Linux 3.1.10
Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream.
Don't free a valid measurement entry on TPM PCR extend failure.
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream.
Info about new measurements are cached in the iint for performance. When
the inode is flushed from cache, the associated iint is flushed as well.
Subsequent access to the inode will cause the inode to be re-measured and
will attempt to add a duplicate entry to the measurement list.
This patch frees the duplicate measurement memory, fixing a memory leak.
commit 50345f1ea9cda4618d9c26e590a97ecd4bc7ac75 upstream.
Fix the following bug in sel_netport_insert() where rcu_dereference() should
be rcu_dereference_protected() as sel_netport_lock is held.
[ INFO: suspicious rcu_dereference_check() usage. ]
security/selinux/netport.c:127 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by ossec-rootcheck/3323:
#0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226
stack backtrace:
Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095
Call Trace:
[<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0
[<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226
[<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc
[<ffffffff8117556c>] selinux_socket_bind+0x115/0x230
[<ffffffff810a5388>] ? might_fault+0x4e/0x9e
[<ffffffff810a53d1>] ? might_fault+0x97/0x9e
[<ffffffff81171cf4>] security_socket_bind+0x11/0x13
[<ffffffff812ba967>] sys_bind+0x56/0x95
[<ffffffff81380dac>] ? sysret_check+0x27/0x62
[<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155
[<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae
[<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b
Acked-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: James Morris <jmorris@namei.org>
Change-Id: I82e2cbd2370e6339bac6d125dc2c016cdcce193f
Reviewed-on: http://git-master/r/74181
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
stack backtrace:
Call Trace:
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
commit 1418a3e5ad4d01b1d4abf2c479c50b0cedd59e3f upstream.
Current tomoyo_realpath_from_path() implementation returns strange pathname
when calculating pathname of a file which belongs to lazy unmounted tree.
Use local pathname rather than strange absolute pathname in that case.
Also, this patch fixes a regression by commit 02125a82 "fix apparmor
dereferencing potentially freed dentry, sanitize __d_path() API".
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
commit 02125a826459a6ad142f8d91c5b6357562f96615 upstream.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
Change-Id: Ie87bb2e71e8ce5cd8c249d0db196bf4e5c5e2ae4
Reviewed-on: http://git-master/r/71039
Tested-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Chris Johnson <cwj@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Add CONFIG_ANDROID_PARANOID_NETWORK inside commoncap.c.
Change-Id: I1cf092e9d5465c144e1b5ca022ee4e48f6d5739c
Signed-off-by: Winnie Hsu <whsu@nvidia.com>
Reviewed-on: http://git-master/r/51930
Reviewed-by: Allen Martin <amartin@nvidia.com>
Rebase-Id: R3c12a048ab722a529b4777451335305024ca90db
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
commit 9f35a33b8d06263a165efe3541d9aa0cdbd70b3b upstream.
Fix a NULL pointer deref in the user-defined key type whereby updating a
negative key into a fully instantiated key will cause an oops to occur
when the code attempts to free the non-existent old payload.
This results in an oops that looks something like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
PGD 3391d067 PUD 3894a067 PMD 0
Oops: 0002 [#1] SMP
CPU 1
Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY
RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e
RSP: 0018:ffff88003d591df8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e
RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c
R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538
R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908
FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000
CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0
Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040)
Stack:
ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50
ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea
ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0
Call Trace:
[<ffffffff810860f0>] call_rcu_sched+0x10/0x12
[<ffffffff8117bfea>] user_update+0x8d/0xa2
[<ffffffff8117723a>] key_create_or_update+0x236/0x270
[<ffffffff811789b1>] sys_add_key+0x123/0x17e
[<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b
Acked-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Neil Horman <nhorman@redhat.com>
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: James Morris <jmorris@namei.org>
The Bluetooth stack has internal connection handlers for all of the various
Bluetooth protocols, and unfortunately, they are currently lacking the LSM
hooks found in the core network stack's connection handlers. I say
unfortunately, because this can cause problems for users who have have an
LSM enabled and are using certain Bluetooth devices. See one problem
report below:
* http://bugzilla.redhat.com/show_bug.cgi?id=741703
In order to keep things simple at this point in time, this patch fixes the
problem by cloning the parent socket's LSM attributes to the newly created
child socket. If we decide we need a more elaborate LSM marking mechanism
for Bluetooth (I somewhat doubt this) we can always revisit this decision
in the future.
