[ Upstream commit cbf52a3e6a8a92beec6e0c70abf4111cd8f8faf7 ]
When the kernel is compiled with an "O=" argument, the object files are
not in the source tree, but in the build tree.
This patch fixes O= build by looking for object files in the build tree.
Fixes: 923e02ecf3f8 ("scripts/tags.sh: Support compiled source")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 55fe6da9efba102866e2fb5b40b04b6a4b26c19e upstream.
cmd_dt_S_dtb constructs the assembly source to incorporate a devicetree
FDT (that is, the .dtb file) as binary data in the kernel image. This
assembly source contains labels before and after the binary data. The
label names incorporate the file name of the corresponding .dtb file.
Hyphens are not legal characters in labels, so .dtb files built into the
kernel with hyphens in the file name result in errors like the
following:
bcm3368-netgear-cvg834g.dtb.S: Assembler messages:
bcm3368-netgear-cvg834g.dtb.S:5: Error: : no such section
bcm3368-netgear-cvg834g.dtb.S:5: Error: junk at end of line, first unrecognized character is `-'
bcm3368-netgear-cvg834g.dtb.S:6: Error: unrecognized opcode `__dtb_bcm3368-netgear-cvg834g_begin:'
bcm3368-netgear-cvg834g.dtb.S:8: Error: unrecognized opcode `__dtb_bcm3368-netgear-cvg834g_end:'
bcm3368-netgear-cvg834g.dtb.S:9: Error: : no such section
bcm3368-netgear-cvg834g.dtb.S:9: Error: junk at end of line, first unrecognized character is `-'
Fix this by updating cmd_dt_S_dtb to transform all hyphens from the file
name to underscores when constructing the labels.
As of v4.16-rc2, 1139 .dts files across ARM64, ARM, MIPS and PowerPC
contain hyphens in their names, but the issue only currently manifests
on Broadcom MIPS platforms, as that is the only place where such files
are built into the kernel. For example when CONFIG_DT_NETGEAR_CVG834G=y,
or on BMIPS kernels when the dtbs target is used (in the latter case it
admittedly shouldn't really build all the dtb.o files, but thats a
separate issue).
Fixes: 695835511f96 ("MIPS: BMIPS: rename bcm96358nb4ser to bcm6358-neufbox4-sercom")
Signed-off-by: James Hogan <jhogan@kernel.org>
Reviewed-by: Frank Rowand <frowand.list@gmail.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: <stable@vger.kernel.org> # 4.9+
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8)
There's a risk that a kernel which has full retpoline mitigations becomes
vulnerable when a module gets loaded that hasn't been compiled with the
right compiler or the right option.
To enable detection of that mismatch at module load time, add a module info
string "retpoline" at build time when the module was compiled with
retpoline support. This only covers compiled C source, but assembler source
or prebuilt object files are not checked.
If a retpoline enabled kernel detects a non retpoline protected module at
load time, print a warning and report it in the sysfs vulnerability file.
[ tglx: Massaged changelog ]
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: jeyu@kernel.org
Cc: arjan@linux.intel.com
Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[jwang: port to 4.4]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit d920f7c6628c63a390009c237fb80a203c2e400a upstream.
Do not try to recover too early and segfault when parsing invalid
declarations such as
echo 'int (int);' | scripts/genksyms/genksyms
echo 'int a, (int);' | scripts/genksyms/genksyms
echo 'extern void *__inline_memcpy((void *), (const void *), (__kernel_size_t));' | scripts/genksyms/genksyms
The last one was a real-life bug with
include/asm-generic/asm-prototypes.h on x86_64.
Reported-and-tested-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Michal Marek <mmarek@suse.com>
[arnd: rebase to 4.4, regenerate parse.tab.{c,h}]
[ Upstream commit e814bccbafece52a24e152d2395b5d49eef55841 ]
My bisect scripts starting running into build failures when trying to
compile 4.15-rc1 with the builds failing with things like:
drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c:2078: error: Cannot parse struct or union!
The line in question is actually just a #define, but after some digging
it turns out that my scripts pass W=1 and since commit 3a025e1d1c2ea
("Add optional check for bad kernel-doc comments") that results in
kernel-doc running on each source file. The file in question has a
badly formatted comment immediately before the #define:
* struct brcmf_skbuff_cb reserves first two bytes in sk_buff::cb for
* bus layer usage.
which causes the regex in dump_struct to fail (lack of braces following
struct declaration) and kernel-doc returns 1, which causes the build
to fail.
Fix the issue by always returning 0 from kernel-doc when invoked with
-none. It successfully generates no documentation, and prints out any
issues.
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
commit c153693d7eb9eeb28478aa2deaaf0b4e7b5ff5e9 upstream.
PowerPC64 uses the symbol .TOC. much as other targets use
_GLOBAL_OFFSET_TABLE_. It identifies the value of the GOT pointer (or in
powerpc parlance, the TOC pointer). Global offset tables are generally
local to an executable or shared library, or in the kernel, module. Thus
it does not make sense for a module to resolve a relocation against
.TOC. to the kernel's .TOC. value. A module has its own .TOC., and
indeed the powerpc64 module relocation processing ignores the kernel
value of .TOC. and instead calculates a module-local value.
