path: root/security/apparmor/Makefile
2012-10-17apparmor: fix apparmor OOPS in audit_log_untrustedstring+0x1c/0x40John Johansen
The capability defines have moved causing the auto generated names of capabilities that apparmor uses in logging to be incorrect. Fix the autogenerated table source to uapi/linux/capability.h Reported-by: YanHong <clouds.yan@gmail.com> Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Analyzed-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-04UAPI: (Scripted) Disintegrate include/asm-genericDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-03-19AppArmor: Fix location of const qualifier on generated string tablesTetsuo Handa
Signed-off-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Signed-off-by: John Johansen <john.johansen@canonical.com>
2012-03-14AppArmor: Add const qualifiers to generated string tablesJohn Johansen
2012-02-27AppArmor: export known rlimit names/value mappings in securityfsKees Cook
Since the parser needs to know which rlimits are known to the kernel, export the list via a mask file in the "rlimit" subdirectory in the securityfs "features" directory. Signed-off-by: Kees Cook <kees@ubuntu.com> Signed-off-by: John Johansen <john.johansen@canonical.com>
2011-03-08AppArmor: cleanup generated files correctlyMichal Hocko
clean-files should be defined as a variable not a target. Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: John Johansen <john.johansen@canonical.com>
2011-03-05AppArmor: Cleanup make file to remove cruft and make it easier to readJohn Johansen
Cleanups based on comments from Sam Ravnborg, * remove references to the currently unused af_names.h * add rlim_names.h to clean-files: * rework cmd_make-XXX to make them more readable by adding comments, reworking the expressions to put logical components on individual lines, and keep lines < 80 characters. Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-02AppArmor: Enable configuring and building of the AppArmor security moduleJohn Johansen
Kconfig and Makefiles to enable configuration and building of AppArmor. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
