This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION.
Now that the required bits have been addressed, reenable
PARAVIRT.
We fail to see what CONFIG_KAISER_REAL_SWITCH is for: it seems to be
left over from early development, and now just obscures tricky parts
of the code. Delete it before adding PCIDs, or nokaiser boot option.
(Or if there is some good reason to keep the option, then it needs
a help text - and a "depends on KAISER", so that all those without
KAISER are not asked the question. But we'd much rather delete it.)
It is absurd that KAISER should depend on SMP, but apparently nobody
has tried a UP build before: which breaks on implicit declaration of
function 'per_cpu_offset' in arch/x86/mm/kaiser.c.
Now, you would expect that to be trivially fixed up; but looking at
the System.map when that block is #ifdef'ed out of kaiser_init(),
I see that in a UP build __per_cpu_user_mapped_end is precisely at
__per_cpu_user_mapped_start, and the items carefully gathered into
that section for user-mapping on SMP, dispersed elsewhere on UP.
So, some other kind of section assignment will be needed on UP,
but implementing that is not a priority: just make KAISER depend
on SMP for now.
Also inserted a blank line before the option, tidied up the
brief Kconfig help message, and added an "If unsure, Y".
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging).
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 4dca6ea1d9432052afb06baf2e3ae78188a4410b upstream.
When the request_key() syscall is not passed a destination keyring, it
links the requested key (if constructed) into the "default" request-key
keyring. This should require Write permission to the keyring. However,
there is actually no permission check.
This can be abused to add keys to any keyring to which only Search
permission is granted. This is because Search permission allows joining
the keyring. keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_SESSION_KEYRING)
then will set the default request-key keyring to the session keyring.
Then, request_key() can be used to add keys to the keyring.
Both negatively and positively instantiated keys can be added using this
method. Adding negative keys is trivial. Adding a positive key is a
bit trickier. It requires that either /sbin/request-key positively
instantiates the key, or that another thread adds the key to the process
keyring at just the right time, such that request_key() misses it
initially but then finds it in construct_alloc_key().
Fix this bug by checking for Write permission to the keyring in
construct_get_dest_keyring() when the default keyring is being used.
We don't do the permission check for non-default keyrings because that
was already done by the earlier call to lookup_user_key(). Also,
request_key_and_link() is currently passed a 'struct key *' rather than
a key_ref_t, so the "possessed" bit is unavailable.
We also don't do the permission check for the "requestor keyring", to
continue to support the use case described by commit 8bbf4976b59f
("KEYS: Alter use of key instantiation link-to-keyring argument") where
/sbin/request-key recursively calls request_key() to add keys to the
original requestor's destination keyring. (I don't know of any users
who actually do that, though...)
Fixes: 3e30148c3d52 ("[PATCH] Keys: Make request-key create an authorisation key")
[ Upstream commit ebe7c0a7be92bbd34c6ff5b55810546a0ee05bee ]
The hash_setup function always sets the hash_setup_done flag, even
when the hash algorithm is invalid. This prevents the default hash
algorithm defined as CONFIG_IMA_DEFAULT_HASH from being used.
This patch sets hash_setup_done flag only for valid hash algorithms.
Fixes: e7a2ad7eb6f4 "ima: enable support for larger default filedata hash algorithms"
Signed-off-by: Boshi Wang <wangboshi@huawei.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 020aae3ee58c1af0e7ffc4e2cc9fe4dc630338cb upstream.
Commit b65a9cfc2c38 ("Untangling ima mess, part 2: deal with counters")
moved the call of ima_file_check() from may_open() to do_filp_open() at a
point where the file descriptor is already opened.
This breaks the assumption made by IMA that file descriptors being closed
belong to files whose access was granted by ima_file_check(). The
consequence is that security.ima and security.evm are updated with good
values, regardless of the current appraisal status.
For example, if a file does not have security.ima, IMA will create it after
opening the file for writing, even if access is denied. Access to the file
will be allowed afterwards.
Avoid this issue by checking the appraisal status before updating
security.ima.
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 47b2c3fff4932e6fc17ce13d51a43c6969714e20 upstream.
CONFIG_KEYS_COMPAT is defined in arch-specific Kconfigs and is missing for
several 64-bit architectures : mips, parisc, tile.
At the moment and for those architectures, calling in 32-bit userspace the
keyctl syscall would return an ENOSYS error.
This patch moves the CONFIG_KEYS_COMPAT option to security/keys/Kconfig, to
make sure the compatibility wrapper is registered by default for any 64-bit
architecture as long as it is configured with CONFIG_COMPAT.
[DH: Modified to remove arm64 compat enablement also as requested by Eric
Biggers]
Signed-off-by: Bilal Amarni <bilal.amarni@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
cc: Eric Biggers <ebiggers3@gmail.com>
Cc: James Cowgill <james.cowgill@mips.com>
commit a3c812f7cfd80cf51e8f5b7034f7418f6beb56c1 upstream.
When calling keyctl_read() on a key of type "trusted", if the
user-supplied buffer was too small, the kernel ignored the buffer length
and just wrote past the end of the buffer, potentially corrupting
userspace memory. Fix it by instead returning the size required, as per
the documentation for keyctl_read().
We also don't even fill the buffer at all in this case, as this is
slightly easier to implement than doing a short read, and either
behavior appears to be permitted. It also makes it match the behavior
of the "encrypted" key type.
