path: root/security/integrity
2012-01-18ima: fix invalid memory referenceRoberto Sassu
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream. Don't free a valid measurement entry on TPM PCR extend failure. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-18ima: free duplicate measurement memoryRoberto Sassu
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream. Info about new measurements are cached in the iint for performance. When the inode is flushed from cache, the associated iint is flushed as well. Subsequent access to the inode will cause the inode to be re-measured and will attempt to add a duplicate entry to the measurement list. This patch frees the duplicate measurement memory, fixing a memory leak. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-26ima: fmode_t misspelled as mode_t...Al Viro
2011-02-23ima: remove unnecessary call to ima_must_measureMimi Zohar
The original ima_must_measure() function based its results on cached iint information, which required an iint be allocated for all files. Currently, an iint is allocated only for files in policy. As a result, for those files in policy, ima_must_measure() is now called twice: once to determine if the inode is in the measurement policy and, the second time, to determine if it needs to be measured/re-measured. The second call to ima_must_measure() unnecessarily checks to see if the file is in policy. As we already know the file is in policy, this patch removes the second unnecessary call to ima_must_measure(), removes the vestige iint parameter, and just checks the iint directly to determine if the inode has been measured or needs to be measured/re-measured. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-10IMA: remove IMA imbalance checkingMimi Zohar
Now that i_readcount is maintained by the VFS layer, remove the imbalance checking in IMA. Cleans up the IMA code nicely. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-10IMA: maintain i_readcount in the VFS layerMimi Zohar
ima_counts_get() updated the readcount and invalidated the PCR, as necessary. Only update the i_readcount in the VFS layer. Move the PCR invalidation checks to ima_file_check(), where it belongs. Maintaining the i_readcount in the VFS layer, will allow other subsystems to use i_readcount. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-02-10IMA: convert i_readcount to atomicMimi Zohar
Convert the inode's i_readcount from an unsigned int to atomic. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Eric Paris <eparis@redhat.com>
2011-01-03ima: fix add LSM rule bugMimi Zohar
If security_filter_rule_init() doesn't return a rule, then not everything is as fine as the return code implies. This bug only occurs when the LSM (eg. SELinux) is disabled at runtime. Adding an empty LSM rule causes ima_match_rules() to always succeed, ignoring any remaining rules. default IMA TCB policy: # PROC_SUPER_MAGIC dont_measure fsmagic=0x9fa0 # SYSFS_MAGIC dont_measure fsmagic=0x62656572 # DEBUGFS_MAGIC dont_measure fsmagic=0x64626720 # TMPFS_MAGIC dont_measure fsmagic=0x01021994 # SECURITYFS_MAGIC dont_measure fsmagic=0x73636673 < LSM specific rule > dont_measure obj_type=var_log_t measure func=BPRM_CHECK measure func=FILE_MMAP mask=MAY_EXEC measure func=FILE_CHECK mask=MAY_READ uid=0 Thus without the patch, with the boot parameters 'tcb selinux=0', adding the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB measurement policy, would result in nothing being measured. The patch prevents the default TCB policy from being replaced. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: David Safford <safford@watson.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: fix the ToMToU logicEric Paris
Current logic looks like this: rc = ima_must_measure(NULL, inode, MAY_READ, FILE_CHECK); if (rc < 0) goto out; if (mode & FMODE_WRITE) { if (inode->i_readcount) send_tomtou = true; goto out; } if (atomic_read(&inode->i_writecount) > 0) send_writers = true; Lets assume we have a policy which states that all files opened for read by root must be measured. Lets assume the file has permissions 777. Lets assume that root has the given file open for read. Lets assume that a non-root process opens the file write. The non-root process will get to ima_counts_get() and will check the ima_must_measure(). Since it is not supposed to measure it will goto out. We should check the i_readcount no matter what since we might be causing a ToMToU voilation! This is close to correct, but still not quite perfect. The situation could have been that root, which was interested in the mesurement opened and closed the file and another process which is not interested in the measurement is the one holding the i_readcount ATM. This is just overly strict on ToMToU violations, which is better than not strict enough... Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: explicit IMA i_flag to remove global lock on inode_deleteEric Paris
Currently for every removed inode IMA must take a global lock and search the IMA rbtree looking for an associated integrity structure. Instead we explicitly mark an inode when we add an integrity structure so we only have to take the global lock and do the removal if it exists. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: drop refcnt from ima_iint_cache since it isn't neededEric Paris
Since finding a struct ima_iint_cache requires a valid struct inode, and the struct ima_iint_cache is supposed to have the same lifetime as a struct inode (technically they die together but don't need to be created at the same time) we don't have to worry about the ima_iint_cache outliving or dieing before the inode. So the refcnt isn't useful. Just get rid of it and free the structure when the inode is freed. Signed-off-by: Eric Paris <eapris@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: only allocate iint when neededEric Paris
