path: root/security
2011-01-26KEYS: Fix __key_link_end() quota fixup on errorDavid Howells
Fix __key_link_end()'s attempt to fix up the quota if an error occurs. There are two erroneous cases: Firstly, we always decrease the quota if the preallocated replacement keyring needs cleaning up, irrespective of whether or not we should (we may have replaced a pointer rather than adding another pointer). Secondly, we never clean up the quota if we added a pointer without the keyring storage being extended (we allocate multiple pointers at a time, even if we're not going to use them all immediately). We handle this by setting the bottom bit of the preallocation pointer in __key_link_begin() to indicate that the quota needs fixing up, which is then passed to __key_link() (which clears the whole thing) and __key_link_end(). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-24selinux: return -ENOMEM when memory allocation failsDavidlohr Bueso
Return -ENOMEM when memory allocation fails in cond_init_bool_indexes, correctly propagating error code to caller. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24trusted keys: Fix a memory leak in trusted_update().Jesper Juhl
One failure path in security/keys/trusted.c::trusted_update() does not free 'new_p' while the others do. This patch makes sure we also free it in the remaining path (if datablob_parse() returns different from Opt_update). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24encrypted-keys: rename encrypted_defined files to encryptedMimi Zohar
Rename encrypted_defined.c and encrypted_defined.h files to encrypted.c and encrypted.h, respectively. Based on request from David Howells. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-24trusted-keys: rename trusted_defined files to trustedMimi Zohar
Rename trusted_defined.c and trusted_defined.h files to trusted.c and trusted.h, respectively. Based on request from David Howells. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-21KEYS: Fix up comments in key management codeDavid Howells
Fix up comments in the key management code. No functional changes. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-21KEYS: Do some style cleanup in the key management code.David Howells
Do a bit of a style clean up in the key management code. No functional changes. Done using: perl -p -i -e 's!^/[*]*/\n!!' security/keys/*.c perl -p -i -e 's!} /[*] end [a-z0-9_]*[(][)] [*]/\n!}\n!' security/keys/*.c sed -i -s -e ": next" -e N -e 's/^\n[}]$/}/' -e t -e P -e 's/^.*\n//' -e "b next" security/keys/*.c To remove /*****/ lines, remove comments on the closing brace of a function to name the function and remove blank lines before the closing brace of a function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-19trusted-keys: avoid scattring va_end()Tetsuo Handa
We can avoid scattering va_end() within the va_start(); for (;;) { } va_end(); loop, assuming that crypto_shash_init()/crypto_shash_update() return 0 on success and negative value otherwise. Make TSS_authhmac()/TSS_checkhmac1()/TSS_checkhmac2() similar to TSS_rawhmac() by removing "va_end()/goto" from the loop. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-19trusted-keys: check for NULL before using itTetsuo Handa
TSS_rawhmac() checks for data != NULL before using it. We should do the same thing for TSS_authhmac(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-19trusted-keys: another free memory bugfixTetsuo Handa
TSS_rawhmac() forgot to call va_end()/kfree() when data == NULL and forgot to call va_end() when crypto_shash_update() < 0. Fix these bugs by escaping from the loop using "break" (rather than "return"/"goto") in order to make sure that va_end()/kfree() are always called. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-14trusted-keys: free memory bugfixMimi Zohar
Add missing kfree(td) in tpm_seal() before the return, freeing td on error paths as well. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Safford <safford@watson.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Serge Hallyn <serge@hallyn.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (30 commits) MAINTAINERS: Add tomoyo-dev-en ML. SELinux: define permissions for DCB netlink messages encrypted-keys: style and other cleanup encrypted-keys: verify datablob size before converting to binary trusted-keys: kzalloc and other cleanup trusted-keys: additional TSS return code and other error handling syslog: check cap_syslog when dmesg_restrict Smack: Transmute labels on specified directories selinux: cache sidtab_context_to_sid results SELinux: do not compute transition labels on mountpoint labeled filesystems This patch adds a new security attribute to Smack called SMACK64EXEC. It defines label that is used while task is running. SELinux: merge policydb_index_classes and policydb_index_others selinux: convert part of the sym_val_to_name array to use flex_array selinux: convert type_val_to_struct to flex_array flex_array: fix flex_array_put_ptr macro to be valid C SELinux: do not set automatic i_ino in selinuxfs selinux: rework security_netlbl_secattr_to_sid SELinux: standardize return code handling in selinuxfs.c SELinux: standardize return code handling in selinuxfs.c SELinux: standardize return code handling in policydb.c ...
