path: root/security
2014-04-30selinux: correctly label /proc inodes in use before the policy is loadedPaul Moore
commit f64410ec665479d7b4b77b7519e814253ed0f686 upstream. This patch is based on an earlier patch by Eric Paris, he describes the problem below: "If an inode is accessed before policy load it will get placed on a list of inodes to be initialized after policy load. After policy load we call inode_doinit() which calls inode_doinit_with_dentry() on all inodes accessed before policy load. In the case of inodes in procfs that means we'll end up at the bottom where it does: /* Default to the fs superblock SID. */ isec->sid = sbsec->sid; if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) { if (opt_dentry) { isec->sclass = inode_mode_to_security_class(...) rc = selinux_proc_get_sid(opt_dentry, isec->sclass, &sid); if (rc) goto out_unlock; isec->sid = sid; } } Since opt_dentry is null, we'll never call selinux_proc_get_sid() and will leave the inode labeled with the label on the superblock. I believe a fix would be to mimic the behavior of xattrs. Look for an alias of the inode. If it can't be found, just leave the inode uninitialized (and pick it up later) if it can be found, we should be able to call selinux_proc_get_sid() ..." On a system exhibiting this problem, you will notice a lot of files in /proc with the generic "proc_t" type (at least the ones that were accessed early in the boot), for example: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax However, with this patch in place we see the expected result: # ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }' system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02SELinux: bigendian problems with filename trans rulesEric Paris
commit 9085a6422900092886da8c404e1c5340c4ff1cbf upstream. When writing policy via /sys/fs/selinux/policy I wrote the type and class of filename trans rules in CPU endian instead of little endian. On x86_64 this works just fine, but it means that on big endian arch's like ppc64 and s390 userspace reads the policy and converts it from le32_to_cpu. So the values are all screwed up. Write the values in le format like it should have been to start. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02SELinux: Fix kernel BUG on empty security contexts.Stephen Smalley
commit 2172fa709ab32ca60e86179dc67d0857be8e2c98 upstream. Setting an empty security context (length=0) on a file will lead to incorrectly dereferencing the type and other fields of the security context structure, yielding a kernel BUG. As a zero-length security context is never valid, just reject all such security contexts whether coming from userspace via setxattr or coming from the filesystem upon a getxattr request by SELinux. Setting a security context value (empty or otherwise) unknown to SELinux in the first place is only possible for a root process (CAP_MAC_ADMIN), and, if running SELinux in enforcing mode, only if the corresponding SELinux mac_admin permission is also granted to the domain by policy. In Fedora policies, this is only allowed for specific domains such as livecd for setting down security contexts that are not defined in the build host policy. Reproducer: su setenforce 0 touch foo setfattr -n security.selinux foo Caveat: Relabeling or removing foo after doing the above may not be possible without booting with SELinux disabled. Any subsequent access to foo after doing the above will also trigger the BUG. BUG output from Matthew Thode: [ 473.893141] ------------[ cut here ]------------ [ 473.962110] kernel BUG at security/selinux/ss/services.c:654! [ 473.995314] invalid opcode: 0000 [#6] SMP [ 474.027196] Modules linked in: [ 474.058118] CPU: 0 PID: 8138 Comm: ls Tainted: G D I 3.13.0-grsec #1 [ 474.116637] Hardware name: Supermicro X8ST3/X8ST3, BIOS 2.0 07/29/10 [ 474.149768] task: ffff8805f50cd010 ti: ffff8805f50cd488 task.ti: ffff8805f50cd488 [ 474.183707] RIP: 0010:[<ffffffff814681c7>] [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 474.219954] RSP: 0018:ffff8805c0ac3c38 EFLAGS: 00010246 [ 474.252253] RAX: 0000000000000000 RBX: ffff8805c0ac3d94 RCX: 0000000000000100 [ 474.287018] RDX: ffff8805e8aac000 RSI: 00000000ffffffff RDI: ffff8805e8aaa000 [ 474.321199] RBP: ffff8805c0ac3cb8 R08: 0000000000000010 R09: 0000000000000006 [ 474.357446] R10: 0000000000000000 R11: ffff8805c567a000 R12: 0000000000000006 [ 474.419191] R13: ffff8805c2b74e88 R14: 00000000000001da R15: 0000000000000000 [ 474.453816] FS: 00007f2e75220800(0000) GS:ffff88061fc00000(0000) knlGS:0000000000000000 [ 474.489254] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 474.522215] CR2: 00007f2e74716090 CR3: 00000005c085e000 CR4: 00000000000207f0 [ 474.556058] Stack: [ 474.584325] ffff8805c0ac3c98 ffffffff811b549b ffff8805c0ac3c98 ffff8805f1190a40 [ 474.618913] ffff8805a6202f08 ffff8805c2b74e88 00068800d0464990 ffff8805e8aac860 [ 474.653955] ffff8805c0ac3cb8 000700068113833a ffff880606c75060 ffff8805c0ac3d94 [ 474.690461] Call Trace: [ 474.723779] [<ffffffff811b549b>] ? lookup_fast+0x1cd/0x22a [ 