5 - on Back clicked, deselect old item. Port xconfig to Qt5 - Add(back) one click checkbox toggle. Port xconfig to Qt5 - Add(back) lineedit editing. Port xconfig to Qt5 - Remove some commented code. Port xconfig to Qt5 - Source format. Port xconfig to Qt5 - Add horizontal scrollbar, and scroll per pixel. Port xconfig to Qt5 - Change ConfigItem constructor parent type. Port xconfig to Qt5 - Disable ConfigList soring Port xconfig to Qt5 - Remove ConfigList::updateMenuList template. Port xconfig to Qt5 - Add ConfigList::mode to initializer list. Port xconfig to Qt5 - Add ConfigItem::nextItem to initializer list. Port xconfig to Qt5 - Tree widget set column titles. ...
2015-11-09Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Nothing exciting, minor tweaks and cleanups" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: scripts: [modpost] add new sections to white list modpost: Add flag -E for making section mismatches fatal params: don't ignore the rest of cmdline if parse_one() fails modpost: abort if a module symbol is too long
2015-11-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - most of the rest of MM - procfs - lib/ updates - printk updates - bitops infrastructure tweaks - checkpatch updates - nilfs2 update - signals - various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc, dma-debug, dma-mapping, ... * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits) ipc,msg: drop dst nil validation in copy_msg include/linux/zutil.h: fix usage example of zlib_adler32() panic: release stale console lock to always get the logbuf printed out dma-debug: check nents in dma_sync_sg* dma-mapping: tidy up dma_parms default handling pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode kexec: use file name as the output message prefix fs, seqfile: always allow oom killer seq_file: reuse string_escape_str() fs/seq_file: use seq_* helpers in seq_hex_dump() coredump: change zap_threads() and zap_process() to use for_each_thread() coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT) signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread() signal: turn dequeue_signal_lock() into kernel_dequeue_signal() signals: kill block_all_signals() and unblock_all_signals() nilfs2: fix gcc uninitialized-variable warnings in powerpc build nilfs2: fix gcc unused-but-set-variable warnings MAINTAINERS: nilfs2: add header file for tracing nilfs2: add tracepoints for analyzing reading and writing metadata files ...
2015-11-06checkpatch: improve the unnecessary initialisers testsJoe Perches
Global and static variables don't need to be initialized to 0. There is already a test for this but the output message doesn't mention booleans initialized to false. Improve the output message and the test by adding various forms with possible specific integer types and possible multiple zeros. Miscellanea: o Use a variable to hold the possible 0 test Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Shailendra Verma <shailendra.v@samsung.com> Tested-by: Shailendra Verma <shailendra.v@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06checkpatch: improve tests for fixes:, long lines and stack dumps in commit logJoe Perches
Including BUG and stack dumps in commit logs makes checkpatch produce some false positive warning messages. checkpatch has multiple types of false positives: o Commit message lines > 75 chars o Stack dump address are mistaken for git commit IDs o Link: and Fixes: lines are allowed to be > 75 chars. o Fixes: style doesn't require ("<commit_description>") parentheses and double quotes like other uses of git commit ID and description. Fix these. Miscellanea: o Move the test for checking $commit_log_possible_stack_dump above the test for a long line commit message o Add test for hex address surrounded by square or angle brackets Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06get_maintainer: add subsystem to reviewer outputJoe Perches
Reviewer output currently does not include the subsystem that matched. Add it. Miscellanea: o Add a get_subsystem_name routine to centralize this Signed-off-by: Joe Perches <joe@perches.com> Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Lee Jones <lee.jones@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06get_maintainer: --r (list reviewer) is on by defaultBrian Norris
We don't consistenly document the default value next to the option listing, but we do have a list of defaults here, so let's keep it up to date. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06get_maintainer: add --no-foo options to --helpBrian Norris
Many flag options are boolean and support both a positive and a negative invocation from the command line. Some of these are even mentioned by example (e.g., --nogit is mentioned as a default option), but they aren't explicitly mentioned in the list of options. It happens that some of these are pretty important, as they are default-on, and to turn them off, you have to know about the --no-foo version. Rather than clutter the whole help text with bracketed '--[no]foo', let's just mention the general rule, a la 'man gcc'. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06get_maintainer: it's '--pattern-depth', not '-pattern-depth'Brian Norris
Though it appears that Perl's GetOptions will take either, the latter is not documented in the options listing. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06get_maintainer: add missing documentation for --git-blame-signaturesBrian Norris
