path: root/security
2012-12-24ima: fallback to MODULE_SIG_ENFORCE for existing kernel module syscallMimi Zohar
The new kernel module syscall appraises kernel modules based on policy. If the IMA policy requires kernel module checking, fallback to module signature enforcing for the existing syscall. Without CONFIG_MODULE_SIG_FORCE enabled, the kernel module's integrity is unknown, return -EACCES. Changelog v1: - Fix ima_module_check() return result (Tetsuo Handa) Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2012-12-20keys: fix unreachable codeAlan Cox
We set ret to NULL then test it. Remove the bogus test Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Really fix tuntap SKB use after free bug, from Eric Dumazet. 2) Adjust SKB data pointer to point past the transport header before calling icmpv6_notify() so that the headers are in the state which that function expects. From Duan Jiong. 3) Fix ambiguities in the new tuntap multi-queue APIs. From Jason Wang. 4) mISDN needs to use del_timer_sync(), from Konstantin Khlebnikov. 5) Don't destroy mutex after freeing up device private in mac802154, fix also from Konstantin Khlebnikov. 6) Fix INET request socket leak in TCP and DCCP, from Christoph Paasch. 7) SCTP HMAC kconfig rework, from Neil Horman. 8) Fix SCTP jprobes function signature, otherwise things explode, from Daniel Borkmann. 9) Fix typo in ipv6-offload Makefile variable reference, from Simon Arlott. 10) Don't fail USBNET open just because remote wakeup isn't supported, from Oliver Neukum. 11) be2net driver bug fixes from Sathya Perla. 12) SOLOS PCI ATM driver bug fixes from Nathan Williams and David Woodhouse. 13) Fix MTU changing regression in 8139cp driver, from John Greene. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (45 commits) solos-pci: ensure all TX packets are aligned to 4 bytes solos-pci: add firmware upgrade support for new models solos-pci: remove superfluous debug output solos-pci: add GPIO support for newer versions on Geos board 8139cp: Prevent dev_close/cp_interrupt race on MTU change net: qmi_wwan: add ZTE MF880 drivers/net: Use of_match_ptr() macro in smsc911x.c drivers/net: Use of_match_ptr() macro in smc91x.c ipv6: addrconf.c: remove unnecessary "if" bridge: Correctly encode addresses when dumping mdb entries bridge: Do not unregister all PF_BRIDGE rtnl operations use generic usbnet_manage_power() usbnet: generic manage_power() usbnet: handle PM failure gracefully ksz884x: fix receive polling race condition qlcnic: update driver version qlcnic: fix unused variable warnings net: fec: forbid FEC_PTP on SoCs that do not support be2net: fix wrong frag_idx reported by RX CQ be2net: fix be_close() to ensure all events are ack'ed ...
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull (again) user namespace infrastructure changes from Eric Biederman: "Those bugs, those darn embarrasing bugs just want don't want to get fixed. Linus I just updated my mirror of your kernel.org tree and it appears you successfully pulled everything except the last 4 commits that fix those embarrasing bugs. When you get a chance can you please repull my branch" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Fix typo in description of the limitation of userns_install userns: Add a more complete capability subset test to commit_creds userns: Require CAP_SYS_ADMIN for most uses of setns. Fix cap_capable to only allow owners in the parent user namespace to have caps.
