commit c84da8b9ad3761eef43811181c7e896e9834b26b upstream.
In nop_mcount, shdr->sh_offset and welp->r_offset should handle
endianness properly, otherwise it will trigger Segmentation fault
if the recordmcount main and file.o have different endianness.
Link: http://lkml.kernel.org/r/563806C7.7070606@huawei.com
Signed-off-by: Li Bin <huawei.libin@huawei.com>
commit c0ddc8c745b7f89c50385fd7aa03c78dc543fa7a upstream.
In kbuild it is allowed to define objects in files named "Makefile"
and "Kbuild".
Currently localmodconfig reads objects only from "Makefile"s and misses
modules like nouveau.
Link: http://lkml.kernel.org/r/1437948415-16290-1-git-send-email-richard@nod.at
Reported-and-tested-by: Leonidas Spyropoulos <artafinde@gmail.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 1caf6aaaa47471831d77c75f094d4e00ad1ec808 upstream.
Compiling SH with gcc-4.8 fails due to the -m32 option not being
supported.
From http://buildd.debian-ports.org/status/fetch.php?pkg=linux&arch=sh4&ver=3.16.7-ckt4-1&stamp=1421425783
CC init/main.o
gcc-4.8: error: unrecognized command line option '-m32'
ld: cannot find init/.tmp_mc_main.o: No such file or directory
objcopy: 'init/.tmp_mx_main.o': No such file
rm: cannot remove 'init/.tmp_mx_main.o': No such file or directory
rm: cannot remove 'init/.tmp_mc_main.o': No such file or directory
Link: http://lkml.kernel.org/r/1421537778-29001-1-git-send-email-kernel@mkarcher.dialup.fu-berlin.de
Link: http://lkml.kernel.org/r/54BCBDD4.10102@physik.fu-berlin.de
Cc: Matt Fleming <matt@console-pimps.org>
Reported-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de>
Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de>
commit 91ad11d7cc6f4472ebf177a6252fbf0fd100d798 upstream.
On MIPS calls to _mcount in modules generate 2 instructions to load
the _mcount address (and therefore 2 relocations). The mcount_loc
table should only reference the first of these, so the second is
filtered out by checking the relocation offset and ignoring ones that
immediately follow the previous one seen.
However if a module has an _mcount call at offset 0, the second
relocation would not be filtered out due to old_r_offset == 0
being taken to mean that the current relocation is the first one
seen, and both would end up in the mcount_loc table.
This results in ftrace_make_nop() patching both (adjacent)
instructions to branches over the _mcount call sequence like so:
0xffffffffc08a8000: 04 00 00 10 b 0xffffffffc08a8014
0xffffffffc08a8004: 04 00 00 10 b 0xffffffffc08a8018
0xffffffffc08a8008: 2d 08 e0 03 move at,ra
The second branch is in the delay slot of the first, which is
defined to be unpredictable - on the platform on which this bug was
encountered, it triggers a reserved instruction exception.
Fix by initializing old_r_offset to ~0 and using that instead of 0
to determine whether the current relocation is the first seen.
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7098/
commit 8fe9c93e7453e67b8bd09f263ec1bb0783c733fc upstream.
GCC 4.8 now generates out-of-line vr save/restore functions when
optimizing for size. They are needed for the raid6 altivec support.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit f8ce239dfc7ba9add41d9ecdc5e7810738f839fa upstream.
builddeb generates a control file that says the linux-headers package
can only be built for the build system primary architecture. This
breaks cross-building configurations. We should use $debarch for this
instead.
Since $debarch is not yet set when generating the control file, set
Architecture: any and use control file variables to fill in the
description.
Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg')
Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com>
commit c5e318f67eebbad491615a752c51dbfde7dc3d78 upstream.
