path: root/security
2012-11-06device_cgroup: fix RCU usageTejun Heo
dev_cgroup->exceptions is protected with devcgroup_mutex for writes and RCU for reads; however, RCU usage isn't correct. * dev_exception_clean() doesn't use RCU variant of list_del() and kfree(). The function can race with may_access() and may_access() may end up dereferencing already freed memory. Use list_del_rcu() and kfree_rcu() instead. * may_access() may be called only with RCU read locked but doesn't use RCU safe traversal over ->exceptions. Use list_for_each_entry_rcu(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: stable@vger.kernel.org Cc: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com>
2012-11-06device_cgroup: fix unchecked cgroup parent usageAristeu Rozanski
In 4cef7299b478687 ("device_cgroup: add proper checking when changing default behavior") the cgroup parent usage is unchecked. root will not have a parent and trying to use device.{allow,deny} will cause problems. For some reason my stressing scripts didn't test the root directory so I didn't catch it on my regular tests. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2012-10-25device_cgroup: add proper checking when changing default behaviorAristeu Rozanski
Before changing a group's default behavior to ALLOW, we must check if its parent's behavior is also ALLOW. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25device_cgroup: stop using simple_strtoul()Aristeu Rozanski
Convert the code to use kstrtou32() instead of simple_strtoul() which is deprecated. The real size of the variables are u32, so use kstrtou32 instead of kstrtoul Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25device_cgroup: rename deny_all to behaviorAristeu Rozanski
This was done in a v2 patch but v1 ended up being committed. The variable name is less confusing and stores the default behavior when no matching exception exists. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25cgroup: fix invalid rcu dereferenceJiri Slaby
Commit ad676077a2ae ("device_cgroup: convert device_cgroup internally to policy + exceptions") removed rcu locks which are needed in task_devcgroup called in this chain: devcgroup_inode_mknod OR __devcgroup_inode_permission -> __devcgroup_inode_permission -> task_devcgroup -> task_subsys_state -> task_subsys_state_check. Change the code so that task_devcgroup is safely called with rcu read lock held. =============================== [ INFO: suspicious RCU usage. ] 3.6.0-rc5-next-20120913+ #42 Not tainted ------------------------------- include/linux/cgroup.h:553 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by kdevtmpfs/23: #0: (sb_writers){.+.+.+}, at: [<ffffffff8116873f>] mnt_want_write+0x1f/0x50 #1: (&sb->s_type->i_mutex_key#3/1){+.+.+.}, at: [<ffffffff811558af>] kern_path_create+0x7f/0x170 stack backtrace: Pid: 23, comm: kdevtmpfs Not tainted 3.6.0-rc5-next-20120913+ #42 Call Trace: lockdep_rcu_suspicious+0xfd/0x130 devcgroup_inode_mknod+0x19d/0x240 vfs_mknod+0x71/0xf0 handle_create.isra.2+0x72/0x200 devtmpfsd+0x114/0x140 ? handle_create.isra.2+0x200/0x200 kthread+0xd6/0xe0 kernel_thread_helper+0x4/0x10 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Dave Jones <davej@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-25apparmor: fix IRQ stack overflow during free_profileJohn Johansen
BugLink: http://bugs.launchpad.net/bugs/1056078 Profile replacement can cause long chains of profiles to build up when the profile being replaced is pinned. When the pinned profile is finally freed, it puts the reference to its replacement, which may in turn nest another call to free_profile on the stack. Because this may happen for each profile in the replacedby chain this can result in a recusion that causes the stack to overflow. Break this nesting by directly walking the chain of replacedby profiles (ie. use iteration instead of recursion to free the list). This results in at most 2 levels of free_profile being called, while freeing a replacedby chain. Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-10-17apparmor: fix apparmor OOPS in audit_log_untrustedstring+0x1c/0x40John Johansen
The capability defines have moved causing the auto generated names of capabilities that apparmor uses in logging to be incorrect. Fix the autogenerated table source to uapi/linux/capability.h Reported-by: YanHong <clouds.yan@gmail.com> Reported-by: Krzysztof Kolasa <kkolasa@winsoft.pl> Analyzed-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: John Johansen <john.johansen@canonical.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-16fix a leak in replace_fd() usersAl Viro