This patch removes code involved in exporting the kernel .TOC., tweaks
modpost to ignore an undefined .TOC., and the module loader to twiddle
the section symbol so that .TOC. isn't seen as undefined.
Note that if the kernel was compiled with -msingle-pic-base then ELFv2
would not have function global entry code setting up r2. In that case
the module call stubs would need to be modified to set up r2 using the
kernel .TOC. value, requiring some of this code to be reinstated.
mpe: Furthermore a change in binutils master (not yet released) causes
the current way we handle the TOC to no longer work when building with
MODVERSIONS=y and RELOCATABLE=n. The symptom is that modules can not be
loaded due to there being no version found for TOC.
Signed-off-by: Alan Modra <amodra@gmail.com>
commit 4efca4ed05cbdfd13ec3e8cb623fb77d6e4ab187 upstream.
Allow architectures to create asm/asm-prototypes.h file that
provides C prototypes for exported asm functions, which enables
proper CRC versions to be generated for them.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
[jkosina@suse.cz: folded cc6acc11cad1 fixup in as well ]
commit a78f70e8d65e88b9f631d073f68cb26dcd746298 upstream.
The reference files use spaces to separate tokens, however, we must
preserve spaces inside string literals. Currently the only case in the
tree is struct edac_raw_error_desc in <linux/edac.h>:
$ KBUILD_SYMTYPES=1 make -s drivers/edac/amd64_edac.symtypes
$ mv drivers/edac/amd64_edac.{symtypes,symref}
drivers/edac/amd64_edac.c:527: warning: amd64_get_dram_hole_info: modversion changed because of changes in struct edac_raw_error_desc
[ Upstream commit 2dbc644ac62bbcb9ee78e84719953f611be0413d ]
For rpm-pkg and deb-pkg, a source tar file is created. All paths in
the archive must be prefixed with the base name of the tar so that
everything is contained in the directory when you extract it.
Currently, scripts/package/Makefile uses a symlink for that, and
removes it after the tar is created.
If you terminate the build during the tar creation, the symlink is
left over. Then, at the next package build, you will see a warning
like follows:
ln: '.' and 'kernel-4.14.0+/.' are the same file
It is possible to fix it by adding -n (--no-dereference) option to
the "ln" command, but a cleaner way is to use --transform option
of "tar" command. This option is GNU extension, but it should not
hurt to use it in the Linux build system.
The 'S' flag is needed to exclude symlinks from the path fixup.
Without it, symlinks in the kernel are broken.
[ Upstream commit ab42632156becd35d3884ee5c14da2bedbf3149a ]
For powerpc the __jump_table section in modules is not aligned, this
causes a WARN_ON() splat when loading a module containing a __jump_table.
Strict alignment became necessary with commit 3821fd35b58d
("jump_label: Reduce the size of struct static_key"), currently in
linux-next, which uses the two least significant bits of pointers to
__jump_table elements.
Fix by forcing __jump_table to 8, which is the same alignment used for
this section in the kernel proper.
Link: http://lkml.kernel.org/r/20170301220453.4756-1-david.daney@cavium.com
Reviewed-by: Jason Baron <jbaron@akamai.com>
Acked-by: Jessica Yu <jeyu@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 8d81ae05d0176da1c54aeaed697fa34be5c5575e upstream.
As of perl 5, version 26, subversion 0 (v5.26.0) some new warnings have
occurred when running checkpatch.
Unescaped left brace in regex is deprecated here (and will be fatal in
Perl 5.30), passed through in regex; marked by <-- HERE in m/^(.\s*){
<-- HERE \s*/ at scripts/checkpatch.pl line 3544.
<-- HERE \s*/ at scripts/checkpatch.pl line 3885.
m/^(\+.*(?:do|\))){ <-- HERE / at scripts/checkpatch.pl line 4374.
It seems perfectly reasonable to do as the warning suggests and simply
escape the left brace in these three locations.
Link: http://lkml.kernel.org/r/20170607060135.17384-1-cyrilbur@gmail.com
Signed-off-by: Cyril Bur <cyrilbur@gmail.com>
Acked-by: Joe Perches <joe@perches.com>
commit 79e51b5c2deea542b3bb8c66e0d502230b017dde upstream.
Currently it is impossible to edit the value of a config symbol with a
prompt longer than (terminal width - 2) characters. dialog_inputbox()
calculates a negative x-offset for the input window and newwin() fails
as this is invalid. It also doesn't check for this failure, so it
busy-loops calling wgetch(NULL) which immediately returns -1.
The additions in the offset calculations also don't match the intended
size of the window.
Limit the window size and calculate the offset similarly to
show_scroll_win().
Fixes: 692d97c380c6 ("kconfig: new configuration interface (nconfig)")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 82031ea29e454b574bc6f49a33683a693ca5d907 upstream.
Adding -no-PIE to the fstack protector check. -no-PIE was introduced
before -fstack-protector so there is no need for a runtime check.
Without it the build stops:
|Cannot use CONFIG_CC_STACKPROTECTOR_STRONG: -fstack-protector-strong available but compiler is broken
due to -mcmodel=kernel + -fPIE if -fPIE is enabled by default.
Tagging it stable so it is possible to compile recent stable kernels as
well.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
This reverts commit fcf5e5198b447969ed2a56ec335dae3c695a6b46 which is
548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Cc: Borislav Petkov <bp@suse.de>
commit 548acf19234dbda5a52d5a8e7e205af46e9da840 upstream.
