path: root/scripts
2015-08-25localmodconfig: Use Kbuild files tooRichard Weinberger
commit c0ddc8c745b7f89c50385fd7aa03c78dc543fa7a upstream. In kbuild it is allowed to define objects in files named "Makefile" and "Kbuild". Currently localmodconfig reads objects only from "Makefile"s and misses modules like nouveau. Link: http://lkml.kernel.org/r/1437948415-16290-1-git-send-email-richard@nod.at Reported-and-tested-by: Leonidas Spyropoulos <artafinde@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-06-23scripts/sortextable: suppress warning: `relocs_size' may be used uninitializedTim Gardner
commit 7cbc0ea79da2cbe70d8da9319895f07f872a3190 upstream. In file included from scripts/sortextable.c:194:0: scripts/sortextable.c: In function `main': scripts/sortextable.h:176:3: warning: `relocs_size' may be used uninitialized in this function [-Wmaybe-uninitialized] memset(relocs, 0, relocs_size); ^ scripts/sortextable.h:106:6: note: `relocs_size' was declared here int relocs_size; ^ In file included from scripts/sortextable.c:192:0: scripts/sortextable.h:176:3: warning: `relocs_size' may be used uninitialized in this function [-Wmaybe-uninitialized] memset(relocs, 0, relocs_size); ^ scripts/sortextable.h:106:6: note: `relocs_size' was declared here int relocs_size; ^ gcc 4.9.1 Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Reviewed-by: Jamie Iles <jamie.iles@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-09kconfig: Fix warning "‘jump’ may be used uninitialized"Peter Kümmel
commit 2d560306096739e2251329ab5c16059311a151b0 upstream. Warning: In file included from scripts/kconfig/zconf.tab.c:2537:0: scripts/kconfig/menu.c: In function ‘get_symbol_str’: scripts/kconfig/menu.c:590:18: warning: ‘jump’ may be used uninitialized in this function [-Wmaybe-uninitialized] jump->offset = strlen(r->s); Simplifies the test logic because (head && local) means (jump != 0) and makes GCC happy when checking if the jump pointer was initialized. Signed-off-by: Peter Kümmel <syntheticpp@gmx.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Cc: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-09kconfig: fix bug in search results string: use strlen(gstr->s), not gstr->lenMartin Walch
commit 503c823048e81cc85c0e9d8c297cc70203e335e5 upstream. The struct gstr has a capacity that may differ from the actual string length. However, a string manipulation in the function search_conf made the assumption that it is the same, which led to messing up some search results, especially when the content of the gstr in use had not yet reached at least 63 chars. Signed-off-by: Martin Walch <walch.martin@web.de> Acked-by: Wang YanQing <udknight@gmail.com> Acked-by: Benjamin Poirier <bpoirier@suse.de> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-29scripts/recordmcount.pl: There is no -m32 gcc option on Super-H anymoreMichael Karcher
commit 1caf6aaaa47471831d77c75f094d4e00ad1ec808 upstream. Compiling SH with gcc-4.8 fails due to the -m32 option not being supported. From http://buildd.debian-ports.org/status/fetch.php?pkg=linux&arch=sh4&ver=3.16.7-ckt4-1&stamp=1421425783 CC init/main.o gcc-4.8: error: unrecognized command line option '-m32' ld: cannot find init/.tmp_mc_main.o: No such file or directory objcopy: 'init/.tmp_mx_main.o': No such file rm: cannot remove 'init/.tmp_mx_main.o': No such file or directory rm: cannot remove 'init/.tmp_mc_main.o': No such file or directory Link: http://lkml.kernel.org/r/1421537778-29001-1-git-send-email-kernel@mkarcher.dialup.fu-berlin.de Link: http://lkml.kernel.org/r/54BCBDD4.10102@physik.fu-berlin.de Cc: Matt Fleming <matt@console-pimps.org> Reported-by: John Paul Adrian Glaubitz <glaubitz@physik.fu-berlin.de> Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26scripts/kernel-doc: don't eat struct members with __alignedJohannes Berg
commit 7b990789a4c3420fa57596b368733158e432d444 upstream. The change from \d+ to .+ inside __aligned() means that the following structure: struct test { u8 a __aligned(2); u8 b __aligned(2); }; essentially gets modified to struct test { u8 a; }; for purposes of kernel-doc, thus dropping a struct member, which in turns causes warnings and invalid kernel-doc generation. Fix this by replacing the catch-all (".") with anything that's not a semicolon ("[^;]"). Fixes: 9dc30918b23f ("scripts/kernel-doc: handle struct member __aligned without numbers") Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: Nishanth Menon <nm@ti.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-07-17recordmcount/MIPS: Fix possible incorrect mcount_loc table entries in modulesAlex Smith
