path: root/security
2008-04-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] get rid of __exit_files(), __exit_fs() and __put_fs_struct() [PATCH] proc_readfd_common() race fix [PATCH] double-free of inode on alloc_file() failure exit in create_write_pipe() [PATCH] teach seq_file to discard entries [PATCH] umount_tree() will unhash everything itself [PATCH] get rid of more nameidata passing in namespace.c [PATCH] switch a bunch of LSM hooks from nameidata to path [PATCH] lock exclusively in collect_mounts() and drop_collected_mounts() [PATCH] move a bunch of declarations to fs/internal.h
2008-04-22SELinux fixups needed for preemptable RCU from -rtPaul E. McKenney
The attached patch needs to move from -rt to mainline given preemptable RCU. This patch fixes SELinux code that implicitly assumes that disabling preemption prevents an RCU grace period from completing, an assumption that is valid for Classic RCU, but not necessarily for preemptable RCU. Explicit rcu_read_lock() calls are thus added. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21[PATCH] switch a bunch of LSM hooks from nameidata to pathAl Viro
Namely, ones from namespace.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-22SELinux: no BUG_ON(!ss_initialized) in selinux_clone_mnt_optsEric Paris
The Fedora installer actually makes multiple NFS mounts before it loads selinux policy. The code in selinux_clone_mnt_opts() assumed that the init process would always be loading policy before NFS was up and running. It might be possible to hit this in a diskless environment as well, I'm not sure. There is no need to BUG_ON() in this situation since we can safely continue given the circumstances. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6: SELinux: one little, two little, three little whitespaces, the avc.c saga. SELinux: cleanup on isle selinuxfs.c changing whitespace for fun and profit: policydb.c SELinux: whitespace and formating fixes for hooks.c SELinux: clean up printks SELinux: sidtab.c whitespace, syntax, and static declaraction cleanups SELinux: services.c whitespace, syntax, and static declaraction cleanups SELinux: mls.c whitespace, syntax, and static declaraction cleanups SELinux: hashtab.c whitespace, syntax, and static declaraction cleanups SELinux: ebitmap.c whitespace, syntax, and static declaraction cleanups SELinux: conditional.c whitespace, syntax, and static declaraction cleanups SELinux: avtab.c whitespace, syntax, and static declaraction cleanups SELinux: xfrm.c whitespace, syntax, and static declaraction cleanups SELinux: nlmsgtab.c whitespace, syntax, and static declaraction cleanups SELinux: netnode.c whitespace, syntax, and static declaraction cleanups SELinux: netlink.c whitespace, syntax, and static declaraction cleanups SELinux: netlabel.c whitespace, syntax, and static declaraction cleanups SELinux: netif.c whitespace, syntax, and static declaraction cleanups
2008-04-21SELinux: one little, two little, three little whitespaces, the avc.c saga.Eric Paris
avc.c was bad. It had whitespace and syntax issues which are against our coding style. I have had a little chat with it and the result of that conversation looked like this patch. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: cleanup on isle selinuxfs.cEric Paris
Why would anyone just clean up white space all day? Because they were out too late last night and don't want to think for a day. So here is a nice clean selinuxfs.c patch. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21changing whitespace for fun and profit: policydb.cEric Paris
More formatting changes. Aside from the 80 character line limit even the checkpatch scripts like this file now. Too bad I don't get paid by the lines of code I change. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: whitespace and formating fixes for hooks.cEric Paris
All whitespace and formatting. Nothing interesting to see here. About the only thing to remember is that we aren't supposed to initialize static variables to 0/NULL. It is done for us and doing it ourselves puts them in a different section. With this patch running checkpatch.pl against hooks.c only gives us complaints about busting the 80 character limit and declaring extern's in .c files. Apparently they don't like it, but I don't feel like going to the trouble of moving those to .h files... Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: clean up printksEric Paris
Make sure all printk start with KERN_* Make sure all printk end with \n Make sure all printk have the word 'selinux' in them Change "function name" to "%s", __func__ (found 2 wrong) Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: sidtab.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes sidtab.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: services.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes services.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: mls.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes mls.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: hashtab.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes hashtab.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: ebitmap.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes ebitmap.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: conditional.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes conditional.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: avtab.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes avtab.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: xfrm.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes xfrm.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: nlmsgtab.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes nlmsgtab.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: netnode.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes netnode.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: netlink.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes netlink.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: netlabel.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes netlabel.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis locateion of { around struct and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-21SELinux: netif.c whitespace, syntax, and static declaraction cleanupsEric Paris
