path: root/scripts
2012-12-10kbuild: Do not package /boot and /lib in make tar-pkgMichal Marek
commit fe04ddf7c2910362f3817c8156e41cbd6c0ee35d upstream. There were reports of users destroying their Fedora installs by a kernel tarball that replaces the /lib -> /usr/lib symlink. Let's remove the toplevel directories from the tarball to prevent this from happening. Reported-by: Andi Kleen <andi@firstfloor.org> Suggested-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz> [bwh: Fold in commit 3ce9e53e788881da0d5f3912f80e0dd6b501f304 to avoid conflicts] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13localmodconfig: Fix localyesconfig to set to 'y' not 'm'Yuta Ando
commit 4eae518d4b01b0cbf2f0d8edb5a6f3d6245ee8fb upstream. The kbuild target 'localyesconfig' has been same as 'localmodconfig' since the commit 50bce3e "kconfig/streamline_config.pl: merge local{mod,yes}config". The commit expects this script generates different configure depending on target, but it was not yet implemented. So I added code that sets to 'yes' when target is 'localyesconfig'. Link: http://lkml.kernel.org/r/1349101470-12243-1-git-send-email-yuta.and@gmail.com Signed-off-by: Yuta Ando <yuta.and@gmail.com> Cc: linux-kbuild@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@rostedt.homelinux.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13kbuild: Fix gcc -x syntaxJean Delvare
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream. The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13kbuild: make: fix if_changed when command contains backslashesSascha Hauer
commit c353acba28fb3fa1fd05fd6b85a9fc7938330f9c upstream. The call if_changed mechanism does not work when the command contains backslashes. This basically is an issue with lzo and bzip2 compressed kernels. The compressed binaries do not contain the uncompressed image size, so these use size_append to append the size. This results in backslashes in the executed command. With this if_changed always detects a change in the command and rebuilds the compressed image even if nothing has changed. Fix this by escaping backslashes in make-cmd Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-18x86, realmode: 16-bit real-mode code support for relocs toolH. Peter Anvin
A new option is added to the relocs tool called '--realmode'. This option causes the generation of 16-bit segment relocations and 32-bit linear relocations for the real-mode code. When the real-mode code is moved to the low-memory during kernel initialization, these relocation entries can be used to relocate the code properly. In the assembly code 16-bit segment relocations must be relative to the 'real_mode_seg' absolute symbol. Linear relocations must be relative to a symbol prefixed with 'pa_'. 16-bit segment relocation is used to load cs:ip in 16-bit code. Linear relocations are used in the 32-bit code for relocatable data references. They are declared in the linker script of the real-mode code. The relocs tool is moved to arch/x86/tools/relocs.c, and added new target archscripts that can be used to build scripts needed building an architecture. be compiled before building the arch/x86 tree. [ hpa: accelerating this because it detects invalid absolute relocations, a serious bug in binutils 2.22.52.0.x which currently produces bad kernels. ] Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Link: http://lkml.kernel.org/r/1336501366-28617-2-git-send-email-jarkko.sakkinen@intel.com Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: <stable@vger.kernel.org>
2012-04-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull build system failure fix from Michal Marek: "This fixes build failure with newer gcc that adds some internal symbols that end in "__mod_*_device_table", but are not actually the tables themselves." * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: Fix modpost failures in fedora 17
2012-04-18xz: Enable BCJ filters on SPARC and 32-bit x86Lasse Collin
The BCJ filters were meant to be enabled already on these archs, but the xz_wrap.sh script was buggy. Enabling the filters should give smaller kernel images. xz_wrap.sh will now use $SRCARCH instead of $ARCH to detect the architecture. That way it doesn't need to care about the subarchs (like i386 vs. x86_64) since the BCJ filters don't care either. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Acked-by: Jan Beulich <jbeulich@suse.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-18Fix modpost failures in fedora 17David Miller