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
commit b2e1c26f0b62531636509fbcb6dab65617ed8331 upstream.
glibc recently did a sync up (94e73c95d9b5 "elf.h: Sync with the gabi
webpage") that added a #define for EM_METAG but did not add relocations
This triggers build errors:
scripts/recordmcount.c: In function 'do_file':
scripts/recordmcount.c:466:28: error: 'R_METAG_ADDR32' undeclared (first use in this function)
case EM_METAG: reltype = R_METAG_ADDR32;
scripts/recordmcount.c:466:28: note: each undeclared identifier is reported only once for each function it appears in
scripts/recordmcount.c:468:20: error: 'R_METAG_NONE' undeclared (first use in this function)
rel_type_nop = R_METAG_NONE;
Work around this change with some more #ifdefery for the relocations.
Fedora Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1354034
Link: http://lkml.kernel.org/r/1468005530-14757-1-git-send-email-labbott@redhat.com
Cc: James Hogan <james.hogan@imgtec.com>
Fixes: 00512bdd4573 ("metag: ftrace support")
Reported-by: Ross Burton <ross.burton@intel.com>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit b3c0a4dab7e35a9b6d69c0415641d2280fdefb2b upstream.
Because of an improper dereference, a stray 'C' character was output to
the modalias when no 'compatible' was specified. This is the case for
some old PowerMac drivers which only set the 'name' property. Fix it to
let them match again.
Reported-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Tested-by: Mathieu Malaterre <malat@debian.org>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Fixes: 6543becf26fff6 ("mod/file2alias: make modalias generation safe for cross compiling")
commit 65a9f31c5042e5bb50d30ed8ae374044be561054 upstream.
After commit 21a59991ce0c ("scripts/package/Makefile: rpmbuild is needed
for rpm targets"), it is no longer possible to specify RPMOPTS.
For example, we can no longer able to control _topdir using the following
make command.
make RPMOPTS="--define '_topdir /home/xyz/workspace/'" binrpm-pkg
Fixes: 21a59991ce0c ("scripts/package/Makefile: rpmbuild is needed for rpm targets")
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 upstream.
gcc-6 started warning by default about variables that are not
used anywhere and that are marked 'const', generating many
false positives in an allmodconfig build, e.g.:
arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=]
arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=]
drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=]
drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=]
drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=]
drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=]
This is similar to the existing -Wunused-but-set-variable warning
that was added in an earlier release and that we disable by default
now and only enable when W=1 is set, so it makes sense to do
the same here. Once we have eliminated the majority of the
warnings for both, we can put them back into the default list.
We probably want this in backport kernels as well, to allow building
them with gcc-6 without introducing extra warnings.
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
commit 6b87b70c5339f30e3c5b32085e69625906513dc2 upstream.
Prior to 3.13 make allmodconfig KCONFIG_ALLCONFIG=/dev/null used
to be equivalent to make allmodconfig; these days it hardwires MODULES to n.
In fact, any KCONFIG_ALLCONFIG that doesn't set MODULES explicitly is
treated as if it set it to n.
Regression had been introduced by commit cfa98f ("kconfig: do not
override symbols already set"); what happens is that conf_read_simple()
does sym_calc_value(modules_sym) on exit, which leaves SYMBOL_VALID set and
has conf_set_all_new_symbols() skip modules_sym.
It's pretty easy to fix - simply move that call of sym_calc_value()
into the callers, except for the ones in KCONFIG_ALLCONFIG handling.
Objections?
Fixes: cfa98f2e0ae9 ("kconfig: do not override symbols already set")
commit c8b08ca558c0067bc9e15ce3f1e70af260410bb2 upstream.
mkspec is copying built kernel to temporrary location
/boot/vmlinuz-$KERNELRELEASE-rpm
and runs installkernel on it. This however directly leads to grub2
menuentry for this suffixed binary being generated as well during the run
of installkernel script.
Later in the process the temporary -rpm suffixed files are removed, and
therefore we end up with spurious (and non-functional) grub2 menu entries
for each installed kernel RPM.
Fix that by using a different temporary name (prefixed by '.'), so that
the binary is not recognized as an actual kernel binary and no menuentry
is created for it.
Fixes: 3c9c7a14b627 ("rpm-pkg: add %post section to create initramfs and grub hooks")
commit 42f9d3c6888bceef6dc7ba72c77acf47347dcf05 upstream.
Documentation/Changes still lists this as the minimal required version,
so it ought to remain usable for the time being.
Fixes: d2036f30cf ("scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target")
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
commit 1b669e713f277a4d4b3cec84e13d16544ac8286d upstream.
& is no longer allowed in column 0, since Coccinelle 1.0.4.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Tested-by: Nishanth Menon <nm@ti.com>
commit 4b7b1ef2c2f83d702272555e8adb839a50ba0f8e upstream.
The ld-version.sh script fails on some versions of awk with the
following error, resulting in build failures for MIPS:
awk: scripts/ld-version.sh: line 4: regular expression compile failed (missing '(')
This is due to the regular expression ".*)", meant to strip off the
beginning of the ld version string up to the close bracket, however
brackets have a meaning in regular expressions, so lets escape it so
that awk doesn't expect a corresponding open bracket.
