path: root/scripts
2015-05-28scripts/gdb: fix lx-lsmod refcntAdrien Schildknecht
Commit 2f35c41f58a9 ("module: Replace module_ref with atomic_t refcnt") changes the way refcnt is handled but did not update the gdb script to use the new variable. Since refcnt is not per-cpu anymore, we can directly read its value. Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me> Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com> Cc: Pantelis Koukousoulas <pktoss@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-22Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Quentin opened a can of worms by adding extable entry checking to modpost, but most architectures seem fixed now. Thanks to all involved. Last minute rebase because I noticed a "[PATCH]" had snuck into a commit message somehow" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: don't emit section mismatch warnings for compiler optimizations modpost: expand pattern matching to support substring matches modpost: do not try to match the SHT_NUL section. modpost: fix extable entry size calculation. modpost: fix inverted logic in is_extable_fault_address(). modpost: handle -ffunction-sections modpost: Whitelist .text.fixup and .exception.text params: handle quotes properly for values not of form foo="bar". modpost: document the use of struct section_check. modpost: handle relocations mismatch in __ex_table. scripts: add check_extable.sh script. modpost: mismatch_handler: retrieve tosym information only when needed. modpost: factorize symbol pretty print in get_pretty_name(). modpost: add handler function pointer to sectioncheck. modpost: add .sched.text and .kprobes.text to the TEXT_SECTIONS list. modpost: add strict white-listing when referencing sections. module: do not print allocation-fail warning on bogus user buffer size kernel/module.c: fix typos in message about unused symbols
2015-04-22Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's the usual "low-priority fixes that didn't make it into the last few -rcs, with a twist: We had a fixes pull request that I didn't send in time to get into 4.0, so we'll send some of them to Greg for -stable as well. Contents here is as usual not all that controversial: - a handful of randconfig fixes from Arnd, in particular for older Samsung platforms - Exynos fixes, !SMP building, DTS updates for MMC and lid switch - Kbuild fix to create output subdirectory for DTB files - misc minor fixes for OMAP" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits) ARM: at91/dt: sama5d3 xplained: add phy address for macb1 kbuild: Create directory for target DTB ARM: mvebu: Disable CPU Idle on Armada 38x ARM: DRA7: Enable Cortex A15 errata 798181 ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102 ARM: dts: DRA7: Add bandgap and related thermal nodes bus: ocp2scp: SYNC2 value should be changed to 0x6 ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP ARM: OMAP2+: remove superfluous NULL pointer check ARM: EXYNOS: Fix build breakage cpuidle on !SMP ARM: dts: fix lid and power pin-functions for exynos5250-spring ARM: dts: fix mmc node updates for exynos5250-spring ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688 MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs ARM: cns3xxx: don't export static symbol ARM: S3C24XX: avoid a Kconfig warning ARM: S3C24XX: fix header file inclusions ARM: S3C24XX: fix building without PM_SLEEP ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416 ...