IMA always allocates an integrity structure to hold information about every inode, but only needed this structure to track the number of readers and writers currently accessing a given inode. Since that information was moved into struct inode instead of the integrity struct this patch stops allocating the integrity stucture until it is needed. Thus greatly reducing memory usage. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: move read counter into struct inodeEric Paris
IMA currently allocated an inode integrity structure for every inode in core. This stucture is about 120 bytes long. Most files however (especially on a system which doesn't make use of IMA) will never need any of this space. The problem is that if IMA is enabled we need to know information about the number of readers and the number of writers for every inode on the box. At the moment we collect that information in the per inode iint structure and waste the rest of the space. This patch moves those counters into the struct inode so we can eventually stop allocating an IMA integrity structure except when absolutely needed. This patch does the minimum needed to move the location of the data. Further cleanups, especially the location of counter updates, may still be possible. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: use i_writecount rather than a private counterEric Paris
IMA tracks the number of struct files which are holding a given inode readonly and the number which are holding the inode write or r/w. It needs this information so when a new reader or writer comes in it can tell if this new file will be able to invalidate results it already made about existing files. aka if a task is holding a struct file open RO, IMA measured the file and recorded those measurements and then a task opens the file RW IMA needs to note in the logs that the old measurement may not be correct. It's called a "Time of Measure Time of Use" (ToMToU) issue. The same is true is a RO file is opened to an inode which has an open writer. We cannot, with any validity, measure the file in question since it could be changing. This patch attempts to use the i_writecount field to track writers. The i_writecount field actually embeds more information in it's value than IMA needs but it should work for our purposes and allow us to shrink the struct inode even more. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: use inode->i_lock to protect read and write countersEric Paris
Currently IMA used the iint->mutex to protect the i_readcount and i_writecount. This patch uses the inode->i_lock since we are going to start using in inode objects and that is the most appropriate lock. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: convert internal flags from long to charEric Paris
The IMA flags is an unsigned long but there is only 1 flag defined. Lets save a little space and make it a char. This packs nicely next to the array of u8's. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: use unsigned int instead of long for countersEric Paris
Currently IMA uses 2 longs in struct inode. To save space (and as it seems impossible to overflow 32 bits) we switch these to unsigned int. The switch to unsigned does require slightly different checks for underflow, but it isn't complex. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: drop the inode opencount since it isn't needed for operationEric Paris
The opencount was used to help debugging to make sure that everything which created a struct file also correctly made the IMA calls. Since we moved all of that into the VFS this isn't as necessary. We should be able to get the same amount of debugging out of just the reader and write count. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26IMA: use rbtree instead of radix tree for inode information cacheEric Paris
The IMA code needs to store the number of tasks which have an open fd granting permission to write a file even when IMA is not in use. It needs this information in order to be enabled at a later point in time without losing it's integrity garantees. At the moment that means we store a little bit of data about every inode in a cache. We use a radix tree key'd on the inode's memory address. Dave Chinner pointed out that a radix tree is a terrible data structure for such a sparse key space. This patch switches to using an rbtree which should be more efficient. Bug report from Dave: "I just noticed that slabtop was reporting an awfully high usage of radix tree nodes: OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME 4200331 2778082 66% 0.55K 144839 29 2317424K radix_tree_node 2321500 2060290 88% 1.00K 72581 32 2322592K xfs_inode 2235648 2069791 92% 0.12K 69864 32 279456K iint_cache That is, 2.7M radix tree nodes are allocated, and the cache itself is consuming 2.3GB of RAM. I know that the XFS inodei caches are indexed by radix tree node, but for 2 million cached inodes that would mean a density of 1 inode per radix tree node, which for a system with 16M inodes in the filsystems is an impossibly low density. The worst I've seen in a production system like kernel.org is about 20-25% density, which would mean about 150-200k radix tree nodes for that many inodes. So it's not the inode cache. So I looked up what the iint_cache was. It appears to used for storing per-inode IMA information, and uses a radix tree for indexing. It uses the *address* of the struct inode as the indexing key. That means the key space is extremely sparse - for XFS the struct inode addresses are approximately 1000 bytes apart, which means the closest the radix tree index keys get is ~1000. Which means that there is a single entry per radix tree leaf node, so the radix tree is using roughly 550 bytes for every 120byte structure being cached. For the above example, it's probably wasting close to 1GB of RAM...." Reported-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-08ima: always maintain countersMimi Zohar