Fixes: ccbef1674a15 ("Kbuild, lto: add ld-version and ld-ifversion ...")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Tested-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Cc: Michal Marek <mmarek@suse.com>
Cc: linux-mips@linux-mips.org
Cc: linux-kbuild@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/12838/
commit a7df4716d19594b7b3f106f0bc0ca1c548e508e6 upstream.
Similarly to commit fb1770aa78a43530940d0c2dd161e77bc705bdac, with gcc 5
on Ubuntu and CONFIG_STATIC_LINK=y I was seeing these linker errors:
/usr/lib/gcc/x86_64-linux-gnu/5/../../../x86_64-linux-gnu/librt.a(timer_create.o): In function `__timer_create_new':
(.text+0xcd): undefined reference to `pthread_once'
(.text+0x126): undefined reference to `pthread_attr_init'
(.text+0x168): undefined reference to `pthread_attr_setdetachstate'
Obviously we also need -lpthread for librt.a.
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
commit 72214a24a7677d4c7501eecc9517ed681b5f2db2 upstream.
In Python3+ print is a function so the old syntax is not correct
anymore:
$ ./scripts/bloat-o-meter vmlinux.o vmlinux.o.old
File "./scripts/bloat-o-meter", line 61
print "add/remove: %s/%s grow/shrink: %s/%s up/down: %s/%s (%s)" % \
SyntaxError: invalid syntax
Fix by calling print as a function.
Tested on python 2.7.11, 3.5.1
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 2e50c4bef77511b42cc226865d6bc568fa7f8769 upstream.
If a text section starts out with a data blob before the first
function start label, disassembly parsing doing in recordmcount.pl
gets confused on powerpc, leading to creation of corrupted module
objects.
This was not a problem so far since the compiler would never create
such text sections. However, this has changed with a recent change
in GCC 6 to support distances of > 2GB between a function and its
assoicated TOC in the ELFv2 ABI, exposing this problem.
There is already code in recordmcount.pl to handle such data blobs
on the sparc64 platform. This patch uses the same method to handle
those on powerpc as well.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Ulrich Weigand <ulrich.weigand@de.ibm.com>
Fix build warning:
scripts/recordmcount.c:589:4: warning: format not a string
literal and no format arguments [-Wformat-security]
sprintf("%s: failed\n", file);
Fixes: a50bd43935586 ("ftrace/scripts: Have recordmcount copy the object file")
Link: http://lkml.kernel.org/r/1451516801-16951-1-git-send-email-colin.king@canonical.com
Cc: Li Bin <huawei.libin@huawei.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: stable@vger.kernel.org # 2.6.37+
Russell King found that he had weird side effects when compiling the kernel
with hard linked ccache. The reason was that recordmcount modified the
kernel in place via mmap, and when a file gets modified twice by
recordmcount, it will complain about it. To fix this issue, Russell wrote a
patch that checked if the file was hard linked more than once and would
unlink it if it was.
Linus Torvalds was not happy with the fact that recordmcount does this in
place modification. Instead of doing the unlink only if the file has two or
more hard links, it does the unlink all the time. In otherwords, it always
does a copy if it changed something. That is, it does the write out if a
change was made.
recordmcount edits the file in-place, which can cause problems when
using ccache in hardlink mode. Arrange for recordmcount to break a
hardlinked object.
Link: http://lkml.kernel.org/r/E1a7MVT-0000et-62@rmk-PC.arm.linux.org.uk
On gcc Ubuntu 4.8.4-2ubuntu1~14.04, linking vmlinux fails with:
arch/um/os-Linux/built-in.o: In function `os_timer_create':
/android/kernel/android/arch/um/os-Linux/time.c:51: undefined reference to `timer_create'
arch/um/os-Linux/built-in.o: In function `os_timer_set_interval':
/android/kernel/android/arch/um/os-Linux/time.c:84: undefined reference to `timer_settime'
arch/um/os-Linux/built-in.o: In function `os_timer_remain':
/android/kernel/android/arch/um/os-Linux/time.c:109: undefined reference to `timer_gettime'
arch/um/os-Linux/built-in.o: In function `os_timer_one_shot':
/android/kernel/android/arch/um/os-Linux/time.c:132: undefined reference to `timer_settime'
arch/um/os-Linux/built-in.o: In function `os_timer_disable':
/android/kernel/android/arch/um/os-Linux/time.c:145: undefined reference to `timer_settime'
This is because -lrt appears in the generated link commandline
after arch/um/os-Linux/built-in.o. Fix this by removing -lrt from
arch/um/Makefile and adding it to the UM-specific section of
scripts/link-vmlinux.sh.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Changeset 4d73270192ec('scripts/kernel-doc: Replacing highlights
hash by an array') broke compatibility of the kernel-doc script with
older versions of perl by using "keys ARRAY" syntax with is available
only on Perl 5.12 or newer, according with:
http://perldoc.perl.org/functions/keys.html
Restore backward compatibility by replacing "foreach my $k (keys ARRAY)"
by a C-like variant: "for (my $k = 0; $k < !ARRAY; $k++)"
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates from Michal Marek:
"This is the non-critical part of kbuild:
- several coccinelle updates
- make deb-pkg creates an armhf package if CONFIG_VFP=y
- make tags understands some more powerpc macros"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
coccinelle: Improve checking for missing NULL terminators
coccinelle: ifnullfree: handle various destroy functions
coccinelle: ifnullfree: various cleanups
cocinelle: iterators: semantic patch to delete unneeded of_node_put
deb-pkg: Add automatic support for armhf architecture
scripts/coccinelle: fix typos
coccinelle: misc: remove "complex return code" warnings
Coccinelle: fix incorrect -include option transformation
coccinelle: tests: improve odd_ptr_err.cocci
coccinelle: misc: move constants to the right
scripts/tags.sh: Teach tags about some powerpc macros
Pull kconfig updates from Michal Marek:
- 'make xconfig' ported to Qt5, dropping support for Qt3
- merge_config.sh supports a single-input-file mode and also respects
$KCONFIG_CONFIG
- Fix for incorrect display of >= and > in dependency expressions
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (44 commits)
Add current selection check.
