commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream.
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
... except where that code acts as a filesystem driver, rather than
working with dentries given to it.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
This patch fix spelling typo found in DocBook/kernel-api.xml.
It is because the file is generated from the source comments,
I have to fix the comments in source codes.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
inode needs to be fully set up before we feed it to d_instantiate().
securityfs_create_file() does *not* do so; it sets ->i_fop and
->i_private only after we'd exposed the inode. Unfortunately,
that's done fairly deep in call chain, so the amount of churn
is considerable. Helper functions killed by substituting into
their solitary call sites, dead code removed. We finally can
bury default_file_ops, now that the final value of ->i_fop is
available (and assigned) at the point where inode is allocated.
Reviewed-by: James Morris <jmorris@namei.org>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
lookup_one_len increments dentry reference count which is not decremented
when the create operation fails. This can cause a kernel BUG at
fs/dcache.c:676 at unmount time. Also error code returned when new_inode()
fails was replaced with more appropriate -ENOMEM.
Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@sophos.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
Signed-off-by: James Morris <jmorris@namei.org>
There is a typo here. We should be testing "*dentry" instead of
"dentry". If "*dentry" is an ERR_PTR, it gets dereferenced in either
mkdir() or create() which would cause an OOPs.
if we'd just got success from it, vfsmount won't be NULL
Both of the securityfs users (TPM and IMA) can call securityfs_remove and pass
an IS_ERR(dentry) in their failure paths. This patch handles those rather
than panicing when it tries to start deferencing some negative memory.
Signed-off-by: Eric Paris <eparis@redhat.com>
fs/namei.c
Manually merged per:
diff --cc fs/namei.c
index 734f2b5,bbc15c2..0000000
--- a/fs/namei.c
+++ b/fs/namei.c
@@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char
nd->flags |= LOOKUP_CONTINUE;
err = exec_permission_lite(inode);
if (err == -EAGAIN)
- err = vfs_permission(nd, MAY_EXEC);
+ err = inode_permission(nd->path.dentry->d_inode,
+ MAY_EXEC);
+ if (!err)
+ err = ima_path_check(&nd->path, MAY_EXEC);
if (err)
break;
@@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc
flag &= ~O_TRUNC;
- error = vfs_permission(nd, acc_mode);
+ error = inode_permission(inode, acc_mode);
if (error)
return error;
- error = ima_path_check(&nd->path,
++ error = ima_path_check(path,
+ acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC));
+ if (error)
+ return error;
* An append-only file must be opened in append mode for writing.
If there is an error creating a file through securityfs_create_file,
NULL is not returned, rather the error is propagated.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
... and don't bother in callers. Don't bother with zeroing i_blocks,
while we are at it - it's already been zeroed.
i_mode is not worth the effort; it has no common default value.
Discussion on the mailing list questioned the use of these
magic values in userspace, concluding these values are already
exported to userspace via statfs and their correct/incorrect
usage is left up to the userspace application.
- Move special fs magic number definitions to magic.h
- Add magic.h include
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Add security/inode.c functions to the kernel-api docbook.
Use '%' on constants in kernel-doc notation.
Fix several typos/spellos in security function descriptions.
There is no need for kobject_unregister() anymore, thanks to Kay's
kobject cleanup changes, so replace all instances of it with
kobject_put().
Cc: Kay Sievers <kay.sievers@vrfy.org>
kernel_kset does not need to be a kset, but a much simpler kobject now
that we have kobj_attributes.
We also rename kernel_kset to kernel_kobj to catch all users of this
symbol with a build error instead of an easy-to-ignore build warning.
Dynamically create the kset instead of declaring it statically. We also
rename kernel_subsys to kernel_kset to catch all users of this symbol
We don't need a kset here, a simple kobject will do just fine, so
dynamically create the kobject and use it.
Acked-by: Chris Wright <chrisw@sous-sol.org>
We don't need a "default" ktype for a kset. We should set this
explicitly every time for each kset. This change is needed so that we
can make ksets dynamic, and cleans up one of the odd, undocumented
assumption that the kset/kobject/ktype model has.
This patch is based on a lot of help from Kay Sievers.
Nasty bug in the block code was found by Dave Young
<hidave.darkstar@gmail.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
This patch contains the following cleanups that are now possible:
- remove the unused security_operations->inode_xattr_getsuffix
- remove the no longer used security_operations->unregister_security
- remove some no longer required exit code
- remove a bunch of no longer used exports
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: James Morris <jmorris@namei.org>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Serge Hallyn <serue@us.ibm.com>
We need to work on cleaning up the relationship between kobjects, ksets and
ktypes. The removal of 'struct subsystem' is the first step of this,
especially as it is not really needed at all.
Thanks to Kay for fixing the bugs in this patch.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Acked-by: Christoph Hellwig <hch@lst.de>
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The following patches reduce the size of the VFS inode structure by 28 bytes
on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction
in the inode size on a UP kernel that is configured in a production mode
(i.e., with no spinlock or other debugging functions enabled; if you want to
save memory taken up by in-core inodes, the first thing you should do is
disable the debugging options; they are responsible for a huge amount of bloat
in the VFS inode structure).
This patch:
The filesystem or device-specific pointer in the inode is inside a union,
which is pretty pointless given that all 30+ users of this field have been
using the void pointer. Get rid of the union and rename it to i_private, with
a comment to explain who is allowed to use the void pointer. This is just a
cleanup, but it allows us to reuse the union 'u' for something something where
the union will actually be used.
[judith@osdl.org: powerpc build fix]
Signed-off-by: Judith Lebzelter <judith@osdl.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
fs/nfs/inode.c
fs/super.c
Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch
'VFS: Permit filesystem to override root dentry on mount'
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Roland Dreier <rolandd@cisco.com>
Replace all module uses with the new vfs_kern_mount() interface, and fix up
simple_pin_fs().
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
Here's a small patch against 2.6.13-rc2 that adds securityfs, a virtual
fs that all LSMs can use instead of creating their own. The fs should
be mounted at /sys/kernel/security, and the fs creates that mount point.
This will make the LSB people happy that we aren't creating a new
/my_lsm_fs directory in the root for every different LSM.
It has changed a bit since the last version, thanks to comments from
Mike Waychison.
Signed-off-by: Chris Wright <chrisw@osdl.org>