Fixes: d00a1c72f7f4 ("keys: add new trusted key-type")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Reviewed-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Reviewed-by: James Morris <james.l.morris@oracle.com>
commit ee618b4619b72527aaed765f0f0b74072b281159 upstream.
As the previous patch did for encrypted-keys, zero sensitive any
potentially sensitive data related to the "trusted" key type before it
is freed. Notably, we were not zeroing the tpm_buf structures in which
the actual key is stored for TPM seal and unseal, nor were we zeroing
the trusted_key_payload in certain error paths.
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: David Safford <safford@us.ibm.com>
[ Upstream commit 3ccb76c5dfe0d25c1d0168d5b726d0b43d19a485 ]
The kernel build bot turned up a bad config combination when
CONFIG_SECURITY_APPARMOR is y and CONFIG_SECURITY_APPARMOR_HASH is n,
resulting in the build error
security/built-in.o: In function `aa_unpack':
(.text+0x841e2): undefined reference to `aa_g_hash_policy'
Signed-off-by: John Johansen <john.johansen@canonical.com>
commit 3239b6f29bdfb4b0a2ba59df995fc9e6f4df7f1f upstream.
Commit e645016abc80 ("KEYS: fix writing past end of user-supplied buffer
in keyring_read()") made keyring_read() stop corrupting userspace memory
when the user-supplied buffer is too small. However it also made the
return value in that case be the short buffer size rather than the size
required, yet keyctl_read() is actually documented to return the size
required. Therefore, switch it over to the documented behavior.
Note that for now we continue to have it fill the short buffer, since it
did that before (pre-v3.13) and dump_key_tree_aux() in keyutils arguably
relies on it.
Fixes: e645016abc80 ("KEYS: fix writing past end of user-supplied buffer in keyring_read()")
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream.
Currently, when passed a key that already exists, add_key() will call the
key's ->update() method if such exists. But this is heavily broken in the
case where the key is uninstantiated because it doesn't call
__key_instantiate_and_link(). Consequently, it doesn't do most of the
things that are supposed to happen when the key is instantiated, such as
setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and
awakening tasks waiting on it, and incrementing key->user->nikeys.
It also never takes key_construction_mutex, which means that
->instantiate() can run concurrently with ->update() on the same key. In
the case of the "user" and "logon" key types this causes a memory leak, at
best. Maybe even worse, the ->update() methods of the "encrypted" and
"trusted" key types actually just dereference a NULL pointer when passed an
uninstantiated key.
Change key_create_or_update() to wait interruptibly for the key to finish
construction before continuing.
This patch only affects *uninstantiated* keys. For now we still allow a
negatively instantiated key to be updated (thereby positively
instantiating it), although that's broken too (the next patch fixes it)
and I'm not sure that anyone actually uses that functionality either.
Here is a simple reproducer for the bug using the "encrypted" key type
(requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug
pertained to more than just the "encrypted" key type:
#include <stdlib.h>
#include <unistd.h>
#include <keyutils.h>
int main(void)
int ringid = keyctl_join_session_keyring(NULL);
if (fork()) {
for (;;) {
const char payload[] = "update user:foo 32";
usleep(rand() % 10000);
add_key("encrypted", "desc", payload, sizeof(payload), ringid);
keyctl_clear(ringid);
} else {
for (;;)
request_key("encrypted", "desc", "callout_info", ringid);
It causes:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: encrypted_update+0xb0/0x170
PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0
PREEMPT SMP
CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
task: ffff8a467a39a340 task.stack: ffffb15c40770000
RIP: 0010:encrypted_update+0xb0/0x170
RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000
RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303
RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17
R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f
FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000
CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0
Call Trace:
key_create_or_update+0x2bc/0x460
SyS_add_key+0x10c/0x1d0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x7f5d7f211259
RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8
RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259
RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04
RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004
R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868
R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000
Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b
RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8
cc: Eric Biggers <ebiggers@google.com>
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream.
A key of type "encrypted" references a "master key" which is used to
encrypt and decrypt the encrypted key's payload. However, when we
accessed the master key's payload, we failed to handle the case where
the master key has been revoked, which sets the payload pointer to NULL.
Note that request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
This was an issue for master keys of type "user" only. Master keys can
also be of type "trusted", but those cannot be revoked.
Fixes: 7e70cb497850 ("keys: add new key-type encrypted")
commit 57e7ba04d422c3d41c8426380303ec9b7533ded9 upstream.
security_inode_getsecurity() provides the text string value
of a security attribute. It does not provide a "secctx".
The code in xattr_getsecurity() that calls security_inode_getsecurity()
and then calls security_release_secctx() happened to work because
SElinux and Smack treat the attribute and the secctx the same way.
It fails for cap_inode_getsecurity(), because that module has no
secctx that ever needs releasing. It turns out that Smack is the
one that's doing things wrong by not allocating memory when instructed
to do so by the "alloc" parameter.
The fix is simple enough. Change the security_release_secctx() to
kfree() because it isn't a secctx being returned by
security_inode_getsecurity(). Change Smack to allocate the string when
told to do so.
Note: this also fixes memory leaks for LSMs which implement
inode_getsecurity but not release_secctx, such as capabilities.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
commit 37863c43b2c6464f252862bf2e9768264e961678 upstream.