Use pkg-config to find Qt 4 and 5 instead of direct qmake
kconfig: Fix copy&paste error
kconfig/merge_config.sh: Accept a single file
kconfig/merge_config.sh: Support KCONFIG_CONFIG
Update the buildsystem for KConfig finding Qt
Port xconfig to Qt5 - Update copyright.
Port xconfig to Qt5 - Fix goParent issue.
Port xconfig to Qt5 - on Back clicked, deselect old item.
Port xconfig to Qt5 - Add(back) one click checkbox toggle.
Port xconfig to Qt5 - Add(back) lineedit editing.
Port xconfig to Qt5 - Remove some commented code.
Port xconfig to Qt5 - Source format.
Port xconfig to Qt5 - Add horizontal scrollbar, and scroll per pixel.
Port xconfig to Qt5 - Change ConfigItem constructor parent type.
Port xconfig to Qt5 - Disable ConfigList soring
Port xconfig to Qt5 - Remove ConfigList::updateMenuList template.
Port xconfig to Qt5 - Add ConfigList::mode to initializer list.
Port xconfig to Qt5 - Add ConfigItem::nextItem to initializer list.
Port xconfig to Qt5 - Tree widget set column titles.
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Nothing exciting, minor tweaks and cleanups"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
scripts: [modpost] add new sections to white list
modpost: Add flag -E for making section mismatches fatal
params: don't ignore the rest of cmdline if parse_one() fails
modpost: abort if a module symbol is too long
Merge second patch-bomb from Andrew Morton:
- most of the rest of MM
- procfs
- lib/ updates
- printk updates
- bitops infrastructure tweaks
- checkpatch updates
- nilfs2 update
- signals
- various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc,
dma-debug, dma-mapping, ...
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits)
ipc,msg: drop dst nil validation in copy_msg
include/linux/zutil.h: fix usage example of zlib_adler32()
panic: release stale console lock to always get the logbuf printed out
dma-debug: check nents in dma_sync_sg*
dma-mapping: tidy up dma_parms default handling
pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode
kexec: use file name as the output message prefix
fs, seqfile: always allow oom killer
seq_file: reuse string_escape_str()
fs/seq_file: use seq_* helpers in seq_hex_dump()
coredump: change zap_threads() and zap_process() to use for_each_thread()
coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP
signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT)
signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread()
signal: turn dequeue_signal_lock() into kernel_dequeue_signal()
signals: kill block_all_signals() and unblock_all_signals()
nilfs2: fix gcc uninitialized-variable warnings in powerpc build
nilfs2: fix gcc unused-but-set-variable warnings
MAINTAINERS: nilfs2: add header file for tracing
nilfs2: add tracepoints for analyzing reading and writing metadata files
Global and static variables don't need to be initialized to 0.
There is already a test for this but the output message doesn't
mention booleans initialized to false.
Improve the output message and the test by adding various forms
with possible specific integer types and possible multiple zeros.
Miscellanea:
o Use a variable to hold the possible 0 test
Signed-off-by: Shailendra Verma <shailendra.v@samsung.com>
Tested-by: Shailendra Verma <shailendra.v@samsung.com>
Including BUG and stack dumps in commit logs makes checkpatch produce some
false positive warning messages.
checkpatch has multiple types of false positives:
o Commit message lines > 75 chars
o Stack dump address are mistaken for git commit IDs
o Link: and Fixes: lines are allowed to be > 75 chars.
o Fixes: style doesn't require ("<commit_description>")
parentheses and double quotes like other uses of
git commit ID and description.
Fix these.
Miscellanea:
o Move the test for checking $commit_log_possible_stack_dump
above the test for a long line commit message
o Add test for hex address surrounded by square or angle brackets
Reported-by: Stephen Smalley <sds@tycho.nsa.gov>
Reviewer output currently does not include the subsystem
that matched. Add it.
Miscellanea:
o Add a get_subsystem_name routine to centralize this
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Lee Jones <lee.jones@linaro.org>
We don't consistenly document the default value next to the option
listing, but we do have a list of defaults here, so let's keep it up to
date.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Many flag options are boolean and support both a positive and a negative
invocation from the command line. Some of these are even mentioned by
example (e.g., --nogit is mentioned as a default option), but they aren't
explicitly mentioned in the list of options. It happens that some of
these are pretty important, as they are default-on, and to turn them off,
you have to know about the --no-foo version.