replace_fd() began with "eats a reference, tries to insert into descriptor table" semantics; at some point I'd switched it to much saner current behaviour ("try to insert into descriptor table, grabbing a new reference if inserted; caller should do fput() in any case"), but forgot to update the callers. Mea culpa... [Spotted by Pavel Roskin, who has really weird system with pipe-fed coredumps as part of what he considers a normal boot ;-)] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-11consitify do_mount() argumentsAl Viro
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: use mm->exe_file instead of first VM_EXECUTABLE vma->vm_fileKonstantin Khlebnikov
Some security modules and oprofile still uses VM_EXECUTABLE for retrieving a task's executable file. After this patch they will use mm->exe_file directly. mm->exe_file is protected with mm->mmap_sem, so locking stays the same. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [arch/tile] Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> [tomoyo] Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull IMA bugfix (security subsystem) from James Morris. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: ima: fix bug in argument order
2012-10-06device_cgroup: rename whitelist to exception listAristeu Rozanski
This patch replaces the "whitelist" usage in the code and comments and replace them by exception list related information. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: convert device_cgroup internally to policy + exceptionsAristeu Rozanski
The original model of device_cgroup is having a whitelist where all the allowed devices are listed. The problem with this approach is that is impossible to have the case of allowing everything but few devices. The reason for that lies in the way the whitelist is handled internally: since there's only a whitelist, the "all devices" entry would have to be removed and replaced by the entire list of possible devices but the ones that are being denied. Since dev_t is 32 bits long, representing the allowed devices as a bitfield is not memory efficient. This patch replaces the "whitelist" by a "exceptions" list and the default policy is kept as "deny_all" variable in dev_cgroup structure. The current interface determines that whenever "a" is written to devices.allow or devices.deny, the entry masking all devices will be added or removed, respectively. This behavior is kept and it's what will determine the default policy: # cat devices.list a *:* rwm # echo a >devices.deny # cat devices.list # echo a >devices.allow # cat devices.list a *:* rwm The interface is also preserved. For example, if one wants to block only access to /dev/null: # ls -l /dev/null crw-rw-rw- 1 root root 1, 3 Jul 24 16:17 /dev/null # echo a >devices.allow # echo "c 1:3 rwm" >devices.deny # cat /dev/null cat: /dev/null: Operation not permitted # echo >/dev/null bash: /dev/null: Operation not permitted mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 r" >devices.allow # cat /dev/null # echo >/dev/null bash: /dev/null: Operation not permitted mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 rw" >devices.allow # echo >/dev/null # cat /dev/null # mknod /tmp/null c 1 3 mknod: `/tmp/null': Operation not permitted # echo "c 1:3 rwm" >devices.allow # echo >/dev/null # cat /dev/null # mknod /tmp/null c 1 3 # Note that I didn't rename the functions/variables in this patch, but in the next one to make reviewing easier. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: introduce dev_whitelist_clean()Aristeu Rozanski
This function cleans all the items in a whitelist and will be used by the next patches. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06device_cgroup: add "deny_all" in dev_cgroup structureAristeu Rozanski
deny_all will determine if the default policy is to deny all device access unless for the ones in the exception list. This variable will be used in the next patches to convert device_cgroup internally into a default policy + rules. Signed-off-by: Aristeu Rozanski <aris@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: James Morris <jmorris@namei.org> Cc: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-05ima: fix bug in argument orderDmitry Kasatkin