474.778049] [<ffffffff81468824>] security_compute_av+0xf4/0x20b [ 474.811398] [<ffffffff8196f419>] avc_compute_av+0x2a/0x179 [ 474.843813] [<ffffffff8145727b>] avc_has_perm+0x45/0xf4 [ 474.875694] [<ffffffff81457d0e>] inode_has_perm+0x2a/0x31 [ 474.907370] [<ffffffff81457e76>] selinux_inode_getattr+0x3c/0x3e [ 474.938726] [<ffffffff81455cf6>] security_inode_getattr+0x1b/0x22 [ 474.970036] [<ffffffff811b057d>] vfs_getattr+0x19/0x2d [ 475.000618] [<ffffffff811b05e5>] vfs_fstatat+0x54/0x91 [ 475.030402] [<ffffffff811b063b>] vfs_lstat+0x19/0x1b [ 475.061097] [<ffffffff811b077e>] SyS_newlstat+0x15/0x30 [ 475.094595] [<ffffffff8113c5c1>] ? __audit_syscall_entry+0xa1/0xc3 [ 475.148405] [<ffffffff8197791e>] system_call_fastpath+0x16/0x1b [ 475.179201] Code: 00 48 85 c0 48 89 45 b8 75 02 0f 0b 48 8b 45 a0 48 8b 3d 45 d0 b6 00 8b 40 08 89 c6 ff ce e8 d1 b0 06 00 48 85 c0 49 89 c7 75 02 <0f> 0b 48 8b 45 b8 4c 8b 28 eb 1e 49 8d 7d 08 be 80 01 00 00 e8 [ 475.255884] RIP [<ffffffff814681c7>] context_struct_compute_av+0xce/0x308 [ 475.296120] RSP <ffff8805c0ac3c38> [ 475.328734] ---[ end trace f076482e9d754adc ]--- Reported-by: Matthew Thode <mthode@mthode.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02SELinux: Fix memory leak upon loading policyTetsuo Handa
commit 8ed814602876bec9bad2649ca17f34b499357a1c upstream. Hello. I got below leak with linux-3.10.0-54.0.1.el7.x86_64 . [ 681.903890] kmemleak: 5538 new suspected memory leaks (see /sys/kernel/debug/kmemleak) Below is a patch, but I don't know whether we need special handing for undoing ebitmap_set_bit() call. ---------- >>From fe97527a90fe95e2239dfbaa7558f0ed559c0992 Mon Sep 17 00:00:00 2001 From: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Date: Mon, 6 Jan 2014 16:30:21 +0900 Subject: [PATCH] SELinux: Fix memory leak upon loading policy Commit 2463c26d "SELinux: put name based create rules in a hashtable" did not check return value from hashtab_insert() in filename_trans_read(). It leaks memory if hashtab_insert() returns error. unreferenced object 0xffff88005c9160d0 (size 8): comm "systemd", pid 1, jiffies 4294688674 (age 235.265s) hex dump (first 8 bytes): 57 0b 00 00 6b 6b 6b a5 W...kkk. backtrace: [<ffffffff816604ae>] kmemleak_alloc+0x4e/0xb0 [<ffffffff811cba5e>] kmem_cache_alloc_trace+0x12e/0x360 [<ffffffff812aec5d>] policydb_read+0xd1d/0xf70 [<ffffffff812b345c>] security_load_policy+0x6c/0x500 [<ffffffff812a623c>] sel_write_load+0xac/0x750 [<ffffffff811eb680>] vfs_write+0xc0/0x1f0 [<ffffffff811ec08c>] SyS_write+0x4c/0xa0 [<ffffffff81690419>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff However, we should not return EEXIST error to the caller, or the systemd will show below message and the boot sequence freezes. systemd[1]: Failed to load SELinux policy. Freezing. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02selinux: process labeled IPsec TCP SYN-ACK packets properly in ↵Paul Moore
selinux_ip_postroute() commit 5c6c26813a209e7075baf908e3ad81c1a9d389e8 upstream. Due to difficulty in arriving at the proper security label for TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets while/before they are undergoing XFRM transforms instead of waiting until afterwards so that we can determine the correct security label. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> [bwh: Backported to 3.2: s/selinux_peerlbl_enabled()/netlbl_enabled() || selinux_xfrm_enabled()/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-02-15SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
commit 3dc91d4338d698ce77832985f9cb183d8eeaf6be upstream. While running stress tests on adding and deleting ftrace instances I hit this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: selinux_inode_permission+0x85/0x160 PGD 63681067 PUD 7ddbe067 PMD 0 Oops: 0000 [#1] PREEMPT CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000 RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160 RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840 RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000 RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54 R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000 R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000 FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0 Call Trace: security_inode_permission+0x1c/0x30 __inode_permission+0x41/0xa0 inode_permission+0x18/0x50 link_path_walk+0x66/0x920 path_openat+0xa6/0x6c0 do_filp_open+0x43/0xa0 do_sys_open+0x146/0x240 SyS_open+0x1e/0x20 system_call_fastpath+0x16/0x1b Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff RIP selinux_inode_permission+0x85/0x160 CR2: 0000000000000020 Investigating, I found that the inode->i_security was NULL, and the dereference of it caused the oops. in selinux_inode_permission(): isec = inode->i_security; rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd); Note, the crash came from stressing the deletion and reading of debugfs files. I was not able to recreate this via normal files. But I'm not sure they are safe. It may just be that the race window is much