The symbol table on x86-64 starts to have entries that have names like: _GLOBAL__sub_I_65535_0___mod_x86cpu_device_table They are of type STT_FUNCTION and this one had a length of 18. This matched the device ID validation logic and it barfed because the length did not meet the device type's criteria. -------------------- FATAL: arch/x86/crypto/aesni-intel: sizeof(struct x86cpu_device_id)=16 is not a modulo of the size of section __mod_x86cpu_device_table=18. Fix definition of struct x86cpu_device_id in mod_devicetable.h -------------------- These are some kind of compiler tool internal stuff being emitted and not something we want to inspect in modpost's device ID table validation code. So skip the symbol if it is not of type STT_OBJECT. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-04-16checkpatch: revert --strict test for net/ and drivers/net block comment styleJoe Perches
Revert the --strict test for the old preferred block comment style in drivers/net and net/ Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12kconfig: delete last traces of __enabled_ from autoconf.hPaul Gortmaker
We've now fixed IS_ENABLED() and friends to not require any special "__enabled_" prefixed versions of the normal Kconfig options, so delete the last traces of them being generated. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-12Revert "kconfig: fix __enabled_ macros definition for invisible and ↵Paul Gortmaker
un-selected symbols" This reverts commit 953742c8fe8ac45be453fee959d7be40cd89f920. Dumping two lines into autoconf.h for all existing Kconfig options results in a giant file (~16k lines) we have to process each time we compile something. We've weaned IS_ENABLED() and similar off of requiring the __enabled_ definitions so now we can revert the change which caused all the extra lines. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-09modpost: Fix modpost license checking of vmlinux.oFrank Rowand
Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols placing each of them in its own elf section. This sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux.o (which is not linked yet) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. [ This above is a slightly corrected version of the explanation of the problem, copied from commit 62a2635610db ("modpost: Fix modpost's license checking V3"). That commit fixed the problem for module object files, but not for vmlinux.o. This patch fixes modpost for vmlinux.o. ] Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-05Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge batch of fixes from Andrew Morton: "The simple_open() cleanup was held back while I wanted for laggards to merge things. I still need to send a few checkpoint/restore patches. I've been wobbly about merging them because I'm wobbly about the overall prospects for success of the project. But after speaking with Pavel at the LSF conference, it sounds like they're further toward completion than I feared - apparently davem is at the "has stopped complaining" stage regarding the net changes. So I need to go back and re-review those patchs and their (lengthy) discussion." * emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches) memcg swap: use mem_cgroup_uncharge_swap fix backlight: add driver for DA9052/53 PMIC v1 C6X: use set_current_blocked() and block_sigmask() MAINTAINERS: add entry for sparse checker MAINTAINERS: fix REMOTEPROC F: typo alpha: use set_current_blocked() and block_sigmask() simple_open: automatically convert to simple_open() scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open() libfs: add simple_open() hugetlbfs: remove unregister_filesystem() when initializing module drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback fs/xattr.c:setxattr(): improve handling of allocation failures fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed fs/xattr.c: suppress page allocation failure warnings from sys_listxattr() sysrq: use SEND_SIG_FORCED instead of force_sig() proc: fix mount -t proc -o AAA
2012-04-05scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()Julia Lawall
Find instances of an open-coded simple_open() and replace them with calls to simple_open(). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reported-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-02Subject: [PATCH] tags.sh: Add missing quotesStephen Boyd
