path: root/security/integrity
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this update, Smack learns to love IPv6 and to mount a filesystem with a transmutable hierarchy (i.e. security labels are inherited from parent directory upon creation rather than creating process). The rest of the changes are maintenance" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (37 commits) tpm/tpm_i2c_infineon: Remove unused header file tpm: tpm_i2c_infinion: Don't modify i2c_client->driver evm: audit integrity metadata failures integrity: move integrity_audit_msg() evm: calculate HMAC after initializing posix acl on tmpfs maintainers: add Dmitry Kasatkin Smack: Fix the bug smackcipso can't set CIPSO correctly Smack: Fix possible NULL pointer dereference at smk_netlbl_mls() Smack: Add smkfstransmute mount option Smack: Improve access check performance Smack: Local IPv6 port based controls tpm: fix regression caused by section type conflict of tpm_dev_release() in ppc builds maintainers: Remove Kent from maintainers tpm: move TPM_DIGEST_SIZE defintion tpm_tis: missing platform_driver_unregister() on error in init_tis() security: clarify cap_inode_getsecctx description apparmor: no need to delay vfree() apparmor: fix fully qualified name parsing apparmor: fix setprocattr arg processing for onexec apparmor: localize getting the security context to a few macros ...
2013-06-29Replace a bunch of file->dentry->d_inode refs with file_inode()David Howells
Replace a bunch of file->dentry->d_inode refs with file_inode(). In __fput(), use file->f_inode instead so as not to be affected by any tricks that file_inode() might grow. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-20evm: audit integrity metadata failuresMimi Zohar
Before modifying an EVM protected extended attribute or any other metadata included in the HMAC calculation, the existing 'security.evm' is verified. This patch adds calls to integrity_audit_msg() to audit integrity metadata failures. Reported-by: Sven Vermeulen <sven.vermeulen@siphos.be> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-06-20integrity: move integrity_audit_msg()Mimi Zohar
This patch moves the integrity_audit_msg() function and defintion to security/integrity/, the parent directory, renames the 'ima_audit' boot command line option to 'integrity_audit', and fixes the Kconfig help text to reflect the actual code. Changelog: - Fixed ifdef inclusion of integrity_audit_msg() (Fengguang Wu) Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-04-17ima: eliminate passing d_name.name to process_measurement()Mimi Zohar
Passing a pointer to the dentry name, as a parameter to process_measurement(), causes a race condition with rename() and is unnecessary, as the dentry name is already accessible via the file parameter. In the normal case, we use the full pathname as provided by brpm->filename, bprm->interp, or ima_d_path(). Only on ima_d_path() failure, do we fallback to using the d_name.name, which points either to external memory or d_iname. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26block: fix part_pack_uuid() build errorMimi Zohar
Commit "85865c1 ima: add policy support for file system uuid" introduced a CONFIG_BLOCK dependency. This patch defines a wrapper called blk_part_pack_uuid(), which returns -EINVAL, when CONFIG_BLOCK is not defined. security/integrity/ima/ima_policy.c:538:4: error: implicit declaration of function 'part_pack_uuid' [-Werror=implicit-function-declaration] Changelog v2: - Reference commit number in patch description Changelog v1: - rename ima_part_pack_uuid() to blk_part_pack_uuid() - resolve scripts/checkpatch.pl warnings Changelog v0: - fix UUID scripts/Lindent msgs Reported-by: Randy Dunlap <rdunlap@infradead.org> Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-02-26ima: "remove enforce checking duplication" merge fixMimi Zohar
Commit "750943a ima: remove enforce checking duplication" combined the 'in IMA policy' and 'enforcing file integrity' checks. For the non-file, kernel module verification, a specific check for 'enforcing file integrity' was not added. This patch adds the check. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "This is basically a maintenance update for the TPM driver and EVM/IMA" Fix up conflicts in lib/digsig.c and security/integrity/ima/ima_main.c * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (45 commits) tpm/ibmvtpm: build only when IBM pseries is configured ima: digital signature verification using asymmetric keys ima: rename hash calculation functions ima: use new crypto_shash API instead of old crypto_hash ima: add policy support for file system uuid evm: add file system uuid to EVM hmac tpm_tis: check pnp_acpi_device return code char/tpm/tpm_i2c_stm_st33: drop temporary variable for return value char/tpm/tpm_i2c_stm_st33: remove dead assignment in tpm_st33_i2c_probe char/tpm/tpm_i2c_stm_st33: Remove __devexit attribute char/tpm/tpm_i2c_stm_st33: Don't use memcpy for one byte assignment tpm_i2c_stm_st33: removed unused variables/code TPM: Wait for TPM_ACCESS tpmRegValidSts to go high at startup tpm: Fix cancellation of TPM commands (interrupt mode) tpm: Fix cancellation of TPM commands (polling mode) tpm: Store TPM vendor ID TPM: Work around buggy TPMs that block during continue self test tpm_i2c_stm_st33: fix oops when i2c client is unavailable char/tpm: Use struct dev_pm_ops for power management TPM: STMicroelectronics ST33 I2C BUILD STUFF ...