harder to hit. What seems to have happened (and what I have traced), is the file is being opened at the same time the file or directory is being deleted. As the dentry and inode locks are not held during the path walk, nor is the inodes ref counts being incremented, there is nothing saving these structures from being discarded except for an rcu_read_lock(). The rcu_read_lock() protects against freeing of the inode, but it does not protect freeing of the inode_security_struct. Now if the freeing of the i_security happens with a call_rcu(), and the i_security field of the inode is not changed (it gets freed as the inode gets freed) then there will be no issue here. (Linus Torvalds suggested not setting the field to NULL such that we do not need to check if it is NULL in the permission check). Note, this is a hack, but it fixes the problem at hand. A real fix is to restructure the destroy_inode() to call all the destructor handlers from the RCU callback. But that is a major job to do, and requires a lot of work. For now, we just band-aid this bug with this fix (it works), and work on a more maintainable solution in the future. Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-02-15selinux: selinux_setprocattr()->ptrace_parent() needs rcu_read_lock()Oleg Nesterov
commit c0c1439541f5305b57a83d599af32b74182933fe upstream. selinux_setprocattr() does ptrace_parent(p) under task_lock(p), but task_struct->alloc_lock doesn't pin ->parent or ->ptrace, this looks confusing and triggers the "suspicious RCU usage" warning because ptrace_parent() does rcu_dereference_check(). And in theory this is wrong, spin_lock()->preempt_disable() doesn't necessarily imply rcu_read_lock() we need to access the ->parent. Reported-by: Evan McNabb <emcnabb@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-02-15selinux: fix broken peer recv checkChad Hanson
commit 46d01d63221c3508421dd72ff9c879f61053cffc upstream. Fix a broken networking check. Return an error if peer recv fails. If secmark is active and the packet recv succeeds the peer recv error is ignored. Signed-off-by: Chad Hanson <chanson@trustedcs.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()Paul Moore
commit 446b802437f285de68ffb8d6fac3c44c3cab5b04 upstream. In selinux_ip_postroute() we perform access checks based on the packet's security label. For locally generated traffic we get the packet's security label from the associated socket; this works in all cases except for TCP SYN-ACK packets. In the case of SYN-ACK packet's the correct security label is stored in the connection's request_sock, not the server's socket. Unfortunately, at the point in time when selinux_ip_postroute() is called we can't query the request_sock directly, we need to recreate the label using the same logic that originally labeled the associated request_sock. See the inline comments for more explanation. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()Paul Moore
commit 47180068276a04ed31d24fe04c673138208b07a9 upstream. In selinux_ip_output() we always label packets based on the parent socket. While this approach works in almost all cases, it doesn't work in the case of TCP SYN-ACK packets when the correct label is not the label of the parent socket, but rather the label of the larval socket represented by the request_sock struct. Unfortunately, since the request_sock isn't queued on the parent socket until *after* the SYN-ACK packet is sent, we can't lookup the request_sock to determine the correct label for the packet; at this point in time the best we can do is simply pass/NF_ACCEPT the packet. It must be said that simply passing the packet without any explicit labeling action, while far from ideal, is not terrible as the SYN-ACK packet will inherit any IP option based labeling from the initial connection request so the label *should* be correct and all our access controls remain in place so we shouldn't have to worry about information leaks. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Tested-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03selinux: correct locking in selinux_netlbl_socket_connect)Paul Moore
commit 42d64e1add3a1ce8a787116036163b8724362145 upstream. The SELinux/NetLabel glue code has a locking bug that affects systems with NetLabel enabled, see the kernel error message below. This patch corrects this problem by converting the bottom half socket lock to a more conventional, and correct for this call-path, lock_sock() call. =============================== [ INFO: suspicious RCU usage. ] 3.11.0-rc3+ #19 Not tainted ------------------------------- net/ipv4/cipso_ipv4.c:1928 suspicious rcu_dereference_protected() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by ping/731: #0: (slock-AF_INET/1){+.-...}, at: [...] selinux_netlbl_socket_connect #1: (rcu_read_lock){.+.+..}, at: [<...