commit 91ad11d7cc6f4472ebf177a6252fbf0fd100d798 upstream. On MIPS calls to _mcount in modules generate 2 instructions to load the _mcount address (and therefore 2 relocations). The mcount_loc table should only reference the first of these, so the second is filtered out by checking the relocation offset and ignoring ones that immediately follow the previous one seen. However if a module has an _mcount call at offset 0, the second relocation would not be filtered out due to old_r_offset == 0 being taken to mean that the current relocation is the first one seen, and both would end up in the mcount_loc table. This results in ftrace_make_nop() patching both (adjacent) instructions to branches over the _mcount call sequence like so: 0xffffffffc08a8000: 04 00 00 10 b 0xffffffffc08a8014 0xffffffffc08a8004: 04 00 00 10 b 0xffffffffc08a8018 0xffffffffc08a8008: 2d 08 e0 03 move at,ra ... The second branch is in the delay slot of the first, which is defined to be unpredictable - on the platform on which this bug was encountered, it triggers a reserved instruction exception. Fix by initializing old_r_offset to ~0 and using that instead of 0 to determine whether the current relocation is the first seen. Signed-off-by: Alex Smith <alex.smith@imgtec.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7098/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-07-02builddeb: use $OBJCOPY variable instead of objcopyFathi Boudra
commit 6b4a144a92ab81a1f45fb9b12aebaaaee0d08120 upstream. In cross-build environment, we expect to use the cross-compiler objcopy instead of the host objcopy. It fixes following build failures: objcopy --only-keep-debug lib/modules/3.14/kernel/net/ipv6/xfrm6_mode_tunnel.ko /srv/build/linux/debian/dbgtmp/usr/lib/debug/lib/modules/3.14/kernel/net/ipv6/xfrm6_mode_tunnel.ko objcopy: Unable to recognise the format of the input file `lib/modules/3.14/kernel/net/ipv6/xfrm6_mode_tunnel.ko' Signed-off-by: Fathi Boudra <fathi.boudra@linaro.org> Fixes: 810e843746b7 ('deb-pkg: split debug symbols in their own package') Reviewed-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-07-02module: allow multiple calls to MODULE_DEVICE_TABLE() per moduleTom Gundersen
commit 21bdd17b21b45ea48e06e23918d681afbe0622e9 upstream. Commit 78551277e4df5: "Input: i8042 - add PNP modaliases" had a bug, where the second call to MODULE_DEVICE_TABLE() overrode the first resulting in not all the modaliases being exposed. This fixes the problem by including the name of the device_id table in the __mod_*_device_table alias, allowing us to export several device_id tables per module. Suggested-by: Kay Sievers <kay@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Tom Gundersen <teg@jklm.no> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Conflicts: include/linux/module.h
2014-05-15powerpc: Add vr save/restore functionsAndreas Schwab
commit 8fe9c93e7453e67b8bd09f263ec1bb0783c733fc upstream. GCC 4.8 now generates out-of-line vr save/restore functions when optimizing for size. They are needed for the raid6 altivec support. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-31deb-pkg: Fix cross-building linux-headers packageBen Hutchings
commit f8ce239dfc7ba9add41d9ecdc5e7810738f839fa upstream. builddeb generates a control file that says the linux-headers package can only be built for the build system primary architecture. This breaks cross-building configurations. We should use $debarch for this instead. Since $debarch is not yet set when generating the control file, set Architecture: any and use control file variables to fill in the description. Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg') Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-31deb-pkg: Fix building for MIPS big-endian or ARM OABIBen Hutchings
commit c5e318f67eebbad491615a752c51dbfde7dc3d78 upstream. These commands will mysteriously fail: $ make ARCH=arm versatile_defconfig [...] $ make ARCH=arm deb-pkg [...] make[1]: *** [deb-pkg] Error 1 make: *** [deb-pkg] Error 2 The Debian architecture selection for these kernel architectures does 'grep FOO=y $KCONFIG_CONFIG && echo bar', and after 'set -e' this aborts the script if grep does not find the given config symbol. Fixes: 10f26fa64200 ('build, deb-pkg: select userland architecture based on UTS_MACHINE') Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-02-22Modpost: fixed USB alias generation for ranges including 0x9 and 0xAJan Moskyto Matejka