2015-04-22modpost: don't emit section mismatch warnings for compiler optimizationsPaul Gortmaker
Currently an allyesconfig build [gcc-4.9.1] can generate the following: WARNING: vmlinux.o(.text.unlikely+0x3864): Section mismatch in reference from the function cpumask_empty.constprop.3() to the variable .init.data:nmi_ipi_mask which comes from the cpumask_empty usage in arch/x86/kernel/nmi_selftest.c. Normally we would not see a symbol entry for cpumask_empty since it is: static inline bool cpumask_empty(const struct cpumask *srcp) however in this case, the variant of the symbol gets emitted when GCC does constant propagation optimization. Fix things up so that any locally optimized constprop variants don't warn when accessing variables that live in the __init sections. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: expand pattern matching to support substring matchesPaul Gortmaker
Currently the match() function supports a leading * to match any prefix and a trailing * to match any suffix. However there currently is not a combination of both that can be used to target matches of whole families of functions that share a common substring. Here we expand the *foo and foo* match to also support *foo* with the goal of targeting compiler generated symbol names that contain strings like ".constprop." and ".isra." Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: do not try to match the SHT_NUL section.Quentin Casasnovas
Trying to match the SHT_NUL section isn't useful and causes build failures on parisc and mn10300 since the addition of section strict white-listing and __ex_table sanitizing. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Reported-by: Guenter Roeck <linux@roeck-us.net> Fixes: 050e57fd5936 ("modpost: add strict white-listing when referencing....") Fixes: 52dc0595d540 ("modpost: handle relocations mismatch in __ex_table.") Tested-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: fix extable entry size calculation.Quentin Casasnovas
As Guenter pointed out, we were never really calculating the extable entry size because the pointer arithmetic was simply wrong. We want to check we're handling the second relocation in __ex_table to infer an entry size, but we were using (void*) pointers instead of Elf_Rel[a]* ones. This fixes the problem by moving that check in the caller (since we can deal with different types of relocations) and add is_second_extable_reloc() to make the whole thing more readable. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Reported-by: Guenter Roeck <linux@roeck-us.net> CC: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: fix inverted logic in is_extable_fault_address().Quentin Casasnovas
As Guenter pointed out, we want to assert that extable_entry_size has been discovered and not the other way around. Moreover, this sanity check is only valid when we're not dealing with the first relocation in __ex_table, since we have not discovered the extable entry size at that point. This was leading to a divide-by-zero on some architectures and make the build fail. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Reported-by: Guenter Roeck <linux@roeck-us.net> CC: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: handle -ffunction-sectionsRusty Russell
52dc0595d540 introduced OTHER_TEXT_SECTIONS for identifying what sections could validly have __ex_table entries. Unfortunately, it wasn't tested with -ffunction-sections, which some architectures use. Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-22modpost: Whitelist .text.fixup and .exception.textThierry Reding
32-bit and 64-bit ARM use these sections to store executable code, so they must be whitelisted in modpost's table of valid text sections. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-21Merge tag 'char-misc-4.1-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver patchset for 4.1-rc1. Lots of different driver subsystem updates here, nothing major, full details are in the shortlog. All of this has been in linux-next for a while" * tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits) mei: trace: remove unused TRACE_SYSTEM_STRING DTS: ARM: OMAP3-N900: Add lis3lv02d support Documentation: DT: lis302: update wakeup binding lis3lv02d: DT: add wakeup unit 2 and wakeup threshold lis3lv02d: DT: use s32 to support negative values Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case mei: replace check for connection instead of transitioning mei: use mei_cl_is_connected consistently mei: fix mei_poll operation hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg() Drivers: hv: hv_balloon: survive ballooning request with num_pages=0 Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function Drivers: hv: hv_balloon: do not online pages in offline blocks hv: remove the per-channel workqueue hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind() hv: run non-blocking message handlers in the dispatch tasklet coresight: moving to new "hwtracing" directory coresight-tmc: Adding a status interface to sysfs coresight: remove the unnecessary configuration coresight-default-sink ...