This patch changes netif.c to fix whitespace and syntax issues. Things that are fixed may include (does not not have to include) whitespace at end of lines spaces followed by tabs spaces used instead of tabs spacing around parenthesis location of { around structs and else clauses location of * in pointer declarations removal of initialization of static data to keep it in the right section useless {} in if statemetns useless checking for NULL before kfree fixing of the indentation depth of switch statements and any number of other things I forgot to mention Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18security: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: security: fix up documentation for security_module_enable Security: Introduce security= boot parameter Audit: Final renamings and cleanup SELinux: use new audit hooks, remove redundant exports Audit: internally use the new LSM audit hooks LSM/Audit: Introduce generic Audit LSM hooks SELinux: remove redundant exports Netlink: Use generic LSM hook Audit: use new LSM hooks instead of SELinux exports SELinux: setup new inode/ipc getsecid hooks LSM: Introduce inode_getsecid and ipc_getsecid hooks
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits) [NET]: Fix and allocate less memory for ->priv'less netdevices [IPV6]: Fix dangling references on error in fib6_add(). [NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found [PKT_SCHED]: Fix datalen check in tcf_simp_init(). [INET]: Uninline the __inet_inherit_port call. [INET]: Drop the inet_inherit_port() call. SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked. [netdrvr] forcedeth: internal simplifications; changelog removal phylib: factor out get_phy_id from within get_phy_device PHY: add BCM5464 support to broadcom PHY driver cxgb3: Fix __must_check warning with dev_dbg. tc35815: Statistics cleanup natsemi: fix MMIO for PPC 44x platforms [TIPC]: Cleanup of TIPC reference table code [TIPC]: Optimized initialization of TIPC reference table [TIPC]: Remove inlining of reference table locking routines e1000: convert uint16_t style integers to u16 ixgb: convert uint16_t style integers to u16 sb1000.c: make const arrays static sb1000.c: stop inlining largish static functions ...
2008-04-19security: fix up documentation for security_module_enableJames Morris
security_module_enable() can only be called during kernel init. Signed-off-by: James Morris <jmorris@namei.org>
2008-04-19Security: Introduce security= boot parameterAhmed S. Darwish
Add the security= boot parameter. This is done to avoid LSM registration clashes in case of more than one bult-in module. User can choose a security module to enable at boot. If no security= boot parameter is specified, only the first LSM asking for registration will be loaded. An invalid security module name will be treated as if no module has been chosen. LSM modules must check now if they are allowed to register by calling security_module_enable(ops) first. Modify SELinux and SMACK to do so. Do not let SMACK register smackfs if it was not chosen on boot. Smackfs assumes that smack hooks are registered and the initial task security setup (swapper->security) is done. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-19Audit: Final renamings and cleanupAhmed S. Darwish
Rename the se_str and se_rule audit fields elements to lsm_str and lsm_rule to avoid confusion. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-19SELinux: use new audit hooks, remove redundant exportsAhmed S. Darwish
Setup the new Audit LSM hooks for SELinux. Remove the now redundant exported SELinux Audit interface. Audit: Export 'audit_krule' and 'audit_field' to the public since their internals are needed by the implementation of the new LSM hook 'audit_rule_known'. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-19LSM/Audit: Introduce generic Audit LSM hooksAhmed S. Darwish
Introduce a generic Audit interface for security modules by adding the following new LSM hooks: audit_rule_init(field, op, rulestr, lsmrule) audit_rule_known(krule) audit_rule_match(secid, field, op, rule, actx) audit_rule_free(rule) Those hooks are only available if CONFIG_AUDIT is enabled. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Paul Moore <paul.moore@hp.com>
2008-04-19SELinux: remove redundant exportsAhmed S. Darwish
Remove the following exported SELinux interfaces: selinux_get_inode_sid(inode, sid) selinux_get_ipc_sid(ipcp, sid) selinux_get_task_sid(tsk, sid) selinux_sid_to_string(sid, ctx, len) They can be substitued with the following generic equivalents respectively: new LSM hook, inode_getsecid(inode, secid) new LSM hook, ipc_getsecid*(ipcp, secid) LSM hook, task_getsecid(tsk, secid) LSM hook, sid_to_secctx(sid, ctx, len) Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Paul Moore <paul.moore@hp.com>
2008-04-19SELinux: setup new inode/ipc getsecid hooksAhmed S. Darwish
Setup the new inode_getsecid and ipc_getsecid() LSM hooks for SELinux. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Paul Moore <paul.moore@hp.com>
2008-04-19LSM: Introduce inode_getsecid and ipc_getsecid hooksAhmed S. Darwish
