commit a00ae4d21b2fa9379914f270ffffd8d3bec55430 upstream.
As of commit ee18d64c1f632043a02e6f5ba5e045bb26a5465f ("KEYS: Add a keyctl to
install a process's session keyring on its parent [try #6]"), CONFIG_KEYS=y
fails to build on architectures that haven't implemented TIF_NOTIFY_RESUME yet:
security/keys/keyctl.c: In function 'keyctl_session_to_parent':
security/keys/keyctl.c:1312: error: 'TIF_NOTIFY_RESUME' undeclared (first use in this function)
security/keys/keyctl.c:1312: error: (Each undeclared identifier is reported only once
security/keys/keyctl.c:1312: error: for each function it appears in.)
Make KEYCTL_SESSION_TO_PARENT depend on TIF_NOTIFY_RESUME until
m68k, and xtensa have implemented it.
Signed-off-by: James Morris <jmorris@namei.org>
The destination keyring specified to request_key() and co. is made available to
the process that instantiates the key (the slave process started by
/sbin/request-key typically). This is passed in the request_key_auth struct as
the dest_keyring member.
keyctl_instantiate_key and keyctl_negate_key() call get_instantiation_keyring()
to get the keyring to attach the newly constructed key to at the end of
instantiation. This may be given a specific keyring into which a link will be
made later, or it may be asked to find the keyring passed to request_key(). In
the former case, it returns a keyring with the refcount incremented by
lookup_user_key(); in the latter case, it returns the keyring from the
request_key_auth struct - and does _not_ increment the refcount.
The latter case will eventually result in an oops when the keyring prematurely
runs out of references and gets destroyed. The effect may take some time to
show up as the key is destroyed lazily.
To fix this, the keyring returned by get_instantiation_keyring() must always
have its refcount incremented, no matter where it comes from.
This can be tested by setting /etc/request-key.conf to:
#OP TYPE DESCRIPTION CALLOUT INFO PROGRAM ARG1 ARG2 ARG3 ...
create * test:* * |/bin/false %u %g %d %{user:_display}
negate * * * /bin/keyctl negate %k 10 @u
and then doing:
keyctl add user _display aaaaaaaa @u
while keyctl request2 user test:x test:x @u &&
keyctl list @u;
do
keyctl request2 user test:x test:x @u;
sleep 31;
keyctl list @u;
done
which will oops eventually. Changing the negate line to have @u rather than
%S at the end is important as that forces the latter case by passing a special
keyring ID rather than an actual keyring ID.
Reported-by: Alexander Zangerl <az@bond.edu.au>
Tested-by: Alexander Zangerl <az@bond.edu.au>
Fix a number of problems with the new key garbage collector:
(1) A rogue semicolon in keyring_gc() was causing the initial count of dead
keys to be miscalculated.
(2) A missing return in keyring_gc() meant that under certain circumstances,
the keyring semaphore would be unlocked twice.
(3) The key serial tree iterator (key_garbage_collector()) part of the garbage
collector has been modified to:
(a) Complete each scan of the keyrings before setting the new timer.
(b) Only set the new timer for keys that have yet to expire. This means
that the new timer is now calculated correctly, and the gc doesn't
get into a loop continually scanning for keys that have expired, and
preventing other things from happening, like RCU cleaning up the old
keyring contents.
(c) Perform an extra scan if any keys were garbage collected in this one
as a key might become garbage during a scan, and (b) could mean we
don't set the timer again.
(4) Made key_schedule_gc() take the time at which to do a collection run,
rather than the time at which the key expires. This means the collection
of dead keys (key type unregistered) can happen immediately.
When we exit early from keyctl_session_to_parent because of permissions or
because the session keyring is the same as the parent, we need to unlock the
tasklist.
The missing unlock causes the system to hang completely when using
keyctl(KEYCTL_SESSION_TO_PARENT) with a keyring shared with the parent.
Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
Add a keyctl to install a process's session keyring onto its parent. This
replaces the parent's session keyring. Because the COW credential code does
not permit one process to change another process's credentials directly, the
change is deferred until userspace next starts executing again. Normally this
will be after a wait*() syscall.
To support this, three new security hooks have been provided:
cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in
the blank security creds and key_session_to_parent() - which asks the LSM if
the process may replace its parent's session keyring.
