path: root/security
2011-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: merge fchmod() and fchmodat() guts, kill ancient broken kludge xfs: fix misspelled S_IS...() xfs: get rid of open-coded S_ISREG(), etc. vfs: document locking requirements for d_move, __d_move and d_materialise_unique omfs: fix (mode & S_IFDIR) abuse btrfs: S_ISREG(mode) is not mode & S_IFREG... ima: fmode_t misspelled as mode_t... pci-label.c: size_t misspelled as mode_t jffs2: S_ISLNK(mode & S_IFMT) is pointless snd_msnd ->mode is fmode_t, not mode_t v9fs_iop_get_acl: get rid of unused variable vfs: dont chain pipe/anon/socket on superblock s_inodes list Documentation: Exporting: update description of d_splice_alias fs: add missing unlock in default_llseek()
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ima: fmode_t misspelled as mode_t...Al Viro
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24VFS : mount lock scalability for internal mountsTim Chen
For a number of file systems that don't have a mount point (e.g. sockfs and pipefs), they are not marked as long term. Therefore in mntput_no_expire, all locks in vfs_mount lock are taken instead of just local cpu's lock to aggregate reference counts when we release reference to file objects. In fact, only local lock need to have been taken to update ref counts as these file systems are in no danger of going away until we are ready to unregister them. The attached patch marks file systems using kern_mount without mount point as long term. The contentions of vfs_mount lock is now eliminated. Before un-registering such file system, kern_unmount should be called to remove the long term flag and make the mount point ready to be freed. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-22Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: Fix wrong check in list_splice_init_rcu() net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu() sysctl,rcu: Convert call_rcu(free_head) to kfree vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu() vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu() ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu() ipc,rcu: Convert call_rcu(free_un) to kfree_rcu() security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu() security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu() ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu() block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu() scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu() audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu() security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu() md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
2011-07-22Merge branch 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/miscLinus Torvalds
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits) ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction connector: add an event for monitoring process tracers ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task() ptrace_init_task: initialize child->jobctl explicitly has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/ ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/ ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented() ptrace: ptrace_reparented() should check same_thread_group() redefine thread_group_leader() as exit_signal >= 0 do not change dead_task->exit_signal kill task_detached() reparent_leader: check EXIT_DEAD instead of task_detached() make do_notify_parent() __must_check, update the callers __ptrace_detach: avoid task_detached(), check do_notify_parent() kill tracehook_notify_death() make do_notify_parent() return bool ptrace: s/tracehook_tracer_task()/ptrace_parent()/ ...
2011-07-20security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu()Lai Jiangshan
The rcu callback sel_netport_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sel_netport_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Eric Paris <eparis@parisplace.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-20security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu()Lai Jiangshan
The rcu callback sel_netnode_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sel_netnode_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Eric Paris <eparis@parisplace.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-20security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu()Lai Jiangshan
The rcu callback whitelist_item_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(whitelist_item_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-07-20get rid of pointless checks for dentry->sb == NULLAl Viro
it never is... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to exec_permission()Al Viro
pass mask instead; kill security_inode_exec_permission() since we can use security_inode_permission() instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20selinux: don't transliterate MAY_NOT_BLOCK to IPERM_FLAG_RCUAl Viro
2011-07-20->permission() sanitizing: don't pass flags to ->inode_permission()Al Viro
pass that via mask instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-08rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_checkMichal Hocko
