path: root/security/apparmor/policy.c
2010-11-11APPARMOR: Fix memory leak of alloc_namespace()wzt.wzt@gmail.com
policy->name is a substring of policy->hname, if prefix is not NULL, it will allocted strlen(prefix) + strlen(name) + 3 bytes to policy->hname in policy_init(). use kzfree(ns->base.name) will casue memory leak if alloc_namespace() failed. Signed-off-by: Zhitong Wang <zhitong.wangzt@alibaba-inc.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-09-08AppArmor: Fix locking from removal of profile namespaceJohn Johansen
The locking for profile namespace removal is wrong, when removing a profile namespace, it needs to be removed from its parent's list. Lock the parent of namespace list instead of the namespace being removed. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02AppArmor: core policy routinesJohn Johansen
The basic routines and defines for AppArmor policy. AppArmor policy is defined by a few basic components. profiles - the basic unit of confinement contain all the information to enforce policy on a task Profiles tend to be named after an executable that they will attach to but this is not required. namespaces - a container for a set of profiles that will be used during attachment and transitions between profiles. sids - which provide a unique id for each profile Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
