commit 09c50b4a52c01a1f450b8eec819089e228655bfb upstream.
At some point we (okay, I) managed to break the ability for users to use the
setsockopt() syscall to set IPv4 options when NetLabel was not active on the
socket in question. The problem was noticed by someone trying to use the
"-R" (record route) option of ping:
# ping -R 10.0.0.1
ping: record route: No message of desired type
The solution is relatively simple, we catch the unlabeled socket case and
clear the error code, allowing the operation to succeed. Please note that we
still deny users the ability to override IPv4 options on socket's which have
NetLabel labeling active; this is done to ensure the labeling remains intact.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: James Morris <jmorris@namei.org>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit d7f59dc4642ce2fc7b79fcd4ec02ffce7f21eb02 upstream.
Rick McNeal from LSI identified a panic in selinux_netlbl_inode_permission()
caused by a certain sequence of SUNRPC operations. The problem appears to be
due to the lack of NULL pointer checking in the function; this patch adds the
pointer checks so the function will exit safely in the cases where the socket
is not completely initialized.
commit 0d54ee1c7850a954026deec4cd4885f331da35cc upstream.
Plug this leak.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
commit 938bb9f5e840eddbf54e4f62f6c5ba9b3ae12c9d upstream.
commit 1e7bfb2134dfec37ce04fb3a4ca89299e892d10c upstream.
commit 0b82ac37b889ec881b645860da3775118effb3ca upstream.
The devcgroup_inode_permission() hook in the devices whitelist cgroup has
always bypassed access checks on fifos. But the mknod hook did not. The
devices whitelist is only about block and char devices, and fifos can't
even be added to the whitelist, so fifos can't be created at all except by
tasks which have 'a' in their whitelist (meaning they have access to all
devices).
Fix the behavior by bypassing access checks to mkfifo.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Paul Menage <menage@google.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Reported-by: Daniel Lezcano <dlezcano@fr.ibm.com>
Make request_key() instantiate the per-user keyrings so that it doesn't oops
if it needs to get hold of the user session keyring because there isn't a
session keyring in place.
Tested-by: Steve French <smfrench@gmail.com>
Tested-by: Rutger Nijlunsing <rutger.nijlunsing@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
SELinux: properly handle empty tty_files list
While Linux doesn't honor setuid on scripts. However, it mistakenly
behaves differently for file capabilities.
This patch fixes that behavior by making sure that get_file_caps()
begins with empty bprm->caps_*. That way when a script is loaded,
its bprm->caps_* may be filled when binfmt_misc calls prepare_binprm(),
but they will be cleared again when binfmt_elf calls prepare_binprm()
next to read the interpreter's file capabilities.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Acked-by: Andrew G. Morgan <morgan@kernel.org>
SELinux has wrongly (since 2004) had an incorrect test for an empty
tty->tty_files list. With an empty list selinux would be pointing to part
of the tty struct itself and would then proceed to dereference that value
and again dereference that result. An F10 change to plymouth on a ppc64
system is actually currently triggering this bug. This patch uses
list_empty() to handle empty lists rather than looking at a meaningless
location.
[note, this fixes the oops reported in
https://bugzilla.redhat.com/show_bug.cgi?id=469079]
Signed-off-by: Eric Paris <eparis@redhat.com>
Junjiro R. Okajima reported a problem where knfsd crashes if you are
using it to export shmemfs objects and run strict overcommit. In this
situation the current->mm based modifier to the overcommit goes through a
NULL pointer.
We could simply check for NULL and skip the modifier but we've caught
other real bugs in the past from mm being NULL here - cases where we did
need a valid mm set up (eg the exec bug about a year ago).
