path: root/security/Kconfig
2010-08-02AppArmor: Enable configuring and building of the AppArmor security moduleJohn Johansen
Kconfig and Makefiles to enable configuration and building of AppArmor. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-24remove CONFIG_SECURITY_FILE_CAPABILITIES compile optionSerge E. Hallyn
As far as I know, all distros currently ship kernels with default CONFIG_SECURITY_FILE_CAPABILITIES=y. Since having the option on leaves a 'no_file_caps' option to boot without file capabilities, the main reason to keep the option is that turning it off saves you (on my s390x partition) 5k. In particular, vmlinux sizes came to: without patch fscaps=n: 53598392 without patch fscaps=y: 53603406 with this patch applied: 53603342 with the security-next tree. Against this we must weigh the fact that there is no simple way for userspace to figure out whether file capabilities are supported, while things like per-process securebits, capability bounding sets, and adding bits to pI if CAP_SETPCAP is in pE are not supported with SECURITY_FILE_CAPABILITIES=n, leaving a bit of a problem for applications wanting to know whether they can use them and/or why something failed. It also adds another subtly different set of semantics which we must maintain at the risk of severe security regressions. So this patch removes the SECURITY_FILE_CAPABILITIES compile option. It drops the kernel size by about 50k over the stock SECURITY_FILE_CAPABILITIES=y kernel, by removing the cap_limit_ptraced_target() function. Changelog: Nov 20: remove cap_limit_ptraced_target() as it's logic was ifndef'ed. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Andrew G. Morgan" <morgan@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-09Config option to set a default LSMJohn Johansen
The LSM currently requires setting a kernel parameter at boot to select a specific LSM. This adds a config option that allows specifying a default LSM that is used unless overridden with the security= kernel parameter. If the the config option is not set the current behavior of first LSM to register is used. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-20security: remove root_plugJames Morris
Remove the root_plug example LSM code. It's unmaintained and increasingly broken in various ways. Made at the 2009 Kernel Summit in Tokyo! Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02Merge commit 'v2.6.31-rc8' into x86/txtIngo Molnar
Conflicts: arch/x86/kernel/reboot.c security/Kconfig Merge reason: resolve the conflicts, bump up from rc3 to rc8. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-01x86, intel_txt: clean up the impact on generic code, unbreak non-x86Shane Wang
Move tboot.h from asm to linux to fix the build errors of intel_txt patch on non-X86 platforms. Remove the tboot code from generic code init/main.c and kernel/cpu.c. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-08-19security: Fix prompt for LSM_MMAP_MIN_ADDRAndreas Schwab
Fix prompt for LSM_MMAP_MIN_ADDR. (Verbs are cool!) Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-19security: Make LSM_MMAP_MIN_ADDR default match its help text.Dave Jones
Commit 788084aba2ab7348257597496befcbccabdc98a3 added the LSM_MMAP_MIN_ADDR option, whose help text states "For most ia64, ppc64 and x86 users with lots of address space a value of 65536 is reasonable and should cause no problems." Which implies that it's default setting was typoed. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-17Security/SELinux: seperate lsm specific mmap_min_addrEric Paris
Currently SELinux enforcement of controls on the ability to map low memory is determined by the mmap_min_addr tunable. This patch causes SELinux to ignore the tunable and instead use a seperate Kconfig option specific to how much space the LSM should protect. The tunable will now only control the need for CAP_SYS_RAWIO and SELinux permissions will always protect the amount of low memory designated by CONFIG_LSM_MMAP_MIN_ADDR. This allows users who need to disable the mmap_min_addr controls (usual reason being they run WINE as a non-root user) to do so and still have SELinux controls preventing confined domains (like a web server) from being able to map some area of low memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-08-14x86, intel_txt: Fix typos in Kconfig helpArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-21x86, intel_txt: Intel TXT boot supportJoseph Cihula
This patch adds kernel configuration and boot support for Intel Trusted Execution Technology (Intel TXT). Intel's technology for safer computing, Intel Trusted Execution Technology (Intel TXT), defines platform-level enhancements that provide the building blocks for creating trusted platforms. Intel TXT was formerly known by the code name LaGrande Technology (LT). Intel TXT in Brief: o Provides dynamic root of trust for measurement (DRTM) o Data protection in case of improper shutdown o Measurement and verification of launched environment Intel TXT is part of the vPro(TM) brand and is also available some non-vPro systems. It is currently available on desktop systems based on the Q35, X38, Q45, and Q43 Express chipsets (e.g. Dell Optiplex 755, HP dc7800, etc.) and mobile systems based on the GM45, PM45, and GS45 Express chipsets. For more information, see http://www.intel.com/technology/security/. This site also has a link to the Intel TXT MLE Developers Manual, which has been updated for the new released platforms. A much more complete description of how these patches support TXT, how to configure a