2013-02-06ima: digital signature verification using asymmetric keysDmitry Kasatkin
Asymmetric keys were introduced in linux-3.7 to verify the signature on signed kernel modules. The asymmetric keys infrastructure abstracts the signature verification from the crypto details. This patch adds IMA/EVM signature verification using asymmetric keys. Support for additional signature verification methods can now be delegated to the asymmetric key infrastructure. Although the module signature header and the IMA/EVM signature header could use the same format, to minimize the signature length and save space in the extended attribute, this patch defines a new IMA/EVM header format. The main difference is that the key identifier is a sha1[12 - 19] hash of the key modulus and exponent, similar to the current implementation. The only purpose of the key identifier is to identify the corresponding key in the kernel keyring. ima-evm-utils was updated to support the new signature format. While asymmetric signature verification functionality supports many different hash algorithms, the hash used in this patch is calculated during the IMA collection phase, based on the configured algorithm. The default algorithm is sha1, but for backwards compatibility md5 is supported. Due to this current limitation, signatures should be generated using a sha1 hash algorithm. Changes in this patch: - Functionality has been moved to separate source file in order to get rid of in source #ifdefs. - keyid is derived according to the RFC 3280. It does not require to assign IMA/EVM specific "description" when loading X509 certificate. Kernel asymmetric key subsystem automatically generate the description. Also loading a certificate does not require using of ima-evm-utils and can be done using keyctl only. - keyid size is reduced to 32 bits to save xattr space. Key search is done using partial match functionality of asymmetric_key_match(). - Kconfig option title was changed Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: rename hash calculation functionsDmitry Kasatkin
Rename hash calculation functions to reflect meaning and change argument order in conventional way. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: use new crypto_shash API instead of old crypto_hashDmitry Kasatkin
Old crypto hash API internally uses shash API. Using shash API directly is more efficient. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06ima: add policy support for file system uuidDmitry Kasatkin
The IMA policy permits specifying rules to enable or disable measurement/appraisal/audit based on the file system magic number. If, for example, the policy contains an ext4 measurement rule, the rule is enabled for all ext4 partitions. Sometimes it might be necessary to enable measurement/appraisal/audit only for one partition and disable it for another partition of the same type. With the existing IMA policy syntax, this can not be done. This patch provides support for IMA policy rules to specify the file system by its UUID (eg. fsuuid=397449cd-687d-4145-8698-7fed4a3e0363). For partitions not being appraised, it might be a good idea to mount file systems with the 'noexec' option to prevent executing non-verified binaries. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-02-06evm: add file system uuid to EVM hmacDmitry Kasatkin
EVM uses the same key for all file systems to calculate the HMAC, making it possible to paste inodes from one file system on to another one, without EVM being able to detect it. To prevent such an attack, it is necessary to make the EVM HMAC file system specific. This patch uses the file system UUID, a file system unique identifier, to bind the EVM HMAC to the file system. The value inode->i_sb->s_uuid is used for the HMAC hash calculation, instead of using it for deriving the file system specific key. Initializing the key for every inode HMAC calculation is a bit more expensive operation than adding the uuid to the HMAC hash. Changing the HMAC calculation method or adding additional info to the calculation, requires existing EVM labeled file systems to be relabeled. This patch adds a Kconfig HMAC version option for backwards compatability. Changelog v1: - squash "hmac version setting" Changelog v0: - add missing Kconfig depends (Mimi) Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-22ima: differentiate appraise status only for hook specific rulesMimi Zohar
Different hooks can require different methods for appraising a file's integrity. As a result, an integrity appraisal status is cached on a per hook basis. Only a hook specific rule, requires the inode to be re-appraised. This patch eliminates unnecessary appraisals. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2013-01-22ima: per hook cache integrity appraisal statusMimi Zohar