To preserve the checks and get the logic we want shuffle the checking
around and add a new helper to the vm_ security wrappers
Also fix a current->mm reference in nommu that should use the passed mm
[akpm@linux-foundation.org: fix build]
Reported-by: Junjiro R. Okajima <hooanon05@yahoo.co.jp>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Alan Cox <alan@redhat.com>
* 'v28-timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
fix documentation of sysrq-q really
Fix documentation of sysrq-q
timer_list: add base address to clock base
timer_list: print cpu number of clockevents device
timer_list: print real timer address
NOHZ: restart tick device from irq_enter()
NOHZ: split tick_nohz_restart_sched_tick()
NOHZ: unify the nohz function calls in irq_enter()
timers: fix itimer/many thread hang, fix
timers: fix itimer/many thread hang, v3
ntp: improve adjtimex frequency rounding
timekeeping: fix rounding problem during clock update
ntp: let update_persistent_clock() sleep
hrtimer: reorder struct hrtimer to save 8 bytes on 64bit builds
posix-timers: lock_timer: make it readable
posix-timers: lock_timer: kill the bogus ->it_id check
posix-timers: kill ->it_sigev_signo and ->it_sigev_value
posix-timers: sys_timer_create: cleanup the error handling
posix-timers: move the initialization of timer->sigq from send to create path
posix-timers: sys_timer_create: simplify and s/tasklist/rcu/
Fix trivial conflicts due to sysrq-q description clahes in
Documentation/sysrq.txt and drivers/char/sysrq.c
Since we introduced rcu for read side, spin_lock is used only for update.
But we always hold cgroup_lock() when update, so spin_lock() is not need.
Additional cleanup:
1) include linux/rcupdate.h explicitly
2) remove unused variable cur_devcgroup in devcgroup_update_access()
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
This saves 40 bytes on my x86_32 box.
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
This is a much better version of a previous patch to make the parser
tables constant. Rather than changing the typedef, we put the "const" in
all the various places where its required, allowing the __initconst
exception for nfsroot which was the cause of the previous trouble.
This was posted for review some time ago and I believe its been in -mm
since then.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Alexander Viro <aviro@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (24 commits)
integrity: special fs magic
As pointed out by Jonathan Corbet, the timer must be deleted before
ERROR: code indent should use tabs where possible
The tpm_dev_release function is only called for platform devices, not pnp
Protect tpm_chip_list when transversing it.
Renames num_open to is_open, as only one process can open the file at a time.
Remove the BKL calls from the TPM driver, which were added in the overall
netlabel: Add configuration support for local labeling
cipso: Add support for native local labeling and fixup mapping names
netlabel: Changes to the NetLabel security attributes to allow LSMs to pass full contexts
selinux: Cache NetLabel secattrs in the socket's security struct
selinux: Set socket NetLabel based on connection endpoint
netlabel: Add functionality to set the security attributes of a packet
netlabel: Add network address selectors to the NetLabel/LSM domain mapping
netlabel: Add a generic way to create ordered linked lists of network addrs
netlabel: Replace protocol/NetLabel linking with refrerence counts
smack: Fix missing calls to netlbl_skbuff_err()
selinux: Fix missing calls to netlbl_skbuff_err()
selinux: Fix a problem in security_netlbl_sid_to_secattr()
selinux: Better local/forward check in selinux_ip_postroute()
Currently it is sometimes locked by the tty mutex and sometimes by the
sighand lock. The latter is in fact correct and now we can hand back referenced
objects we can fix this up without problems around sleeping functions.
We now return a kref covered tty reference. That ensures the tty structure
doesn't go away when you have a return from get_current_tty. This is not
enough to protect you from most of the resources being freed behind your
back - yet.
[Updated to include fixes for SELinux problems found by Andrew Morton and
an s390 leak found while debugging the former]
Discussion on the mailing list questioned the use of these
magic values in userspace, concluding these values are already
exported to userspace via statfs and their correct/incorrect
usage is left up to the userspace application.
- Move special fs magic number definitions to magic.h
- Add magic.h include
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Reviewed-by: James Morris <jmorris@namei.org>
git://git.infradead.org/users/pcmoore/lblnet-2.6_next into next
full contexts
This patch provides support for including the LSM's secid in addition to
the LSM's MLS information in the NetLabel security attributes structure.
Previous work enabled the use of address based NetLabel selectors, which
while highly useful, brought the potential for additional per-packet overhead
when used. This patch attempts to mitigate some of that overhead by caching
the NetLabel security attribute struct within the SELinux socket security
structure. This should help eliminate the need to recreate the NetLabel
secattr structure for each packet resulting in less overhead.
Previous work enabled the use of address based NetLabel selectors, which while
highly useful, brought the potential for additional per-packet overhead when
used. This patch attempts to solve that by applying NetLabel socket labels
when sockets are connect()'d. This should alleviate the per-packet NetLabel
labeling for all connected sockets (yes, it even works for connected DGRAM
sockets).