The replacement may only happen if the process has the same ownership details
as its parent, and the process has LINK permission on the session keyring, and
the session keyring is owned by the process, and the LSM permits it.
Note that this requires alteration to each architecture's notify_resume path.
This has been done for all arches barring blackfin, m68k* and xtensa, all of
which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the
replacement to be performed at the point the parent process resumes userspace
execution.
This allows the userspace AFS pioctl emulation to fully emulate newpag() and
the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to
alter the parent process's PAG membership. However, since kAFS doesn't use
PAGs per se, but rather dumps the keys into the session keyring, the session
keyring of the parent must be replaced if, for example, VIOCSETTOK is passed
the newpag flag.
This can be tested with the following program:
#include <stdio.h>
#include <stdlib.h>
#include <keyutils.h>
#define KEYCTL_SESSION_TO_PARENT 18
#define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0)
int main(int argc, char **argv)
key_serial_t keyring, key;
long ret;
keyring = keyctl_join_session_keyring(argv[1]);
OSERROR(keyring, "keyctl_join_session_keyring");
key = add_key("user", "a", "b", 1, keyring);
OSERROR(key, "add_key");
ret = keyctl(KEYCTL_SESSION_TO_PARENT);
OSERROR(ret, "KEYCTL_SESSION_TO_PARENT");
return 0;
Compiled and linked with -lkeyutils, you should see something like:
[dhowells@andromeda ~]$ keyctl show
Session Keyring
-3 --alswrv 4043 4043 keyring: _ses
355907932 --alswrv 4043 -1 \_ keyring: _uid.4043
[dhowells@andromeda ~]$ /tmp/newpag
Session Keyring
1055658746 --alswrv 4043 4043 \_ user: a
[dhowells@andromeda ~]$ /tmp/newpag hello
Session Keyring
-3 --alswrv 4043 4043 keyring: hello
340417692 --alswrv 4043 4043 \_ user: a
Where the test program creates a new session keyring, sticks a user key named
'a' into it and then installs it on its parent.
Add garbage collection for dead, revoked and expired keys. This involved
erasing all links to such keys from keyrings that point to them. At that
point, the key will be deleted in the normal manner.
Keyrings from which garbage collection occurs are shrunk and their quota
consumption reduced as appropriate.
Dead keys (for which the key type has been removed) will be garbage collected
immediately.
Revoked and expired keys will hang around for a number of seconds, as set in
/proc/sys/kernel/keys/gc_delay before being automatically removed. The default
is 5 minutes.
[try #6]
Allow keyctl_revoke() to operate on keys that have SETATTR but not WRITE
permission, rather than only on keys that have WRITE permission.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Allow keys for which the key type has been removed to be unlinked. Currently
dead-type keys can only be disposed of by completely clearing the keyrings
that point to them.
per-uid keys were looked by uid only. Use the user namespace
to distinguish the same uid in different namespaces.
This does not address key_permission. So a task can for instance
try to join a keyring owned by the same uid in another namespace.
That will be handled by a separate patch.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Plug this leak.
Cc: <stable@kernel.org>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Fix the following sparse warning:
CC security/keys/key.o
security/keys/keyctl.c:1297:10: warning: incorrect type in argument 2 (different address spaces)
security/keys/keyctl.c:1297:10: expected char [noderef] <asn:1>*buffer
security/keys/keyctl.c:1297:10: got char *<noident>
which appears to be caused by lack of __user annotation to the cast of
a syscall argument.
Fix variable uninitialisation warnings introduced in:
commit 8bbf4976b59fc9fc2861e79cab7beb3f6d647640
Author: David Howells <dhowells@redhat.com>
Date: Fri Nov 14 10:39:14 2008 +1100
KEYS: Alter use of key instantiation link-to-keyring argument
As:
security/keys/keyctl.c: In function 'keyctl_negate_key':
security/keys/keyctl.c:976: warning: 'dest_keyring' may be used uninitialized in this function
security/keys/keyctl.c: In function 'keyctl_instantiate_key':
security/keys/keyctl.c:898: warning: 'dest_keyring' may be used uninitialized in this function
Some versions of gcc notice that get_instantiation_key() doesn't always set
*_dest_keyring, but fail to observe that if this happens then *_dest_keyring
will not be read by the caller.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Inaugurate copy-on-write credentials management. This uses RCU to manage the
credentials pointer in the task_struct with respect to accesses by other tasks.
