path: root/security/keys
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30KEYS: split call to call_usermodehelper_fns()Lucas De Marchi
Use call_usermodehelper_setup() + call_usermodehelper_exec() instead of calling call_usermodehelper_fns(). In case there's an OOM in this last function the cleanup function may not be called - in this case we would miss a call to key_put(). Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-12keys: fix race with concurrent install_user_keyrings()David Howells
This fixes CVE-2013-1792. There is a race in install_user_keyrings() that can cause a NULL pointer dereference when called concurrently for the same user if the uid and uid-session keyrings are not yet created. It might be possible for an unprivileged user to trigger this by calling keyctl() from userspace in parallel immediately after logging in. Assume that we have two threads both executing lookup_user_key(), both looking for KEY_SPEC_USER_SESSION_KEYRING. THREAD A THREAD B =============================== =============================== ==>call install_user_keyrings(); if (!cred->user->session_keyring) ==>call install_user_keyrings() ... user->uid_keyring = uid_keyring; if (user->uid_keyring) return 0; <== key = cred->user->session_keyring [== NULL] user->session_keyring = session_keyring; atomic_inc(&key->usage); [oops] At the point thread A dereferences cred->user->session_keyring, thread B hasn't updated user->session_keyring yet, but thread A assumes it is populated because install_user_keyrings() returned ok. The race window is really small but can be exploited if, for example, thread B is interrupted or preempted after initializing uid_keyring, but before doing setting session_keyring. This couldn't be reproduced on a stock kernel. However, after placing systemtap probe on 'user->session_keyring = session_keyring;' that introduced some delay, the kernel could be crashed reliably. Fix this by checking both pointers before deciding whether to return. Alternatively, the test could be done away with entirely as it is checked inside the mutex - but since the mutex is global, that may not be the best way. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Mateusz Guzik <mguzik@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2013-03-03userns: Stop oopsing in key_change_session_keyringEric W. Biederman
Dave Jones <davej@redhat.com> writes: > Just hit this on Linus' current tree. > > [ 89.621770] BUG: unable to handle kernel NULL pointer dereference at 00000000000000c8 > [ 89.623111] IP: [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.624062] PGD 122bfd067 PUD 122bfe067 PMD 0 > [ 89.624901] Oops: 0000 [#1] PREEMPT SMP > [ 89.625678] Modules linked in: caif_socket caif netrom bridge hidp 8021q garp stp mrp rose llc2 af_rxrpc phonet af_key binfmt_misc bnep l2tp_ppp can_bcm l2tp_core pppoe pppox can_raw scsi_transport_iscsi ppp_generic slhc nfnetlink can ipt_ULOG ax25 decnet irda nfc rds x25 crc_ccitt appletalk atm ipx p8023 psnap p8022 llc lockd sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_conntrack nf_conntrack ip6table_filter ip6_tables btusb bluetooth snd_hda_codec_realtek snd_hda_intel snd_hda_codec snd_pcm vhost_net snd_page_alloc snd_timer tun macvtap usb_debug snd rfkill microcode macvlan edac_core pcspkr serio_raw kvm_amd soundcore kvm r8169 mii > [ 89.637846] CPU 2 > [ 89.638175] Pid: 782, comm: trinity-main Not tainted 3.8.0+ #63 Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H > [ 89.639850] RIP: 0010:[<ffffffff810784b0>] [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.641161] RSP: 0018:ffff880115657eb8 EFLAGS: 00010207 > [ 89.641984] RAX: 00000000000003e8 RBX: ffff88012688b000 RCX: 0000000000000000 > [ 89.643069] RDX: 0000000000000000 RSI: ffffffff81c32960 RDI: ffff880105839600 > [ 89.644167] RBP: ffff880115657ed8 R08: 0000000000000000 R09: 0000000000000000 > [ 89.645254] R10: 0000000000000001 R11: 0000000000000246 R12: ffff880105839600 > [ 89.646340] R13: ffff88011beea490 R14: ffff88011beea490 R15: 0000000000000000 > [ 89.647431] FS: 00007f3ac063b740(0000) GS:ffff88012b200000(0000) knlGS:0000000000000000 > [ 89.648660] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b > [ 89.649548] CR2: 00000000000000c8 CR3: 0000000122bfc000 CR4: 00000000000007e0 > [ 89.650635] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 > [ 89.651723] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 > [ 89.652812] Process trinity-main (pid: 782, threadinfo ffff880115656000, task ffff88011beea490) > [ 89.654128] Stack: > [ 89.654433] 0000000000000000 ffff8801058396a0 ffff880105839600 ffff88011beeaa78 > [ 89.655769] ffff880115657ef8 ffffffff812c7d9b ffffffff82079be0 0000000000000000 > [ 89.657073] ffff880115657f28 ffffffff8106c665 0000000000000002 ffff880115657f58 > [ 89.658399] Call Trace: > [ 89.658822] [<ffffffff812c7d9b>] key_change_session_keyring+0xfb/0x140 > [ 89.659845] [<ffffffff8106c665>] task_work_run+0xa5/0xd0 > [ 89.660698] [<ffffffff81002911>] do_notify_resume+0x71/0xb0 > [ 