[ Upstream commit b3c0a4dab7e35a9b6d69c0415641d2280fdefb2b ]
Because of an improper dereference, a stray 'C' character was output to
the modalias when no 'compatible' was specified. This is the case for
some old PowerMac drivers which only set the 'name' property. Fix it to
let them match again.
Reported-by: Mathieu Malaterre <malat@debian.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Tested-by: Mathieu Malaterre <malat@debian.org>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Fixes: 6543becf26fff6 ("mod/file2alias: make modalias generation safe for cross compiling")
Cc: stable@vger.kernel.org # v3.9+
[ Upstream commit c9c6837d39311b0cc14cdbe7c18e815ab44aefb1 ]
gcc-6 started warning by default about variables that are not
used anywhere and that are marked 'const', generating many
false positives in an allmodconfig build, e.g.:
arch/arm/mach-davinci/board-da830-evm.c:282:20: warning: 'da830_evm_emif25_pins' defined but not used [-Wunused-const-variable=]
arch/arm/plat-omap/dmtimer.c:958:34: warning: 'omap_timer_match' defined but not used [-Wunused-const-variable=]
drivers/bluetooth/hci_bcm.c:625:39: warning: 'acpi_bcm_default_gpios' defined but not used [-Wunused-const-variable=]
drivers/char/hw_random/omap-rng.c:92:18: warning: 'reg_map_omap4' defined but not used [-Wunused-const-variable=]
drivers/devfreq/exynos/exynos5_bus.c:381:32: warning: 'exynos5_busfreq_int_pm' defined but not used [-Wunused-const-variable=]
drivers/dma/mv_xor.c:1139:34: warning: 'mv_xor_dt_ids' defined but not used [-Wunused-const-variable=]
This is similar to the existing -Wunused-but-set-variable warning
that was added in an earlier release and that we disable by default
now and only enable when W=1 is set, so it makes sense to do
the same here. Once we have eliminated the majority of the
warnings for both, we can put them back into the default list.
We probably want this in backport kernels as well, to allow building
them with gcc-6 without introducing extra warnings.
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Michal Marek <mmarek@suse.com>
[ Upstream commit 1b669e713f277a4d4b3cec84e13d16544ac8286d ]
& is no longer allowed in column 0, since Coccinelle 1.0.4.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Tested-by: Nishanth Menon <nm@ti.com>
[ Upstream commit 4b7b1ef2c2f83d702272555e8adb839a50ba0f8e ]
The ld-version.sh script fails on some versions of awk with the
following error, resulting in build failures for MIPS:
awk: scripts/ld-version.sh: line 4: regular expression compile failed (missing '(')
This is due to the regular expression ".*)", meant to strip off the
beginning of the ld version string up to the close bracket, however
brackets have a meaning in regular expressions, so lets escape it so
that awk doesn't expect a corresponding open bracket.
Fixes: ccbef1674a15 ("Kbuild, lto: add ld-version and ld-ifversion ...")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Tested-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
Cc: Michal Marek <mmarek@suse.com>
Cc: linux-mips@linux-mips.org
Cc: linux-kbuild@vger.kernel.org
Cc: stable@vger.kernel.org # 4.4.x-
Patchwork: https://patchwork.linux-mips.org/patch/12838/
[ Upstream commit 72214a24a7677d4c7501eecc9517ed681b5f2db2 ]
In Python3+ print is a function so the old syntax is not correct
anymore:
$ ./scripts/bloat-o-meter vmlinux.o vmlinux.o.old
File "./scripts/bloat-o-meter", line 61
print "add/remove: %s/%s grow/shrink: %s/%s up/down: %s/%s (%s)" % \
SyntaxError: invalid syntax
Fix by calling print as a function.
Tested on python 2.7.11, 3.5.1
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: <stable@vger.kernel.org>
commit c84da8b9ad3761eef43811181c7e896e9834b26b upstream.
In nop_mcount, shdr->sh_offset and welp->r_offset should handle
endianness properly, otherwise it will trigger Segmentation fault
if the recordmcount main and file.o have different endianness.
Link: http://lkml.kernel.org/r/563806C7.7070606@huawei.com
Signed-off-by: Li Bin <huawei.libin@huawei.com>
commit 2ee8a74f2a5da913637f75a19a0da0e7a08c0f86 upstream.