When $remove_structs is empty a test for empty string will turn into test -n with no arguments meaning true. Add quotes so an empty string is tested and so that make cscope works again. Reported-and-tested-by: Jike Song <albcamus@gmail.com> Reported-by: Prarit Bhargava <prarit@redhat.com> Acked-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Unification of cmd_uimage among archs that use it - make headers_check tries harder before reporting a missing <linux/types.h> include - kbuild portability fix for shells that do not support echo -e - make clean descends into samples/ - setlocalversion grep fix - modpost typo fix - dtc warnings fix * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: setlocalversion: Use "grep -q" instead of piping output to "read dummy" modpost: fix ALL_INIT_DATA_SECTIONS Kbuild: centralize MKIMAGE and cmd_uimage definitions headers_check: recursively search for linux/types.h inclusion scripts/Kbuild.include: Fix portability problem of "echo -e" scripts: dtc: fix compile warnings kbuild: clean up samples directory kbuild: disable -Wmissing-field-initializers for W=1
2012-03-30Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull non-critical part of kbuild from Michal Marek: - New semantic patches, make coccicheck M= fix - make gtags speedup - make tags/TAGS always removes struct forward declarations - make deb-pkg fixes (some patches are still pending, I know) - scripts/patch-kernel fix from the last user of this script ;) * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/patch-kernel: digest kernel.org hosted .xz patches scripts/coccinelle/api/ptr_ret.cocci: semantic patch for ptr_err scripts: refactor remove structure forward declarations kbuild: incremental tags update for GNU Global coccinelle: semantic patch for bool issues coccinelle: semantic patch to check for PTR_ERR after reassignment coccinelle: semantic patch converting 0 test to null test coccinelle: semantic patch for missing iounmap coccinelle: semantic patch for missing clk_put kbuild: Fix out-of-tree build for 'make deb-pkg' kbuild: Only build linux-image package for UML kbuild: Fix link to headers in 'make deb-pkg' coccicheck: change handling of C={1,2} when M= is set
2012-03-30Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig bits from Michal Marek: "There is one fix for make oldconfig by Arnaud and updates to the merge_config.sh tool." * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: merge_config.sh: Add option to display redundant configs merge_config.sh: Set execute bit merge_config.sh: Use the first file as the initial config kconfig: fix new choices being skipped upon config update
2012-03-30scripts/patch-kernel: digest kernel.org hosted .xz patchesShawn Landden
kernel.org is hosting patches and kernel compressed with xz (lzma2+). Allow scripts/patch-kernel to decompress these files. Signed-off-by: Shawn Landden <shawnlandden@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-30merge_config.sh: Add option to display redundant configsJohn Stultz
Provide a -r option to display when fragments contain redundant options. This is really useful when breaking apart a config into fragments, as well as cleaning up older fragments. Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Acked-by: Bruce Ashfield <bruce.ashfield@windriver.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-30merge_config.sh: Set execute bitJohn Stultz
Somehow the merge_config.sh script didn't get its execute bit set when it was merged. Fix this. Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Acked-by: Bruce Ashfield <bruce.ashfield@windriver.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull more ARM updates from Russell King. This got a fair number of conflicts with the <asm/system.h> split, but also with some other sparse-irq and header file include cleanups. They all looked pretty trivial, though. * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits) ARM: fix Kconfig warning for HAVE_BPF_JIT ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds ARM: 7349/1: integrator: convert to sparse irqs ARM: 7259/3: net: JIT compiler for packet filters ARM: 7334/1: add jump label support ARM: 7333/2: jump label: detect %c support for ARM ARM: 7338/1: add support for early console output via semihosting ARM: use set_current_blocked() and block_sigmask() ARM: exec: remove redundant set_fs(USER_DS) ARM: 7332/1: extract out code patch function from kprobes ARM: 7331/1: extract out insn generation code from ftrace ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format ARM: 7351/1: ftrace: remove useless memory checks ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path ARM: Versatile Express: add NO_IOPORT ARM: get rid of asm/irq.h in asm/prom.h ARM: 7319/1: Print debug info for SIGBUS in user faults ARM: 7318/1: gic: refactor irq_start assignment ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop ARM: 7315/1: perf: add support for the Cortex-A7 PMU ...