These commands will mysteriously fail:
$ make ARCH=arm versatile_defconfig
$ make ARCH=arm deb-pkg
make[1]: *** [deb-pkg] Error 1
make: *** [deb-pkg] Error 2
The Debian architecture selection for these kernel architectures does
'grep FOO=y $KCONFIG_CONFIG && echo bar', and after 'set -e' this
aborts the script if grep does not find the given config symbol.
Fixes: 10f26fa64200 ('build, deb-pkg: select userland architecture based on UTS_MACHINE')
commit d20917670ee1fd4b090555e551faea04b014ca97 upstream.
Signed-off-by: Anisse Astier <anisse@astier.eu>
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
[bwh: Backported to 3.2: adjust context]
commit 03b56329f9bb5a1cb73d7dc659d529a9a9bf3acc upstream.
Commit afe2dab4f6 ("USB: add hex/bcd detection to usb modalias generation")
changed the routine that generates alias ranges. Before that change, only
digits 0-9 were supported; the commit tried to fix the case when the range
includes higher values than 0x9.
Unfortunately, the commit didn't fix the case when the range includes both
0x9 and 0xA, meaning that the final range must look like [x-9A-y] where
x <= 0x9 and y >= 0xA -- instead the [x-9A-x] range was produced.
Modprobe doesn't complain as it sees no difference between no-match and
bad-pattern results of fnmatch().
Fixing this simple bug to fix the aliases.
Also changing the hardcoded beginning of the range to uppercase as all the
other letters are also uppercase in the device version numbers.
Fortunately, this affects only the dvb-usb-dib0700 module, AFAIK.
Signed-off-by: Jan Moskyto Matejka <mq@suse.cz>
commit 654784284430bf2739985914b65e09c7c35a7273 upstream.
Prior to this patch the following code breaks:
* multiline_example - this breaks kernel-doc
#define multiline_example( \
myparam)
Producing this error:
Error(somefile.h:983): cannot understand prototype: 'multiline_example( \ '
This patch fixes the issue by appending all lines ending in a blackslash
(optionally followed by whitespace), removing the backslash and any
whitespace after it prior to appending (just like the C pre-processor
would).
This fixes a break in kerel-doc introduced by the additions to rbtree.h.
Signed-off-by: Daniel Santos <daniel.santos@pobox.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michal Marek <mmarek@suse.cz>
commit c353acba28fb3fa1fd05fd6b85a9fc7938330f9c upstream.
The call if_changed mechanism does not work when the command contains
backslashes. This basically is an issue with lzo and bzip2 compressed
kernels. The compressed binaries do not contain the uncompressed image
size, so these use size_append to append the size. This results in
backslashes in the executed command. With this if_changed always
detects a change in the command and rebuilds the compressed image even
if nothing has changed.
Fix this by escaping backslashes in make-cmd
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: Bernhard Walle <bernhard@bwalle.de>
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream.
The correct syntax for gcc -x is "gcc -x assembler", not
"gcc -xassembler". Even though the latter happens to work, the former
is what is documented in the manual page and thus what gcc wrappers
such as icecream do expect.
This isn't a cosmetic change. The missing space prevents icecream from
recognizing compilation tasks it can't handle, leading to silent kernel
miscompilations.
Besides me, credits go to Michael Matz and Dirk Mueller for
investigating the miscompilation issue and tracking it down to this
incorrect -x parameter syntax.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
[bwh: Backported to 3.2: drop unneeded change to arch/x86/Makefile]
commit 875de98623fa2b29f0cb19915fe3292ab6daa1cb upstream.
"echo -e" is a GNU extension. When cross-compiling the kernel on a
BSD-like operating system (Mac OS X in my case), this doesn't work.
One could install a GNU version of echo, put that in the $PATH before
the system echo and use "/usr/bin/env echo", but the solution with
printf is simpler.
Since it is no disadvantage on Linux, I hope that gets accepted even if
cross-compiling the Linux kernel on another Unix operating system is
quite a rare use case.
