path: root/scripts
2009-02-27checkpatch: version 0.28Andy Whitcroft
Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: add __ref as a sparse modifierAndy Whitcroft
Add __ref as a sparse modifier. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: extend attribute testing to all modifiersAndy Whitcroft
We should allow testing of all modifiers not just attributes. Extend testing and test for all the know modifiers. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: a modifier is not an identifier at the end of a typeAndy Whitcroft
We must make sure we do not misrecognise a modifier as an Identifier when trying to match types. Prevent us matching this: void * __ref Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: pointer type star may have modifiers followingAndy Whitcroft
We may have any modifier following a pointer type star. Handle this: void * __user * __user foo; Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: correctly handle type spacing in the face of modifiersAndy Whitcroft
We need to handle interspersed modifiers in the middle of pointer types, for example: void * __user * __user bar; Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: do not warn about -p0 patches when checking filesAndy Whitcroft
We are triggering the -p0 check for our own diffs generated using --file command line option. Suppress this check for files. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27checkpatch: make in_atomic ok in the coreAndy Whitcroft
We say that in_atomic() is ok in the core kernel, but then always report it regardless of where in the kernel it is. Keep quiet if it is used in kernel/*. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: create the source symlink earlier in the objdir scripts: add x86 64 bit support to the markup_oops.pl script scripts: add x86 register parser to markup_oops.pl kbuild: add sys_* entries for syscalls in tags kbuild: fix tags generation of config symbols bootgraph: fix for use with dot symbols kbuild: add vmlinux to kernel rpm kbuild,setlocalversion: shorten the make time when using svn
2009-02-17HID: fix bus endianity in file2aliasJiri Slaby
Fix endianness of bus member of hid_device_id in modpost. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reported-by: Nye Liu <nyet@mrv.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-02-15scripts: add x86 64 bit support to the markup_oops.pl scriptArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15scripts: add x86 register parser to markup_oops.plArjan van de Ven
An oops dump also contains the register values. This patch parses these for (32 bit) x86, and then annotates the disassembly with these values; this helps in analysis of the oops by the developer, for example, NULL pointer or other pointer bugs show up clearly this way. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild: add sys_* entries for syscalls in tagsRabin Vincent
Currently, it is no longer possible to use the tags file to jump to system call function definitions with sys_foo, because the definitions are obscured by use of the SYSCALL_DEFINE* macros. This patch adds the appropriate option to ctags to make it see through the macro. Also, it adds the ENTRY() work already done for Exuberant to Emacs too. Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild: fix tags generation of config symbolsAlexey Dobriyan
commit 4f628248a578585472e19e4cba2c604643af8c6c aka "kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscope" breaks tags generation for Kconfig symbols. Steps to reproduce: make tags vi -t PROC_FS It should jump to 'config PROC_FS' line. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Tested-by: Pete Wyckoff <pw@padd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15bootgraph: fix for use with dot symbolsMichael Neuling
powerpc has dot symbols, so the dmesg output looks like: <4>[ 0.327310] calling .migration_init+0x0/0x9c @ 1 <4>[ 0.327595] initcall .migration_init+0x0/0x9c returned 1 after 0 usecs The below fixes bootgraph.pl so it handles this correctly. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild: add vmlinux to kernel rpmJosh Hunt
We are building an automated system to test kernels weekly and need to provide an rpm to our QA dept. We would like to use the ability to create kernel rpms already in the kernel's Makefile, but need the vmlinux file included in the rpm for later debugging. This patch adds a compressed vmlinux to the kernel rpm when doing a make rpm-pkg or binrpm-pkg and upon install places the vmlinux file in /boot. Signed-off-by: Josh Hunt <josh@scalex86.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-15kbuild,setlocalversion: shorten the make time when using svnMike Frysinger
Don't bother doing `svn st` as it takes a retarded amount of time when the source is cold Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-02-11kernel-doc: fix syscall wrapper processingRandy Dunlap
Fix kernel-doc processing of SYSCALL wrappers. The SYSCALL wrapper patches played havoc with kernel-doc for syscalls. Syscalls that were scanned for DocBook processing reported warnings like this one, for sys_tgkill: Warning(kernel/signal.c:2285): No description found for parameter 'tgkill' Warning(kernel/signal.c:2285): No description found for parameter 'pid_t' Warning(kernel/signal.c:2285): No description found for parameter 'int' because the macro parameters all "look like" function parameters, although they are not: /** * sys_tgkill - send signal to one specific thread * @tgid: the thread group ID of the thread * @pid: the PID of the thread * @sig: signal to be sent * * This syscall also checks the @tgid and returns -ESRCH even if the PID * exists but it's not belonging to the target process anymore. This * method solves the problem of threads exiting and PIDs getting reused. */ SYSCALL_DEFINE3(tgkill, pid_t, tgid, pid_t, pid, int, sig) { ... This patch special-cases the handling SYSCALL_DEFINE* function prototypes by expanding them to long sys_foobar(type1 arg1, type1 arg2, ...) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: fix kbuild.txt typos kbuild: print usage with no arguments in scripts/config Revert "kbuild: strip generated symbols from *.ko"
