Change-Id: I318afbe66efa346b71e82413ac6442672cef4d36
Reviewed-on: http://git-master/r/21196
Reviewed-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Tested-by: Jonathan B White (Engrg-Mobile) <jwhite@nvidia.com>
Reviewed-by: Maria Gutowski <mgutowski@nvidia.com>
Kconfig and Makefiles to enable configuration and building of AppArmor.
Signed-off-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: James Morris <jmorris@namei.org>
As far as I know, all distros currently ship kernels with default
CONFIG_SECURITY_FILE_CAPABILITIES=y. Since having the option on
leaves a 'no_file_caps' option to boot without file capabilities,
the main reason to keep the option is that turning it off saves
you (on my s390x partition) 5k. In particular, vmlinux sizes
came to:
without patch fscaps=n: 53598392
without patch fscaps=y: 53603406
with this patch applied: 53603342
with the security-next tree.
Against this we must weigh the fact that there is no simple way for
userspace to figure out whether file capabilities are supported,
while things like per-process securebits, capability bounding
sets, and adding bits to pI if CAP_SETPCAP is in pE are not supported
with SECURITY_FILE_CAPABILITIES=n, leaving a bit of a problem for
applications wanting to know whether they can use them and/or why
something failed.
It also adds another subtly different set of semantics which we must
maintain at the risk of severe security regressions.
So this patch removes the SECURITY_FILE_CAPABILITIES compile
option. It drops the kernel size by about 50k over the stock
SECURITY_FILE_CAPABILITIES=y kernel, by removing the
cap_limit_ptraced_target() function.
Changelog:
Nov 20: remove cap_limit_ptraced_target() as it's logic
was ifndef'ed.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Acked-by: Andrew G. Morgan" <morgan@kernel.org>
The LSM currently requires setting a kernel parameter at boot to select
a specific LSM. This adds a config option that allows specifying a default
LSM that is used unless overridden with the security= kernel parameter.
If the the config option is not set the current behavior of first LSM
to register is used.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Remove the root_plug example LSM code. It's unmaintained and
increasingly broken in various ways.
Made at the 2009 Kernel Summit in Tokyo!
arch/x86/kernel/reboot.c
security/Kconfig
Merge reason: resolve the conflicts, bump up from rc3 to rc8.
Move tboot.h from asm to linux to fix the build errors of intel_txt
patch on non-X86 platforms. Remove the tboot code from generic code
init/main.c and kernel/cpu.c.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Fix prompt for LSM_MMAP_MIN_ADDR.
(Verbs are cool!)
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Eric Paris <eparis@redhat.com>
Commit 788084aba2ab7348257597496befcbccabdc98a3 added the LSM_MMAP_MIN_ADDR
option, whose help text states "For most ia64, ppc64 and x86 users with lots
of address space a value of 65536 is reasonable and should cause no problems."
Which implies that it's default setting was typoed.
Signed-off-by: Dave Jones <davej@redhat.com>
Currently SELinux enforcement of controls on the ability to map low memory
is determined by the mmap_min_addr tunable. This patch causes SELinux to
ignore the tunable and instead use a seperate Kconfig option specific to how
much space the LSM should protect.
The tunable will now only control the need for CAP_SYS_RAWIO and SELinux
permissions will always protect the amount of low memory designated by
CONFIG_LSM_MMAP_MIN_ADDR.
This allows users who need to disable the mmap_min_addr controls (usual reason
being they run WINE as a non-root user) to do so and still have SELinux
controls preventing confined domains (like a web server) from being able to
map some area of low memory.
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This patch adds kernel configuration and boot support for Intel Trusted
Execution Technology (Intel TXT).
Intel's technology for safer computing, Intel Trusted Execution
Technology (Intel TXT), defines platform-level enhancements that
provide the building blocks for creating trusted platforms.
Intel TXT was formerly known by the code name LaGrande Technology (LT).
Intel TXT in Brief:
o Provides dynamic root of trust for measurement (DRTM)
o Data protection in case of improper shutdown
o Measurement and verification of launched environment
Intel TXT is part of the vPro(TM) brand and is also available some
non-vPro systems. It is currently available on desktop systems based on
the Q35, X38, Q45, and Q43 Express chipsets (e.g. Dell Optiplex 755, HP
dc7800, etc.) and mobile systems based on the GM45, PM45, and GS45
Express chipsets.