A process may only modify its own credentials, and so does not need locking to
access or modify its own credentials.
A mutex (cred_replace_mutex) is added to the task_struct to control the effect
of PTRACE_ATTACHED on credential calculations, particularly with respect to
execve().
With this patch, the contents of an active credentials struct may not be
changed directly; rather a new set of credentials must be prepared, modified
and committed using something like the following sequence of events:
struct cred *new = prepare_creds();
int ret = blah(new);
if (ret < 0) {
abort_creds(new);
return ret;
return commit_creds(new);
There are some exceptions to this rule: the keyrings pointed to by the active
credentials may be instantiated - keyrings violate the COW rule as managing
COW keyrings is tricky, given that it is possible for a task to directly alter
the keys in a keyring in use by another task.
To help enforce this, various pointers to sets of credentials, such as those in
the task_struct, are declared const. The purpose of this is compile-time
discouragement of altering credentials through those pointers. Once a set of
credentials has been made public through one of these pointers, it may not be
modified, except under special circumstances:
(1) Its reference count may incremented and decremented.
(2) The keyrings to which it points may be modified, but not replaced.
The only safe way to modify anything else is to create a replacement and commit
using the functions described in Documentation/credentials.txt (which will be
added by a later patch).
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
This now prepares and commits credentials in various places in the
security code rather than altering the current creds directly.
(2) Temporary credential overrides.
do_coredump() and sys_faccessat() now prepare their own credentials and
temporarily override the ones currently on the acting thread, whilst
preventing interference from other threads by holding cred_replace_mutex
on the thread being dumped.
This will be replaced in a future patch by something that hands down the
credentials directly to the functions being called, rather than altering
the task's objective credentials.
(3) LSM interface.
A number of functions have been changed, added or removed:
(*) security_capset_check(), ->capset_check()
(*) security_capset_set(), ->capset_set()
Removed in favour of security_capset().
(*) security_capset(), ->capset()
New. This is passed a pointer to the new creds, a pointer to the old
creds and the proposed capability sets. It should fill in the new
creds or return an error. All pointers, barring the pointer to the
new creds, are now const.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
Changed; now returns a value, which will cause the process to be
killed if it's an error.
(*) security_task_alloc(), ->task_alloc_security()
Removed in favour of security_prepare_creds().
(*) security_cred_free(), ->cred_free()
New. Free security data attached to cred->security.
(*) security_prepare_creds(), ->cred_prepare()
New. Duplicate any security data attached to cred->security.
(*) security_commit_creds(), ->cred_commit()
New. Apply any security effects for the upcoming installation of new
security by commit_creds().
(*) security_task_post_setuid(), ->task_post_setuid()
Removed in favour of security_task_fix_setuid().
(*) security_task_fix_setuid(), ->task_fix_setuid()
Fix up the proposed new credentials for setuid(). This is used by
cap_set_fix_setuid() to implicitly adjust capabilities in line with
setuid() changes. Changes are made to the new credentials, rather
than the task itself as in security_task_post_setuid().
(*) security_task_reparent_to_init(), ->task_reparent_to_init()
Removed. Instead the task being reparented to init is referred
directly to init's credentials.
NOTE! This results in the loss of some state: SELinux's osid no
longer records the sid of the thread that forked it.
(*) security_key_alloc(), ->key_alloc()
(*) security_key_permission(), ->key_permission()
Changed. These now take cred pointers rather than task pointers to
refer to the security context.
(4) sys_capset().
This has been simplified and uses less locking. The LSM functions it
calls have been merged.
(5) reparent_to_kthreadd().
This gives the current thread the same credentials as init by simply using
commit_thread() to point that way.
(6) __sigqueue_alloc() and switch_uid()
__sigqueue_alloc() can't stop the target task from changing its creds
beneath it, so this function gets a reference to the currently applicable
user_struct which it then passes into the sigqueue struct it returns if
successful.
switch_uid() is now called from commit_creds(), and possibly should be
folded into that. commit_creds() should take care of protecting
__sigqueue_alloc().
(7) [sg]et[ug]id() and co and [sg]et_current_groups.
