path: root/scripts
2012-08-21checkpatch: add control statement test to SINGLE_STATEMENT_DO_WHILE_MACROJoe Perches
Commit b13edf7ff2dd ("checkpatch: add checks for do {} while (0) macro misuses") added a test that is overly simplistic for single statement macros. Macros that start with control tests should be enclosed in a do {} while (0) loop. Add the necessary control tests to the check. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andy Whitcroft <apw@canonical.com> Tested-by: Franz Schrober <franzschrober@yahoo.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-17scripts/kernel-doc: fix fatal script errorRandy Dunlap
Fix fatal error in scripts/kernel-doc by ignoring the "__weak" attribute: Error(drivers/pci/pci.c:2820): cannot understand prototype: 'char * __weak pcibios_setup(char *str) ' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-16scripts/decodecode: Fixup trapping instruction markerBorislav Petkov
When dumping "Code: " sections from an oops, the trapping instruction %rip points to can be a string copy 2b:* f3 a5 rep movsl %ds:(%rsi),%es:(%rdi) and the line contain a bunch of ":". Current "cut" selects only the and the second field output looks funnily overlaid this: 2b:* f3 a5 rep movsl %ds <-- trapping instruction:(%rsi),%es:(%rdi Fix this by selecting the remaining fields too. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kbuild@vger.kernel.org Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "This it the second batch of s390 patches for the 3.6 merge window. Included is enablement for two common code changes, killable page faults and sorted exception tables. And the regular set of cleanup and bug fix patches." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: make use of user_mode() macro where possible s390/mm: rename user_mode variable to addressing_mode s390/mm: fix fault handling for page table walk case s390/mm: make page faults killable s390: update defconfig s390/mm: downgrade page table after fork of a 31 bit process s390/ipl: Use diagnose 8 command separation s390/linker script: use RO_DATA_SECTION s390/exceptions: sort exception table at build time s390/debug: remove module_exit function / move EXPORT_SYMBOLs
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30checkpatch: add checks for do {} while (0) macro misusesJoe Perches
These types of macros should not be used for either a single statement nor should the macro end with a semi-colon. Add tests for these conditions. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30checkpatch: Add acheck for use of sizeof without parenthesisJoe Perches
Kernel style uses parenthesis around sizeof. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30checkpatch: check usleep_range() argumentsJoe Perches
usleep_range() shouldn't use the same args for min and max. Report it when it happens and when both args are decimal and min > max. Signed-off-by: Joe Perches <joe@perches.com> Cc: Yuval Mintz <yuvalmin@broadcom.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30checkpatch: test for non-standard signaturesJoe Perches
Warn on non-standard signature styles. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30checkpatch: Update alignment checkJoe Perches
Parenthesis alignment doesn't correctly check an existing line after an inserted or modified line with an open parenthesis. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Whitcroft <apw@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge tag 'localmodconfig-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig Pull localmodconfig updates from Steven Rostedt: "Improve localmodconfig to remove even more unused module configs. These changes drastically improve the amount of module configs removed from a config file. It also adds some debug that I can have users easily enable if things do not work for them." * tag 'localmodconfig-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-kconfig: localmodconfig: Add debug environment variable LOCALMODCONFIG_DEBUG localmodconfig: Check if configs are already set for selects localmodconfig: Read in orig config file to avoid extra processing localmodconfig: Comments and cleanup for streamline_config.pl
