The original code returns a freed pointer. This function is expected to
return NULL on errors.
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: James Morris <jmorris@namei.org>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
passing *any* namespace root to __d_path() as root is equivalent
to just passing it {NULL, NULL}; no need to bother with finding
the root of our namespace in there.
Variable "atmark" is currently unused.
Holding tasklist_lock is no longer sufficient for find_task_by_vpid().
Explicit rcu_read_lock() is required.
security/tomoyo/common.c | 4 ++++
1 file changed, 4 insertions(+)
__func__ is used for only debug printk(). We can remove it.
tomoyo_path_perm() tomoyo_path2_perm() and tomoyo_check_rewrite_permission()
always receive tomoyo_domain(). We can move it from caller to callee.
Use shorter name to reduce newlines needed for 80 columns limit.
Use enum to declare index numbers.
This patch adds garbage collector support to TOMOYO.
Elements are protected by "struct srcu_struct tomoyo_ss".
Acked-by: Serge Hallyn <serue@us.ibm.com>
Add refcounter to "struct tomoyo_domain_info" since garbage collector needs to
determine whether this struct is referred by "struct cred"->security or not.
Gather structures and constants scattered around security/tomoyo/ directory.
This is for preparation for adding garbage collector since garbage collector
needs to know structures and constants which TOMOYO uses.
Add refcounter to "struct tomoyo_name_entry" and replace tomoyo_save_name()
with tomoyo_get_name()/tomoyo_put_name() pair so that we can kfree() when
garbage collector is added.
Since the codes for adding an entry and removing an entry are similar, we can
save some lines by using "if (is_delete) { ... } else { ... }" branches.
Since list elements are rounded up to kmalloc() size rather than sizeof(int),
saving one byte by using bitfields is no longer helpful.
TOMOYO was using own memory usage counter for detecting memory leak.
But as kernel 2.6.31 introduced memory leak detection mechanism
( CONFIG_DEBUG_KMEMLEAK ), we no longer need to have own counter.
We remove usage counter for memory used for permission checks, but we keep
usage counter for memory used for policy so that we can apply quota.
commit 5300990c0370e804e49d9a59d928c5d53fb73487 had stepped on a rather
nasty mess: definitions of ACC_MODE used to be different. Fixed the
resulting breakage, converting them to variant that takes O_... value;
all callers have that and it actually simplifies life (see tomoyo part
of changes).
Currently, TOMOYO allocates memory for list elements from memory pool allocated
by kmalloc(PAGE_SIZE). But that makes it difficult to kfree() when garbage
collector is added. Thus, remove memory pool and use kmalloc(sizeof()).
Currently, TOMOYO allocates memory for string data from memory pool allocated
collector is added. Thus, remove memory pool and use kmalloc(strlen()).
Since readers no longer use down_read(), writers no longer
need to use rw_semaphore. Replace individual rw_semaphore by
single mutex.
* pull ACC_MODE to fs.h; we have several copies all over the place
* nightmarish expression calculating f_mode by f_flags deserves a helper
too (OPEN_FMODE(flags))
Replace list operation with RCU primitives and replace
down_read()/up_read() with srcu_read_lock()/srcu_read_unlock().
Please apply below one after merging 1557d33007f63dd96e5d15f33af389378e5f2e54
(Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6).
[PATCH for 2.6.33] TOMOYO: Compare filesystem by magic number rather than by name.
We can use magic number for checking whether the filesystem is procfs or not.
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
LSM hooks for chmod()/chown()/chroot() are now ready.
This patch utilizes these hooks.
TOMOYO 1.7.1 has recursive directory matching operator support.
I want to add it to TOMOYO for Linux 2.6.33 .
[PATCH] TOMOYO: Add recursive directory matching operator support.
This patch introduces new operator /\{dir\}/ which matches
'/' + 'One or more repetitions of dir/' (e.g. /dir/ /dir/dir/ /dir/dir/dir/ ).
Acked-by: John Johansen <john.johansen@canonical.com>
Now that sys_sysctl is an emulation on top of proc sys all sysctl
operations look like normal filesystem operations and we don't need
to use the special sysctl hook to authenticate them.
proc mount.