By now, the recordmcount only records the function that in
following sections:
.text/.ref.text/.sched.text/.spinlock.text/.irqentry.text/
.kprobes.text/.text.unlikely
For the function that not in these sections, the call mcount
will be in place and not be replaced when kernel boot up. And
it will bring performance overhead, such as do_mem_abort (in
.exception.text section). This patch make the call mcount to
nop for this case in recordmcount.
Link: http://lkml.kernel.org/r/1446019445-14421-1-git-send-email-huawei.libin@huawei.com
Link: http://lkml.kernel.org/r/1446193864-24593-4-git-send-email-huawei.libin@huawei.com
Cc: <lkp@intel.com>
Cc: <catalin.marinas@arm.com>
Cc: <takahiro.akashi@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
commit 2e50c4bef77511b42cc226865d6bc568fa7f8769 upstream.
If a text section starts out with a data blob before the first
function start label, disassembly parsing doing in recordmcount.pl
gets confused on powerpc, leading to creation of corrupted module
objects.
This was not a problem so far since the compiler would never create
such text sections. However, this has changed with a recent change
in GCC 6 to support distances of > 2GB between a function and its
assoicated TOC in the ELFv2 ABI, exposing this problem.
There is already code in recordmcount.pl to handle such data blobs
on the sparc64 platform. This patch uses the same method to handle
those on powerpc as well.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Ulrich Weigand <ulrich.weigand@de.ibm.com>
commit c0ddc8c745b7f89c50385fd7aa03c78dc543fa7a upstream.
In kbuild it is allowed to define objects in files named "Makefile"
and "Kbuild".
Currently localmodconfig reads objects only from "Makefile"s and misses
modules like nouveau.
Link: http://lkml.kernel.org/r/1437948415-16290-1-git-send-email-richard@nod.at
Reported-and-tested-by: Leonidas Spyropoulos <artafinde@gmail.com>
Signed-off-by: Richard Weinberger <richard@nod.at>
Commit d5e616fc1c1d ("checkpatch: add a few more --fix corrections")
broke the GLOBAL_INITIALISERS test with bad parentheses and optional
leading spaces.
Fix it.
Reported-by: Bandan Das <bsd@makefile.in>
Commit 2f35c41f58a9 ("module: Replace module_ref with atomic_t refcnt")
changes the way refcnt is handled but did not update the gdb script to
use the new variable.
Since refcnt is not per-cpu anymore, we can directly read its value.
Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me>
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Pantelis Koukousoulas <pktoss@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Quentin opened a can of worms by adding extable entry checking to
modpost, but most architectures seem fixed now. Thanks to all
involved.
Last minute rebase because I noticed a "[PATCH]" had snuck into a
commit message somehow"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
modpost: don't emit section mismatch warnings for compiler optimizations
modpost: expand pattern matching to support substring matches
modpost: do not try to match the SHT_NUL section.
modpost: fix extable entry size calculation.
modpost: fix inverted logic in is_extable_fault_address().
modpost: handle -ffunction-sections
modpost: Whitelist .text.fixup and .exception.text
params: handle quotes properly for values not of form foo="bar".
modpost: document the use of struct section_check.
modpost: handle relocations mismatch in __ex_table.
scripts: add check_extable.sh script.
modpost: mismatch_handler: retrieve tosym information only when needed.
modpost: factorize symbol pretty print in get_pretty_name().
modpost: add handler function pointer to sectioncheck.
modpost: add .sched.text and .kprobes.text to the TEXT_SECTIONS list.
modpost: add strict white-listing when referencing sections.
module: do not print allocation-fail warning on bogus user buffer size
kernel/module.c: fix typos in message about unused symbols
Pull ARM SoC fixes from Olof Johansson:
"Here's the usual "low-priority fixes that didn't make it into the last
few -rcs, with a twist: We had a fixes pull request that I didn't send
in time to get into 4.0, so we'll send some of them to Greg for
-stable as well.