Reported-by: James M. Cape <jcape@ignore-your.tv>
Signed-off-by: Paul Moore <pmoore@redhat.com>
Commit bd03a3e4 "TOMOYO: Add policy namespace support." forgot to set EOF flag
and forgot to print namespace at PREFERENCE line.
My @hp.com will no longer be valid starting August 5, 2011 so an update is
necessary. My new email address is employer independent so we don't have
to worry about doing this again any time soon.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
merge fchmod() and fchmodat() guts, kill ancient broken kludge
xfs: fix misspelled S_IS...()
xfs: get rid of open-coded S_ISREG(), etc.
vfs: document locking requirements for d_move, __d_move and d_materialise_unique
omfs: fix (mode & S_IFDIR) abuse
btrfs: S_ISREG(mode) is not mode & S_IFREG...
ima: fmode_t misspelled as mode_t...
pci-label.c: size_t misspelled as mode_t
jffs2: S_ISLNK(mode & S_IFMT) is pointless
snd_msnd ->mode is fmode_t, not mode_t
v9fs_iop_get_acl: get rid of unused variable
vfs: dont chain pipe/anon/socket on superblock s_inodes list
Documentation: Exporting: update description of d_splice_alias
fs: add missing unlock in default_llseek()
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
For a number of file systems that don't have a mount point (e.g. sockfs
and pipefs), they are not marked as long term. Therefore in
mntput_no_expire, all locks in vfs_mount lock are taken instead of just
local cpu's lock to aggregate reference counts when we release
reference to file objects. In fact, only local lock need to have been
taken to update ref counts as these file systems are in no danger of
going away until we are ready to unregister them.
The attached patch marks file systems using kern_mount without
mount point as long term. The contentions of vfs_mount lock
is now eliminated. Before un-registering such file system,
kern_unmount should be called to remove the long term flag and
make the mount point ready to be freed.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Fix wrong check in list_splice_init_rcu()
net,rcu: Convert call_rcu(xt_rateest_free_rcu) to kfree_rcu()
sysctl,rcu: Convert call_rcu(free_head) to kfree
vmalloc,rcu: Convert call_rcu(rcu_free_vb) to kfree_rcu()
vmalloc,rcu: Convert call_rcu(rcu_free_va) to kfree_rcu()
ipc,rcu: Convert call_rcu(ipc_immediate_free) to kfree_rcu()
ipc,rcu: Convert call_rcu(free_un) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netport_free) to kfree_rcu()
security,rcu: Convert call_rcu(sel_netnode_free) to kfree_rcu()
ia64,rcu: Convert call_rcu(sn_irq_info_free) to kfree_rcu()
block,rcu: Convert call_rcu(disk_free_ptbl_rcu_cb) to kfree_rcu()
scsi,rcu: Convert call_rcu(fc_rport_free_rcu) to kfree_rcu()
audit_tree,rcu: Convert call_rcu(__put_tree) to kfree_rcu()
security,rcu: Convert call_rcu(whitelist_item_free) to kfree_rcu()
md,rcu: Convert call_rcu(free_conf) to kfree_rcu()
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits)
ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever
ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction
connector: add an event for monitoring process tracers
ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED
ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()
ptrace_init_task: initialize child->jobctl explicitly
has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/
ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop
ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/
ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented()
ptrace: ptrace_reparented() should check same_thread_group()
redefine thread_group_leader() as exit_signal >= 0
do not change dead_task->exit_signal
kill task_detached()
reparent_leader: check EXIT_DEAD instead of task_detached()
make do_notify_parent() __must_check, update the callers
__ptrace_detach: avoid task_detached(), check do_notify_parent()
kill tracehook_notify_death()
make do_notify_parent() return bool
ptrace: s/tracehook_tracer_task()/ptrace_parent()/
The rcu callback sel_netport_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sel_netport_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Eric Paris <eparis@parisplace.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The rcu callback sel_netnode_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sel_netnode_free).