mask argument goes first, then func, like ima_must_measure and ima_get_action. ima_inode_post_setattr() assumes that. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-10-04UAPI: (Scripted) Disintegrate include/asm-genericDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-02Merge branch 'for-3.7-hierarchy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup hierarchy update from Tejun Heo: "Currently, different cgroup subsystems handle nested cgroups completely differently. There's no consistency among subsystems and the behaviors often are outright broken. People at least seem to agree that the broken hierarhcy behaviors need to be weeded out if any progress is gonna be made on this front and that the fallouts from deprecating the broken behaviors should be acceptable especially given that the current behaviors don't make much sense when nested. This patch makes cgroup emit warning messages if cgroups for subsystems with broken hierarchy behavior are nested to prepare for fixing them in the future. This was put in a separate branch because more related changes were expected (didn't make it this round) and the memory cgroup wanted to pull in this and make changes on top." * 'for-3.7-hierarchy' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: mark subsystems with broken hierarchy support and whine if cgroups are nested for them
2012-10-02Merge branch 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "This is workqueue updates for v3.7-rc1. A lot of activities this round including considerable API and behavior cleanups. * delayed_work combines a timer and a work item. The handling of the timer part has always been a bit clunky leading to confusing cancelation API with weird corner-case behaviors. delayed_work is updated to use new IRQ safe timer and cancelation now works as expected. * Another deficiency of delayed_work was lack of the counterpart of mod_timer() which led to cancel+queue combinations or open-coded timer+work usages. mod_delayed_work[_on]() are added. These two delayed_work changes make delayed_work provide interface and behave like timer which is executed with process context. * A work item could be executed concurrently on multiple CPUs, which is rather unintuitive and made flush_work() behavior confusing and half-broken under certain circumstances. This problem doesn't exist for non-reentrant workqueues. While non-reentrancy check isn't free, the overhead is incurred only when a work item bounces across different CPUs and even in simulated pathological scenario the overhead isn't too high. All workqueues are made non-reentrant. This removes the distinction between flush_[delayed_]work() and flush_[delayed_]_work_sync(). The former is now as strong as the latter and the specified work item is guaranteed to have finished execution of any previous queueing on return. * In addition to the various bug fixes, Lai redid and simplified CPU hotplug handling significantly. * Joonsoo introduced system_highpri_wq and used it during CPU hotplug. There are two merge commits - one to pull in IRQ safe timer from tip/timers/core and the other to pull in CPU hotplug fixes from wq/for-3.6-fixes as Lai's hotplug restructuring depended on them." Fixed a number of trivial conflicts, but the more interesting conflicts were silent ones where the deprecated interfaces had been used by new code in the merge window, and thus didn't cause any real data conflicts. Tejun pointed out a few of them, I fixed a couple more. * 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits) workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending() workqueue: use cwq_set_max_active() helper for workqueue_set_max_active() workqueue: introduce cwq_set_max_active() helper for thaw_workqueues() workqueue: remove @delayed from cwq_dec_nr_in_flight() workqueue: fix possible stall on try_to_grab_pending() of a delayed work item workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback() workqueue: use __cpuinit instead of __devinit for cpu callbacks workqueue: rename manager_mutex to assoc_mutex workqueue: WORKER_REBIND is no longer necessary for idle rebinding workqueue: WORKER_REBIND is no longer necessary for busy rebinding workqueue: reimplement idle worker rebinding workqueue: deprecate __cancel_delayed_work() workqueue: reimplement cancel_delayed_work() using try_to_grab_pending() workqueue: use mod_delayed_work() instead of __cancel + queue workqueue: use irqsafe timer for delayed_work workqueue: clean up delayed_work initializers and add missing one workqueue: make deferrable delayed_work initializer names consistent workqueue: cosmetic whitespace updates for macro definitions workqueue: deprecate system_nrt[_freezable]_wq workqueue: deprecate flush[_delayed]_work_sync() ...
