path: root/security/inode.c
2010-10-29convert get_sb_single() usersAl Viro
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-02securityfs: Drop dentry reference count when mknod failsTvrtko Ursulin
lookup_one_len increments dentry reference count which is not decremented when the create operation fails. This can cause a kernel BUG at fs/dcache.c:676 at unmount time. Also error code returned when new_inode() fails was replaced with more appropriate -ENOMEM. Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-22security: testing the wrong variable in create_by_name()Dan Carpenter
There is a typo here. We should be testing "*dentry" instead of "dentry". If "*dentry" is an ERR_PTR, it gets dereferenced in either mkdir() or create() which would cause an OOPs. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-01-26get rid of pointless checks after simple_pin_fs()Al Viro
if we'd just got success from it, vfsmount won't be NULL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-12securityfs: securityfs_remove should handle IS_ERR pointersEric Paris
Both of the securityfs users (TPM and IMA) can call securityfs_remove and pass an IS_ERR(dentry) in their failure paths. This patch handles those rather than panicing when it tries to start deferencing some negative memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-06Merge branch 'master' into nextJames Morris
Conflicts: fs/namei.c Manually merged per: diff --cc fs/namei.c index 734f2b5,bbc15c2..0000000 --- a/fs/namei.c +++ b/fs/namei.c @@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char nd->flags |= LOOKUP_CONTINUE; err = exec_permission_lite(inode); if (err == -EAGAIN) - err = vfs_permission(nd, MAY_EXEC); + err = inode_permission(nd->path.dentry->d_inode, + MAY_EXEC); + if (!err) + err = ima_path_check(&nd->path, MAY_EXEC); if (err) break; @@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc flag &= ~O_TRUNC; } - error = vfs_permission(nd, acc_mode); + error = inode_permission(inode, acc_mode); if (error) return error; + - error = ima_path_check(&nd->path, ++ error = ima_path_check(path, + acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC)); + if (error) + return error; /* * An append-only file must be opened in append mode for writing. */ Signed-off-by: James Morris <jmorris@namei.org>
2009-02-03securityfs: fix long-broken securityfs_create_file commentSerge E. Hallyn
If there is an error creating a file through securityfs_create_file, NULL is not returned, rather the error is propagated. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-13integrity: special fs magicMimi Zohar
Discussion on the mailing list questioned the use of these magic values in userspace, concluding these values are already exported to userspace via statfs and their correct/incorrect usage is left up to the userspace application. - Move special fs magic number definitions to magic.h - Add magic.h include Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-20security: add/fix security kernel-docRandy Dunlap
Add security/inode.c functions to the kernel-api docbook. Use '%' on constants in kernel-doc notation. Fix several typos/spellos in security function descriptions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-01-24Kobject: convert remaining kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert kernel_kset to be a kobjectGreg Kroah-Hartman
kernel_kset does not need to be a kset, but a much simpler kobject now that we have kobj_attributes. We also rename kernel_kset to kernel_kobj to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert kernel_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename kernel_subsys to kernel_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert securityfs to use kobject_createGreg Kroah-Hartman
We don't need a kset here, a simple kobject will do just fine, so dynamically create the kobject and use it. Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-17security/ cleanupsAdrian Bunk
This patch contains the following cleanups that are now possible: - remove the unused security_operations->inode_xattr_getsuffix - remove the no longer used security_operations->unregister_security - remove some no longer required exit code - remove a bunch of no longer used exports Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-12[PATCH] mark struct file_operations const 9Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-07-08[PATCH] add securityfs for all LSMs to useGreg KH
Here's a small patch against 2.6.13-rc2 that adds securityfs, a virtual fs that all LSMs can use instead of creating their own. The fs should be mounted at /sys/kernel/security, and the fs creates that mount point. This will make the LSB people happy that we aren't creating a new /my_lsm_fs directory in the root for every different LSM. It has changed a bit since the last version, thanks to comments from Mike Waychison. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Chris Wright <chrisw@osdl.org>