Because keyctl_read_key() looks up the key with no permissions
requested, it may find a negatively instantiated key. If the key is
also possessed, we went ahead and called ->read() on the key. But the
key payload will actually contain the ->reject_error rather than the
normal payload. Thus, the kernel oopses trying to read the
user_key_payload from memory address (int)-ENOKEY = 0x00000000ffffff82.
Fortunately the payload data is stored inline, so it shouldn't be
possible to abuse this as an arbitrary memory read primitive...
Reproducer:
keyctl new_session
keyctl request2 user desc '' @s
keyctl read $(keyctl show | awk '/user: desc/ {print $1}')
It causes a crash like the following:
BUG: unable to handle kernel paging request at 00000000ffffff92
IP: user_read+0x33/0xa0
PGD 36a54067 P4D 36a54067 PUD 0
Oops: 0000 [#1] SMP
CPU: 0 PID: 211 Comm: keyctl Not tainted 4.14.0-rc1 #337
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
task: ffff90aa3b74c3c0 task.stack: ffff9878c0478000
RIP: 0010:user_read+0x33/0xa0
RSP: 0018:ffff9878c047bee8 EFLAGS: 00010246
RAX: 0000000000000001 RBX: ffff90aa3d7da340 RCX: 0000000000000017
RDX: 0000000000000000 RSI: 00000000ffffff82 RDI: ffff90aa3d7da340
RBP: ffff9878c047bf00 R08: 00000024f95da94f R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f58ece69740(0000) GS:ffff90aa3e200000(0000) knlGS:0000000000000000
CR2: 00000000ffffff92 CR3: 0000000036adc001 CR4: 00000000003606f0
Call Trace:
keyctl_read_key+0xac/0xe0
SyS_keyctl+0x99/0x120
RIP: 0033:0x7f58ec787bb9
RSP: 002b:00007ffc8d401678 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 00007ffc8d402800 RCX: 00007f58ec787bb9
RDX: 0000000000000000 RSI: 00000000174a63ac RDI: 000000000000000b
RBP: 0000000000000004 R08: 00007ffc8d402809 R09: 0000000000000020
R10: 0000000000000000 R11: 0000000000000206 R12: 00007ffc8d402800
R13: 00007ffc8d4016e0 R14: 0000000000000000 R15: 0000000000000000
Code: e5 41 55 49 89 f5 41 54 49 89 d4 53 48 89 fb e8 a4 b4 ad ff 85 c0 74 09 80 3d b9 4c 96 00 00 74 43 48 8b b3 20 01 00 00 4d 85 ed <0f> b7 5e 10 74 29 4d 85 e4 74 24 4c 39 e3 4c 89 e2 4c 89 ef 48
RIP: user_read+0x33/0xa0 RSP: ffff9878c047bee8
Fixes: 61ea0c0ba904 ("KEYS: Skip key state checks when checking for possession")
commit 237bbd29f7a049d310d907f4b2716a7feef9abf3 upstream.
It was possible for an unprivileged user to create the user and user
session keyrings for another user. For example:
sudo -u '#3000' sh -c 'keyctl add keyring _uid.4000 "" @u
keyctl add keyring _uid_ses.4000 "" @u
sleep 15' &
sleep 1
sudo -u '#4000' keyctl describe @u
sudo -u '#4000' keyctl describe @us
This is problematic because these "fake" keyrings won't have the right
permissions. In particular, the user who created them first will own
them and will have full access to them via the possessor permissions,
which can be used to compromise the security of a user's keys:
-4: alswrv-----v------------ 3000 0 keyring: _uid.4000
-5: alswrv-----v------------ 3000 0 keyring: _uid_ses.4000
Fix it by marking user and user session keyrings with a flag
KEY_FLAG_UID_KEYRING. Then, when searching for a user or user session
keyring by name, skip all keyrings that don't have the flag set.
Fixes: 69664cf16af4 ("keys: don't generate user and user session keyrings unless they're accessed")
commit e645016abc803dafc75e4b8f6e4118f088900ffb upstream.
Userspace can call keyctl_read() on a keyring to get the list of IDs of
keys in the keyring. But if the user-supplied buffer is too small, the
kernel would write the full list anyway --- which will corrupt whatever
userspace memory happened to be past the end of the buffer. Fix it by
only filling the space that is available.
Fixes: b2a4df200d57 ("KEYS: Expand the capacity of a keyring")
commit 428490e38b2e352812e0b765d8bceafab0ec441d upstream.
This started out as just replacing the use of crypto/rng with
get_random_bytes_wait, so that we wouldn't use bad randomness at boot
time. But, upon looking further, it appears that there were even deeper
underlying cryptographic problems, and that this seems to have been
committed with very little crypto review. So, I rewrote the whole thing,
trying to keep to the conventions introduced by the previous author, to
fix these cryptographic flaws.
It makes no sense to seed crypto/rng at boot time and then keep
using it like this, when in fact there's already get_random_bytes_wait,
which can ensure there's enough entropy and be a much more standard way
of generating keys. Since this sensitive material is being stored
untrusted, using ECB and no authentication is simply not okay at all. I
find it surprising and a bit horrifying that this code even made it past
basic crypto review, which perhaps points to some larger issues. This
patch moves from using AES-ECB to using AES-GCM. Since keys are uniquely
generated each time, we can set the nonce to zero. There was also a race
condition in which the same key would be reused at the same time in
different threads. A mutex fixes this issue now.