2012-07-30Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild changes from Michal Marek: "This is the non-critical part of kbuild for v3.6-rc1: - Two new coccinelle semantic patches - New scripts/tags.sh regexp - scripts/config improvements that I mistakenly applied here instead of in the kconfig branch (but there are no conflicts) - Debian packaging fixes" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/tags.sh: Teach [ce]tags about libtraceeevent error codes scripts/coccinelle: list iterator variable semantic patch scripts/coccinelle: Find threaded IRQs requests which are missing IRQF_ONESHOT deb-pkg: Add all Makefiles to header package deb-pkg: Install linux-firmware-image in versioned dir scripts/config: add option to undef a symbol scripts/config: allow alternate prefix to config option symbol scripts/config: add option to not upper-case symbols
2012-07-30Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig changes from Michal Marek: - kconfig Makefile portability fixes - menuconfig/nconfig help pager usability fix - .gitignore cleanup - quoting fix in scripts/config - Makefile prints errors to stderr - support for arbitrarily log lines in .config - fix oldnoconfig description in 'make help' * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: Document oldnoconfig to what it really does nconf: add u, d command keys in scroll windows menuconfig: add u, d, q command keys in text boxes scripts/config: fix double-quotes un-escaping kconfig: Print errors to stderr in the Makefile kconfig: allow long lines in config file kconfig: remove lkc_defs.h from .gitignore and dontdiff xconfig: add quiet rule for moc xconfig: use pkgconfig to find moc kconfig: fix check-lxdialog for DLL platforms kconfig: check ncursesw headers first in check-lxdialog kconfig/nconf: fix compile with ncurses reentrant API
2012-07-30Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild fix from Michal Marek: "The main kbuild branch ended up with a single commit this time, a fix to send errors to stderr" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Print errors to stderr
2012-07-26Merge tag 'usb-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg Kroah-Hartman: "Here's the big USB patch set for the 3.6-rc1 merge window. Lots of little changes in here, primarily for gadget controllers and drivers. There's some scsi changes that I think also went in through the scsi tree, but they merge just fine. All of these patches have been in the linux-next tree for a while now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fix up trivial conflicts in include/scsi/scsi_device.h (same libata conflict that Jeff had already encountered) * tag 'usb-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (207 commits) usb: Add USB_QUIRK_RESET_RESUME for all Logitech UVC webcams usb: Add quirk detection based on interface information usb: s3c-hsotg: Add header file protection macros in s3c-hsotg.h USB: ehci-s5p: Add vbus setup function to the s5p ehci glue layer USB: add USB_VENDOR_AND_INTERFACE_INFO() macro USB: notify phy when root hub port connect change USB: remove 8 bytes of padding from usb_host_interface on 64 bit builds USB: option: add ZTE MF821D USB: sierra: QMI mode MC7710 moved to qcserial USB: qcserial: adding Sierra Wireless devices USB: qcserial: support generic Qualcomm serial ports USB: qcserial: make probe more flexible USB: qcserial: centralize probe exit path USB: qcserial: consolidate usb_set_interface calls USB: ehci-s5p: Add support for device tree USB: ohci-exynos: Add support for device tree USB: ehci-omap: fix compile failure(v1) usb: host: tegra: pass correct pointer in ehci_setup() USB: ehci-fsl: Update ifdef check to work on 64-bit ppc USB: serial: keyspan: Removed unrequired parentheses. ...
