path: root/security/selinux
2007-06-08[NetLabel]: consolidate the struct socket/sock handling to just struct sockPaul Moore
The current NetLabel code has some redundant APIs which allow both "struct socket" and "struct sock" types to be used; this may have made sense at some point but it is wasteful now. Remove the functions that operate on sockets and convert the callers. Not only does this make the code smaller and more consistent but it pushes the locking burden up to the caller which can be more intelligent about the locks. Also, perform the same conversion (socket to sock) on the SELinux/NetLabel glue code where it make sense. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08tty: introduce no_tty and use it in selinuxEric W. Biederman
While researching the tty layer pid leaks I found a weird case in selinux when we drop a controlling tty because of inadequate permissions we don't do the normal hangup processing. Which is a problem if it happens the session leader has exec'd something that can no longer access the tty. We already have code in the kernel to handle this case in the form of the TIOCNOTTY ioctl. So this patch factors out a helper function that is the essence of that ioctl and calls it from the selinux code. This removes the inconsistency in handling dropping of a controlling tty and who knows it might even make some part of user space happy because it received a SIGHUP it was expecting. In addition since this removes the last user of proc_set_tty outside of tty_io.c proc_set_tty is made static and removed from tty.h Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: selinux: preserve boolean values across policy reloads selinux: change numbering of boolean directory inodes in selinuxfs selinux: remove unused enumeration constant from selinuxfs selinux: explicitly number all selinuxfs inodes selinux: export initial SID contexts via selinuxfs selinux: remove userland security class and permission definitions SELinux: move security_skb_extlbl_sid() out of the security server MAINTAINERS: update selinux entry SELinux: rename selinux_netlabel.h to netlabel.h SELinux: extract the NetLabel SELinux support from the security server NetLabel: convert a BUG_ON in the CIPSO code to a runtime check NetLabel: cleanup and document CIPSO constants
2007-04-26selinux: preserve boolean values across policy reloadsStephen Smalley
At present, the userland policy loading code has to go through contortions to preserve boolean values across policy reloads, and cannot do so atomically. As this is what we always want to do for reloads, let the kernel preserve them instead. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Karl MacMillan <kmacmillan@mentalrootkit.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26selinux: change numbering of boolean directory inodes in selinuxfsJames Carter
Change the numbering of the booleans directory inodes in selinuxfs to provide more room for new inodes without a conflict in inode numbers and to be consistent with how inode numbering is done in the initial_contexts directory. Signed-off-by: James Carter <jwcart2@tycho.nsa.gov> Acked-by: Eric Paris <eparis@parisplace.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26selinux: remove unused enumeration constant from selinuxfsJames Carter
Remove the unused enumeration constant, SEL_AVC, from the sel_inos enumeration in selinuxfs. Signed-off-by: James Carter <jwcart2@tycho.nsa.gov> Acked-by: Eric Paris <eparis@parisplace.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26selinux: explicitly number all selinuxfs inodesJames Carter
Explicitly number all selinuxfs inodes to prevent a conflict between inodes numbered using last_ino when created with new_inode() and those labeled explicitly. Signed-off-by: James Carter <jwcart2@tycho.nsa.gov> Acked-by: Eric Paris <eparis@parisplace.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26selinux: export initial SID contexts via selinuxfsJames Carter
Make the initial SID contexts accessible to userspace via selinuxfs. An initial use of this support will be to make the unlabeled context available to libselinux for use for invalidated userspace SIDs. Signed-off-by: James Carter <jwcart2@tycho.nsa.gov> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26selinux: remove userland security class and permission definitionsStephen Smalley
Remove userland security class and permission definitions from the kernel as the kernel only needs to use and validate its own class and permission definitions and userland definitions may change. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26SELinux: move security_skb_extlbl_sid() out of the security serverPaul Moore
As suggested, move the security_skb_extlbl_sid() function out of the security server and into the SELinux hooks file. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26SELinux: rename selinux_netlabel.h to netlabel.hPaul Moore
In the beginning I named the file selinux_netlabel.h to avoid potential namespace colisions. However, over time I have realized that there are several other similar cases of multiple header files with the same name so I'm changing the name to something which better fits with existing naming conventions. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-26SELinux: extract the NetLabel SELinux support from the security serverPaul Moore
Up until this patch the functions which have provided NetLabel support to SELinux have been integrated into the SELinux security server, which for various reasons is not really ideal. This patch makes an effort to extract as much of the NetLabel support from the security server as possibile and move it into it's own file within the SELinux directory structure. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Introduce nlmsg_hdr() helperArnaldo Carvalho de Melo