system for it, etc. is in the Documentation/intel_txt.txt file in this patch. This patch provides the TXT support routines for complete functionality, documentation for TXT support and for the changes to the boot_params structure, and boot detection of a TXT launch. Attempts to shutdown (reboot, Sx) the system will result in platform resets; subsequent patches will support these shutdown modes properly. Documentation/intel_txt.txt | 210 +++++++++++++++++++++ Documentation/x86/zero-page.txt | 1 arch/x86/include/asm/bootparam.h | 3 arch/x86/include/asm/fixmap.h | 3 arch/x86/include/asm/tboot.h | 197 ++++++++++++++++++++ arch/x86/kernel/Makefile | 1 arch/x86/kernel/setup.c | 4 arch/x86/kernel/tboot.c | 379 +++++++++++++++++++++++++++++++++++++++ security/Kconfig | 30 +++ 9 files changed, 827 insertions(+), 1 deletion(-) Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Gang Wei <gang.wei@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-04security: use mmap_min_addr indepedently of security modelsChristoph Lameter
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY. It also sets a default mmap_min_addr of 4096. mmapping of addresses below 4096 will only be possible for processes with CAP_SYS_RAWIO. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Eric Paris <eparis@redhat.com> Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-12Kconfig and MakefileKentaro Takeda
TOMOYO uses LSM hooks for pathname based access control and securityfs support. Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06Merge branch 'master' into nextJames Morris
Conflicts: fs/namei.c Manually merged per: diff --cc fs/namei.c index 734f2b5,bbc15c2..0000000 --- a/fs/namei.c +++ b/fs/namei.c @@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char nd->flags |= LOOKUP_CONTINUE; err = exec_permission_lite(inode); if (err == -EAGAIN) - err = vfs_permission(nd, MAY_EXEC); + err = inode_permission(nd->path.dentry->d_inode, + MAY_EXEC); + if (!err) + err = ima_path_check(&nd->path, MAY_EXEC); if (err) break; @@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc flag &= ~O_TRUNC; } - error = vfs_permission(nd, acc_mode); + error = inode_permission(inode, acc_mode); if (error) return error; + - error = ima_path_check(&nd->path, ++ error = ima_path_check(path, + acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC)); + if (error) + return error; /* * An append-only file must be opened in append mode for writing. */ Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06integrity: IMA as an integrity service providerMimi Zohar
IMA provides hardware (TPM) based measurement and attestation for file measurements. As the Trusted Computing (TPM) model requires, IMA measures all files before they are accessed in any way (on the integrity_bprm_check, integrity_path_check and integrity_file_mmap hooks), and commits the measurements to the TPM. Once added to the TPM, measurements can not be removed. In addition, IMA maintains a list of these file measurements, which can be used to validate the aggregate value stored in the TPM. The TPM can sign these measurements, and thus the system can prove, to itself and to a third party, the system's integrity in a way that cannot be circumvented by malicious or compromised software. - alloc ima_template_entry before calling ima_store_template() - log ima_add_boot_aggregate() failure - removed unused IMA_TEMPLATE_NAME_LEN - replaced hard coded string length with #define name Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-12-31introduce new LSM hooks where vfsmount is available.Kentaro Takeda
Add new LSM hooks for path-based checks. Call them on directory-modifying operations at the points where we still know the vfsmount involved. Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-28securityfs: do not depend on CONFIG_SECURITYEric Paris
Add a new Kconfig option SECURITYFS which will build securityfs support but does not require CONFIG_SECURITY. The only current user of securityfs does not depend on CONFIG_SECURITY and there is no reason the full LSM needs to be built to build this fs. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-24security: filesystem capabilities no longer experimentalAndrew G. Morgan
Filesystem capabilities have come of age. Remove the experimental tag for configuring filesystem capabilities. Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14security: remove dummy module fixMiklos Szeredi
Fix small oversight in "security: remove dummy module": CONFIG_SECURITY_FILE_CAPABILITIES doesn't depend on CONFIG_SECURITY Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-14security: remove dummy moduleMiklos Szeredi
Remove the dummy module and make the "capability" module the default. Compile and boot tested. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18security: enhance DEFAULT_MMAP_MIN_ADDR descriptionmaximilian attems
Got burned by setting the proposed default of 65536 across all Debian archs. Thus proposing to be more specific on which archs you may set this. Also propose a value for arm and friends that doesn't break sshd. Reword to mention working archs ia64 and ppc64 too. Signed-off-by: maximilian attems <max@stro.at> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Gordon Farquharson <gordonfarquharson@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-02-06security: allow Kconfig to set default mmap_min_addr protectionEric Paris