Signed-off-by: Bernhard Walle <bernhard@bwalle.de>
Andreas Bießmann <andreas@biessmann.de>
commit 4eae518d4b01b0cbf2f0d8edb5a6f3d6245ee8fb upstream.
The kbuild target 'localyesconfig' has been same as 'localmodconfig'
since the commit 50bce3e "kconfig/streamline_config.pl: merge
local{mod,yes}config". The commit expects this script generates
different configure depending on target, but it was not yet implemented.
So I added code that sets to 'yes' when target is 'localyesconfig'.
Link: http://lkml.kernel.org/r/1349101470-12243-1-git-send-email-yuta.and@gmail.com
Cc: linux-kbuild@vger.kernel.org
Signed-off-by: Yuta Ando <yuta.and@gmail.com>
Signed-off-by: Steven Rostedt <rostedt@rostedt.homelinux.com>
commit fe04ddf7c2910362f3817c8156e41cbd6c0ee35d upstream.
There were reports of users destroying their Fedora installs by a kernel
tarball that replaces the /lib -> /usr/lib symlink. Let's remove the
toplevel directories from the tarball to prevent this from happening.
Reported-by: Andi Kleen <andi@firstfloor.org>
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
[bwh: Fold in commit 3ce9e53e788881da0d5f3912f80e0dd6b501f304 to avoid
conflicts]
commit 620c231c7a7f48745094727bb612f6321cfc8844 upstream.
scripts/depmod.sh checks for the output of '-V' expecting that it has
module-init-tools in it. It's a hack to prevent users from using
modutils instead of module-init-tools, that only works with 2.4.x
kernels. This however prints an annoying warning for kmod tool, that is
currently replacing module-init-tools.
Rather than putting another check for kmod's version, just remove it
since users of 2.4.x kernel are unlikely to upgrade to 3.x, and if they
do, let depmod fail in that case because they should know what they are
doing.
Acked-by: WANG Cong <amwang@redhat.com>
Acked-By: Kay Sievers <kay.sievers@vrfy.org>
commit 6520fe5564acf07ade7b18a1272db1184835c487 upstream.
A new option is added to the relocs tool called '--realmode'.
This option causes the generation of 16-bit segment relocations
and 32-bit linear relocations for the real-mode code. When
the real-mode code is moved to the low-memory during kernel
initialization, these relocation entries can be used to
relocate the code properly.
In the assembly code 16-bit segment relocations must be relative
to the 'real_mode_seg' absolute symbol. Linear relocations must be
relative to a symbol prefixed with 'pa_'.
16-bit segment relocation is used to load cs:ip in 16-bit code.
Linear relocations are used in the 32-bit code for relocatable
data references. They are declared in the linker script of the
real-mode code.
The relocs tool is moved to arch/x86/tools/relocs.c, and added new
target archscripts that can be used to build scripts needed building
an architecture. be compiled before building the arch/x86 tree.
[ hpa: accelerating this because it detects invalid absolute
relocations, a serious bug in binutils 2.22.52.0.x which currently
produces bad kernels. ]
Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com>
Cc: <stable@vger.kernel.org>
- Adjust context (no archheaders; no insn_sanity)
- Expand put_unaligned_le32()]
commit e88aa7bbbe3046a125ea1936b16bb921cc9c6349 upstream.
The symbol table on x86-64 starts to have entries that have names
like:
_GLOBAL__sub_I_65535_0___mod_x86cpu_device_table
They are of type STT_FUNCTION and this one had a length of 18. This
matched the device ID validation logic and it barfed because the
length did not meet the device type's criteria.
FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18.
Fix definition of struct x86cpu_device_id in mod_devicetable.h
These are some kind of compiler tool internal stuff being emitted and
not something we want to inspect in modpost's device ID table
validation code.
So skip the symbol if it is not of type STT_OBJECT.
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 258f742635360175564e9470eb060ff4d4b984e7 upstream.
Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols
placing each of them in its own elf section. This sorting and merging
into the canonical sections are done by the linker.
