The pointer returned from tracehook_tracer_task() is only valid inside
the rcu_read_lock. However the tracer pointer obtained is being passed
to aa_may_ptrace outside of the rcu_read_lock critical section.
Mover the aa_may_ptrace test into the rcu_read_lock critical section, to
fix this.
Kernels affected: 2.6.36 - 3.0
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: stable@kernel.org
Signed-off-by: John Johansen <john.johansen@canonical.com>
To be able to start using enforcing mode from the early stage of boot sequence,
this patch adds support for activating access control without calling external
policy loader program. This will be useful for systems where operations which
can lead to the hijacking of the boot sequence are needed before loading the
policy. For example, you can activate immediately after loading the fixed part
of policy which will allow only operations needed for mounting a partition
which contains the variant part of policy and verifying (e.g. running GPG
check) and loading the variant part of policy. Since you can start using
enforcing mode from the beginning, you can reduce the possibility of hijacking
the boot sequence.
This patch makes several variables configurable on build time. This patch also
adds TOMOYO_loader= and TOMOYO_trigger= kernel command line option to boot the
same kernel in two different init systems (BSD-style init and systemd).
Signed-off-by: James Morris <jmorris@namei.org>
this patch adds support for built-in policy configuration (and next patch adds
support for activating access control without calling external policy loader
program).
Show statistics such as last policy update time and last policy violation time
in addition to memory usage.
Gather string constants to one file in order to make the object size smaller.
Use unsigned type where appropriate.
read()/write() returns ssize_t.
Currently TOMOYO holds SRCU lock upon open() and releases it upon close()
because list elements stored in the "struct tomoyo_io_buffer" instances are
accessed until close() is called. However, such SRCU usage causes lockdep to
complain about leaving the kernel with SRCU lock held.
This patch solves the warning by holding/releasing SRCU upon each
read()/write(). This patch is doing something similar to calling kfree()
without calling synchronize_srcu(), by selectively deferring kfree() by keeping
track of the "struct tomoyo_io_buffer" instances.
TOMOYO wants to use /proc/self/ rather than /proc/$PID/ if $PID matches current
thread's process ID in order to prevent current thread from accessing other
process's information unless needed.
But since procfs can be mounted on various locations (e.g. /proc/ /proc2/ /p/
/tmp/foo/100/p/ ), TOMOYO cannot tell that whether the numeric part in the
string returned by __d_path() represents process ID or not.
Therefore, to be able to convert from $PID to self no matter where procfs is
mounted, this patch changes pathname representations for filesystems which do
not support rename() operation (e.g. proc, sysfs, securityfs).
Examples:
/proc/self/mounts => proc:/self/mounts
/sys/kernel/security/ => sys:/kernel/security/
/dev/pts/0 => devpts:/0
Mauras Olivier reported that it is difficult to use TOMOYO in LXC environments,
for TOMOYO cannot distinguish between environments outside the container and
environments inside the container since LXC environments are created using
pivot_root(). To address this problem, this patch introduces policy namespace.
Each policy namespace has its own set of domain policy, exception policy and
profiles, which are all independent of other namespaces. This independency
allows users to develop policy without worrying interference among namespaces.
ACL group allows administrator to globally grant not only "file read"
permission but also other permissions.
Add /sys/kernel/security/tomoyo/audit interface. This interface generates audit
logs in the form of domain policy so that /usr/sbin/tomoyo-auditd can reuse
audit logs for appending to /sys/kernel/security/tomoyo/domain_policy
interface.
Remove global preference from profile structure in order to make code simpler.
Due to this structure change, printk() warnings upon policy violation are
temporarily disabled. They will be replaced by
/sys/kernel/security/tomoyo/audit by next patch.
Convert "allow_..." style directives to "file ..." style directives.
By converting to the latter style, we can pack policy like
"file read/write/execute /path/to/file".
Use structure for passing ACL line, in preparation for supporting policy
namespace and conditional parameters.
Use common structure for ACL with "struct list_head" + "atomic_t".
Use array/struct where possible.
Remove is_group from "struct tomoyo_name_union"/"struct tomoyo_number_union".
Pass "struct file"->private_data rather than "struct file".
Update some of comments.
Bring tomoyo_same_acl_head() from common.h to domain.c .
Bring tomoyo_invalid()/tomoyo_valid() from common.h to util.c .