With the change of sys_sysctl going through the internal proc mount we no
longer need to handle security_sysctl in tomoyo as we have valid pathnames
for all sysctl accesses. There is one slight caveat to that in that
all of the paths from the internal mount look like
"/sys/net/ipv4/ip_local_port_range" instead of
"/proc/sys/net/ipv4/ip_local_port_range" so tomoyo needs to add the
"/proc" portion manually when resolving to full path names to get what it expects.
This change teaches tomoyo perform that modification.
ctl_name field was removed. Always use procname field.
When examining the network device name hash, it was discovered that
the low order bits of full_name_hash() are not very well dispersed
across the possible values. When used by filesystem code, this is handled
by folding with the function hash_long().
The only other non-filesystem usage of full_name_hash() at this time
appears to be in TOMOYO. This patch should fix that.
I do not use TOMOYO at this time, so this patch is build tested only.
Add a keyctl to install a process's session keyring onto its parent. This
replaces the parent's session keyring. Because the COW credential code does
not permit one process to change another process's credentials directly, the
change is deferred until userspace next starts executing again. Normally this
will be after a wait*() syscall.
To support this, three new security hooks have been provided:
cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in
the blank security creds and key_session_to_parent() - which asks the LSM if
the process may replace its parent's session keyring.
The replacement may only happen if the process has the same ownership details
as its parent, and the process has LINK permission on the session keyring, and
the session keyring is owned by the process, and the LSM permits it.
Note that this requires alteration to each architecture's notify_resume path.
This has been done for all arches barring blackfin, m68k* and xtensa, all of
which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the
replacement to be performed at the point the parent process resumes userspace
execution.
This allows the userspace AFS pioctl emulation to fully emulate newpag() and
the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to
alter the parent process's PAG membership. However, since kAFS doesn't use
PAGs per se, but rather dumps the keys into the session keyring, the session
keyring of the parent must be replaced if, for example, VIOCSETTOK is passed
the newpag flag.
This can be tested with the following program:
#include <stdio.h>
#include <stdlib.h>
#include <keyutils.h>
#define KEYCTL_SESSION_TO_PARENT 18
#define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0)
int main(int argc, char **argv)
key_serial_t keyring, key;
long ret;
keyring = keyctl_join_session_keyring(argv[1]);
OSERROR(keyring, "keyctl_join_session_keyring");
key = add_key("user", "a", "b", 1, keyring);
OSERROR(key, "add_key");
ret = keyctl(KEYCTL_SESSION_TO_PARENT);
OSERROR(ret, "KEYCTL_SESSION_TO_PARENT");
return 0;
Compiled and linked with -lkeyutils, you should see something like:
[dhowells@andromeda ~]$ keyctl show
Session Keyring
-3 --alswrv 4043 4043 keyring: _ses
355907932 --alswrv 4043 -1 \_ keyring: _uid.4043
[dhowells@andromeda ~]$ /tmp/newpag
Session Keyring
1055658746 --alswrv 4043 4043 \_ user: a
[dhowells@andromeda ~]$ /tmp/newpag hello
Session Keyring
-3 --alswrv 4043 4043 keyring: hello
340417692 --alswrv 4043 4043 \_ user: a
Where the test program creates a new session keyring, sticks a user key named
'a' into it and then installs it on its parent.
We can update bprm->cred->security inside tomoyo_find_next_domain().
We can mark tomoyo_delete_domain() as a "static" function
by moving it from domain.c to common.c .
This patch adds some descriptions of lists and structures.
This patch contains no code changes.
TOMOYO 2.2.0 is not using total_len field of "struct tomoyo_path_info".
TOMOYO 2.2.0 does not check argv[] and envp[] upon execve().
We don't need to pass "struct tomoyo_page_buffer".
We can directly assign the result of tomoyo_io_printf() to done flag.
Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp>
Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp>
Remove '/***** START/STOP *****/' markers.
I forgot to remove on TOMOYO's 15th posting.
Use task_cred_xxx(task, security) in tomoyo_real_domain() to
avoid a get+put of the target cred.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
cap_bprm_set_creds() has to be called from security_bprm_set_creds().
TOMOYO forgot to call cap_bprm_set_creds() from tomoyo_bprm_set_creds()
and suid executables were not being working.
Make sure we call cap_bprm_set_creds() with TOMOYO, to set credentials
properly inside tomoyo_bprm_set_creds().
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
... use kern_path() where possible
[folded a fix from rdd]
Since TOMOYO's policy management tools does not use the "undelete domain"
command, we decided to remove that command.