2012-03-26setlocalversion: Use "grep -q" instead of piping output to "read dummy"Roland Dreier
In some circumstances (eg when running a build in an emacs shell buffer), I get a spew of messages like grep: writing output: Broken pipe from setlocalversion, because the "read" subshell apparently exits as soon as it reads one line and gives EPIPE to grep. It's not clear to me why this way of writing the check was used instead of just using grep -q to suppress output, but unless there is some deep reason I don't know, this way looks cleaner to me anyway, and gets rid of the ugly message spew. (I double checked at http://pubs.opengroup.org/onlinepubs/009604499/utilities/grep.html and "grep -q" is specified in POSIX / SuS, so hopefully even people cross-compiling the kernel on some bizarre host OS can't complain about this change) Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26scripts/coccinelle/api/ptr_ret.cocci: semantic patch for ptr_errJulia Lawall
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26modpost: fix ALL_INIT_DATA_SECTIONSJan Beulich
This was lacking a comma between two supposed to be separate strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: <stable@vger.kernel.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26scripts: refactor remove structure forward declarationsYang Bai
Since now it has some problems when generate TAGS, refactor this code. Now it will not show the error message and will remove declarations using emacs etags. Signed-off-by: Yang Bai <hamo.by@gmail.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26Kbuild: centralize MKIMAGE and cmd_uimage definitionsStephen Warren
All ARCHs have the same definition of MKIMAGE. Move it to Makefile.lib to avoid duplication. All ARCHs have similar definitions of cmd_uimage. Place a sufficiently parameterized version in Makefile.lib to avoid duplication. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Nicolas Pitre <nico@linaro.org> Tested-by: Mike Frysinger <vapier@gentoo.org> [Blackfin] Tested-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Guan Xuetao <gxt@mprc.pku.edu.cn> [unicore32] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26kbuild: incremental tags update for GNU GlobalJianbin Kang
GNU gtags support '-i' for updating tag files incrementally. It runs more quickly than generating new tags after kernel source update. Signed-off-by: Jianbin Kang <kjbmail@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-26headers_check: recursively search for linux/types.h inclusionBobby Powers
headers_check.pl currently emits some spurious warnings, especially for the drm headers, about using __[us]{8,16,32,64} types without including linux/types.h. Recursively search for types.h inclusion, avoiding circular references. Signed-off-by: Bobby Powers <bobbypowers@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-24scripts/Kbuild.include: Fix portability problem of "echo -e"Bernhard Walle
"echo -e" is a GNU extension. When cross-compiling the kernel on a BSD-like operating system (Mac OS X in my case), this doesn't work. One could install a GNU version of echo, put that in the $PATH before the system echo and use "/usr/bin/env echo", but the solution with printf is simpler. Since it is no disadvantage on Linux, I hope that gets accepted even if cross-compiling the Linux kernel on another Unix operating system is quite a rare use case. Signed-off-by: Bernhard Walle <bernhard@bwalle.de> Andreas Bießmann <andreas@biessmann.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-24merge_config.sh: Use the first file as the initial configJosh Boyer
Take the first config fragment and use it verbatim as the initial config set. This avoids running the verification loop for the first file, as nothing has actually been merged at this point. This significantly increases performance for large config fragments. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-24scripts: dtc: fix compile warningsFelipe Balbi
Fix following compile warnings: scripts/dtc/flattree.c: In function ‘flat_read_mem_reserve’: scripts/dtc/flattree.c:700:14: warning: variable ‘p’ set but not used [-Wunused-but-set-variable] scripts/dtc/dtc.c: In function ‘main’: scripts/dtc/dtc.c:104:17: warning: variable ‘check’ set but not used [-Wunused-but-set-variable] Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-03-24ARM: 7333/2: jump label: detect %c support for ARMRabin Vincent
Some versions of ARM GCC which do support asm goto, do not support the %c specifier. Since we need the %c to support jump labels on ARM, detect that too in the asm goto detection script to avoid build errors with these versions. http://gcc.gnu.org/bugzilla/show_bug.cgi?id=48637 Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-23checkpatch: check for quoted strings broken across linesJosh Triplett
checkpatch already makes an exception to the 80-column rule for quoted strings, and Documentation/CodingStyle recommends not splitting quoted strings across lines, because it breaks the ability to grep for the string. Rather than just permitting this, actively warn about quoted strings split across lines. Test case: void context(void) { struct { unsigned magic; const char *strdata; } foo[] = { { 42, "these strings" "do not produce warnings" }, { 256, "though perhaps" "they should" }, }; pr_err("this string" " should produce a warning\n"); pr_err("this multi-line string\n" "should not produce a warning\n"); asm ("this asm\n\t" "should not produce a warning"); } Results of checkpatch on that test case: WARNING: quoted string split across lines + " should produce a warning\n"); total: 0 errors, 1 warnings, 15 lines checked Signed-off-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: whitespace - add/remove blank linesJoe Perches