2012-10-01Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core kernel fixes from Ingo Molnar: "This is a complex task_work series from Oleg that fixes the bug that this VFS commit tried to fix: d35abdb28824 hold task_lock around checks in keyctl but solves the problem without the lockup regression that d35abdb28824 introduced in v3.6. This series came late in v3.6 and I did not feel confident about it so late in the cycle. Might be worth backporting to -stable if it proves itself upstream." * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: task_work: Simplify the usage in ptrace_notify() and get_signal_to_deliver() task_work: Revert "hold task_lock around checks in keyctl" task_work: task_work_add() should not succeed after exit_task_work() task_work: Make task_work_add() lockless
2012-10-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull the trivial tree from Jiri Kosina: "Tiny usual fixes all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) doc: fix old config name of kprobetrace fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc btrfs: fix the commment for the action flags in delayed-ref.h btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID vfs: fix kerneldoc for generic_fh_to_parent() treewide: fix comment/printk/variable typos ipr: fix small coding style issues doc: fix broken utf8 encoding nfs: comment fix platform/x86: fix asus_laptop.wled_type module parameter mfd: printk/comment fixes doc: getdelays.c: remember to close() socket on error in create_nl_socket() doc: aliasing-test: close fd on write error mmc: fix comment typos dma: fix comments spi: fix comment/printk typos in spi Coccinelle: fix typo in memdup_user.cocci tmiofb: missing NULL pointer checks tools: perf: Fix typo in tools/perf tools/testing: fix comment / output typos ...
2012-09-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/team/team.c drivers/net/usb/qmi_wwan.c net/batman-adv/bat_iv_ogm.c net/ipv4/fib_frontend.c net/ipv4/route.c net/l2tp/l2tp_netlink.c The team, fib_frontend, route, and l2tp_netlink conflicts were simply overlapping changes. qmi_wwan and bat_iv_ogm were of the "use HEAD" variety. With help from Antonio Quartulli. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-28Merge tag 'v3.6-rc7' into nextJames Morris
Linux 3.6-rc7 Requested by David Howells so he can merge his key susbsystem work into my tree with requisite -linus changesets.
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26new helper: iterate_fd()Al Viro
iterates through the opened files in given descriptor table, calling a supplied function; we stop once non-zero is returned. Callback gets struct file *, descriptor number and const void * argument passed to iterator. It is called with files->file_lock held, so it is not allowed to block. tty_io, netprio_cgroup and selinux flush_unauthorized_files() converted to its use. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26switch flush_unauthorized_files() to replace_fd()Al Viro
2012-09-21userns: Teach security_path_chown to take kuids and kgidsEric W. Biederman
Don't make the security modules deal with raw user space uid and gids instead pass in a kuid_t and a kgid_t so that security modules only have to deal with internal kernel uids and gids. Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: James Morris <james.l.morris@oracle.com> Cc: John Johansen <john.johansen@canonical.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Add user namespace support to IMAEric W. Biederman
Use kuid's in the IMA rules. When reporting the current uid in audit logs use from_kuid to get a usable value. Cc: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert EVM to deal with kuids and kgids in it's hmac computationEric W. Biederman
2012-09-21userns: Convert selinux to use kuid and kgid where appropriateEric W. Biederman
Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <james.l.morris@oracle.com> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-21userns: Convert tomoyo to use kuid and kgid where appropriateEric W. Biederman
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-21userns: Convert apparmor to use kuid and kgid where appropriateEric W. Biederman
Cc: John Johansen <john.johansen@canonical.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-19ima: change flags container data typeDmitry Kasatkin
IMA audit hashes patches introduced new IMA flags and required space went beyond 8 bits. Currently the only flag is IMA_DIGSIG. This patch use 16 bit short instead of 8 bit char. Without this fix IMA signature will be replaced with hash, which should not happen. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2012-09-18xfrm: invalidate dst on policy insertion/deletionNicolas Dichtel
When a policy is inserted or deleted, all dst should be recalculated. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18Smack: setprocattr memory leak fixCasey Schaufler