So, to summarize, this commit fixes the following vulnerabilities:
* Low entropy key generation, allowing an attacker to potentially
guess or predict keys.
* Unauthenticated encryption, allowing an attacker to modify the
cipher text in particular ways in order to manipulate the plaintext,
which is is even more frightening considering the next point.
* Use of ECB mode, allowing an attacker to trivially swap blocks or
compare identical plaintext blocks.
* Key re-use.
* Faulty memory zeroing.
[Note that in backporting this commit to 4.9, get_random_bytes_wait was
replaced with get_random_bytes, since 4.9 does not have the former
function. This might result in slightly worse entropy in key generation,
but common use cases of big_keys makes that likely not a huge deal. And,
this is the best we can do with this old kernel. Alas.]
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Reviewed-by: Eric Biggers <ebiggers3@gmail.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Kirill Marinushkin <k.marinushkin@gmail.com>
Cc: security@kernel.org
commit 910801809b2e40a4baedd080ef5d80b4a180e70e upstream.
Error paths forgot to zero out sensitive material, so this patch changes
some kfrees into a kzfrees.
commit 57cb17e764ba0aaa169d07796acce54ccfbc6cae upstream.
This function has two callers and neither are able to handle a NULL
return. Really, -EINVAL is the correct thing return here anyway. This
fixes some static checker warnings like:
security/keys/encrypted-keys/encrypted.c:709 encrypted_key_decrypt()
error: uninitialized symbol 'master_key'.
Acked-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit e9ff56ac352446f55141aaef1553cee662b2e310 upstream.
Since v4.9, the crypto API cannot (normally) be used to encrypt/decrypt
stack buffers because the stack may be virtually mapped. Fix this for
the padding buffers in encrypted-keys by using ZERO_PAGE for the
encryption padding and by allocating a temporary heap buffer for the
decryption padding.
Tested with CONFIG_DEBUG_SG=y:
keyctl new_session
keyctl add user master "abcdefghijklmnop" @s
keyid=$(keyctl add encrypted desc "new user:master 25" @s)
datablob="$(keyctl pipe $keyid)"
keyctl unlink $keyid
keyid=$(keyctl add encrypted desc "load $datablob" @s)
datablob2="$(keyctl pipe $keyid)"
[ "$datablob" = "$datablob2" ] && echo "Success!"
commit 63a0b0509e700717a59f049ec6e4e04e903c7fe2 upstream.
key_update() freed the key_preparsed_payload even if it was not
initialized first. This would cause a crash if userspace called
keyctl_update() on a key with type like "asymmetric" that has a
->preparse() method but not an ->update() method. Possibly it could
even be triggered for other key types by racing with keyctl_setperm() to
make the KEY_NEED_WRITE check fail (the permission was already checked,
so normally it wouldn't fail there).
Reproducer with key type "asymmetric", given a valid cert.der:
keyctl new_session
keyid=$(keyctl padd asymmetric desc @s < cert.der)
keyctl setperm $keyid 0x3f000000
keyctl update $keyid data
[ 150.686666] BUG: unable to handle kernel NULL pointer dereference at 0000000000000001
[ 150.687601] IP: asymmetric_key_free_kids+0x12/0x30
[ 150.688139] PGD 38a3d067
[ 150.688141] PUD 3b3de067
[ 150.688447] PMD 0
[ 150.688745]
[ 150.689160] Oops: 0000 [#1] SMP
[ 150.689455] Modules linked in:
[ 150.689769] CPU: 1 PID: 2478 Comm: keyctl Not tainted 4.11.0-rc4-xfstests-00187-ga9f6b6b8cd2f #742
[ 150.690916] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014
[ 150.692199] task: ffff88003b30c480 task.stack: ffffc90000350000
[ 150.692952] RIP: 0010:asymmetric_key_free_kids+0x12/0x30
[ 150.693556] RSP: 0018:ffffc90000353e58 EFLAGS: 00010202
[ 150.694142] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000004
[ 150.694845] RDX: ffffffff81ee3920 RSI: ffff88003d4b0700 RDI: 0000000000000001
[ 150.697569] RBP: ffffc90000353e60 R08: ffff88003d5d2140 R09: 0000000000000000
[ 150.702483] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000001
[ 150.707393] R13: 0000000000000004 R14: ffff880038a4d2d8 R15: 000000000040411f
[ 150.709720] FS: 00007fcbcee35700(0000) GS:ffff88003fd00000(0000) knlGS:0000000000000000
[ 150.711504] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 150.712733] CR2: 0000000000000001 CR3: 0000000039eab000 CR4: 00000000003406e0
[ 150.714487] Call Trace:
[ 150.714975] asymmetric_key_free_preparse+0x2f/0x40
[ 150.715907] key_update+0xf7/0x140
[ 150.716560] ? key_default_cmp+0x20/0x20
[ 150.717319] keyctl_update_key+0xb0/0xe0
[ 150.718066] SyS_keyctl+0x109/0x130
[ 150.718663] entry_SYSCALL_64_fastpath+0x1f/0xc2
[ 150.719440] RIP: 0033:0x7fcbce75ff19
[ 150.719926] RSP: 002b:00007ffd5d167088 EFLAGS: 00000206 ORIG_RAX: 00000000000000fa
[ 150.720918] RAX: ffffffffffffffda RBX: 0000000000404d80 RCX: 00007fcbce75ff19
[ 150.721874] RDX: 00007ffd5d16785e RSI: 000000002866cd36 RDI: 0000000000000002
[ 150.722827] RBP: 0000000000000006 R08: 000000002866cd36 R09: 00007ffd5d16785e
[ 150.723781] R10: 0000000000000004 R11: 0000000000000206 R12: 0000000000404d80
[ 150.724650] R13: 00007ffd5d16784d R14: 00007ffd5d167238 R15: 000000000040411f
[ 150.725447] Code: 83 c4 08 31 c0 5b 41 5c 41 5d 41 5e 41 5f 5d c3 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 85 ff 74 23 55 48 89 e5 53 48 89 fb <48> 8b 3f e8 06 21 c5 ff 48 8b 7b 08 e8 fd 20 c5 ff 48 89 df e8
[ 150.727489] RIP: asymmetric_key_free_kids+0x12/0x30 RSP: ffffc90000353e58
[ 150.728117] CR2: 0000000000000001
[ 150.728430] ---[ end trace f7f8fe1da2d5ae8d ]---
Fixes: 4d8c0250b841 ("KEYS: Call ->free_preparse() even after ->preparse() returns an error")
commit 5649645d725c73df4302428ee4e02c869248b4c5 upstream.