I really haven't used this option much myself, so feel free to improve on the documentation for it. I just noticed it while inspecting this script for undocumented features. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06Merge tag 'trace-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracking updates from Steven Rostedt: "Most of the changes are clean ups and small fixes. Some of them have stable tags to them. I searched through my INBOX just as the merge window opened and found lots of patches to pull. I ran them through all my tests and they were in linux-next for a few days. Features added this release: ---------------------------- - Module globbing. You can now filter function tracing to several modules. # echo '*:mod:*snd*' > set_ftrace_filter (Dmitry Safonov) - Tracer specific options are now visible even when the tracer is not active. It was rather annoying that you can only see and modify tracer options after enabling the tracer. Now they are in the options/ directory even when the tracer is not active. Although they are still only visible when the tracer is active in the trace_options file. - Trace options are now per instance (although some of the tracer specific options are global) - New tracefs file: set_event_pid. If any pid is added to this file, then all events in the instance will filter out events that are not part of this pid. sched_switch and sched_wakeup events handle next and the wakee pids" * tag 'trace-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (68 commits) tracefs: Fix refcount imbalance in start_creating() tracing: Put back comma for empty fields in boot string parsing tracing: Apply tracer specific options from kernel command line. tracing: Add some documentation about set_event_pid ring_buffer: Remove unneeded smp_wmb() before wakeup of reader benchmark tracing: Allow dumping traces without tracking trace started cpus ring_buffer: Fix more races when terminating the producer in the benchmark ring_buffer: Do no not complete benchmark reader too early tracing: Remove redundant TP_ARGS redefining tracing: Rename max_stack_lock to stack_trace_max_lock tracing: Allow arch-specific stack tracer recordmcount: arm64: Replace the ignored mcount call into nop recordmcount: Fix endianness handling bug for nop_mcount tracepoints: Fix documentation of RCU lockdep checks tracing: ftrace_event_is_function() can return boolean tracing: is_legal_op() can return boolean ring-buffer: rb_event_is_commit() can return boolean ring-buffer: rb_per_cpu_empty() can return boolean ring_buffer: ring_buffer_empty{cpu}() can return boolean ring-buffer: rb_is_reader_page() can return boolean ...
2015-11-06Merge tag 'sound-4.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "Here is the first batch of updates for sound system on 4.4-rc1. Again at this time, the update looks fairly calm; no big changes in either ALSA core or ASoC infrastructures, rather all small cleanups, in addition to the new stuff as usual. The biggest changes are about Firewire sound devices. It gained lots of new device support, and MIDI functionality. Also there are updates for a few still working-in-progress stuff (topology API and ASoC skylake), too. But overall, this update should give no big surprise. Some highlights are below: Core: - A few more Kconfig items for tinification; it's marked as EXPERT, so normal user should't be bothered :) - Refactoring with a new PCM hw_constraint helper - Removal of unused transfer_ack_{begin,end} PCM callbacks Firewire: - Restructuring of code subtree, lots of refactoring - Support AMDTP variants - New driver for Digidesign 002/003 family - Adds support for TASCAM FireOne to ALSA OXFW driver - Add MIDI support to TASCAM and Digi00x devices HD-Audio: - Automated modalias generation for codec drivers, finally - Improvement on heuristics for setting mixer name - A few fixes for longstanding bugs on Creative CA0132 cards - Addition of audio rate callback with i915 communication - Fix suspend issue on recent Dell XPS - Intel Lewisburg controller support ASoC: - Updates to the topology userspace interface - Big updates to the Renesas support (rcar) - More updates for supporting Intel Sky Lake systems - New drivers for Asahi Kasei Microdevices AK4613, Allwinnner A10, Cirrus Logic WM8998, Dialog DA7219, Nuvoton NAU8825, Rockchip S/PDIF, and Atmel class D amplifier USB-Audio: - A fix for newer Roland MIDI devices - Quirks and workarounds for Zoom R16/24 device Misc: - A few fixes for some old Cirrus CS46xx PCI sound boards - Yet another fixes for some old ESS Maestro3 PCI sound boards" * tag 'sound-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (330 commits) ALSA: hda - Add Intel Lewisburg device IDs Audio ALSA: hda - Apply pin fixup for HP ProBook 6550b ALSA: hda - Fix lost 4k BDL boundary workaround ALSA: maestro3: Fix Allegro mute until master volume/mute is touched ALSA: maestro3: Enable docking support for Dell Latitude C810 ALSA: firewire-digi00x: add another rawmidi character device for MIDI control ports ALSA: firewire-digi00x: add MIDI operations for MIDI control port ALSA: firewire-digi00x: rename identifiers of MIDI operation for physical ports ALSA: cs46xx: Fix suspend for all channels ALSA: cs46xx: Fix Duplicate front for CS4294 and CS4298 codecs ALSA: DocBook: Add soc-ops.c and soc-compress.c ALSA: hda - Add / fix kernel doc comments ALSA: Constify ratden/ratnum constraints ALSA: hda - Disable 64bit address for Creative HDA controllers ALSA: hda/realtek - Dell XPS one ALC3260 speaker no sound after resume back ALSA: hda/ca0132 - Convert leftover pr_info() and pr_err() ASoC: fsl: Use #ifdef instead of #if for CONFIG_PM_SLEEP ASoC: rt5645: Sort the order for register bit defines ASoC: dwc: add check for master/slave format ASoC: rt5645: Add the HWEQ for the speaker output ...
