path: root/security/selinux
2011-06-15Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-06-14SELinux: skip file_name_trans_write() when policy downgraded.Roy.Li
When policy version is less than POLICYDB_VERSION_FILENAME_TRANS, skip file_name_trans_write(). Signed-off-by: Roy.Li <rongqing.li@windriver.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-06-08selinux: simplify and clean up inode_has_perm()Linus Torvalds
This is a rather hot function that is called with a potentially NULL "struct common_audit_data" pointer argument. And in that case it has to provide and initialize its own dummy common_audit_data structure. However, all the _common_ cases already pass it a real audit-data structure, so that uncommon NULL case not only creates a silly run-time test, more importantly it causes that function to have a big stack frame for the dummy variable that isn't even used in the common case! So get rid of that stupid run-time behavior, and make the (few) functions that currently call with a NULL pointer just call a new helper function instead (naturally called inode_has_perm_noapd(), since it has no adp argument). This makes the run-time test be a static code generation issue instead, and allows for a much denser stack since none of the common callers need the dummy structure. And a denser stack not only means less stack space usage, it means better cache behavior. So we have a win-win-win from this simplification: less code executed, smaller stack footprint, and better cache behavior. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26selinux: don't pass in NULL avd to avc_has_perm_noauditLinus Torvalds
Right now security_get_user_sids() will pass in a NULL avd pointer to avc_has_perm_noaudit(), which then forces that function to have a dummy entry for that case and just generally test it. Don't do it. The normal callers all pass a real avd pointer, and this helper function is incredibly hot. So don't make avc_has_perm_noaudit() do conditional stuff that isn't needed for the common case. This also avoids some duplicated stack space. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26selinux: fix case of names with whitespace/multibytes on /selinux/createKohei Kaigai
I submit the patch again, according to patch submission convension. This patch enables to accept percent-encoded object names as forth argument of /selinux/create interface to avoid possible bugs when we give an object name including whitespace or multibutes. E.g) if and when a userspace object manager tries to create a new object named as "resolve.conf but fake", it shall give this name as the forth argument of the /selinux/create. But sscanf() logic in kernel space fetches only the part earlier than the first whitespace. In this case, selinux may unexpectedly answer a default security context configured to "resolve.conf", but it is bug. Although I could not test this patch on named TYPE_TRANSITION rules actually, But debug printk() message seems to me the logic works correctly. I assume the libselinux provides an interface to apply this logic transparently, so nothing shall not be changed from the viewpoint of application. Signed-off-by: KaiGai Kohei <kohei.kaigai@emea.nec.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-26Merge commit 'v2.6.39' into 20110526Eric Paris
Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c
2011-05-24Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into ↵James Morris
for-linus Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c Manually resolve conflicts. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19selinux: avoid unnecessary avc cache stat hit countLinus Torvalds
There is no point in counting hits - we can calculate it from the number of lookups and misses. This makes the avc statistics a bit smaller, and makes the code generation better too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19selinux: de-crapify avc cache stat code generationLinus Torvalds
You can turn off the avc cache stats, but distributions seem to not do that (perhaps because several performance tuning how-to's talk about the avc cache statistics). Which is sad, because the code it generates is truly horrendous, with the statistics update being sandwitched between get_cpu/put_cpu which in turn causes preemption disables etc. We're talking ten+ instructions just to increment a per-cpu variable in some pretty hot code. Fix the craziness by just using 'this_cpu_inc()' instead. Suddenly we only need a single 'inc' instruction to increment the statistics. This is quite noticeable in the incredibly hot avc_has_perm_noaudit() function (which triggers all the statistics by virtue of doing an avc_lookup() call). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-13Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-05-12SELinux: delete debugging printks from filename_trans rule processingEric Paris
The filename_trans rule processing has some printk(KERN_ERR ) messages which were intended as debug aids in creating the code but weren't removed before it was submitted. Remove them. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-11SELINUX: add /sys/fs/selinux mount point to put selinuxfsGreg Kroah-Hartman
In the interest of keeping userspace from having to create new root filesystems all the time, let's follow the lead of the other in-kernel filesystems and provide a proper mount point for it in sysfs. For selinuxfs, this mount point should be in /sys/fs/selinux/ Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Eric Paris <eparis@parisplace.org> Cc: Lennart Poettering <mzerqung@0pointer.de> Cc: Daniel J Walsh <dwalsh@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [include kobject.h - Eric Paris] [use selinuxfs_obj throughout - Eric Paris] Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-07security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()Lai Jiangshan
The rcu callback sel_netif_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sel_netif_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-04Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-04-28flex_array: flex_array_prealloc takes a number of elements, not an endEric Paris