>] netlbl_conn_setattr stack backtrace: CPU: 1 PID: 731 Comm: ping Not tainted 3.11.0-rc3+ #19 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 0000000000000001 ffff88006f659d28 ffffffff81726b6a ffff88003732c500 ffff88006f659d58 ffffffff810e4457 ffff88006b845a00 0000000000000000 000000000000000c ffff880075aa2f50 ffff88006f659d90 ffffffff8169bec7 Call Trace: [<ffffffff81726b6a>] dump_stack+0x54/0x74 [<ffffffff810e4457>] lockdep_rcu_suspicious+0xe7/0x120 [<ffffffff8169bec7>] cipso_v4_sock_setattr+0x187/0x1a0 [<ffffffff8170f317>] netlbl_conn_setattr+0x187/0x190 [<ffffffff8170f195>] ? netlbl_conn_setattr+0x5/0x190 [<ffffffff8131ac9e>] selinux_netlbl_socket_connect+0xae/0xc0 [<ffffffff81303025>] selinux_socket_connect+0x135/0x170 [<ffffffff8119d127>] ? might_fault+0x57/0xb0 [<ffffffff812fb146>] security_socket_connect+0x16/0x20 [<ffffffff815d3ad3>] SYSC_connect+0x73/0x130 [<ffffffff81739a85>] ? sysret_check+0x22/0x5d [<ffffffff810e5e2d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [<ffffffff81373d4e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff815d52be>] SyS_connect+0xe/0x10 [<ffffffff81739a59>] system_call_fastpath+0x16/0x1b Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-10key: Fix resource leakAlan Cox
commit a84a921978b7d56e0e4b87ffaca6367429b4d8ff upstream. On an error iov may still have been reallocated and need freeing Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27selinux: use GFP_ATOMIC under spin_lockDan Carpenter
commit 4502403dcf8f5c76abd4dbab8726c8e4ecb5cd34 upstream. The call tree here is: sk_clone_lock() <- takes bh_lock_sock(newsk); xfrm_sk_clone_policy() __xfrm_sk_clone_policy() clone_policy() <- uses GFP_ATOMIC for allocations security_xfrm_policy_clone() security_ops->xfrm_policy_clone_security() selinux_xfrm_policy_clone() Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-20Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream. Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-20keys: fix race with concurrent install_user_keyrings()David Howells
commit 0da9dfdd2cd9889201bc6f6f43580c99165cd087 upstream. This fixes CVE-2013-1792. There is a race in install_user_keyrings() that can cause a NULL pointer dereference when called concurrently for the same user if the uid and uid-session keyrings are not yet created. It might be possible for an unprivileged user to trigger this by calling keyctl() from userspace in parallel immediately after logging in. Assume that we have two threads both executing lookup_user_key(), both looking for KEY_SPEC_USER_SESSION_KEYRING. THREAD A THREAD B =============================== =============================== ==>call install_user_keyrings(); if (!cred->user->session_keyring) ==>call install_user_keyrings() ... user->uid_keyring = uid_keyring; if (user->uid_keyring) return 0; <== key = cred->user->session_keyring [== NULL] user->session_keyring = session_keyring; atomic_inc(&key->usage); [oops] At the point thread A dereferences cred->user->session_keyring, thread B hasn't updated user->session_keyring yet, but thread A assumes it is populated because install_user_keyrings() returned ok. The race window is really small but can be exploited if, for example, thread B is interrupted or preempted after initializing uid_keyring, but before doing setting session_keyring. This couldn't be reproduced on a stock kernel. However, after placing systemtap probe on 'user->session_keyring = session_keyring;' that introduced some delay, the kernel could be crashed reliably. Fix this by checking both pointers before deciding whether to return. Alternatively, the test could be done away with entirely as it is checked inside the mutex - but since the mutex is global, that may not be the best way. Signed-off-by: David Howells <dhowells@redhat.com> Reported-by: Mateusz Guzik <mguzik@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-02-06evm: checking if removexattr is not a NULLDmitry Kasatkin
commit a67adb997419fb53540d4a4f79c6471c60bc69b6 upstream. The following lines of code produce a kernel oops. fd = socket(PF_FILE, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0); fchmod(fd, 0666); [ 139.922364] BUG: unable to handle kernel NULL pointer dereference at (null) [ 139.924982] IP: [< (null)>] (null) [ 139.924982] *pde = 00000000 [ 139.924982] Oops: 0000 [#5] SMP [ 139.924982] Modules linked in: fuse dm_crypt dm_mod i2c_piix4 serio_raw evdev binfmt_misc button [ 139.924982] Pid: 3070, comm: acpid Tainted: G D 3.8.0-rc2-kds+ #465 Bochs Bochs [ 139.924982] EIP: 0060:[<00000000>] EFLAGS: 00010246 CPU: 0 [ 139.924982] EIP is at 0x0 [ 139.924982] EAX: cf5ef000 EBX: cf5ef000 ECX: c143d600 EDX: c15225f2 [ 139.924982] ESI: cf4d2a1c EDI: cf4d2a1c EBP: cc02df10 ESP: cc02dee4 [ 139.924982] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 139.924982] CR0: 80050033 CR2: 00000000 CR3: 0c059000 CR4: 000006d0 [ 139.924982] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 139.924982] DR6: ffff0ff0 DR7: 00000400 [ 139.924982] Process acpid (pid: 3070, ti=cc02c000 task=d7705340 task.ti=cc02c000) [ 139.924982] Stack: [ 139.924982] c1203c88 00000000 cc02def4 cf4d2a1c ae21eefa 471b60d5 1083c1ba c26a5940 [ 139.924982] e891fb5e 00000041 00000004 cc02df1c c1203964 00000000 cc02df4c c10e20c3 [ 139.924982] 00000002 00000000 00000000 22222222 c1ff2222 cf5ef000 00000000 d76efb08 [ 139.924982] Call Trace: [ 139.924982] [<c1203c88>] ? evm_update_evmxattr+0x5b/0x62 [ 139.924982] [<c1203964>] evm_inode_post_setattr+0x22/0x26 [ 139.924982] [<c10e20c3>] notify_change+0x25f/0x281 [ 139.924982] [<c10cbf56>] chmod_common+0x59/0x76 [ 139.924982] [<c10e27a1>] ? put_unused_fd+0x33/0x33 [ 139.924982] [<c10cca09>] sys_fchmod+0x39/0x5c [ 139.924982] [<c13f4f30>] syscall_call+0x7/0xb [ 139.924982] Code: Bad EIP value. This happens because sockets do not define the removexattr operation. Before removing the xattr, verify the removexattr function pointer is not NULL. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03Revert "device_cgroup: fix RCU usage"Ben Hutchings