2015-04-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates: "This is the remaining part of kbuild stuff for v4.1-rc1: - One wew coccinelle script and a clarification of the proposed fix in bugon.coccinelle - CONFIG_KERNEL_LZ4 support for extract-ikconfig" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warning scripts/extract-ikconfig: Support LZ4-compressed images. irqf_oneshot.cocci: add check of devm_request_threaded_irq()
2015-04-17Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for MIPS for Linux 4.1. Most noteworthy: - Add more Octeon-optimized crypto functions - Octeon crypto preemption and locking fixes - Little endian support for Octeon - Use correct CSR to soft reset Octeons - Support LEDs on the Octeon-based DSR-1000N - Fix PCI interrupt mapping for the Octeon-based DSR-1000N - Mark prom_free_prom_memory() as __init for a number of systems - Support for Imagination's Pistachio SOC. This includes arch and CLK bits. I'd like to merge pinctrl bits later - Improve parallelism of csum_partial for certain pipelines - Organize DTB files in subdirs like other architectures - Implement read_sched_clock for all MIPS platforms other than Octeon - Massive series of 38 fixes and cleanups for the FPU emulator / kernel - Further FPU remulator work to support new features. This sits on a separate branch which also has been pulled into the 4.1 KVM branch - Clean up and fixes for the SEAD3 eval board; remove unused file - Various updates for Netlogic platforms - A number of small updates for Loongson 3 platforms - Increase the memory limit for ATH79 platforms to 256MB - A fair number of fixes and updates for BCM47xx platforms - Finish the implementation of XPA support - MIPS FDC support. No, not floppy controller but Fast Debug Channel :) - Detect the R16000 used in SGI legacy platforms - Fix Kconfig dependencies for the SSB bus support" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits) MIPS: Makefile: Fix MIPS ASE detection code MIPS: asm: elf: Set O32 default FPU flags MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G MIPS: Kconfig: Disable SMP/CPS for 64-bit MIPS: Hibernate: flush TLB entries earlier MIPS: smp-cps: cpu_set FPU mask if FPU present MIPS: lose_fpu(): Disable FPU when MSA enabled MIPS: ralink: add missing symbol for RALINK_ILL_ACC MIPS: ralink: Fix bad config symbol in PCI makefile. SSB: fix Kconfig dependencies MIPS: Malta: Detect and fix bad memsize values Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores." MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard. MIPS: Fix cpu_has_mips_r2_exec_hazard. MIPS: kernel: entry.S: Set correct ISA level for mips_ihb MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter MIPS: unaligned: Fix regular load/store instruction emulation for EVA MIPS: unaligned: Surround load/store macros in do {} while statements ...
2015-04-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patchbomb from Andrew Morton: - various misc things - a couple of lib/ optimisations - provide DIV_ROUND_CLOSEST_ULL() - checkpatch updates - rtc tree - befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs - ptrace fixes - fork() fixes - seccomp cleanups - more mmap_sem hold time reductions from Davidlohr * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits) proc: show locks in /proc/pid/fdinfo/X docs: add missing and new /proc/PID/status file entries, fix typos drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic Documentation/spi/spidev_test.c: fix warning drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type .gitignore: ignore *.tar MAINTAINERS: add Mediatek SoC mailing list tomoyo: reduce mmap_sem hold for mm->exe_file powerpc/oprofile: reduce mmap_sem hold for exe_file oprofile: reduce mmap_sem hold for mm->exe_file mips: ip32: add platform data hooks to use DS1685 driver lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text x86: switch to using asm-generic for seccomp.h sparc: switch to using asm-generic for seccomp.h powerpc: switch to using asm-generic for seccomp.h parisc: switch to using asm-generic for seccomp.h mips: switch to using asm-generic for seccomp.h microblaze: use asm-generic for seccomp.h arm: use asm-generic for seccomp.h seccomp: allow COMPAT sigreturn overrides ...