The set functions now all use prepare_creds(), commit_creds() and
abort_creds() to build and check a new set of credentials before applying
it.
security_task_set[ug]id() is called inside the prepared section. This
guarantees that nothing else will affect the creds until we've finished.
The calling of set_dumpable() has been moved into commit_creds().
Much of the functionality of set_user() has been moved into
commit_creds().
The get functions all simply access the data directly.
(8) security_task_prctl() and cap_task_prctl().
security_task_prctl() has been modified to return -ENOSYS if it doesn't
want to handle a function, or otherwise return the return value directly
rather than through an argument.
Additionally, cap_task_prctl() now prepares a new set of credentials, even
if it doesn't end up using it.
(9) Keyrings.
A number of changes have been made to the keyrings code:
(a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have
all been dropped and built in to the credentials functions directly.
They may want separating out again later.
(b) key_alloc() and search_process_keyrings() now take a cred pointer
rather than a task pointer to specify the security context.
(c) copy_creds() gives a new thread within the same thread group a new
thread keyring if its parent had one, otherwise it discards the thread
keyring.
(d) The authorisation key now points directly to the credentials to extend
the search into rather pointing to the task that carries them.
(e) Installing thread, process or session keyrings causes a new set of
credentials to be created, even though it's not strictly necessary for
process or session keyrings (they're shared).
(10) Usermode helper.
The usermode helper code now carries a cred struct pointer in its
subprocess_info struct instead of a new session keyring pointer. This set
of credentials is derived from init_cred and installed on the new process
after it has been cloned.
call_usermodehelper_setup() allocates the new credentials and
call_usermodehelper_freeinfo() discards them if they haven't been used. A
special cred function (prepare_usermodeinfo_creds()) is provided
specifically for call_usermodehelper_setup() to call.
call_usermodehelper_setkeys() adjusts the credentials to sport the
supplied keyring as the new session keyring.
(11) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) selinux_setprocattr() no longer does its check for whether the
current ptracer can access processes with the new SID inside the lock
that covers getting the ptracer's SID. Whilst this lock ensures that
the check is done with the ptracer pinned, the result is only valid
until the lock is released, so there's no point doing it inside the
lock.
(12) is_single_threaded().
This function has been extracted from selinux_setprocattr() and put into
a file of its own in the lib/ directory as join_session_keyring() now
wants to use it too.
The code in SELinux just checked to see whether a task shared mm_structs
with other tasks (CLONE_VM), but that isn't good enough. We really want
to know if they're part of the same thread group (CLONE_THREAD).
(13) nfsd.
The NFS server daemon now has to use the COW credentials to set the
credentials it is going to use. It really needs to pass the credentials
down to the functions it calls, but it can't do that until other patches
in this series have been applied.
Acked-by: James Morris <jmorris@namei.org>
Separate the task security context from task_struct. At this point, the
security data is temporarily embedded in the task_struct with two pointers
pointing to it.
Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in
entry.S via asm-offsets.
With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
Alter the use of the key instantiation and negation functions' link-to-keyring
arguments. Currently this specifies a keyring in the target process to link
the key into, creating the keyring if it doesn't exist. This, however, can be
a problem for copy-on-write credentials as it means that the instantiating
process can alter the credentials of the requesting process.
This patch alters the behaviour such that:
(1) If keyctl_instantiate_key() or keyctl_negate_key() are given a specific
keyring by ID (ringid >= 0), then that keyring will be used.
(2) If keyctl_instantiate_key() or keyctl_negate_key() are given one of the
special constants that refer to the requesting process's keyrings
(KEY_SPEC_*_KEYRING, all <= 0), then:
(a) If sys_request_key() was given a keyring to use (destringid) then the
key will be attached to that keyring.
(b) If sys_request_key() was given a NULL keyring, then the key being
instantiated will be attached to the default keyring as set by
keyctl_set_reqkey_keyring().
(3) No extra link will be made.
Decision point (1) follows current behaviour, and allows those instantiators
who've searched for a specifically named keyring in the requestor's keyring so
as to partition the keys by type to still have their named keyrings.