For more information, see http://www.intel.com/technology/security/.
This site also has a link to the Intel TXT MLE Developers Manual, which
has been updated for the new released platforms.
A much more complete description of how these patches support TXT, how to
configure a system for it, etc. is in the Documentation/intel_txt.txt file
in this patch.
This patch provides the TXT support routines for complete functionality,
documentation for TXT support and for the changes to the boot_params structure,
and boot detection of a TXT launch. Attempts to shutdown (reboot, Sx) the system
will result in platform resets; subsequent patches will support these shutdown modes
properly.
Documentation/intel_txt.txt | 210 +++++++++++++++++++++
Documentation/x86/zero-page.txt | 1
arch/x86/include/asm/bootparam.h | 3
arch/x86/include/asm/fixmap.h | 3
arch/x86/include/asm/tboot.h | 197 ++++++++++++++++++++
arch/x86/kernel/Makefile | 1
arch/x86/kernel/setup.c | 4
arch/x86/kernel/tboot.c | 379 +++++++++++++++++++++++++++++++++++++++
security/Kconfig | 30 +++
9 files changed, 827 insertions(+), 1 deletion(-)
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
Signed-off-by: Gang Wei <gang.wei@intel.com>
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY.
It also sets a default mmap_min_addr of 4096.
mmapping of addresses below 4096 will only be possible for processes
with CAP_SYS_RAWIO.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org>
TOMOYO uses LSM hooks for pathname based access control and securityfs support.
Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp>
fs/namei.c
Manually merged per:
diff --cc fs/namei.c
index 734f2b5,bbc15c2..0000000
--- a/fs/namei.c
+++ b/fs/namei.c
@@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char
nd->flags |= LOOKUP_CONTINUE;
err = exec_permission_lite(inode);
if (err == -EAGAIN)
- err = vfs_permission(nd, MAY_EXEC);
+ err = inode_permission(nd->path.dentry->d_inode,
+ MAY_EXEC);
+ if (!err)
+ err = ima_path_check(&nd->path, MAY_EXEC);
if (err)
break;
@@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc
flag &= ~O_TRUNC;
- error = vfs_permission(nd, acc_mode);
+ error = inode_permission(inode, acc_mode);
if (error)
return error;
- error = ima_path_check(&nd->path,
++ error = ima_path_check(path,
+ acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC));
+ if (error)
+ return error;
* An append-only file must be opened in append mode for writing.
IMA provides hardware (TPM) based measurement and attestation for
file measurements. As the Trusted Computing (TPM) model requires,
IMA measures all files before they are accessed in any way (on the
integrity_bprm_check, integrity_path_check and integrity_file_mmap
hooks), and commits the measurements to the TPM. Once added to the
TPM, measurements can not be removed.
In addition, IMA maintains a list of these file measurements, which
can be used to validate the aggregate value stored in the TPM. The
TPM can sign these measurements, and thus the system can prove, to
itself and to a third party, the system's integrity in a way that
cannot be circumvented by malicious or compromised software.
- alloc ima_template_entry before calling ima_store_template()
- log ima_add_boot_aggregate() failure
- removed unused IMA_TEMPLATE_NAME_LEN
- replaced hard coded string length with #define name
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Add new LSM hooks for path-based checks. Call them on directory-modifying
operations at the points where we still know the vfsmount involved.
Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp>
Add a new Kconfig option SECURITYFS which will build securityfs support
but does not require CONFIG_SECURITY. The only current user of
securityfs does not depend on CONFIG_SECURITY and there is no reason the
full LSM needs to be built to build this fs.
Filesystem capabilities have come of age. Remove the experimental tag for
configuring filesystem capabilities.
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Fix small oversight in "security: remove dummy module":
CONFIG_SECURITY_FILE_CAPABILITIES doesn't depend on CONFIG_SECURITY
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Remove the dummy module and make the "capability" module the default.
Compile and boot tested.
Got burned by setting the proposed default of 65536
across all Debian archs.
Thus proposing to be more specific on which archs you may
set this. Also propose a value for arm and friends that
doesn't break sshd.