2015-04-17kasan: Makefile: shut up warnings if CONFIG_COMPILE_TEST=yAndrey Ryabinin
It might be annoying to constantly see this: scripts/Makefile.kasan:16: Cannot use CONFIG_KASAN: -fsanitize=kernel-address is not supported by compiler while performing allmodconfig/allyesconfig build tests. Disable this warning if CONFIG_COMPILE_TEST=y. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: avoid "spaces required around that ':'" false positiveJoe Perches
Since commit 1f65f947a6a8 ("checkpatch: add checks for question mark and colon spacing") back in 2008, checkpatch has reported false positive for asm volatile uses of "::" checkpatch thinks colons should always have spaces around it. Add an exception for colons with colons on either side for this valid asm volatile (and c++) use. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Yehuda Yitschak <yehuday@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: fix --fix use with a patch of multiple filesJoe Perches
If a patch touches multiple files, the --fix and --fix-inplace option doesn't keep the proper line count and makes the new patch file not able to be applied via bad offset line numbers when lines are added or deleted by the --fix option. Dunno how that extra backslash snuck in there. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch.pl: new instances of ENOSYS are errorsAndy Lutomirski
ENOSYS means that a nonexistent system call was called. We have a bad habit of using it for things like invalid operations on otherwise valid syscalls. We should avoid this in new code. Pervasive incorrect usage of ENOSYS came up at the kernel summit ABI review discussion. Let's see if checkpatch can help. I'll submit a separate patch for include/uapi/asm-generic/errno.h. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add a test for const with __read_mostly usesJoe Perches
const objects shouldn't be __read_mostly. They are read-only. Marking these objects as __read_mostly causes section conflicts with LTO linking. So add a test to try to avoid this issue. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: improve operator spacing checkSam Bobroff
Code such as: x = timercmp(&now, &end, <); Will currently trigger a checkpatch error. e.g. ERROR: spaces required around that '<' This is because the "Ignore operators passed as parameters" check looks only for a comma following the operator. Improve the check by also looking for a close parenthesis. Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add 'Prefer ARRAY_SIZE" testJoe Perches
Add a test for sizeof(foo)/sizeof(foo[0]) that could be ARRAY_SIZE(foo). Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add uart_ops to normally const structsJoe Perches
Add another struct to the list of normally const struct types Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add #define foo "string" long line exceptionJoe Perches
There are #defines with long string constants like: #define foo "some really long string > 80 columns" Add a long line exception for them. Miscellanea: Use the $String variable for slightly better readability Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch, SubmittingPatches: suggest line wrapping commit messages at 75 ↵Joe Perches
columns Commit messages lines are sometimes overly long. Suggest line wrapping at 75 columns so the default git commit log indentation of 4 plus the commit message text still fits on an 80 column screen. Add a checkpatch test for long commit messages lines too. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Miller <davem@davemloft.net> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ian Morris <ipm@chirality.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: don't ask for asm/file.h to linux/file.h unconditionallyFabian Frederick
Currently checkpatch warns when asm/file.h is included and linux/file.h exists. That conversion can be made when linux/file.h includes asm/file.h which is not always the case.(See signal.h) Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Andy Whitcroft <apw@canonical.com> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add test for repeated const usesJoe Perches
Using 'const <type> const *' is generally meant to be written 'const <type> * const'. Add a test for the miswritten form. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: improve return negative errno checkJoe Perches
Add a few conditions to the test to find return (ERRNO); Make the output message a bit less cryptic too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: match more world writable permissionsJoe Perches
Currently checkpatch will fuss if one uses world writable settings in debugfs files and DEVICE_ATTR uses by testing S_IWUGO but not testing S_IWOTH, S_IRWXUGO or S_IALLUGO. Extend the check to catch all cases exporting world writable permissions including octal values. [akpm@linux-foundation.org: remove stray $] Signed-off-by: Joe Perches <joe@perches.com> Original-patch-by: Nicholas Mc Guire <hofrat@osadl.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add optional --codespell dictionary to find more typosJoe Perches