2011-01-10headers: kobject.h reduxAlexey Dobriyan
Remove kobject.h from files which don't need it, notably, sched.h and fs.h. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10headers: path.h reduxAlexey Dobriyan
Remove path.h from sched.h and other files. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-01-10Merge branch 'master' into nextJames Morris
Conflicts: security/smack/smack_lsm.c Verified and added fix by Stephen Rothwell <sfr@canb.auug.org.au> Ok'd by Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-07Merge branch 'vfs-scale-working' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin * 'vfs-scale-working' of git://git.kernel.org/pub/scm/linux/kernel/git/npiggin/linux-npiggin: (57 commits) fs: scale mntget/mntput fs: rename vfsmount counter helpers fs: implement faster dentry memcmp fs: prefetch inode data in dcache lookup fs: improve scalability of pseudo filesystems fs: dcache per-inode inode alias locking fs: dcache per-bucket dcache hash locking bit_spinlock: add required includes kernel: add bl_list xfs: provide simple rcu-walk ACL implementation btrfs: provide simple rcu-walk ACL implementation ext2,3,4: provide simple rcu-walk ACL implementation fs: provide simple rcu-walk generic_check_acl implementation fs: provide rcu-walk aware permission i_ops fs: rcu-walk aware d_revalidate method fs: cache optimise dentry and inode for rcu-walk fs: dcache reduce branches in lookup path fs: dcache remove d_mounted fs: fs_struct use seqlock fs: rcu-walk for path lookup ...
2011-01-07fs: rcu-walk for path lookupNick Piggin
Perform common cases of path lookups without any stores or locking in the ancestor dentry elements. This is called rcu-walk, as opposed to the current algorithm which is a refcount based walk, or ref-walk. This results in far fewer atomic operations on every path element, significantly improving path lookup performance. It also avoids cacheline bouncing on common dentries, significantly improving scalability. The overall design is like this: * LOOKUP_RCU is set in nd->flags, which distinguishes rcu-walk from ref-walk. * Take the RCU lock for the entire path walk, starting with the acquiring of the starting path (eg. root/cwd/fd-path). So now dentry refcounts are not required for dentry persistence. * synchronize_rcu is called when unregistering a filesystem, so we can access d_ops and i_ops during rcu-walk. * Similarly take the vfsmount lock for the entire path walk. So now mnt refcounts are not required for persistence. Also we are free to perform mount lookups, and to assume dentry mount points and mount roots are stable up and down the path. * Have a per-dentry seqlock to protect the dentry name, parent, and inode, so we can load this tuple atomically, and also check whether any of its members have changed. * Dentry lookups (based on parent, candidate string tuple) recheck the parent sequence after the child is found in case anything changed in the parent during the path walk. * inode is also RCU protected so we can load d_inode and use the inode for limited things. * i_mode, i_uid, i_gid can be tested for exec permissions during path walk. * i_op can be loaded. When we reach the destination dentry, we lock it, recheck lookup sequence, and increment its refcount and mountpoint refcount. RCU and vfsmount locks are dropped. This is termed "dropping rcu-walk". If the dentry refcount does not match, we can not drop rcu-walk gracefully at the current point in the lokup, so instead return -ECHILD (for want of a better errno). This signals the path walking code to re-do the entire lookup with a ref-walk. Aside from the final dentry, there are other situations that may be encounted where we cannot continue rcu-walk. In that case, we drop rcu-walk (ie. take a reference on the last good dentry) and continue with a ref-walk. Again, if we can drop rcu-walk gracefully, we return -ECHILD and do the whole lookup using ref-walk. But it is very important that we can continue with ref-walk for most cases, particularly to avoid the overhead of double lookups, and to gain the scalability advantages on common path elements (like cwd and root). The cases where rcu-walk cannot continue are: * NULL dentry (ie. any uncached path element) * parent with d_inode->i_op->permission or ACLs * dentries with d_revalidate * Following links In future patches, permission checks and d_revalidate become rcu-walk aware. It may be possible eventually to make following links rcu-walk aware. Uncached path elements will always require dropping to ref-walk mode, at the very least because i_mutex needs to be grabbed, and objects allocated. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache rationalise dget variantsNick Piggin
dget_locked was a shortcut to avoid the lazy lru manipulation when we already held dcache_lock (lru manipulation was relatively cheap at that point). However, how that the lru lock is an innermost one, we never hold it at any caller, so the lock cost can now be avoided. We already have well working lazy dcache LRU, so it should be fine to defer LRU manipulations to scan time. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale subdirsNick Piggin