Contents here is as usual not all that controversial:
- a handful of randconfig fixes from Arnd, in particular for older
Samsung platforms
- Exynos fixes, !SMP building, DTS updates for MMC and lid switch
- Kbuild fix to create output subdirectory for DTB files
- misc minor fixes for OMAP"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: at91/dt: sama5d3 xplained: add phy address for macb1
kbuild: Create directory for target DTB
ARM: mvebu: Disable CPU Idle on Armada 38x
ARM: DRA7: Enable Cortex A15 errata 798181
ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102
ARM: dts: DRA7: Add bandgap and related thermal nodes
bus: ocp2scp: SYNC2 value should be changed to 0x6
ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP
ARM: OMAP2+: remove superfluous NULL pointer check
ARM: EXYNOS: Fix build breakage cpuidle on !SMP
ARM: dts: fix lid and power pin-functions for exynos5250-spring
ARM: dts: fix mmc node updates for exynos5250-spring
ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688
MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT
ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs
ARM: cns3xxx: don't export static symbol
ARM: S3C24XX: avoid a Kconfig warning
ARM: S3C24XX: fix header file inclusions
ARM: S3C24XX: fix building without PM_SLEEP
ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416
Currently an allyesconfig build [gcc-4.9.1] can generate the following:
WARNING: vmlinux.o(.text.unlikely+0x3864): Section mismatch in
reference from the function cpumask_empty.constprop.3() to the
variable .init.data:nmi_ipi_mask
which comes from the cpumask_empty usage in arch/x86/kernel/nmi_selftest.c.
Normally we would not see a symbol entry for cpumask_empty since it is:
static inline bool cpumask_empty(const struct cpumask *srcp)
however in this case, the variant of the symbol gets emitted when GCC does
constant propagation optimization.
Fix things up so that any locally optimized constprop variants don't warn
when accessing variables that live in the __init sections.
Currently the match() function supports a leading * to match any
prefix and a trailing * to match any suffix. However there currently
is not a combination of both that can be used to target matches of
whole families of functions that share a common substring.
Here we expand the *foo and foo* match to also support *foo* with
the goal of targeting compiler generated symbol names that contain
strings like ".constprop." and ".isra."
Trying to match the SHT_NUL section isn't useful and causes build failures
on parisc and mn10300 since the addition of section strict white-listing
and __ex_table sanitizing.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Fixes: 050e57fd5936 ("modpost: add strict white-listing when referencing....")
Fixes: 52dc0595d540 ("modpost: handle relocations mismatch in __ex_table.")
Tested-by: Guenter Roeck <linux@roeck-us.net>
As Guenter pointed out, we were never really calculating the extable entry
size because the pointer arithmetic was simply wrong. We want to check
we're handling the second relocation in __ex_table to infer an entry size,
but we were using (void*) pointers instead of Elf_Rel[a]* ones.
This fixes the problem by moving that check in the caller (since we can
deal with different types of relocations) and add is_second_extable_reloc()
to make the whole thing more readable.
CC: Rusty Russell <rusty@rustcorp.com.au>
As Guenter pointed out, we want to assert that extable_entry_size has been
discovered and not the other way around. Moreover, this sanity check is
only valid when we're not dealing with the first relocation in __ex_table,
since we have not discovered the extable entry size at that point.
This was leading to a divide-by-zero on some architectures and make the
build fail.
52dc0595d540 introduced OTHER_TEXT_SECTIONS for identifying what
sections could validly have __ex_table entries. Unfortunately, it
wasn't tested with -ffunction-sections, which some architectures
use.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
32-bit and 64-bit ARM use these sections to store executable code, so
they must be whitelisted in modpost's table of valid text sections.
Signed-off-by: Thierry Reding <treding@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver patchset for 4.1-rc1.
Lots of different driver subsystem updates here, nothing major, full
details are in the shortlog.
All of this has been in linux-next for a while"
* tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits)
mei: trace: remove unused TRACE_SYSTEM_STRING
DTS: ARM: OMAP3-N900: Add lis3lv02d support
Documentation: DT: lis302: update wakeup binding
lis3lv02d: DT: add wakeup unit 2 and wakeup threshold
lis3lv02d: DT: use s32 to support negative values
Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case
Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case
mei: replace check for connection instead of transitioning
mei: use mei_cl_is_connected consistently
mei: fix mei_poll operation
hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg()
Drivers: hv: hv_balloon: survive ballooning request with num_pages=0
Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function
Drivers: hv: hv_balloon: do not online pages in offline blocks
hv: remove the per-channel workqueue
hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind()
hv: run non-blocking message handlers in the dispatch tasklet
coresight: moving to new "hwtracing" directory
coresight-tmc: Adding a status interface to sysfs
coresight: remove the unnecessary configuration coresight-default-sink
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull misc kbuild updates:
"This is the remaining part of kbuild stuff for v4.1-rc1:
- One wew coccinelle script and a clarification of the proposed fix
in bugon.coccinelle
- CONFIG_KERNEL_LZ4 support for extract-ikconfig"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warning
scripts/extract-ikconfig: Support LZ4-compressed images.