Decision point (2) allows the requestor to make sure that the key or keys that
get produced by request_key() go where they want, whilst allowing the
instantiator to request that the key is retained. This is mainly useful for
situations where the instantiator makes a secondary request, the key for which
should be retained by the initial requestor:
| Requestor |------->| Instantiator |------->| Instantiator |
request_key() request_key()
This might be useful, for example, in Kerberos, where the requestor requests a
ticket, and then the ticket instantiator requests the TGT, which someone else
then has to go and fetch. The TGT, however, should be retained in the
keyrings of the requestor, not the first instantiator. To make this explict
an extra special keyring constant is also added.
Reviewed-by: James Morris <jmorris@namei.org>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Make the keyring quotas controllable through /proc/sys files:
(*) /proc/sys/kernel/keys/root_maxkeys
/proc/sys/kernel/keys/root_maxbytes
Maximum number of keys that root may have and the maximum total number of
bytes of data that root may have stored in those keys.
(*) /proc/sys/kernel/keys/maxkeys
/proc/sys/kernel/keys/maxbytes
Maximum number of keys that each non-root user may have and the maximum
total number of bytes of data that each of those users may have stored in
their keys.
Also increase the quotas as a number of people have been complaining that it's
not big enough. I'm not sure that it's big enough now either, but on the
other hand, it can now be set in /etc/sysctl.conf.
Cc: <kwc@citi.umich.edu>
Cc: <arunsr@cse.iitk.ac.in>
Cc: <dwalsh@redhat.com>
The key_create_or_update() function provided by the keyring code has a default
set of permissions that are always applied to the key when created. This
might not be desirable to all clients.
Here's a patch that adds a "perm" parameter to the function to address this,
which can be set to KEY_PERM_UNDEF to revert to the current behaviour.
Signed-off-by: Arun Raghavan <arunsr@cse.iitk.ac.in>
Cc: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Add a keyctl() function to get the security label of a key.
The following is added to Documentation/keys.txt:
(*) Get the LSM security context attached to a key.
long keyctl(KEYCTL_GET_SECURITY, key_serial_t key, char *buffer,
size_t buflen)
This function returns a string that represents the LSM security context
attached to a key in the buffer provided.
Unless there's an error, it always returns the amount of data it could
produce, even if that's too big for the buffer, but it won't copy more
than requested to userspace. If the buffer pointer is NULL then no copy
will take place.
A NUL character is included at the end of the string if the buffer is
sufficiently big. This is included in the returned count. If no LSM is
in force then an empty string will be returned.
A process must have view permission on the key for this function to be
successful.
[akpm@linux-foundation.org: declare keyctl_get_security()]
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Paul Moore <paul.moore@hp.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Kevin Coffman <kwc@citi.umich.edu>
Allow the callout data to be passed as a blob rather than a string for
internal kernel services that call any request_key_*() interface other than
request_key(). request_key() itself still takes a NUL-terminated string.
The functions that change are:
request_key_with_auxdata()
request_key_async()
request_key_async_with_auxdata()
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Increase the size of a payload that can be used to instantiate a key in
add_key() and keyctl_instantiate_key(). This permits huge CIFS SPNEGO blobs
to be passed around. The limit is raised to 1MB. If kmalloc() can't allocate
a buffer of sufficient size, vmalloc() will be tried instead.
Cc: Steven French <sfrench@us.ibm.com>
The proposed NFS key type uses its own method of passing key requests to
userspace (upcalling) rather than invoking /sbin/request-key. This is
because the responsible userspace daemon should already be running and will
be contacted through rpc_pipefs.
This patch permits the NFS filesystem to pass auxiliary data to the upcall
operation (struct key_type::request_key) so that the upcaller can use a
pre-existing communications channel more easily.
Acked-By: Kevin Coffman <kwc@citi.umich.edu>
Let keyctl_chown() change a key's owner, including attempting to transfer the
quota burden to the new user.
Add the ability for key creation to overrun the user's quota in some
circumstances - notably when a session keyring is created and assigned to a
process that didn't previously have one.
This means it's still possible to log in, should PAM require the creation of a
new session keyring, and fix an overburdened key quota.
Copies user-space string with strndup_user() and moves the type string
duplication code to a function (thus fixing a wrong check on the length of the
type.)
Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com>
In the small window between strnlen_user() and copy_from_user() userspace
could alter the terminating `\0' character.