2012-07-26kconfig: Document oldnoconfig to what it really doesSteven Rostedt
The make target 'oldnoconfig' is a misnomer. It doesn't set new symbols to 'n', but instead sets it to their default values. Unfortunately, assuming that it actually did this, broke ktest in some of its tests. For example, the tests to create a minimum config and even a config bisect, depends on removing various configs and using oldnoconfig to get rid of other configs that may have depended on it. But because some configs that it was trying to disable, were in fact default enabled, this caused those configs to re-enable and corrupt the test. I thought about fixing oldnoconfig, but I'm afraid that people are already dependent on its current behavior. Instead, I'm just updating the documentation to state that it sets the new symbols to their default values and not to 'n'. Ideally, this would be called, 'olddefconfig' and we have an 'oldnoconfig' that actually disables the new symbols. But it's useless for me now. If it changed, ktest would need to be consistent between each version, and that would be to difficult to detect. I'll handle this issue with ktest with other means. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-26scripts/tags.sh: Teach [ce]tags about libtraceeevent error codesNamhyung Kim
As we use a macro trick to sync each error codes with its description string, teach [ce]tags to process them properly. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/n/tip-qt5fv4pzigr2nnl27ydimg4h@git.kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-26nconf: add u, d command keys in scroll windowsBenjamin Poirier
They function just like they do in less(1). Also correct some discrepancy between the help text and the code wrt function keys. Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-26menuconfig: add u, d, q command keys in text boxesBenjamin Poirier
They function just like they do in less(1). Signed-off-by: Benjamin Poirier <bpoirier@suse.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-26scripts/config: fix double-quotes un-escapingYann E. MORIN
When reporting a string value, only the first double-quote was un-escaped. We need to un-escape all escaped double-quotes. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-26s390/exceptions: sort exception table at build timeHeiko Carstens
Follow x86 and MIPS and sort the main exception table at build time. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2012-07-24Merge tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug: - Add MMCONFIG support for hot-added host bridges (Jiang Liu) Device hotplug: - Move fixups from __init to __devinit (Sebastian Andrzej Siewior) - Call FINAL fixups for hot-added devices, too (Myron Stowe) - Factor out generic code for P2P bridge hot-add (Yinghai Lu) - Remove all functions in a slot, not just those with _EJx (Amos Kong) Dynamic resource management: - Track bus number allocation (struct resource tree per domain) (Yinghai Lu) - Make P2P bridge 1K I/O windows work with resource reassignment (Bjorn Helgaas, Yinghai Lu) - Disable decoding while updating 64-bit BARs (Bjorn Helgaas) Power management: - Add PCIe runtime D3cold support (Huang Ying) Virtualization: - Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex Williamson) - Add quirks for devices with broken INTx masking (Jan Kiszka) Miscellaneous: - Fix some PCI Express capability version issues (Myron Stowe) - Factor out some arch code with a weak, generic, pcibios_setup() (Myron Stowe)" * tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits) PCI: hotplug: ensure a consistent return value in error case PCI: fix undefined reference to 'pci_fixup_final_inited' PCI: build resource code for M68K architecture PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width() PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits PCI: acpiphp: merge acpiphp_debug and debug PCI: acpiphp: remove unused res_lock sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: disable MEM decoding while updating 64-bit MEM BARs PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()' ...
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
2012-07-20trivial: typo in comment in mksysmapMasatake YAMATO
Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-13scripts/coccinelle: list iterator variable semantic patchJulia Lawall
If list_for_each_entry, etc complete a traversal of the list, the iterator variable ends up pointing to an address at an offset from the list head, and not a meaningful structure. Thus this value should not be used after the end of the iterator. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13kconfig: Print errors to stderr in the MakefileMichal Marek
2012-07-13kconfig: allow long lines in config fileCody Schafer
For some config options (CONFIG_EXTRA_FIRMWARE, for example), the length of a config file line can exceed the 1024 byte buffer. Switch from fgets to compat_getline to fix. compat_getline is an internally implimented getline work-alike for portability purposes. Signed-off-by: Cody Schafer <cody@linux.vnet.ibm.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13scripts/coccinelle: Find threaded IRQs requests which are missing IRQF_ONESHOTLars-Peter Clausen