This reverts commit c5ee58688baa98bc3a4f6095a1acf6fd7fd9e967, which was commit 201e72acb2d3821e2de9ce6091e98859c316b29a upstream. Herton Ronaldo Krzesinski pointed out that the race condition this dealt with does not exist in 3.2.y. Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06selinux: fix sel_netnode_insert() suspicious rcu dereferenceDave Jones
commit 88a693b5c1287be4da937699cb82068ce9db0135 upstream. =============================== [ INFO: suspicious RCU usage. ] 3.5.0-rc1+ #63 Not tainted ------------------------------- security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by trinity-child1/8750: #0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0 stack backtrace: Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63 Call Trace: [<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0 [<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0 [<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0 [<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0 [<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60 [<ffffffff812c9536>] security_socket_bind+0x16/0x20 [<ffffffff815550ca>] sys_bind+0x7a/0x100 [<ffffffff816c03d5>] ? sysret_check+0x22/0x5d [<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0 [<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b This patch below does what Paul McKenney suggested in the previous thread. Signed-off-by: Dave Jones <davej@redhat.com> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-12-06device_cgroup: fix RCU usageTejun Heo
commit 201e72acb2d3821e2de9ce6091e98859c316b29a upstream. dev_cgroup->exceptions is protected with devcgroup_mutex for writes and RCU for reads; however, RCU usage isn't correct. * dev_exception_clean() doesn't use RCU variant of list_del() and kfree(). The function can race with may_access() and may_access() may end up dereferencing already freed memory. Use list_del_rcu() and kfree_rcu() instead. * may_access() may be called only with RCU read locked but doesn't use RCU safe traversal over ->exceptions. Use list_for_each_entry_rcu(). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Cc: Aristeu Rozanski <aris@redhat.com> Cc: Li Zefan <lizefan@huawei.com> [bwh: Backported to 3.2: - Adjust context - Exception list is called whitelist] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31SELinux: if sel_make_bools errors don't leave inconsistent stateEric Paris
commit 154c50ca4eb9ae472f50b6a481213e21ead4457d upstream. We reset the bool names and values array to NULL, but do not reset the number of entries in these arrays to 0. If we error out and then get back into this function we will walk these NULL pointers based on the belief that they are non-zero length. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-04-22security: fix compile error in commoncap.cJonghwan Choi
commit 51b79bee627d526199b2f6a6bef8ee0c0739b6d1 upstream. Add missing "personality.h" security/commoncap.c: In function 'cap_bprm_set_creds': security/commoncap.c:510: error: 'PER_CLEAR_ON_SETID' undeclared (first use in this function) security/commoncap.c:510: error: (Each undeclared identifier is reported only once security/commoncap.c:510: error: for each function it appears in.) Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-22fcaps: clear the same personality flags as suid when fcaps are usedEric Paris
commit d52fc5dde171f030170a6cb78034d166b13c9445 upstream. If a process increases permissions using fcaps all of the dangerous personality flags which are cleared for suid apps should also be cleared. Thus programs given priviledge with fcaps will continue to have address space randomization enabled even if the parent tried to disable it to make it easier to attack. Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13TOMOYO: Fix mount flags checking order.Tetsuo Handa
commit df91e49477a9be15921cb2854e1d12a3bdb5e425 upstream. Userspace can pass in arbitrary combinations of MS_* flags to mount(). If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are passed, device name which should be checked for MS_BIND was not checked because MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND. If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had higher priority than MS_REMOUNT. Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND -> MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does. Also, unconditionally return -EINVAL if more than one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount flags passed to change_mnt_propagation()" clarified that these flags must be exclusively passed. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02ima: fix Kconfig dependenciesFabio Estevam