This patch builds upon the new NetLabel address selector functionality by
providing the NetLabel KAPI and CIPSO engine support needed to enable the
new packet-based labeling. The only new addition to the NetLabel KAPI at
this point is shown below:
* int netlbl_skbuff_setattr(skb, family, secattr)
... and is designed to be called from a Netfilter hook after the packet's
IP header has been populated such as in the FORWARD or LOCAL_OUT hooks.
This patch also provides the necessary SELinux hooks to support this new
functionality. Smack support is not currently included due to uncertainty
regarding the permissions needed to expand the Smack network access controls.
NetLabel has always had a list of backpointers in the CIPSO DOI definition
structure which pointed to the NetLabel LSM domain mapping structures which
referenced the CIPSO DOI struct. The rationale for this was that when an
administrator removed a CIPSO DOI from the system all of the associated
NetLabel LSM domain mappings should be removed as well; a list of
backpointers made this a simple operation.
Unfortunately, while the backpointers did make the removal easier they were
a bit of a mess from an implementation point of view which was making
further development difficult. Since the removal of a CIPSO DOI is a
realtively rare event it seems to make sense to remove this backpointer
list as the optimization was hurting us more then it was helping. However,
we still need to be able to track when a CIPSO DOI definition is being used
so replace the backpointer list with a reference count. In order to
preserve the current functionality of removing the associated LSM domain
mappings when a CIPSO DOI is removed we walk the LSM domain mapping table,
removing the relevant entries.
Smack needs to call netlbl_skbuff_err() to let NetLabel do the necessary
protocol specific error handling.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
At some point I think I messed up and dropped the calls to netlbl_skbuff_err()
which are necessary for CIPSO to send error notifications to remote systems.
This patch re-introduces the error handling calls into the SELinux code.
Currently when SELinux fails to allocate memory in
security_netlbl_sid_to_secattr() the NetLabel LSM domain field is set to
NULL which triggers the default NetLabel LSM domain mapping which may not
always be the desired mapping. This patch fixes this by returning an error
when the kernel is unable to allocate memory. This could result in more
failures on a system with heavy memory pressure but it is the "correct"
thing to do.
It turns out that checking to see if skb->sk is NULL is not a very good
indicator of a forwarded packet as some locally generated packets also have
skb->sk set to NULL. Fix this by not only checking the skb->sk field but also
the IP[6]CB(skb)->flags field for the IP[6]SKB_FORWARDED flag. While we are
at it, we are calling selinux_parse_skb() much earlier than we really should
resulting in potentially wasted cycles parsing packets for information we
might no use; so shuffle the code around a bit to fix this.
We did the right thing in a few cases but there were several areas where we
determined a packet's address family based on the socket's address family which
is not the right thing to do since we can get IPv4 packets on IPv6 sockets.
This patch fixes these problems by either taking the address family directly
from the packet.
We were doing a lot of extra work in selinux_netlbl_sock_graft() what wasn't
necessary so this patch removes that code. It also removes the redundant
second argument to selinux_netlbl_sock_setsid() which allows us to simplify a
few other functions.
At some point during the 2.6.27 development cycle two new fields were added
to the SELinux context structure, a string pointer and a length field. The
code in selinux_secattr_to_sid() was not modified and as a result these two
fields were left uninitialized which could result in erratic behavior,
including kernel panics, when NetLabel is used. This patch fixes the
problem by fully initializing the context in selinux_secattr_to_sid() before
use and reducing the level of direct context manipulation done to help
prevent future problems.
Please apply this to the 2.6.27-rcX release stream.
As we are not concerned with fine-grained control over reading of
symlinks in proc, always use the default proc SID for all proc symlinks.
This should help avoid permission issues upon changes to the proc tree
as in the /proc/net -> /proc/self/net example.
This does not alter labeling of symlinks within /proc/pid directories.
ls -Zd /proc/net output before and after the patch should show the difference.
Signed-off-by: Stephen D. Smalley <sds@tycho.nsa.gov>
This reduces the kernel size by 289 bytes.
MAINTAINERS
Thanks for breaking my tree :-)
Overview
This patch reworks the handling of POSIX CPU timers, including the
ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together
with the help of Roland McGrath, the owner and original writer of this code.