irqf_oneshot.cocci: add check of devm_request_threaded_irq()
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for MIPS for Linux 4.1. Most
noteworthy:
- Add more Octeon-optimized crypto functions
- Octeon crypto preemption and locking fixes
- Little endian support for Octeon
- Use correct CSR to soft reset Octeons
- Support LEDs on the Octeon-based DSR-1000N
- Fix PCI interrupt mapping for the Octeon-based DSR-1000N
- Mark prom_free_prom_memory() as __init for a number of systems
- Support for Imagination's Pistachio SOC. This includes arch and
CLK bits. I'd like to merge pinctrl bits later
- Improve parallelism of csum_partial for certain pipelines
- Organize DTB files in subdirs like other architectures
- Implement read_sched_clock for all MIPS platforms other than
Octeon
- Massive series of 38 fixes and cleanups for the FPU emulator /
kernel
- Further FPU remulator work to support new features. This sits on a
separate branch which also has been pulled into the 4.1 KVM branch
- Clean up and fixes for the SEAD3 eval board; remove unused file
- Various updates for Netlogic platforms
- A number of small updates for Loongson 3 platforms
- Increase the memory limit for ATH79 platforms to 256MB
- A fair number of fixes and updates for BCM47xx platforms
- Finish the implementation of XPA support
- MIPS FDC support. No, not floppy controller but Fast Debug Channel :)
- Detect the R16000 used in SGI legacy platforms
- Fix Kconfig dependencies for the SSB bus support"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (265 commits)
MIPS: Makefile: Fix MIPS ASE detection code
MIPS: asm: elf: Set O32 default FPU flags
MIPS: BCM47XX: Fix detecting Microsoft MN-700 & Asus WL500G
MIPS: Kconfig: Disable SMP/CPS for 64-bit
MIPS: Hibernate: flush TLB entries earlier
MIPS: smp-cps: cpu_set FPU mask if FPU present
MIPS: lose_fpu(): Disable FPU when MSA enabled
MIPS: ralink: add missing symbol for RALINK_ILL_ACC
MIPS: ralink: Fix bad config symbol in PCI makefile.
SSB: fix Kconfig dependencies
MIPS: Malta: Detect and fix bad memsize values
Revert "MIPS: Avoid pipeline stalls on some MIPS32R2 cores."
MIPS: Octeon: Delete override of cpu_has_mips_r2_exec_hazard.
MIPS: Fix cpu_has_mips_r2_exec_hazard.
MIPS: kernel: entry.S: Set correct ISA level for mips_ihb
MIPS: asm: spinlock: Fix addiu instruction for R10000_LLSC_WAR case
MIPS: r4kcache: Use correct base register for MIPS R6 cache flushes
MIPS: Kconfig: Fix typo for the r2-to-r6 emulator kernel parameter
MIPS: unaligned: Fix regular load/store instruction emulation for EVA
MIPS: unaligned: Surround load/store macros in do {} while statements
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
It might be annoying to constantly see this:
scripts/Makefile.kasan:16: Cannot use CONFIG_KASAN: -fsanitize=kernel-address is not supported by compiler
while performing allmodconfig/allyesconfig build tests.
Disable this warning if CONFIG_COMPILE_TEST=y.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Michal Marek <mmarek@suse.cz>
Since commit 1f65f947a6a8 ("checkpatch: add checks for question mark and
colon spacing") back in 2008, checkpatch has reported false positive for
asm volatile uses of "::" checkpatch thinks colons should always have
spaces around it.
Add an exception for colons with colons on either side for this valid asm
volatile (and c++) use.
Reported-by: Yehuda Yitschak <yehuday@marvell.com>
If a patch touches multiple files, the --fix and --fix-inplace option
doesn't keep the proper line count and makes the new patch file not able
to be applied via bad offset line numbers when lines are added or deleted
by the --fix option.
Dunno how that extra backslash snuck in there.
Cc: Andy Whitcroft <apw@canonical.com>
ENOSYS means that a nonexistent system call was called. We have a
bad habit of using it for things like invalid operations on
otherwise valid syscalls. We should avoid this in new code.