With the new IMA policy 'appraise_type=' option, different hooks can require different methods for appraising a file's integrity. For example, the existing 'ima_appraise_tcb' policy defines a generic rule, requiring all root files to be appraised, without specfying the appraisal method. A more specific rule could require all kernel modules, for example, to be signed. appraise fowner=0 func=MODULE_CHECK appraise_type=imasig appraise fowner=0 As a result, the integrity appraisal results for the same inode, but for different hooks, could differ. This patch caches the integrity appraisal results on a per hook basis. Changelog v2: - Rename ima_cache_status() to ima_set_cache_status() - Rename and move get_appraise_status() to ima_get_cache_status() Changelog v0: - include IMA_APPRAISE/APPRAISED_SUBMASK in IMA_DO/DONE_MASK (Dmitry) - Support independent MODULE_CHECK appraise status. - fixed IMA_XXXX_APPRAISE/APPRAISED flags Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2013-01-22ima: increase iint flag sizeMimi Zohar
In preparation for hook specific appraise status results, increase the iint flags size. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2013-01-22ima: added policy support for 'security.ima' typeDmitry Kasatkin
The 'security.ima' extended attribute may contain either the file data's hash or a digital signature. This patch adds support for requiring a specific extended attribute type. It extends the IMA policy with a new keyword 'appraise_type=imasig'. (Default is hash.) Changelog v2: - Fixed Documentation/ABI/testing/ima_policy option syntax Changelog v1: - Differentiate between 'required' vs. 'actual' extended attribute Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-22evm: checking if removexattr is not a NULLDmitry Kasatkin
The following lines of code produce a kernel oops. fd = socket(PF_FILE, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0); fchmod(fd, 0666); [ 139.922364] BUG: unable to handle kernel NULL pointer dereference at (null) [ 139.924982] IP: [< (null)>] (null) [ 139.924982] *pde = 00000000 [ 139.924982] Oops: 0000 [#5] SMP [ 139.924982] Modules linked in: fuse dm_crypt dm_mod i2c_piix4 serio_raw evdev binfmt_misc button [ 139.924982] Pid: 3070, comm: acpid Tainted: G D 3.8.0-rc2-kds+ #465 Bochs Bochs [ 139.924982] EIP: 0060:[<00000000>] EFLAGS: 00010246 CPU: 0 [ 139.924982] EIP is at 0x0 [ 139.924982] EAX: cf5ef000 EBX: cf5ef000 ECX: c143d600 EDX: c15225f2 [ 139.924982] ESI: cf4d2a1c EDI: cf4d2a1c EBP: cc02df10 ESP: cc02dee4 [ 139.924982] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 139.924982] CR0: 80050033 CR2: 00000000 CR3: 0c059000 CR4: 000006d0 [ 139.924982] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 139.924982] DR6: ffff0ff0 DR7: 00000400 [ 139.924982] Process acpid (pid: 3070, ti=cc02c000 task=d7705340 task.ti=cc02c000) [ 139.924982] Stack: [ 139.924982] c1203c88 00000000 cc02def4 cf4d2a1c ae21eefa 471b60d5 1083c1ba c26a5940 [ 139.924982] e891fb5e 00000041 00000004 cc02df1c c1203964 00000000 cc02df4c c10e20c3 [ 139.924982] 00000002 00000000 00000000 22222222 c1ff2222 cf5ef000 00000000 d76efb08 [ 139.924982] Call Trace: [ 139.924982] [<c1203c88>] ? evm_update_evmxattr+0x5b/0x62 [ 139.924982] [<c1203964>] evm_inode_post_setattr+0x22/0x26 [ 139.924982] [<c10e20c3>] notify_change+0x25f/0x281 [ 139.924982] [<c10cbf56>] chmod_common+0x59/0x76 [ 139.924982] [<c10e27a1>] ? put_unused_fd+0x33/0x33 [ 139.924982] [<c10cca09>] sys_fchmod+0x39/0x5c [ 139.924982] [<c13f4f30>] syscall_call+0x7/0xb [ 139.924982] Code: Bad EIP value. This happens because sockets do not define the removexattr operation. Before removing the xattr, verify the removexattr function pointer is not NULL. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-01-16ima: forbid write access to files with digital signaturesDmitry Kasatkin
This patch forbids write access to files with digital signatures, as they are considered immutable. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16ima: move full pathname resolution to separate functionDmitry Kasatkin
Define a new function ima_d_path(), which returns the full pathname. This function will be used further, for example, by the directory verification code. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16integrity: reduce storage size for ima_status and evm_statusDmitry Kasatkin
This patch reduces size of the iint structure by 8 bytes. It saves about 15% of iint cache memory. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16ima: rename FILE_MMAP to MMAP_CHECKMimi Zohar
Rename FILE_MMAP hook to MMAP_CHECK to be consistent with the other hook names. Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2013-01-16ima: remove security.ima hexdumpDmitry Kasatkin