Rather than clutter the whole help text with bracketed '--[no]foo', let's
just mention the general rule, a la 'man gcc'.
Though it appears that Perl's GetOptions will take either, the latter is
not documented in the options listing.
I really haven't used this option much myself, so feel free to improve on
the documentation for it. I just noticed it while inspecting this script
for undocumented features.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracking updates from Steven Rostedt:
"Most of the changes are clean ups and small fixes. Some of them have
stable tags to them. I searched through my INBOX just as the merge
window opened and found lots of patches to pull. I ran them through
all my tests and they were in linux-next for a few days.
Features added this release:
- Module globbing. You can now filter function tracing to several
modules. # echo '*:mod:*snd*' > set_ftrace_filter (Dmitry Safonov)
- Tracer specific options are now visible even when the tracer is not
active. It was rather annoying that you can only see and modify
tracer options after enabling the tracer. Now they are in the
options/ directory even when the tracer is not active. Although
they are still only visible when the tracer is active in the
trace_options file.
- Trace options are now per instance (although some of the tracer
specific options are global)
- New tracefs file: set_event_pid. If any pid is added to this file,
then all events in the instance will filter out events that are not
part of this pid. sched_switch and sched_wakeup events handle next
and the wakee pids"
* tag 'trace-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (68 commits)
tracefs: Fix refcount imbalance in start_creating()
tracing: Put back comma for empty fields in boot string parsing
tracing: Apply tracer specific options from kernel command line.
tracing: Add some documentation about set_event_pid
ring_buffer: Remove unneeded smp_wmb() before wakeup of reader benchmark
tracing: Allow dumping traces without tracking trace started cpus
ring_buffer: Fix more races when terminating the producer in the benchmark
ring_buffer: Do no not complete benchmark reader too early
tracing: Remove redundant TP_ARGS redefining
tracing: Rename max_stack_lock to stack_trace_max_lock
tracing: Allow arch-specific stack tracer
recordmcount: arm64: Replace the ignored mcount call into nop
recordmcount: Fix endianness handling bug for nop_mcount
tracepoints: Fix documentation of RCU lockdep checks
tracing: ftrace_event_is_function() can return boolean
tracing: is_legal_op() can return boolean
ring-buffer: rb_event_is_commit() can return boolean
ring-buffer: rb_per_cpu_empty() can return boolean
ring_buffer: ring_buffer_empty{cpu}() can return boolean
ring-buffer: rb_is_reader_page() can return boolean
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"Here is the first batch of updates for sound system on 4.4-rc1.
Again at this time, the update looks fairly calm; no big changes in
either ALSA core or ASoC infrastructures, rather all small cleanups,
in addition to the new stuff as usual.
The biggest changes are about Firewire sound devices. It gained lots
of new device support, and MIDI functionality. Also there are updates
for a few still working-in-progress stuff (topology API and ASoC
skylake), too. But overall, this update should give no big surprise.
Some highlights are below:
Core:
- A few more Kconfig items for tinification; it's marked as EXPERT,
so normal user should't be bothered :)
- Refactoring with a new PCM hw_constraint helper
- Removal of unused transfer_ack_{begin,end} PCM callbacks
Firewire:
- Restructuring of code subtree, lots of refactoring
- Support AMDTP variants
- New driver for Digidesign 002/003 family
- Adds support for TASCAM FireOne to ALSA OXFW driver
- Add MIDI support to TASCAM and Digi00x devices
HD-Audio:
- Automated modalias generation for codec drivers, finally
- Improvement on heuristics for setting mixer name
- A few fixes for longstanding bugs on Creative CA0132 cards
- Addition of audio rate callback with i915 communication
- Fix suspend issue on recent Dell XPS
- Intel Lewisburg controller support
ASoC:
- Updates to the topology userspace interface
- Big updates to the Renesas support (rcar)
- More updates for supporting Intel Sky Lake systems
- New drivers for Asahi Kasei Microdevices AK4613, Allwinnner A10,
Cirrus Logic WM8998, Dialog DA7219, Nuvoton NAU8825, Rockchip
S/PDIF, and Atmel class D amplifier
USB-Audio:
- A fix for newer Roland MIDI devices
- Quirks and workarounds for Zoom R16/24 device
Misc:
- A few fixes for some old Cirrus CS46xx PCI sound boards
- Yet another fixes for some old ESS Maestro3 PCI sound boards"
* tag 'sound-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (330 commits)
ALSA: hda - Add Intel Lewisburg device IDs Audio
ALSA: hda - Apply pin fixup for HP ProBook 6550b
ALSA: hda - Fix lost 4k BDL boundary workaround
ALSA: maestro3: Fix Allegro mute until master volume/mute is touched
ALSA: maestro3: Enable docking support for Dell Latitude C810
ALSA: firewire-digi00x: add another rawmidi character device for MIDI control ports
ALSA: firewire-digi00x: add MIDI operations for MIDI control port
ALSA: firewire-digi00x: rename identifiers of MIDI operation for physical ports
ALSA: cs46xx: Fix suspend for all channels
ALSA: cs46xx: Fix Duplicate front for CS4294 and CS4298 codecs
ALSA: DocBook: Add soc-ops.c and soc-compress.c
ALSA: hda - Add / fix kernel doc comments