Reword to mention working archs ia64 and ppc64 too.
Signed-off-by: maximilian attems <max@stro.at>
Cc: Martin Michlmayr <tbm@cyrius.com>
Cc: Gordon Farquharson <gordonfarquharson@gmail.com>
Since it was decided that low memory protection from userspace couldn't
be turned on by default add a Kconfig option to allow users/distros to
set a default at compile time. This value is still tunable after boot
in /proc/sys/vm/mmap_min_addr
Discussion:
http://www.mail-archive.com/linux-security-module@vger.kernel.org/msg02543.html
Smack is the Simplified Mandatory Access Control Kernel.
Smack implements mandatory access control (MAC) using labels
attached to tasks and data containers, including files, SVIPC,
and other tasks. Smack is a kernel based scheme that requires
an absolute minimum of application support and a very small
amount of configuration data.
Smack uses extended attributes and
provides a set of general mount options, borrowing technics used
elsewhere. Smack uses netlabel for CIPSO labeling. Smack provides
a pseudo-filesystem smackfs that is used for manipulation of
system Smack attributes.
The patch, patches for ls and sshd, a README, a startup script,
and x86 binaries for ls and sshd are also available on
http://www.schaufler-ca.com
Development has been done using Fedora Core 7 in a virtual machine
environment and on an old Sony laptop.
Smack provides mandatory access controls based on the label attached
to a task and the label attached to the object it is attempting to
access. Smack labels are deliberately short (1-23 characters) text
strings. Single character labels using special characters are reserved
for system use. The only operation applied to Smack labels is equality
comparison. No wildcards or expressions, regular or otherwise, are
used. Smack labels are composed of printable characters and may not
include "/".
A file always gets the Smack label of the task that created it.
Smack defines and uses these labels:
"*" - pronounced "star"
"_" - pronounced "floor"
"^" - pronounced "hat"
"?" - pronounced "huh"
The access rules enforced by Smack are, in order:
1. Any access requested by a task labeled "*" is denied.
2. A read or execute access requested by a task labeled "^"
is permitted.
3. A read or execute access requested on an object labeled "_"
is permitted.
4. Any access requested on an object labeled "*" is permitted.
5. Any access requested by a task on an object with the same
label is permitted.
6. Any access requested that is explicitly defined in the loaded
rule set is permitted.
7. Any other access is denied.
Rules may be explicitly defined by writing subject,object,access
triples to /smack/load.
Smack rule sets can be easily defined that describe Bell&LaPadula
sensitivity, Biba integrity, and a variety of interesting
configurations. Smack rule sets can be modified on the fly to
accommodate changes in the operating environment or even the time
of day.
Some practical use cases:
Hierarchical levels. The less common of the two usual uses
for MLS systems is to define hierarchical levels, often
unclassified, confidential, secret, and so on. To set up smack
to support this, these rules could be defined:
C Unclass rx
S C rx
S Unclass rx
TS S rx
TS C rx
TS Unclass rx
A TS process can read S, C, and Unclass data, but cannot write it.
An S process can read C and Unclass. Note that specifying that
TS can read S and S can read C does not imply TS can read C, it
has to be explicitly stated.
Non-hierarchical categories. This is the more common of the
usual uses for an MLS system. Since the default rule is that a
subject cannot access an object with a different label no
access rules are required to implement compartmentalization.
A case that the Bell & LaPadula policy does not allow is demonstrated
with this Smack access rule:
A case that Bell&LaPadula does not allow that Smack does:
ESPN ABC r
ABC ESPN r
On my portable video device I have two applications, one that
shows ABC programming and the other ESPN programming. ESPN wants
to show me sport stories that show up as news, and ABC will
only provide minimal information about a sports story if ESPN
is covering it. Each side can look at the other's info, neither
can change the other. Neither can see what FOX is up to, which
is just as well all things considered.
Another case that I especially like:
SatData Guard w
Guard Publish w
A program running with the Guard label opens a UDP socket and
accepts messages sent by a program running with a SatData label.
The Guard program inspects the message to ensure it is wholesome
and if it is sends it to a program running with the Publish label.
This program then puts the information passed in an appropriate
place. Note that the Guard program cannot write to a Publish
file system object because file system semanitic require read as
well as write.