commit f4a0391dfa91155bd961673b31eb42d9d45c799d upstream. Fix the following build warning: warning: (IMA) selects TCG_TPM which has unmet direct dependencies (HAS_IOMEM && EXPERIMENTAL) Suggested-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29Security: tomoyo: add .gitignore fileGreg Kroah-Hartman
commit 735e93c70434614bffac4a914ca1da72e37d43c0 upstream. This adds the .gitignore file for the autogenerated TOMOYO files to keep git from complaining after building things. Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: James Morris <jmorris@namei.org> Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-25TOMOYO: Accept \000 as a valid character.Tetsuo Handa
commit 25add8cf99c9ec8b8dc0acd8b9241e963fc0d29c upstream. TOMOYO 2.5 in Linux 3.2 and later handles Unix domain socket's address. Thus, tomoyo_correct_word2() needs to accept \000 as a valid character, or TOMOYO 2.5 cannot handle Unix domain's abstract socket address. Reported-by: Steven Allen <steven@stebalien.com> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25ima: fix invalid memory referenceRoberto Sassu
commit 7b7e5916aa2f46e57f8bd8cb89c34620ebfda5da upstream. Don't free a valid measurement entry on TPM PCR extend failure. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-25ima: free duplicate measurement memoryRoberto Sassu
commit 45fae7493970d7c45626ccd96d4a74f5f1eea5a9 upstream. Info about new measurements are cached in the iint for performance. When the inode is flushed from cache, the associated iint is flushed as well. Subsequent access to the inode will cause the inode to be re-measured and will attempt to add a duplicate entry to the measurement list. This patch frees the duplicate measurement memory, fixing a memory leak. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-03security: Fix security_old_inode_init_security() when CONFIG_SECURITY is not setJan Kara
Commit 1e39f384bb01 ("evm: fix build problems") makes the stub version of security_old_inode_init_security() return 0 when CONFIG_SECURITY is not set. But that makes callers such as reiserfs_security_init() assume that security_old_inode_init_security() has set name, value, and len arguments properly - but security_old_inode_init_security() left them uninitialized which then results in interesting failures. Revert security_old_inode_init_security() to the old behavior of returning EOPNOTSUPP since both callers (reiserfs and ocfs2) handle this just fine. [ Also fixed the S_PRIVATE(inode) case of the actual non-stub security_old_inode_init_security() function to return EOPNOTSUPP for the same reason, as pointed out by Mimi Zohar. It got incorrectly changed to match the new function in commit fb88c2b6cbb1: "evm: fix security/security_old_init_security return code". - Linus ] Reported-by: Jorge Bastos <mysql.jorge@decimal.pt> Acked-by: James Morris <jmorris@namei.org> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-21SELinux: Fix RCU deref check warning in sel_netport_insert()David Howells
Fix the following bug in sel_netport_insert() where rcu_dereference() should be rcu_dereference_protected() as sel_netport_lock is held. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- security/selinux/netport.c:127 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by ossec-rootcheck/3323: #0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226 stack backtrace: Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095 Call Trace: [<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0 [<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226 [<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc [<ffffffff8117556c>] selinux_socket_bind+0x115/0x230 [<ffffffff810a5388>] ? might_fault+0x4e/0x9e [<ffffffff810a53d1>] ? might_fault+0x97/0x9e [<ffffffff81171cf4>] security_socket_bind+0x11/0x13 [<ffffffff812ba967>] sys_bind+0x56/0x95 [<ffffffff81380dac>] ? sysret_check+0x27/0x62 [<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155 [<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae [<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-12-20evm: prevent racing during tfm allocationDmitry Kasatkin
There is a small chance of racing during tfm allocation. This patch fixes it. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-12-20evm: key must be set once during initializationDmitry Kasatkin
On multi-core systems, setting of the key before every caclculation, causes invalid HMAC calculation for other tfm users, because internal state (ipad, opad) can be invalid before set key call returns. It needs to be set only once during initialization. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Acked-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-12-08TOMOYO: Fix pathname handling of disconnected paths.Tetsuo Handa