Unfortunately modpost to generate Module.symvers file parses vmlinux.o
(which is not linked yet) and all modules object files (which aren't
linked yet). These aren't sanitized by the linker yet. That breaks
modpost that can't detect license properly for modules.
This patch makes modpost aware of the new exported symbols structure.
[ This above is a slightly corrected version of the explanation of the
problem, copied from commit 62a2635610db ("modpost: Fix modpost's
license checking V3"). That commit fixed the problem for module
object files, but not for vmlinux.o. This patch fixes modpost for
vmlinux.o. ]
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
commit 9aaf440f8fabcebf9ea79a62ccf4c212e6544b49 upstream.
This was lacking a comma between two supposed to be separate strings.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 6c635224602d760c1208ada337562f40d8ae93a5 upstream.
The current use of /tmp for file lists is insecure. Put them under
$objtree/debian instead.
Acked-by: maximilian attems <max@stro.at>
commit 2e885057b7f75035f0b85e02f737891482815a81 upstream.
In ELF64, the sh_flags field is 64-bits wide. recordmcount was
erroneously treating it as a 32-bit wide field. For little endian
objects this works because the flags of interest (SHF_EXECINSTR)
reside in the lower 32 bits of the word, and you get the same result
with either a 32-bit or 64-bit read. Big endian objects on the
other hand do not work at all with this error.
The fix: Correctly treat sh_flags as 64-bits wide in elf64 objects.
The symptom I observed was that my
__start_mcount_loc..__stop_mcount_loc was empty even though ftrace
function tracing was enabled.
Link: http://lkml.kernel.org/r/1324345362-12230-1-git-send-email-ddaney.cavm@gmail.com
Signed-off-by: David Daney <david.daney@cavium.com>
commit 364212fddaaa60c5a64f67a0f5624ad996ecc8a0 upstream.
Thomas Lange reported that when he did a 'make localmodconfig', his
config was missing the brcmsmac driver, even though he had the module
loaded.
Looking into this, I found the file:
drivers/net/wireless/brcm80211/brcmsmac/Makefile
had the following in the Makefile:
MODULEPFX := brcmsmac
obj-$(CONFIG_BRCMSMAC) += $(MODULEPFX).o
The way streamline-config.pl works, is parsing all the
obj-$(CONFIG_FOO) += foo.o
lines to find that CONFIG_FOO belongs to the module foo.ko.
But in this case, the brcmsmac.o was not used, but a variable in its place.
By changing streamline-config.pl to remember defined variables in Makefiles
and substituting them when they are used in the obj-X lines, allows
Thomas (and others) to have their brcmsmac module stay configured
when it is loaded and running "make localmodconfig".
Reported-by: Thomas Lange <thomas-lange2@gmx.de>
Tested-by: Thomas Lange <thomas-lange2@gmx.de>
Cc: Arend van Spriel <arend@broadcom.com>
commit d060d963e88f3e990cec2fe5214de49de9a49eca upstream.
Simplify the way lines ending with backslashes (continuation) in Makefiles
is parsed. This is needed to implement a necessary fix.
Commit 5c48b108 ("um: take arch/um/sys-x86 to arch/x86/um") broke the
make target update-po-config, as its symlink trick (again) fails.
(Previous breakage was fixed with commit bdc69ca4 ("kconfig: change
update-po-config to reflect new layout of arch/um").)