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't using dcache_lock for these anyway (eg. using i_mutex). Note: if we change the locking rule in future so that ->d_child protection is provided only with ->d_parent->d_lock, it may allow us to reduce some locking. But it would be an exception to an otherwise regular locking scheme, so we'd have to see some good results. Probably not worthwhile. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale d_unhashedNick Piggin
Protect d_unhashed(dentry) condition with d_lock. This means keeping DCACHE_UNHASHED bit in synch with hash manipulations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits) cassini: Use local-mac-address prom property for Cassini MAC address net: remove the duplicate #ifdef __KERNEL__ net: bridge: check the length of skb after nf_bridge_maybe_copy_header() netconsole: clarify stopping message netconsole: don't announce stopping if nothing happened cnic: Fix the type field in SPQ messages netfilter: fix export secctx error handling netfilter: fix the race when initializing nf_ct_expect_hash_rnd ipv4: IP defragmentation must be ECN aware net: r6040: Return proper error for r6040_init_one dcb: use after free in dcb_flushapp() dcb: unlock on error in dcbnl_ieee_get() net: ixp4xx_eth: Return proper error for eth_init_one include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel net: add POLLPRI to sock_def_readable() af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks. net_sched: pfifo_head_drop problem mac80211: remove stray extern mac80211: implement off-channel TX using hw r-o-c offload mac80211: implement hardware offload for remain-on-channel ...
2011-01-05af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks.David S. Miller
unix_release() can asynchornously set socket->sk to NULL, and it does so without holding the unix_state_lock() on "other" during stream connects. However, the reverse mapping, sk->sk_socket, is only transitioned to NULL under the unix_state_lock(). Therefore make the security hooks follow the reverse mapping instead of the forward mapping. Reported-by: Jeremy Fitzhardinge <jeremy@goop.org> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-03ima: fix add LSM rule bugMimi Zohar
If security_filter_rule_init() doesn't return a rule, then not everything is as fine as the return code implies. This bug only occurs when the LSM (eg. SELinux) is disabled at runtime. Adding an empty LSM rule causes ima_match_rules() to always succeed, ignoring any remaining rules. default IMA TCB policy: # PROC_SUPER_MAGIC dont_measure fsmagic=0x9fa0 # SYSFS_MAGIC dont_measure fsmagic=0x62656572 # DEBUGFS_MAGIC dont_measure fsmagic=0x64626720 # TMPFS_MAGIC dont_measure fsmagic=0x01021994 # SECURITYFS_MAGIC dont_measure fsmagic=0x73636673 < LSM specific rule > dont_measure obj_type=var_log_t measure func=BPRM_CHECK measure func=FILE_MMAP mask=MAY_EXEC measure func=FILE_CHECK mask=MAY_READ uid=0 Thus without the patch, with the boot parameters 'tcb selinux=0', adding the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB measurement policy, would result in nothing being measured. The patch prevents the default TCB policy from being replaced. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: David Safford <safford@watson.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/ipv4/fib_frontend.c
2010-12-23KEYS: Don't call up_write() if __key_link_begin() returns an errorDavid Howells
In construct_alloc_key(), up_write() is called in the error path if __key_link_begin() fails, but this is incorrect as __key_link_begin() only returns with the nominated keyring locked if it returns successfully. Without this patch, you might see the following in dmesg: ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- mount.cifs/5769 is trying to release lock (&key->sem) at: [<ffffffff81201159>] request_key_and_link+0x263/0x3fc but there are no more locks to release! other info that might help us debug this: 3 locks held by mount.cifs/5769: #0: (&type->s_umount_key#41/1){+.+.+.}, at: [<ffffffff81131321>] sget+0x278/0x3e7 #1: (&ret_buf->session_mutex){+.+.+.}, at: [<ffffffffa0258e59>] cifs_get_smb_ses+0x35a/0x443 [cifs] #2: (root_key_user.cons_lock){+.+.+.