Update (or temporarily remove) comments.
Remove or replace some of #define lines.
In order to synchronize with TOMOYO 1.8's syntax,
(1) Remove special handling for allow_read/write permission.
(2) Replace deny_rewrite/allow_rewrite permission with allow_append permission.
(3) Remove file_pattern keyword.
(4) Remove allow_read permission from exception policy.
(5) Allow creating domains in enforcing mode without calling supervisor.
(6) Add permission check for opening directory for reading.
(7) Add permission check for stat() operation.
(8) Make "cat < /sys/kernel/security/tomoyo/self_domain" behave as if
"cat /sys/kernel/security/tomoyo/self_domain".
The 'encrypted' key type defines its own payload format which contains a
symmetric key randomly generated that cannot be used directly to mount
an eCryptfs filesystem, because it expects an authentication token
structure.
This patch introduces the new format 'ecryptfs' that allows to store an
authentication token structure inside the encrypted key payload containing
a randomly generated symmetric key, as the same for the format 'default'.
More details about the usage of encrypted keys with the eCryptfs
filesystem can be found in the file 'Documentation/keys-ecryptfs.txt'.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Acked-by: Gianluca Ramunno <ramunno@polito.it>
Acked-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
This patch introduces a new parameter, called 'format', that defines the
format of data stored by encrypted keys. The 'default' format identifies
encrypted keys containing only the symmetric key, while other formats can
be defined to support additional information. The 'format' parameter is
written in the datablob produced by commands 'keyctl print' or
'keyctl pipe' and is integrity protected by the HMAC.
Some debug messages have been added in the function datablob_parse() in
order to better identify errors returned when dealing with 'encrypted'
keys.
Changelog from version v4:
- made the debug messages more understandable
Valid key type prefixes for the parameter 'key-type' are: 'trusted' and
'user'.
Do not dump the master key if an error is encountered during the request.
tracehook.h is on the way out. Rename tracehook_tracer_task() to
ptrace_parent() and move it from tracehook.h to ptrace.h.
Cc: John Johansen <john.johansen@canonical.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
Fix error handling in construct_key_and_link().
If construct_alloc_key() returns an error, it shouldn't pass out through
the normal path as the key_serial() called by the kleave() statement
will oops when it gets an error code in the pointer:
BUG: unable to handle kernel paging request at ffffffffffffff84
IP: [<ffffffff8120b401>] request_key_and_link+0x4d7/0x52f
Call Trace:
[<ffffffff8120b52c>] request_key+0x41/0x75
[<ffffffffa00ed6e8>] cifs_get_spnego_key+0x206/0x226 [cifs]
[<ffffffffa00eb0c9>] CIFS_SessSetup+0x511/0x1234 [cifs]
[<ffffffffa00d9799>] cifs_setup_session+0x90/0x1ae [cifs]
[<ffffffffa00d9c02>] cifs_get_smb_ses+0x34b/0x40f [cifs]
[<ffffffffa00d9e05>] cifs_mount+0x13f/0x504 [cifs]
[<ffffffffa00caabb>] cifs_do_mount+0xc4/0x672 [cifs]
[<ffffffff8113ae8c>] mount_fs+0x69/0x155
[<ffffffff8114ff0e>] vfs_kern_mount+0x63/0xa0
[<ffffffff81150be2>] do_kern_mount+0x4d/0xdf
[<ffffffff81152278>] do_mount+0x63c/0x69f
[<ffffffff8115255c>] sys_mount+0x88/0xc2
[<ffffffff814fbdc2>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
devcgroup_inode_permission: take "is it a device node" checks to inlined wrapper
fix comment in generic_permission()
kill obsolete comment for follow_down()
proc_sys_permission() is OK in RCU mode
reiserfs_permission() doesn't need to bail out in RCU mode
proc_fd_permission() is doesn't need to bail out in RCU mode
nilfs2_permission() doesn't need to bail out in RCU mode
logfs doesn't need ->permission() at all
coda_ioctl_permission() is safe in RCU mode
cifs_permission() doesn't need to bail out in RCU mode
bad_inode_permission() is safe from RCU mode
ubifs: dereferencing an ERR_PTR in ubifs_mount()
inode_permission() calls devcgroup_inode_permission() and almost all such
calls are _not_ for device nodes; let's at least keep the common path
straight...