commit 03b56329f9bb5a1cb73d7dc659d529a9a9bf3acc upstream. Commit afe2dab4f6 ("USB: add hex/bcd detection to usb modalias generation") changed the routine that generates alias ranges. Before that change, only digits 0-9 were supported; the commit tried to fix the case when the range includes higher values than 0x9. Unfortunately, the commit didn't fix the case when the range includes both 0x9 and 0xA, meaning that the final range must look like [x-9A-y] where x <= 0x9 and y >= 0xA -- instead the [x-9A-x] range was produced. Modprobe doesn't complain as it sees no difference between no-match and bad-pattern results of fnmatch(). Fixing this simple bug to fix the aliases. Also changing the hardcoded beginning of the range to uppercase as all the other letters are also uppercase in the device version numbers. Fortunately, this affects only the dvb-usb-dib0700 module, AFAIK. Signed-off-by: Jan Moskyto Matejka <mq@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09scripts/link-vmlinux.sh: only filter kernel symbols for armMing Lei
commit 7122c3e9154b5d9a7422f68f02d8acf050fad2b0 upstream. Actually CONFIG_PAGE_OFFSET isn't same with PAGE_OFFSET, so it isn't easy to figue out PAGE_OFFSET defined in header file from scripts. Because CONFIG_PAGE_OFFSET may not be defined in some ARCHs( 64bit ARCH), or defined as bogus value in !MMU case, so this patch only applys the filter on ARM when CONFIG_PAGE_OFFSET is defined as the original problem is only on ARM. Cc: Rusty Russell <rusty@rustcorp.com.au> Fixes: f6537f2f0eba4eba3354e48dbe3047db6d8b6254 Singed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-02scripts/kallsyms: filter symbols not in kernel address spaceMing Lei
This patch uses CONFIG_PAGE_OFFSET to filter symbols which are not in kernel address space because these symbols are generally for generating code purpose and can't be run at kernel mode, so we needn't keep them in /proc/kallsyms. For example, on ARM there are some symbols which may be linked in relocatable code section, then perf can't parse symbols any more from /proc/kallsyms, this patch fixes the problem (introduced b9b32bf70f2fb710b07c94e13afbc729afe221da) Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@vger.kernel.org
2013-09-24checkpatch: make extern in .h prototypes quieterJoe Perches
The use of extern in .h files is a bit contentious. Make the warning be emitted only when --strict is used on the command line. Signed-off-by: Joe Perches <joe@perches.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig fix from Michal Marek: "This is a fix for a regression caused by my previous pull request. A sed command in scripts/config that used colons as separator was accidentally changed to use slashes, which fails when you use slashes in a value. Changing it back to colons is of course not a proper fix, but at least it will be broken in the same way it had been for four years. A proper fix is pending" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/config: fix variable substitution command
2013-09-13scripts/config: fix variable substitution commandClement Chauplannaz
Commit 229455bc02b87f7128f190c4491b4ceffff38648 accidentally changed the separator between sed `s' command and its parameters from ':' to '/'. Revert this change. Reported-and-tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Clement Chauplannaz <chauplac@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-12Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This has been sitting in -next for a while with no objections and all MIPS defconfigs except one are building fine; that one platform got broken by another patch in your tree and I'm going to submit a patch separately. - a handful of fixes that didn't make 3.11 - a few bits of Octeon 3 support with more to come for a later release - platform enhancements for Octeon, ath79, Lantiq, Netlogic and Ralink SOCs - a GPIO driver for the Octeon - some dusting off of the DECstation code - the usual dose of cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (65 commits) MIPS: DMA: Fix BUG due to smp_processor_id() in preemptible code MIPS: kexec: Fix random crashes while loading crashkernel MIPS: kdump: Skip walking indirection page for crashkernels MIPS: DECstation HRT calibration bug fixes MIPS: Export copy_from_user_page() (needed by lustre) MIPS: Add driver for the built-in PCI controller of the RT3883 SoC MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000 MIPS: ralink: Add support for reset-controller API MIPS: ralink: mt7620: Add cpu-feature-override header MIPS: ralink: mt7620: Add spi clock definition MIPS: ralink: mt7620: Add wdt clock definition MIPS: ralink: mt7620: Improve clock frequency detection MIPS: ralink: mt7620: This SoC has EHCI and OHCI hosts MIPS: ralink: mt7620: Add verbose ram info MIPS: ralink: Probe clocksources from OF MIPS: ralink: Add support for systick timer found on newer ralink SoC MIPS: ralink: Add support for periodic timer irq MIPS: Netlogic: Built-in DTB for XLP2xx SoC boards MIPS: Netlogic: Add support for USB on XLP2xx MIPS: Netlogic: XLP2xx update for I2C controller ...