}, at: [<ffffffff81201000>] request_key_and_link+0x10a/0x3fc stack backtrace: Pid: 5769, comm: mount.cifs Not tainted 2.6.37-rc6+ #1 Call Trace: [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81081601>] print_unlock_inbalance_bug+0xca/0xd5 [<ffffffff81083248>] lock_release_non_nested+0xc1/0x263 [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81201159>] ? request_key_and_link+0x263/0x3fc [<ffffffff81083567>] lock_release+0x17d/0x1a4 [<ffffffff81073f45>] up_write+0x23/0x3b [<ffffffff81201159>] request_key_and_link+0x263/0x3fc [<ffffffffa026fe9e>] ? cifs_get_spnego_key+0x61/0x21f [cifs] [<ffffffff812013c5>] request_key+0x41/0x74 [<ffffffffa027003d>] cifs_get_spnego_key+0x200/0x21f [cifs] [<ffffffffa026e296>] CIFS_SessSetup+0x55d/0x1273 [cifs] [<ffffffffa02589e1>] cifs_setup_session+0x90/0x1ae [cifs] [<ffffffffa0258e7e>] cifs_get_smb_ses+0x37f/0x443 [cifs] [<ffffffffa025a9e3>] cifs_mount+0x1aa1/0x23f3 [cifs] [<ffffffff8111fd94>] ? alloc_debug_processing+0xdb/0x120 [<ffffffffa027002c>] ? cifs_get_spnego_key+0x1ef/0x21f [cifs] [<ffffffffa024cc71>] cifs_do_mount+0x165/0x2b3 [cifs] [<ffffffff81130e72>] vfs_kern_mount+0xaf/0x1dc [<ffffffff81131007>] do_kern_mount+0x4d/0xef [<ffffffff811483b9>] do_mount+0x6f4/0x733 [<ffffffff8114861f>] sys_mount+0x88/0xc2 [<ffffffff8100ac42>] system_call_fastpath+0x16/0x1b Reported-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-and-Tested-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-16SELinux: define permissions for DCB netlink messagesEric Paris
Commit 2f90b865 added two new netlink message types to the netlink route socket. SELinux has hooks to define if netlink messages are allowed to be sent or received, but it did not know about these two new message types. By default we allow such actions so noone likely noticed. This patch adds the proper definitions and thus proper permissions enforcement. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-15encrypted-keys: style and other cleanupMimi Zohar
Cleanup based on David Howells suggestions: - use static const char arrays instead of #define - rename init_sdesc to alloc_sdesc - convert 'unsigned int' definitions to 'size_t' - revert remaining 'const unsigned int' definitions to 'unsigned int' Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15encrypted-keys: verify datablob size before converting to binaryMimi Zohar
Verify the hex ascii datablob length is correct before converting the IV, encrypted data, and HMAC to binary. Reported-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15trusted-keys: kzalloc and other cleanupMimi Zohar
Cleanup based on David Howells suggestions: - replace kzalloc, where possible, with kmalloc - revert 'const unsigned int' definitions to 'unsigned int' Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-15trusted-keys: additional TSS return code and other error handlingMimi Zohar
Previously not all TSS return codes were tested, as they were all eventually caught by the TPM. Now all returns are tested and handled immediately. This patch also fixes memory leaks in error and non-error paths. Signed-off-by: David Safford <safford@watson.ibm.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-12-07Smack: Transmute labels on specified directoriesJarkko Sakkinen
In a situation where Smack access rules allow processes with multiple labels to write to a directory it is easy to get into a situation where the directory gets cluttered with files that the owner can't deal with because while they could be written to the directory a process at the label of the directory can't write them. This is generally the desired behavior, but when it isn't it is a real issue. This patch introduces a new attribute SMACK64TRANSMUTE that instructs Smack to create the file with the label of the directory under certain circumstances. A new access mode, "t" for transmute, is made available to Smack access rules, which are expanded from "rwxa" to "rwxat". If a file is created in a directory marked as transmutable and if access was granted to perform the operation by a rule that included the transmute mode, then the file gets the Smack label of the directory instead of the Smack label of the creating process. Note that this is equivalent to creating an empty file at the label of the directory and then having the other process write to it. The transmute scheme requires that both the access rule allows transmutation and that the directory be explicitly marked. Signed-off-by: Jarkko Sakkinen <ext-jarkko.2.sakkinen@nokia.com> Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2010-12-07selinux: cache sidtab_context_to_sid resultsEric Paris
sidtab_context_to_sid takes up a large share of time when creating large numbers of new inodes (~30-40% in oprofile runs). This patch implements a cache of 3 entries which is checked before we do a full context_to_sid lookup. On one system this showed over a x3 improvement in the number of inodes that could be created per second and around a 20% improvement on another system. Any time we look up the same context string sucessivly (imagine ls -lZ) we should hit this cache hot. A cache miss should have a relatively minor affect on performance next to doing the full table search. All operations on the cache are done COMPLETELY lockless. We know that all struct sidtab_node objects created will never be deleted until a new policy is loaded thus we never have to worry about a pointer being dereferenced. Since we also know that pointer assignment is atomic we know that the cache will always have valid pointers. Given this information we implement a FIFO cache in an array of 3 pointers. Every result (whether a cache hit or table