2012-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "While small this set of changes is very significant with respect to containers in general and user namespaces in particular. The user space interface is now complete. This set of changes adds support for unprivileged users to create user namespaces and as a user namespace root to create other namespaces. The tyranny of supporting suid root preventing unprivileged users from using cool new kernel features is broken. This set of changes completes the work on setns, adding support for the pid, user, mount namespaces. This set of changes includes a bunch of basic pid namespace cleanups/simplifications. Of particular significance is the rework of the pid namespace cleanup so it no longer requires sending out tendrils into all kinds of unexpected cleanup paths for operation. At least one case of broken error handling is fixed by this cleanup. The files under /proc/<pid>/ns/ have been converted from regular files to magic symlinks which prevents incorrect caching by the VFS, ensuring the files always refer to the namespace the process is currently using and ensuring that the ptrace_mayaccess permission checks are always applied. The files under /proc/<pid>/ns/ have been given stable inode numbers so it is now possible to see if different processes share the same namespaces. Through the David Miller's net tree are changes to relax many of the permission checks in the networking stack to allowing the user namespace root to usefully use the networking stack. Similar changes for the mount namespace and the pid namespace are coming through my tree. Two small changes to add user namespace support were commited here adn in David Miller's -net tree so that I could complete the work on the /proc/<pid>/ns/ files in this tree. Work remains to make it safe to build user namespaces and 9p, afs, ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the Kconfig guard remains in place preventing that user namespaces from being built when any of those filesystems are enabled. Future design work remains to allow root users outside of the initial user namespace to mount more than just /proc and /sys." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits) proc: Usable inode numbers for the namespace file descriptors. proc: Fix the namespace inode permission checks. proc: Generalize proc inode allocation userns: Allow unprivilged mounts of proc and sysfs userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file procfs: Print task uids and gids in the userns that opened the proc file userns: Implement unshare of the user namespace userns: Implent proc namespace operations userns: Kill task_user_ns userns: Make create_new_namespaces take a user_ns parameter userns: Allow unprivileged use of setns. userns: Allow unprivileged users to create new namespaces userns: Allow setting a userns mapping to your current uid. userns: Allow chown and setgid preservation userns: Allow unprivileged users to create user namespaces. userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped userns: fix return value on mntns_install() failure vfs: Allow unprivileged manipulation of the mount namespace. vfs: Only support slave subtrees across different user namespaces vfs: Add a user namespace reference from struct mnt_namespace ...
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-12-15bridge: update selinux perm table for RTM_NEWMDB and RTM_DELMDBAmerigo Wang
Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-14Fix cap_capable to only allow owners in the parent user namespace to have caps.Eric W. Biederman
Andy Lutomirski pointed out that the current behavior of allowing the owner of a user namespace to have all caps when that owner is not in a parent user namespace is wrong. Add a test to ensure the owner of a user namespace is in the parent of the user namespace to fix this bug. Thankfully this bug did not apply to the initial user namespace, keeping the mischief that can be caused by this bug quite small. This is bug was introduced in v3.5 by commit 783291e6900 "Simplify the user_namespace by making userns->creator a kuid." But did not matter until the permisions required to create a user namespace were relaxed allowing a user namespace to be created inside of a user namespace. The bug made it possible for the owner of a user namespace to be present in a child user namespace. Since the owner of a user nameapce is granted all capabilities it became possible for users in a grandchild user namespace to have all privilges over their parent user namspace. Reorder the checks in cap_capable. This should make the common case faster and make it clear that nothing magic happens in the initial user namespace. The reordering is safe because cred->user_ns can only be in targ_ns or targ_ns->parent but not both. Add a comment a the top of the loop to make the logic of the code clear. Add a distinct variable ns that changes as we walk up the user namespace hierarchy to make it clear which variable is changing. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-12-14Smack: create a sysfs mount point for smackfsCasey Schaufler
There are a number of "conventions" for where to put LSM filesystems. Smack adheres to none of them. Create a mount point at /sys/fs/smackfs for mounting smackfs so that Smack can be conventional. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-12-14Smack: use select not depends in KconfigCasey Schaufler
The components NETLABEL and SECURITY_NETWORK are required by Smack. Using "depends" in Kconfig hides the Smack option if the user hasn't figured out that they need to be enabled while using make menuconfig. Using select is a better choice. Because select is not recursive depends on NET and SECURITY are added. The reflects similar usage in TOMOYO and AppArmor. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-12-14ima: support new kernel module syscallMimi Zohar