Hexdump is not really helping. Audit messages prints error messages. Remove it. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16ima: remove enforce checking duplicationDmitry Kasatkin
Based on the IMA appraisal policy, files are appraised. For those files appraised, the IMA hooks return the integrity appraisal result, assuming IMA-appraisal is in enforcing mode. This patch combines both of these criteria (in policy and enforcing file integrity), removing the checking duplication. Changelog v1: - Update hook comments Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16ima: set appraise status in fix mode only when xattr is fixedDmitry Kasatkin
When a file system is mounted read-only, setting the xattr value in fix mode fails with an error code -EROFS. The xattr should be fixed after the file system is remounted read-write. This patch verifies that the set xattr succeeds, before setting the appraise status value to INTEGRITY_PASS. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16evm: remove unused cleanup functionsDmitry Kasatkin
EVM cannot be built as a kernel module. Remove the unncessary __exit functions. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-01-16ima: re-initialize IMA policy LSM infoMimi Zohar
Although the IMA policy does not change, the LSM policy can be reloaded, leaving the IMA LSM based rules referring to the old, stale LSM policy. This patch updates the IMA LSM based rules to reflect the reloaded LSM policy. Reported-by: Sven Vermeulen <sven.vermeulen@siphos.be> tested-by: Sven Vermeulen <sven.vermeulen@siphos.be> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: Eric Paris <eparis@parisplace.org> Cc: Casey Schaufler <casey@schaufler-ca.com>
2012-12-24ima: fallback to MODULE_SIG_ENFORCE for existing kernel module syscallMimi Zohar
The new kernel module syscall appraises kernel modules based on policy. If the IMA policy requires kernel module checking, fallback to module signature enforcing for the existing syscall. Without CONFIG_MODULE_SIG_FORCE enabled, the kernel module's integrity is unknown, return -EACCES. Changelog v1: - Fix ima_module_check() return result (Tetsuo Handa) Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-12-14ima: support new kernel module syscallMimi Zohar
With the addition of the new kernel module syscall, which defines two arguments - a file descriptor to the kernel module and a pointer to a NULL terminated string of module arguments - it is now possible to measure and appraise kernel modules like any other file on the file system. This patch adds support to measure and appraise kernel modules in an extensible and consistent manner. To support filesystems without extended attribute support, additional patches could pass the signature as the first parameter. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-05ima: fix bug in argument orderDmitry Kasatkin
mask argument goes first, then func, like ima_must_measure and ima_get_action. ima_inode_post_setattr() assumes that. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
2012-09-21userns: Add user namespace support to IMAEric W. Biederman
Use kuid's in the IMA rules. When reporting the current uid in audit logs use from_kuid to get a usable value. Cc: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert EVM to deal with kuids and kgids in it's hmac computationEric W. Biederman
2012-09-19ima: change flags container data typeDmitry Kasatkin
IMA audit hashes patches introduced new IMA flags and required space went beyond 8 bits. Currently the only flag is IMA_DIGSIG. This patch use 16 bit short instead of 8 bit char. Without this fix IMA signature will be replaced with hash, which should not happen. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-13ima: audit log hashesPeter Moody
This adds an 'audit' policy action which audit logs file measurements. Changelog v6: - use new action flag handling (Dmitry Kasatkin). - removed whitespace (Mimi) Changelog v5: - use audit_log_untrustedstring. Changelog v4: - cleanup digest -> hash conversion. - use filename rather than d_path in ima_audit_measurement. Changelog v3: - Use newly exported audit_log_task_info for logging pid/ppid/uid/etc. - Update the ima_policy ABI documentation. Changelog v2: - Use 'audit' action rather than 'measure_and_audit' to permit auditing in the absence of measuring.. Changelog v1: - Initial posting. Signed-off-by: Peter Moody <pmoody@google.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-13ima: generic IMA action flag handlingDmitry Kasatkin
Make the IMA action flag handling generic in order to support additional new actions, without requiring changes to the base implementation. New actions, like audit logging, will only need to modify the define statements. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-12ima: rename ima_must_appraise_or_measureDmitry Kasatkin