The new UML layout allows to drop the symlick trick entirely. And if,
one day, another architecture supports UML too, that should now work
without again breaking this make target.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
script/checkpatch.pl: warn about deprecated use of EXTRA_{A,C,CPP,LD}FLAGS
tags, powerpc: Update tags.sh to support _GLOBAL symbols
scripts: add extract-vmlinux
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/kconfig/nconf: add KEY_HOME / KEY_END for dialog_inputbox
scripts/kconfig/nconf: fix editing long strings
scripts/kconfig/nconf: dynamically alloc dialog_input_result
scripts/kconfig/nconf: fix memmove's length arg
scripts/kconfig/nconf: fix typo: unknow => unknown
kconfig: fix set but not used variables
kconfig: handle SIGINT in menuconfig
kconfig: fix __enabled_ macros definition for invisible and un-selected symbols
kconfig: factor code in menu_get_ext_help()
kbuild: Fix help text not displayed in choice option.
kconfig/nconf: nuke unreferenced `nohelp_text'
kconfig/streamline_config.pl: merge local{mod,yes}config
kconfig/streamline_config.pl: use options to determine operating mode
kconfig/streamline_config.pl: directly access LSMOD from the environment
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: append missing-syscalls to the default target list
genksyms: Regenerate lexer and parser
genksyms: Do not expand internal types
genksyms: Minor parser cleanup
Makefile: remove a duplicated line
fixdep: fix extraneous dependencies
scripts/Makefile.build: do not reference EXTRA_CFLAGS as CFLAGS replacement
kbuild: prevent make from deleting _shipped files
kbuild: Do not delete empty files in make distclean
Use of the GPL or a compatible licence doesn't necessarily make the code
any good. We already consider staging modules to be suspect, and this
should also be true for out-of-tree modules which may receive very
little review.
Reviewed-by: Dave Jones <davej@redhat.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (patched oops-tracing.txt)
Some find using utf-8 in commit logs inappropriate.
Some patch commit logs contain unintended utf-8 characters when doing
things like copy/pasting compilation output.
Look for the start of any commit log by skipping initial lines that look
like email headers and "From: " lines.
Stop looking for utf-8 at the first signature line.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Andy Whitcroft <apw@shadowen.org>
Mark obsolete/deprecated strict_strto<foo> and simple_strto<foo> functions
and macros as obsolete.
Update checkpatch to warn about their use.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits)
staging: et131x: Remove redundant check and return statement
staging: et131x: Mainly whitespace changes to appease checkpatch
staging: et131x: Remove last of the forward declarations
staging: et131x: Remove even more forward declarations
staging: et131x: Remove yet more forward declarations
staging: et131x: Remove more forward declarations
staging: et131x: Remove forward declaration of et131x_adapter_setup
staging: et131x: Remove some forward declarations
staging: et131x: Remove unused rx_ring.recv_packet_pool
staging: et131x: Remove call to find pci pm capability
staging: et131x: Remove redundant et131x_reset_recv() call
staging: et131x: Remove unused rx_ring.recv_buffer_pool
Staging: bcm: Fix three initialization errors in InterfaceDld.c
Staging: bcm: Fix coding style issues in InterfaceDld.c
staging:iio:dac: Add AD5360 driver
staging:iio:trigger:bfin-timer: Fix compile error
Staging: vt6655: add some range checks before memcpy()
Staging: vt6655: whitespace fixes to iotcl.c
Staging: vt6656: add some range checks before memcpy()
Staging: vt6656: whitespace cleanups in ioctl.c
Fix up conflicts in:
- drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}:
vg driver movement
- drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}:
driver removal vs now stale changes
- drivers/staging/rtl8192e/r8192E_core.c:
- drivers/staging/et131x/et131*:
driver consolidation into one file, tried to do fixups
Consider structures, unions and enums defined in the source file as
internal and do not expand them. This way, changes to e.g. struct
serial_private in drivers/tty/serial/8250_pci.c will not affect the
checksum of the pciserial_* exports.
Move the identical logic for recording a struct/union/enum definition to
a function.