For the common "(struct nlmsghdr *)skb->data" sequence, so that we reduce the number of direct accesses to skb->data and for consistency with all the other cast skb member helpers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-14[PATCH] sanitize security_getprocattr() APIAl Viro
have it return the buffer it had allocated Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26Always initialize scontext and scontext_lenStephen Smalley
Always initialize *scontext and *scontext_len in security_sid_to_context. (via http://lkml.org/lkml/2007/2/23/135) Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-02-26Reassign printk levels in selinux kernel codeEric Paris
Below is a patch which demotes many printk lines to KERN_DEBUG from KERN_INFO. It should help stop the spamming of logs with messages in which users are not interested nor is there any action that users should take. It also promotes some KERN_INFO to KERN_ERR such as when there are improper attempts to register/unregister security modules. A similar patch was discussed a while back on list: http://marc.theaimsgroup.com/?t=116656343500003&r=1&w=2 This patch addresses almost all of the issues raised. I believe the only advice not taken was in the demoting of messages related to undefined permissions and classes. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> security/selinux/hooks.c | 20 ++++++++++---------- security/selinux/ss/avtab.c | 2 +- security/selinux/ss/policydb.c | 6 +++--- security/selinux/ss/sidtab.c | 2 +- 4 files changed, 15 insertions(+), 15 deletions(-) Signed-off-by: James Morris <jmorris@namei.org>
2007-02-14[PATCH] selinux: enhance selinux to always ignore private inodesStephen Smalley
Hmmm...turns out to not be quite enough, as the /proc/sys inodes aren't truly private to the fs, so we can run into them in a variety of security hooks beyond just the inode hooks, such as security_file_permission (when reading and writing them via the vfs helpers), security_sb_mount (when mounting other filesystems on directories in proc like binfmt_misc), and deeper within the security module itself (as in flush_unauthorized_files upon inheritance across execve). So I think we have to add an IS_PRIVATE() guard within SELinux, as below. Note however that the use of the private flag here could be confusing, as these inodes are _not_ private to the fs, are exposed to userspace, and security modules must implement the sysctl hook to get any access control over them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: fix the selinux_sysctl_get_sidEric W. Biederman
I goofed and when reenabling the fine grained selinux labels for sysctls and forgot to add the "/sys" prefix before consulting the policy database. When computing the same path using proc_dir_entries we got the "/sys" for free as it was part of the tree, but it isn't true for clt_table trees. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove the proc_dir_entry member for the sysctl tablesEric W. Biederman
It isn't needed anymore, all of the users are gone, and all of the ctl_table initializers have been converted to use explicit names of the fields they are initializing. [akpm@osdl.org: NTFS fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 9Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Replace regular code with appropriate calls to container_of()Robert P. J. Day
Replace a small number of expressions with a call to the "container_of()" macro. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[SELINUX]: Fix 2.6.20-rc6 build when no xfrmVenkat Yekkirala
This patch is an incremental fix to the flow_cache_genid patch for selinux that breaks the build of 2.6.20-rc6 when xfrm is not configured. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-23[SELINUX]: increment flow cache genidVenkat Yekkirala
Currently, old flow cache entries remain valid even after a reload of SELinux policy. This patch increments the flow cache generation id on policy (re)loads so that flow cache entries are revalidated as needed. Thanks to Herbet Xu for pointing this out. See: http://marc.theaimsgroup.com/?l=linux-netdev&m=116841378704536&w=2 There's also a general issue as well as a solution proposed by David Miller for when flow_cache_genid wraps. I might be submitting a separate patch for that later. I request that this be applied to 2.6.20 since it's a security relevant fix. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-09NetLabel: correct locking in selinux_netlbl_socket_setsid()Paul Moore
The spinlock protecting the update of the "sksec->nlbl_state" variable is not currently softirq safe which can lead to problems. This patch fixes this by changing the spin_{un}lock() functions into spin_{un}lock_bh() functions. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-01-08selinux: Delete mls_copy_contextVenkat Yekkirala
This deletes mls_copy_context() in favor of mls_context_cpy() and replaces mls_scopy_context() with mls_context_cpy_low(). Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2007-01-02[PATCH] selinux: fix selinux_netlbl_inode_permission() lockingParag Warudkar
do not call a sleeping lock API in an RCU read section. lock_sock_nested can sleep, its BH counterpart doesn't. selinux_netlbl_inode_permission() needs to use the BH counterpart unconditionally. Compile tested. From: Ingo Molnar <mingo@elte.hu> added BH disabling, because this function can be called from non-atomic contexts too, so a naked bh_lock_sock() would be deadlock-prone. Boot-tested the resulting kernel. Signed-off-by: Parag Warudkar <paragw@paragw.zapto.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert selinuxJosef Sipek