If a codespell dictionary exists, use it if desired. default is off, maybe it could be turned on later. codespell's dictionary format allows multiple possible corrections, ignore that for now and only use the first suggestion. Also add \b to spelling test so that consecutive misspelled words are found properly. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Kees Cook <keescook@chromium.org> Cc: Masanari Iida <standby24x7@gmail.com> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: spell check reudceJani Nikula
References: http://mid.gmane.org/1424977312-24902-1-git-send-email-ville.syrjala@linux.intel.com Signed-off-by: Jani Nikula <jani.nikula@intel.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: add spell checking of email subject lineJoe Perches
Only commit log and patch additions are checked for typos and spelling errors currently. Add a check of the email subject line too. Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Jani Nikula <jani.nikula@linux.intel.com> Tested-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17checkpatch: improve "no space is necessary after a cast" testJoe Perches
The "no space is necessary after a cast" sizeof exclusion doesn't work properly. The test reports a false positive for code like: BUILD_BUG_ON(sizeof(struct batadv_bla_claim_dst) != 6); Make it work, simplify the exclusions, and add some comments. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Marek Lindner <mareklindner@neomailbox.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-16Merge tag 'stable/for-linus-4.1-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen features and fixes from David Vrabel: - use a single source list of hypercalls, generating other tables etc. at build time. - add a "Xen PV" APIC driver to support >255 VCPUs in PV guests. - significant performance improve to guest save/restore/migration. - scsiback/front save/restore support. - infrastructure for multi-page xenbus rings. - misc fixes. * tag 'stable/for-linus-4.1-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pci: Try harder to get PXM information for Xen xenbus_client: Extend interface to support multi-page ring xen-pciback: also support disabling of bus-mastering and memory-write-invalidate xen: support suspend/resume in pvscsi frontend xen: scsiback: add LUN of restored domain xen-scsiback: define a pr_fmt macro with xen-pvscsi xen/mce: fix up xen_late_init_mcelog() error handling xen/privcmd: improve performance of MMAPBATCH_V2 xen: unify foreign GFN map/unmap for auto-xlated physmap guests x86/xen/apic: WARN with details. x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs xen/pciback: Don't print scary messages when unsupported by hypervisor. xen: use generated hypercall symbols in arch/x86/xen/xen-head.S xen: use generated hypervisor symbols in arch/x86/xen/trace.c xen: synchronize include/xen/interface/xen.h with xen xen: build infrastructure for generating hypercall depending symbols xen: balloon: Use static attribute groups for sysfs entries xen: pcpu: Use static attribute groups for sysfs entry
2015-04-15Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "Here is the kconfig stuff for v4.1-rc1: - fixes for mergeconfig (used by make kvmconfig/tinyconfig) - header cleanup - make -s *config is silent now" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: Do not print status messages in make -s mode kconfig: Simplify Makefile kbuild: add generic mergeconfig target, %.config merge_config.sh: rename MAKE to RUNMAKE merge_config.sh: improve indentation kbuild: mergeconfig: remove redundant $(objtree) kbuild: mergeconfig: move an error check to merge_config.sh kbuild: mergeconfig: fix "jobserver unavailable" warning kconfig: Remove unnecessary prototypes from headers kconfig: Remove dead code kconfig: Get rid of the P() macro in headers kconfig: fix a misspelling in scripts/kconfig/merge_config.sh
2015-04-15Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild updates from Michal Marek: "Here is the first round of kbuild changes for v4.1-rc1: - kallsyms fix for ARM and cleanup - make dep(end) removed (developers have no sense of nostalgia these days...) - include Makefiles by relative path - stop useless rebuilds of asm-offsets.h and bounds.h" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbols Kbuild: kallsyms: ignore veneers emitted by the ARM linker kbuild: ia64: use $(src)/Makefile.gate rather than particular path kbuild: include $(src)/Makefile rather than $(obj)/Makefile kbuild: use relative path more to include Makefile kbuild: use relative path to include Makefile kbuild: do not add $(bounds-file) and $(offsets-file) to targets kbuild: remove warning about "make depend" kbuild: Don't reset timestamps in include/generated if not needed
2015-04-15scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warningFabian Frederick
if()/BUG conversion to BUG_ON must be avoided when there's side effect in condition. The reason being BUG_ON won't execute the condition when CONFIG_BUG is not defined. Inspired-by: J. Bruce Fields <bfields@fieldses.org> Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-15scripts/extract-ikconfig: Support LZ4-compressed images.Alex Pilon
Support for kernel image LZ4 compression was added around 3.11, but not the corresponding kernel .config extraction. This makes possible extracting the kernel config for LZ4-compressed kernels you're not running, or the current LZ4-compressed kernel if compiled without /proc/config.gz support. Signed-off-by: Alex Pilon <alp+linux@alexpilon.ca> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-14scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warningFabian Frederick