commit 8262bb85da allocated the inode integrity struct (iint) before any inodes were created. Only after IMA was initialized in late_initcall were the counters updated. This patch updates the counters, whether or not IMA has been initialized, to resolve 'imbalance' messages. This patch fixes the bug as reported in bugzilla: 15673. When the i915 is builtin, the ring_buffer is initialized before IMA, causing the imbalance message on suspend. Reported-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Tested-by: Thomas Meyer <thomas@m3y3r.de> Tested-by: David Safford<safford@watson.ibm.com> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02ima: use generic_file_llseek for securityfsArnd Bergmann
The default for llseek will change to no_llseek, so securityfs users need to add explicit .llseek assignments. Since we're dealing with regular files from a VFS perspective, use generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-21kref: remove kref_setNeilBrown
Of the three uses of kref_set in the kernel: One really should be kref_put as the code is letting go of a reference, Two really should be kref_init because the kref is being initialised. This suggests that making kref_set available encourages bad code. So fix the three uses and remove kref_set completely. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-17ima: remove ACPI dependencyMimi Zohar
The ACPI dependency moved to the TPM, where it belongs. Although IMA per-se does not require access to the bios measurement log, verifying the IMA boot aggregate does, which requires ACPI. This patch prereq's 'TPM: ACPI/PNP dependency removal' http://lkml.org/lkml/2010/5/4/378. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Reported-by: Jean-Christophe Dubois <jcd@tribudubois.net> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-07Revert "ima: remove ACPI dependency"James Morris
This reverts commit a674fa46c79ffa37995bd1c8e4daa2b3be5a95ae. Previous revert was a prereq. Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06Merge branch 'master' into nextJames Morris
2010-05-05ima: remove ACPI dependencyMimi Zohar
2010-04-23IMA: include the word IMA in printk messagesEric Paris
As an example IMA emits a warning when it can't find a TPM chip: "No TPM chip found, activating TPM-bypass!" This patch prefaces that message with IMA so we know what subsystem is bypassing the TPM. Do this for all pr_info and pr_err messages. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: drop the word integrity in the audit messageEric Paris
integrity_audit_msg() uses "integrity:" in the audit message. This violates the (loosely defined) audit system requirements that everything be a key=value pair and it doesn't provide additional information. This can be obviously gleaned from the message type. Just drop it. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: use audit_log_untrusted_string rather than %sEric Paris
Convert all of the places IMA calls audit_log_format with %s into audit_log_untrusted_string(). This is going to cause them all to get quoted, but it should make audit log injection harder. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: handle comments in policyEric Paris
IMA policy load parser will reject any policies with a comment. This patch will allow the parser to just ignore lines which start with a #. This is not very robust. # can ONLY be used at the very beginning of a line. Inline comments are not allowed. Signed-off-by: Eric Paris Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: handle whitespace betterEric Paris
IMA parser will fail if whitespace is used in any way other than a single space. Using a tab or even using 2 spaces in a row will result in a policy being rejected. This patch makes the kernel ignore whitespace a bit better. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: reject policies with unknown entriesEric Paris
Currently the ima policy load code will print what it doesn't understand but really I think it should reject any policy it doesn't understand. This patch makes it so! Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: set entry->action to UNKNOWN rather than hard codingEric Paris
ima_parse_rule currently sets entry->action = -1 and then later tests if (entry->action == UNKNOWN). It is true that UNKNOWN == -1 but actually setting it to UNKNOWN makes a lot more sense in case things change in the future. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21IMA: do not allow the same rule to specify the same thing twiceEric Paris
IMA will accept rules which specify things twice and will only pay attention to the last one. We should reject such rules. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-04-21ima: handle multiple rules per writeEric Paris
Currently IMA will only accept one rule per write(). This patch allows IMA to accept writes which contain multiple rules but only processes one rule per write. \n is used as the delimiter between rules. IMA will return a short write indicating that it only accepted up to the first \n. This allows simple userspace utilities like cat to be used to load an IMA policy instead of needing a special userspace utility that understood 'one write per rule' Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-10security/ima: replace gcc specific __FUNCTION__ with __func__H Hartley Sweeten
As noted by checkpatch.pl, __func__ should be used instead of gcc specific __FUNCTION__. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-25security: fix error return path in ima_inode_allocXiaotian Feng