When AUDIT action support is added to the IMA, ima_must_appraise_or_measure() does not reflect the real meaning anymore. Rename it to ima_get_action(). Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-07ima: digital signature verification supportDmitry Kasatkin
This patch adds support for digital signature based integrity appraisal. With this patch, 'security.ima' contains either the file data hash or a digital signature of the file data hash. The file data hash provides the security attribute of file integrity. In addition to file integrity, a digital signature provides the security attribute of authenticity. Unlike EVM, when the file metadata changes, the digital signature is replaced with an HMAC, modification of the file data does not cause the 'security.ima' digital signature to be replaced with a hash. As a result, after any modification, subsequent file integrity appraisals would fail. Although digitally signed files can be modified, but by not updating 'security.ima' to reflect these modifications, in essence digitally signed files could be considered 'immutable'. IMA uses a different keyring than EVM. While the EVM keyring should not be updated after initialization and locked, the IMA keyring should allow updating or adding new keys when upgrading or installing packages. Changelog v4: - Change IMA_DIGSIG to hex equivalent Changelog v3: - Permit files without any 'security.ima' xattr to be labeled properly. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-07ima: add support for different security.ima data typesMimi Zohar
IMA-appraisal currently verifies the integrity of a file based on a known 'good' measurement value. This patch reserves the first byte of 'security.ima' as a place holder for the type of method used for verifying file data integrity. Changelog v1: - Use the newly defined 'struct evm_ima_xattr_data' Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-07ima: add ima_inode_setxattr/removexattr function and callsMimi Zohar
Based on xattr_permission comments, the restriction to modify 'security' xattr is left up to the underlying fs or lsm. Ensure that not just anyone can modify or remove 'security.ima'. Changelog v1: - Unless IMA-APPRAISE is configured, use stub ima_inode_removexattr()/setxattr() functions. (Moved ima_inode_removexattr()/setxattr() to ima_appraise.c) Changelog: - take i_mutex to fix locking (Dmitry Kasatkin) - ima_reset_appraise_flags should only be called when modifying or removing the 'security.ima' xattr. Requires CAP_SYS_ADMIN privilege. (Incorporated fix from Roberto Sassu) - Even if allowed to update security.ima, reset the appraisal flags, forcing re-appraisal. - Replace CAP_MAC_ADMIN with CAP_SYS_ADMIN - static inline ima_inode_setxattr()/ima_inode_removexattr() stubs - ima_protect_xattr should be static Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2012-09-07ima: replace iint spinblock with rwlock/read_lockDmitry Kasatkin
For performance, replace the iint spinlock with rwlock/read_lock. Eric Paris questioned this change, from spinlocks to rwlocks, saying "rwlocks have been shown to actually be slower on multi processor systems in a number of cases due to the cache line bouncing required." Based on performance measurements compiling the kernel on a cold boot with multiple jobs with/without this patch, Dmitry Kasatkin and I found that rwlocks performed better than spinlocks, but very insignificantly. For example with total compilation time around 6 minutes, with rwlocks time was 1 - 3 seconds shorter... but always like that. Changelog v2: - new patch taken from the 'allocating iint improvements' patch Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-09-07ima: allocating iint improvementsDmitry Kasatkin
With IMA-appraisal's removal of the iint mutex and taking the i_mutex instead, allocating the iint becomes a lot simplier, as we don't need to be concerned with two processes racing to allocate the iint. This patch cleans up and improves performance for allocating the iint. - removed redundant double i_mutex locking - combined iint allocation with tree search Changelog v2: - removed the rwlock/read_lock changes from this patch Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-09-07ima: add appraise action keywords and default rulesMimi Zohar