2013-09-11checkpatch: add test for positional misuse of section specifiers like __initdataJoe Perches
As discussed recently on the arm [1] and lm-sensors [2] lists, it is possible to use section markers on variables in a way which gcc doesn't understand (or at least not the way the developer intended): static struct __initdata samsung_pll_clock exynos4_plls[nr_plls] = { does NOT put exynos4_plls in the .initdata section. The __initdata marker can be virtually anywhere on the line, EXCEPT right after "struct". The preferred location is before the "=" sign if there is one, or before the trailing ";" otherwise. [1] http://permalink.gmane.org/gmane.linux.ports.arm.kernel/258149 [2] http://lists.lm-sensors.org/pipermail/lm-sensors/2013-August/039836.html So, update checkpatch to find these misuses and report an error when it's immediately after struct or union, and a warning when it's otherwise not immediately before the ; or =. A similar patch was suggested by Andi Kleen https://lkml.org/lkml/2013/8/5/648 Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Jean Delvare <khali@linux-fr.org> Tested-by: Guenter Roeck <linux@roeck-us.net> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: fix perl version 5.12 and earlier incompatibilityJoe Perches
A previous patch ("checkpatch: add --types option to report only specific message types") uses a perl syntax introduced in perl version 5.14. Use the backward compatible perl syntax instead. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: reduce runtime/cpu time usedJoe Perches
There are some cases where checkpatch can take a long time to complete. Reduce the likelihood of this long run-time by adding a new test for lines with and without comments and eliminating checks on lines with only comments. This reduces the number of "ctx_statement_block" calls, and also the number of tests of $stat, which is now undefined for these blank lines. One test in particular, the "check for switch/default statements without a break", could take an extremely long time to parse as it tries to skip interleaving comments within the ctx_statement_block/$stat and that could be done multiple times unnecessarily. A small test case taken from cfg80211.h before this patch would take 1000's of seconds to run, now it's just a couple seconds. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: better --fix of SPACING errors.Joe Perches
Previous attempt at fixing SPACING errors could make a hash of several defects. This patch should make --fix be a lot better at correcting these defects. Trim left and right sides of these defects appropriately instead of a somewhat random attempt at it. Trim left spaces from any following bit of the modified line when only a single space is required around an operator. Signed-off-by: Joe Perches <joe@perches.com> Cc: Phil Carmody <phil.carmody@partner.samsung.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: ignore #define TRACE_<foo> macrosJoe Perches
The tracing subsystem uses slightly odd #defines to set path/directory locations for include files. These #defines can cause false positives for the complex macro tests so add exclusions for these specific #defines (TRACE_SYSTEM, TRACE_INCLUDE_FILE, TRACE_INCLUDE_PATH). Signed-off-by: Joe Perches <joe@perches.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: add --types option to report only specific message typesJoe Perches
Add a --types convenience option to show only specific message types. Combined with the --fix option, this can produce specific suggested formatting patches to files. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: fix networking kernel-doc block comment defectJoe Perches
checkpatch can generate a false positive when inserting a new kernel-doc block and function above an existing kernel-doc block. Fix it by checking that the context line is also a newly inserted line. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: warn when using extern with function prototypes in .h filesJoe Perches
Using the extern keyword on function prototypes is superfluous visual noise so suggest removing it. Using extern can cause unnecessary line wrapping at 80 columns and unnecessarily long multi-line function prototypes. Signed-off-by: Joe Perches <joe@perches.com> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: check for duplicate signaturesJoe Perches
Emit a warning when a signature is used more than once. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: enforce sane perl versionDave Hansen