Since commit 1c6c69525b ("genirq: Reject bogus threaded irq requests") threaded IRQs without a primary handler need to be requested with IRQF_ONESHOT, otherwise the request will fail. This semantic patch will help to statically identify (and fix) such cases. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13kconfig: remove lkc_defs.h from .gitignore and dontdiffPaul Bolle
Commit 5a6f8d2bd9e3392569ed6f29ea4d7210652f929b ("kconfig: nuke LKC_DIRECT_LINK cruft") removed all traces of lkc_defs.h from the tree. Remove its entries in dontdiff and kconfig's .gitignore file too. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13xconfig: add quiet rule for mocYaakov Selkowitz
Also add a dependency on .tmp_qtcheck for KC_QT_MOC. Signed-off-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-13xconfig: use pkgconfig to find mocYaakov Selkowitz
Various schemes exist to allow parallel installations of multiple major versions of Qt (4.x with the previous 3.x and/or the upcoming 5.x). QtCore.pc includes a moc_location variable which should be a more reliable way to find moc. Signed-off-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-07kbuild: Print errors to stderrMichal Marek
... at least in the top-level Makefile and scripts/link-vmlinux.sh. There are some more instances of the 'echo <error>; exit 1' pattern in some arch Makefiles and kconfig. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-05Merge 3.5-rc5 into usb-nextGreg Kroah-Hartman
This resolves a merge issue with the option.c USB serial driver. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-04kconfig: fix check-lxdialog for DLL platformsYaakov Selkowitz
Import libraries on Cygwin and MinGW/MSYS use the .dll.a suffix, so checking this suffix is necessary to make sure ncurses will still be found when built without static libraries. Signed-off-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-04kconfig: check ncursesw headers first in check-lxdialogYaakov Selkowitz
Commit 8c41e5e363db55d91aa3b1cdce4ab02ad9821de7 added a check for ncursesw/curses.h for the case where ncurses and ncursesw are build separately but only one is installed. But if both are installed, the headers ncurses/curses.h and ncursesw/curses.h differ, and since libncursesw will be found first, so should ncursesw/curses.h. Signed-off-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-07-04kconfig/nconf: fix compile with ncurses reentrant APIYaakov Selkowitz
ESCDELAY is a global variable which is replaced by getter and setter functions with NCURSES_REENTRANT. This fixes the following error: nconf.c: In function ‘main’: nconf.c:1506:2: error: lvalue required as left operand of assignment Signed-off-by: Yaakov Selkowitz <yselkowitz@users.sourceforge.net> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28deb-pkg: Add all Makefiles to header packagemaximilian attems
I discovered that make deb-pkg does not add Makefile_32.cpu from arch/x86 directory when doing i386 kernel build and package build. Fix it by greedily adding all Makefiles. Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28deb-pkg: Install linux-firmware-image in versioned dirmaximilian attems
That way they don't file conflict with official firmware package: trying to overwrite '/lib/firmware/qlogic/1040.bin', which is also in package firmware-qlogic 0.35 .. Reported-by: Michael Prokop <mika@debian.org> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28scripts/config: add option to undef a symbolYann E. MORIN
It is currently possible to enable, disable or modularise a symbol. Also, an undefined symbol is reported as such. Add a new command to undefine a symbol, by removing the corresponding line from the .config file. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28scripts/config: allow alternate prefix to config option symbolYann E. MORIN
While the Linux kernel uses 'CONFIG_' as a prefix to the config options symbols, many projects that use kconfig may use different prefixes, or even none at all. If the CONFIG_ environment variable is set, use it as the prefix (empty is a valid prefix). Otherwise, use the default prefix 'CONFIG_'. This matches the support for alternate prefixes in scripts/kconfig/lkc.h, which uses the same logic (albeit with a C define instead of an environment variable). Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-28scripts/config: add option to not upper-case symbolsYann E. MORIN
Currently, scripts/config mangles the config option symbols to always be upper-case. While the Linux kernel almost exclusively uses upper-case symbols, there are still a few symbols with lower-case which this script can not handle: $ grep -r -E '^[[:space:]]*config[[:space:]]+[^[:space:]]*[[:lower:]][^[:space:]=.]*$' . |wc -l 173 (that's roughly 1.3% of the symbols in 3.5-rc1) Eg.: ./arch/arm/Kconfig:config VFPv3 ./arch/powerpc/platforms/Kconfig.cputype:config 40x ./arch/x86/Kconfig:config SCx200HR_TIMER ./drivers/video/console/Kconfig:config FONT_8x8 ./drivers/video/Kconfig:config NTSC_640x480 Also, other projects that use kconfig may allow for lower- or mixed-case symbols, and may find easier to reuse this script than implement each their own (potentially flawed) logic. For such a use-case, see: http://marc.info/?l=linux-kbuild&m=133409932115848&w=2 This patch adds a new option to keep the given case, and keep the current default to upper-case the symbols. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-06-27chmod +x scripts/gfp-translateDave Jones
