path: root/security/apparmor/procattr.c
2011-09-09apparmor: sparse fix: include procattr.h in procattr.cJames Morris
Fix sparse warnings: security/apparmor/procattr.c:35:5: warning: symbol 'aa_getprocattr' was not declared. Should it be static? security/apparmor/procattr.c:113:5: warning: symbol 'aa_setprocattr_changehat' was not declared. Should it be static? security/apparmor/procattr.c:158:5: warning: symbol 'aa_setprocattr_changeprofile' was not declared. Should it be static? security/apparmor/procattr.c:166:5: warning: symbol 'aa_setprocattr_permipc' was not declared. Should it be static? Signed-off-by: James Morris <jmorris@namei.org> Acked-by: John Johansen <john.johansen@canonical.com>
2010-08-02AppArmor: userspace interfacesJohn Johansen
The /proc/<pid>/attr/* interface is used for process introspection and commands. While the apparmorfs interface is used for global introspection and loading and removing policy. The interface currently only contains the files necessary for loading policy, and will be extended in the future to include sysfs style single per file introspection inteface. The old AppArmor 2.4 interface files have been removed into a compatibility patch, that distros can use to maintain backwards compatibility. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