I got a bug report from a couple of users who said checkpatch.pl was broken for them. It was erroring out on fairly random lines most commonly with messages like: Nested quantifiers in regex; marked by <--HERE in m/(\((?:[^\(\)]++ <-- HERE |(?-1))*\))/ at ./checkpatch.pl line 340. The bug reporter was running a version of perl 5.8 which was end-of-lifed in 2008: http://www.cpan.org/src/. Versions of perl this old are at _best_ quite untested. At worst, they are crusty and known to be completely broken. If folks have a system _that_ old, then we should have mercy on them and give them a half-decent error message rather than fail with nutty error messages. This patch enforces that checkpatch.pl is run with perl 5.10, which was end-of-lifed in 2009. The new --ignore-perl-version command-line switch will let folks override this if they want. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: check CamelCase by word, not by $LvalJoe Perches
$Lval is a test for complete name (ie: foo->bar.Baz[1]) If any of this is CamelCase, then the current test uses the entire $Lval. This isn't optimal because it can emit messages with foo->bar.Baz and bar.Baz when Baz is a variable specified in an include file. So instead, break the $Lval into words and check each word for CamelCase uses. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11checkpatch: add a few more --fix correctionsJoe Perches
Suggest a few more single-line corrections. Remove DOS line endings Simplify removing trailing whitespace Remove global/static initializations to 0/NULL Convert pr_warning to pr_warn Add space after brace Convert binary constants to hex Remove whitespace after line continuation Use inline not __inline or __inline__ Use __printf and __scanf Use a single ; for statement terminations Convert __FUNCTION__ to __func__ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig updates from Michal Marek: "This is the kconfig part of kbuild for v3.12-rc1: - post-3.11 search code fixes and micro-optimizations - CONFIG_MODULES is no longer a special case; this is needed to eventually fix the bug that using KCONFIG_ALLCONFIG breaks allmodconfig - long long is used to store hex and int values - make silentoldconfig no longer warns when a symbol changes from tristate to bool (it's a job for make oldconfig) - scripts/diffconfig updated to work with newer Pythons - scripts/config does not rely on GNU sed extensions" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: do not allow more than one symbol to have 'option modules' kconfig: regenerate bison parser kconfig: do not special-case 'MODULES' symbol diffconfig: Update script to support python versions 2.5 through 3.3 diffconfig: Gracefully exit if the default config files are not present modules: do not depend on kconfig to set 'modules' option to symbol MODULES kconfig: silence warning when parsing auto.conf when a symbol has changed type scripts/config: use sed's POSIX interface kconfig: switch to "long long" for sanity kconfig: simplify symbol-search code kconfig: don't allocate n+1 elements in temporary array kconfig: minor style fixes in symbol-search code kconfig/[mn]conf: shorten title in search-box kconfig: avoid multiple calls to strlen Documentation/kconfig: more concise and straightforward search explanation
2013-09-07Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates from Michal Marek: "In the kbuild misc branch, I have: - make rpm-pkg updates, most importantly the rpm package now calls /sbin/installkernel - make deb-pkg: debuginfo split, correct kernel image path for parisc, mips and powerpc and a couple more minor fixes - New coccinelle check" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/checkkconfigsymbols.sh: replace echo -e with printf Provide version number for Debian firmware package coccinelle: replace 0/1 with false/true in functions returning bool deb-pkg: add a hook argument to match debian hooks parameters deb-pkg: fix installed image path on parisc, mips and powerpc deb-pkg: split debug symbols in their own package deb-pkg: use KCONFIG_CONFIG instead of .config file directly rpm-pkg: add generation of kernel-devel rpm-pkg: install firmware files in kernel relative directory rpm-pkg: add %post section to create initramfs and grub hooks
2013-09-07Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild update from Michal Marek: "Only these two commits are in the kbuild branch this time: - Using filechk for include/config/kernel.release - Cleanup in scripts/sortextable.c" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not overwrite include/config/kernel.release needlessly scripts: remove unused function in sortextable.c