____call_usermodehelper() now erases any credentials set by the
subprocess_inf::init() function. The problem is that commit
17f60a7da150 ("capabilites: allow the application of capability limits
to usermode helpers") creates and commits new credentials with
prepare_kernel_cred() after the call to the init() function. This wipes
all keyrings after umh_keys_init() is called.
The best way to deal with this is to put the init() call just prior to
the commit_creds() call, and pass the cred pointer to init(). That
means that umh_keys_init() and suchlike can modify the credentials
_before_ they are published and potentially in use by the rest of the
system.
This prevents request_key() from working as it is prevented from passing
the session keyring it set up with the authorisation token to
/sbin/request-key, and so the latter can't assume the authority to
instantiate the key. This causes the in-kernel DNS resolver to fail
with ENOKEY unconditionally.
Acked-by: Eric Paris <eparis@redhat.com>
Tested-by: Jeff Layton <jlayton@redhat.com>
into for-linus
When policy version is less than POLICYDB_VERSION_FILENAME_TRANS,
skip file_name_trans_write().
Signed-off-by: Roy.Li <rongqing.li@windriver.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
In tomoyo_mount_acl() since 2.6.36, kern_path() was called without checking
dev_name != NULL. As a result, an unprivileged user can trigger oops by issuing
mount(NULL, "/", "ext3", 0, NULL) request.
Fix this by checking dev_name != NULL before calling kern_path(dev_name).
Don't return EAGAIN to keyctl_assume_authority() to indicate that a key could
not be found (ENOKEY is only returned if a negative key is found). Instead
return ENOKEY in both cases.
Affected kernels 2.6.36 - 3.0
AppArmor may do a GFP_KERNEL memory allocation with task_lock(tsk->group_leader);
held when called from security_task_setrlimit. This will only occur when the
task's current policy has been replaced, and the task's creds have not been
updated before entering the LSM security_task_setrlimit() hook.
BUG: sleeping function called from invalid context at mm/slub.c:847
in_atomic(): 1, irqs_disabled(): 0, pid: 1583, name: cupsd
2 locks held by cupsd/1583:
#0: (tasklist_lock){.+.+.+}, at: [<ffffffff8104dafa>] do_prlimit+0x61/0x189
#1: (&(&p->alloc_lock)->rlock){+.+.+.}, at: [<ffffffff8104db2d>]
do_prlimit+0x94/0x189
Pid: 1583, comm: cupsd Not tainted 3.0.0-rc2-git1 #7
Call Trace:
[<ffffffff8102ebf2>] __might_sleep+0x10d/0x112
[<ffffffff810e6f46>] slab_pre_alloc_hook.isra.49+0x2d/0x33
[<ffffffff810e7bc4>] kmem_cache_alloc+0x22/0x132
[<ffffffff8105b6e6>] prepare_creds+0x35/0xe4
[<ffffffff811c0675>] aa_replace_current_profile+0x35/0xb2
[<ffffffff811c4d2d>] aa_current_profile+0x45/0x4c
[<ffffffff811c4d4d>] apparmor_task_setrlimit+0x19/0x3a
[<ffffffff811beaa5>] security_task_setrlimit+0x11/0x13
[<ffffffff8104db6b>] do_prlimit+0xd2/0x189
[<ffffffff8104dea9>] sys_setrlimit+0x3b/0x48
[<ffffffff814062bb>] system_call_fastpath+0x16/0x1b
Reported-by: Miles Lane <miles.lane@gmail.com>
This is a rather hot function that is called with a potentially NULL
"struct common_audit_data" pointer argument. And in that case it has to
provide and initialize its own dummy common_audit_data structure.
However, all the _common_ cases already pass it a real audit-data
structure, so that uncommon NULL case not only creates a silly run-time
test, more importantly it causes that function to have a big stack frame
for the dummy variable that isn't even used in the common case!
So get rid of that stupid run-time behavior, and make the (few)
functions that currently call with a NULL pointer just call a new helper
function instead (naturally called inode_has_perm_noapd(), since it has
no adp argument).
This makes the run-time test be a static code generation issue instead,
and allows for a much denser stack since none of the common callers need
the dummy structure. And a denser stack not only means less stack space
usage, it means better cache behavior. So we have a win-win-win from
this simplification: less code executed, smaller stack footprint, and
When invalid parameters are passed to apparmor_setprocattr a NULL deref
oops occurs when it tries to record an audit message. This is because
it is passing NULL for the profile parameter for aa_audit. But aa_audit
now requires that the profile passed is not NULL.