With the addition of the new kernel module syscall, which defines two arguments - a file descriptor to the kernel module and a pointer to a NULL terminated string of module arguments - it is now possible to measure and appraise kernel modules like any other file on the file system. This patch adds support to measure and appraise kernel modules in an extensible and consistent manner. To support filesystems without extended attribute support, additional patches could pass the signature as the first parameter. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-14security: introduce kernel_module_from_file hookKees Cook
Now that kernel module origins can be reasoned about, provide a hook to the LSMs to make policy decisions about the module file. This will let Chrome OS enforce that loadable kernel modules can only come from its read-only hash-verified root filesystem. Other LSMs can, for example, read extended attributes for signatures, etc. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: Eric Paris <eparis@redhat.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-12-12Merge branch 'for-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "A lot of activities on cgroup side. The big changes are focused on making cgroup hierarchy handling saner. - cgroup_rmdir() had peculiar semantics - it allowed cgroup destruction to be vetoed by individual controllers and tried to drain refcnt synchronously. The vetoing never worked properly and caused good deal of contortions in cgroup. memcg was the last reamining user. Michal Hocko removed the usage and cgroup_rmdir() path has been simplified significantly. This was done in a separate branch so that the memcg people can base further memcg changes on top. - The above allowed cleaning up cgroup lifecycle management and implementation of generic cgroup iterators which are used to improve hierarchy support. - cgroup_freezer updated to allow migration in and out of a frozen cgroup and handle hierarchy. If a cgroup is frozen, all descendant cgroups are frozen. - netcls_cgroup and netprio_cgroup updated to handle hierarchy properly. - Various fixes and cleanups. - Two merge commits. One to pull in memcg and rmdir cleanups (needed to build iterators). The other pulled in cgroup/for-3.7-fixes for device_cgroup fixes so that further device_cgroup patches can be stacked on top." Fixed up a trivial conflict in mm/memcontrol.c as per Tejun (due to commit bea8c150a7 ("memcg: fix hotplugged memory zone oops") in master touching code close to commit 2ef37d3fe4 ("memcg: Simplify mem_cgroup_force_empty_list error handling") in for-3.8) * 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (65 commits) cgroup: update Documentation/cgroups/00-INDEX cgroup_rm_file: don't delete the uncreated files cgroup: remove subsystem files when remounting cgroup cgroup: use cgroup_addrm_files() in cgroup_clear_directory() cgroup: warn about broken hierarchies only after css_online cgroup: list_del_init() on removed events cgroup: fix lockdep warning for event_control cgroup: move list add after list head initilization netprio_cgroup: allow nesting and inherit config on cgroup creation netprio_cgroup: implement netprio[_set]_prio() helpers netprio_cgroup: use cgroup->id instead of cgroup_netprio_state->prioidx netprio_cgroup: reimplement priomap expansion netprio_cgroup: shorten variable names in extend_netdev_table() netprio_cgroup: simplify write_priomap() netcls_cgroup: move config inheritance to ->css_online() and remove .broken_hierarchy marking cgroup: remove obsolete guarantee from cgroup_task_migrate. cgroup: add cgroup->id cgroup, cpuset: remove cgroup_subsys->post_clone() cgroup: s/CGRP_CLONE_CHILDREN/CGRP_CPUSET_CLONE_CHILDREN/ cgroup: rename ->create/post_create/pre_destroy/destroy() to ->css_alloc/online/offline/free() ...
2012-12-10rtnetlink: add missing message types to selinux perm tableCong Wang
Rebased on the latest net-next tree. RTM_NEWNETCONF and RTM_GETNETCONF are missing in this table. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-07bridge: export multicast database via netlinkCong Wang
V5: fix two bugs pointed out by Thomas remove seq check for now, mark it as TODO V4: remove some useless #include some coding style fix V3: drop debugging printk's update selinux perm table as well V2: drop patch 1/2, export ifindex directly Redesign netlink attributes Improve netlink seq check Handle IPv6 addr as well This patch exports bridge multicast database via netlink message type RTM_GETMDB. Similar to fdb, but currently bridge-specific. We may need to support modify multicast database too (RTM_{ADD,DEL}MDB). (Thanks to Thomas for patient reviews) Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Graf <tgraf@suug.ch> Cc: Jesper Dangaard Brouer <brouer@redhat.com> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-21selinux: fix sel_netnode_insert() suspicious rcu dereferenceDave Jones