Since it was decided that low memory protection from userspace couldn't be turned on by default add a Kconfig option to allow users/distros to set a default at compile time. This value is still tunable after boot in /proc/sys/vm/mmap_min_addr Discussion: http://www.mail-archive.com/linux-security-module@vger.kernel.org/msg02543.html Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-02-05Smack: Simplified Mandatory Access Control KernelCasey Schaufler
Smack is the Simplified Mandatory Access Control Kernel. Smack implements mandatory access control (MAC) using labels attached to tasks and data containers, including files, SVIPC, and other tasks. Smack is a kernel based scheme that requires an absolute minimum of application support and a very small amount of configuration data. Smack uses extended attributes and provides a set of general mount options, borrowing technics used elsewhere. Smack uses netlabel for CIPSO labeling. Smack provides a pseudo-filesystem smackfs that is used for manipulation of system Smack attributes. The patch, patches for ls and sshd, a README, a startup script, and x86 binaries for ls and sshd are also available on http://www.schaufler-ca.com Development has been done using Fedora Core 7 in a virtual machine environment and on an old Sony laptop. Smack provides mandatory access controls based on the label attached to a task and the label attached to the object it is attempting to access. Smack labels are deliberately short (1-23 characters) text strings. Single character labels using special characters are reserved for system use. The only operation applied to Smack labels is equality comparison. No wildcards or expressions, regular or otherwise, are used. Smack labels are composed of printable characters and may not include "/". A file always gets the Smack label of the task that created it. Smack defines and uses these labels: "*" - pronounced "star" "_" - pronounced "floor" "^" - pronounced "hat" "?" - pronounced "huh" The access rules enforced by Smack are, in order: 1. Any access requested by a task labeled "*" is denied. 2. A read or execute access requested by a task labeled "^" is permitted. 3. A read or execute access requested on an object labeled "_" is permitted. 4. Any access requested on an object labeled "*" is permitted. 5. Any access requested by a task on an object with the same label is permitted. 6. Any access requested that is explicitly defined in the loaded rule set is permitted. 7. Any other access is denied. Rules may be explicitly defined by writing subject,object,access triples to /smack/load. Smack rule sets can be easily defined that describe Bell&LaPadula sensitivity, Biba integrity, and a variety of interesting configurations. Smack rule sets can be modified on the fly to accommodate changes in the operating environment or even the time of day. Some practical use cases: Hierarchical levels. The less common of the two usual uses for MLS systems is to define hierarchical levels, often unclassified, confidential, secret, and so on. To set up smack to support this, these rules could be defined: C Unclass rx S C rx S Unclass rx TS S rx TS C rx TS Unclass rx A TS process can read S, C, and Unclass data, but cannot write it. An S process can read C and Unclass. Note that specifying that TS can read S and S can read C does not imply TS can read C, it has to be explicitly stated. Non-hierarchical categories. This is the more common of the usual uses for an MLS system. Since the default rule is that a subject cannot access an object with a different label no access rules are required to implement compartmentalization. A case that the Bell & LaPadula policy does not allow is demonstrated with this Smack access rule: A case that Bell&LaPadula does not allow that Smack does: ESPN ABC r ABC ESPN r On my portable video device I have two applications, one that shows ABC programming and the other ESPN programming. ESPN wants to show me sport stories that show up as news, and ABC will only provide minimal information about a sports story if ESPN is covering it. Each side can look at the other's info, neither can change the other. Neither can see what FOX is up to, which is just as well all things considered. Another case that I especially like: SatData Guard w Guard Publish w A program running with the Guard label opens a UDP socket and accepts messages sent by a program running with a SatData label. The Guard program inspects the message to ensure it is wholesome and if it is sends it to a program running with the Publish label. This program then puts the information passed in an appropriate place. Note that the Guard program cannot write to a Publish file system object because file system semanitic require read as well as write. The four cases (categories, levels, mutual read, guardbox) here are all quite real, and problems I've been asked to solve over the years. The first two are easy to do with traditonal MLS systems while the last two you can't without invoking privilege, at least for a while. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Cc: Joshua Brindle <method@manicmethod.com> Cc: Paul Moore <paul.moore@hp.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Chris Wright <chrisw@sous-sol.org> Cc: James Morris <jmorris@namei.org> Cc: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Andrew G. Morgan <morgan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30security: compile capabilities by defaultsergeh@us.ibm.com
Capabilities have long been the default when CONFIG_SECURITY=n, and its help text suggests turning it on when CONFIG_SECURITY=y. But it is set to default n. Default it to y instead. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17Implement file posix capabilitiesSerge E. Hallyn