Fix this by passing the current profile on the task that is trying to
setprocattr.
Signed-off-by: Kees Cook <kees@ubuntu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs
* 'docs-move' of git://git.kernel.org/pub/scm/linux/kernel/git/rdunlap/linux-docs:
Create Documentation/security/, move LSM-, credentials-, and keys-related files from Documentation/ to Documentation/security/, add Documentation/security/00-INDEX, and update all occurrences of Documentation/<moved_file> to Documentation/security/<moved_file>.
Right now security_get_user_sids() will pass in a NULL avd pointer to
avc_has_perm_noaudit(), which then forces that function to have a dummy
entry for that case and just generally test it.
Don't do it. The normal callers all pass a real avd pointer, and this
helper function is incredibly hot. So don't make avc_has_perm_noaudit()
do conditional stuff that isn't needed for the common case.
This also avoids some duplicated stack space.
Add cgroup subsystem callbacks for per-thread attachment in atomic contexts
Add can_attach_task(), pre_attach(), and attach_task() as new callbacks
for cgroups's subsystem interface. Unlike can_attach and attach, these
are for per-thread operations, to be called potentially many times when
attaching an entire threadgroup.
Also, the old "bool threadgroup" interface is removed, as replaced by
this. All subsystems are modified for the new interface - of note is
cpuset, which requires from/to nodemasks for attach to be globally scoped
(though per-cpuset would work too) to persist from its pre_attach to
attach_task and attach.
This is a pre-patch for cgroup-procs-writable.patch.
Signed-off-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Matt Helsley <matthltc@us.ibm.com>
Reviewed-by: Paul Menage <menage@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
I submit the patch again, according to patch submission convension.
This patch enables to accept percent-encoded object names as forth
argument of /selinux/create interface to avoid possible bugs when we
give an object name including whitespace or multibutes.
E.g) if and when a userspace object manager tries to create a new object
named as "resolve.conf but fake", it shall give this name as the forth
argument of the /selinux/create. But sscanf() logic in kernel space
fetches only the part earlier than the first whitespace.
In this case, selinux may unexpectedly answer a default security context
configured to "resolve.conf", but it is bug.
Although I could not test this patch on named TYPE_TRANSITION rules
actually, But debug printk() message seems to me the logic works
correctly.
I assume the libselinux provides an interface to apply this logic
transparently, so nothing shall not be changed from the viewpoint of
application.
Signed-off-by: KaiGai Kohei <kohei.kaigai@emea.nec.com>
lib/flex_array.c
security/selinux/avc.c
security/selinux/hooks.c
security/selinux/ss/policydb.c
security/smack/smack_lsm.c
Since this cred was not created with copy_creds(), it needs to get
initialized. Otherwise use of syscall(__NR_keyctl, KEYCTL_SESSION_TO_PARENT);
can lead to a NULL deref. Thanks to Robert for finding this.
But introduced by commit 47a150edc2a ("Cache user_ns in struct cred").
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Reported-by: Robert Święcki <robert@swiecki.net>
Cc: stable@kernel.org (2.6.39)
for-linus
lib/flex_array.c
Manually resolve conflicts.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
There is no point in counting hits - we can calculate it from the number
of lookups and misses.
This makes the avc statistics a bit smaller, and makes the code
generation better too.
You can turn off the avc cache stats, but distributions seem to not do
that (perhaps because several performance tuning how-to's talk about the
avc cache statistics).
Which is sad, because the code it generates is truly horrendous, with
the statistics update being sandwitched between get_cpu/put_cpu which in
turn causes preemption disables etc. We're talking ten+ instructions
just to increment a per-cpu variable in some pretty hot code.
Fix the craziness by just using 'this_cpu_inc()' instead. Suddenly we
only need a single 'inc' instruction to increment the statistics. This
is quite noticeable in the incredibly hot avc_has_perm_noaudit()
function (which triggers all the statistics by virtue of doing an
avc_lookup() call).
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
include/linux/capability.h
Manually resolve merge conflict w/ thanks to Stephen Rothwell.
into for-linus
The filename_trans rule processing has some printk(KERN_ERR ) messages
which were intended as debug aids in creating the code but weren't removed
before it was submitted. Remove them.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