=============================== [ INFO: suspicious RCU usage. ] 3.5.0-rc1+ #63 Not tainted ------------------------------- security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by trinity-child1/8750: #0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0 stack backtrace: Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63 Call Trace: [<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0 [<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0 [<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0 [<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0 [<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60 [<ffffffff812c9536>] security_socket_bind+0x16/0x20 [<ffffffff815550ca>] sys_bind+0x7a/0x100 [<ffffffff816c03d5>] ? sysret_check+0x22/0x5d [<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0 [<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b This patch below does what Paul McKenney suggested in the previous thread. Signed-off-by: Dave Jones <davej@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Eric Paris <eparis@parisplace.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-11-20Yama: remove locking from delete pathKees Cook
Instead of locking the list during a delete, mark entries as invalid and trigger a workqueue to clean them up. This lets us easily handle task_free from interrupt context. Signed-off-by: Kees Cook <keescook@chromium.org>
2012-11-20Yama: add RCU to drop read lockingKees Cook
Stop using spinlocks in the read path. Add RCU list to handle the readers. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: John Johansen <john.johansen@canonical.com>
2012-11-20userns: Kill task_user_nsEric W. Biederman
The task_user_ns function hides the fact that it is getting the user namespace from struct cred on the task. struct cred may go away as soon as the rcu lock is released. This leads to a race where we can dereference a stale user namespace pointer. To make it obvious a struct cred is involved kill task_user_ns. To kill the race modify the users of task_user_ns to only reference the user namespace while the rcu lock is held. Cc: Kees Cook <keescook@chromium.org> Cc: James Morris <james.l.morris@oracle.com> Acked-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-11-19cgroup: rename ->create/post_create/pre_destroy/destroy() to ↵Tejun Heo
->css_alloc/online/offline/free() Rename cgroup_subsys css lifetime related callbacks to better describe what their roles are. Also, update documentation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2012-11-06device_cgroup: add lockdep assertsTejun Heo
device_cgroup uses RCU safe ->exceptions list which is write-protected by devcgroup_mutex and has had some issues using locking correctly. Add lockdep asserts to utility functions so that future errors can be easily detected. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com>
2012-11-06device_cgroup: fix RCU usageTejun Heo
dev_cgroup->exceptions is protected with devcgroup_mutex for writes and RCU for reads; however, RCU usage isn't correct. * dev_exception_clean() doesn't use RCU variant of list_del() and kfree(). The function can race with may_access() and may_access() may end up dereferencing already freed memory. Use list_del_rcu() and kfree_rcu() instead. * may_access() may be called only with RCU read locked but doesn't use RCU safe traversal over ->exceptions. Use list_for_each_entry_rcu(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: stable@vger.kernel.org Cc: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com>
2012-11-06device_cgroup: fix unchecked cgroup parent usageAristeu Rozanski
In 4cef7299b478687 ("device_cgroup: add proper checking when changing default behavior") the cgroup parent usage is unchecked. root will not have a parent and trying to use device.{allow,deny} will cause problems. For some reason my stressing scripts didn't test the root directory so I didn't catch it on my regular tests. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-10-28Merge branch 'master' into for-nextJiri Kosina
Sync up with Linus' tree to be able to apply Cesar's patch against newer version of the code. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-25device_cgroup: add proper checking when changing default behaviorAristeu Rozanski
Before changing a group's default behavior to ALLOW, we must check if its parent's behavior is also ALLOW. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25device_cgroup: stop using simple_strtoul()Aristeu Rozanski
Convert the code to use kstrtou32() instead of simple_strtoul() which is deprecated. The real size of the variables are u32, so use kstrtou32 instead of kstrtoul Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25device_cgroup: rename deny_all to behaviorAristeu Rozanski
This was done in a v2 patch but v1 ended up being committed. The variable name is less confusing and stores the default behavior when no matching exception exists. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25cgroup: fix invalid rcu dereferenceJiri Slaby
Commit ad676077a2ae ("device_cgroup: convert device_cgroup internally to policy + exceptions") removed rcu locks which are needed in task_devcgroup called in this chain: devcgroup_inode_mknod OR __devcgroup_inode_permission -> __devcgroup_inode_permission -> task_devcgroup -> task_subsys_state -> task_subsys_state_check. Change the code so that task_devcgroup is safely called with rcu read lock held. =============================== [ INFO: suspicious RCU usage. ] 3.6.0-rc5-next-20120913+ #42 Not tainted ------------------------------- include/linux/cgroup.h:553 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by kdevtmpfs/23: #0: (sb_writers){.+.+.+}, at: [<ffffffff8116873f>] mnt_want_write+0x1f/0x50 #1: (&sb->s_type->i_mutex_key#3/1){+.+.+.}, at: [<ffffffff811558af>] kern_path_create+0x7f/0x170 stack backtrace: Pid: 23, comm: kdevtmpfs Not tainted 3.6.0-rc5-next-20120913+ #42 Call Trace: lockdep_rcu_suspicious+0xfd/0x130 devcgroup_inode_mknod+0x19d/0x240 vfs_mknod+0x71/0xf0 handle_create.isra.2+0x72/0x200 devtmpfsd+0x114/0x140 ? handle_create.isra.2+0x200/0x200 kthread+0xd6/0xe0 kernel_thread_helper+0x4/0x10 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25keys: Fix unreachable codeAlan Cox