sys_add_key() and the KEYCTL_UPDATE operation of sys_keyctl() allowed a
NULL payload with nonzero length to be passed to the key type's
->preparse(), ->instantiate(), and/or ->update() methods. Various key
types including asymmetric, cifs.idmap, cifs.spnego, and pkcs7_test did
not handle this case, allowing an unprivileged user to trivially cause a
NULL pointer dereference (kernel oops) if one of these key types was
present. Fix it by doing the copy_from_user() when 'plen' is nonzero
rather than when '_payload' is non-NULL, causing the syscall to fail
with EFAULT as expected when an invalid buffer is specified.
commit 1ac202e978e18f045006d75bd549612620c6ec3a upstream.
Modifying the attributes of a file makes ima_inode_post_setattr reset
the IMA cache flags. So if the file, which has just been created,
is opened a second time before the first file descriptor is closed,
verification fails since the security.ima xattr has not been written
yet. We therefore have to look at the IMA_NEW_FILE even if the file
already existed.
With this patch there should no longer be an error when cat tries to
open testfile:
$ rm -f testfile
$ ( echo test >&3 ; touch testfile ; cat testfile ) 3>testfile
A file being new is no reason to accept that it is missing a digital
signature demanded by the policy.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
commit c9f838d104fed6f2f61d68164712e3204bf5271b upstream.
This fixes CVE-2017-7472.
Running the following program as an unprivileged user exhausts kernel
memory by leaking thread keyrings:
int main()
for (;;)
keyctl_set_reqkey_keyring(KEY_REQKEY_DEFL_THREAD_KEYRING);
Fix it by only creating a new thread keyring if there wasn't one before.
To make things more consistent, make install_thread_keyring_to_cred()
and install_process_keyring_to_cred() both return 0 if the corresponding
keyring is already present.
Fixes: d84f4f992cbd ("CRED: Inaugurate COW credentials")
commit c1644fe041ebaf6519f6809146a77c3ead9193af upstream.
This fixes CVE-2017-6951.
Userspace should not be able to do things with the "dead" key type as it
doesn't have some of the helper functions set upon it that the kernel
needs. Attempting to use it may cause the kernel to crash.
Fix this by changing the name of the type to ".dead" so that it's rejected
up front on userspace syscalls by key_get_type_from_user().
Though this doesn't seem to affect recent kernels, it does affect older
ones, certainly those prior to:
commit c06cfb08b88dfbe13be44a69ae2fdc3a7c902d81
Author: David Howells <dhowells@redhat.com>
Date: Tue Sep 16 17:36:06 2014 +0100
KEYS: Remove key_type::match in favour of overriding default by match_preparse
which went in before 3.18-rc1.
commit ee8f844e3c5a73b999edf733df1c529d6503ec2f upstream.
This fixes CVE-2016-9604.
Keyrings whose name begin with a '.' are special internal keyrings and so
userspace isn't allowed to create keyrings by this name to prevent
shadowing. However, the patch that added the guard didn't fix
KEYCTL_JOIN_SESSION_KEYRING. Not only can that create dot-named keyrings,
it can also subscribe to them as a session keyring if they grant SEARCH
permission to the user.
This, for example, allows a root process to set .builtin_trusted_keys as
its session keyring, at which point it has full access because now the
possessor permissions are added. This permits root to add extra public
keys, thereby bypassing module verification.
This also affects kexec and IMA.
This can be tested by (as root):
keyctl session .builtin_trusted_keys
keyctl add user a a @s
keyctl list @s
which on my test box gives me:
2 keys in keyring:
180010936: ---lswrv 0 0 asymmetric: Build time autogenerated kernel key: ae3d4a31b82daa8e1a75b49dc2bba949fd992a05
801382539: --alswrv 0 0 user: a
Fix this by rejecting names beginning with a '.' in the keyctl.
cc: linux-ima-devel@lists.sourceforge.net
commit bc15ed663e7e53ee4dc3e60f8d09c93a0528c694 upstream.