- Move capable() from sched.h to capability.h;
- Use <linux/capability.h> where capable() is used
(in include/, block/, ipc/, kernel/, a few drivers/,
mm/, security/, & sound/;
many more drivers/ to go)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Make it possible for a running process (such as gssapid) to be able to
instantiate a key, as was requested by Trond Myklebust for NFS4.
The patch makes the following changes:
(1) A new, optional key type method has been added. This permits a key type
to intercept requests at the point /sbin/request-key is about to be
spawned and do something else with them - passing them over the
rpc_pipefs files or netlink sockets for instance.
The uninstantiated key, the authorisation key and the intended operation
name are passed to the method.
(2) The callout_info is no longer passed as an argument to /sbin/request-key
to prevent unauthorised viewing of this data using ps or by looking in
/proc/pid/cmdline.
This means that the old /sbin/request-key program will not work with the
patched kernel as it will expect to see an extra argument that is no
longer there.
A revised keyutils package will be made available tomorrow.
(3) The callout_info is now attached to the authorisation key. Reading this
key will retrieve the information.
(4) A new field has been added to the task_struct. This holds the
authorisation key currently active for a thread. Searches now look here
for the caller's set of keys rather than looking for an auth key in the
lowest level of the session keyring.
This permits a thread to be servicing multiple requests at once and to
switch between them. Note that this is per-thread, not per-process, and
so is usable in multithreaded programs.
The setting of this field is inherited across fork and exec.
(5) A new keyctl function (KEYCTL_ASSUME_AUTHORITY) has been added that
permits a thread to assume the authority to deal with an uninstantiated
key. Assumption is only permitted if the authorisation key associated
with the uninstantiated key is somewhere in the thread's keyrings.
This function can also clear the assumption.
(6) A new magic key specifier has been added to refer to the currently
assumed authorisation key (KEY_SPEC_REQKEY_AUTH_KEY).
(7) Instantiation will only proceed if the appropriate authorisation key is
assumed first. The assumed authorisation key is discarded if
instantiation is successful.
(8) key_validate() is moved from the file of request_key functions to the
file of permissions functions.
(9) The documentation is updated.
Build fix.
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Alexander Zangerl <az@bond.edu.au>
Add a new keyctl function that allows the expiry time to be set on a key or
removed from a key, provided the caller has attribute modification access.
The attached patch adds LSM hooks for key management facilities. The notable
changes are:
(1) The key struct now supports a security pointer for the use of security
modules. This will permit key labelling and restrictions on which
programs may access a key.
(2) Security modules get a chance to note (or abort) the allocation of a key.
(3) The key permission checking can now be enhanced by the security modules;
the permissions check consults LSM if all other checks bear out.
(4) The key permissions checking functions now return an error code rather
than a boolean value.
(5) An extra permission has been added to govern the modification of
attributes (UID, GID, permissions).
Note that there isn't an LSM hook specifically for each keyctl() operation,
but rather the permissions hook allows control of individual operations based
on the permission request bits.
Key management access control through LSM is enabled by automatically if both
CONFIG_KEYS and CONFIG_SECURITY are enabled.
This should be applied on top of the patch ensubjected:
[PATCH] Keys: Possessor permissions should be additive
Signed-Off-By: David Howells <dhowells@redhat.com>
Signed-off-by: Chris Wright <chrisw@osdl.org>
The attached patch adds extra permission grants to keys for the possessor of a
key in addition to the owner, group and other permissions bits. This makes
SUID binaries easier to support without going as far as labelling keys and key
targets using the LSM facilities.
This patch adds a second "pointer type" to key structures (struct key_ref *)
that can have the bottom bit of the address set to indicate the possession of
a key. This is propagated through searches from the keyring to the discovered
key. It has been made a separate type so that the compiler can spot attempts
to dereference a potentially incorrect pointer.
The "possession" attribute can't be attached to a key structure directly as
it's not an intrinsic property of a key.
Pointers to keys have been replaced with struct key_ref *'s wherever
possession information needs to be passed through.
This does assume that the bottom bit of the pointer will always be zero on
return from kmem_cache_alloc().
The key reference type has been made into a typedef so that at least it can be
located in the sources, even though it's basically a pointer to an undefined
type. I've also renamed the accessor functions to be more useful, and all
reference variables should now end in "_ref".
This fixes five bugs in the key management syscall interface:
(1) add_key() returns 0 rather than EINVAL if the key type is "".