Unlike the IMA measurement policy, the appraise policy can not be dependent on runtime process information, such as the task uid, as the 'security.ima' xattr is written on file close and must be updated each time the file changes, regardless of the current task uid. This patch extends the policy language with 'fowner', defines an appraise policy, which appraises all files owned by root, and defines 'ima_appraise_tcb', a new boot command line option, to enable the appraise policy. Changelog v3: - separate the measure from the appraise rules in order to support measuring without appraising and appraising without measuring. - change appraisal default for filesystems without xattr support to fail - update default appraise policy for cgroups Changelog v1: - don't appraise RAMFS (Dmitry Kasatkin) - merged rest of "ima: ima_must_appraise_or_measure API change" commit (Dmtiry Kasatkin) ima_must_appraise_or_measure() called ima_match_policy twice, which searched the policy for a matching rule. Once for a matching measurement rule and subsequently for an appraisal rule. Searching the policy twice is unnecessary overhead, which could be noticeable with a large policy. The new version of ima_must_appraise_or_measure() does everything in a single iteration using a new version of ima_match_policy(). It returns IMA_MEASURE, IMA_APPRAISE mask. With the use of action mask only one efficient matching function is enough. Removed other specific versions of matching functions. Changelog: - change 'owner' to 'fowner' to conform to the new LSM conditions posted by Roberto Sassu. - fix calls to ima_log_string() Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2012-09-07ima: integrity appraisal extensionMimi Zohar
IMA currently maintains an integrity measurement list used to assert the integrity of the running system to a third party. The IMA-appraisal extension adds local integrity validation and enforcement of the measurement against a "good" value stored as an extended attribute 'security.ima'. The initial methods for validating 'security.ima' are hashed based, which provides file data integrity, and digital signature based, which in addition to providing file data integrity, provides authenticity. This patch creates and maintains the 'security.ima' xattr, containing the file data hash measurement. Protection of the xattr is provided by EVM, if enabled and configured. Based on policy, IMA calls evm_verifyxattr() to verify a file's metadata integrity and, assuming success, compares the file's current hash value with the one stored as an extended attribute in 'security.ima'. Changelov v4: - changed iint cache flags to hex values Changelog v3: - change appraisal default for filesystems without xattr support to fail Changelog v2: - fix audit msg 'res' value - removed unused 'ima_appraise=' values Changelog v1: - removed unused iint mutex (Dmitry Kasatkin) - setattr hook must not reset appraised (Dmitry Kasatkin) - evm_verifyxattr() now differentiates between no 'security.evm' xattr (INTEGRITY_NOLABEL) and no EVM 'protected' xattrs included in the 'security.evm' (INTEGRITY_NOXATTRS). - replace hash_status with ima_status (Dmitry Kasatkin) - re-initialize slab element ima_status on free (Dmitry Kasatkin) - include 'security.ima' in EVM if CONFIG_IMA_APPRAISE, not CONFIG_IMA - merged half "ima: ima_must_appraise_or_measure API change" (Dmitry Kasatkin) - removed unnecessary error variable in process_measurement() (Dmitry Kasatkin) - use ima_inode_post_setattr() stub function, if IMA_APPRAISE not configured (moved ima_inode_post_setattr() to ima_appraise.c) - make sure ima_collect_measurement() can read file Changelog: - add 'iint' to evm_verifyxattr() call (Dimitry Kasatkin) - fix the race condition between chmod, which takes the i_mutex and then iint->mutex, and ima_file_free() and process_measurement(), which take the locks in the reverse order, by eliminating iint->mutex. (Dmitry Kasatkin) - cleanup of ima_appraise_measurement() (Dmitry Kasatkin) - changes as a result of the iint not allocated for all regular files, but only for those measured/appraised. - don't try to appraise new/empty files - expanded ima_appraisal description in ima/Kconfig - IMA appraise definitions required even if IMA_APPRAISE not enabled - add return value to ima_must_appraise() stub - unconditionally set status = INTEGRITY_PASS *after* testing status, not before. (Found by Joe Perches) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2012-08-22ima: enable the IBM vTPM as the default TPM in the PPC64 caseKent Yoder
Enable tpm_ibmvtpm driver by default when IMA is enabled on PPC64 Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-07-05ima: audit is compiled only when enabledDmitry Kasatkin
IMA auditing code was compiled even when CONFIG_AUDIT was not enabled. This patch compiles auditing code only when possible and enabled. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-07-05ima: ima_initialized is set only if successfulDmitry Kasatkin
Set ima_initialized only if initialization was successful. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