The data structure allocations being done in prepare_creds are duplicated in smack_setprocattr. This results in the structure allocated in prepare_creds being orphaned and never freed. The duplicate code is removed from smack_setprocattr. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2012-09-18Smack: implement revoking all rules for a subject labelRafal Krypa
Add /smack/revoke-subject special file. Writing a SMACK label to this file will set the access to '-' for all access rules with that subject label. Targeted for git://git.gitorious.org/smack-next/kernel.git Signed-off-by: Rafal Krypa <r.krypa@samsung.com>
2012-09-18Smack: remove task_wait() hook.Casey Schaufler
On 12/20/2011 11:20 PM, Jarkko Sakkinen wrote: > Allow SIGCHLD to be passed to child process without > explicit policy. This will help to keep the access > control policy simple and easily maintainable with > complex applications that require use of multiple > security contexts. It will also help to keep them > as isolated as possible. > > Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@intel.com> I have a slightly different version that applies to the current smack-next tree. Allow SIGCHLD to be passed to child process without explicit policy. This will help to keep the access control policy simple and easily maintainable with complex applications that require use of multiple security contexts. It will also help to keep them as isolated as possible. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> security/smack/smack_lsm.c | 37 ++++++++----------------------------- 1 files changed, 8 insertions(+), 29 deletions(-)
2012-09-14cgroup: mark subsystems with broken hierarchy support and whine if cgroups ↵Tejun Heo
are nested for them Currently, cgroup hierarchy support is a mess. cpu related subsystems behave correctly - configuration, accounting and control on a parent properly cover its children. blkio and freezer completely ignore hierarchy and treat all cgroups as if they're directly under the root cgroup. Others show yet different behaviors. These differing interpretations of cgroup hierarchy make using cgroup confusing and it impossible to co-mount controllers into the same hierarchy and obtain sane behavior. Eventually, we want full hierarchy support from all subsystems and probably a unified hierarchy. Users using separate hierarchies expecting completely different behaviors depending on the mounted subsystem is deterimental to making any progress on this front. This patch adds cgroup_subsys.broken_hierarchy and sets it to %true for controllers which are lacking in hierarchy support. The goal of this patch is two-fold. * Move users away from using hierarchy on currently non-hierarchical subsystems, so that implementing proper hierarchy support on those doesn't surprise them. * Keep track of which controllers are broken how and nudge the subsystems to implement proper hierarchy support. For now, start with a single warning message. We can whine louder later on. v2: Fixed a typo spotted by Michal. Warning message updated. v3: Updated memcg part so that it doesn't generate warning in the cases where .use_hierarchy=false doesn't make the behavior different from root.use_hierarchy=true. Fixed a typo spotted by Glauber. v4: Check ->broken_hierarchy after cgroup creation is complete so that ->create() can affect the result per Michal. Dropped unnecessary memcg root handling per Michal. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2012-09-13userns: Convert security/keys to the new userns infrastructureEric W. Biederman
- Replace key_user ->user_ns equality checks with kuid_has_mapping checks. - Use from_kuid to generate key descriptions - Use kuid_t and kgid_t and the associated helpers instead of uid_t and gid_t - Avoid potential problems with file descriptor passing by displaying keys in the user namespace of the opener of key status proc files. Cc: linux-security-module@vger.kernel.org Cc: keyrings@linux-nfs.org Cc: David Howells <dhowells@redhat.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-13ima: audit log hashesPeter Moody
This adds an 'audit' policy action which audit logs file measurements. Changelog v6: - use new action flag handling (Dmitry Kasatkin). - removed whitespace (Mimi) Changelog v5: - use audit_log_untrustedstring. Changelog v4: - cleanup digest -> hash conversion. - use filename rather than d_path in ima_audit_measurement. Changelog v3: - Use newly exported audit_log_task_info for logging pid/ppid/uid/etc. - Update the ima_policy ABI documentation. Changelog v2: - Use 'audit' action rather than 'measure_and_audit' to permit auditing in the absence of measuring.. Changelog v1: - Initial posting. Signed-off-by: Peter Moody <pmoody@google.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