Add blank lines between a few tests, remove an extraneous one. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: warn on use of yield()Joe Perches
Using yield() is generally wrong. Warn on its use. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: add --strict tests for braces, comments and castsJoe Perches
Add some more subjective --strict tests. Add a test for block comments that start with a blank line followed only by a line with just the comment block initiator. Prefer a blank line followed by /* comment... Add a test for unnecessary spaces after a cast. Add a test for symmetric uses of braces in if/else blocks. If one branch needs braces, then all branches should use braces. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: add [] to type extensionsAndy Whitcroft
Add [] to a type extensions. Fixes false positives on: .attrs = (struct attribute *[]) { Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: high precedence operators do not require additional parentheses ↵Andy Whitcroft
in #defines With any very high precedence operator it is not necessary to enforce additional parentheses around simple negated expressions. This prevents us requesting further perentheses around the following: #define PMEM_IS_FREE(id, index) !(pmem[id].bitmap[index].allocated) For now add logical and bitwise not and unary minus. Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: handle string concatenation in simple #definesAndy Whitcroft
Adjacent strings indicate concatentation, therefore look at identifiers directly adjacent to literal strings as strings too. This allows us to better detect the form below and accept it as a simple constant: #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: allow simple character constants in #definesAndy Whitcroft
2012-03-23checkpatch: catch [ ... ] usage when not at the beginning of definitionAndy Whitcroft
Handle the [ A ... B ] form deeper into a definition, for example: static const unsigned char pci_irq_swizzle[2][PCI_MAX_DEVICES] = { {0, 0, 0, 0, 0, 0, 0, 27, 27, [9 ... PCI_MAX_DEVICES - 1] = 0 }, {0, 0, 0, 0, 0, 0, 0, 29, 29, [9 ... PCI_MAX_DEVICES - 1] = 0 }, }; Reported-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch.pl: be silent when -q and --ignore is givenArtem Bityutskiy
Fix checkpatch.pl when both -q and --ignore are given and prevents it from printing a NOTE: Ignored message types: blah messages. E.g., if I use -q --ignore PREFER_PACKED,PREFER_ALIGNED, i see: NOTE: Ignored message types: PREFER_ALIGNED PREFER_PACKED It makes no sense to print this when -q is given. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23checkpatch: add some --strict coding style checksJoe Perches
Argument alignment across multiple lines should match the open parenthesis. Logical continuations should be at the end of the previous line, not the start of a new line. These are not required by CodingStyle so make the tests active only when using --strict. Improved by some examples from Bruce Allen. Signed-off-by: Joe Perches <joe@perches.com> Cc: "Bruce W. Allen" <bruce.w.allan@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23include/ and checkpatch: prefer __scanf to __attribute__((format(scanf,...)Joe Perches
It's equivalent to __printf, so prefer __scanf. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23get_maintainer.pl: add support for moderated listsRichard Weinberger
Currently get_maintainer.pl reports moderated lists as open, which is just wrong. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23get_maintainer: use a default "unknown" S: status/roleJoe Perches
When an "S:" status line is unavailable, use a default "unknown" role. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-09Merge 3.3-rc6 into driver-core-nextGreg Kroah-Hartman
This was done to resolve a conflict in the drivers/base/cpu.c file. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-27mod/file2alias: make modpost compile on darwin againAndreas Bießmann
commit e49ce14150c64b29a8dd211df785576fa19a9858 breaks cross compiling the linux kernel on darwin hosts. This fix introduce some minimal glue to adopt linker section handling for darwin hosts. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> CC: Jochen Friedrich <jochen@scram.de> CC: Samuel Ortiz <sameo@linux.intel.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Bernhard Walle <bernhard@bwalle.de>
2012-02-25Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild three kbuild fixes for 3.3: - make deb-pkg symlink race fix. - make coccicheck fix. - Dropping the check for modutils. This is not a regression, but allows the module-init-tools replacement kmod work with the 3.3 kernel. * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: coccicheck: change handling of C={1,2} when M= is set builddeb: Don't create files in /tmp with predictable names kbuild: do not check for ancient modutils tools