We set ret to NULL then test it. Remove the bogus test Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-25apparmor: fix IRQ stack overflow during free_profileJohn Johansen
BugLink: http://bugs.launchpad.net/bugs/1056078 Profile replacement can cause long chains of profiles to build up when the profile being replaced is pinned. When the pinned profile is finally freed, it puts the reference to its replacement, which may in turn nest another call to free_profile on the stack. Because this may happen for each profile in the replacedby chain this can result in a recusion that causes the stack to overflow. Break this nesting by directly walking the chain of replacedby profiles (ie. use iteration instead of recursion to free the list). This results in at most 2 levels of free_profile being called, while freeing a replacedby chain. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-10-17apparmor: fix apparmor OOPS in audit_log_untrustedstring+0x1c/0x40John Johansen
The capability defines have moved causing the auto generated names of capabilities that apparmor uses in logging to be incorrect. Fix the autogenerated table source to uapi/linux/capability.h Reported-by: YanHong <clouds.yan@gmail.com> Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Analyzed-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-16fix a leak in replace_fd() usersAl Viro
replace_fd() began with "eats a reference, tries to insert into descriptor table" semantics; at some point I'd switched it to much saner current behaviour ("try to insert into descriptor table, grabbing a new reference if inserted; caller should do fput() in any case"), but forgot to update the callers. Mea culpa... [Spotted by Pavel Roskin, who has really weird system with pipe-fed coredumps as part of what he considers a normal boot ;-)] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-11consitify do_mount() argumentsAl Viro
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: use mm->exe_file instead of first VM_EXECUTABLE vma->vm_fileKonstantin Khlebnikov
Some security modules and oprofile still uses VM_EXECUTABLE for retrieving a task's executable file. After this patch they will use mm->exe_file directly. mm->exe_file is protected with mm->mmap_sem, so locking stays the same. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [arch/tile] Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> [tomoyo] Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull IMA bugfix (security subsystem) from James Morris. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: ima: fix bug in argument order
2012-10-06device_cgroup: rename whitelist to exception listAristeu Rozanski
This patch replaces the "whitelist" usage in the code and comments and replace them by exception list related information. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: convert device_cgroup internally to policy + exceptionsAristeu Rozanski
The original model of device_cgroup is having a whitelist where all the allowed devices are listed. The problem with this approach is that is impossible to have the case of allowing everything but few devices. The reason for that lies in the way the whitelist is handled internally: since there's only a whitelist, the "all devices" entry would have to be removed and replaced by the entire list of possible devices but the ones that are being denied. Since dev_t is 32 bits long, representing the allowed devices as a bitfield is not memory efficient. This patch replaces the "whitelist" by a "exceptions" list and the default policy is kept as "deny_all" variable in dev_cgroup structure. The current interface determines that whenever "a" is written to devices.allow or devices.deny, the entry masking all devices will be added or removed, respectively. This behavior is kept and it's what will determine the default policy: # cat devices.list a *:* rwm # echo a >devices.deny # cat devices.list # echo a >devices.allow # cat devices.list a *:* rwm The interface is also preserved. For example, if one wants to block only access to /dev/null: # ls -l /dev/null crw-rw-rw- 1 root root 1, 3 Jul 24 16:17 /dev/null # echo a >devices.allow # echo "c 1:3 rwm" >devices.deny # cat /dev/null cat: /dev/null: Operation not permitted # echo >/dev/null bash: /dev/null: Operation not permitted mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 r" >devices.allow # cat /dev/null # echo >/dev/null bash: /dev/null: Operation not permitted mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 rw" >devices.allow # echo >/dev/null # cat /dev/null # mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 rwm" >devices.allow # echo >/dev/null # cat /dev/null # mknod /tmp/null c 1 3 # Note that I didn't rename the functions/variables in this patch, but in the next one to make reviewing easier. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: introduce dev_whitelist_clean()Aristeu Rozanski
This function cleans all the items in a whitelist and will be used by the next patches. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: add "deny_all" in dev_cgroup structureAristeu Rozanski
deny_all will determine if the default policy is to deny all device access unless for the ones in the exception list. This variable will be used in the next patches to convert device_cgroup internally into a default policy + rules. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-05ima: fix bug in argument orderDmitry Kasatkin
mask argument goes first, then func, like ima_must_measure and ima_get_action. ima_inode_post_setattr() assumes that. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-10-04UAPI: (Scripted) Disintegrate include/asm-genericDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