Current tomoyo_realpath_from_path() implementation returns strange pathname when calculating pathname of a file which belongs to lazy unmounted tree. Use local pathname rather than strange absolute pathname in that case. Also, this patch fixes a regression by commit 02125a82 "fix apparmor dereferencing potentially freed dentry, sanitize __d_path() API". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-06fix apparmor dereferencing potentially freed dentry, sanitize __d_path() APIAl Viro
__d_path() API is asking for trouble and in case of apparmor d_namespace_path() getting just that. The root cause is that when __d_path() misses the root it had been told to look for, it stores the location of the most remote ancestor in *root. Without grabbing references. Sure, at the moment of call it had been pinned down by what we have in *path. And if we raced with umount -l, we could have very well stopped at vfsmount/dentry that got freed as soon as prepend_path() dropped vfsmount_lock. It is safe to compare these pointers with pre-existing (and known to be still alive) vfsmount and dentry, as long as all we are asking is "is it the same address?". Dereferencing is not safe and apparmor ended up stepping into that. d_namespace_path() really wants to examine the place where we stopped, even if it's not connected to our namespace. As the result, it looked at ->d_sb->s_magic of a dentry that might've been already freed by that point. All other callers had been careful enough to avoid that, but it's really a bad interface - it invites that kind of trouble. The fix is fairly straightforward, even though it's bigger than I'd like: * prepend_path() root argument becomes const. * __d_path() is never called with NULL/NULL root. It was a kludge to start with. Instead, we have an explicit function - d_absolute_root(). Same as __d_path(), except that it doesn't get root passed and stops where it stops. apparmor and tomoyo are using it. * __d_path() returns NULL on path outside of root. The main caller is show_mountinfo() and that's precisely what we pass root for - to skip those outside chroot jail. Those who don't want that can (and do) use d_path(). * __d_path() root argument becomes const. Everyone agrees, I hope. * apparmor does *NOT* try to use __d_path() or any of its variants when it sees that path->mnt is an internal vfsmount. In that case it's definitely not mounted anywhere and dentry_path() is exactly what we want there. Handling of sysctl()-triggered weirdness is moved to that place. * if apparmor is asked to do pathname relative to chroot jail and __d_path() tells it we it's not in that jail, the sucker just calls d_absolute_path() instead. That's the other remaining caller of __d_path(), BTW. * seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway - the normal seq_file logics will take care of growing the buffer and redoing the call of ->show() just fine). However, if it gets path not reachable from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped ignoring the return value as it used to do). Reviewed-by: John Johansen <john.johansen@canonical.com> ACKed-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org
2011-11-18Merge branch 'encrypted-key-fixes' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/linux-integrity into for-linus
2011-11-18Merge branch 'for-1111' of git://gitorious.org/smack-next/kernel into for-linusJames Morris
2011-11-16encrypted-keys: module build fixesMimi Zohar
Encrypted keys are encrypted/decrypted using either a trusted or user-defined key type, which is referred to as the 'master' key. The master key may be of type trusted iff the trusted key is builtin or both the trusted key and encrypted keys are built as modules. This patch resolves the build dependency problem. - Use "masterkey-$(CONFIG_TRUSTED_KEYS)-$(CONFIG_ENCRYPTED_KEYS)" construct to encapsulate the above logic. (Suggested by Dimtry Kasatkin.) - Fixing the encrypted-keys Makefile, results in a module name change from encrypted.ko to encrypted-keys.ko. - Add module dependency for request_trusted_key() definition Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-11-16encrypted-keys: fix error return codeMimi Zohar
Fix request_master_key() error return code. Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-11-15KEYS: Fix a NULL pointer deref in the user-defined key typeDavid Howells