if()/BUG conversion to BUG_ON must be avoided when there's side effect in condition. The reason being BUG_ON won't execute the condition when CONFIG_BUG is not defined. With inspiration from Bruce Fields. Signed-off-by: Fabian Frederick <fabf@skynet.be> Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Cc: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-13modpost: document the use of struct section_check.Quentin Casasnovas
struct section_check is used as a generic way of describing what relocations are authorized/forbidden when running modpost. This commit tries to describe how each field is used. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (Fixed "mist"ake)
2015-04-13modpost: handle relocations mismatch in __ex_table.Quentin Casasnovas
__ex_table is a simple table section where each entry is a pair of addresses - the first address is an address which can fault in kernel space, and the second address points to where the kernel should jump to when handling that fault. This is how copy_from_user() does not crash the kernel if userspace gives a borked pointer for example. If one of these addresses point to a non-executable section, something is seriously wrong since it either means the kernel will never fault from there or it will not be able to jump to there. As both cases are serious enough, we simply error out in these cases so the build fails and the developper has to fix the issue. In case the section is executable, but it isn't referenced in our list of authorized sections to point to from __ex_table, we just dump a warning giving more information about it. We do this in case the new section is executable but isn't supposed to be executed by the kernel. This happened with .altinstr_replacement, which is executable but is only used to copy instructions from - we should never have our instruction pointer pointing in .altinstr_replacement. Admitedly, a proper fix in that case would be to just set .altinstr_replacement NX, but we need to warn about future cases like this. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added long casts)
2015-04-13scripts: add check_extable.sh script.Quentin Casasnovas
This shell script can be used to sanity check the __ex_table section on an object file, making sure the relocations in there are pointing to valid executable sections. If it finds some suspicious relocations, it'll use addr2line to try and dump where this is coming from. This works best with CONFIG_DEBUG_INFO. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-13modpost: mismatch_handler: retrieve tosym information only when needed.Quentin Casasnovas
2015-04-13modpost: factorize symbol pretty print in get_pretty_name().Quentin Casasnovas
2015-04-13modpost: add handler function pointer to sectioncheck.Quentin Casasnovas
This will be useful when we want to have special handlers which need to go through more hops to print useful information to the user. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-13modpost: add .sched.text and .kprobes.text to the TEXT_SECTIONS list.Quentin Casasnovas
sched.text and .kprobes.text should behave exactly like .text with regards to how we should warn about referencing sections which might get discarded at runtime. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-13modpost: add strict white-listing when referencing sections.Quentin Casasnovas
Prints a warning when a section references a section outside a strict white-list. This will be useful to print a warning if __ex_table references a non-executable section. Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2015-04-09kconfig: Do not print status messages in make -s modeMichal Marek
Add an -s option to the various frontends and pass it when make -s is used. Also, use $(kecho) instead of @echo in the Makefile. Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-08kconfig: Simplify MakefileMichal Marek
Use a single rule for targets handled directly by the conf program. Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-07Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbolsArd Biesheuvel
Since we have required at least GCC v3.2 for some time now, we can drop the special handling of the 'gcc[0-9]_compiled.' label which is not emitted anymore since GCC v3.0. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2015-04-07Kbuild: kallsyms: ignore veneers emitted by the ARM linkerArd Biesheuvel
When linking large kernels on ARM, the linker will insert veneers (i.e., PLT like stubs) when function symbols are out of reach for the ordinary relative branch/branch-and-link instructions. However, due to the fact that the kallsyms region sits in .rodata, which is between .text and .init.text, additional veneers may be emitted in the second pass due to the fact that the size of the kallsyms region itself has pushed the .init.text section further apart, requiring even more veneers. So ignore the veneers when generating the symbol table. Veneers have no corresponding source code, and they will not turn up in backtraces anyway. This patch also lightly refactors the symbol_valid() function to use a local 'sym_name' rather than the obfuscated 'sym + 1' and 'sym + offset' Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