Checking the key type isn't "" should be left to lookup_user_key().
(2) request_key() returns ENOKEY rather than EPERM if the key type begins
with a ".".
lookup_user_key() can't do this because internal key types begin with a
(3) Key revocation always returns 0, even if it fails.
(4) Key read can return EAGAIN rather than EACCES under some circumstances.
A key is permitted to by read by a process if it doesn't grant read
access, but it does grant search access and it is in the process's
keyrings. That search returns EAGAIN if it fails, and this needs
translating to EACCES.
(5) request_key() never adds the new key to the destination keyring if one is
supplied.
The wrong macro was being used to test for an error condition: PTR_ERR()
will always return true, whether or not there's an error; this should've
been IS_ERR().
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
The attached patch makes the following changes:
(1) There's a new special key type called ".request_key_auth".
This is an authorisation key for when one process requests a key and
another process is started to construct it. This type of key cannot be
created by the user; nor can it be requested by kernel services.
Authorisation keys hold two references:
(a) Each refers to a key being constructed. When the key being
constructed is instantiated the authorisation key is revoked,
rendering it of no further use.
(b) The "authorising process". This is either:
(i) the process that called request_key(), or:
(ii) if the process that called request_key() itself had an
authorisation key in its session keyring, then the authorising
process referred to by that authorisation key will also be
referred to by the new authorisation key.
This means that the process that initiated a chain of key requests
will authorise the lot of them, and will, by default, wind up with
the keys obtained from them in its keyrings.
(2) request_key() creates an authorisation key which is then passed to
/sbin/request-key in as part of a new session keyring.
(3) When request_key() is searching for a key to hand back to the caller, if
it comes across an authorisation key in the session keyring of the
calling process, it will also search the keyrings of the process
specified therein and it will use the specified process's credentials
(fsuid, fsgid, groups) to do that rather than the calling process's
credentials.
This allows a process started by /sbin/request-key to find keys belonging
to the authorising process.
(4) A key can be read, even if the process executing KEYCTL_READ doesn't have
direct read or search permission if that key is contained within the
keyrings of a process specified by an authorisation key found within the
calling process's session keyring, and is searchable using the
credentials of the authorising process.
This allows a process started by /sbin/request-key to read keys belonging
(5) The magic KEY_SPEC_*_KEYRING key IDs when passed to KEYCTL_INSTANTIATE or
KEYCTL_NEGATE will specify a keyring of the authorising process, rather
than the process doing the instantiation.
(6) One of the process keyrings can be nominated as the default to which
request_key() should attach new keys if not otherwise specified. This is
done with KEYCTL_SET_REQKEY_KEYRING and one of the KEY_REQKEY_DEFL_*
constants. The current setting can also be read using this call.
(7) request_key() is partially interruptible. If it is waiting for another
process to finish constructing a key, it can be interrupted. This permits
a request-key cycle to be broken without recourse to rebooting.
Signed-Off-By: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
The attached patch changes the key implementation in a number of ways:
(1) It removes the spinlock from the key structure.
(2) The key flags are now accessed using atomic bitops instead of
write-locking the key spinlock and using C bitwise operators.
The three instantiation flags are dealt with with the construction
semaphore held during the request_key/instantiate/negate sequence, thus
rendering the spinlock superfluous.
The key flags are also now bit numbers not bit masks.
(3) The key payload is now accessed using RCU. This permits the recursive
keyring search algorithm to be simplified greatly since no locks need be
taken other than the usual RCU preemption disablement. Searching now does
not require any locks or semaphores to be held; merely that the starting
keyring be pinned.
(4) The keyring payload now includes an RCU head so that it can be disposed
of by call_rcu(). This requires that the payload be copied on unlink to
prevent introducing races in copy-down vs search-up.
(5) The user key payload is now a structure with the data following it. It
includes an RCU head like the keyring payload and for the same reason. It
also contains a data length because the data length in the key may be
changed on another CPU whilst an RCU protected read is in progress on the
payload. This would then see the supposed RCU payload and the on-key data
length getting out of sync.
I'm tempted to drop the key's datalen entirely, except that it's used in
conjunction with quota management and so is a little tricky to get rid
of.
(6) Update the keys documentation.
infrastructure for it.
Let it rip!