89.661581] [<ffffffff816c9a4a>] int_signal+0x12/0x17 > [ 89.662385] Code: 24 90 00 00 00 48 8b b3 90 00 00 00 49 8b 4c 24 40 48 39 f2 75 08 e9 83 00 00 00 48 89 ca 48 81 fa 60 29 c3 81 0f 84 41 fe ff ff <48> 8b 8a c8 00 00 00 48 39 ce 75 e4 3b 82 d0 00 00 00 0f 84 4b > [ 89.667778] RIP [<ffffffff810784b0>] commit_creds+0x250/0x2f0 > [ 89.668733] RSP <ffff880115657eb8> > [ 89.669301] CR2: 00000000000000c8 > > My fastest trinity induced oops yet! > > > Appears to be.. > > if ((set_ns == subset_ns->parent) && > 850: 48 8b 8a c8 00 00 00 mov 0xc8(%rdx),%rcx > > from the inlined cred_cap_issubset By historical accident we have been reading trying to set new->user_ns from new->user_ns. Which is totally silly as new->user_ns is NULL (as is every other field in new except session_keyring at that point). The intent is clearly to copy all of the fields from old to new so copy old->user_ns into into new->user_ns. Cc: stable@vger.kernel.org Reported-by: Dave Jones <davej@redhat.com> Tested-by: Dave Jones <davej@redhat.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-21KEYS: Revert one application of "Fix unreachable code" patchDavid Howells
A patch to fix some unreachable code in search_my_process_keyrings() got applied twice by two different routes upstream as commits e67eab39bee2 and b010520ab3d2 (both "fix unreachable code"). Unfortunately, the second application removed something it shouldn't have and this wasn't detected by GIT. This is due to the patch not having sufficient lines of context to distinguish the two places of application. The effect of this is relatively minor: inside the kernel, the keyring search routines may search multiple keyrings and then prioritise the errors if no keys or negative keys are found in any of them. With the extra deletion, the presence of a negative key in the thread keyring (causing ENOKEY) is incorrectly overridden by an error searching the process keyring. So revert the second application of the patch. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-20keys: fix unreachable codeAlan Cox
We set ret to NULL then test it. Remove the bogus test Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-10-28Merge branch 'master' into for-nextJiri Kosina
Sync up with Linus' tree to be able to apply Cesar's patch against newer version of the code. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-25keys: Fix unreachable codeAlan Cox
We set ret to NULL then test it. Remove the bogus test Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
2012-10-02Merge branch 'modsign-keys-devel' into security-next-keysDavid Howells
2012-10-02KEYS: Use keyring_alloc() to create special keyringsDavid Howells
Use keyring_alloc() to create special keyrings now that it has a permissions parameter rather than using key_alloc() + key_instantiate_and_link(). Also document and export keyring_alloc() so that modules can use it too. Signed-off-by: David Howells <dhowells@redhat.com>
2012-10-02KEYS: Reduce initial permissions on keysDavid Howells
Reduce the initial permissions on new keys to grant the possessor everything, view permission only to the user (so the keys can be seen in /proc/keys) and nothing else. This gives the creator a chance to adjust the permissions mask before other processes can access the new key or create a link to it. To aid with this, keyring_alloc() now takes a permission argument rather than setting the permissions itself. The following permissions are now set: (1) The user and user-session keyrings grant the user that owns them full permissions and grant a possessor everything bar SETATTR. (2) The process and thread keyrings grant the possessor full permissions but only grant the user VIEW. This permits the user to see them in /proc/keys, but not to do anything with them. (3) Anonymous session keyrings grant the possessor full permissions, but only grant the user VIEW and READ. This means that the user can see them in /proc/keys and can list them, but nothing else. Possibly READ shouldn't be provided either. (4) Named session keyrings grant everything an anonymous session keyring does, plus they grant the user LINK permission. The whole point of named session keyrings is that others can also subscribe to them. Possibly this should be a separate permission to LINK. (5) The temporary session keyring created by call_sbin_request_key() gets the same permissions as an anonymous session keyring. (6) Keys created by add_key() get VIEW, SEARCH, LINK and SETATTR for the possessor, plus READ and/or WRITE if the key type supports them. The used only gets VIEW now. (7) Keys created by request_key() now get the same as those created by add_key(). Reported-by: Lennart Poettering <lennart@poettering.net> Reported-by: Stef Walter <stefw@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-10-02KEYS: Make the session and process keyrings per-threadDavid Howells