Pervasive incorrect usage of ENOSYS came up at the kernel summit ABI
review discussion. Let's see if checkpatch can help.
I'll submit a separate patch for include/uapi/asm-generic/errno.h.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Joe Perches <joe@perches.com>
const objects shouldn't be __read_mostly. They are read-only.
Marking these objects as __read_mostly causes section conflicts with LTO
linking.
So add a test to try to avoid this issue.
Cc: Andy Whitcroft <apw@shadowen.org>
Code such as:
x = timercmp(&now, &end, <);
Will currently trigger a checkpatch error. e.g.
ERROR: spaces required around that '<'
This is because the "Ignore operators passed as parameters" check looks
only for a comma following the operator. Improve the check by also
looking for a close parenthesis.
Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
Add a test for sizeof(foo)/sizeof(foo[0]) that could be ARRAY_SIZE(foo).
Add another struct to the list of normally const struct types
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
There are #defines with long string constants like:
#define foo "some really long string > 80 columns"
Add a long line exception for them.
Miscellanea:
Use the $String variable for slightly better readability
Reported-by: Madalin-Cristian Bucur <madalin.bucur@freescale.com>
columns
Commit messages lines are sometimes overly long.
Suggest line wrapping at 75 columns so the default git commit log
indentation of 4 plus the commit message text still fits on an 80 column
screen.
Add a checkpatch test for long commit messages lines too.
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Ian Morris <ipm@chirality.org.uk>
Currently checkpatch warns when asm/file.h is included and linux/file.h
exists. That conversion can be made when linux/file.h includes asm/file.h
which is not always the case.(See signal.h)
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Acked-by: Joe Perches <joe@perches.com>
Using 'const <type> const *' is generally meant to be written 'const
<type> * const'.
Add a test for the miswritten form.
Add a few conditions to the test to find
return (ERRNO);
Make the output message a bit less cryptic too.
Currently checkpatch will fuss if one uses world writable settings in
debugfs files and DEVICE_ATTR uses by testing S_IWUGO but not testing
S_IWOTH, S_IRWXUGO or S_IALLUGO.
Extend the check to catch all cases exporting world writable permissions
including octal values.
[akpm@linux-foundation.org: remove stray $]
Original-patch-by: Nicholas Mc Guire <hofrat@osadl.org>
If a codespell dictionary exists, use it if desired. default is off,
maybe it could be turned on later.
codespell's dictionary format allows multiple possible corrections, ignore
that for now and only use the first suggestion.
Also add \b to spelling test so that consecutive misspelled words
are found properly.
Cc: Masanari Iida <standby24x7@gmail.com>
Cc: Lucas De Marchi <lucas.de.marchi@gmail.com>
References: http://mid.gmane.org/1424977312-24902-1-git-send-email-ville.syrjala@linux.intel.com
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Only commit log and patch additions are checked for typos and spelling
errors currently. Add a check of the email subject line too.
Suggested-by: Jani Nikula <jani.nikula@linux.intel.com>
Tested-by: Jani Nikula <jani.nikula@intel.com>
The "no space is necessary after a cast" sizeof exclusion doesn't work
properly.
The test reports a false positive for code like:
BUILD_BUG_ON(sizeof(struct batadv_bla_claim_dst) != 6);
Make it work, simplify the exclusions, and add some comments.
Reported-by: Marek Lindner <mareklindner@neomailbox.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen features and fixes from David Vrabel:
- use a single source list of hypercalls, generating other tables etc.
at build time.
- add a "Xen PV" APIC driver to support >255 VCPUs in PV guests.
- significant performance improve to guest save/restore/migration.
- scsiback/front save/restore support.
- infrastructure for multi-page xenbus rings.
- misc fixes.