2009-01-20PNP: fix broken pnp lowercasing for acpi module aliasesKay Sievers
Based on a patch from Brian, who identified the issue. Signed-off-by: Bryan Kadzban <bryan@kadzban.is-a-geek.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-15checkpatch: version: 0.27Andy Whitcroft
2009-01-15checkpatch: struct seq_operations should normally be constAndy Whitcroft
In the general use case struct seq_operations should be a const object. Check for and warn where it is not. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15checkpatch: if should not continue a preceeding braceAndy Whitcroft
We should not be continuing a braced section with an if, for example: if (...) { } if (...) { } Detect this and suggest adding a newline. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15checkpatch: allow parentheses on return handle array valuesAndy Whitcroft
When we allow return to have surrounding parentheses when containing comparison operators we are not correctly handling the case where the values contain array sufffixes. Squash them. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15checkpatch: type/cast spacing should not check prefix spacingAndy Whitcroft
We should not be complaining about the prefix spacing for types and casts. We are triggering here because the check for spacing between '*'s is overly loose. Tighten this up. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15checkpatch: handle missing #if open in contextAndy Whitcroft
If the #if opening statement is not in the context then the context stack can be empty. Handle this by ensuring there is always a blank entry in the stack. Signed-off-by: Andy Whitcroft <apw@canonical.com> Tested-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14kbuild: print usage with no arguments in scripts/configAndi Kleen
Requested by Sam. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-12script: improve markup_oops.pl to also decode oopses in modulesArjan van de Ven
There has been some light flamewar on lkml about decoding oopses in modules (as part of the crashdump flamewar). Now this isn't rocket science, just the markup_oops.pl script cheaped out and didn't handle modules. But really; a flamewar all about that?? What happened to C++ in the kernel or reading files from inside the kernel? This patch adds module support to markup_oops.pl; it's not the most pretty perl but it works for my testcases... Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-10bootgraph: make the bootgraph script show async waiting timeArjan van de Ven
It is useful for diagnosing boot performance to see where async function calls are waiting on serialization... this patch adds this functionality to the bootgraph.pl script. The waiting time is shown as a half transparent, gray bar through the block that is waiting. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07kconfig: add script to manipulate .config files on the command lineAndi Kleen
I often change single options in .config files. Instead of using an editor or one of the frontends it's convenient to do this from the command line. It's also useful to do from automated build scripts when building different variants from a base config file. I extracted most of the CONFIG manipulation code from one of my build scripts into a new shell script scripts/config The script is not integrated with the normal Kconfig machinery and doesn't do any checking against Kconfig files, but just manipulates that text format. This is always done at make time anyways. I believe this script would be a useful standard addition for scripts/* Sample usage: ./scripts/config --disable smp Disable SMP in .config file ./scripts/config --file otherdir/.config --module e1000e Enable E1000E as module in otherdir/.config ./scripts/config --state smp y Check state of config option CONFIG_SMP After merging into git please make scripts/config executable Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07kbuild: reintroduce ALLSOURCE_ARCHS support for tags/cscopeJike Song
This patch reintroduce the ALLSOURCE_ARCHS support for tags/TAGS/ cscope targets. The Kbuild previously has this feature, but after moving the targets into scripts/tags.sh, ALLSOURCE_ARCHS disappears. It's something like this: $ make ALLSOURCE_ARCHS="x86 mips arm" tags cscope Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07bootchart: improve output based on Dave Jones' feedbackArjan van de Ven
Dave Jones, in his blog, had some feedback about the bootchart script: Primarily his complaint was that shorter delays weren't visualized. The reason for that was that too small delays will have their labels mixed up in the graph in an unreadable mess. This patch has a fix for this; for one, it makes the output wider, so more will fit. The second part is that smaller delays are now shown with a much smaller font for the label; while this isn't per se readable at a 1:1 zoom, at least you can zoom in with most SVG viewing applications and see what it is you are looking at. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-07fix modules_install via NFSSam Ravnborg