On failure to return a pathname from ima_d_path(), a pointer to
dname is returned, which is subsequently used in the IMA measurement
list, the IMA audit records, and other audit logging. Saving the
pointer to dname for later use has the potential to race with rename.
Intead of returning a pointer to dname on failure, this patch returns
a pointer to a copy of the filename.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream.
SELinux tries to support setting/clearing of /proc/pid/attr attributes
from the shell by ignoring terminating newlines and treating an
attribute value that begins with a NUL or newline as an attempt to
clear the attribute. However, the test for clearing attributes has
always been wrong; it has an off-by-one error, and this could further
lead to reading past the end of the allocated buffer since commit
bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write():
switch to memdup_user()"). Fix the off-by-one error.
Even with this fix, setting and clearing /proc/pid/attr attributes
from the shell is not straightforward since the interface does not
support multiple write() calls (so shells that write the value and
newline separately will set and then immediately clear the attribute,
requiring use of echo -n to set the attribute), whereas trying to use
echo -n "" to clear the attribute causes the shell to skip the
write() call altogether since POSIX says that a zero-length write
causes no side effects. Thus, one must use echo -n to set and echo
without -n to clear, as in the following example:
$ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate
$ cat /proc/$$/attr/fscreate
$ echo "" > /proc/$$/attr/fscreate
Note the use of /proc/$$ rather than /proc/self, as otherwise
the cat command will read its own attribute value, not that of the shell.
There are no users of this facility to my knowledge; possibly we
should just get rid of it.
UPDATE: Upon further investigation it appears that a local process
with the process:setfscreate permission can cause a kernel panic as a
result of this bug. This patch fixes CVE-2017-2618.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: added the update about CVE-2017-2618 to the commit description]
Signed-off-by: Paul Moore <paul@paul-moore.com>
commit 9a11a18902bc3b904353063763d06480620245a6 upstream.
When the "policy" securityfs file is opened for read, it is opened as a
sequential file. However, when it is eventually released, there is no
cleanup for the sequential file, therefore some memory is leaked.
This patch adds a call to seq_release() in ima_release_policy() to clean up
the memory when the file is opened for read.
Fixes: 80eae209d63a IMA: allow reading back the current policy
Reported-by: Colin Ian King <colin.king@canonical.com>
Signed-off-by: Eric Richter <erichte@linux.vnet.ibm.com>
Tested-by: Colin Ian King <colin.king@canonical.com>
After a policy replacement, the task cred may be out of date and need
to be updated. However change_hat is using the stale profiles from
the out of date cred resulting in either: a stale profile being applied
or, incorrect failure when searching for a hat profile as it has been
migrated to the new parent profile.
Fixes: 01e2b670aa898a39259bc85c78e3d74820f4d3b6 (failure to find hat)
Fixes: 898127c34ec03291c86f4ff3856d79e9e18952bc (stale policy being applied)
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1000287
Cc: stable@vger.kernel.org
Since BIG_KEYS can't be compiled as module it requires one of the "stdrng"
providers to be compiled into kernel. Otherwise big_key_crypto_init() fails
on crypto_alloc_rng step and next dereference of big_key_skcipher (e.g. in
big_key_preparse()) results in a NULL pointer dereference.
Fixes: 13100a72f40f5748a04017e0ab3df4cf27c809ef ('Security: Keys: Big keys stored encrypted')
Signed-off-by: Artem Savkov <asavkov@redhat.com>
cc: Stephan Mueller <smueller@chronox.de>
cc: Kirill Marinushkin <k.marinushkin@gmail.com>
cc: stable@vger.kernel.org
big_key has two separate initialisation functions, one that registers the
key type and one that registers the crypto. If the key type fails to
register, there's no problem if the crypto registers successfully because
there's no way to reach the crypto except through the key type.
However, if the key type registers successfully but the crypto does not,
big_key_rng and big_key_blkcipher may end up set to NULL - but the code
neither checks for this nor unregisters the big key key type.
Furthermore, since the key type is registered before the crypto, it is
theoretically possible for the kernel to try adding a big_key before the
crypto is set up, leading to the same effect.
Fix this by merging big_key_crypto_init() and big_key_init() and calling
the resulting function late. If they're going to be encrypted, we
shouldn't be creating big_keys before we have the facilities to do the
encryption available. The key type registration is also moved after the
crypto initialisation.
The fix also includes message printing on failure.
If the big_key type isn't correctly set up, simply doing:
dd if=/dev/zero bs=4096 count=1 | keyctl padd big_key a @s
ought to cause an oops.
cc: Peter Hlavaty <zer0mem@yahoo.com>
cc: Artem Savkov <asavkov@redhat.com>
This fixes CVE-2016-7042.
Fix a short sprintf buffer in proc_keys_show(). If the gcc stack protector
is turned on, this can cause a panic due to stack corruption.
The problem is that xbuf[] is not big enough to hold a 64-bit timeout
rendered as weeks:
(gdb) p 0xffffffffffffffffULL/(60*60*24*7)
$2 = 30500568904943
That's 14 chars plus NUL, not 11 chars plus NUL.
Expand the buffer to 16 chars.
I think the unpatched code apparently works if the stack-protector is not
enabled because on a 32-bit machine the buffer won't be overflowed and on a
64-bit machine there's a 64-bit aligned pointer at one side and an int that
isn't checked again on the other side.