Make the session keyring per-thread rather than per-process, but still inherited from the parent thread to solve a problem with PAM and gdm. The problem is that join_session_keyring() will reject attempts to change the session keyring of a multithreaded program but gdm is now multithreaded before it gets to the point of starting PAM and running pam_keyinit to create the session keyring. See: https://bugs.freedesktop.org/show_bug.cgi?id=49211 The reason that join_session_keyring() will only change the session keyring under a single-threaded environment is that it's hard to alter the other thread's credentials to effect the change in a multi-threaded program. The problems are such as: (1) How to prevent two threads both running join_session_keyring() from racing. (2) Another thread's credentials may not be modified directly by this process. (3) The number of threads is uncertain whilst we're not holding the appropriate spinlock, making preallocation slightly tricky. (4) We could use TIF_NOTIFY_RESUME and key_replace_session_keyring() to get another thread to replace its keyring, but that means preallocating for each thread. A reasonable way around this is to make the session keyring per-thread rather than per-process and just document that if you want a common session keyring, you must get it before you spawn any threads - which is the current situation anyway. Whilst we're at it, we can the process keyring behave in the same way. This means we can clean up some of the ickyness in the creds code. Basically, after this patch, the session, process and thread keyrings are about inheritance rules only and not about sharing changes of keyring. Reported-by: Mantas M. <grawity@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Ray Strode <rstrode@redhat.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-09-28key: Fix resource leakAlan Cox
On an error iov may still have been reallocated and need freeing Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com>
2012-09-28keys: Fix unreachable codeAlan Cox
2012-09-13userns: Convert security/keys to the new userns infrastructureEric W. Biederman
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks. - Use from_kuid to generate key descriptions - Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t - Avoid potential problems with file descriptor passing by displaying keys in the user namespace of the opener of key status proc files. Cc: linux-security-module@vger.kernel.org Cc: keyrings@linux-nfs.org Cc: David Howells <dhowells@redhat.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-13task_work: Revert "hold task_lock around checks in keyctl"Oleg Nesterov
This reverts commit d35abdb28824cf74f0a106a0f9c6f3ff700a35bf. task_lock() was added to ensure exit_mm() and thus exit_task_work() is not possible before task_work_add(). This is wrong, task_lock() must not be nested with write_lock(tasklist). And this is no longer needed, task_work_add() now fails if it is called after exit_task_work(). Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20120826191214.GA4231@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-13KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
2012-08-22tpm: Move tpm_get_random api into the TPM device driverKent Yoder
Move the tpm_get_random api from the trusted keys code into the TPM device driver itself so that other callers can make use of it. Also, change the api slightly so that the number of bytes read is returned in the call, since the TPM command can potentially return fewer bytes than requested. Acked-by: David Safford <safford@linux.vnet.ibm.com> Reviewed-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
2012-08-20workqueue: deprecate system_nrt[_freezable]_wqTejun Heo
system_nrt[_freezable]_wq are now spurious. Mark them deprecated and convert all users to system[_freezable]_wq. If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant, so there's no reason to use system_nrt[_freezable]_wq. Please use system[_freezable]_wq instead. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-By: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com>
2012-07-23Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Nothing groundbreaking for this kernel, just cleanups and fixes, and a couple of Smack enhancements." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (21 commits) Smack: Maintainer Record Smack: don't show empty rules when /smack/load or /smack/load2 is read Smack: user access check bounds Smack: onlycap limits on CAP_MAC_ADMIN Smack: fix smack_new_inode bogosities ima: audit is compiled only when enabled ima: ima_initialized is set only if successful ima: add policy for pseudo fs ima: remove unused cleanup functions ima: free securityfs violations file ima: use full pathnames in measurement list security: Fix nommu build. samples: seccomp: add .gitignore for untracked executables tpm: check the chip reference before using it TPM: fix memleak when register hardware fails TPM: chip disabled state erronously being reported as error MAINTAINERS: TPM maintainers' contacts update Merge branches 'next-queue' and 'next' into next Remove unused code from MPI library Revert "crypto: GnuPG based MPI lib - additional sources (part 4)" ...