Since ca5ecddf (rcu: define __rcu address space modifier for sparse) rcu_dereference_check use rcu_read_lock_held as a part of condition automatically so callers do not have to do that as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-05Merge branch 'master' of ↵David S. Miller
2011-06-22ptrace: s/tracehook_tracer_task()/ptrace_parent()/Tejun Heo
tracehook.h is on the way out. Rename tracehook_tracer_task() to ptrace_parent() and move it from tracehook.h to ptrace.h. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: John Johansen <john.johansen@canonical.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Oleg Nesterov <oleg@redhat.com>
2011-06-21net: remove mm.h inclusion from netdevice.hAlexey Dobriyan
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually). To prevent mm.h inclusion via other channels also extract "enum dma_data_direction" definition into separate header. This tiny piece is what gluing netdevice.h with mm.h via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h". Removal of mm.h from scatterlist.h was tried and was found not feasible on most archs, so the link was cutoff earlier. Hope people are OK with tiny include file. Note, that mm_types.h is still dragged in, but it is a separate story. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21KEYS: Fix error handling in construct_key_and_link()David Howells
Fix error handling in construct_key_and_link(). If construct_alloc_key() returns an error, it shouldn't pass out through the normal path as the key_serial() called by the kleave() statement will oops when it gets an error code in the pointer: BUG: unable to handle kernel paging request at ffffffffffffff84 IP: [<ffffffff8120b401>] request_key_and_link+0x4d7/0x52f .. Call Trace: [<ffffffff8120b52c>] request_key+0x41/0x75 [<ffffffffa00ed6e8>] cifs_get_spnego_key+0x206/0x226 [cifs] [<ffffffffa00eb0c9>] CIFS_SessSetup+0x511/0x1234 [cifs] [<ffffffffa00d9799>] cifs_setup_session+0x90/0x1ae [cifs] [<ffffffffa00d9c02>] cifs_get_smb_ses+0x34b/0x40f [cifs] [<ffffffffa00d9e05>] cifs_mount+0x13f/0x504 [cifs] [<ffffffffa00caabb>] cifs_do_mount+0xc4/0x672 [cifs] [<ffffffff8113ae8c>] mount_fs+0x69/0x155 [<ffffffff8114ff0e>] vfs_kern_mount+0x63/0xa0 [<ffffffff81150be2>] do_kern_mount+0x4d/0xdf [<ffffffff81152278>] do_mount+0x63c/0x69f [<ffffffff8115255c>] sys_mount+0x88/0xc2 [<ffffffff814fbdc2>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: devcgroup_inode_permission: take "is it a device node" checks to inlined wrapper fix comment in generic_permission() kill obsolete comment for follow_down() proc_sys_permission() is OK in RCU mode reiserfs_permission() doesn't need to bail out in RCU mode proc_fd_permission() is doesn't need to bail out in RCU mode nilfs2_permission() doesn't need to bail out in RCU mode logfs doesn't need ->permission() at all coda_ioctl_permission() is safe in RCU mode cifs_permission() doesn't need to bail out in RCU mode bad_inode_permission() is safe from RCU mode ubifs: dereferencing an ERR_PTR in ubifs_mount()
2011-06-20devcgroup_inode_permission: take "is it a device node" checks to inlined wrapperAl Viro
inode_permission() calls devcgroup_inode_permission() and almost all such calls are _not_ for device nodes; let's at least keep the common path straight... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-17KEYS/DNS: Fix ____call_usermodehelper() to not lose the session keyringDavid Howells
____call_usermodehelper() now erases any credentials set by the subprocess_inf::init() function. The problem is that commit 17f60a7da150 ("capabilites: allow the application of capability limits to usermode helpers") creates and commits new credentials with prepare_kernel_cred() after the call to the init() function. This wipes all keyrings after umh_keys_init() is called. The best way to deal with this is to put the init() call just prior to the commit_creds() call, and pass the cred pointer to init(). That means that umh_keys_init() and suchlike can modify the credentials _before_ they are published and potentially in use by the rest of the system. This prevents request_key() from working as it is prevented from passing the session keyring it set up with the authorisation token to /sbin/request-key, and so the latter can't assume the authority to instantiate the key. This causes the in-kernel DNS resolver to fail with ENOKEY unconditionally. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-06-14SELinux: skip file_name_trans_write() when policy downgraded.Roy.Li
When policy version is less than POLICYDB_VERSION_FILENAME_TRANS, skip file_name_trans_write(). Signed-off-by: Roy.Li <rongqing.li@windriver.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-06-14TOMOYO: Fix oops in tomoyo_mount_acl().Tetsuo Handa
In tomoyo_mount_acl() since 2.6.36, kern_path() was called without checking dev_name != NULL. As a result, an unprivileged user can trigger oops by issuing mount(NULL, "/", "ext3", 0, NULL) request. Fix this by checking dev_name != NULL before calling kern_path(dev_name). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-06-09AppArmor: Fix sleep in invalid context from task_setrlimitJohn Johansen