The problem we ran into, and the reason for this rework, has to do with using
a profiling timer in a process with a large number of threads. It appears
that the performance of the old implementation of run_posix_cpu_timers() was
at least O(n*3) (where "n" is the number of threads in a process) or worse.
Everything is fine with an increasing number of threads until the time taken
for that routine to run becomes the same as or greater than the tick time, at
which point things degrade rather quickly.
This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF."
Code Changes
This rework corrects the implementation of run_posix_cpu_timers() to make it
run in constant time for a particular machine. (Performance may vary between
one machine and another depending upon whether the kernel is built as single-
or multiprocessor and, in the latter case, depending upon the number of
running processors.) To do this, at each tick we now update fields in
signal_struct as well as task_struct. The run_posix_cpu_timers() function
uses those fields to make its decisions.
We define a new structure, "task_cputime," to contain user, system and
scheduler times and use these in appropriate places:
struct task_cputime {
cputime_t utime;
cputime_t stime;
unsigned long long sum_exec_runtime;
This is included in the structure "thread_group_cputime," which is a new
substructure of signal_struct and which varies for uniprocessor versus
multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as
a simple substructure, while for multiprocessor kernels it is a pointer:
struct thread_group_cputime {
struct task_cputime totals;
struct task_cputime *totals;
We also add a new task_cputime substructure directly to signal_struct, to
cache the earliest expiration of process-wide timers, and task_cputime also
replaces the it_*_expires fields of task_struct (used for earliest expiration
of thread timers). The "thread_group_cputime" structure contains process-wide
timers that are updated via account_user_time() and friends. In the non-SMP
case the structure is a simple aggregator; unfortunately in the SMP case that
simplicity was not achievable due to cache-line contention between CPUs (in
one measured case performance was actually _worse_ on a 16-cpu system than
the same test on a 4-cpu system, due to this contention). For SMP, the
thread_group_cputime counters are maintained as a per-cpu structure allocated
using alloc_percpu(). The timer functions update only the timer field in
the structure corresponding to the running CPU, obtained using per_cpu_ptr().
We define a set of inline functions in sched.h that we use to maintain the
thread_group_cputime structure and hide the differences between UP and SMP
implementations from the rest of the kernel. The thread_group_cputime_init()
function initializes the thread_group_cputime structure for the given task.
The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the
out-of-line function thread_group_cputime_alloc_smp() to allocate and fill
in the per-cpu structures and fields. The thread_group_cputime_free()
function, also a no-op for UP, in SMP frees the per-cpu structures. The
thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls
thread_group_cputime_alloc() if the per-cpu structures haven't yet been
allocated. The thread_group_cputime() function fills the task_cputime
structure it is passed with the contents of the thread_group_cputime fields;
in UP it's that simple but in SMP it must also safely check that tsk->signal
is non-NULL (if it is it just uses the appropriate fields of task_struct) and,
if so, sums the per-cpu values for each online CPU. Finally, the three
functions account_group_user_time(), account_group_system_time() and
account_group_exec_runtime() are used by timer functions to update the
respective fields of the thread_group_cputime structure.
Non-SMP operation is trivial and will not be mentioned further.
The per-cpu structure is always allocated when a task creates its first new
thread, via a call to thread_group_cputime_clone_thread() from copy_signal().
It is freed at process exit via a call to thread_group_cputime_free() from
cleanup_signal().
All functions that formerly summed utime/stime/sum_sched_runtime values from
from all threads in the thread group now use thread_group_cputime() to
snapshot the values in the thread_group_cputime structure or the values in
the task structure itself if the per-cpu structure hasn't been allocated.
Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit.
The run_posix_cpu_timers() function has been split into a fast path and a
slow path; the former safely checks whether there are any expired thread
timers and, if not, just returns, while the slow path does the heavy lifting.
With the dedicated thread group fields, timers are no longer "rebalanced" and
the process_timer_rebalance() function and related code has gone away. All
summing loops are gone and all code that used them now uses the
thread_group_cputime() inline. When process-wide timers are set, the new
task_cputime structure in signal_struct is used to cache the earliest
expiration; this is checked in the fast path.