2012-07-22hold task_lock around checks in keyctlAl Viro
2012-07-22merge task_work and rcu_head, get rid of separate allocation for keyring caseAl Viro
task_work and rcu_head are identical now; merge them (calling the result struct callback_head, rcu_head #define'd to it), kill separate allocation in security/keys since we can just use cred->rcu now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22trimming task_work: kill ->dataAl Viro
get rid of the only user of ->data; this is _not_ the final variant - in the end we'll have task_work and rcu_head identical and just use cred->rcu, at which point the separate allocation will be gone completely. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-10Merge commit 'v3.5-rc2' into nextJames Morris
2012-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull second pile of signal handling patches from Al Viro: "This one is just task_work_add() series + remaining prereqs for it. There probably will be another pull request from that tree this cycle - at least for helpers, to get them out of the way for per-arch fixes remaining in the tree." Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the pr_foo() infrastructure to prefix printks") which changed one of the pr_err() calls that this merge moves around. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: keys: kill task_struct->replacement_session_keyring keys: kill the dummy key_replace_session_keyring() keys: change keyctl_session_to_parent() to use task_work_add() genirq: reimplement exit_irq_thread() hook via task_work_add() task_work_add: generic process-context callbacks avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers parisc: need to check NOTIFY_RESUME when exiting from syscall move key_repace_session_keyring() into tracehook_notify_resume() TIF_NOTIFY_RESUME is defined on all targets now
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31kmod: convert two call sites to call_usermodehelper_fns()Boaz Harrosh
Both kernel/sys.c && security/keys/request_key.c where inlining the exact same code as call_usermodehelper_fns(); So simply convert these sites to directly use call_usermodehelper_fns(). Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-31security/keys/keyctl.c: suppress memory allocation failure warningAndrew Morton
This allocation may be large. The code is probing to see if it will succeed and if not, it falls back to vmalloc(). We should suppress any page-allocation failure messages when the fallback happens. Reported-by: Dave Jones <davej@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-25KEYS: Fix some sparse warningsDavid Howells
Fix some sparse warnings in the keyrings code: (1) compat_keyctl_instantiate_key_iov() should be static. (2) There were a couple of places where a pointer was being compared against integer 0 rather than NULL. (3) keyctl_instantiate_key_common() should not take a __user-labelled iovec pointer as the caller must have copied the iovec to kernel space. (4) __key_link_begin() takes and __key_link_end() releases keyring_serialise_link_sem under some circumstances and so this should be declared. Note that adding __acquires() and __releases() for this doesn't help cure the warnings messages - something only commenting out both helps. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-23keys: change keyctl_session_to_parent() to use task_work_add()Oleg Nesterov
Change keyctl_session_to_parent() to use task_work_add() and move key_replace_session_keyring() logic into task_work->func(). Note that we do task_work_cancel() before task_work_add() to ensure that only one work can be pending at any time. This is important, we must not allow user-space to abuse the parent's ->task_works list. The callback, replace_session_keyring(), checks PF_EXITING. I guess this is not really needed but looks better. As a side effect, this fixes the (unlikely) race. The callers of key_replace_session_keyring() and keyctl_session_to_parent() lack the necessary barriers, the parent can miss the request. Now we can remove task_struct->replacement_session_keyring and related code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Gordeev <agordeev@redhat.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Smith <dsmith@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Larry Woodman <lwoodman@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-23TIF_NOTIFY_RESUME is defined on all targets nowAl Viro
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-16KEYS: Don't check for NULL key pointer in key_validate()David Howells
Don't bother checking for NULL key pointer in key_validate() as all of the places that call it will crash anyway if the relevant key pointer is NULL by the time they call key_validate(). Therefore, the checking must be done prior to calling here. Whilst we're at it, simplify the key_validate() function a bit and mark its argument const. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-11KEYS: Add invalidation supportDavid Howells
Add support for invalidating a key - which renders it immediately invisible to further searches and causes the garbage collector to immediately wake up, remove it from keyrings and then destroy it when it's no longer referenced. It's better not to do this with keyctl_revoke() as that marks the key to start returning -EKEYREVOKED to searches when what is actually desired is to have the key refetched. To invalidate a key the caller must be granted SEARCH permission by the key. This may be too strict. It may be better to also permit invalidation if the caller has any of READ, WRITE or SETATTR permission. The primary use for this is to evict keys that are cached in special keyrings, such as the DNS resolver or an ID mapper. Signed-off-by: David Howells <dhowells@redhat.com>