This script lacks an executable bit. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-25Merge 3.5-rc4 into usb-nextGreg Kroah-Hartman
This is to get the USB fixes that were merged in the 3.5-rc4 tree into usb-next so that everyone can sync up properly. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20get_maintainer: Fix --help warningJoe Perches
Using --help emits a concatenation error. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Paul Bolle <pebolle@tiscali.nl> Tested-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-19localmodconfig: Add debug environment variable LOCALMODCONFIG_DEBUGSteven Rostedt
If the environment variable LOCALMODCONFIG_DEBUG is set, then debug output will appear in the make localmodconfig. This will simplify debugging what people get with their output, as I can just tell people to do: LOCALMODCONFIG_DEBUG=1 make localmodconfig 2>out.txt and have them send me the out.txt. I'll be able to see why things are not working as they think it should be. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-06-19localmodconfig: Check if configs are already set for selectsSteven Rostedt
There are some cases that a required module does not have a prompt and needs to have another module enabled that selects it to be set. As localmodconfig is conservative and tries to make the minimum config without breaking the user's kernel, or keeping the user from using devices that were loaded when the lsmod was done, all modules that select this module will also be enabled. If you needed module A, but module A did not have a prompt but needed module B to be selected, localmodconfig would make sure B was still enabled. If not only B selected A, but C, D, E, F, and G also selected A, then all of those would also be included, as well as the modules they depend on. This ballooned the number of configs that localmodconfig would keep. The fix here is to process the depends first, and then record those configs that did not have a prompt and needed to be selected. After the depends are done, check what configs are needed to select the configs in the list, and if a config that selects it is already set, then we don't need to do anything else. If no config that selects the config is set, then just pick one and try again. This change brought down the number of selected modules from 290 to 67! Both before and after were run against a config that had 3095 modules enabled. Tested-by: John David Yost <johnyost@ptd.net> # AlleyTrotter Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-06-19localmodconfig: Read in orig config file to avoid extra processingSteven Rostedt
Read in the entire config file. If there's a config that we depend on that happens to be in the core set (not a module) then we do not need to process it as a module. Currently, we follow the entire depend and selects even if they are enabled as core and not modules. By checking to make sure that we only look at modules we can drop the count a little. From one of my tests, localmodconfig went from taking 3095 set modules down to 356 before this patch, and down to 290 modules after the change. Tested-by: John David Yost <johnyost@ptd.net> # AlleyTrotter Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-06-19localmodconfig: Comments and cleanup for streamline_config.plSteven Rostedt
Added some more comments and cleaned up part of the the code to use a named variable instead of one of the special $1 perl variables. No functional changes. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-06-16scripts/modpost: check for bad references in .pci.fixups areaSebastian Andrzej Siewior
Functions used for PCI fixups (like DECLARE_PCI_FIXUP_HEADER) are often marked __init. This is okay as long as nobody is using PCI hotplug. However if one does execute | echo 1 > /sys/bus/pci/rescan and we hit a module which is marked __init istead of __devinit then we go boom because the code is removed after the kernel booted. This patch help to see those section mismatches. Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13USB: allow match on bInterfaceNumberBjørn Mork
Some composite USB devices provide multiple interfaces with different functions, all using "vendor-specific" for class/subclass/protocol. Another OS use interface numbers to match the driver and interface. It seems these devices are designed with that in mind - using static interface numbers for the different functions. This adds support for matching against the bInterfaceNumber, allowing such devices to be supported without having to resort to testing against interface number whitelists and/or blacklists in the probe. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