Performance
The fix appears not to add significant overhead to existing operations. It
generally performs the same as the current code except in two cases, one in
which it performs slightly worse (Case 5 below) and one in which it performs
very significantly better (Case 2 below). Overall it's a wash except in those
two cases.
I've since done somewhat more involved testing on a dual-core Opteron system.
Case 1: With no itimer running, for a test with 100,000 threads, the fixed
kernel took 1428.5 seconds, 513 seconds more than the unfixed system,
all of which was spent in the system. There were twice as many
voluntary context switches with the fix as without it.
Case 2: With an itimer running at .01 second ticks and 4000 threads (the most
an unmodified kernel can handle), the fixed kernel ran the test in
eight percent of the time (5.8 seconds as opposed to 70 seconds) and
had better tick accuracy (.012 seconds per tick as opposed to .023
seconds per tick).
Case 3: A 4000-thread test with an initial timer tick of .01 second and an
interval of 10,000 seconds (i.e. a timer that ticks only once) had
very nearly the same performance in both cases: 6.3 seconds elapsed
for the fixed kernel versus 5.5 seconds for the unfixed kernel.
With fewer threads (eight in these tests), the Case 1 test ran in essentially
the same time on both the modified and unmodified kernels (5.2 seconds versus
5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds
versus 5.4 seconds but again with much better tick accuracy, .013 seconds per
tick versus .025 seconds per tick for the unmodified kernel.
Since the fix affected the rlimit code, I also tested soft and hard CPU limits.
Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer
running), the modified kernel was very slightly favored in that while
it killed the process in 19.997 seconds of CPU time (5.002 seconds of
wall time), only .003 seconds of that was system time, the rest was
user time. The unmodified kernel killed the process in 20.001 seconds
of CPU (5.014 seconds of wall time) of which .016 seconds was system
time. Really, though, the results were too close to call. The results
were essentially the same with no itimer running.
Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds
(where the hard limit would never be reached) and an itimer running,
the modified kernel exhibited worse tick accuracy than the unmodified
kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise,
performance was almost indistinguishable. With no itimer running this
test exhibited virtually identical behavior and times in both cases.
In times past I did some limited performance testing. those results are below.
On a four-cpu Opteron system without this fix, a sixteen-thread test executed
in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On
the same system with the fix, user and elapsed time were about the same, but
system time dropped to 0.007 seconds. Performance with eight, four and one
thread were comparable. Interestingly, the timer ticks with the fix seemed
more accurate: The sixteen-thread test with the fix received 149543 ticks
for 0.024 seconds per tick, while the same test without the fix received 58720
for 0.061 seconds per tick. Both cases were configured for an interval of
0.01 seconds. Again, the other tests were comparable. Each thread in this
test computed the primes up to 25,000,000.
I also did a test with a large number of threads, 100,000 threads, which is
impossible without the fix. In this case each thread computed the primes only
up to 10,000 (to make the runtime manageable). System time dominated, at
1546.968 seconds out of a total 2176.906 seconds (giving a user time of
629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite
accurate. There is obviously no comparable test without the fix.
Signed-off-by: Frank Mayhar <fmayhar@google.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Update the SELinux entry in MAINTAINERS and drop the obsolete information
from the selinux Kconfig help text.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Fix a bug and a philosophical decision about who handles errors.
security_context_to_sid_core() was leaking a context in the common case.
This was causing problems on fedora systems which recently have started
making extensive use of this function.
In discussion it was decided that if string_to_context_struct() had an
error it was its own responsibility to clean up any mess it created
along the way.
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
During the use of a dev_cgroup, we should guarantee the corresponding
cgroup won't be deleted (i.e. via rmdir). This can be done through
css_get(&dev_cgroup->css), but here we can just get and use the dev_cgroup
under rcu_read_lock.
And also remove checking NULL dev_cgroup, it won't be NULL since a task
always belongs to a cgroup.
The purpose of this patch is to assign per-thread security context
under a constraint. It enables multi-threaded server application
to kick a request handler with its fair security context, and
helps some of userspace object managers to handle user's request.
When we assign a per-thread security context, it must not have wider
permissions than the original one. Because a multi-threaded process
shares a single local memory, an arbitary per-thread security context
also means another thread can easily refer violated information.