2013-09-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull Tile arch updates from Chris Metcalf: "These changes bring in a bunch of new functionality that has been maintained internally at Tilera over the last year, plus other stray bits of work that I've taken into the tile tree from other folks. The changes include some PCI root complex work, interrupt-driven console support, support for performing fast-path unaligned data fixups by kernel-based JIT code generation, CONFIG_PREEMPT support, vDSO support for gettimeofday(), a serial driver for the tilegx on-chip UART, KGDB support, more optimized string routines, support for ftrace and kprobes, improved ASLR, and many bug fixes. We also remove support for the old TILE64 chip, which is no longer buildable" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (85 commits) tile: refresh tile defconfig files tile: rework <asm/cmpxchg.h> tile PCI RC: make default consistent DMA mask 32-bit tile: add null check for kzalloc in tile/kernel/setup.c tile: make __write_once a synonym for __read_mostly tile: remove support for TILE64 tile: use asm-generic/bitops/builtin-*.h tile: eliminate no-op "noatomichash" boot argument tile: use standard tile_bundle_bits type in traps.c tile: simplify code referencing hypervisor API addresses tile: change <asm/system.h> to <asm/switch_to.h> in comments tile: mark pcibios_init() as __init tile: check for correct compiler earlier in asm-offsets.c tile: use standard 'generic-y' model for <asm/hw_irq.h> tile: use asm-generic version of <asm/local64.h> tile PCI RC: add comment about "PCI hole" problem tile: remove DEBUG_EXTRA_FLAGS kernel config option tile: add virt_to_kpte() API and clean up and document behavior tile: support FRAME_POINTER tile: support reporting Tilera hypervisor statistics ...
2013-09-05kconfig: do not allow more than one symbol to have 'option modules'Yann E. MORIN
Previously, it was possible to have more than one symbol with the 'option modules' attached to them, although only the last one would in fact control tristates. Since this does not make much sense, only allow at most one symbol to control tristates. Note: it is still possible to have more than one symbol that control tristates, but indirectly: config MOD1 bool "mod1" select MODULES config MOD2 bool "mod2" select MODULES config MODULES bool option modules Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-05kconfig: regenerate bison parserYann E. MORIN
Regenerate bison parser after changes made in: 6902dcc: kconfig: do not special-case 'MODULES' symbol Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-05kconfig: do not special-case 'MODULES' symbolYann E. MORIN
Currently, the 'MODULES' symbol is hard-coded to be the default symbol that enables/disables tristates, if no other symbol was declared with 'option modules'. While this used to be needed for the Linux kernel, we now have an explicit 'option modules' attached to the 'MODULES' symbol (since cset 11097a036), so we no longer need to special-case it in the kconfig code. Furthermore, kconfig is extensively used out of the Linux kernel, and other projects may have another meaning for a symbol named 'MODULES'. This patch changes the way we enable/disable tristates: if a symbol was found with 'option modules' attached to it, then that symbol controls enabling tristates. Otherwise, tristates are disabled, even if a symbol named 'MODULES' exists. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-04Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Minor fixes mainly, including a potential use-after-free on remove found by CONFIG_DEBUG_KOBJECT_RELEASE which may be theoretical" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: Fix mod->mkobj.kobj potentially freed too early kernel/params.c: use scnprintf() instead of sprintf() kernel/module.c: use scnprintf() instead of sprintf() module/lsm: Have apparmor module parameters work with no args module: Add NOARG flag for ops with param_set_bool_enable_only() set function module: Add flag to allow mod params to have no arguments modules: add support for soft module dependencies scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture. module: fix sprintf format specifier in param_get_byte()
2013-09-01diffconfig: Update script to support python versions 2.5 through 3.3Mike Pagano
Support past and active versions of python while maintaining backward compatibility. Script has been tested on python versions up to and including 3.3.X. Signed-off-by: Mike Pagano <mpagano@gentoo.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-08-30tile: support ftrace on tilegxTony Lu
This commit adds support for static ftrace, graph function support, and dynamic tracer support. Signed-off-by: Tony Lu <zlu@tilera.com> Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2013-08-28scripts/checkkconfigsymbols.sh: replace echo -e with printfMax Filippov