2015-11-05Merge tag 'powerpc-4.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: - Kconfig: remove BE-only platforms from LE kernel build from Boqun Feng - Refresh ps3_defconfig from Geoff Levand - Emit GNU & SysV hashes for the vdso from Michael Ellerman - Define an enum for the bolted SLB indexes from Anshuman Khandual - Use a local to avoid multiple calls to get_slb_shadow() from Michael Ellerman - Add gettimeofday() benchmark from Michael Neuling - Avoid link stack corruption in __get_datapage() from Michael Neuling - Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar K.V - Add ppc64le_defconfig from Michael Ellerman - pseries: extract of_helpers module from Andy Shevchenko - Correct string length in pseries_of_derive_parent() from Nathan Fontenot - Free the MSI bitmap if it was slab allocated from Denis Kirjanov - Shorten irq_chip name for the SIU from Christophe Leroy - Wait 1s for secondaries to enter OPAL during kexec from Samuel Mendoza-Jonas - Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V - powerpc/pseries/hvcserver: don't memset pi_buff if it is null from Colin Ian King - Disable hugepd for 64K page size, from Aneesh Kumar K.V - Differentiate between hugetlb and THP during page walk from Aneesh Kumar K.V - Make PCI non-optional for pseries from Michael Ellerman - Individual System V IPC system calls from Sam bobroff - Add selftest of unmuxed IPC calls from Michael Ellerman - discard .exit.data at runtime from Stephen Rothwell - Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul Gortmaker - Use of_get_next_parent to simplify code from Christophe Jaillet - Paginate some xmon output from Sam bobroff - Add some more elements to the xmon PACA dump from Michael Ellerman - Allow the tm-syscall selftest to build with old headers from Michael Ellerman - Run EBB selftests only on POWER8 from Denis Kirjanov - Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael Ellerman - Avoid reference to potentially freed memory in prom.c from Christophe Jaillet - Quieten boot wrapper output with run_cmd from Geoff Levand - EEH fixes and cleanups from Gavin Shan - Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan - Use of_get_next_parent() in of_get_ibm_chip_id() from Michael Ellerman - Fix section mismatch warning in msi_bitmap_alloc() from Denis Kirjanov - Fix ps3-lpm white space from Rudhresh Kumar J - Fix ps3-vuart null dereference from Colin King - nvram: Add missing kfree in error path from Christophe Jaillet - nvram: Fix function name in some errors messages, from Christophe Jaillet - drivers/macintosh: adb: fix misleading Kconfig help text from Aaro Koskinen - agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov - cxl: Free virtual PHB when removing from Andrew Donnellan - scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from Michael Ellerman - scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building with O= from Michael Ellerman - Freescale updates from Scott: Highlights include 64-bit book3e kexec/kdump support, a rework of the qoriq clock driver, device tree changes including qoriq fman nodes, support for a new 85xx board, and some fixes. - MPC5xxx updates from Anatolij: Highlights include a driver for MPC512x LocalPlus Bus FIFO with its device tree binding documentation, mpc512x device tree updates and some minor fixes. * tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits) powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc() powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id() powerpc/pseries: Correct string length in pseries_of_derive_parent() powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s) powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes powerpc: handle error case in cpm_muram_alloc() powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake powerpc/book3e-64: Enable kexec powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32 powerpc/book3e-64/kexec: Enable SMP release powerpc/book3e-64/kexec: create an identity TLB mapping powerpc/book3e-64: Don't limit paca to 256 MiB powerpc/book3e/kdump: Enable crash_kexec_wait_realmode powerpc/book3e: support CONFIG_RELOCATABLE powerpc/booke64: Fix args to copy_and_flush powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts powerpc/e6500: kexec: Handle hardware threads ...