If radix_tree_preload is failed in ima_inode_alloc, we don't need radix_tree_preload_end because kernel is alread preempt enabled Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-07ima: rename PATH_CHECK to FILE_CHECKMimi Zohar
With the movement of the ima hooks functions were renamed from *path* to *file* since they always deal with struct file. This patch renames some of the ima internal flags to make them consistent with the rest of the code. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07ima: rename ima_path_check to ima_file_checkMimi Zohar
ima_path_check actually deals with files! call it ima_file_check instead. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07ima: initialize ima before inodes can be allocatedEric Paris
ima wants to create an inode information struct (iint) when inodes are allocated. This means that at least the part of ima which does this allocation (the allocation is filled with information later) should before any inodes are created. To accomplish this we split the ima initialization routine placing the kmem cache allocator inside a security_initcall() function. Since this makes use of radix trees we also need to make sure that is initialized before security_initcall(). Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-02-07fix ima breakageMimi Zohar
The "Untangling ima mess, part 2 with counters" patch messed up the counters. Based on conversations with Al Viro, this patch streamlines ima_path_check() by removing the counter maintaince. The counters are now updated independently, from measuring the file, in __dentry_open() and alloc_file() by calling ima_counts_get(). ima_path_check() is called from nfsd and do_filp_open(). It also did not measure all files that should have been measured. Reason: ima_path_check() got bogus value passed as mask. [AV: mea culpa] [AV: add missing nfsd bits] Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ima: limit imbalance msgMimi Zohar
Limit the number of imbalance messages to once per filesystem type instead of once per system boot. (it's actually slightly racy and could give you a couple per fs, but this isn't a real issue) Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16Untangling ima mess, part 3: kill dead code in imaAl Viro
Kill the 'update' argument of ima_path_check(), kill dead code in ima. Current rules: ima counters are bumped at the same time when the file switches from put_filp() fodder to fput() one. Which happens exactly in two places - alloc_file() and __dentry_open(). Nothing else needs to do that at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ima: call ima_inode_free ima_inode_freeEric Paris
ima_inode_free() has some funky #define just to confuse the crap out of me. void ima_iint_delete(struct inode *inode) and then things actually call ima_inode_free() and nothing calls ima_iint_delete(). Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16IMA: clean up the IMA counts updating codeEric Paris
We currently have a lot of duplicated code around ima file counts. Clean that all up. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ima: only insert at inode creation timeEric Paris
iints are supposed to be allocated when an inode is allocated (during security_inode_alloc()) But we have code which will attempt to allocate an iint during measurement calls. If we couldn't allocate the iint and we cared, we should have died during security_inode_alloc(). Not make the code more complex and less efficient. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ima: valid return code from ima_inode_allocEric Paris
ima_inode_alloc returns 0 and 1, but the LSM hooks expects an errno. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-03Merge branch 'master' into nextJames Morris
2009-11-19ima: replace GFP_KERNEL with GFP_NOFSMimi Zohar
While running fsstress tests on the NFSv4 mounted ext3 and ext4 filesystem, the following call trace was generated on the nfs server machine. Replace GFP_KERNEL with GFP_NOFS in ima_iint_insert() to avoid a potential deadlock. ================================= [ INFO: inconsistent lock state ] 2.6.31-31.el6.x86_64 #1 --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd2/75 [HC0[0]:SC0[0]:HE1:SE1] takes: (jbd2_handle){+.+.?.}, at: [<ffffffff811edd5e>] jbd2_journal_start+0xfe/0x13f {RECLAIM_FS-ON-W} state was registered at: [<ffffffff81091e40>] mark_held_locks+0x65/0x99 [<ffffffff81091f31>] lockdep_trace_alloc+0xbd/0xf5 [<ffffffff81126fdd>] kmem_cache_alloc+0x40/0x185 [<ffffffff812344d7>] ima_iint_insert+0x3d/0xf1 [<ffffffff812345b0>] ima_inode_alloc+0x25/0x44 [<ffffffff811484ac>] inode_init_always+0xec/0x271 [<ffffffff81148682>] alloc_inode+0x51/0xa1 [<ffffffff81148700>] new_inode+0x2e/0x94 [<ffffffff811b2f08>] ext4_new_inode+0xb8/0xdc9 [<ffffffff811be611>] ext4_create+0xcf/0x175 [<ffffffff8113e2cd>] vfs_create+0x82/0xb8 [<ffffffff8113f337>] do_filp_open+0x32c/0x9ee [<ffffffff811309b9>] do_sys_open+0x6c/0x12c [<ffffffff81130adc>] sys_open+0x2e/0x44 [<ffffffff81011e42>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 90371 hardirqs last enabled at (90371): [<ffffffff8112708d>] kmem_cache_alloc+0xf0/0x185 hardirqs last disabled at (90370): [<ffffffff81127026>] kmem_cache_alloc+0x89/0x185 softirqs last enabled at (89492): [<ffffffff81068ecf>] __do_softirq+0x1bf/0x1eb softirqs last disabled at (89477): [<ffffffff8101312c>] call_softirq+0x1c/0x30 other info that might help us debug this: 2 locks held by kswapd2/75: #0: (shrinker_rwsem){++++..}, at: [<ffffffff810f98ba>] shrink_slab+0x44/0x177 #1: (&type->s_umount_key#25){++++..}, at: [<ffffffff811450ba>] Reported-by: Muni P. Beerakam <mbeeraka@in.ibm.com> Reported-by: Amit K. Arora <amitarora@in.ibm.com> Cc: stable@kernel.org Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