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
This is a resend from the original, changing the title from PATCH to
RFC(since this is a review for commit, and I should have put that the first go around).
and also removing some of the commit's with ia64 and bash since it is significant.
let me know if I might have missed anything etc..
to make it easier to locate begin/end when editing long strings;
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Acked By: Nir Tzachar <nir.tzachar@gmail.com>
The original dialog_inputbox doesn't work with longer than prompt_width
strings, here fixed it in this way:
1) add variable cursor_form_win to record cursor of form_win,
keep its value always between [0, prompt_width-1];
reuse the original cursor_position as cursor of the string result,
use (cursor_position-cursor_form_win) as begin offset to show part of
the string in form_win;
Cc: Arnaud Lacombe <lacombar@gmail.com>
Cc: Nir Tzachar <nir.tzachar@gmail.com>
To support unlimited length string config items;
No check for realloc return value keeps code simple, and to be
consistent with other existing unchecked malloc in kconfig.
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
In case KEY_BACKSPACE / KEY_DC to delete a char, it memmove only
(len-cursor_position+1) bytes;
the default case is to insert a char, it should also memmove exactly
the original use of (len+1) is wrong and may access following memory
that doesn't belong to result, may cause SegFault in theory;
case KEY_BACKSPACE:
if (cursor_position > 0) {
memmove(&result[cursor_position-1],
&result[cursor_position],
len-cursor_position+1);
cursor_position--;
break;
case KEY_DC:
if (cursor_position >= 0 && cursor_position < len) {
memmove(&result[cursor_position],
&result[cursor_position+1],
break;
default:
if ((isgraph(res) || isspace(res)) &&
len-2 < result_len) {
/* insert the char at the proper position */
memmove(&result[cursor_position+1],
result[cursor_position] = res;
cursor_position++;
Acked-by: Nir Tzachar <nir.tzachar@gmail.com>
Acked-by: Arnaud Lacombe <lacombar@gmail.com>
The introduction of include/linux/kconfig.h created 3 extraneous
dependencies:
include/config/.h
include/config/h.h
include/config/foo.h
Fix this by excluding kconfig.h from fixdep calculations.
Signed-off-by: Peter Foley <pefoley2@verizon.net>
Usage of these flags has been deprecated for nearly 4 years by:
commit f77bf01425b11947eeb3b5b54685212c302741b8
Author: Sam Ravnborg <sam@neptun.(none)>
Date: Mon Oct 15 22:25:06 2007 +0200
kbuild: introduce ccflags-y, asflags-y and ldflags-y
Moreover, these flags (at least EXTRA_CFLAGS) have been documented for command
line use. By default, gmake(1) do not override command line setting, so this is
likely to result in build failure or unexpected behavior.
Warn about their introduction in Makefile or Kbuild files.
Cc: Andy Whitcroft <apw@canonical.com>
command line use. By default, gmake(1) do not override command line
setting, so this is likely to result in build failure or unexpected
behavior.
Do not advertise for its usage.
commit 7373f4f (kbuild: add implicit rules for parser generation)
created a implicit rule chain (%.c: %.c_shipped: %.y).
Make considers the _shipped files to be intermediate files which
causes them to be deleted if they didn't exist before make was run.
Mark the _shipped files PRECIOUS to prevent make from deleting them.
On PowerPC we use _GLOBAL throughout the assembly to define symbols, but
currently these symbols are missing from the tags generated with
ARCH=powerpc make tags. This patch modifies the tags.sh script to
recognise _GLOBAL(.*) so that these symbols will be in the tags.
This is almost (but not quite) PowerPC specific and this change should
not affect anyone else:
$ git grep -E '^_GLOBAL\(([^)]*)\).*' |sed 's/^\([^/]*\/[^/]*\)\/.*$/\1/'|uniq -c
627 arch/powerpc
2 arch/um
Signed-off-by: Ian Munsie <imunsie@au1.ibm.com>
This script can be used to extract vmlinux from a compressed
kernel image (bzImage, etc..). It's inspired from (a subset of)
extract-ikconfig.
It's something a lot of people have been looking for (mainly
people with xen < 4 that doesn't support bzImages at all).
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
kbuild/kconfig
Some variables were being set but never used, which was triggering
warnings in GCC >= 4.6.