2015-11-05Merge tag 'docs-for-linus' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation update from Jon Corbet: "There is a nice new document from Neil on how pathname lookups work and some new CAN driver documentation. Beyond that, we have kernel-doc fixes, a bit more work to support reproducible builds, and the usual collection of small fixes" * tag 'docs-for-linus' of git://git.lwn.net/linux: (34 commits) Documentation: add new description of path-name lookup. Documentation/vm/slub.txt: document slabinfo-gnuplot.sh Doc: ABI/stable: Fix typo in ABI/stable doc: Clarify that nmi_watchdog param is for hardlockups Typo correction for description in gpio document. DocBook: Fix kernel-doc to be case-insensitive for private: kernel-docs.txt: update kernelnewbies reference Doc:kvm: Fix typo in Doc/virtual/kvm Documentation/Changes: Add bc in "Current Minimal Requirements" section Documentation/email-clients.txt: remove trailing whitespace DocBook: Use a fixed encoding for output MAINTAINERS: The docs tree has moved Docs/kernel-parameters: Add earlycon devicetree usage SubmittingPatches: make Subject examples match the de facto standard Documentation: gpio: mention that <function>-gpio has been deprecated Documentation: cgroups: just fix a few typos Documentation: Update kselftest.txt Documentation: DMA API: Be more explicit that nents is always the same Documentation: Update the default value of crashkernel low zram: update documentation ...
2015-11-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem update from James Morris: "This is mostly maintenance updates across the subsystem, with a notable update for TPM 2.0, and addition of Jarkko Sakkinen as a maintainer of that" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (40 commits) apparmor: clarify CRYPTO dependency selinux: Use a kmem_cache for allocation struct file_security_struct selinux: ioctl_has_perm should be static selinux: use sprintf return value selinux: use kstrdup() in security_get_bools() selinux: use kmemdup in security_sid_to_context_core() selinux: remove pointless cast in selinux_inode_setsecurity() selinux: introduce security_context_str_to_sid selinux: do not check open perm on ftruncate call selinux: change CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE default KEYS: Merge the type-specific data with the payload data KEYS: Provide a script to extract a module signature KEYS: Provide a script to extract the sys cert list from a vmlinux file keys: Be more consistent in selection of union members used certs: add .gitignore to stop git nagging about x509_certificate_list KEYS: use kvfree() in add_key Smack: limited capability for changing process label TPM: remove unnecessary little endian conversion vTPM: support little endian guests char: Drop owner assignment from i2c_driver ...
2015-11-05Merge tag 'media/v4.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "Media updates, including: - Lots of improvements at the kABI documentation - Split of Videobuf2 into a common part and a V4L2 specific one - Split of the VB2 tracing events into a separate header file - s5p-mfc got support for Exynos 5433 - v4l2 fixes for 64-bits alignment when running 32 bits userspace on ARM - Added support for SDR radio transmitter at core, vivid and hackrf drivers - Some y2038 fixups - Some improvements at V4L2 colorspace support - saa7164 converted to use the V4L2 core control framework - several new boards additions, cleanups and fixups PS: There are two patches for scripts/kernel-doc that are needed by the documentation patches on Media. Jon is OK on merging those via my tree" * tag 'media/v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (146 commits) [media] c8sectpfe: Remove select on CONFIG_FW_LOADER_USER_HELPER_FALLBACK [media] DocBook media: update copyright/version numbers [media] ivtv: Convert to get_user_pages_unlocked() [media] media/v4l2-ctrls: fix setting autocluster to manual with VIDIOC_S_CTRL [media] DocBook media: Fix a typo in encoder cmd [media] DocBook: add SDR specific info to G_MODULATOR / S_MODULATOR [media] DocBook: add SDR specific info to G_TUNER / S_TUNER [media] hackrf: do not set human readable name for formats [media] hackrf: add support for transmitter [media] hackrf: switch to single function which configures everything [media] hackrf: add control for RF amplifier [media] DocBook: add modulator type field [media] v4l: add type field to v4l2_modulator struct [media] DocBook: document SDR transmitter [media] v4l2: add support for SDR transmitter [media] DocBook: document tuner RF gain control [media] v4l2: add RF gain control [media] v4l2: rename V4L2_TUNER_ADC to V4L2_TUNER_SDR [media] media/vivid-osd: fix info leak in ioctl [media] media: videobuf2: Move v4l2-specific stuff to videobuf2-v4l2 ...