The constraint on a per-thread security context requires a new domain
has to be equal or weaker than its original one, when it tries to assign
a per-thread security context.
Bounds relationship between two types is a way to ensure a domain can
never have wider permission than its bounds. We can define it in two
explicit or implicit ways.
The first way is using new TYPEBOUNDS statement. It enables to define
a boundary of types explicitly. The other one expand the concept of
existing named based hierarchy. If we defines a type with "." separated
name like "httpd_t.php", toolchain implicitly set its bounds on "httpd_t".
This feature requires a new policy version.
The 24th version (POLICYDB_VERSION_BOUNDARY) enables to ship them into
kernel space, and the following patch enables to handle it.
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
Add a new Kconfig option SECURITYFS which will build securityfs support
but does not require CONFIG_SECURITY. The only current user of
securityfs does not depend on CONFIG_SECURITY and there is no reason the
full LSM needs to be built to build this fs.
Add security/inode.c functions to the kernel-api docbook.
Use '%' on constants in kernel-doc notation.
Fix several typos/spellos in security function descriptions.
Replace "thing != NULL" comparisons with just "thing" to make
the code look more uniform (mixed styles were used even in the
same source file).
Signed-off-by: Vesa-Matti Kari <vmkari@cc.helsinki.fi>
Fix the setting of PF_SUPERPRIV by __capable() as it could corrupt the flags
the target process if that is not the current process and it is trying to
change its own flags in a different way at the same time.
__capable() is using neither atomic ops nor locking to protect t->flags. This
patch removes __capable() and introduces has_capability() that doesn't set
PF_SUPERPRIV on the process being queried.
This patch further splits security_ptrace() in two:
(1) security_ptrace_may_access(). This passes judgement on whether one
process may access another only (PTRACE_MODE_ATTACH for ptrace() and
PTRACE_MODE_READ for /proc), and takes a pointer to the child process.
current is the parent.
(2) security_ptrace_traceme(). This passes judgement on PTRACE_TRACEME only,
and takes only a pointer to the parent process. current is the child.
In Smack and commoncap, this uses has_capability() to determine whether
the parent will be permitted to use PTRACE_ATTACH if normal checks fail.
This does not set PF_SUPERPRIV.
Two of the instances of __capable() actually only act on current, and so have
been changed to calls to capable().
Of the places that were using __capable():
(1) The OOM killer calls __capable() thrice when weighing the killability of a
process. All of these now use has_capability().
(2) cap_ptrace() and smack_ptrace() were using __capable() to check to see
whether the parent was allowed to trace any process. As mentioned above,
these have been split. For PTRACE_ATTACH and /proc, capable() is now
used, and for PTRACE_TRACEME, has_capability() is used.
(3) cap_safe_nice() only ever saw current, so now uses capable().
(4) smack_setprocattr() rejected accesses to tasks other than current just
after calling __capable(), so the order of these two tests have been
switched and capable() is used instead.
(5) In smack_file_send_sigiotask(), we need to allow privileged processes to
receive SIGIO on files they're manipulating.
(6) In smack_task_wait(), we let a process wait for a privileged process,
whether or not the process doing the waiting is privileged.
I've tested this with the LTP SELinux and syscalls testscripts.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
expr_isvalid() in conditional.c was off-by-one and allowed
invalid expression type COND_LAST. However, it is this header file
that needs to be fixed. That way the if-statement's disjunction's
second component reads more naturally, "if expr type is greater than
the last allowed value" ( rather than using ">=" in conditional.c):
if (expr->expr_type <= 0 || expr->expr_type > COND_LAST)
There have been a number of requests to make the Smack LSM
enforce MAC even in the face of privilege, either capability
based or superuser based. This is not universally desired,
however, so it seems desirable to make it optional. Further,
at least one legacy OS implemented a scheme whereby only
processes running with one particular label could be exempt
from MAC. This patch supports these three cases.
If /smack/onlycap is empty (unset or null-string) privilege
is enforced in the normal way.
If /smack/onlycap contains a label only processes running with
that label may be MAC exempt.
If the label in /smack/onlycap is the star label ("*") the
semantics of the star label combine with the privilege
restrictions to prevent any violations of MAC, even in the
presence of privilege.
Again, this will be independent of the privilege scheme.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