* tag 'stable/for-linus-4.1-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/pci: Try harder to get PXM information for Xen
xenbus_client: Extend interface to support multi-page ring
xen-pciback: also support disabling of bus-mastering and memory-write-invalidate
xen: support suspend/resume in pvscsi frontend
xen: scsiback: add LUN of restored domain
xen-scsiback: define a pr_fmt macro with xen-pvscsi
xen/mce: fix up xen_late_init_mcelog() error handling
xen/privcmd: improve performance of MMAPBATCH_V2
xen: unify foreign GFN map/unmap for auto-xlated physmap guests
x86/xen/apic: WARN with details.
x86/xen: Provide a "Xen PV" APIC driver to support >255 VCPUs
xen/pciback: Don't print scary messages when unsupported by hypervisor.
xen: use generated hypercall symbols in arch/x86/xen/xen-head.S
xen: use generated hypervisor symbols in arch/x86/xen/trace.c
xen: synchronize include/xen/interface/xen.h with xen
xen: build infrastructure for generating hypercall depending symbols
xen: balloon: Use static attribute groups for sysfs entries
xen: pcpu: Use static attribute groups for sysfs entry
Pull kconfig updates from Michal Marek:
"Here is the kconfig stuff for v4.1-rc1:
- fixes for mergeconfig (used by make kvmconfig/tinyconfig)
- header cleanup
- make -s *config is silent now"
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kconfig: Do not print status messages in make -s mode
kconfig: Simplify Makefile
kbuild: add generic mergeconfig target, %.config
merge_config.sh: rename MAKE to RUNMAKE
merge_config.sh: improve indentation
kbuild: mergeconfig: remove redundant $(objtree)
kbuild: mergeconfig: move an error check to merge_config.sh
kbuild: mergeconfig: fix "jobserver unavailable" warning
kconfig: Remove unnecessary prototypes from headers
kconfig: Remove dead code
kconfig: Get rid of the P() macro in headers
kconfig: fix a misspelling in scripts/kconfig/merge_config.sh
Pull kbuild updates from Michal Marek:
"Here is the first round of kbuild changes for v4.1-rc1:
- kallsyms fix for ARM and cleanup
- make dep(end) removed (developers have no sense of nostalgia these
days...)
- include Makefiles by relative path
- stop useless rebuilds of asm-offsets.h and bounds.h"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
Kbuild: kallsyms: drop special handling of pre-3.0 GCC symbols
Kbuild: kallsyms: ignore veneers emitted by the ARM linker
kbuild: ia64: use $(src)/Makefile.gate rather than particular path
kbuild: include $(src)/Makefile rather than $(obj)/Makefile
kbuild: use relative path more to include Makefile
kbuild: use relative path to include Makefile
kbuild: do not add $(bounds-file) and $(offsets-file) to targets
kbuild: remove warning about "make depend"
kbuild: Don't reset timestamps in include/generated if not needed
if()/BUG conversion to BUG_ON must be avoided when there's side effect
in condition. The reason being BUG_ON won't execute the condition when
CONFIG_BUG is not defined.
Inspired-by: J. Bruce Fields <bfields@fieldses.org>
Suggested-by: Julia Lawall <Julia.Lawall@lip6.fr>
Acked-by: Julia Lawall <Julia.Lawall@lip6.fr>
Support for kernel image LZ4 compression was added around 3.11, but not
the corresponding kernel .config extraction.
This makes possible extracting the kernel config for LZ4-compressed
kernels you're not running, or the current LZ4-compressed kernel if
compiled without /proc/config.gz support.
Signed-off-by: Alex Pilon <alp+linux@alexpilon.ca>
With inspiration from Bruce Fields.
Cc: J. Bruce Fields <bfields@fieldses.org>
struct section_check is used as a generic way of describing what
relocations are authorized/forbidden when running modpost. This commit
tries to describe how each field is used.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (Fixed "mist"ake)
__ex_table is a simple table section where each entry is a pair of
addresses - the first address is an address which can fault in kernel
space, and the second address points to where the kernel should jump to
when handling that fault. This is how copy_from_user() does not crash the
kernel if userspace gives a borked pointer for example.
If one of these addresses point to a non-executable section, something is
seriously wrong since it either means the kernel will never fault from
there or it will not be able to jump to there. As both cases are serious
enough, we simply error out in these cases so the build fails and the
developper has to fix the issue.
In case the section is executable, but it isn't referenced in our list of
authorized sections to point to from __ex_table, we just dump a warning
giving more information about it. We do this in case the new section is
executable but isn't supposed to be executed by the kernel. This happened
with .altinstr_replacement, which is executable but is only used to copy
instructions from - we should never have our instruction pointer pointing
in .altinstr_replacement. Admitedly, a proper fix in that case would be to
just set .altinstr_replacement NX, but we need to warn about future cases
like this.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added long casts)