Rafael reported: I get the following error from 'make modules_install' on my test boxes: HOSTCC firmware/ihex2fw /home/rafael/src/linux-2.6/firmware/ihex2fw.c:268: fatal error: opening dependency file firmware/.ihex2fw.d: Read-only file system compilation terminated. make[3]: *** [firmware/ihex2fw] Error 1 make[2]: *** [_modinst_post] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 where the configuration is that the kernel is compiled on a build box with 'make O=<destdir> -j5' and then <destdir> is mounted over NFS read-only by each test box (full path to this directory is the same on the build box and on the test boxes). Then, I cd into <destdir>, run 'make modules_install' and get the error above. The issue turns out to be that we when we install firmware pick up the list of firmware blobs from firmware/Makefile. And this triggers the Makefile rules to update ihex2fw. There were two solutions for this issue: 1) Move the list of firmware blobs to a separate file 2) Avoid ihex2fw rebuild by moving it to scripts As I seriously beleive that the list of firmware blobs should be done in a fundamental different way solution 2) was selected. Reported-and-tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org>
2009-01-06checkpatch: version: 0.26Andy Whitcroft
2009-01-06checkpatch: fix the perlcritic errorsAndy Whitcroft
Clean up checkpatch using perlcritic. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: struct file_operations should normally be constAndy Whitcroft
In the general use case struct file_operations should be a const object. Check for and warn where it is not. As suggested by Steven and Ingo. Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: ensure we actually detect if assignments split across linesAndy Whitcroft
When checking for assignments within if conditionals we check the whole of the condition, but the match is performed using a line constrained regular expression. This means we can miss split conditionals or those on the second line. Allow the check to span lines. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: do not report nr_static as a static declarationAndy Whitcroft
Ensure we do not report identifiers containing the word static as static declarations. For example this should not be reported as an unecessary assignement of 0: long nr_static = 0; Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: track #ifdef/#else/#endif when tracking blocksAndy Whitcroft
When picking up a complete statement or block for analysis we cannot simply track open/close/etc parenthesis we must take into account preprocessor section boundaries. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: fix continuation detection when handling spacing on operatorsAndy Whitcroft
We are miscategorising a continuation fragment following an operator which may lead to us thinking that there is a space after it when there is not. Fix this up. Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: loosen spacing on typedef function checksAndy Whitcroft
Loosen spacing checks to correctly detect this valid use of a typedef: typedef struct rcu_data *(*get_data_func)(int); Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: try to catch missing VMLINUX_SYMBOL() in vmlinux.lds.hMike Frysinger
Seems like every other release we have someone who updates vmlinux.lds.h and adds C-visible symbols without VMLINUX_SYMBOL() around them. So start checking the file and reject assignments which have plain symbols on either side. [apw@canonical.com: soften the check, add tests] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: allow parentheses on return for comparisonsAndy Whitcroft
It seems to be a common idiom to include braces on conditionals in all contexts including return. Allow this exception to the return is not a function checks. Reported by Kay Sievers. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: Add warning for p0-patchesWolfram Sang
Some people work internally with -p0-patches which has the danger that one forgets to convert them to -p1 before mainlining. Bitten myself and seen p0-patches in mailing lists occasionally, this patch adds a warning to checkpatch.pl in case a patch is -p0. If you really want, you can fool this check to generate false positives, this is why it just spits a warning. Making the check 100% proof is trickier than it looks, so let's start with a version which catches the cases of real use. [apw@canonical.com: update message language, handle null prefix, add tests] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: update copyrightsAndy Whitcroft
2009-01-06checkpatch: version: 0.25Andy Whitcroft
Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: dissallow spaces between stars in pointer typesAndy Whitcroft
Disallow spaces within multiple pointer stars (*) in both casts and definitions. Both of these would now be reported: (char * *) char * *foo; Also now consistently detects and reports the attributes within these structures making the error report itself clearer. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: comment ends inside strings is most likely not an open commentAndy Whitcroft
When we are detecting whether a comment is open when we start a hunk we check for the first comment edge in the hunk and assume its inverse. However if the hunk contains something like below, then we will assume that a comment was open. Update this heuristic to see if the comment edge is obviously within double quotes and ignore it if so: foo(" */); Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06checkpatch: detect multiple bitfield declarationsAndy Whitcroft
Detect the colons (:) which make up secondary bitfield declarations and apply binary colon checks. For example the following is common idiom: int foo:1, bar:1; Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