2012-05-11KEYS: Do LRU discard in full keyringsDavid Howells
Do an LRU discard in keyrings that are full rather than returning ENFILE. To perform this, a time_t is added to the key struct and updated by the creation of a link to a key and by a key being found as the result of a search. At the completion of a successful search, the keyrings in the path between the root of the search and the first found link to it also have their last-used times updated. Note that discarding a link to a key from a keyring does not necessarily destroy the key as there may be references held by other places. An alternate discard method that might suffice is to perform FIFO discard from the keyring, using the spare 2-byte hole in the keylist header as the index of the next link to be discarded. This is useful when using a keyring as a cache for DNS results or foreign filesystem IDs. This can be tested by the following. As root do: echo 1000 >/proc/sys/kernel/keys/root_maxkeys kr=`keyctl newring foo @s` for ((i=0; i<2000; i++)); do keyctl add user a$i a $kr; done Without this patch ENFILE should be reported when the keyring fills up. With this patch, the keyring discards keys in an LRU fashion. Note that the stored LRU time has a granularity of 1s. After doing this, /proc/key-users can be observed and should show that most of the 2000 keys have been discarded: [root@andromeda ~]# cat /proc/key-users 0: 517 516/516 513/1000 5249/20000 The "513/1000" here is the number of quota-accounted keys present for this user out of the maximum permitted. In /proc/keys, the keyring shows the number of keys it has and the number of slots it has allocated: [root@andromeda ~]# grep foo /proc/keys 200c64c4 I--Q-- 1 perm 3b3f0000 0 0 keyring foo: 509/509 The maximum is (PAGE_SIZE - header) / key pointer size. That's typically 509 on a 64-bit system and 1020 on a 32-bit system. Signed-off-by: David Howells <dhowells@redhat.com>
2012-05-11KEYS: Permit in-place link replacement in keyring listDavid Howells
Make use of the previous patch that makes the garbage collector perform RCU synchronisation before destroying defunct keys. Key pointers can now be replaced in-place without creating a new keyring payload and replacing the whole thing as the discarded keys will not be destroyed until all currently held RCU read locks are released. If the keyring payload space needs to be expanded or contracted, then a replacement will still need allocating, and the original will still have to be freed by RCU. Signed-off-by: David Howells <dhowells@redhat.com>
2012-05-11KEYS: Perform RCU synchronisation on keys prior to key destructionDavid Howells
Make the keys garbage collector invoke synchronize_rcu() prior to destroying keys with a zero usage count. This means that a key can be examined under the RCU read lock in the safe knowledge that it won't get deallocated until after the lock is released - even if its usage count becomes zero whilst we're looking at it. This is useful in keyring search vs key link. Consider a keyring containing a link to a key. That link can be replaced in-place in the keyring without requiring an RCU copy-and-replace on the keyring contents without breaking a search underway on that keyring when the displaced key is released, provided the key is actually destroyed only after the RCU read lock held by the search algorithm is released. This permits __key_link() to replace a key without having to reallocate the key payload. A key gets replaced if a new key being linked into a keyring has the same type and description. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com>
2012-05-11KEYS: Announce key type (un)registrationDavid Howells
Announce the (un)registration of a key type in the core key code rather than in the callers. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
2012-05-11KEYS: Reorganise keys MakefileDavid Howells
Reorganise the keys directory Makefile to put all the core bits together and the type-specific bits after. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
2012-05-11KEYS: Move the key config into security/keys/KconfigDavid Howells
Move the key config into security/keys/Kconfig as there are going to be a lot of key-related options. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com>
2012-05-03userns: Convert group_info values from gid_t to kgid_t.Eric W. Biederman
As a first step to converting struct cred to be all kuid_t and kgid_t values convert the group values stored in group_info to always be kgid_t values. Unless user namespaces are used this change should have no effect. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-07cred: Refcount the user_ns pointed to by the cred.Eric W. Biederman
struct user_struct will shortly loose it's user_ns reference so make the cred user_ns reference a proper reference complete with reference counting. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-07userns: Use cred->user_ns instead of cred->user->user_nsEric W. Biederman
Optimize performance and prepare for the removal of the user_ns reference from user_struct. Remove the slow long walk through cred->user->user_ns and instead go straight to cred->user_ns. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