The four cases (categories, levels, mutual read, guardbox) here
are all quite real, and problems I've been asked to solve over
the years. The first two are easy to do with traditonal MLS systems
while the last two you can't without invoking privilege, at least
for a while.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Cc: Joshua Brindle <method@manicmethod.com>
Cc: Paul Moore <paul.moore@hp.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: "Ahmed S. Darwish" <darwish.07@gmail.com>
Cc: Andrew G. Morgan <morgan@kernel.org>
Capabilities have long been the default when CONFIG_SECURITY=n,
and its help text suggests turning it on when CONFIG_SECURITY=y.
But it is set to default n.
Default it to y instead.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Matt LaPlante <kernel1@cyberdogtech.com>
Implement file posix capabilities. This allows programs to be given a
subset of root's powers regardless of who runs them, without having to use
setuid and giving the binary all of root's powers.
This version works with Kaigai Kohei's userspace tools, found at
http://www.kaigai.gr.jp/index.php. For more information on how to use this
patch, Chris Friedhoff has posted a nice page at
http://www.friedhoff.org/fscaps.html.
Changelog:
Nov 27:
Incorporate fixes from Andrew Morton
(security-introduce-file-caps-tweaks and
security-introduce-file-caps-warning-fix)
Fix Kconfig dependency.
Fix change signaling behavior when file caps are not compiled in.
Nov 13:
Integrate comments from Alexey: Remove CONFIG_ ifdef from
capability.h, and use %zd for printing a size_t.
Nov 13:
Fix endianness warnings by sparse as suggested by Alexey
Dobriyan.
Nov 09:
Address warnings of unused variables at cap_bprm_set_security
when file capabilities are disabled, and simultaneously clean
up the code a little, by pulling the new code into a helper
function.
Nov 08:
For pointers to required userspace tools and how to use
them, see http://www.friedhoff.org/fscaps.html.
Nov 07:
Fix the calculation of the highest bit checked in
check_cap_sanity().
Nov 07:
Allow file caps to be enabled without CONFIG_SECURITY, since
capabilities are the default.
Hook cap_task_setscheduler when !CONFIG_SECURITY.
Move capable(TASK_KILL) to end of cap_task_kill to reduce
audit messages.
Nov 05:
Add secondary calls in selinux/hooks.c to task_setioprio and
task_setscheduler so that selinux and capabilities with file
cap support can be stacked.
Sep 05:
As Seth Arnold points out, uid checks are out of place
for capability code.
Sep 01:
Define task_setscheduler, task_setioprio, cap_task_kill, and
task_setnice to make sure a user cannot affect a process in which
they called a program with some fscaps.
One remaining question is the note under task_setscheduler: are we
ok with CAP_SYS_NICE being sufficient to confine a process to a
cpuset?
It is a semantic change, as without fsccaps, attach_task doesn't
allow CAP_SYS_NICE to override the uid equivalence check. But since
it uses security_task_setscheduler, which elsewhere is used where
CAP_SYS_NICE can be used to override the uid equivalence check,
fixing it might be tough.
task_setscheduler
note: this also controls cpuset:attach_task. Are we ok with
CAP_SYS_NICE being used to confine to a cpuset?
task_setioprio
task_setnice
sys_setpriority uses this (through set_one_prio) for another
process. Need same checks as setrlimit
Aug 21:
Updated secureexec implementation to reflect the fact that
euid and uid might be the same and nonzero, but the process
might still have elevated caps.
Aug 15:
Handle endianness of xattrs.
Enforce capability version match between kernel and disk.
Enforce that no bits beyond the known max capability are
set, else return -EPERM.
With this extra processing, it may be worth reconsidering
doing all the work at bprm_set_security rather than
d_instantiate.
Aug 10:
Always call getxattr at bprm_set_security, rather than
caching it at d_instantiate.
[morgan@kernel.org: file-caps clean up for linux/capability.h]
[bunk@kernel.org: unexport cap_inode_killpriv]
Cc: Andrew Morgan <morgan@kernel.org>
Signed-off-by: Andrew Morgan <morgan@kernel.org>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Convert LSM into a static interface, as the ability to unload a security
module is not required by in-tree users and potentially complicates the
overall security architecture.