2015-11-04Merge tag 'char-misc-4.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big char/misc driver update for 4.4-rc1. Lots of different driver and subsystem updates, hwtracing being the largest with the addition of some new platforms that are now supported. Full details in the shortlog. All of these have been in linux-next for a long time with no reported issues" * tag 'char-misc-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (181 commits) fpga: socfpga: Fix check of return value of devm_request_irq lkdtm: fix ACCESS_USERSPACE test mcb: Destroy IDA on module unload mcb: Do not return zero on error path in mcb_pci_probe() mei: bus: set the device name before running fixup mei: bus: use correct lock ordering mei: Fix debugfs filename in error output char: ipmi: ipmi_ssif: Replace timeval with timespec64 fpga: zynq-fpga: Fix issue with drvdata being overwritten. fpga manager: remove unnecessary null pointer checks fpga manager: ensure lifetime with of_fpga_mgr_get fpga: zynq-fpga: Change fw format to handle bin instead of bit. fpga: zynq-fpga: Fix unbalanced clock handling misc: sram: partition base address belongs to __iomem space coresight: etm3x: adding documentation for sysFS's cpu interface vme: 8-bit status/id takes 256 values, not 255 fpga manager: Adding FPGA Manager support for Xilinx Zynq 7000 ARM: zynq: dt: Updated devicetree for Zynq 7000 platform. ARM: dt: fpga: Added binding docs for Xilinx Zynq FPGA manager. ver_linux: proc/modules, limit text processing to 'sed' ...
2015-11-04Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Catalin Marinas: - "genirq: Introduce generic irq migration for cpu hotunplugged" patch merged from tip/irq/for-arm to allow the arm64-specific part to be upstreamed via the arm64 tree - CPU feature detection reworked to cope with heterogeneous systems where CPUs may not have exactly the same features. The features reported by the kernel via internal data structures or ELF_HWCAP are delayed until all the CPUs are up (and before user space starts) - Support for 16KB pages, with the additional bonus of a 36-bit VA space, though the latter only depending on EXPERT - Implement native {relaxed, acquire, release} atomics for arm64 - New ASID allocation algorithm which avoids IPI on roll-over, together with TLB invalidation optimisations (using local vs global where feasible) - KASan support for arm64 - EFI_STUB clean-up and isolation for the kernel proper (required by KASan) - copy_{to,from,in}_user optimisations (sharing the memcpy template) - perf: moving arm64 to the arm32/64 shared PMU framework - L1_CACHE_BYTES increased to 128 to accommodate Cavium hardware - Support for the contiguous PTE hint on kernel mapping (16 consecutive entries may be able to use a single TLB entry) - Generic CONFIG_HZ now used on arm64 - defconfig updates * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (91 commits) arm64/efi: fix libstub build under CONFIG_MODVERSIONS ARM64: Enable multi-core scheduler support by default arm64/efi: move arm64 specific stub C code to libstub arm64: page-align sections for DEBUG_RODATA arm64: Fix build with CONFIG_ZONE_DMA=n arm64: Fix compat register mappings arm64: Increase the max granular size arm64: remove bogus TASK_SIZE_64 check arm64: make Timer Interrupt Frequency selectable arm64/mm: use PAGE_ALIGNED instead of IS_ALIGNED arm64: cachetype: fix definitions of ICACHEF_* flags arm64: cpufeature: declare enable_cpu_capabilities as static genirq: Make the cpuhotplug migration code less noisy arm64: Constify hwcap name string arrays arm64/kvm: Make use of the system wide safe values arm64/debug: Make use of the system wide safe value arm64: Move FP/ASIMD hwcap handling to common code arm64/HWCAP: Use system wide safe values arm64/capabilities: Make use of system wide safe value arm64: Delay cpu feature capability checks ...