lookup) will be places in the 0 spot of the cache and the rest of the entries moved down one spot. The 3rd entry will be lost. Races are possible and are even likely to happen. Lets assume that 4 tasks are hitting sidtab_context_to_sid. The first task checks against the first entry in the cache and it is a miss. Now lets assume a second task updates the cache with a new entry. This will push the first entry back to the second spot. Now the first task might check against the second entry (which it already checked) and will miss again. Now say some third task updates the cache and push the second entry to the third spot. The first task my check the third entry (for the third time!) and again have a miss. At which point it will just do a full table lookup. No big deal! Signed-off-by: Eric Paris <eparis@redhat.com>
2010-12-02SELinux: do not compute transition labels on mountpoint labeled filesystemsEric Paris
selinux_inode_init_security computes transitions sids even for filesystems that use mount point labeling. It shouldn't do that. It should just use the mount point label always and no matter what. This causes 2 problems. 1) it makes file creation slower than it needs to be since we calculate the transition sid and 2) it allows files to be created with a different label than the mount point! # id -Z staff_u:sysadm_r:sysadm_t:s0-s0:c0.c1023 # sesearch --type --class file --source sysadm_t --target tmp_t Found 1 semantic te rules: type_transition sysadm_t tmp_t : file user_tmp_t; # mount -o loop,context="system_u:object_r:tmp_t:s0" /tmp/fs /mnt/tmp # ls -lZ /mnt/tmp drwx------. root root system_u:object_r:tmp_t:s0 lost+found # touch /mnt/tmp/file1 # ls -lZ /mnt/tmp -rw-r--r--. root root staff_u:object_r:user_tmp_t:s0 file1 drwx------. root root system_u:object_r:tmp_t:s0 lost+found Whoops, we have a mount point labeled filesystem tmp_t with a user_tmp_t labeled file! Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Reviewed-by: James Morris <jmorris@namei.org>
2010-12-02This patch adds a new security attribute to Smack calledCasey Schaufler
SMACK64EXEC. It defines label that is used while task is running. Exception: in smack_task_wait() child task is checked for write access to parent task using label inherited from the task that forked it. Fixed issues from previous submit: - SMACK64EXEC was not read when SMACK64 was not set. - inode security blob was not updated after setting SMACK64EXEC - inode security blob was not updated when removing SMACK64EXEC
2010-11-30SELinux: merge policydb_index_classes and policydb_index_othersEric Paris
We duplicate functionality in policydb_index_classes() and policydb_index_others(). This patch merges those functions just to make it clear there is nothing special happening here. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30selinux: convert part of the sym_val_to_name array to use flex_arrayEric Paris
The sym_val_to_name type array can be quite large as it grows linearly with the number of types. With known policies having over 5k types these allocations are growing large enough that they are likely to fail. Convert those to flex_array so no allocation is larger than PAGE_SIZE Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30selinux: convert type_val_to_struct to flex_arrayEric Paris
In rawhide type_val_to_struct will allocate 26848 bytes, an order 3 allocations. While this hasn't been seen to fail it isn't outside the realm of possibiliy on systems with severe memory fragmentation. Convert to flex_array so no allocation will ever be bigger than PAGE_SIZE. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30SELinux: do not set automatic i_ino in selinuxfsEric Paris
selinuxfs carefully uses i_ino to figure out what the inode refers to. The VFS used to generically set this value and we would reset it to something useable. After 85fe4025c616 each filesystem sets this value to a default if needed. Since selinuxfs doesn't use the default value and it can only lead to problems (I'd rather have 2 inodes with i_ino == 0 than one pointing to the wrong data) lets just stop setting a default. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <jmorris@namei.org>
2010-11-30selinux: rework security_netlbl_secattr_to_sidEric Paris
security_netlbl_secattr_to_sid is difficult to follow, especially the return codes. Try to make the function obvious. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30SELinux: standardize return code handling in selinuxfs.cEric Paris
selinuxfs.c has lots of different standards on how to handle return paths on error. For the most part transition to rc=errno if (failure) goto out; [...] out: cleanup() return rc; Instead of doing cleanup mid function, or having multiple returns or other options. This doesn't do that for every function, but most of the complex functions which have cleanup routines on error. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30SELinux: standardize return code handling in policydb.cEric Paris