The panic incurred looks something like:
Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81352ebe
CPU: 0 PID: 1692 Comm: reproducer Not tainted 4.7.2-201.fc24.x86_64 #1
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
0000000000000086 00000000fbbd2679 ffff8800a044bc00 ffffffff813d941f
ffffffff81a28d58 ffff8800a044bc98 ffff8800a044bc88 ffffffff811b2cb6
ffff880000000010 ffff8800a044bc98 ffff8800a044bc30 00000000fbbd2679
Call Trace:
[<ffffffff813d941f>] dump_stack+0x63/0x84
[<ffffffff811b2cb6>] panic+0xde/0x22a
[<ffffffff81352ebe>] ? proc_keys_show+0x3ce/0x3d0
[<ffffffff8109f7f9>] __stack_chk_fail+0x19/0x30
[<ffffffff81352ebe>] proc_keys_show+0x3ce/0x3d0
[<ffffffff81350410>] ? key_validate+0x50/0x50
[<ffffffff8134db30>] ? key_default_cmp+0x20/0x20
[<ffffffff8126b31c>] seq_read+0x2cc/0x390
[<ffffffff812b6b12>] proc_reg_read+0x42/0x70
[<ffffffff81244fc7>] __vfs_read+0x37/0x150
[<ffffffff81357020>] ? security_file_permission+0xa0/0xc0
[<ffffffff81246156>] vfs_read+0x96/0x130
[<ffffffff81247635>] SyS_read+0x55/0xc0
[<ffffffff817eb872>] entry_SYSCALL_64_fastpath+0x1a/0xa4
Reported-by: Ondrej Kozina <okozina@redhat.com>
Tested-by: Ondrej Kozina <okozina@redhat.com>
Pull vmap stack fixes from Ingo Molnar:
"This is fallout from CONFIG_HAVE_ARCH_VMAP_STACK=y on x86: stack
accesses that used to be just somewhat questionable are now totally
buggy.
These changes try to do it without breaking the ABI: the fields are
left there, they are just reporting zero, or reporting narrower
information (the maps file change)"
* 'mm-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm: Change vm_is_stack_for_task() to vm_is_stack_for_current()
fs/proc: Stop trying to report thread stacks
fs/proc: Stop reporting eip and esp in /proc/PID/stat
mm/numa: Remove duplicated include from mprotect.c
Asking for a non-current task's stack can't be done without races
unless the task is frozen in kernel mode. As far as I know,
vm_is_stack_for_task() never had a safe non-current use case.
The __unused annotation is because some KSTK_ESP implementations
ignore their parameter, which IMO is further justification for this
patch.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Jann Horn <jann@thejh.net>
Cc: Linux API <linux-api@vger.kernel.org>
Cc: Tycho Andersen <tycho.andersen@canonical.com>
Link: http://lkml.kernel.org/r/4c3f68f426e6c061ca98b4fc7ef85ffbb0a25b0c.1475257877.git.luto@kernel.org
This removes the 'write' and 'force' from get_user_pages_remote() and
replaces them with 'gup_flags' to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
hence bugs) within the mm subsystem.
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Pull misc vfs updates from Al Viro:
"Assorted misc bits and pieces.
There are several single-topic branches left after this (rename2
series from Miklos, current_time series from Deepa Dinamani, xattr
series from Andreas, uaccess stuff from from me) and I'd prefer to
send those separately"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits)
proc: switch auxv to use of __mem_open()
hpfs: support FIEMAP
cifs: get rid of unused arguments of CIFSSMBWrite()
posix_acl: uapi header split
posix_acl: xattr representation cleanups
fs/aio.c: eliminate redundant loads in put_aio_ring_file
fs/internal.h: add const to ns_dentry_operations declaration
compat: remove compat_printk()
fs/buffer.c: make __getblk_slow() static
proc: unsigned file descriptors
fs/file: more unsigned file descriptors
fs: compat: remove redundant check of nr_segs
cachefiles: Fix attempt to read i_blocks after deleting file [ver #2]
cifs: don't use memcpy() to copy struct iov_iter
get rid of separate multipage fault-in primitives
fs: Avoid premature clearing of capabilities
fs: Give dentry to inode_change_ok() instead of inode
fuse: Propagate dentry down to inode_change_ok()
ceph: Propagate dentry down to inode_change_ok()
xfs: Propagate dentry down to inode_change_ok()
Merge my system logging cleanups, triggered by the broken '\n' patches.
The line continuation handling has been broken basically forever, and
the code to handle the system log records was both confusing and
dubious. And it would do entirely the wrong thing unless you always had
a terminating newline, partly because it couldn't actually see whether a
message was marked KERN_CONT or not (but partly because the LOG_CONT
handling in the recording code was rather confusing too).
This re-introduces a real semantically meaningful KERN_CONT, and fixes
the few places I noticed where it was missing. There are probably more
missing cases, since KERN_CONT hasn't actually had any semantic meaning
for at least four years (other than the checkpatch meaning of "no log
level necessary, this is a continuation line").
This also allows the combination of KERN_CONT and a log level. In that
case the log level will be ignored if the merging with a previous line
is successful, but if a new record is needed, that new record will now
get the right log level.
That also means that you can at least in theory combine KERN_CONT with
the "pr_info()" style helpers, although any use of pr_fmt() prefixing
would make that just result in a mess, of course (the prefix would end
up in the middle of a continuing line).