Implement file posix capabilities. This allows programs to be given a subset of root's powers regardless of who runs them, without having to use setuid and giving the binary all of root's powers. This version works with Kaigai Kohei's userspace tools, found at http://www.kaigai.gr.jp/index.php. For more information on how to use this patch, Chris Friedhoff has posted a nice page at http://www.friedhoff.org/fscaps.html. Changelog: Nov 27: Incorporate fixes from Andrew Morton (security-introduce-file-caps-tweaks and security-introduce-file-caps-warning-fix) Fix Kconfig dependency. Fix change signaling behavior when file caps are not compiled in. Nov 13: Integrate comments from Alexey: Remove CONFIG_ ifdef from capability.h, and use %zd for printing a size_t. Nov 13: Fix endianness warnings by sparse as suggested by Alexey Dobriyan. Nov 09: Address warnings of unused variables at cap_bprm_set_security when file capabilities are disabled, and simultaneously clean up the code a little, by pulling the new code into a helper function. Nov 08: For pointers to required userspace tools and how to use them, see http://www.friedhoff.org/fscaps.html. Nov 07: Fix the calculation of the highest bit checked in check_cap_sanity(). Nov 07: Allow file caps to be enabled without CONFIG_SECURITY, since capabilities are the default. Hook cap_task_setscheduler when !CONFIG_SECURITY. Move capable(TASK_KILL) to end of cap_task_kill to reduce audit messages. Nov 05: Add secondary calls in selinux/hooks.c to task_setioprio and task_setscheduler so that selinux and capabilities with file cap support can be stacked. Sep 05: As Seth Arnold points out, uid checks are out of place for capability code. Sep 01: Define task_setscheduler, task_setioprio, cap_task_kill, and task_setnice to make sure a user cannot affect a process in which they called a program with some fscaps. One remaining question is the note under task_setscheduler: are we ok with CAP_SYS_NICE being sufficient to confine a process to a cpuset? It is a semantic change, as without fsccaps, attach_task doesn't allow CAP_SYS_NICE to override the uid equivalence check. But since it uses security_task_setscheduler, which elsewhere is used where CAP_SYS_NICE can be used to override the uid equivalence check, fixing it might be tough. task_setscheduler note: this also controls cpuset:attach_task. Are we ok with CAP_SYS_NICE being used to confine to a cpuset? task_setioprio task_setnice sys_setpriority uses this (through set_one_prio) for another process. Need same checks as setrlimit Aug 21: Updated secureexec implementation to reflect the fact that euid and uid might be the same and nonzero, but the process might still have elevated caps. Aug 15: Handle endianness of xattrs. Enforce capability version match between kernel and disk. Enforce that no bits beyond the known max capability are set, else return -EPERM. With this extra processing, it may be worth reconsidering doing all the work at bprm_set_security rather than d_instantiate. Aug 10: Always call getxattr at bprm_set_security, rather than caching it at d_instantiate. [morgan@kernel.org: file-caps clean up for linux/capability.h] [bunk@kernel.org: unexport cap_inode_killpriv] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Andrew Morgan <morgan@kernel.org> Signed-off-by: Andrew Morgan <morgan@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17security: Convert LSM into a static interfaceJames Morris
Convert LSM into a static interface, as the ability to unload a security module is not required by in-tree users and potentially complicates the overall security architecture. Needlessly exported LSM symbols have been unexported, to help reduce API abuse. Parameters for the capability and root_plug modules are now specified at boot. The SECURITY_FRAMEWORK_VERSION macro has also been removed. In a nutshell, there is no safe way to unload an LSM. The modular interface is thus unecessary and broken infrastructure. It is used only by out-of-tree modules, which are often binary-only, illegal, abusive of the API and dangerous, e.g. silently re-vectoring SELinux. [akpm@linux-foundation.org: cleanups] [akpm@linux-foundation.org: USB Kconfig fix] [randy.dunlap@oracle.com: fix LSM kernel-doc] Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Acked-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] LSM: remove BSD secure level security moduleChris Wright
This code has suffered from broken core design and lack of developer attention. Broken security modules are too dangerous to leave around. It is time to remove this one. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Davi Arnaut <davi.arnaut@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: James Morris <jmorris@namei.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] keys: restrict contents of /proc/keys to Viewable keysMichael LeMay
Restrict /proc/keys such that only those keys to which the current task is granted View permission are presented. The documentation is also updated to reflect these changes. Signed-off-by: Michael LeMay <mdlemay@epoch.ncsc.mil> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-22[PATCH] SECURITY must depend on SYSFSAdrian Bunk
CONFIG_SECURITY=y and CONFIG_SYSFS=n results in the following compile error: <-- snip --> ... LD vmlinux security/built-in.o: In function `securityfs_init': inode.c:(.init.text+0x1c2): undefined reference to `kernel_subsys' make: *** [vmlinux] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Chris Wright <chrisw@osdl.org>