ALSA: Constify ratden/ratnum constraints
ALSA: hda - Disable 64bit address for Creative HDA controllers
ALSA: hda/realtek - Dell XPS one ALC3260 speaker no sound after resume back
ALSA: hda/ca0132 - Convert leftover pr_info() and pr_err()
ASoC: fsl: Use #ifdef instead of #if for CONFIG_PM_SLEEP
ASoC: rt5645: Sort the order for register bit defines
ASoC: dwc: add check for master/slave format
ASoC: rt5645: Add the HWEQ for the speaker output
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
- Kconfig: remove BE-only platforms from LE kernel build from Boqun
Feng
- Refresh ps3_defconfig from Geoff Levand
- Emit GNU & SysV hashes for the vdso from Michael Ellerman
- Define an enum for the bolted SLB indexes from Anshuman Khandual
- Use a local to avoid multiple calls to get_slb_shadow() from Michael
Ellerman
- Add gettimeofday() benchmark from Michael Neuling
- Avoid link stack corruption in __get_datapage() from Michael Neuling
- Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar
K.V
- Add ppc64le_defconfig from Michael Ellerman
- pseries: extract of_helpers module from Andy Shevchenko
- Correct string length in pseries_of_derive_parent() from Nathan
Fontenot
- Free the MSI bitmap if it was slab allocated from Denis Kirjanov
- Shorten irq_chip name for the SIU from Christophe Leroy
- Wait 1s for secondaries to enter OPAL during kexec from Samuel
Mendoza-Jonas
- Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V
- powerpc/pseries/hvcserver: don't memset pi_buff if it is null from
Colin Ian King
- Disable hugepd for 64K page size, from Aneesh Kumar K.V
- Differentiate between hugetlb and THP during page walk from Aneesh
Kumar K.V
- Make PCI non-optional for pseries from Michael Ellerman
- Individual System V IPC system calls from Sam bobroff
- Add selftest of unmuxed IPC calls from Michael Ellerman
- discard .exit.data at runtime from Stephen Rothwell
- Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul
Gortmaker
- Use of_get_next_parent to simplify code from Christophe Jaillet
- Paginate some xmon output from Sam bobroff
- Add some more elements to the xmon PACA dump from Michael Ellerman
- Allow the tm-syscall selftest to build with old headers from Michael
Ellerman
- Run EBB selftests only on POWER8 from Denis Kirjanov
- Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael
Ellerman
- Avoid reference to potentially freed memory in prom.c from Christophe
Jaillet
- Quieten boot wrapper output with run_cmd from Geoff Levand
- EEH fixes and cleanups from Gavin Shan
- Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan
- Use of_get_next_parent() in of_get_ibm_chip_id() from Michael
Ellerman
- Fix section mismatch warning in msi_bitmap_alloc() from Denis
Kirjanov
- Fix ps3-lpm white space from Rudhresh Kumar J
- Fix ps3-vuart null dereference from Colin King
- nvram: Add missing kfree in error path from Christophe Jaillet
- nvram: Fix function name in some errors messages, from Christophe
Jaillet
- drivers/macintosh: adb: fix misleading Kconfig help text from Aaro
Koskinen
- agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov
- cxl: Free virtual PHB when removing from Andrew Donnellan
- scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from
Michael Ellerman
- scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building
with O= from Michael Ellerman
- Freescale updates from Scott: Highlights include 64-bit book3e
kexec/kdump support, a rework of the qoriq clock driver, device tree
changes including qoriq fman nodes, support for a new 85xx board, and
some fixes.
- MPC5xxx updates from Anatolij: Highlights include a driver for
MPC512x LocalPlus Bus FIFO with its device tree binding
documentation, mpc512x device tree updates and some minor fixes.
* tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits)
powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc()
powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id()
powerpc/pseries: Correct string length in pseries_of_derive_parent()
powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry
powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s)
powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan
powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes
powerpc: handle error case in cpm_muram_alloc()
powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake
powerpc/book3e-64: Enable kexec
powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop
powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32
powerpc/book3e-64/kexec: Enable SMP release
powerpc/book3e-64/kexec: create an identity TLB mapping
powerpc/book3e-64: Don't limit paca to 256 MiB
powerpc/book3e/kdump: Enable crash_kexec_wait_realmode
powerpc/book3e: support CONFIG_RELOCATABLE
powerpc/booke64: Fix args to copy_and_flush
powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts
powerpc/e6500: kexec: Handle hardware threads
Pull documentation update from Jon Corbet:
"There is a nice new document from Neil on how pathname lookups work
and some new CAN driver documentation. Beyond that, we have
kernel-doc fixes, a bit more work to support reproducible builds, and
the usual collection of small fixes"
* tag 'docs-for-linus' of git://git.lwn.net/linux: (34 commits)
Documentation: add new description of path-name lookup.
Documentation/vm/slub.txt: document slabinfo-gnuplot.sh
Doc: ABI/stable: Fix typo in ABI/stable
doc: Clarify that nmi_watchdog param is for hardlockups
Typo correction for description in gpio document.