Affected kernels 2.6.36 - 3.0 AppArmor may do a GFP_KERNEL memory allocation with task_lock(tsk->group_leader); held when called from security_task_setrlimit. This will only occur when the task's current policy has been replaced, and the task's creds have not been updated before entering the LSM security_task_setrlimit() hook. BUG: sleeping function called from invalid context at mm/slub.c:847 in_atomic(): 1, irqs_disabled(): 0, pid: 1583, name: cupsd 2 locks held by cupsd/1583: #0: (tasklist_lock){.+.+.+}, at: [<ffffffff8104dafa>] do_prlimit+0x61/0x189 #1: (&(&p->alloc_lock)->rlock){+.+.+.}, at: [<ffffffff8104db2d>] do_prlimit+0x94/0x189 Pid: 1583, comm: cupsd Not tainted 3.0.0-rc2-git1 #7 Call Trace: [<ffffffff8102ebf2>] __might_sleep+0x10d/0x112 [<ffffffff810e6f46>] slab_pre_alloc_hook.isra.49+0x2d/0x33 [<ffffffff810e7bc4>] kmem_cache_alloc+0x22/0x132 [<ffffffff8105b6e6>] prepare_creds+0x35/0xe4 [<ffffffff811c0675>] aa_replace_current_profile+0x35/0xb2 [<ffffffff811c4d2d>] aa_current_profile+0x45/0x4c [<ffffffff811c4d4d>] apparmor_task_setrlimit+0x19/0x3a [<ffffffff811beaa5>] security_task_setrlimit+0x11/0x13 [<ffffffff8104db6b>] do_prlimit+0xd2/0x189 [<ffffffff8104dea9>] sys_setrlimit+0x3b/0x48 [<ffffffff814062bb>] system_call_fastpath+0x16/0x1b Signed-off-by: John Johansen <john.johansen@canonical.com> Reported-by: Miles Lane <miles.lane@gmail.com> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-06-08selinux: simplify and clean up inode_has_perm()Linus Torvalds
This is a rather hot function that is called with a potentially NULL "struct common_audit_data" pointer argument. And in that case it has to provide and initialize its own dummy common_audit_data structure. However, all the _common_ cases already pass it a real audit-data structure, so that uncommon NULL case not only creates a silly run-time test, more importantly it causes that function to have a big stack frame for the dummy variable that isn't even used in the common case! So get rid of that stupid run-time behavior, and make the (few) functions that currently call with a NULL pointer just call a new helper function instead (naturally called inode_has_perm_noapd(), since it has no adp argument). This makes the run-time test be a static code generation issue instead, and allows for a much denser stack since none of the common callers need the dummy structure. And a denser stack not only means less stack space usage, it means better cache behavior. So we have a win-win-win from this simplification: less code executed, smaller stack footprint, and better cache behavior. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-01AppArmor: fix oops in apparmor_setprocattrKees Cook
When invalid parameters are passed to apparmor_setprocattr a NULL deref oops occurs when it tries to record an audit message. This is because it is passing NULL for the profile parameter for aa_audit. But aa_audit now requires that the profile passed is not NULL. Fix this by passing the current profile on the task that is trying to setprocattr. Signed-off-by: Kees Cook <kees@ubuntu.com> Signed-off-by: John Johansen <john.johansen@canonical.com> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-05-27Merge branch 'docs-move' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs * 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs: Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
2011-05-26selinux: don't pass in NULL avd to avc_has_perm_noauditLinus Torvalds
Right now security_get_user_sids() will pass in a NULL avd pointer to avc_has_perm_noaudit(), which then forces that function to have a dummy entry for that case and just generally test it. Don't do it. The normal callers all pass a real avd pointer, and this helper function is incredibly hot. So don't make avc_has_perm_noaudit() do conditional stuff that isn't needed for the common case. This also avoids some duplicated stack space. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26cgroups: add per-thread subsystem callbacksBen Blum
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts Add can_attach_task(), pre_attach(), and attach_task() as new callbacks for cgroups's subsystem interface. Unlike can_attach and attach, these are for per-thread operations, to be called potentially many times when attaching an entire threadgroup. Also, the old "bool threadgroup" interface is removed, as replaced by this. All subsystems are modified for the new interface - of note is cpuset, which requires from/to nodemasks for attach to be globally scoped (though per-cpuset would work too) to persist from its pre_attach to attach_task and attach. This is a pre-patch for cgroup-procs-writable.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26selinux: fix case of names with whitespace/multibytes on /selinux/createKohei Kaigai