2015-11-03recordmcount: arm64: Replace the ignored mcount call into nopLi Bin
By now, the recordmcount only records the function that in following sections: .text/.ref.text/.sched.text/.spinlock.text/.irqentry.text/ .kprobes.text/.text.unlikely For the function that not in these sections, the call mcount will be in place and not be replaced when kernel boot up. And it will bring performance overhead, such as do_mem_abort (in .exception.text section). This patch make the call mcount to nop for this case in recordmcount. Link: http://lkml.kernel.org/r/1446019445-14421-1-git-send-email-huawei.libin@huawei.com Link: http://lkml.kernel.org/r/1446193864-24593-4-git-send-email-huawei.libin@huawei.com Cc: <lkp@intel.com> Cc: <catalin.marinas@arm.com> Cc: <takahiro.akashi@linaro.org> Cc: <stable@vger.kernel.org> # 3.18+ Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-03recordmcount: Fix endianness handling bug for nop_mcountlibin
In nop_mcount, shdr->sh_offset and welp->r_offset should handle endianness properly, otherwise it will trigger Segmentation fault if the recordmcount main and file.o have different endianness. Link: http://lkml.kernel.org/r/563806C7.7070606@huawei.com Cc: <stable@vger.kernel.org> # 3.0+ Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-02Add current selection check.Boris Barbulovski
Signed-off-by: Boris Barbulovski <bbarbulovski@gmail.com> Signed-off-by: Thiago Macieira <thiago.macieira@intel.com> [mmarek: I missed it in the original Qt5 patch set, which caused a crash] Signed-off-by: Michal Marek <mmarek@suse.com>
2015-11-02Use pkg-config to find Qt 4 and 5 instead of direct qmakeThiago Macieira
The Qt Project recommendation is that there should always be a "qmake" binary and it should never be renamed. If it's necessary to handle multiple Qt versions, the Qt Project recommends using qtchooser. Unfortunately, some distros do not follow the recommendation, so we would need to check qmake-qt4, qmake-qt5, etc. So, instead, let's try pkg-config. Signed-off-by: Thiago Macieira <thiago.macieira@intel.com> Reported-by: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com> Signed-off-by: Michal Marek <mmarek@suse.com>
2015-11-02recordmcount: x86: Assign a meaningful value to rel_type_nopLi Bin
Although, the default value of rel_type_nop is zero, and the value of R_386_NONE/R_X86_64_NONE is zero too, but it should be assigned a meaningful value explicitly, otherwise it looks confused. Assign R_386_NONE to rel_type_nop for 386, assign R_X86_64_NONE to rel_type_nop for x86_64. Link: http://lkml.kernel.org/r/1446020606-16352-1-git-send-email-huawei.libin@huawei.com Signed-off-by: Li Bin <huawei.libin@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-10-26coccinelle: Improve checking for missing NULL terminatorsDaniel Granat
Extend checking on tables containing structures which are initialized without specifying member name. Added new tables for checking: i2c_device_id and platform_device_id. Signed-off-by: Daniel Granat <d.granat@samsung.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-10-26coccinelle: ifnullfree: handle various destroy functionsJulia Lawall
Extend ifnullfree to the various destroy functions that were recently extended to tolerate NULL arguments. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-10-26coccinelle: ifnullfree: various cleanupsJulia Lawall
Adjust tests to compare against NULL, to match cases that explicitly make that comparison. Remove removal and re-addition of freeing functions. Add position variable on usb_free_urb in the non-patch case. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-10-26cocinelle: iterators: semantic patch to delete unneeded of_node_putJulia Lawall
Device node iterators perform an of_node_put on each iteration, so putting an of_node_put before a continue results in a double put. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-10-26deb-pkg: Add automatic support for armhf architectureBen Hutchings
The Debian armhf architecture uses the ARM EABI hard-float variant, whereas armel uses the soft-float variant. Although the kernel doesn't use FP itself, CONFIG_VFP must be enabled to support hard-float userland and will probably be disabled when supporting a soft-float userland. So set the architecture to armhf by default when CONFIG_AEABI and CONFIG_VFP are both enabled. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Fathi Boudra <fathi.boudra@linaro.org> Reviewed-by: Riku Voipio <riku.voipio@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