DocBook: Fix kernel-doc to be case-insensitive for private:
kernel-docs.txt: update kernelnewbies reference
Doc:kvm: Fix typo in Doc/virtual/kvm
Documentation/Changes: Add bc in "Current Minimal Requirements" section
Documentation/email-clients.txt: remove trailing whitespace
DocBook: Use a fixed encoding for output
MAINTAINERS: The docs tree has moved
Docs/kernel-parameters: Add earlycon devicetree usage
SubmittingPatches: make Subject examples match the de facto standard
Documentation: gpio: mention that <function>-gpio has been deprecated
Documentation: cgroups: just fix a few typos
Documentation: Update kselftest.txt
Documentation: DMA API: Be more explicit that nents is always the same
Documentation: Update the default value of crashkernel low
zram: update documentation
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem update from James Morris:
"This is mostly maintenance updates across the subsystem, with a
notable update for TPM 2.0, and addition of Jarkko Sakkinen as a
maintainer of that"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (40 commits)
apparmor: clarify CRYPTO dependency
selinux: Use a kmem_cache for allocation struct file_security_struct
selinux: ioctl_has_perm should be static
selinux: use sprintf return value
selinux: use kstrdup() in security_get_bools()
selinux: use kmemdup in security_sid_to_context_core()
selinux: remove pointless cast in selinux_inode_setsecurity()
selinux: introduce security_context_str_to_sid
selinux: do not check open perm on ftruncate call
selinux: change CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE default
KEYS: Merge the type-specific data with the payload data
KEYS: Provide a script to extract a module signature
KEYS: Provide a script to extract the sys cert list from a vmlinux file
keys: Be more consistent in selection of union members used
certs: add .gitignore to stop git nagging about x509_certificate_list
KEYS: use kvfree() in add_key
Smack: limited capability for changing process label
TPM: remove unnecessary little endian conversion
vTPM: support little endian guests
char: Drop owner assignment from i2c_driver
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"Media updates, including:
- Lots of improvements at the kABI documentation
- Split of Videobuf2 into a common part and a V4L2 specific one
- Split of the VB2 tracing events into a separate header file
- s5p-mfc got support for Exynos 5433
- v4l2 fixes for 64-bits alignment when running 32 bits userspace
on ARM
- Added support for SDR radio transmitter at core, vivid and hackrf
drivers
- Some y2038 fixups
- Some improvements at V4L2 colorspace support
- saa7164 converted to use the V4L2 core control framework
- several new boards additions, cleanups and fixups
PS: There are two patches for scripts/kernel-doc that are needed by
the documentation patches on Media. Jon is OK on merging those via
my tree"
* tag 'media/v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (146 commits)
[media] c8sectpfe: Remove select on CONFIG_FW_LOADER_USER_HELPER_FALLBACK
[media] DocBook media: update copyright/version numbers
[media] ivtv: Convert to get_user_pages_unlocked()
[media] media/v4l2-ctrls: fix setting autocluster to manual with VIDIOC_S_CTRL
[media] DocBook media: Fix a typo in encoder cmd
[media] DocBook: add SDR specific info to G_MODULATOR / S_MODULATOR
[media] DocBook: add SDR specific info to G_TUNER / S_TUNER
[media] hackrf: do not set human readable name for formats
[media] hackrf: add support for transmitter
[media] hackrf: switch to single function which configures everything
[media] hackrf: add control for RF amplifier
[media] DocBook: add modulator type field
[media] v4l: add type field to v4l2_modulator struct
[media] DocBook: document SDR transmitter
[media] v4l2: add support for SDR transmitter
[media] DocBook: document tuner RF gain control
[media] v4l2: add RF gain control
[media] v4l2: rename V4L2_TUNER_ADC to V4L2_TUNER_SDR
[media] media/vivid-osd: fix info leak in ioctl
[media] media: videobuf2: Move v4l2-specific stuff to videobuf2-v4l2
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big char/misc driver update for 4.4-rc1. Lots of
different driver and subsystem updates, hwtracing being the largest
with the addition of some new platforms that are now supported. Full
details in the shortlog.
All of these have been in linux-next for a long time with no reported
issues"
* tag 'char-misc-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (181 commits)
fpga: socfpga: Fix check of return value of devm_request_irq
lkdtm: fix ACCESS_USERSPACE test
mcb: Destroy IDA on module unload
mcb: Do not return zero on error path in mcb_pci_probe()
mei: bus: set the device name before running fixup
mei: bus: use correct lock ordering
mei: Fix debugfs filename in error output
char: ipmi: ipmi_ssif: Replace timeval with timespec64
fpga: zynq-fpga: Fix issue with drvdata being overwritten.
fpga manager: remove unnecessary null pointer checks
fpga manager: ensure lifetime with of_fpga_mgr_get
fpga: zynq-fpga: Change fw format to handle bin instead of bit.
fpga: zynq-fpga: Fix unbalanced clock handling
misc: sram: partition base address belongs to __iomem space
coresight: etm3x: adding documentation for sysFS's cpu interface
vme: 8-bit status/id takes 256 values, not 255
fpga manager: Adding FPGA Manager support for Xilinx Zynq 7000
ARM: zynq: dt: Updated devicetree for Zynq 7000 platform.
ARM: dt: fpga: Added binding docs for Xilinx Zynq FPGA manager.
ver_linux: proc/modules, limit text processing to 'sed'