Introduce inode_getsecid(inode, secid) and ipc_getsecid(ipcp, secid) LSM hooks. These hooks will be used instead of similar exported SELinux interfaces. Let {inode,ipc,task}_getsecid hooks set the secid to 0 by default if CONFIG_SECURITY is not defined or if the hook is set to NULL (dummy). This is done to notify the caller that no valid secid exists. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org> Reviewed-by: Paul Moore <paul.moore@hp.com>
2008-04-18security: enhance DEFAULT_MMAP_MIN_ADDR descriptionmaximilian attems
Got burned by setting the proposed default of 65536 across all Debian archs. Thus proposing to be more specific on which archs you may set this. Also propose a value for arm and friends that doesn't break sshd. Reword to mention working archs ia64 and ppc64 too. Signed-off-by: maximilian attems <max@stro.at> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Gordon Farquharson <gordonfarquharson@gmail.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: add netport.[ch]James Morris
Thank you, git. Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: Add network port SID cachePaul Moore
Much like we added a network node cache, this patch adds a network port cache. The design is taken almost completely from the network node cache which in turn was taken from the network interface cache. The basic idea is to cache entries in a hash table based on protocol/port information. The hash function only takes the port number into account since the number of different protocols in use at any one time is expected to be relatively small. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: turn mount options strings into definesEric Paris
Convert the strings used for mount options into #defines rather than retyping the string throughout the SELinux code. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18selinux/ss/services.c should #include <linux/selinux.h>Adrian Bunk
Every file should include the headers containing the externs for its global code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18selinux: introduce permissive typesEric Paris
Introduce the concept of a permissive type. A new ebitmap is introduced to the policy database which indicates if a given type has the permissive bit set or not. This bit is tested for the scontext of any denial. The bit is meaningless on types which only appear as the target of a decision and never the source. A domain running with a permissive type will be allowed to perform any action similarly to when the system is globally set permissive. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18selinux: remove ptrace_sidRoland McGrath
This changes checks related to ptrace to get rid of the ptrace_sid tracking. It's good to disentangle the security model from the ptrace implementation internals. It's sufficient to check against the SID of the ptracer at the time a tracee attempts a transition. Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: requesting no permissions in avc_has_perm_noaudit is a BUG()Eric Paris
This patch turns the case where we have a call into avc_has_perm with no requested permissions into a BUG_ON. All callers to this should be in the kernel and thus should be a function we need to fix if we ever hit this. The /selinux/access permission checking it done directly in the security server and not through the avc, so those requests which we cannot control from userspace should not be able to trigger this BUG_ON. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18security: code cleanupAndrew Morton
ERROR: "(foo*)" should be "(foo *)" #168: FILE: security/selinux/hooks.c:2656: + "%s, rc=%d\n", __func__, (char*)value, -rc); total: 1 errors, 0 warnings, 195 lines checked ./patches/security-replace-remaining-__function__-occurences.patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS. Please run checkpatch prior to sending patches Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18security: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: create new open permissionEric Paris
Adds a new open permission inside SELinux when 'opening' a file. The idea is that opening a file and reading/writing to that file are not the same thing. Its different if a program had its stdout redirected to /tmp/output than if the program tried to directly open /tmp/output. This should allow policy writers to more liberally give read/write permissions across the policy while still blocking many design and programing flaws SELinux is so good at catching today. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Reviewed-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18selinux: selinux/netlabel.c should #include "netlabel.h"Adrian Bunk
Every file should include the headers containing the externs for its global code. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: unify printk messagesJames Morris
Replace "security:" prefixes in printk messages with "SELinux" to help users identify the source of the messages. Also fix a couple of minor formatting issues. Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: remove unused backpointers from security objectsJames Morris
Remove unused backpoiters from security objects. Signed-off-by: James Morris <jmorris@namei.org>
2008-04-18SELinux: Correct the NetLabel locking for the sk_security_structPaul Moore
The RCU/spinlock locking approach for the nlbl_state in the sk_security_struct was almost certainly overkill. This patch removes both the RCU and spinlock locking, relying on the existing socket locks to handle the case of multiple writers. This change also makes several code reductions possible. Less locking, less code - it's a Good Thing. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