Change flex_array_prealloc to take the number of elements for which space should be allocated instead of the last (inclusive) element. Users and documentation are updated accordingly. flex_arrays got introduced before they had users. When folks started using it, they ended up needing a different API than was coded up originally. This swaps over to the API that folks apparently need. Based-on-patch-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Paris <eparis@redhat.com> Tested-by: Chris Richards <gizmo@giz-works.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: stable@kernel.org [2.6.38+]
2011-04-28SELinux: pass last path component in may_createEric Paris
New inodes are created in a two stage process. We first will compute the label on a new inode in security_inode_create() and check if the operation is allowed. We will then actually re-compute that same label and apply it in security_inode_init_security(). The change to do new label calculations based in part on the last component of the path name only passed the path component information all the way down the security_inode_init_security hook. Down the security_inode_create hook the path information did not make it past may_create. Thus the two calculations came up differently and the permissions check might not actually be against the label that is created. Pass and use the same information in both places to harmonize the calculations and checks. Reported-by: Dominick Grift <domg472@gmail.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-28SELinux: introduce path_has_permEric Paris
We currently have inode_has_perm and dentry_has_perm. dentry_has_perm just calls inode_has_perm with additional audit data. But dentry_has_perm can take either a dentry or a path. Split those to make the code obvious and to fix the previous problem where I thought dentry_has_perm always had a valid dentry and mnt. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-28SELinux: put name based create rules in a hashtableEric Paris
To shorten the list we need to run if filename trans rules exist for the type of the given parent directory I put them in a hashtable. Given the policy we are expecting to use in Fedora this takes the worst case list run from about 5,000 entries to 17. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-28SELinux: generic hashtab entry counterEric Paris
Instead of a hashtab entry counter function only useful for range transition rules make a function generic for any hashtable to use. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-28SELinux: calculate and print hashtab stats with a generic functionEric Paris
We have custom debug functions like rangetr_hash_eval and symtab_hash_eval which do the same thing. Just create a generic function that takes the name of the hash table as an argument instead of having custom functions. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-28SELinux: skip filename trans rules if ttype does not match parent dirEric Paris
Right now we walk to filename trans rule list for every inode that is created. First passes at policy using this facility creates around 5000 filename trans rules. Running a list of 5000 entries every time is a bad idea. This patch adds a new ebitmap to policy which has a bit set for each ttype that has at least 1 filename trans rule. Thus when an inode is created we can quickly determine if any rules exist for this parent directory type and can skip the list if we know there is definitely no relevant entry. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-28SELinux: rename filename_compute_type argument to *type instead of *conEric Paris
filename_compute_type() takes as arguments the numeric value of the type of the subject and target. It does not take a context. Thus the names are misleading. Fix the argument names. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-28SELinux: fix comment to state filename_compute_type takes an objname not a qstrEric Paris
filename_compute_type used to take a qstr, but it now takes just a name. Fix the comments to indicate it is an objname, not a qstr. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-25SELINUX: Make selinux cache VFS RCU walks safeEric Paris
Now that the security modules can decide whether they support the dcache RCU walk or not it's possible to make selinux a bit more RCU friendly. The SELinux AVC and security server access decision code is RCU safe. A specific piece of the LSM audit code may not be RCU safe. This patch makes the VFS RCU walk retry if it would hit the non RCU safe chunk of code. It will normally just work under RCU. This is done simply by passing the VFS RCU state as a flag down into the avc_audit() code and returning ECHILD there if it would have an issue. Based-on-patch-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-25LSM: separate LSM_AUDIT_DATA_DENTRY from LSM_AUDIT_DATA_PATHEric Paris
This patch separates and audit message that only contains a dentry from one that contains a full path. This allows us to make it harder to misuse the interfaces or for the interfaces to be implemented wrong. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2011-04-25LSM: split LSM_AUDIT_DATA_FS into _PATH and _INODEEric Paris
The lsm common audit code has wacky contortions making sure which pieces of information are set based on if it was given a path, dentry, or inode. Split this into path and inode to get rid of some of the code complexity. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com>
2011-04-25SECURITY: Move exec_permission RCU checks into security modulesAndi Kleen
Right now all RCU walks fall back to reference walk when CONFIG_SECURITY is enabled, even though just the standard capability module is active. This is because security_inode_exec_permission unconditionally fails RCU walks. Move this decision to the low level security module. This requires passing the RCU flags down the security hook. This way at least the capability module and a few easy cases in selinux/smack work with RCU walks with CONFIG_SECURITY=y Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-25SELinux: security_read_policy should take a size_t not ssize_tEric Paris