The rcu callback whitelist_item_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(whitelist_item_free).
it never is...
pass mask instead; kill security_inode_exec_permission() since we can use
security_inode_permission() instead.
pass that via mask instead.
Update comments for scripts/kernel-doc and fix some of errors reported by
scripts/checkpatch.pl .
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Enable conditional ACL by passing object's pointers.
This patch adds support for permission checks using argv[]/envp[] of execve()
request. Hooks are in the last patch of this pathset.
This patch adds support for permission checks using executable file's realpath
upon execve() and symlink's target upon symlink(). Hooks are in the last patch
of this pathset.
This patch adds support for permission checks using file object's DAC
attributes (e.g. owner/group) when checking file's pathnames. Hooks for passing
file object's pointers are in the last patch of this pathset.
This patch adds support for permission checks using current thread's UID/GID
etc. in addition to pathnames.
Since ca5ecddf (rcu: define __rcu address space modifier for sparse)
rcu_dereference_check use rcu_read_lock_held as a part of condition
automatically so callers do not have to do that as well.
/sys/kernel/security/tomoyo/.domain_status can be easily emulated using
/sys/kernel/security/tomoyo/domain_policy . We can remove this interface by
updating /usr/sbin/tomoyo-setprofile utility.
Commit eadd99cc "TOMOYO: Add auditing interface." by error replaced
"struct tomoyo_request_info"->domain with tomoyo_domain().
Sort by alphabetic order.
I forgot to add #ifndef in commit 0e4ae0e0 "TOMOYO: Make several options
configurable.", resulting
security/built-in.o: In function `tomoyo_bprm_set_creds':
tomoyo.c:(.text+0x4698e): undefined reference to `tomoyo_load_policy'
error.
git://git.kernel.org/pub/scm/linux/kernel/git/jj/apparmor-dev into next
AppArmor is masking the capabilities returned by capget against the
capabilities mask in the profile. This is wrong, in complain mode the
profile has effectively all capabilities, as the profile restrictions are
not being enforced, merely tested against to determine if an access is
known by the profile.
This can result in the wrong behavior of security conscience applications
like sshd which examine their capability set, and change their behavior
accordingly. In this case because of the masked capability set being
returned sshd fails due to DAC checks, even when the profile is in complain
mode.
Kernels affected: 2.6.36 - 3.0.
Signed-off-by: John Johansen <john.johansen@canonical.com>
The pointer returned from tracehook_tracer_task() is only valid inside
the rcu_read_lock. However the tracer pointer obtained is being passed
to aa_may_ptrace outside of the rcu_read_lock critical section.
Mover the aa_may_ptrace test into the rcu_read_lock critical section, to
fix this.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: stable@kernel.org
To be able to start using enforcing mode from the early stage of boot sequence,
this patch adds support for activating access control without calling external
policy loader program. This will be useful for systems where operations which
can lead to the hijacking of the boot sequence are needed before loading the
policy. For example, you can activate immediately after loading the fixed part
of policy which will allow only operations needed for mounting a partition
which contains the variant part of policy and verifying (e.g. running GPG
check) and loading the variant part of policy. Since you can start using
enforcing mode from the beginning, you can reduce the possibility of hijacking
the boot sequence.
This patch makes several variables configurable on build time. This patch also
adds TOMOYO_loader= and TOMOYO_trigger= kernel command line option to boot the
same kernel in two different init systems (BSD-style init and systemd).