-e is a non-standard echo option, echo output is implementation-dependent when it is used. Replace echo -e with printf as suggested by POSIX echo manual. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-08-26kbuild: Add MIPS specific files to generated package.Stuart Longland
A lot of 64-bit systems supported by Linux/MIPS have boot firmware or bootloaders that only understand 32-bit ELF files, and as such, the vmlinux.32 target exists to support these systems. Therefore, it'd be nice if the tar-pkg target recognised this, and included the right version when packaging up a binary of the kernel. This updates buildtar to support MIPS targets. MIPS may use 'vmlinux' or 'vmlinux.32' depending on the target system. This uses 'vmlinux.32' in preference to 'vmlinux' where present (although I should check which is newer), including either file as /boot/vmlinux-${version}. Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1673/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-08-20scripts/mod/modpost.c: permit '.cranges' secton for sh64 architecture.Chen Gang
Need permit '.cranges' section for sh64 architecture, or modpost will report warning: LD init/built-in.o WARNING: init/built-in.o (.cranges): unexpected non-allocatable section. Did you forget to use "ax"/"aw" in a .S file? Note that for example <linux/init.h> contains section definitions for use in .S files. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-08-19diffconfig: Gracefully exit if the default config files are not presentMike Pagano
Handle gracefully the instance where config files are not present. Compatible with python versions 2.5, 2.6 and 2.7. The try/except is forward compatible with python version 3 once the entire script is ported. Signed-off-by: Mike Pagano <mpagano@gentoo.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-08-15kconfig: silence warning when parsing auto.conf when a symbol has changed typeYann E. MORIN
When a symbol changes type from tristate to bool, and was previously set to 'm', a subsequent silentoldconfig would warn about inconsistency, such as: include/config/auto.conf:3014:warning: symbol value 'm' invalid for HOTPLUG_PCI_PCIE Seen by Linus with the merge in aa8032b (sequence to reproduce by Michal): git checkout 1fe0135 make mrproper make allmodconfig make silentoldconfig git checkout aa8032b make allmodconfig make silentoldconfig Since HOTPLUG_PCI_PCIE changed from tristate to bool in aa8032b, it was previously set to 'm' in auto.conf by the first allmodconfig+silentoldconfig, but then was set to 'y' by the second allmodconfig. Then the second silentoldconfig prints the warning. The warning in this case is a spurious warning, which happens at the time kconfig tries to detect symbols that have changed, to touch the empty header files in include/config used for dependency-tracking by make. Silence the warning when we read the old auto.conf file, since it is perfectly legit that a symbol changed type since the previous call. Thread in: http://marc.info/?l=linux-pci&m=137569198904000&w=2 Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-15scripts/config: use sed's POSIX interfaceClement Chauplannaz
Script `config' relies on extensions of `GNU sed', and is thus not working on all Unixes: - in-place edition of files (-i), which can be replaced with a temporary file; - extended-regexps (-r), which can be split into basic regexps; - single-line calls to `a' command, while some implementations require a leading newline before the parameter. Rewrite calls to `sed' to comply with POSIX interface, and move them to helper functions. Signed-off-by: Clement Chauplannaz <chauplac@gmail.com> Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Yann E. MORIN <yann.morin.1998@free.fr>
2013-08-15kconfig: switch to "long long" for sanityKees Cook
Instead of using "long" for kconfig "hex" and "range" values, which may change in size depending on the host architecture, use "long long". This will allow values greater than INT_MAX on 32-bit hosts when cross compiling. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
2013-08-15Provide version number for Debian firmware packageHeinrich Schuchardt
scripts/package/builddeb is used to create Debian packages. Currently the firmware package always gets the same version number irrespective of the Kernel version. The paths inside the firmware package depend on the Kernel version. With the patch supplied the Kernel version becomes part of the Debian firmware package number. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-08-13coccinelle: replace 0/1 with false/true in functions returning boolRasmus Villemoes
This semantic patch replaces "return {0,1};" with "return {false,true};" in functions returning bool. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Acked-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