Needlessly exported LSM symbols have been unexported, to help reduce API
abuse.
Parameters for the capability and root_plug modules are now specified
at boot.
The SECURITY_FRAMEWORK_VERSION macro has also been removed.
In a nutshell, there is no safe way to unload an LSM. The modular interface
is thus unecessary and broken infrastructure. It is used only by out-of-tree
modules, which are often binary-only, illegal, abusive of the API and
dangerous, e.g. silently re-vectoring SELinux.
[akpm@linux-foundation.org: cleanups]
[akpm@linux-foundation.org: USB Kconfig fix]
[randy.dunlap@oracle.com: fix LSM kernel-doc]
Acked-by: Chris Wright <chrisw@sous-sol.org>
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Acked-by: Arjan van de Ven <arjan@infradead.org>
This code has suffered from broken core design and lack of developer
attention. Broken security modules are too dangerous to leave around. It
is time to remove this one.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Davi Arnaut <davi.arnaut@gmail.com>
Acked-by: James Morris <jmorris@namei.org>
Acked-by: Alan Cox <alan@redhat.com>
Restrict /proc/keys such that only those keys to which the current task is
granted View permission are presented.
The documentation is also updated to reflect these changes.
Signed-off-by: Michael LeMay <mdlemay@epoch.ncsc.mil>
This patch series implements per packet access control via the
extension of the Linux Security Modules (LSM) interface by hooks in
the XFRM and pfkey subsystems that leverage IPSec security
associations to label packets. Extensions to the SELinux LSM are
included that leverage the patch for this purpose.
This patch implements the changes necessary to the XFRM subsystem,
pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a
socket to use only authorized security associations (or no security
association) to send/receive network packets.
Patch purpose:
The patch is designed to enable access control per packets based on
the strongly authenticated IPSec security association. Such access
controls augment the existing ones based on network interface and IP
address. The former are very coarse-grained, and the latter can be
spoofed. By using IPSec, the system can control access to remote
hosts based on cryptographic keys generated using the IPSec mechanism.
This enables access control on a per-machine basis or per-application
if the remote machine is running the same mechanism and trusted to
enforce the access control policy.
Patch design approach:
The overall approach is that policy (xfrm_policy) entries set by
user-level programs (e.g., setkey for ipsec-tools) are extended with a
security context that is used at policy selection time in the XFRM
subsystem to restrict the sockets that can send/receive packets via
security associations (xfrm_states) that are built from those
policies.
A presentation available at
www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf
from the SELinux symposium describes the overall approach.
Patch implementation details:
On output, the policy retrieved (via xfrm_policy_lookup or
xfrm_sk_policy_lookup) must be authorized for the security context of
the socket and the same security context is required for resultant
security association (retrieved or negotiated via racoon in
ipsec-tools). This is enforced in xfrm_state_find.
On input, the policy retrieved must also be authorized for the socket
(at __xfrm_policy_check), and the security context of the policy must
also match the security association being used.
The patch has virtually no impact on packets that do not use IPSec.
The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as
before.
Also, if IPSec is used without security contexts, the impact is
minimal. The LSM must allow such policies to be selected for the
combination of socket and remote machine, but subsequent IPSec
processing proceeds as in the original case.
Testing:
The pfkey interface is tested using the ipsec-tools. ipsec-tools have
been modified (a separate ipsec-tools patch is available for version
0.5) that supports assignment of xfrm_policy entries and security
associations with security contexts via setkey and the negotiation
using the security contexts via racoon.
The xfrm_user interface is tested via ad hoc programs that set
security contexts. These programs are also available from me, and
contain programs for setting, getting, and deleting policy for testing
this interface. Testing of sa functions was done by tracing kernel
behavior.
Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu>
CONFIG_SECURITY=y and CONFIG_SYSFS=n results in the following compile
error:
<-- snip -->
LD vmlinux
security/built-in.o: In function `securityfs_init':
inode.c:(.init.text+0x1c2): undefined reference to `kernel_subsys'
make: *** [vmlinux] Error 1
<-- snip -->
Signed-off-by: Chris Wright <chrisw@osdl.org>
infrastructure for it.
Let it rip!