2006-12-08[PATCH] tty: ->signal->tty lockingPeter Zijlstra
Fix the locking of signal->tty. Use ->sighand->siglock to protect ->signal->tty; this lock is already used by most other members of ->signal/->sighand. And unless we are 'current' or the tasklist_lock is held we need ->siglock to access ->signal anyway. (NOTE: sys_unshare() is broken wrt ->sighand locking rules) Note that tty_mutex is held over tty destruction, so while holding tty_mutex any tty pointer remains valid. Otherwise the lifetime of ttys are governed by their open file handles. This leaves some holes for tty access from signal->tty (or any other non file related tty access). It solves the tty SLAB scribbles we were seeing. (NOTE: the change from group_send_sig_info to __group_send_sig_info needs to be examined by someone familiar with the security framework, I think it is safe given the SEND_SIG_PRIV from other __group_send_sig_info invocations) [schwidefsky@de.ibm.com: 3270 fix] [akpm@osdl.org: various post-viro fixes] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Alan Cox <alan@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] selinux endianness annotationsAl Viro
2006-12-02Rename class_destroy to avoid namespace conflicts.James Morris
We're seeing increasing namespace conflicts between the global class_destroy() function declared in linux/device.h, and the private function in the SELinux core code. This patch renames the SELinux function to cls_destroy() to avoid this conflict. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: convert to an extensibile/sparse category bitmapPaul Moore
The original NetLabel category bitmap was a straight char bitmap which worked fine for the initial release as it only supported 240 bits due to limitations in the CIPSO restricted bitmap tag (tag type 0x01). This patch converts that straight char bitmap into an extensibile/sparse bitmap in order to lay the foundation for other CIPSO tag types and protocols. This patch also has a nice side effect in that all of the security attributes passed by NetLabel into the LSM are now in a format which is in the host's native byte/bit ordering which makes the LSM specific code much simpler; look at the changes in security/selinux/ss/ebitmap.c as an example. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02Compile fix for "peer secid consolidation for external network labeling"James Morris
Use a forward declaration instead of dragging in skbuff.h and related junk. Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: peer secid consolidation for external network labelingPaul Moore
Now that labeled IPsec makes use of the peer_sid field in the sk_security_struct we can remove a lot of the special cases between labeled IPsec and NetLabel. In addition, create a new function, security_skb_extlbl_sid(), which we can use in several places to get the security context of the packet's external label which allows us to further simplify the code in a few places. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: SELinux cleanupsPaul Moore
This patch does a lot of cleanup in the SELinux NetLabel support code. A summary of the changes include: * Use RCU locking for the NetLabel state variable in the skk_security_struct instead of using the inode_security_struct mutex. * Remove unnecessary parameters in selinux_netlbl_socket_post_create(). * Rename selinux_netlbl_sk_clone_security() to selinux_netlbl_sk_security_clone() to better fit the other NetLabel sk_security functions. * Improvements to selinux_netlbl_inode_permission() to help reduce the cost of the common case. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: make netlbl_lsm_secattr struct easier/quicker to understandPaul Moore
The existing netlbl_lsm_secattr struct required the LSM to check all of the fields to determine if any security attributes were present resulting in a lot of work in the common case of no attributes. This patch adds a 'flags' field which is used to indicate which attributes are present in the structure; this should allow the LSM to do a quick comparison to determine if the structure holds any security attributes. Example: if (netlbl_lsm_secattr->flags) /* security attributes present */ else /* NO security attributes present */ Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[IPv6] prefix: Convert RTM_NEWPREFIX notifications to use the new netlink apiThomas Graf
RTM_GETPREFIX is completely unused and is thus removed. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SELinux]: Add support for DCCPJames Morris
This patch implements SELinux kernel support for DCCP (http://linux-net.osdl.org/index.php/DCCP), which is similar in operation to TCP in terms of connected state between peers. The SELinux support for DCCP is thus modeled on existing handling of TCP. A new DCCP socket class is introduced, to allow protocol differentation. The permissions for this class inherit all of the socket permissions, as well as the current TCP permissions (node_bind, name_bind etc). IPv4 and IPv6 are supported, although labeled networking is not, at this stage. Patches for SELinux userspace are at: http://people.redhat.com/jmorris/selinux/dccp/user/ I've performed some basic testing, and it seems to be working as expected. Adding policy support is similar to TCP, the only real difference being that it's a different protocol. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02SELinux: Fix SA selection semanticsVenkat Yekkirala
Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. This eliminates the SELinux policy's ability to use/sendto SAs with contexts other than the socket's. With this patch applied, the SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