* printk-cleanups:
printk: make reading the kernel log flush pending lines
printk: re-organize log_output() to be more legible
printk: split out core logging code into helper function
printk: reinstate KERN_CONT for printing continuation lines
Long long ago the kernel log buffer was a buffered stream of bytes, very
much like stdio in user space. It supported log levels by scanning the
stream and noticing the log level markers at the beginning of each line,
but if you wanted to print a partial line in multiple chunks, you just
did multiple printk() calls, and it just automatically worked.
Except when it didn't, and you had very confusing output when different
lines got all mixed up with each other. Then you got fragment lines
mixing with each other, or with non-fragment lines, because it was
traditionally impossible to tell whether a printk() call was a
continuation or not.
To at least help clarify the issue of continuation lines, we added a
KERN_CONT marker back in 2007 to mark continuation lines:
474925277671 ("printk: add KERN_CONT annotation").
That continuation marker was initially an empty string, and didn't
actuall make any semantic difference. But it at least made it possible
to annotate the source code, and have check-patch notice that a printk()
didn't need or want a log level marker, because it was a continuation of
a previous line.
To avoid the ambiguity between a continuation line that had that
KERN_CONT marker, and a printk with no level information at all, we then
in 2009 made KERN_CONT be a real log level marker which meant that we
could now reliably tell the difference between the two cases.
5fd29d6ccbc9 ("printk: clean up handling of log-levels and newlines")
and we could take advantage of that to make sure we didn't mix up
continuation lines with lines that just didn't have any loglevel at all.
Then, in 2012, the kernel log buffer was changed to be a "record" based
log, where each line was a record that has a loglevel and a timestamp.
You can see the beginning of that conversion in commits
e11fea92e13f ("kmsg: export printk records to the /dev/kmsg interface")
7ff9554bb578 ("printk: convert byte-buffer to variable-length record buffer")
with a number of follow-up commits to fix some painful fallout from that
conversion. Over all, it took a couple of months to sort out most of
it. But the upside was that you could have concurrent readers (and
writers) of the kernel log and not have lines with mixed output in them.
And one particular pain-point for the record-based kernel logging was
exactly the fragmentary lines that are generated in smaller chunks. In
order to still log them as one recrod, the continuation lines need to be
attached to the previous record properly.
However the explicit continuation record marker that is actually useful
for this exact case was actually removed in aroundm the same time by commit
61e99ab8e35a ("printk: remove the now unnecessary "C" annotation for KERN_CONT")
due to the incorrect belief that KERN_CONT wasn't meaningful. The
ambiguity between "is this a continuation line" or "is this a plain
printk with no log level information" was reintroduced, and in fact
became an even bigger pain point because there was now the whole
record-level merging of kernel messages going on.
This patch reinstates the KERN_CONT as a real non-empty string marker,
so that the ambiguity is fixed once again.
But it's not a plain revert of that original removal: in the four years
since we made KERN_CONT an empty string again, not only has the format
of the log level markers changed, we've also had some usage changes in
this area.
For example, some ACPI code seems to use KERN_CONT _together_ with a log
level, and now uses both the KERN_CONT marker and (for example) a
KERN_INFO marker to show that it's an informational continuation of a
line.
Which is actually not a bad idea - if the continuation line cannot be
attached to its predecessor, without the log level information we don't
know what log level to assign to it (and we traditionally just assigned
it the default loglevel). So having both a log level and the KERN_CONT
marker is not necessarily a bad idea, but it does mean that we need to
actually iterate over potentially multiple markers, rather than just a
single one.
Also, since KERN_CONT was still conceptually needed, and encouraged, but
didn't actually _do_ anything, we've also had the reverse problem:
rather than having too many annotations it has too few, and there is bit
rot with code that no longer marks the continuation lines with the
KERN_CONT marker.
So this patch not only re-instates the non-empty KERN_CONT marker, it
also fixes up the cases of bit-rot I noticed in my own logs.
There are probably other cases where KERN_CONT will be needed to be
added, either because it is new code that never dealt with the need for
KERN_CONT, or old code that has bitrotted without anybody noticing.
That said, we should strive to avoid the need for KERN_CONT. It does
result in real problems for logging, and should generally not be seen as
a good feature. If we some day can get rid of the feature entirely,
because nobody does any fragmented printk calls, that would be lovely.
But until that point, let's at mark the code that relies on the hacky
multi-fragment kernel printk's. Not only does it avoid the ambiguity,
it also annotates code as "maybe this would be good to fix some day".
(That said, particularly during single-threaded bootup, the downsides of
KERN_CONT are very limited. Things get much hairier when you have
multiple threads going on and user level reading and writing logs too).
Right now, various places in the kernel check for the existence of
getxattr, setxattr, and removexattr inode operations and directly call
those operations. Switch to helper functions and test for the IOP_XATTR
flag instead.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: James Morris <james.l.morris@oracle.com>
Pull trivial updates from Jiri Kosina:
"The usual rocket science from the trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
tracing/syscalls: fix multiline in error message text
lib/Kconfig.debug: fix DEBUG_SECTION_MISMATCH description
doc: vfs: fix fadvise() sycall name
x86/entry: spell EBX register correctly in documentation
securityfs: fix securityfs_create_dir comment
irq: Fix typo in tracepoint.xml