Fix a NULL pointer deref in the user-defined key type whereby updating a negative key into a fully instantiated key will cause an oops to occur when the code attempts to free the non-existent old payload. This results in an oops that looks something like the following: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff81085fa1>] __call_rcu+0x11/0x13e PGD 3391d067 PUD 3894a067 PMD 0 Oops: 0002 [#1] SMP CPU 1 Pid: 4354, comm: keyctl Not tainted 3.1.0-fsdevel+ #1140 /DG965RY RIP: 0010:[<ffffffff81085fa1>] [<ffffffff81085fa1>] __call_rcu+0x11/0x13e RSP: 0018:ffff88003d591df8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000006e RDX: ffffffff8161d0c0 RSI: 0000000000000000 RDI: 0000000000000000 RBP: ffff88003d591e18 R08: 0000000000000000 R09: ffffffff8152fa6c R10: 0000000000000000 R11: 0000000000000300 R12: ffff88003b8f9538 R13: ffffffff8161d0c0 R14: ffff88003b8f9d50 R15: ffff88003c69f908 FS: 00007f97eb18c720(0000) GS:ffff88003bd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000008 CR3: 000000003d47a000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process keyctl (pid: 4354, threadinfo ffff88003d590000, task ffff88003c78a040) Stack: ffff88003e0ffde0 ffff88003b8f9538 0000000000000001 ffff88003b8f9d50 ffff88003d591e28 ffffffff810860f0 ffff88003d591e68 ffffffff8117bfea ffff88003d591e68 ffffffff00000000 ffff88003e0ffde1 ffff88003e0ffde0 Call Trace: [<ffffffff810860f0>] call_rcu_sched+0x10/0x12 [<ffffffff8117bfea>] user_update+0x8d/0xa2 [<ffffffff8117723a>] key_create_or_update+0x236/0x270 [<ffffffff811789b1>] sys_add_key+0x123/0x17e [<ffffffff813b84bb>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Horman <nhorman@redhat.com> Acked-by: Steve Dickson <steved@redhat.com> Acked-by: James Morris <jmorris@namei.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-11Smack: smackfs cipso seq read repairCasey Schaufler
Commit 272cd7a8c67dd40a31ecff76a503bbb84707f757 introduced a change to the way rule lists are handled and reported in the smackfs filesystem. One of the issues addressed had to do with the termination of read requests on /smack/load. This change introduced a error in /smack/cipso, which shares some of the same list processing code. This patch updates all the file access list handling in smackfs to use the code introduced for /smack/load. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-02Merge branch 'for-linus' of git://git.selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://git.selinuxproject.org/~jmorris/linux-security: TOMOYO: Fix interactive judgment functionality.
2011-11-02Merge branch 'for-linus' of git://github.com/richardweinberger/linuxLinus Torvalds
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits) um: fix ubd cow size um: Fix kmalloc argument order in um/vdso/vma.c um: switch to use of drivers/Kconfig UserModeLinux-HOWTO.txt: fix a typo UserModeLinux-HOWTO.txt: remove ^H characters um: we need sys/user.h only on i386 um: merge delay_{32,64}.c um: distribute exports to where exported stuff is defined um: kill system-um.h um: generic ftrace.h will do... um: segment.h is x86-only and needed only there um: asm/pda.h is not needed anymore um: hw_irq.h can go generic as well um: switch to generic-y um: clean Kconfig up a bit um: a couple of missing dependencies... um: kill useless argument of free_chan() and free_one_chan() um: unify ptrace_user.h um: unify KSTK_... um: fix gcov build breakage ...
2011-11-02um: switch to use of drivers/KconfigAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-10-31security: follow rename pack_hex_byte() to hex_byte_pack()Andy Shevchenko
There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31selinux: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
The pervasive, but implicit presence of <linux/module.h> meant that things like this file would happily compile as-is. But with the desire to phase out the module.h being included everywhere, point this file at export.h which will give it THIS_MODULE and the EXPORT_SYMBOL variants. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-29TOMOYO: Fix interactive judgment functionality.Tetsuo Handa
Commit 17fcfbd9 "TOMOYO: Add interactive enforcing mode." introduced ability to query access decision using userspace programs. It was using global PID for reaching policy configuration of the process. However, use of PID returns stale policy configuration when the process's subjective credentials and objective credentials differ. Fix this problem by allowing reaching policy configuration via query id. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-10-25Merge branch 'next' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'next' of git://selinuxproject.org/~jmorris/linux-security: (95 commits) TOMOYO: Fix incomplete read after seek. Smack: allow to access /smack/access as normal user TOMOYO: Fix unused kernel config option. Smack: fix: invalid length set for the result of /smack/access Smack: compilation fix Smack: fix for /smack/access output, use string instead of byte Smack: domain transition protections (v3) Smack: Provide information for UDS getsockopt(SO_PEERCRED) Smack: Clean up comments Smack: Repair processing of fcntl Smack: Rule list lookup performance Smack: check permissions from user space (v2) TOMOYO: Fix quota and garbage collector. TOMOYO: Remove redundant tasklist_lock. TOMOYO: Fix domain transition failure warning. TOMOYO: Remove tomoyo_policy_memory_lock spinlock. TOMOYO: Simplify garbage collector. TOMOYO: Fix make namespacecheck warnings. target: check hex2bin result encrypted-keys: check hex2bin result ...
2011-10-22Merge branch 'master' of git://gitorious.org/smack-next/kernel into nextJames Morris
