If security_filter_rule_init() doesn't return a rule, then not everything
is as fine as the return code implies.
This bug only occurs when the LSM (eg. SELinux) is disabled at runtime.
Adding an empty LSM rule causes ima_match_rules() to always succeed,
ignoring any remaining rules.
default IMA TCB policy:
# PROC_SUPER_MAGIC
dont_measure fsmagic=0x9fa0
# SYSFS_MAGIC
dont_measure fsmagic=0x62656572
# DEBUGFS_MAGIC
dont_measure fsmagic=0x64626720
# TMPFS_MAGIC
dont_measure fsmagic=0x01021994
# SECURITYFS_MAGIC
dont_measure fsmagic=0x73636673
< LSM specific rule >
dont_measure obj_type=var_log_t
measure func=BPRM_CHECK
measure func=FILE_MMAP mask=MAY_EXEC
measure func=FILE_CHECK mask=MAY_READ uid=0
Thus without the patch, with the boot parameters 'tcb selinux=0', adding
the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB
measurement policy, would result in nothing being measured. The patch
prevents the default TCB policy from being replaced.
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: David Safford <safford@watson.ibm.com>
Cc: <stable@kernel.org>
Convert all of the places IMA calls audit_log_format with %s into
audit_log_untrusted_string(). This is going to cause them all to get
quoted, but it should make audit log injection harder.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Mimi Zohar <zohar@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
IMA policy load parser will reject any policies with a comment. This patch
will allow the parser to just ignore lines which start with a #. This is not
very robust. # can ONLY be used at the very beginning of a line. Inline
comments are not allowed.
IMA parser will fail if whitespace is used in any way other than a single
space. Using a tab or even using 2 spaces in a row will result in a policy
being rejected. This patch makes the kernel ignore whitespace a bit better.
Currently the ima policy load code will print what it doesn't understand
but really I think it should reject any policy it doesn't understand. This
patch makes it so!
ima_parse_rule currently sets entry->action = -1 and then later tests
if (entry->action == UNKNOWN). It is true that UNKNOWN == -1 but actually
setting it to UNKNOWN makes a lot more sense in case things change in the
future.
IMA will accept rules which specify things twice and will only pay
attention to the last one. We should reject such rules.
Currently IMA will only accept one rule per write(). This patch allows IMA to
accept writes which contain multiple rules but only processes one rule per
write. \n is used as the delimiter between rules. IMA will return a short
write indicating that it only accepted up to the first \n.
This allows simple userspace utilities like cat to be used to load an IMA
policy instead of needing a special userspace utility that understood 'one
write per rule'
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
With the movement of the ima hooks functions were renamed from *path* to
*file* since they always deal with struct file. This patch renames some of
the ima internal flags to make them consistent with the rest of the code.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
A number of IMA functions only used during init are not marked with __init.
Add those notations so they are freed automatically.
The IMA TCB policy is dangerous. A normal use can use all of a system's
memory (which cannot be freed) simply by building and running lots of
executables. The TCB policy is also nearly useless because logging in as root
often causes a policy violation when dealing with utmp, thus rendering the
measurements meaningless.
There is no good fix for this in the kernel. A full TCB policy would need to
be loaded in userspace using LSM rule matching to get both a protected and
useful system. But, if too little is measured before userspace can load a real
policy one again ends up with a meaningless set of measurements. One option
would be to put the policy load inside the initrd in order to get it early
enough in the boot sequence to be useful, but this runs into trouble with the
LSM. For IMA to measure the LSM policy and the LSM policy loading mechanism
it needs rules to do so, but we already talked about problems with defaulting
to such broad rules....
IMA also depends on the files being measured to be on an FS which implements
and supports i_version. Since the only FS with this support (ext4) doesn't
even use it by default it seems silly to have any IMA rules by default.
This should reduce the performance overhead of IMA to near 0 while still
letting users who choose to configure their machine as such to inclue the
ima_tcb kernel paramenter and get measurements during boot before they can
load a customized, reasonable policy in userspace.
The selinuxfs superblock magic is used inside the IMA code, but is being
defined in two places and could someday get out of sync. This patch moves the
declaration into magic.h so it is only done once.
The IMA default policy measures every single file opened by root. This is
terrible for most users. Consider a system (like mine) with virtual machine
images. When those images are touched (which happens at boot for me) those
images are measured. This is just way too much for the default case.
An audit subsystem change replaced AUDIT_EQUAL with Audit_equal.
Update calls to security_filter_rule_init()/match() to reflect
the change.
Based on discussions on linux-audit, as per Steve Grubb's request
http://lkml.org/lkml/2009/2/6/269, the following changes were made:
- forced audit result to be either 0 or 1.
- made template names const
- Added new stand-alone message type: AUDIT_INTEGRITY_RULE
Acked-by: Steve Grubb <sgrubb@redhat.com>
Fix ima_delete_rules() definition so sparse doesn't complain.
Support for a user loadable policy through securityfs
with support for LSM specific policy data.
- free invalid rule in ima_parse_add_rule()
Acked-by: Serge Hallyn <serue@us.ibm.com>
IMA provides hardware (TPM) based measurement and attestation for
file measurements. As the Trusted Computing (TPM) model requires,
IMA measures all files before they are accessed in any way (on the
integrity_bprm_check, integrity_path_check and integrity_file_mmap
hooks), and commits the measurements to the TPM. Once added to the
TPM, measurements can not be removed.
In addition, IMA maintains a list of these file measurements, which
can be used to validate the aggregate value stored in the TPM. The
TPM can sign these measurements, and thus the system can prove, to
itself and to a third party, the system's integrity in a way that
cannot be circumvented by malicious or compromised software.
- alloc ima_template_entry before calling ima_store_template()
- log ima_add_boot_aggregate() failure
- removed unused IMA_TEMPLATE_NAME_LEN
- replaced hard coded string length with #define name