policydb.c has lots of different standards on how to handle return paths on error. For the most part transition to rc=errno if (failure) goto out; [...] out: cleanup() return rc; Instead of doing cleanup mid function, or having multiple returns or other options. This doesn't do that for every function, but most of the complex functions which have cleanup routines on error. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-11-30keys: add missing include file for trusted and encrypted keysMimi Zohar
This patch fixes the linux-next powerpc build errors as reported by Stephen Rothwell. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Tested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29Smack: UDS revisionCasey Schaufler
This patch addresses a number of long standing issues with the way Smack treats UNIX domain sockets. All access control was being done based on the label of the file system object. This is inconsistant with the internet domain, in which access is done based on the IPIN and IPOUT attributes of the socket. As a result of the inode label policy it was not possible to use a UDS socket for label cognizant services, including dbus and the X11 server. Support for SCM_PEERSEC on UDS sockets is also provided. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29keys: add new key-type encryptedMimi Zohar
Define a new kernel key-type called 'encrypted'. Encrypted keys are kernel generated random numbers, which are encrypted/decrypted with a 'trusted' symmetric key. Encrypted keys are created/encrypted/decrypted in the kernel. Userspace only ever sees/stores encrypted blobs. Changelog: - bug fix: replaced master-key rcu based locking with semaphore (reported by David Howells) - Removed memset of crypto_shash_digest() digest output - Replaced verification of 'key-type:key-desc' using strcspn(), with one based on string constants. - Moved documentation to Documentation/keys-trusted-encrypted.txt - Replace hash with shash (based on comments by David Howells) - Make lengths/counts size_t where possible (based on comments by David Howells) Could not convert most lengths, as crypto expects 'unsigned int' (size_t: on 32 bit is defined as unsigned int, but on 64 bit is unsigned long) - Add 'const' where possible (based on comments by David Howells) - allocate derived_buf dynamically to support arbitrary length master key (fixed by Roberto Sassu) - wait until late_initcall for crypto libraries to be registered - cleanup security/Kconfig - Add missing 'update' keyword (reported/fixed by Roberto Sassu) - Free epayload on failure to create key (reported/fixed by Roberto Sassu) - Increase the data size limit (requested by Roberto Sassu) - Crypto return codes are always 0 on success and negative on failure, remove unnecessary tests. - Replaced kzalloc() with kmalloc() Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: David Safford <safford@watson.ibm.com> Reviewed-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: James Morris <jmorris@namei.org>
2010-11-29keys: add new trusted key-typeMimi Zohar
Define a new kernel key-type called 'trusted'. Trusted keys are random number symmetric keys, generated and RSA-sealed by the TPM. The TPM only unseals the keys, if the boot PCRs and other criteria match. Userspace can only ever see encrypted blobs. Based on suggestions by Jason Gunthorpe, several new options have been added to support additional usages. The new options are: migratable= designates that the key may/may not ever be updated (resealed under a new key, new pcrinfo or new auth.) pcrlock=n extends the designated PCR 'n' with a random value, so that a key sealed to that PCR may not be unsealed again until after a reboot. keyhandle= specifies the sealing/unsealing key handle. keyauth= specifies the sealing/unsealing key auth. blobauth= specifies the sealed data auth. Implementation of a kernel reserved locality for trusted keys will be investigated for a possible future extension. Changelog: - Updated and added examples to Documentation/keys-trusted-encrypted.txt - Moved generic TPM constants to include/linux/tpm_command.h (David Howell's suggestion.) - trusted_defined.c: replaced kzalloc with kmalloc, added pcrlock failure error handling, added const qualifiers where appropriate. - moved to late_initcall - updated from hash to shash (suggestion by David Howells) - reduced worst stack usage (tpm_seal) from 530 to 312 bytes - moved documentation to Documentation directory (suggestion by David Howells) - all the other code cleanups suggested by David Howells - Add pcrlock CAP_SYS_ADMIN dependency (based on comment by Jason Gunthorpe) - New options: migratable, pcrlock, keyhandle, keyauth, blobauth (based on discussions with Jason Gunthorpe) - Free payload on failure to create key(reported/fixed by Roberto Sassu) - Updated Kconfig and other descriptions (based on Serge Hallyn's suggestion) - Replaced kzalloc() with kmalloc() (reported by Serge Hallyn) Signed-off-by: David Safford <safford@watson.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