The len should be an size_t but is a ssize_t. Easy enough fix to silence build warnings. We have no need for signed-ness. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-25SELinux: silence build warning when !CONFIG_BUGEric Paris
If one builds a kernel without CONFIG_BUG there are a number of 'may be used uninitialized' warnings. Silence these by returning after the BUG(). Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: James Morris <jmorris@namei.org>
2011-04-22SECURITY: Move exec_permission RCU checks into security modulesAndi Kleen
Right now all RCU walks fall back to reference walk when CONFIG_SECURITY is enabled, even though just the standard capability module is active. This is because security_inode_exec_permission unconditionally fails RCU walks. Move this decision to the low level security module. This requires passing the RCU flags down the security hook. This way at least the capability module and a few easy cases in selinux/smack work with RCU walks with CONFIG_SECURITY=y Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-20SELinux: delete debugging printks from filename_trans rule processingEric Paris
The filename_trans rule processing has some printk(KERN_ERR ) messages which were intended as debug aids in creating the code but weren't removed before it was submitted. Remove them. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-07Initialize policydb.process_class eariler.Harry Ciao
Initialize policydb.process_class once all symtabs read from policy image, so that it could be used to setup the role_trans.tclass field when a lower version policy.X is loaded. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-04-07selinux: Fix regression for XorgStephen Smalley
Commit 6f5317e730505d5cbc851c435a2dfe3d5a21d343 introduced a bug in the handling of userspace object classes that is causing breakage for Xorg when XSELinux is enabled. Fix the bug by changing map_class() to return SECCLASS_NULL when the class cannot be mapped to a kernel object class. Reported-by: "Justin P. Mattock" <justinmattock@gmail.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2011-04-01selinux: add type_transition with name extension support for selinuxfsKohei Kaigai
The attached patch allows /selinux/create takes optional 4th argument to support TYPE_TRANSITION with name extension for userspace object managers. If 4th argument is not supplied, it shall perform as existing kernel. In fact, the regression test of SE-PostgreSQL works well on the patched kernel. Thanks, Signed-off-by: KaiGai Kohei <kohei.kaigai@eu.nec.com> [manually verify fuzz was not an issue, and it wasn't: eparis] Signed-off-by: Eric Paris <eparis@redhat.com>
2011-03-29selinux: Fix regression for XorgStephen Smalley
2011-03-28SELinux: Write class field in role_trans_write.Harry Ciao
If kernel policy version is >= 26, then write the class field of the role_trans structure into the binary reprensentation. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-03-28SELinux: Compute role in newcontext for all classesHarry Ciao
Apply role_transition rules for all kinds of classes. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-03-28SELinux: Add class support to the role_trans structureHarry Ciao
If kernel policy version is >= 26, then the binary representation of the role_trans structure supports specifying the class for the current subject or the newly created object. If kernel policy version is < 26, then the class field would be default to the process class. Signed-off-by: Harry Ciao <qingtao.cao@windriver.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: security: make capabilities relative to the user namespaceSerge E. Hallyn
- Introduce ns_capable to test for a capability in a non-default user namespace. - Teach cap_capable to handle capabilities in a non-default user namespace. The motivation is to get to the unprivileged creation of new namespaces. It looks like this gets us 90% of the way there, with only potential uid confusion issues left. I still need to handle getting all caps after creation but otherwise I think I have a good starter patch that achieves all of your goals. Changelog: 11/05/2010: [serge] add apparmor 12/14/2010: [serge] fix capabilities to created user namespaces Without this, if user serge creates a user_ns, he won't have capabilities to the user_ns he created. THis is because we were first checking whether his effective caps had the caps he needed and returning -EPERM if not, and THEN checking whether he was the creator. Reverse those checks. 12/16/2010: [serge] security_real_capable needs ns argument in !security case 01/11/2011: [serge] add task_ns_capable helper 01/11/2011: [serge] add nsown_capable() helper per Bastian Blank suggestion 02/16/2011: [serge] fix a logic bug: the root user is always creator of init_user_ns, but should not always have capabilities to it! Fix the check in cap_capable(). 02/21/2011: Add the required user_ns parameter to security_capable, fixing a compile failure. 02/23/2011: Convert some macros to functions as per akpm comments. Some couldn't be converted because we can't easily forward-declare them (they are inline if !SECURITY, extern if SECURITY). Add a current_user_ns function so we can use it in capability.h without #including cred.h. Move all forward declarations together to the top of the #ifdef __KERNEL__ section, and use kernel-doc format. 02/23/2011: Per dhowells, clean up comment in cap_capable(). 02/23/2011: Per akpm, remove unreachable 'return -EPERM' in cap_capable. (Original written and signed off by Eric; latest, modified version acked by him) [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: export current_user_ns() for ecryptfs] [serge.hallyn@canonical.com: remove unneeded extra argument in selinux's task_has_capability] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