I submit the patch again, according to patch submission convension. This patch enables to accept percent-encoded object names as forth argument of /selinux/create interface to avoid possible bugs when we give an object name including whitespace or multibutes. E.g) if and when a userspace object manager tries to create a new object named as "resolve.conf but fake", it shall give this name as the forth argument of the /selinux/create. But sscanf() logic in kernel space fetches only the part earlier than the first whitespace. In this case, selinux may unexpectedly answer a default security context configured to "resolve.conf", but it is bug. Although I could not test this patch on named TYPE_TRANSITION rules actually, But debug printk() message seems to me the logic works correctly. I assume the libselinux provides an interface to apply this logic transparently, so nothing shall not be changed from the viewpoint of application. Signed-off-by: KaiGai Kohei <kohei.kaigai@emea.nec.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-26Merge commit 'v2.6.39' into 20110526Eric Paris
Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c
2011-05-26Set cred->user_ns in key_replace_session_keyringSerge E. Hallyn
Since this cred was not created with copy_creds(), it needs to get initialized. Otherwise use of syscall(__NR_keyctl, KEYCTL_SESSION_TO_PARENT); can lead to a NULL deref. Thanks to Robert for finding this. But introduced by commit 47a150edc2a ("Cache user_ns in struct cred"). Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Reported-by: Robert Święcki <robert@swiecki.net> Cc: David Howells <dhowells@redhat.com> Cc: stable@kernel.org (2.6.39) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into ↵James Morris
for-linus Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c Manually resolve conflicts. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-24Merge branch 'next' into for-linusJames Morris
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19selinux: avoid unnecessary avc cache stat hit countLinus Torvalds
There is no point in counting hits - we can calculate it from the number of lookups and misses. This makes the avc statistics a bit smaller, and makes the code generation better too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19selinux: de-crapify avc cache stat code generationLinus Torvalds
You can turn off the avc cache stats, but distributions seem to not do that (perhaps because several performance tuning how-to's talk about the avc cache statistics). Which is sad, because the code it generates is truly horrendous, with the statistics update being sandwitched between get_cpu/put_cpu which in turn causes preemption disables etc. We're talking ten+ instructions just to increment a per-cpu variable in some pretty hot code. Fix the craziness by just using 'this_cpu_inc()' instead. Suddenly we only need a single 'inc' instruction to increment the statistics. This is quite noticeable in the incredibly hot avc_has_perm_noaudit() function (which triggers all the statistics by virtue of doing an avc_lookup() call). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-19Create Documentation/security/,Randy Dunlap
2011-05-19Merge branch 'master' into nextJames Morris
Conflicts: include/linux/capability.h Manually resolve merge conflict w/ thanks to Stephen Rothwell. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-13Merge branch 'for-linus' of git://git.infradead.org/users/eparis/selinux ↵James Morris
into for-linus
2011-05-12SELinux: delete debugging printks from filename_trans rule processingEric Paris
The filename_trans rule processing has some printk(KERN_ERR ) messages which were intended as debug aids in creating the code but weren't removed before it was submitted. Remove them. Reported-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-12TOMOYO: Fix wrong domainname validation.Tetsuo Handa
In tomoyo_correct_domain() since 2.6.36, TOMOYO was by error validating "<kernel>" + "/foo/\" + "/bar" when "<kernel> /foo/\* /bar" was given. As a result, legal domainnames like "<kernel> /foo/\* /bar" are rejected. Reported-by: Hayama Yossihiro <yossi@yedo.src.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-05-11SELINUX: add /sys/fs/selinux mount point to put selinuxfsGreg Kroah-Hartman
In the interest of keeping userspace from having to create new root filesystems all the time, let's follow the lead of the other in-kernel filesystems and provide a proper mount point for it in sysfs. For selinuxfs, this mount point should be in /sys/fs/selinux/ Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Eric Paris <eparis@parisplace.org> Cc: Lennart Poettering <mzerqung@0pointer.de> Cc: Daniel J Walsh <dwalsh@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [include kobject.h - Eric Paris] [use selinuxfs_obj throughout - Eric Paris] Signed-off-by: Eric Paris <eparis@redhat.com>
2011-05-07security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()Lai Jiangshan
The rcu callback sel_netif_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sel_netif_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-07security,rcu: convert call_rcu(user_update_rcu_disposal) to kfree_rcu()Lai Jiangshan
The rcu callback user_update_rcu_disposal() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(user_update_rcu_disposal). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
